Zdravim, narazil som na maly problemik s modraskom 1.1, po zapojeni Netbox-ieho internetu 100/100mbit (troma roznymi straight kablami) do WAN interfacu, port zostal dole (NO LINK). Testoval som nejaky TP-link z rovnakou MAC adresou na WAN ako ma Turris, a ten bezal bez problemov (tj. internet+kabel su OK?). Router je po factory resete, skusane s TOS3.11.2x a aktualne na 5.1.8, ziadna zmena, stale nedetekuje zapojeny kabel vo WAN porte.
Volal som na support Netbox-u, nemaju skusenosti s danou situaciou, ale su schopny pomoc, ak pridem s riesenim, co pozmenit v konfiguracii na ich strane.
Som vdacny za kazdy napad, ako to vyrisiet, pretoze mne uz dosli a nemam vela skusenosti s troubleshootingom L1/L2 problemov.
root@turris:~# ip link show eth2
eth2: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN mode DEFAULT group default qlen 1000
link/ether d8:58:d7:00:19:85 brd ff:ff:ff:ff:ff:ff
root@turris:~# ifconfig eth2
eth2 Link encap:Ethernet HWaddr D8:58:D7:00:19:85
inet6 addr: fe80::da58:d7ff:fe00:1985/64 Scope:Link
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:20711 errors:0 dropped:0 overruns:0 frame:0
TX packets:8833 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:18552550 (17.6 MiB) TX bytes:1204795 (1.1 MiB)
Base address:0xd000
root@turris:~# ethtool eth2
Settings for eth2:
Supported ports: [ MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: No
Speed: 10Mb/s
Duplex: Half
Port: MII
PHYAD: 7
Transceiver: internal
Auto-negotiation: on
Current message level: 0x0000003f (63)
drv probe link timer ifdown ifup
Link detected: no
