You can either use SFP or RJ45, not both at the same time.
If you want to change which port is active, use the search functionality on this forum for the command that needs to be issued via ssh. After using this command you need to reboot.
Will not do this now, as I am still on VDSL and it will take about one more year until fiber internet is finally available here.
But I was able to connect to the device after plugging it into my switch SFP port, so at least it is working.
Can someone confirm if fiber internet is working with the module? It’s the Zyxel PMG3000-D20B, marketed by germany’s biggest ISP, Deutsche Telekom, for their business customers.
