could you please share a picture how TO Wall mount can be attached to the router?
Thank you
Thank you
Good stuff - wanna post it here also?
Is this position of antennas is better? Because I made them vertically i.e. pointed to the bottom.
Or maybe you are using the router to radiate vertically on other floors?
I honestly don’t think it matters in my case, it’s a 2 story structure, and the floors are about 65’x65’. If anything it might provide a little bit of differential for multiple antennas for signal. I haven’t looked into whether or not it actually helps.
Actually setting antennas vertical+horizontal is better. 3D(xyz axis) is even better if there is at least 3 antennas for the wifi adapter.
