my TO is running behind a provider Router (FTTH HG8045Q) and I can not get VPN running. Actually I recently moved, and with the previous router I set up SoftEther and it worked. However, the same installation doesn’t now (they gave me the newer router model above).
Is set the TO to DMZ in the HG8045Q (192.168.11.1), so all traffic should reach the TO (192.168.11.3 on WAN).
The SoftEther LXC and all other devices are connected to the TO and its LAN on 192.168.1.XXX.
I tried SoftEther and the new OpenVPN feature from Foris. Setup works as described. Then I set my fix IP in the file and try to connect but it doesn’t work. BTW reset my TO recently so everything is pretty untouched as I have aeverything runningin my LXC containers.
Are there any test I could try to check if connection is possible?
That were my thoughts too, and I tried to do port forwarding, but that also did not change anything. Thats why I asked above, how can I actually test if I can reach my TO from outside on a port?
BTW the provided router has no bridge mode setting
Well, but it shows all ports as closed. I looked my router up and found several manuals for port opening and I think everything is correct. However the TO is not reachable.
How can I check if the connection request/attempt is reaching the TO?
Is it correct that the foris gui openvpn doesnt create an entry in the firewall of luci?
Edit: oh I found an entry in the “Firewall - Traffic Rules” so that looks good too.
so your openvpn is not listening on 1194
i just remembered that port check might very well not detect UDP ports like 1194 but never the less you openvpn is not working , at least not on 1194
