I have setup my MOX behind a Fritzbox and want to have Voice-over-Wifi working.
I enabled PPPoE in the FB and automatic port opening, so I can control stuff from the MOX.
Does the MOX even support this? Is this ISP specific?
Thanks!
Thanks!
No, VoWifi is not (ap)-device-specific. Your smartphone and your mobile ISP need to support it.
Should work out of the box with MOX/TO (at least it did and does for me).
Ok it seems that Wifi calling (outwards) works perfectly fine!
I will have to see if I can get calls too.
(Using a Google Pixel with GrapheneOS)
