Hey,
I have problems using the Turris Omnia on my Vodafone DSL connection.
Setup:
I am using the Turris Omnia with the Draytec Vigor167 as Modem.
Problem description:
I got different credentials for a dynamic ip and for the static ip. It does work on the turris omnia with the credentials for the dynamic IP (at least for IPv4), but it doesn’t work with the credentials for the static IP.
What I tried:
I also tried it with the FritzBox Router which was provided to me by Vodafone and here the static IP does work, so the credentials seam to be all right.
I tried to use the FritzBox with the Draytec as modem, to make sure this isn’t somehow the issue, and that worked as well.
Configuring the MAC-Adress of the FritzBox at the turris omnia didn’t help either.
Log File:
Here is what I think is the relevant part of the log file. If you need anything else, please let me know.
Sep 5 16:21:55 turris netifd: Interface 'wan' has link connectivity
Sep 5 16:22:00 turris pppd[14041]: Plugin rp-pppoe.so loaded.
Sep 5 16:22:00 turris pppd[14041]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Sep 5 16:22:00 turris pppd[14041]: pppd 2.4.8 started by root, uid 0
Sep 5 16:22:00 turris pppd[14041]: PPP session is 5901
Sep 5 16:22:00 turris pppd[14041]: Connected to 40:7c:7d:dd:b4:a8 via interface eth2.7
Sep 5 18:22:00 turris kernel: [ 1609.253795] pppoe-wan: renamed from ppp0
Sep 5 16:22:00 turris pppd[14041]: Renamed interface ppp0 to pppoe-wan
Sep 5 16:22:00 turris pppd[14041]: Using interface pppoe-wan
Sep 5 16:22:00 turris pppd[14041]: Connect: pppoe-wan <--> eth2.7
Sep 5 16:22:05 turris pppd[14041]: No response to 5 echo-requests
Sep 5 16:22:05 turris pppd[14041]: Serial link appears to be disconnected.
Sep 5 16:22:05 turris pppd[14041]: Connection terminated.
Sep 5 16:22:05 turris pppd[14041]: Sent PADT
Sep 5 16:22:05 turris pppd[14041]: Exit.
Sep 5 16:22:05 turris netifd: Interface 'wan' is now down
Sep 5 18:22:06 turris kernel: [ 1614.500514] mvneta f1034000.ethernet eth2: Link is Down
Sep 5 16:22:06 turris netifd: Interface 'wan' is disabled
Anyone an idea what the issue might be?
