It seems you can’t create a VLAN anymore? Can this feature be added? I’ve used this before to separate different networks (guest wireless on other VLAN).
The development repo noted that this feature won’t be added unless people are using this. Well, I use this.
this is not true, you can still use VLANs both on the WAN port (nothing changed) and on LAN ports. Starting from Turris OS 4.0 VLAN config was switched from swconfig to dsa (because underlying OpenWRT changed it, no decision by Turris). Search this forum for the keyword „dsa“ to find relevant threads … (There are some ups and downs related to this change which I won‘t repeat here, just see related threads)
