Very unstable WiFi
Maybe driver for radio1 is busted.
I thought so before. Seems it is the faulty ath9k driver.
Can’t wait for the fix… Will it ever be?
Pinging my Samsung Note 4 or other smartphone on Wlan1 give me this (device located by the router):
root@Turris_Omnia:~# ping 10.10.10.7
PING 10.10.10.7 (10.10.10.7): 56 data bytes
64 bytes from 10.10.10.7: seq=1 ttl=64 time=794.768 ms
64 bytes from 10.10.10.7: seq=4 ttl=64 time=14094.698 ms
64 bytes from 10.10.10.7: seq=5 ttl=64 time=13094.664 ms
64 bytes from 10.10.10.7: seq=6 ttl=64 time=12094.618 ms
64 bytes from 10.10.10.7: seq=7 ttl=64 time=11095.282 ms
64 bytes from 10.10.10.7: seq=8 ttl=64 time=10095.241 ms
64 bytes from 10.10.10.7: seq=9 ttl=64 time=9095.179 ms
64 bytes from 10.10.10.7: seq=10 ttl=64 time=8095.132 ms
64 bytes from 10.10.10.7: seq=11 ttl=64 time=7095.694 ms
64 bytes from 10.10.10.7: seq=12 ttl=64 time=6095.648 ms
64 bytes from 10.10.10.7: seq=13 ttl=64 time=5095.568 ms
64 bytes from 10.10.10.7: seq=14 ttl=64 time=4095.485 ms
64 bytes from 10.10.10.7: seq=15 ttl=64 time=3095.774 ms
64 bytes from 10.10.10.7: seq=16 ttl=64 time=2095.721 ms
64 bytes from 10.10.10.7: seq=17 ttl=64 time=1095.667 ms
64 bytes from 10.10.10.7: seq=18 ttl=64 time=95.613 ms
^Z[2]+ Stopped ping 10.10.10.7
Additionally, each 5-30 mins. my smartphones get reconnected (short disconnects, no matter which free channel and/or crypt method I choose). This is happening from the first TO run. None of the updates and rescue flashing solved this! My TP-Link TL-WR1043NDv2 (LuCI OpenWRT), placed before in the same corner of my desk, did not give me any issues for 2 years of online work!
I’m really, really disappointed.
This is a firmware issue with the 5 GHz card occurred since update 3.3. I am also having that problem.
:notes:You are not alone :notes:
:notes:I am here with you :notes:
Micheal jackson :).
Thanks, but I was talking about 2,4 GHz (wlan1) :slight_smile:
:notes:You are ALL alone :notes:
:notes:i am NOT with you :notes: :joy:
Oke, enough with the jokes.
Could you give me the following output.
iw wlan1 scan
Do hide your own SSID(wifiname) and BSSID (macaddress)
Put the output in preformatted text < / > in the editor menu of your message.
Well. I’m not alone here. I saw some posts on this forum, telling the same. Also, a friend of mine, owning TO, has the same issue.
BSS xx:xx:xx:xx:xx:xx(on wlan1)
        TSF: 1523448422758 usec (17d, 15:10:48)
        freq: 2452
        beacon interval: 100 TUs
        capability: ESS Privacy ShortSlotTime (0x0411)
        signal: -82.00 dBm
        last seen: 240 ms ago
        Information elements from Probe Response frame:
        SSID:
        Supported rates: 1.0* 2.0* 5.5* 11.0* 9.0 18.0 36.0 54.0
        DS Parameter set: channel 9
        Extended supported rates: 6.0 12.0 24.0 48.0
        Country: PL     Environment: Indoor/Outdoor
                Channels [1 - 13] @ 20 dBm
        TIM: DTIM Count 0 DTIM Period 1 Bitmap Control 0x0 Bitmap[0] 0x30
        WPA:     * Version: 1
                 * Group cipher: TKIP
                 * Pairwise ciphers: TKIP CCMP
                 * Authentication suites: PSK
        RSN:     * Version: 1
                 * Capabilities: 1-PTKSA-RC 1-GTKSA-RC (0x0000)
        ERP: Barker_Preamble_Mode
        HT capabilities:
                Capabilities: 0x118e
                        HT20/HT40
                        SM Power Save disabled
                        TX STBC
                        RX STBC 1-stream
                        Max AMSDU length: 3839 bytes
                        DSSS/CCK HT40
                Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
                Minimum RX AMPDU time spacing: 4 usec (0x05)
                HT RX MCS rate indexes supported: 0-15, 32
                HT TX MCS rate indexes are undefined
        HT operation:
                 * primary channel: 9
                 * secondary channel offset: below
                 * STA channel width: any
                 * RIFS: 0
                 * HT protection: 20 MHz
                 * non-GF present: 1
                 * OBSS non-GF present: 0
                 * dual beacon: 0
                 * dual CTS protection: 0
                 * STBC beacon: 0
                 * L-SIG TXOP Prot: 0
                 * PCO active: 0
                 * PCO phase: 0
        Overlapping BSS scan params:
                 * passive dwell: 20 TUs
                 * active dwell: 10 TUs
                 * channel width trigger scan interval: 300 s
                 * scan passive total per channel: 200 TUs
                 * scan active total per channel: 20 TUs
                 * BSS width channel transition delay factor: 5
                 * OBSS Scan Activity Threshold: 0.25 %
        Extended capabilities: HT Information Exchange Supported
        WMM:     * Parameter version 1
                 * BE: CW 15-1023, AIFSN 3
                 * BK: CW 15-1023, AIFSN 7
                 * VI: CW 7-15, AIFSN 2, TXOP 3008 usec
                 * VO: CW 3-7, AIFSN 2, TXOP 1504 usec
        TSF: 3117063476227 usec (36d, 01:51:03)
        freq: 2472
        signal: -85.00 dBm
        last seen: 30 ms ago
        SSID:
        DS Parameter set: channel 13
        Country: PL     Environment: bogus
        TIM: DTIM Count 0 DTIM Period 1 Bitmap Control 0x0 Bitmap[0] 0x1a
        WPA:     * Version: 1
                 * Group cipher: CCMP
                 * Pairwise ciphers: CCMP
        RSN:     * Version: 1
        WPS:     * Version: 0.0
                 * Wi-Fi Protected Setup State: 2 (Configured)
                 * UUID: bc329e00-1dd8-11b2-8601-e894f6e8ade6
                 * RF Bands: 0x1
        HT capabilities:
                Capabilities: 0x116e
                        HT20/HT40
                        RX HT20 SGI
                        RX HT40 SGI
                        RX STBC 1-stream
                        DSSS/CCK HT40
                HT RX MCS rate indexes supported: 0-7, 32
        HT operation:
                 * primary channel: 13
                 * RIFS: 0
                 * HT protection: no
                 * non-GF present: 0
                 * dual beacon: 0
                 * STBC beacon: 0
                 * PCO active: 0
                 * PCO phase: 0
So looking at the output, it looks like your neighbors are kind of far away from you right? Because you have almost no other WiFi-networks surrounding you.
Did i conclude this right?
Yes, you’re right here.
Could you give me the output of the following things…
cat /etc/config/wireless (do hide ssid and wifi passwords)
iw reg get
iwconfig
config wifi-device 'radio0'
        option type 'mac80211'
        option hwmode '11a'
        option path 'platform/soc/soc:pcie-controller/pci0000:00/0000:00:02.0/0000:02:00.0'
        option htmode 'VHT80'
        option disabled '0'
        option channel 'auto'
        option txpower '20'
        option country 'PL'
config wifi-iface
        option device 'radio0'
        option network 'lan'
        option mode 'ap'
        option disabled '0'
        option encryption 'psk2+tkip+aes'
        option key 'xxxxxxxxxx'
        option ssid 'xxxxxxxxxxx'
config wifi-device 'radio1'
        option hwmode '11g'
        option path 'platform/soc/soc:pcie-controller/pci0000:00/0000:00:01.0/0000:01:00.0'
        option txpower '19'
        option country 'PL'
        option htmode 'HT40'
config wifi-iface
        option device 'radio1'
        option mode 'ap'
        option key 'xxxxxxxxxxx'
        option encryption 'psk2+tkip+ccmp'
country PL: DFS-ETSI
        (2402 - 2482 @ 40), (N/A, 20), (N/A)
        (5170 - 5250 @ 80), (N/A, 20), (N/A)
        (5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS
        (5490 - 5710 @ 160), (N/A, 27), (0 ms), DFS
        (57000 - 66000 @ 2160), (N/A, 40), (N/A)
gre0      no wireless extensions.
pppoe-wan  no wireless extensions.
wlan0     IEEE 802.11  Mode:Master  Tx-Power=20 dBm
          RTS thr:off   Fragment thr:off
          Power Management:off
sit0      no wireless extensions.
gretap0   no wireless extensions.
lo        no wireless extensions.
eth0      no wireless extensions.
eth1      no wireless extensions.
eth2      no wireless extensions.
ip6tnl0   no wireless extensions.
wlan1     IEEE 802.11  Mode:Master  Tx-Power=16 dBm
br-lan    no wireless extensions.
ifb0      no wireless extensions.
teql0     no wireless extensions.
ifb1      no wireless extensions.
Could you set in the
option txpower '19'
to
option channel '6'
option txpower '16'
If you still have the problems with it, try the following
iw reg set CZ
also change in the wireless config the country settings to CZ. Then look if things have changed.
Does this problem occur 24/7 so to say or only a few moments of the day?
Have you also looked at the hardware side? Tighten the antenna screws and also the u.fl connector.
Are the antennas also the antennas that you got with the Omnia or are they different antennas?
I have the same issue and with yesterday’s update disconnects start to be even more frequent. It’s the worst wifi router I ever had.
@yorik
I replaced right from day one, when I got the Turris Omnia, the two pre-installed wifi modules with MikroTik’s R11e-5HacT and R11e-2HPnD cards. With these cards, I get fantastic performance, 100% stability (not once a disconnect) and the signal-strengths to avoid any additional repeater in my large house. I used quite a few different routers in the past and for me, TO ist the best and not the worst I ever had :slight_smile:
It’s not the worst router because the rest of it is simply fantastic!
I hope they will soon fix the wifi problems.
You got two monsters in your Omnia that have gone savage, by having the tx-power boosted up to 30 dBm (2.4 GHz monster), the other one i forgot how much it’s savage power goes. What do you expect …:joy:
With different wifi cards it’s completely different device;) My main complains are about wifi reliability, so your comment isn’t that relevant.
The only good part about omnia is throughput: I can use about my full 1Gbit, but it’s very hard to find a server which allows to use it for something except of tests. But there are a lot of bugs in software (ipv6 dhcpd doesn’t work, not clear how to properly allow external traffic to internal servers, etc) and wifi is just terrible. And even SFP doesn’t work. Right now I’m reflashing my old Netgear R7000 to put it back as primary router and wait until omnia will be fixed or I’ll buy something better.
Thanks for your help, but weakening of the signal should not be a solution to this problem, am I right?
24/7.[quote=ā€œBig_boss, post:52, topic:1698ā€]
[/quote]
I did this before the first run.[quote=ā€œBig_boss, post:52, topic:1698ā€]
[/quote]
They are the preinstalled (stock) ones.
There is no case of ā€œweakeningā€, because the 2.4 GHz only puts out a max of 16 dBm already for each chain. So putting it on 19 does not suddenly change to 19.
That is why i said put it on 16 and the channel use a fixed channel to test it.
