I highly disappointed with Omnia WiFi reliability: from time to time my devices disconnects and fail immediately connect back or stay connected by most of the packets are drops. Especially it’s bad on my tablet: from time to time it lose network and it take 2-5 minutes get connection back. Are there any way to fix? (Adding to that SFP problem and I quite ready to sell my router).
Here is log:
Nov 21 22:54:01 turris cron[17533]: (root) CMD (nethist_stats.lua)
Nov 21 22:54:01 turris cron[17534]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
Nov 21 22:55:01 turris cron[17574]: (root) CMD ( /usr/bin/notifier)
Nov 21 22:55:01 turris cron[17575]: (root) CMD (/usr/bin/watchdog.sh)
Nov 21 22:55:01 turris cron[17576]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
Nov 21 22:55:14 turris netifd: wan6 (2573): sh: write error: Invalid argument
Nov 21 22:56:01 turris cron[17757]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
Nov 21 22:56:01 turris cron[17756]: (root) CMD (nethist_stats.lua)
Nov 21 22:57:01 turris cron[17795]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
Nov 21 22:57:13 turris netifd: wan (2548): Sending renew…
Nov 21 22:57:13 turris netifd: wan (2548): Lease of XXX.XXX.XXX.XXX obtained, lease time 1800
Nov 21 22:58:01 turris cron[17905]: (root) CMD (nethist_stats.lua)
Nov 21 22:58:01 turris cron[17906]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
Nov 21 22:58:25 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.11: authentication OK (open system)
Nov 21 22:58:25 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: event 0 notification
Nov 21 22:58:25 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx MLME: MLME-AUTHENTICATE.indication(xx:xx:xx:xx:xx:xx, OPEN_SYSTEM)
Nov 21 22:58:25 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx MLME: MLME-DELETEKEYS.request(xx:xx:xx:xx:xx:xx)
Nov 21 22:58:25 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.11: authenticated
Nov 21 22:58:25 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.11: association OK (aid 1)
Nov 21 22:58:25 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.11: associated (aid 1)
Nov 21 22:58:25 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx MLME: MLME-ASSOCIATE.indication(xx:xx:xx:xx:xx:xx)
Nov 21 22:58:25 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.11: binding station to interface 'wlan1’
Nov 21 22:58:25 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: event 1 notification
Nov 21 22:58:25 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: sending 1/4 msg of 4-Way Handshake
Nov 21 22:58:25 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: received EAPOL-Key frame (2/4 Pairwise)
Nov 21 22:58:25 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: sending 3/4 msg of 4-Way Handshake
Nov 21 22:58:25 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: EAPOL-Key timeout
Nov 21 22:58:25 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: received EAPOL-Key frame (4/4 Pairwise)
Nov 21 22:58:25 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.1X: authorizing port
Nov 21 22:58:25 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx RADIUS: starting accounting session XXXXXXXXXXXXXXXX
Nov 21 22:58:25 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: pairwise key handshake completed (RSN)
Nov 21 23:58:30 turris dnsmasq-dhcp[2640]: DHCPDISCOVER(br-lan) xx:xx:xx:xx:xx:xx
Nov 21 23:58:30 turris dnsmasq-dhcp[2640]: DHCPOFFER(br-lan) 192.168.1.101 xx:xx:xx:xx:xx:xx
Nov 21 23:58:40 turris dnsmasq-dhcp[2640]: DHCPREQUEST(br-lan) 192.168.1.101 xx:xx:xx:xx:xx:xx
Nov 21 23:58:40 turris dnsmasq-dhcp[2640]: DHCPACK(br-lan) 192.168.1.101 xx:xx:xx:xx:xx:xx android
Nov 21 22:59:12 turris netifd: wan6 (2573): sh: write error: Invalid argument
Nov 21 22:59:39 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.11: authentication OK (open system)
Nov 21 22:59:39 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: event 0 notification
Nov 21 22:59:39 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx MLME: MLME-AUTHENTICATE.indication(xx:xx:xx:xx:xx:xx, OPEN_SYSTEM)
Nov 21 22:59:39 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx MLME: MLME-DELETEKEYS.request(xx:xx:xx:xx:xx:xx)
Nov 21 22:59:39 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.11: authenticated
Nov 21 22:59:42 turris ucollect[2337]: Mempool stats: Global permanent pool: 3092/4096 (18)
Nov 21 22:59:42 turris ucollect[2337]: Mempool stats: Global batch pool: 0/4096 (0)
Nov 21 22:59:42 turris ucollect[2337]: Mempool stats: Global temporary pool: 156/4096 (3)
Nov 21 22:59:42 turris ucollect[2337]: Mempool stats: Buffer pool for uplink: 4/4096 (1)
Nov 21 22:59:42 turris ucollect[2337]: Mempool stats: Config pool: 3589/4096 (108)
Nov 21 22:59:42 turris ucollect[2337]: Mempool stats: Badconf: 48/4096 (1)
Nov 21 22:59:42 turris ucollect[2337]: Mempool stats: Bandwidth: 2744/4096 (6)
Nov 21 22:59:42 turris ucollect[2337]: Mempool stats: Count: 264/4096 (1)
Nov 21 22:59:42 turris ucollect[2337]: Mempool stats: Fake: 14176/16384 (35)
Nov 21 22:59:42 turris ucollect[2337]: Mempool stats: Fake log: 805/4096 (33)
Nov 21 22:59:42 turris ucollect[2337]: Mempool stats: Flow: 128/4096 (5)
Nov 21 22:59:42 turris ucollect[2337]: Mempool stats: Flow pool: 14692/16384 (325)
Nov 21 22:59:42 turris ucollect[2337]: Mempool stats: Flow conf pool: 2281199/2400256 (122418)
Nov 21 22:59:42 turris ucollect[2337]: Mempool stats: Fwup: 168/4096 (7)
Nov 21 22:59:42 turris ucollect[2337]: Mempool stats: FWUp set pool 1: 0/4096 (0)
Nov 21 22:59:42 turris ucollect[2337]: Mempool stats: FWUp set pool 2: 582551/610304 (31127)
Nov 21 22:59:42 turris ucollect[2337]: Mempool stats: Refused: 104/4096 (3)
Nov 21 22:59:42 turris ucollect[2337]: Mempool stats: Refuse pool 1: 38898/40960 (1650)
Nov 21 22:59:42 turris ucollect[2337]: Mempool stats: Refuse pool 2: 0/4096 (0)
Nov 21 22:59:42 turris ucollect[2337]: Mempool stats: Sniff: 44/4096 (3)
Nov 21 22:59:42 turris ucollect[2337]: Mempool stats: Sniffer pool: 0/4096 (0)
Nov 21 22:59:42 turris ucollect[2337]: Mempool stats: Spoof: 224/4096 (1)
Nov 21 22:59:42 turris ucollect[2337]: Mempool stats done
Nov 21 22:59:42 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.11: authentication OK (open system)
Nov 21 22:59:42 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: event 0 notification
Nov 21 22:59:42 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx MLME: MLME-AUTHENTICATE.indication(xx:xx:xx:xx:xx:xx, OPEN_SYSTEM)
Nov 21 22:59:42 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx MLME: MLME-DELETEKEYS.request(xx:xx:xx:xx:xx:xx)
Nov 21 22:59:42 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.11: authenticated
Nov 21 22:59:42 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.11: association OK (aid 1)
Nov 21 22:59:42 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.11: associated (aid 1)
Nov 21 22:59:42 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx MLME: MLME-ASSOCIATE.indication(xx:xx:xx:xx:xx:xx)
Nov 21 22:59:42 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.11: binding station to interface 'wlan1’
Nov 21 22:59:42 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: event 1 notification
Nov 21 22:59:42 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: sending 1/4 msg of 4-Way Handshake
Nov 21 22:59:42 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: received EAPOL-Key frame (2/4 Pairwise)
Nov 21 22:59:42 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: sending 3/4 msg of 4-Way Handshake
Nov 21 22:59:42 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: EAPOL-Key timeout
Nov 21 22:59:42 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: received EAPOL-Key frame (4/4 Pairwise)
Nov 21 22:59:42 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.1X: authorizing port
Nov 21 22:59:42 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx RADIUS: starting accounting session XXXXXXXXXXXXXXXX
Nov 21 22:59:42 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: pairwise key handshake completed (RSN)
Nov 21 22:59:44 turris hostapd: wlan1: WPA rekeying GTK
Nov 21 22:59:44 turris hostapd: wlan1: STA 24:df:6a:33:eb:e4 WPA: sending 1/2 msg of Group Key Handshake
Nov 21 22:59:44 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: sending 1/2 msg of Group Key Handshake
Nov 21 22:59:44 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: received EAPOL-Key frame (2/2 Group)
Nov 21 22:59:44 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: group key handshake completed (RSN)
Nov 21 22:59:45 turris hostapd: wlan1: STA 24:df:6a:33:eb:e4 WPA: received EAPOL-Key frame (2/2 Group)
Nov 21 22:59:45 turris hostapd: wlan1: STA 24:df:6a:33:eb:e4 WPA: group key handshake completed (RSN)
Nov 21 22:59:51 turris netifd: wan6 (2573): sh: write error: Invalid argument
Nov 21 23:00:01 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.11: authentication OK (open system)
Nov 21 23:00:01 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: event 0 notification
Nov 21 23:00:01 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx MLME: MLME-AUTHENTICATE.indication(xx:xx:xx:xx:xx:xx, OPEN_SYSTEM)
Nov 21 23:00:01 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx MLME: MLME-DELETEKEYS.request(xx:xx:xx:xx:xx:xx)
Nov 21 23:00:01 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.11: authenticated
Nov 21 23:00:02 turris watchdog: Restarted nethist
Nov 21 23:00:08 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.11: authentication OK (open system)
Nov 21 23:00:08 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: event 0 notification
Nov 21 23:00:08 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx MLME: MLME-AUTHENTICATE.indication(xx:xx:xx:xx:xx:xx, OPEN_SYSTEM)
Nov 21 23:00:08 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx MLME: MLME-DELETEKEYS.request(xx:xx:xx:xx:xx:xx)
Nov 21 23:00:08 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.11: authenticated
Nov 21 23:00:08 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.11: association OK (aid 1)
Nov 21 23:00:08 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.11: associated (aid 1)
Nov 21 23:00:08 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx MLME: MLME-ASSOCIATE.indication(xx:xx:xx:xx:xx:xx)
Nov 21 23:00:08 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.11: binding station to interface 'wlan1’
Nov 21 23:00:08 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: event 1 notification
Nov 21 23:00:08 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: sending 1/4 msg of 4-Way Handshake
Nov 21 23:00:08 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: received EAPOL-Key frame (2/4 Pairwise)
Nov 21 23:00:08 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: sending 3/4 msg of 4-Way Handshake
Nov 21 23:00:08 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: received EAPOL-Key frame (4/4 Pairwise)
Nov 21 23:00:08 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx IEEE 802.1X: authorizing port
Nov 21 23:00:08 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx RADIUS: starting accounting session XXXXXXXXXXXXXXXX
Nov 21 23:00:08 turris hostapd: wlan1: STA xx:xx:xx:xx:xx:xx WPA: pairwise key handshake completed (RSN)
Nov 22 00:00:09 turris dnsmasq-dhcp[2640]: DHCPDISCOVER(br-lan) xx:xx:xx:xx:xx:xx
Nov 22 00:00:09 turris dnsmasq-dhcp[2640]: DHCPOFFER(br-lan) 192.168.1.101 xx:xx:xx:xx:xx:xx
Nov 22 00:00:09 turris dnsmasq-dhcp[2640]: DHCPREQUEST(br-lan) 192.168.1.101 xx:xx:xx:xx:xx:xx
Nov 22 00:00:09 turris dnsmasq-dhcp[2640]: DHCPACK(br-lan) 192.168.1.101 xx:xx:xx:xx:xx:xx android
Nov 21 23:00:45 turris hostapd: wlan0: WPA rekeying GTK
