I just setup the Omnia and I’m seeing extremely slow speeds when using the internet. With my old router I was seeing 60 Mbps+ on typical speed tests, now I’m seeing <0.25 Mbps.
I tried raising the wondershaper limits (they were very low to start) but it didn’t help. I also tried uninstalling wondershaper altogether also with no improvement.
I only see one drop in the port stats:
root@turris:~# cat /proc/net/dev
Inter-| Receive | Transmit
face |bytes packets errs drop fifo frame compressed multicast|bytes packets errs drop fifo colls carrier compressed
gre0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
wlan0: 0 0 0 0 0 0 0 0 47213 315 0 0 0 0 0 0
sit0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
gretap0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
lo: 29072 280 0 0 0 0 0 0 29072 280 0 0 0 0 0 0
eth0: 3191798 23930 0 1 0 0 0 0 40050519 28358 0 0 0 0 0 0
eth1: 39903996 31917 0 0 0 0 0 0 2943921 22608 0 0 0 0 0 0
eth2: 0 0 0 0 0 0 0 0 41481 315 0 0 0 0 0 0
ip6tnl0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
wlan1: 0 0 0 0 0 0 0 0 47763 320 0 0 0 0 0 0
br-lan: 2719086 23214 0 0 0 0 0 0 39921035 26602 0 0 0 0 0 0
teql0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
The CPU is sitting at 0% and only 10% RAM usage.
Other output that I thought might be useful:
root@turris:~# tc qdisc show
qdisc noqueue 0: dev lo root refcnt 2
qdisc mq 0: dev eth0 root
qdisc fq_codel 0: dev eth0 parent :1 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth0 parent :2 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth0 parent :3 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth0 parent :4 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth0 parent :5 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth0 parent :6 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth0 parent :7 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth0 parent :8 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc mq 0: dev eth1 root
qdisc fq_codel 0: dev eth1 parent :1 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth1 parent :2 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth1 parent :3 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth1 parent :4 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth1 parent :5 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth1 parent :6 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth1 parent :7 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth1 parent :8 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc mq 0: dev eth2 root
qdisc fq_codel 0: dev eth2 parent :1 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth2 parent :2 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth2 parent :3 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth2 parent :4 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth2 parent :5 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth2 parent :6 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth2 parent :7 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth2 parent :8 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc noqueue 0: dev br-lan root refcnt 2
qdisc mq 0: dev wlan0 root
qdisc fq_codel 0: dev wlan0 parent :1 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev wlan0 parent :2 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev wlan0 parent :3 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev wlan0 parent :4 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc mq 0: dev wlan1 root
qdisc fq_codel 0: dev wlan1 parent :1 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev wlan1 parent :2 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev wlan1 parent :3 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev wlan1 parent :4 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
root@turris:~# tc class show dev eth0
class mq :1 root
class mq :2 root
class mq :3 root
class mq :4 root
class mq :5 root
class mq :6 root
class mq :7 root
class mq :8 root
root@turris:~# tc class show dev br-lan
root@turris:~# tc class show dev eth1
class mq :1 root
class mq :2 root
class mq :3 root
class mq :4 root
class mq :5 root
class mq :6 root
class mq :7 root
class mq :8 root
root@turris:~#
Edit: I just did an experiment and this appears to be a problem when I’m plugged into LAN3. LAN1 is fine, as so is wifi. I’m going to try all the LAN ports to see if I can find a pattern.
Edit 2: It is only an issue for LAN3. All the other LAN ports are fine. It’s very strange. I don’t see anything physically wrong with the RJ 45 port or anything.
I do see some L2 errors on the PC when going over LAN3:
C:\Users\Nitori>netstat -e
Interface Statistics
Received Sent
Bytes 3208947607 256103173
Unicast packets 2218741 1113994
Non-unicast packets 1890 18155
Discards 250 0
Errors 250 6
Unknown protocols 0
