Prosím o pomoc. 5-6x denně v nepravidelných intervalech vypadne internet. Při brouzdání internetem to nepoznám , v TV okamžitě. V syslogu je vždy tato sekvence:
2021-01-26 20:54:21 info kernel[]: [1051654.786965] fsl-gianfar ffe26000.ethernet eth2: Link is Down
2021-01-26 20:54:21 notice netifd[]: Network device ‘eth2’ link is down
2021-01-26 20:54:21 notice netifd[]: Interface ‘wan’ has link connectivity loss
2021-01-26 20:54:21 notice netifd[]: wan (7248): udhcpc: sending discover
2021-01-26 20:54:21 notice netifd[]: wan (7248): udhcpc: received SIGTERM
2021-01-26 20:54:24 notice netifd[]: Network device ‘eth2’ link is up
2021-01-26 20:54:24 notice netifd[]: Interface ‘wan’ has link connectivity
2021-01-26 20:54:24 notice netifd[]: Interface ‘wan’ is setting up now
2021-01-26 20:54:24 info kernel[]: [1051657.792711] fsl-gianfar ffe26000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
2021-01-26 20:54:24 notice netifd[]: wan (7366): udhcpc: started, v1.29.3
2021-01-26 20:54:24 notice netifd[]: wan (7366): udhcpc: sending discover
2021-01-26 20:54:26 info kernel[]: [1051659.796597] fsl-gianfar ffe26000.ethernet eth2: Link is Down
2021-01-26 20:54:26 notice netifd[]: Network device ‘eth2’ link is down
2021-01-26 20:54:26 notice netifd[]: Interface ‘wan’ has link connectivity loss
2021-01-26 20:54:26 notice netifd[]: wan (7366): udhcpc: received SIGTERM
2021-01-26 20:54:27 notice netifd[]: Network device ‘eth2’ link is up
2021-01-26 20:54:27 notice netifd[]: Interface ‘wan’ has link connectivity
2021-01-26 20:54:27 notice netifd[]: Interface ‘wan’ is setting up now
2021-01-26 20:54:27 info kernel[]: [1051660.798629] fsl-gianfar ffe26000.ethernet eth2: Link is Up - 100Mbps/Full - flow control off
2021-01-26 20:54:27 notice netifd[]: wan (7381): udhcpc: started, v1.29.3
2021-01-26 20:54:27 notice netifd[]: wan (7381): udhcpc: sending discover
2021-01-26 20:54:27 notice netifd[]: wan (7381): udhcpc: sending select for 192.168.88.254
2021-01-26 20:54:27 notice netifd[]: wan (7381): udhcpc: lease of 192.168.88.254 obtained, lease time 43200
2021-01-26 20:54:27 notice netifd[]: Interface ‘wan6’ is enabled
2021-01-26 20:54:27 notice netifd[]: Network alias ‘eth2’ link is up
2021-01-26 20:54:27 notice netifd[]: Interface ‘wan6’ has link connectivity
2021-01-26 20:54:27 notice netifd[]: Interface ‘wan6’ is setting up now
2021-01-26 20:54:27 notice netifd[]: Interface ‘wan6’ is now up
2021-01-26 20:54:27 notice netifd[]: Interface ‘wan’ is now up
2021-01-26 20:54:27 notice firewall[]: Reloading firewall due to ifup of wan (eth2)
2021-01-26 20:54:27 info turris-firewall-rules[]: (v64) IPv4 WAN interface used - ‘eth2’
2021-01-26 20:54:27 info turris-firewall-rules[]: (v64) IPv6 WAN interface used - ‘eth2’
Vyměnil jsem modem, WAN kabel a nic nepomohlo. T1.1, TOS 3.11.21
