Hey there,
I’d like to add my Mox the modules/addons to turn it into a Wifi router.
I have a Mox with modules A + F (the Cloud set).
What should I buy to sort it out ?
Thanks
Hey there,
Thanks
Hi @dadall,
you have following options to add WiFi functionality to your setup:
It is important to understand that none of the add-ons allows to create 2.4 and 5 GHz network at the same time. You need to have 2 add-ons to achieve this. In my case I have the SDIO add-on for 2.4 GHz network and mPCIe add-on seated in the G module for the 5 GHz network.
Next to that, you might be interested in modules C or E in order to add some RJ-45 ports for your wired devices.
Happy routing!
SDIO card can’t support multiple SSIDs.
Thanks @viktor! I wasnt aware about this limitation. Another reason to go for mPCIe add-on.
I have to warn you that I have quite a bad time running A+G+F configuration right now, as evidenced by my dmesg log: Modules G+F interoperability
It depends if you run a NAS on your MOX. If you do, just be aware of my warning.
Hey,
I ordered G + mPCIe when I saw the post from the other topic where you say it is fixed.
I’m confused because it works and vanish randomly. By vanishing I mean the G module is not loaded by the Mox while nothing changes… Seems to be a software issue…
Any idea ?
Hey there,
Update : the module seems to be loaded at every reboot now. Can’t be sure why it works but it’s cool. Maybe the last updates ?
Sadly, the Mox keeps rebooting twice a day, or more, when the Wifi network is used by multiple devices.
Nothing important from the logs can explain the issue.
I’m using the alternate wifi driver. The basic one makes the Mox the reboot every 45min when the wifi is used.
Turris OS 5.1.1 loaded but my Mox keeps randomly rebooting when the wifi is used.
Am I the only one facing this issue ?
Hey there,
TL;DR :
Here is a quick update of my adventure :
And it works. No more reboots.
My Mox went to CZ for a firmware update of the F module. It helps the mox to stay up and running but the USB module is unusable.
Questions :
I wonder if buying a brand new Mox A can help me to use the entire modules and add-on I have.
Things are I don’t understand why there are a 1GB and a 512GB A modules.
My running A module is 1GB. Is there a stability issue with en 1GB version ?
Is there a known issue with the SDIO add-on ?
Should I change the F module by a G module ? The configurator says it is not possible
Cheers
Hey guys,
I found the topic talking about the soldering issue and that was the problem. Once the SDIO fixed correctly to the card, no more wifi issue.
To answer my questions :
Here we are now : the Mox almost works as expected. I haven’t tried the module F yet. That’s for another post.
