Short story:
I’d like to ask for the following information for Turris MOX:
- Where is the download of the latest stable secure firmware image for flashing to
/dev/mtd0
? - Where is the download of the latest stable U-Boot image for flashing to
/dev/mtd1
? - How do I reset the U-Boot environment variables stored in
/dev/mtd2
to default values? - Where is the download of the latest stable rescue system image for flashing to
/dev/mtd3
? - Where is the download of the latest DTB image for flashing to
/dev/mtd4
? - Instructions on how to flash all of the above
Thank you.
Longer story:
I am trying to recover some old Turris MOX that has a damaged bootloader and is experiencing the old well-known reboot failure, and cannot currently be upgraded to newest TurrisOS.
Firmware update files used to be posted on Releases · Turris / MOX boot-builder · GitLab but that page appears to no longer be updated.
That page contains the files trusted-secure-firmware.bin
and a53-firmware.bin
from v2021.09.07, with instructions to flash them like this:
mtd write trusted-secure-firmware.bin secure-firmware
mtd write a53-firmware.bin a53-firmware || mtd write a53-firmware.bin u-boot
The a53-firmware.bin contains U-Boot 2021.10-rc3-00050-g7d3fea2c7f (Sep 07 2021 - 18:16:56 +0200)
The same page also contains secure-firmware.bin
with no instructions.
There also exists https://repo.turris.cz/hbs/mox/packages/turrispackages/turris-mox-firmware_2.0-3_aarch64_cortex-a53.ipk which contains the files secure-firmware.bin
and uboot
and rescue
The uboot
file contains U-Boot 2022.07 (Aug 15 2022 - 12:25:08 +0000)
There also exists https://repo.turris.cz/hbs/mox/packages/turrispackages/mox-a53-firmware_2.7-5_aarch64_cortex-a53.ipk which contains the file uboot-devel
The uboot-devel
file contains U-Boot 2023.01-OpenWrt-r16881+135-4a1d8ef55c (Feb 13 2024 - 16:26:38 +0000)
. I assume this is some development version not meant to be flashed yet.
What I currently gathered is this:
- The files on Releases · Turris / MOX boot-builder · GitLab are out of date and should not be used.
- The only way to obtain the firmware files is browsing Index of /hbs/mox/packages/turrispackages/ downloading the relevant files and extracting the firmware files from them.
- There are no up to date instructions anywhere on how to flash the files.
I came up with these instructions and don’t know if they are correct, verification would be appreciated.
The secure-firmware.bin
file is flashed to /dev/mtd0
this way:
mtd -e /dev/mtd0 write secure-firmware.bin /dev/mtd0
The uboot
file is flashed to /dev/mtd1
this way:
mtd -e /dev/mtd1 write uboot /dev/mtd1
U-Boot environment variables are stored in /dev/mtd2
, and there are no instructions anywhere on how to reset them or regenerate them.
The rescue
file is flashed to /dev/mtd3
this way:
mtd -e /dev/mtd3 write rescue /dev/mtd3
The DTB files are not available for download anywhere, but would be flashed to /dev/mtd4
Thank you for reading.
