i am not too computer savy, but i have been getting this error and have no idea where to go or how to fix it…if someone could give me a step by step to get the updater working(how to access the updater.sh file to correct it), it would be great…
Error from 2016/12/27 12:34:06
Updater failed:
unreachable: /tmp/crl.pem: No such file or directory
could you add this on the config interface 'lan' part.
So it should look something like this after you have done it.
option ifname 'eth0 eth2'
option force_link '1'
option type 'bridge'
option proto 'static'
option ip6assign '60'
option ipaddr '192.168.1.6'
list dns '8.8.8.8'
list dns '8.8.4.4'
Also a few questions. Looking at your network-config file you have the gateway for WAN setup as 192.168.1.1. Do you have a separate internet router from your internet-provider or so? If that is the case, please change the WAN ip address and lan ip address.
You are using the same ip-address (192.168.1.6) for both, which could be problematic, as they also are on the same subnet so to say. Forgot to mention to also place the list dns with the WAN part, just to be sure.
config interface 'wan'
option ifname 'eth1'
option gateway '192.168.1.1'
list dns '8.8.8.8'
list dns '8.8.4.4'
I wanted to tell you to install “nano”(an easy editor, but realized you have no internet connection XD). Although i am not sure if this would work, but i THINK it would.
Go to LuCi (webinterface), Network–>DHCP and DNS–>DNS forwardings
add both
8.8.8.8
8.8.4.4
Click safe and apply (all the way down the page)
Also go to Network–>interfaces
with WAN click on edit and change the ip-address to something else then 192.168.1.6. For example to 192.168.1.7 or something like that.
You have 5 LAN-ports and you have also a WAN port.
To be able to have internet on your Omnia, not necessarily on your phone or laptop, you MUST have the WAN port somehow connected.
To give you my example. I also have the Internet-provider router and my Omnia. I am connected to the internet-provider router through WiFi. I have configured the WiFi connection that is connected to the internet-provider to be my WAN.
So it looks something like this.
My network and its devices —>cable+WiFi–>Omnia—WiFi-connected(WAN)—>Internet-provider router.
If i would connect to my internet-provider router, i could not connect to the devices that are connected on the Omnia, OR i’d have to accept all the data going to the Omnia through WiFi. However i use the internet-provider router ONLY for internet that’s it. So my WAN-port (physically is empty)
So could you please tell me what you are using your internet-provider router for?
