Zdravím,
mám k dispozici na testování Omnii Turris, ale nedaří se mi ji zprovoznit. Nejsem v těhle věcech příliš zběhlý a jsem již trošku ztracen.
Mám podezření, že mi to dělá Netbox v Brně
Po základním nastavení routeru mi při snaze aktualizovat software hodí chybu.
Updater failed:
unreachable: https://repo.turris.cz/omnia/lists/base.lua: Couldn't resolve host 'repo.turris.cz'
Luci při pokusu o update hlásí
curl: (6) Couldn't resolve host 'repo.turris.cz' Collected errors: * opkg_download: Failed to download https://repo.turris.cz/omnia/packages//base/Packages.gz, curl returned 6. * file_move: Failed to rename /tmp/opkg-DpDidh/Packages.gz to /var/opkg-lists/omnia_base: No such file or directory. * opkg_download: Failed to download https://repo.turris.cz/omnia/packages//hardware/Packages.gz, curl returned 6. * file_move: Failed to rename /tmp/opkg-DpDidh/Packages.gz to /var/opkg-lists/omnia_hardware: No such file or directory. * opkg_download: Failed to download https://repo.turris.cz/omnia/packages//lucics/Packages.gz, curl returned 6. * file_move: Failed to rename /tmp/opkg-DpDidh/Packages.gz to /var/opkg-lists/omnia_lucics: No such file or directory. * opkg_download: Failed to download https://repo.turris.cz/omnia/packages//management/Packages.gz, curl returned 6. * file_move: Failed to rename /tmp/opkg-DpDidh/Packages.gz to /var/opkg-lists/omnia_management: No such file or directory. * opkg_download: Failed to download https://repo.turris.cz/omnia/packages//openwisp/Packages.gz, curl returned 6. * file_move: Failed to rename /tmp/opkg-DpDidh/Packages.gz to /var/opkg-lists/omnia_openwisp: No such file or directory. * opkg_download: Failed to download https://repo.turris.cz/omnia/packages//packages/Packages.gz, curl returned 6. * file_move: Failed to rename /tmp/opkg-DpDidh/Packages.gz to /var/opkg-lists/omnia_packages: No such file or directory. * opkg_download: Failed to download https://repo.turris.cz/omnia/packages//php/Packages.gz, curl returned 6. * file_move: Failed to rename /tmp/opkg-DpDidh/Packages.gz to /var/opkg-lists/omnia_php: No such file or directory. * opkg_download: Failed to download https://repo.turris.cz/omnia/packages//printing/Packages.gz, curl returned 6. * file_move: Failed to rename /tmp/opkg-DpDidh/Packages.gz to /var/opkg-lists/omnia_printing: No such file or directory. * opkg_download: Failed to download https://repo.turris.cz/omnia/packages//routing/Packages.gz, curl returned 6. * file_move: Failed to rename /tmp/opkg-DpDidh/Packages.gz to /var/opkg-lists/omnia_routing: No such file or directory. * opkg_download: Failed to download https://repo.turris.cz/omnia/packages//sidn/Packages.gz, curl returned 6. * file_move: Failed to rename /tmp/opkg-DpDidh/Packages.gz to /var/opkg-lists/omnia_sidn: No such file or directory. * opkg_download: Failed to download https://repo.turris.cz/omnia/packages//telephony/Packages.gz, curl returned 6. * file_move: Failed to rename /tmp/opkg-DpDidh/Packages.gz to /var/opkg-lists/omnia_telephony: No such file or directory. * opkg_download: Failed to download https://repo.turris.cz/omnia/packages//turrispackages/Packages.gz, curl returned 6. * file_move: Failed to rename /tmp/opkg-DpDidh/Packages.gz to /var/opkg-lists/omnia_turrispackages: No such file or directory.
Test IPv4 hlásí, že OK, při testu DNS hlásí chybu. Při všech pokusech nastavení.
Připojení k internetu nemám.
Postoval jsem popis už tady. Myslím, ale asi jsem neuměl správně nastavit.
Nevím jestli pomůže v něčem diagnostika. Kdybyste měli jakýkoliv nápad a navedli, jak to zkusit, budu vděčný. Jestli můžu ještě něco dodat, rád dodám. hlavně jestli se to podaří zprovoznit.
> ############## atsha
> 0000000B00010464
> ************** atsha
> ############## certs
> Package: cznic-cacert-bundle
> Version: 37
> Depends: libc, cert-backup, c-rehash
> Status: install user installed
> Architecture: mvebu
> Installed-Time: 1550492811
> 7089bfbee19076ef47c2563467c7bd52 /etc/cron.d/get-api
> a462ca35948bab86ae8f1ace7d5a2ed2 /etc/ssl/turris.pem
> 24142130c92f35e09561b409da96f3ad /usr/bin/get-api-crl
> d084a5bafee242438f94ae0be94be38e /etc/ssl/ucollect-server.pem
> md5sum: can't open '/etc/ssl/crl.pem': No such file or directory
> de888ce2cdd9c8668eb4de181d772ed7 /etc/ssl/www_turris_cz_ca.pem
> drwxr-xr-x 1 root root 13804 Feb 18 13:27 .
> drwxr-xr-x 1 root root 174 Feb 18 13:26 ..
> lrwxrwxrwx 1 root root 26 Feb 18 13:27 00673b5b.0 -> thawte_Primary_Root_CA.crt
> lrwxrwxrwx 1 root root 45 Feb 18 13:27 02265526.0 -> Entrust_Root_Certification_Authority_-_G2.crt
> lrwxrwxrwx 1 root root 23 Feb 18 13:27 02756ea4.0 -> Certplus_Root_CA_G1.crt
> lrwxrwxrwx 1 root root 36 Feb 18 13:27 03179a64.0 -> Staat_der_Nederlanden_EV_Root_CA.crt
> lrwxrwxrwx 1 root root 41 Feb 18 13:27 04f60c28.0 -> USERTrust_ECC_Certification_Authority.crt
> lrwxrwxrwx 1 root root 27 Feb 18 13:27 062cdee6.0 -> GlobalSign_Root_CA_-_R3.crt
> lrwxrwxrwx 1 root root 25 Feb 18 13:27 064e0aa9.0 -> QuoVadis_Root_CA_2_G3.crt
> lrwxrwxrwx 1 root root 50 Feb 18 13:27 06dc52d5.0 -> SSL.com_EV_Root_Certification_Authority_RSA_R2.crt
> lrwxrwxrwx 1 root root 20 Feb 18 13:27 080911ac.0 -> QuoVadis_Root_CA.crt
> lrwxrwxrwx 1 root root 54 Feb 18 13:27 09789157.0 -> Starfield_Services_Root_Certificate_Authority_-_G2.crt
> lrwxrwxrwx 1 root root 16 Feb 18 13:27 0b1b94ef.0 -> CFCA_EV_ROOT.crt
> lrwxrwxrwx 1 root root 44 Feb 18 13:27 0bf05006.0 -> SSL.com_Root_Certification_Authority_ECC.crt
> lrwxrwxrwx 1 root root 34 Feb 18 13:27 0c4c9b6c.0 -> Global_Chambersign_Root_-_2008.crt
> lrwxrwxrwx 1 root root 61 Feb 18 13:27 0d5a4e1c.0 -> TÜRKTRUST_Elektronik_Sertifika_Hizmet_Sağlayıcısı_H5.crt
> lrwxrwxrwx 1 root root 31 Feb 18 13:27 0d69c7e1.0 -> GlobalSign_ECC_Root_CA_-_R4.crt
> lrwxrwxrwx 1 root root 26 Feb 18 13:27 0f6fa695.0 -> GDCA_TrustAUTH_R5_ROOT.crt
> lrwxrwxrwx 1 root root 54 Feb 18 13:27 10531352.0 -> Starfield_Services_Root_Certificate_Authority_-_G2.crt
> lrwxrwxrwx 1 root root 46 Feb 18 13:27 106f3e4d.0 -> Entrust_Root_Certification_Authority_-_EC1.crt
> lrwxrwxrwx 1 root root 27 Feb 18 13:27 111e6273.0 -> GlobalSign_Root_CA_-_R2.crt
> lrwxrwxrwx 1 root root 49 Feb 18 13:27 116bf586.0 -> GeoTrust_Primary_Certification_Authority_-_G2.crt
> lrwxrwxrwx 1 root root 35 Feb 18 13:27 128805a3.0 -> EE_Certification_Centre_Root_CA.crt
> lrwxrwxrwx 1 root root 18 Feb 18 13:27 12d55845.0 -> DST_Root_CA_X3.crt
> lrwxrwxrwx 1 root root 26 Feb 18 13:27 157753a5.0 -> AddTrust_External_Root.crt
> lrwxrwxrwx 1 root root 59 Feb 18 13:27 1636090b.0 -> Hellenic_Academic_and_Research_Institutions_RootCA_2011.crt
> lrwxrwxrwx 1 root root 31 Feb 18 13:27 17b51fe6.0 -> Certplus_Class_2_Primary_CA.crt
> lrwxrwxrwx 1 root root 23 Feb 18 13:27 18856ac4.0 -> SecureSign_RootCA11.crt
> lrwxrwxrwx 1 root root 31 Feb 18 13:27 1d3472b9.0 -> GlobalSign_ECC_Root_CA_-_R5.crt
> lrwxrwxrwx 1 root root 15 Feb 18 13:27 1dcd6f4c.0 -> Taiwan_GRCA.crt
> lrwxrwxrwx 1 root root 34 Feb 18 13:27 1df5a75f.0 -> D-TRUST_Root_Class_3_CA_2_2009.crt
> lrwxrwxrwx 1 root root 37 Feb 18 13:27 1e08bfd1.0 -> IdenTrust_Public_Sector_Root_CA_1.crt
> lrwxrwxrwx 1 root root 32 Feb 18 13:27 1e09d511.0 -> T-TeleSec_GlobalRoot_Class_2.crt
> lrwxrwxrwx 1 root root 32 Feb 18 13:27 1e1eab7c.0 -> T-TeleSec_GlobalRoot_Class_3.crt
> lrwxrwxrwx 1 root root 27 Feb 18 13:27 1e8e7201.0 -> GlobalSign_Root_CA_-_R3.crt
> lrwxrwxrwx 1 root root 36 Feb 18 13:27 1eb37bdf.0 -> Chambers_of_Commerce_Root_-_2008.crt
> lrwxrwxrwx 1 root root 25 Feb 18 13:27 1f58a078.0 -> QuoVadis_Root_CA_2_G3.crt
> lrwxrwxrwx 1 root root 23 Feb 18 13:27 219d9499.0 -> Go_Daddy_Class_2_CA.crt
> lrwxrwxrwx 1 root root 24 Feb 18 13:27 23f4c490.0 -> Starfield_Class_2_CA.crt
> lrwxrwxrwx 1 root root 38 Feb 18 13:27 244b5494.0 -> DigiCert_High_Assurance_EV_Root_CA.crt
> lrwxrwxrwx 1 root root 49 Feb 18 13:27 27af790d.0 -> GeoTrust_Primary_Certification_Authority_-_G2.crt
> lrwxrwxrwx 1 root root 31 Feb 18 13:27 2add47b6.0 -> GlobalSign_ECC_Root_CA_-_R5.crt
> lrwxrwxrwx 1 root root 20 Feb 18 13:27 2ae6433e.0 -> CA_Disig_Root_R2.crt
> lrwxrwxrwx 1 root root 26 Feb 18 13:27 2b349938.0 -> AffirmTrust_Commercial.crt
> lrwxrwxrwx 1 root root 24 Feb 18 13:27 2c11d503.0 -> OpenTrust_Root_CA_G3.crt
> lrwxrwxrwx 1 root root 22 Feb 18 13:27 2c543cd1.0 -> GeoTrust_Global_CA.crt
> lrwxrwxrwx 1 root root 27 Feb 18 13:27 2d9dafe4.0 -> Buypass_Class_3_Root_CA.crt
> lrwxrwxrwx 1 root root 26 Feb 18 13:27 2e4eed3c.0 -> thawte_Primary_Root_CA.crt
> lrwxrwxrwx 1 root root 18 Feb 18 13:27 2e5ac55d.0 -> DST_Root_CA_X3.crt
> lrwxrwxrwx 1 root root 43 Feb 18 13:27 2fa87019.0 -> Network_Solutions_Certificate_Authority.crt
> lrwxrwxrwx 1 root root 49 Feb 18 13:27 31188b5e.0 -> TUBITAK_Kamu_SM_SSL_Kok_Sertifikasi_-_Surum_1.crt
> lrwxrwxrwx 1 root root 59 Feb 18 13:27 32888f65.0 -> Hellenic_Academic_and_Research_Institutions_RootCA_2015.crt
> lrwxrwxrwx 1 root root 44 Feb 18 13:27 33ee480d.0 -> SSL.com_Root_Certification_Authority_RSA.crt
> lrwxrwxrwx 1 root root 26 Feb 18 13:27 343eb6cb.0 -> Cybertrust_Global_Root.crt
> lrwxrwxrwx 1 root root 10 Feb 18 13:27 349f2832.0 -> EC-ACC.crt
> lrwxrwxrwx 1 root root 41 Feb 18 13:27 35105088.0 -> USERTrust_RSA_Certification_Authority.crt
> lrwxrwxrwx 1 root root 27 Feb 18 13:27 3513523f.0 -> DigiCert_Global_Root_CA.crt
> lrwxrwxrwx 1 root root 24 Feb 18 13:27 3929ec9f.0 -> OpenTrust_Root_CA_G2.crt
> lrwxrwxrwx 1 root root 27 Feb 18 13:27 399e7759.0 -> DigiCert_Global_Root_CA.crt
> lrwxrwxrwx 1 root root 35 Feb 18 13:27 3a3b02ce.0 -> OISTE_WISeKey_Global_Root_GA_CA.crt
> lrwxrwxrwx 1 root root 29 Feb 18 13:27 3ad48a91.0 -> Baltimore_CyberTrust_Root.crt
> lrwxrwxrwx 1 root root 61 Feb 18 13:27 3bde41ac.0 -> Autoridad_de_Certificacion_Firmaprofesional_CIF_A62634068.crt
> lrwxrwxrwx 1 root root 26 Feb 18 13:27 3c58f906.0 -> AddTrust_External_Root.crt
> lrwxrwxrwx 1 root root 36 Feb 18 13:27 3c6676aa.0 -> Staat_der_Nederlanden_EV_Root_CA.crt
> lrwxrwxrwx 1 root root 26 Feb 18 13:27 3c860d51.0 -> SwissSign_Gold_CA_-_G2.crt
> lrwxrwxrwx 1 root root 13 Feb 18 13:27 3c9a4d3b.0 -> ACCVRAIZ1.crt
> lrwxrwxrwx 1 root root 38 Feb 18 13:27 3d441de8.0 -> Staat_der_Nederlanden_Root_CA_-_G2.crt
> lrwxrwxrwx 1 root root 26 Feb 18 13:27 3e44d2f7.0 -> TrustCor_RootCert_CA-2.crt
> lrwxrwxrwx 1 root root 27 Feb 18 13:27 3e45d192.0 -> Hongkong_Post_Root_CA_1.crt
> lrwxrwxrwx 1 root root 45 Feb 18 13:27 3e7271e8.0 -> Entrust.net_Premium_2048_Secure_Server_CA.crt
> lrwxrwxrwx 1 root root 31 Feb 18 13:27 40193066.0 -> Certum_Trusted_Network_CA_2.crt
> lrwxrwxrwx 1 root root 16 Feb 18 13:27 4042bcee.0 -> ISRG_Root_X1.crt
> lrwxrwxrwx 1 root root 34 Feb 18 13:27 40547a79.0 -> COMODO_Certification_Authority.crt
> lrwxrwxrwx 1 root root 59 Feb 18 13:27 40dc992e.0 -> Hellenic_Academic_and_Research_Institutions_RootCA_2011.crt
> lrwxrwxrwx 1 root root 43 Feb 18 13:27 4304c5e5.0 -> Network_Solutions_Certificate_Authority.crt
> lrwxrwxrwx 1 root root 23 Feb 18 13:27 451b5485.0 -> Certplus_Root_CA_G2.crt
> lrwxrwxrwx 1 root root 45 Feb 18 13:27 455f1b52.0 -> Entrust_Root_Certification_Authority_-_G2.crt
> lrwxrwxrwx 1 root root 44 Feb 18 13:27 480720ec.0 -> GeoTrust_Primary_Certification_Authority.crt
> lrwxrwxrwx 1 root root 14 Feb 18 13:27 48a195d8.0 -> Izenpe.com.crt
> lrwxrwxrwx 1 root root 29 Feb 18 13:27 48bec511.0 -> Certum_Trusted_Network_CA.crt
> lrwxrwxrwx 1 root root 27 Feb 18 13:27 4a6481c9.0 -> GlobalSign_Root_CA_-_R2.crt
> lrwxrwxrwx 1 root root 37 Feb 18 13:27 4be590e0.0 -> IdenTrust_Public_Sector_Root_CA_1.crt
> lrwxrwxrwx 1 root root 45 Feb 18 13:27 4bfab552.0 -> Starfield_Root_Certificate_Authority_-_G2.crt
> lrwxrwxrwx 1 root root 30 Feb 18 13:27 4e18c148.0 -> Deutsche_Telekom_Root_CA_2.crt
> lrwxrwxrwx 1 root root 26 Feb 18 13:27 4f316efb.0 -> SwissSign_Gold_CA_-_G2.crt
> lrwxrwxrwx 1 root root 28 Feb 18 13:27 5046c355.0 -> SwissSign_Silver_CA_-_G2.crt
> lrwxrwxrwx 1 root root 51 Feb 18 13:27 524d9b43.0 -> VeriSign_Universal_Root_Certification_Authority.crt
> lrwxrwxrwx 1 root root 35 Feb 18 13:27 5273a94c.0 -> E-Tugra_Certification_Authority.crt
> lrwxrwxrwx 1 root root 25 Feb 18 13:27 52b525c7.0 -> QuoVadis_Root_CA_1_G3.crt
> lrwxrwxrwx 1 root root 32 Feb 18 13:27 5443e9e3.0 -> T-TeleSec_GlobalRoot_Class_3.crt
> lrwxrwxrwx 1 root root 27 Feb 18 13:27 54657681.0 -> Buypass_Class_2_Root_CA.crt
> lrwxrwxrwx 1 root root 24 Feb 18 13:27 559f7c71.0 -> OpenTrust_Root_CA_G3.crt
> lrwxrwxrwx 1 root root 28 Feb 18 13:27 57bcb2da.0 -> SwissSign_Silver_CA_-_G2.crt
> lrwxrwxrwx 1 root root 50 Feb 18 13:27 583d0756.0 -> SSL.com_EV_Root_Certification_Authority_RSA_R2.crt
> lrwxrwxrwx 1 root root 38 Feb 18 13:27 5a250ea7.0 -> Staat_der_Nederlanden_Root_CA_-_G3.crt
> lrwxrwxrwx 1 root root 34 Feb 18 13:27 5a3f0ff8.0 -> COMODO_Certification_Authority.crt
> lrwxrwxrwx 1 root root 38 Feb 18 13:27 5a4d6896.0 -> Staat_der_Nederlanden_Root_CA_-_G3.crt
> lrwxrwxrwx 1 root root 22 Feb 18 13:27 5ad8a5d6.0 -> GlobalSign_Root_CA.crt
> lrwxrwxrwx 1 root root 38 Feb 18 13:27 5c44d531.0 -> Staat_der_Nederlanden_Root_CA_-_G2.crt
> lrwxrwxrwx 1 root root 26 Feb 18 13:27 5cd81ad7.0 -> TeliaSonera_Root_CA_v1.crt
> lrwxrwxrwx 1 root root 20 Feb 18 13:27 5cf9d536.0 -> QuoVadis_Root_CA.crt
> lrwxrwxrwx 1 root root 26 Feb 18 13:27 5d3033c5.0 -> TrustCor_RootCert_CA-1.crt
> lrwxrwxrwx 1 root root 64 Feb 18 13:27 5e4e69e7.0 -> VeriSign_Class_3_Public_Primary_Certification_Authority_-_G4.crt
> lrwxrwxrwx 1 root root 23 Feb 18 13:27 5f15c80c.0 -> TWCA_Global_Root_CA.crt
> lrwxrwxrwx 1 root root 34 Feb 18 13:27 5f47b495.0 -> Actalis_Authentication_Root_CA.crt
> lrwxrwxrwx 1 root root 27 Feb 18 13:27 607986c7.0 -> DigiCert_Global_Root_G2.crt
> lrwxrwxrwx 1 root root 24 Feb 18 13:27 608a55ad.0 -> OpenTrust_Root_CA_G2.crt
> lrwxrwxrwx 1 root root 48 Feb 18 13:27 60afe812.0 -> NetLock_Arany_=Class_Gold=_FĹ‘tanĂşsĂtvány.crt
> lrwxrwxrwx 1 root root 16 Feb 18 13:27 6187b673.0 -> ISRG_Root_X1.crt
> lrwxrwxrwx 1 root root 26 Feb 18 13:27 63a2c897.0 -> TeliaSonera_Root_CA_v1.crt
> lrwxrwxrwx 1 root root 15 Feb 18 13:27 6410666e.0 -> Taiwan_GRCA.crt
> lrwxrwxrwx 1 root root 29 Feb 18 13:27 653b494a.0 -> Baltimore_CyberTrust_Root.crt
> lrwxrwxrwx 1 root root 31 Feb 18 13:27 67495436.0 -> thawte_Primary_Root_CA_-_G3.crt
> lrwxrwxrwx 1 root root 31 Feb 18 13:27 69105f4f.0 -> DigiCert_Assured_ID_Root_CA.crt
> lrwxrwxrwx 1 root root 40 Feb 18 13:27 6b99d060.0 -> Entrust_Root_Certification_Authority.crt
> lrwxrwxrwx 1 root root 20 Feb 18 13:27 6d41d539.0 -> Amazon_Root_CA_2.crt
> lrwxrwxrwx 1 root root 44 Feb 18 13:27 6fa5da56.0 -> SSL.com_Root_Certification_Authority_RSA.crt
> lrwxrwxrwx 1 root root 23 Feb 18 13:27 6fcc125d.0 -> Visa_eCommerce_Root.crt
> lrwxrwxrwx 1 root root 24 Feb 18 13:27 706f604c.0 -> XRamp_Global_CA_Root.crt
> lrwxrwxrwx 1 root root 25 Feb 18 13:27 749e9e03.0 -> QuoVadis_Root_CA_1_G3.crt
> lrwxrwxrwx 1 root root 28 Feb 18 13:27 75680d2e.0 -> Comodo_AAA_Services_root.crt
> lrwxrwxrwx 1 root root 28 Feb 18 13:27 75d1b2ed.0 -> DigiCert_Trusted_Root_G4.crt
> lrwxrwxrwx 1 root root 24 Feb 18 13:27 76579174.0 -> XRamp_Global_CA_Root.crt
> lrwxrwxrwx 1 root root 26 Feb 18 13:27 76cb8f92.0 -> Cybertrust_Global_Root.crt
> lrwxrwxrwx 1 root root 22 Feb 18 13:27 76faf6c0.0 -> QuoVadis_Root_CA_3.crt
> lrwxrwxrwx 1 root root 63 Feb 18 13:27 7719f463.0 -> Hellenic_Academic_and_Research_Institutions_ECC_RootCA_2015.crt
> lrwxrwxrwx 1 root root 47 Feb 18 13:27 7892ad52.0 -> SSL.com_EV_Root_Certification_Authority_ECC.crt
> lrwxrwxrwx 1 root root 61 Feb 18 13:27 7992b8bb.0 -> TÜRKTRUST_Elektronik_Sertifika_Hizmet_Sağlayıcısı_H5.crt
> lrwxrwxrwx 1 root root 22 Feb 18 13:27 7999be0d.0 -> GeoTrust_Global_CA.crt
> lrwxrwxrwx 1 root root 20 Feb 18 13:27 7a7c655d.0 -> Amazon_Root_CA_3.crt
> lrwxrwxrwx 1 root root 22 Feb 18 13:27 7a819ef2.0 -> QuoVadis_Root_CA_2.crt
> lrwxrwxrwx 1 root root 18 Feb 18 13:27 7aaf71c0.0 -> TrustCor_ECA-1.crt
> lrwxrwxrwx 1 root root 26 Feb 18 13:27 7c302982.0 -> TrustCor_RootCert_CA-1.crt
> lrwxrwxrwx 1 root root 64 Feb 18 13:27 7d0b38bd.0 -> VeriSign_Class_3_Public_Primary_Certification_Authority_-_G4.crt
> lrwxrwxrwx 1 root root 64 Feb 18 13:27 7d453d8f.0 -> Verisign_Class_3_Public_Primary_Certification_Authority_-_G3.crt
> lrwxrwxrwx 1 root root 31 Feb 18 13:27 7f3d5d1d.0 -> DigiCert_Assured_ID_Root_G3.crt
> lrwxrwxrwx 1 root root 30 Feb 18 13:27 812e17de.0 -> Deutsche_Telekom_Root_CA_2.crt
> lrwxrwxrwx 1 root root 34 Feb 18 13:27 8160b96c.0 -> Microsec_e-Szigno_Root_CA_2009.crt
> lrwxrwxrwx 1 root root 38 Feb 18 13:27 81b9768f.0 -> DigiCert_High_Assurance_EV_Root_CA.crt
> lrwxrwxrwx 1 root root 27 Feb 18 13:27 82223c44.0 -> Buypass_Class_2_Root_CA.crt
> lrwxrwxrwx 1 root root 45 Feb 18 13:27 85cde254.0 -> Starfield_Root_Certificate_Authority_-_G2.crt
> lrwxrwxrwx 1 root root 26 Feb 18 13:27 86212b19.0 -> AffirmTrust_Networking.crt
> lrwxrwxrwx 1 root root 24 Feb 18 13:27 87229d21.0 -> OpenTrust_Root_CA_G1.crt
> lrwxrwxrwx 1 root root 27 Feb 18 13:27 87753b0d.0 -> GeoTrust_Universal_CA_2.crt
> lrwxrwxrwx 1 root root 20 Feb 18 13:27 882de061.0 -> certSIGN_ROOT_CA.crt
> lrwxrwxrwx 1 root root 27 Feb 18 13:27 8867006a.0 -> GeoTrust_Universal_CA_2.crt
> lrwxrwxrwx 1 root root 44 Feb 18 13:27 88950faa.0 -> SSL.com_Root_Certification_Authority_ECC.crt
> lrwxrwxrwx 1 root root 38 Feb 18 13:27 89c02a45.0 -> COMODO_ECC_Certification_Authority.crt
> lrwxrwxrwx 1 root root 20 Feb 18 13:27 8cb5ee0f.0 -> Amazon_Root_CA_3.crt
> lrwxrwxrwx 1 root root 31 Feb 18 13:27 8d6437c3.0 -> DigiCert_Assured_ID_Root_G2.crt
> lrwxrwxrwx 1 root root 20 Feb 18 13:27 8d86cdd1.0 -> certSIGN_ROOT_CA.crt
> lrwxrwxrwx 1 root root 23 Feb 18 13:27 9168f543.0 -> Certplus_Root_CA_G1.crt
> lrwxrwxrwx 1 root root 35 Feb 18 13:27 91739615.0 -> EE_Certification_Centre_Root_CA.crt
> lrwxrwxrwx 1 root root 16 Feb 18 13:27 9282e51c.0 -> CFCA_EV_ROOT.crt
> lrwxrwxrwx 1 root root 34 Feb 18 13:27 930ac5d2.0 -> Actalis_Authentication_Root_CA.crt
> lrwxrwxrwx 1 root root 22 Feb 18 13:27 9339512a.0 -> QuoVadis_Root_CA_3.crt
> lrwxrwxrwx 1 root root 26 Feb 18 13:27 93bc0acc.0 -> AffirmTrust_Networking.crt
> lrwxrwxrwx 1 root root 63 Feb 18 13:27 9479c8c3.0 -> Hellenic_Academic_and_Research_Institutions_ECC_RootCA_2015.crt
> lrwxrwxrwx 1 root root 20 Feb 18 13:27 9576d26b.0 -> CA_Disig_Root_R2.crt
> lrwxrwxrwx 1 root root 29 Feb 18 13:27 95aff9e3.0 -> Certum_Trusted_Network_CA.crt
> lrwxrwxrwx 1 root root 27 Feb 18 13:27 9685a493.0 -> Hongkong_Post_Root_CA_1.crt
> lrwxrwxrwx 1 root root 44 Feb 18 13:27 9772ca32.0 -> GeoTrust_Primary_Certification_Authority.crt
> lrwxrwxrwx 1 root root 48 Feb 18 13:27 988a38cb.0 -> NetLock_Arany_=Class_Gold=_FĹ‘tanĂşsĂtvány.crt
> lrwxrwxrwx 1 root root 26 Feb 18 13:27 9c2e7d30.0 -> Sonera_Class_2_Root_CA.crt
> lrwxrwxrwx 1 root root 24 Feb 18 13:27 9c3323d4.0 -> OpenTrust_Root_CA_G1.crt
> lrwxrwxrwx 1 root root 27 Feb 18 13:27 9c8dfbd4.0 -> AffirmTrust_Premium_ECC.crt
> lrwxrwxrwx 1 root root 31 Feb 18 13:27 9d04f354.0 -> DigiCert_Assured_ID_Root_G2.crt
> lrwxrwxrwx 1 root root 37 Feb 18 13:27 9d6523ce.0 -> ePKI_Root_Certification_Authority.crt
> lrwxrwxrwx 1 root root 24 Feb 18 13:27 9f0f5fd6.0 -> Certinomis_-_Root_CA.crt
> lrwxrwxrwx 1 root root 34 Feb 18 13:27 9f533518.0 -> Global_Chambersign_Root_-_2008.crt
> -rw-r--r-- 1 root root 2772 Feb 18 13:18 ACCVRAIZ1.crt
> -rw-r--r-- 1 root root 1972 Feb 18 13:18 AC_RAIZ_FNMT-RCM.crt
> -rw-r--r-- 1 root root 2049 Feb 18 13:18 Actalis_Authentication_Root_CA.crt
> -rw-r--r-- 1 root root 1521 Feb 18 13:18 AddTrust_External_Root.crt
> -rw-r--r-- 1 root root 1204 Feb 18 13:18 AffirmTrust_Commercial.crt
> -rw-r--r-- 1 root root 1204 Feb 18 13:18 AffirmTrust_Networking.crt
> -rw-r--r-- 1 root root 1891 Feb 18 13:18 AffirmTrust_Premium.crt
> -rw-r--r-- 1 root root 753 Feb 18 13:18 AffirmTrust_Premium_ECC.crt
> -rw-r--r-- 1 root root 1188 Feb 18 13:18 Amazon_Root_CA_1.crt
> -rw-r--r-- 1 root root 1883 Feb 18 13:18 Amazon_Root_CA_2.crt
> -rw-r--r-- 1 root root 656 Feb 18 13:18 Amazon_Root_CA_3.crt
> -rw-r--r-- 1 root root 737 Feb 18 13:18 Amazon_Root_CA_4.crt
> -rw-r--r-- 1 root root 1261 Feb 18 13:18 Atos_TrustedRoot_2011.crt
> -rw-r--r-- 1 root root 2167 Feb 18 13:18 Autoridad_de_Certificacion_Firmaprofesional_CIF_A62634068.crt
> -rw-r--r-- 1 root root 1261 Feb 18 13:18 Baltimore_CyberTrust_Root.crt
> -rw-r--r-- 1 root root 1915 Feb 18 13:18 Buypass_Class_2_Root_CA.crt
> -rw-r--r-- 1 root root 1915 Feb 18 13:18 Buypass_Class_3_Root_CA.crt
> -rw-r--r-- 1 root root 1935 Feb 18 13:18 CA_Disig_Root_R2.crt
> -rw-r--r-- 1 root root 1984 Feb 18 13:18 CFCA_EV_ROOT.crt
> -rw-r--r-- 1 root root 1489 Feb 18 13:18 COMODO_Certification_Authority.crt
> -rw-r--r-- 1 root root 940 Feb 18 13:18 COMODO_ECC_Certification_Authority.crt
> -rw-r--r-- 1 root root 2086 Feb 18 13:18 COMODO_RSA_Certification_Authority.crt
> -rw-r--r-- 1 root root 1330 Feb 18 13:18 Certigna.crt
> -rw-r--r-- 1 root root 1992 Feb 18 13:18 Certinomis_-_Root_CA.crt
> -rw-r--r-- 1 root root 1298 Feb 18 13:18 Certplus_Class_2_Primary_CA.crt
> -rw-r--r-- 1 root root 1939 Feb 18 13:18 Certplus_Root_CA_G1.crt
> -rw-r--r-- 1 root root 794 Feb 18 13:18 Certplus_Root_CA_G2.crt
> -rw-r--r-- 1 root root 1354 Feb 18 13:18 Certum_Trusted_Network_CA.crt
> -rw-r--r-- 1 root root 2078 Feb 18 13:18 Certum_Trusted_Network_CA_2.crt
> -rw-r--r-- 1 root root 2594 Feb 18 13:18 Chambers_of_Commerce_Root_-_2008.crt
> -rw-r--r-- 1 root root 1517 Feb 18 13:18 Comodo_AAA_Services_root.crt
> -rw-r--r-- 1 root root 1318 Feb 18 13:18 Cybertrust_Global_Root.crt
> -rw-r--r-- 1 root root 1517 Feb 18 13:18 D-TRUST_Root_Class_3_CA_2_2009.crt
> -rw-r--r-- 1 root root 1537 Feb 18 13:18 D-TRUST_Root_Class_3_CA_2_EV_2009.crt
> -rw-r--r-- 1 root root 1200 Feb 18 13:18 DST_Root_CA_X3.crt
> -rw-r--r-- 1 root root 1318 Feb 18 13:18 Deutsche_Telekom_Root_CA_2.crt
> -rw-r--r-- 1 root root 1350 Feb 18 13:18 DigiCert_Assured_ID_Root_CA.crt
> -rw-r--r-- 1 root root 1306 Feb 18 13:18 DigiCert_Assured_ID_Root_G2.crt
> -rw-r--r-- 1 root root 851 Feb 18 13:18 DigiCert_Assured_ID_Root_G3.crt
> -rw-r--r-- 1 root root 1338 Feb 18 13:18 DigiCert_Global_Root_CA.crt
> -rw-r--r-- 1 root root 1294 Feb 18 13:18 DigiCert_Global_Root_G2.crt
> -rw-r--r-- 1 root root 839 Feb 18 13:18 DigiCert_Global_Root_G3.crt
> -rw-r--r-- 1 root root 1367 Feb 18 13:18 DigiCert_High_Assurance_EV_Root_CA.crt
> -rw-r--r-- 1 root root 1988 Feb 18 13:18 DigiCert_Trusted_Root_G4.crt
> -rw-r--r-- 1 root root 2244 Feb 18 13:18 E-Tugra_Certification_Authority.crt
> -rw-r--r-- 1 root root 1911 Feb 18 13:18 EC-ACC.crt
> -rw-r--r-- 1 root root 1452 Feb 18 13:18 EE_Certification_Centre_Root_CA.crt
> -rw-r--r-- 1 root root 1505 Feb 18 13:18 Entrust.net_Premium_2048_Secure_Server_CA.crt
> -rw-r--r-- 1 root root 1643 Feb 18 13:18 Entrust_Root_Certification_Authority.crt
> -rw-r--r-- 1 root root 1090 Feb 18 13:18 Entrust_Root_Certification_Authority_-_EC1.crt
> -rw-r--r-- 1 root root 1533 Feb 18 13:18 Entrust_Root_Certification_Authority_-_G2.crt
> -rw-r--r-- 1 root root 1980 Feb 18 13:18 GDCA_TrustAUTH_R5_ROOT.crt
> -rw-r--r-- 1 root root 1216 Feb 18 13:18 GeoTrust_Global_CA.crt
> -rw-r--r-- 1 root root 1269 Feb 18 13:18 GeoTrust_Primary_Certification_Authority.crt
> -rw-r--r-- 1 root root 989 Feb 18 13:18 GeoTrust_Primary_Certification_Authority_-_G2.crt
> -rw-r--r-- 1 root root 1444 Feb 18 13:18 GeoTrust_Primary_Certification_Authority_-_G3.crt
> -rw-r--r-- 1 root root 1935 Feb 18 13:18 GeoTrust_Universal_CA.crt
> -rw-r--r-- 1 root root 1939 Feb 18 13:18 GeoTrust_Universal_CA_2.crt
> -rw-r--r-- 1 root root 713 Feb 18 13:18 GlobalSign_ECC_Root_CA_-_R4.crt
> -rw-r--r-- 1 root root 794 Feb 18 13:18 GlobalSign_ECC_Root_CA_-_R5.crt
> -rw-r--r-- 1 root root 1261 Feb 18 13:18 GlobalSign_Root_CA.crt
> -rw-r--r-- 1 root root 1354 Feb 18 13:18 GlobalSign_Root_CA_-_R2.crt
> -rw-r--r-- 1 root root 1229 Feb 18 13:18 GlobalSign_Root_CA_-_R3.crt
> -rw-r--r-- 1 root root 2585 Feb 18 13:18 Global_Chambersign_Root_-_2008.crt
> -rw-r--r-- 1 root root 1448 Feb 18 13:18 Go_Daddy_Class_2_CA.crt
> -rw-r--r-- 1 root root 1367 Feb 18 13:18 Go_Daddy_Root_Certificate_Authority_-_G2.crt
> -rw-r--r-- 1 root root 1017 Feb 18 13:18 Hellenic_Academic_and_Research_Institutions_ECC_RootCA_2015.crt
> -rw-r--r-- 1 root root 1513 Feb 18 13:18 Hellenic_Academic_and_Research_Institutions_RootCA_2011.crt
> -rw-r--r-- 1 root root 2155 Feb 18 13:18 Hellenic_Academic_and_Research_Institutions_RootCA_2015.crt
> -rw-r--r-- 1 root root 1168 Feb 18 13:18 Hongkong_Post_Root_CA_1.crt
> -rw-r--r-- 1 root root 1939 Feb 18 13:18 ISRG_Root_X1.crt
> -rw-r--r-- 1 root root 1923 Feb 18 13:18 IdenTrust_Commercial_Root_CA_1.crt
> -rw-r--r-- 1 root root 1931 Feb 18 13:18 IdenTrust_Public_Sector_Root_CA_1.crt
> -rw-r--r-- 1 root root 2122 Feb 18 13:18 Izenpe.com.crt
> -rw-r--r-- 1 root root 2057 Feb 18 13:18 LuxTrust_Global_Root_2.crt
> -rw-r--r-- 1 root root 1460 Feb 18 13:18 Microsec_e-Szigno_Root_CA_2009.crt
> -rw-r--r-- 1 root root 1476 Feb 18 13:18 NetLock_Arany_=Class_Gold=_FĹ‘tanĂşsĂtvány.crt
> -rw-r--r-- 1 root root 1411 Feb 18 13:18 Network_Solutions_Certificate_Authority.crt
> -rw-r--r-- 1 root root 1428 Feb 18 13:18 OISTE_WISeKey_Global_Root_GA_CA.crt
> -rw-r--r-- 1 root root 1346 Feb 18 13:18 OISTE_WISeKey_Global_Root_GB_CA.crt
> -rw-r--r-- 1 root root 1944 Feb 18 13:18 OpenTrust_Root_CA_G1.crt
> -rw-r--r-- 1 root root 1944 Feb 18 13:18 OpenTrust_Root_CA_G2.crt
> -rw-r--r-- 1 root root 798 Feb 18 13:18 OpenTrust_Root_CA_G3.crt
> -rw-r--r-- 1 root root 2078 Feb 18 13:18 QuoVadis_Root_CA.crt
> -rw-r--r-- 1 root root 1923 Feb 18 13:18 QuoVadis_Root_CA_1_G3.crt
> -rw-r--r-- 1 root root 2041 Feb 18 13:18 QuoVadis_Root_CA_2.crt
> -rw-r--r-- 1 root root 1923 Feb 18 13:18 QuoVadis_Root_CA_2_G3.crt
> -rw-r--r-- 1 root root 2354 Feb 18 13:18 QuoVadis_Root_CA_3.crt
> -rw-r--r-- 1 root root 1923 Feb 18 13:18 QuoVadis_Root_CA_3_G3.crt
> -rw-r--r-- 1 root root 956 Feb 18 13:18 SSL.com_EV_Root_Certification_Authority_ECC.crt
> -rw-r--r-- 1 root root 2114 Feb 18 13:18 SSL.com_EV_Root_Certification_Authority_RSA_R2.crt
> -rw-r--r-- 1 root root 944 Feb 18 13:18 SSL.com_Root_Certification_Authority_ECC.crt
> -rw-r--r-- 1 root root 2094 Feb 18 13:18 SSL.com_Root_Certification_Authority_RSA.crt
> -rw-r--r-- 1 root root 1257 Feb 18 13:18 SZAFIR_ROOT_CA2.crt
> -rw-r--r-- 1 root root 1249 Feb 18 13:18 SecureSign_RootCA11.crt
> -rw-r--r-- 1 root root 1350 Feb 18 13:18 SecureTrust_CA.crt
> -rw-r--r-- 1 root root 1354 Feb 18 13:18 Secure_Global_CA.crt
> -rw-r--r-- 1 root root 1261 Feb 18 13:18 Security_Communication_RootCA2.crt
> -rw-r--r-- 1 root root 1224 Feb 18 13:18 Security_Communication_Root_CA.crt
> -rw-r--r-- 1 root root 1143 Feb 18 13:18 Sonera_Class_2_Root_CA.crt
> -rw-r--r-- 1 root root 1948 Feb 18 13:18 Staat_der_Nederlanden_EV_Root_CA.crt
> -rw-r--r-- 1 root root 2069 Feb 18 13:18 Staat_der_Nederlanden_Root_CA_-_G2.crt
> -rw-r--r-- 1 root root 1952 Feb 18 13:18 Staat_der_Nederlanden_Root_CA_-_G3.crt
> -rw-r--r-- 1 root root 1468 Feb 18 13:18 Starfield_Class_2_CA.crt
> -rw-r--r-- 1 root root 1399 Feb 18 13:18 Starfield_Root_Certificate_Authority_-_G2.crt
> -rw-r--r-- 1 root root 1424 Feb 18 13:18 Starfield_Services_Root_Certificate_Authority_-_G2.crt
> -rw-r--r-- 1 root root 2045 Feb 18 13:18 SwissSign_Gold_CA_-_G2.crt
> -rw-r--r-- 1 root root 2049 Feb 18 13:18 SwissSign_Silver_CA_-_G2.crt
> -rw-r--r-- 1 root root 1367 Feb 18 13:18 T-TeleSec_GlobalRoot_Class_2.crt
> -rw-r--r-- 1 root root 1367 Feb 18 13:18 T-TeleSec_GlobalRoot_Class_3.crt
> -rw-r--r-- 1 root root 1582 Feb 18 13:18 TUBITAK_Kamu_SM_SSL_Kok_Sertifikasi_-_Surum_1.crt
> -rw-r--r-- 1 root root 1883 Feb 18 13:18 TWCA_Global_Root_CA.crt
> -rw-r--r-- 1 root root 1269 Feb 18 13:18 TWCA_Root_Certification_Authority.crt
> -rw-r--r-- 1 root root 1948 Feb 18 13:18 Taiwan_GRCA.crt
> -rw-r--r-- 1 root root 1870 Feb 18 13:18 TeliaSonera_Root_CA_v1.crt
> -rw-r--r-- 1 root root 1493 Feb 18 13:18 TrustCor_ECA-1.crt
> -rw-r--r-- 1 root root 1513 Feb 18 13:18 TrustCor_RootCert_CA-1.crt
> -rw-r--r-- 1 root root 2204 Feb 18 13:18 TrustCor_RootCert_CA-2.crt
> -rw-r--r-- 1 root root 1241 Feb 18 13:18 Trustis_FPS_Root_CA.crt
> -rw-r--r-- 1 root root 1501 Feb 18 13:18 TÜRKTRUST_Elektronik_Sertifika_Hizmet_Sağlayıcısı_H5.crt
> -rw-r--r-- 1 root root 948 Feb 18 13:18 USERTrust_ECC_Certification_Authority.crt
> -rw-r--r-- 1 root root 2094 Feb 18 13:18 USERTrust_RSA_Certification_Authority.crt
> -rw-r--r-- 1 root root 1281 Feb 18 13:18 VeriSign_Class_3_Public_Primary_Certification_Authority_-_G4.crt
> -rw-r--r-- 1 root root 1732 Feb 18 13:18 VeriSign_Class_3_Public_Primary_Certification_Authority_-_G5.crt
> -rw-r--r-- 1 root root 1700 Feb 18 13:18 VeriSign_Universal_Root_Certification_Authority.crt
> -rw-r--r-- 1 root root 1484 Feb 18 13:18 Verisign_Class_3_Public_Primary_Certification_Authority_-_G3.crt
> -rw-r--r-- 1 root root 1322 Feb 18 13:18 Visa_eCommerce_Root.crt
> -rw-r--r-- 1 root root 1513 Feb 18 13:18 XRamp_Global_CA_Root.crt
> lrwxrwxrwx 1 root root 28 Feb 18 13:27 a2c66da8.0 -> DigiCert_Trusted_Root_G4.crt
> lrwxrwxrwx 1 root root 34 Feb 18 13:27 a3896b44.0 -> Security_Communication_Root_CA.crt
> lrwxrwxrwx 1 root root 26 Feb 18 13:27 a7605362.0 -> Sonera_Class_2_Root_CA.crt
> lrwxrwxrwx 1 root root 23 Feb 18 13:27 a760e1bd.0 -> Visa_eCommerce_Root.crt
> lrwxrwxrwx 1 root root 31 Feb 18 13:27 a7d2cf64.0 -> thawte_Primary_Root_CA_-_G2.crt
> lrwxrwxrwx 1 root root 19 Feb 18 13:27 a81e292b.0 -> SZAFIR_ROOT_CA2.crt
> lrwxrwxrwx 1 root root 13 Feb 18 13:27 a94d09e5.0 -> ACCVRAIZ1.crt
> lrwxrwxrwx 1 root root 23 Feb 18 13:27 ab5346f4.0 -> SecureSign_RootCA11.crt
> lrwxrwxrwx 1 root root 26 Feb 18 13:27 ab59055e.0 -> GDCA_TrustAUTH_R5_ROOT.crt
> lrwxrwxrwx 1 root root 25 Feb 18 13:27 ad088e1d.0 -> GeoTrust_Universal_CA.crt
> lrwxrwxrwx 1 root root 10 Feb 18 13:27 aeb67534.0 -> EC-ACC.crt
> lrwxrwxrwx 1 root root 45 Feb 18 13:27 aee5f10d.0 -> Entrust.net_Premium_2048_Secure_Server_CA.crt
> lrwxrwxrwx 1 root root 31 Feb 18 13:27 b0e59380.0 -> GlobalSign_ECC_Root_CA_-_R4.crt
> lrwxrwxrwx 1 root root 23 Feb 18 13:27 b0ed035a.0 -> TWCA_Global_Root_CA.crt
> lrwxrwxrwx 1 root root 22 Feb 18 13:27 b0f3e76e.0 -> GlobalSign_Root_CA.crt
> lrwxrwxrwx 1 root root 31 Feb 18 13:27 b1159c4c.0 -> DigiCert_Assured_ID_Root_CA.crt
> lrwxrwxrwx 1 root root 35 Feb 18 13:27 b1b8a7f3.0 -> OISTE_WISeKey_Global_Root_GA_CA.crt
> lrwxrwxrwx 1 root root 64 Feb 18 13:27 b204d74a.0 -> VeriSign_Class_3_Public_Primary_Certification_Authority_-_G5.crt
> lrwxrwxrwx 1 root root 46 Feb 18 13:27 b3fb433b.0 -> Entrust_Root_Certification_Authority_-_EC1.crt
> lrwxrwxrwx 1 root root 20 Feb 18 13:27 b66938e9.0 -> Secure_Global_CA.crt
> lrwxrwxrwx 1 root root 23 Feb 18 13:27 b727005e.0 -> AffirmTrust_Premium.crt
> lrwxrwxrwx 1 root root 37 Feb 18 13:27 b7a5b843.0 -> TWCA_Root_Certification_Authority.crt
> lrwxrwxrwx 1 root root 37 Feb 18 13:27 b7db1890.0 -> TWCA_Root_Certification_Authority.crt
> lrwxrwxrwx 1 root root 25 Feb 18 13:27 b872f2b4.0 -> Atos_TrustedRoot_2011.crt
> lrwxrwxrwx 1 root root 20 Feb 18 13:27 b936d1c6.0 -> AC_RAIZ_FNMT-RCM.crt
> lrwxrwxrwx 1 root root 31 Feb 18 13:27 ba89ed3b.0 -> thawte_Primary_Root_CA_-_G3.crt
> lrwxrwxrwx 1 root root 44 Feb 18 13:27 bc3f2570.0 -> Go_Daddy_Root_Certificate_Authority_-_G2.crt
> lrwxrwxrwx 1 root root 20 Feb 18 13:27 bdacca6f.0 -> Secure_Global_CA.crt
> lrwxrwxrwx 1 root root 40 Feb 18 13:27 bf64f35b.0 -> Entrust_Root_Certification_Authority.crt
> lrwxrwxrwx 1 root root 51 Feb 18 13:27 c01cdfa2.0 -> VeriSign_Universal_Root_Certification_Authority.crt
> lrwxrwxrwx 1 root root 31 Feb 18 13:27 c089bbbd.0 -> thawte_Primary_Root_CA_-_G2.crt
> lrwxrwxrwx 1 root root 64 Feb 18 13:27 c0ff1f52.0 -> Verisign_Class_3_Public_Primary_Certification_Authority_-_G3.crt
> lrwxrwxrwx 1 root root 34 Feb 18 13:27 c28a8a30.0 -> D-TRUST_Root_Class_3_CA_2_2009.crt
> lrwxrwxrwx 1 root root 18 Feb 18 13:27 c2c1704e.0 -> TrustCor_ECA-1.crt
> lrwxrwxrwx 1 root root 36 Feb 18 13:27 c47d9980.0 -> Chambers_of_Commerce_Root_-_2008.crt
> lrwxrwxrwx 1 root root 31 Feb 18 13:27 c491639e.0 -> DigiCert_Assured_ID_Root_G3.crt
> lrwxrwxrwx 1 root root 23 Feb 18 13:27 c51c224c.0 -> Trustis_FPS_Root_CA.crt
> lrwxrwxrwx 1 root root 49 Feb 18 13:27 c7e2a638.0 -> GeoTrust_Primary_Certification_Authority_-_G3.crt
> lrwxrwxrwx 1 root root 26 Feb 18 13:27 c907e29b.0 -> LuxTrust_Global_Root_2.crt
> lrwxrwxrwx 1 root root 27 Feb 18 13:27 c90bc37d.0 -> DigiCert_Global_Root_G2.crt
> -rw-r--r-- 1 root root 207436 Feb 18 13:18 ca-certificates.crt
> lrwxrwxrwx 1 root root 37 Feb 18 13:27 ca6e4ad9.0 -> ePKI_Root_Certification_Authority.crt
> lrwxrwxrwx 1 root root 35 Feb 18 13:27 cb156124.0 -> E-Tugra_Certification_Authority.crt
> lrwxrwxrwx 1 root root 31 Feb 18 13:27 cb1c3204.0 -> Certum_Trusted_Network_CA_2.crt
> lrwxrwxrwx 1 root root 44 Feb 18 13:27 cbf06781.0 -> Go_Daddy_Root_Certificate_Authority_-_G2.crt
> lrwxrwxrwx 1 root root 14 Feb 18 13:27 cc450945.0 -> Izenpe.com.crt
> lrwxrwxrwx 1 root root 27 Feb 18 13:27 ccc52f49.0 -> AffirmTrust_Premium_ECC.crt
> lrwxrwxrwx 1 root root 34 Feb 18 13:27 cd58d51e.0 -> Security_Communication_RootCA2.crt
> lrwxrwxrwx 1 root root 20 Feb 18 13:27 cd8c0d63.0 -> AC_RAIZ_FNMT-RCM.crt
> lrwxrwxrwx 1 root root 20 Feb 18 13:27 ce5e74ef.0 -> Amazon_Root_CA_1.crt
> -rw-r--r-- 1 root root 1176 Feb 18 13:18 certSIGN_ROOT_CA.crt
> lrwxrwxrwx 1 root root 18 Feb 18 13:27 cf701eeb.0 -> SecureTrust_CA.crt
> lrwxrwxrwx 1 root root 32 Feb 18 13:27 d06393bb.0 -> T-TeleSec_GlobalRoot_Class_2.crt
> lrwxrwxrwx 1 root root 26 Feb 18 13:27 d0cddf45.0 -> TrustCor_RootCert_CA-2.crt
> lrwxrwxrwx 1 root root 61 Feb 18 13:27 d16a5865.0 -> Autoridad_de_Certificacion_Firmaprofesional_CIF_A62634068.crt
> lrwxrwxrwx 1 root root 34 Feb 18 13:27 d18e9066.0 -> IdenTrust_Commercial_Root_CA_1.crt
> lrwxrwxrwx 1 root root 20 Feb 18 13:27 d41b5e2a.0 -> Amazon_Root_CA_4.crt
> lrwxrwxrwx 1 root root 38 Feb 18 13:27 d4c339cb.0 -> COMODO_RSA_Certification_Authority.crt
> lrwxrwxrwx 1 root root 37 Feb 18 13:27 d4dae3dd.0 -> D-TRUST_Root_Class_3_CA_2_EV_2009.crt
> lrwxrwxrwx 1 root root 34 Feb 18 13:27 d59297b8.0 -> Security_Communication_RootCA2.crt
> lrwxrwxrwx 1 root root 38 Feb 18 13:27 d6325660.0 -> COMODO_RSA_Certification_Authority.crt
> lrwxrwxrwx 1 root root 24 Feb 18 13:27 d6e6eab9.0 -> Certinomis_-_Root_CA.crt
> lrwxrwxrwx 1 root root 37 Feb 18 13:27 d7746a63.0 -> D-TRUST_Root_Class_3_CA_2_EV_2009.crt
> lrwxrwxrwx 1 root root 22 Feb 18 13:27 d7e8dc79.0 -> QuoVadis_Root_CA_2.crt
> lrwxrwxrwx 1 root root 23 Feb 18 13:27 d8317ada.0 -> Certplus_Root_CA_G2.crt
> lrwxrwxrwx 1 root root 23 Feb 18 13:27 d853d49e.0 -> Trustis_FPS_Root_CA.crt
> lrwxrwxrwx 1 root root 23 Feb 18 13:27 dbc54cab.0 -> AffirmTrust_Premium.crt
> lrwxrwxrwx 1 root root 59 Feb 18 13:27 dc99f41e.0 -> Hellenic_Academic_and_Research_Institutions_RootCA_2015.crt
> lrwxrwxrwx 1 root root 27 Feb 18 13:27 dd8e9d41.0 -> DigiCert_Global_Root_G3.crt
> lrwxrwxrwx 1 root root 20 Feb 18 13:27 de6d66f3.0 -> Amazon_Root_CA_4.crt
> lrwxrwxrwx 1 root root 26 Feb 18 13:27 def36a68.0 -> LuxTrust_Global_Root_2.crt
> lrwxrwxrwx 1 root root 35 Feb 18 13:27 dfc0fe80.0 -> OISTE_WISeKey_Global_Root_GB_CA.crt
> lrwxrwxrwx 1 root root 12 Feb 18 13:27 e113c810.0 -> Certigna.crt
> lrwxrwxrwx 1 root root 25 Feb 18 13:27 e18bfb83.0 -> QuoVadis_Root_CA_3_G3.crt
> lrwxrwxrwx 1 root root 49 Feb 18 13:27 e2799e36.0 -> GeoTrust_Primary_Certification_Authority_-_G3.crt
> lrwxrwxrwx 1 root root 25 Feb 18 13:27 e36a6752.0 -> Atos_TrustedRoot_2011.crt
> lrwxrwxrwx 1 root root 25 Feb 18 13:27 e442e424.0 -> QuoVadis_Root_CA_3_G3.crt
> lrwxrwxrwx 1 root root 26 Feb 18 13:27 e48193cf.0 -> AffirmTrust_Commercial.crt
> lrwxrwxrwx 1 root root 35 Feb 18 13:27 e73d606e.0 -> OISTE_WISeKey_Global_Root_GB_CA.crt
> lrwxrwxrwx 1 root root 25 Feb 18 13:27 e775ed2d.0 -> GeoTrust_Universal_CA.crt
> lrwxrwxrwx 1 root root 34 Feb 18 13:27 e8651083.0 -> Microsec_e-Szigno_Root_CA_2009.crt
> lrwxrwxrwx 1 root root 27 Feb 18 13:27 e8de2f56.0 -> Buypass_Class_3_Root_CA.crt
> -rw-r--r-- 1 root root 2033 Feb 18 13:18 ePKI_Root_Certification_Authority.crt
> lrwxrwxrwx 1 root root 27 Feb 18 13:27 ed39abd0.0 -> DigiCert_Global_Root_G3.crt
> lrwxrwxrwx 1 root root 28 Feb 18 13:27 ee64a828.0 -> Comodo_AAA_Services_root.crt
> lrwxrwxrwx 1 root root 38 Feb 18 13:27 eed8c118.0 -> COMODO_ECC_Certification_Authority.crt
> lrwxrwxrwx 1 root root 34 Feb 18 13:27 ef954a4e.0 -> IdenTrust_Commercial_Root_CA_1.crt
> lrwxrwxrwx 1 root root 31 Feb 18 13:27 f060240e.0 -> Certplus_Class_2_Primary_CA.crt
> lrwxrwxrwx 1 root root 23 Feb 18 13:27 f081611a.0 -> Go_Daddy_Class_2_CA.crt
> lrwxrwxrwx 1 root root 47 Feb 18 13:27 f0c70a8d.0 -> SSL.com_EV_Root_Certification_Authority_ECC.crt
> lrwxrwxrwx 1 root root 41 Feb 18 13:27 f30dd6ad.0 -> USERTrust_ECC_Certification_Authority.crt
> lrwxrwxrwx 1 root root 34 Feb 18 13:27 f3377b1b.0 -> Security_Communication_Root_CA.crt
> lrwxrwxrwx 1 root root 24 Feb 18 13:27 f387163d.0 -> Starfield_Class_2_CA.crt
> lrwxrwxrwx 1 root root 18 Feb 18 13:27 f39fc864.0 -> SecureTrust_CA.crt
> lrwxrwxrwx 1 root root 64 Feb 18 13:27 facacbc6.0 -> VeriSign_Class_3_Public_Primary_Certification_Authority_-_G5.crt
> lrwxrwxrwx 1 root root 20 Feb 18 13:27 fb5fa911.0 -> Amazon_Root_CA_2.crt
> lrwxrwxrwx 1 root root 41 Feb 18 13:27 fc5a8f99.0 -> USERTrust_RSA_Certification_Authority.crt
> lrwxrwxrwx 1 root root 20 Feb 18 13:27 fd08c599.0 -> Amazon_Root_CA_1.crt
> lrwxrwxrwx 1 root root 12 Feb 18 13:27 fde84897.0 -> Certigna.crt
> lrwxrwxrwx 1 root root 19 Feb 18 13:27 fe8a2cd8.0 -> SZAFIR_ROOT_CA2.crt
> lrwxrwxrwx 1 root root 49 Feb 18 13:27 ff34af3f.0 -> TUBITAK_Kamu_SM_SSL_Kok_Sertifikasi_-_Surum_1.crt
> -rw-r--r-- 1 root root 1493 Feb 18 13:18 thawte_Primary_Root_CA.crt
> -rw-r--r-- 1 root root 940 Feb 18 13:18 thawte_Primary_Root_CA_-_G2.crt
> -rw-r--r-- 1 root root 1505 Feb 18 13:18 thawte_Primary_Root_CA_-_G3.crt
> ************** certs
> ############## cron
> Package: vixie-cron
> Version: 7-3
> Depends: libc, syslog-ng3
> Architecture: mvebu
> Installed-Time: 1550492818
> /etc/cron.d/autocollect:MAILTO=""
> /etc/cron.d/autocollect:@daily root /usr/bin/nuci-helper-autocollect
> /etc/cron.d/get-api:MAILTO=""
> /etc/cron.d/get-api:*/30 * * * * root /usr/bin/get-api-crl
> /etc/cron.d/logrotate:MAILTO=""
> /etc/cron.d/logrotate:12 * * * * root /usr/sbin/logrotate -s /tmp/logrotate.state /etc/logrotate.conf
> /etc/cron.d/nethist:MAILTO=""
> /etc/cron.d/nethist:*/2 * * * * root nethist_stats.lua
> /etc/cron.d/nethist:1 0,6,12,18 * * * root (cat /tmp/nethist.stats | sort ; echo "uptime = $(cat /proc/uptime | cut -d. -f1)" ) | logger -p info -t nethist ; rm /tmp/nethist.stats
> /etc/cron.d/rainbow:MAILTO=""
> /etc/cron.d/rainbow:* * * * * root /usr/bin/rainbow_button_sync.sh
> /etc/cron.d/rootkeys_backup:0 1 * * 1 root /usr/bin/rootkeys_backup.sh
> /etc/cron.d/schnapps:MAILTO=""
> /etc/cron.d/schnapps:# m h dom mon dow user command
> /etc/cron.d/schnapps: 5 */12 * * * root schnapps cleanup
> /etc/cron.d/schnapps: 5 1 * * 0 root schnapps create -t time "Snapshot created by cron"
> /etc/cron.d/schnapps: 5 2 * * 0 root schnapps cleanup --compare
> /etc/cron.d/server-uplink.cron:MAILTO=""
> /etc/cron.d/server-uplink.cron:0 * * * * root /usr/share/server-uplink/registration_code.sh
> /etc/cron.d/server-uplink.cron:0 * * * * root /usr/share/server-uplink/contract_valid.sh
> /etc/cron.d/updater:MAILTO=""
> /etc/cron.d/updater:0 0-23/4 * * * root /usr/bin/updater-supervisor -d --rand-sleep
> /etc/cron.d/user_notify.cron:MAILTO=""
> /etc/cron.d/user_notify.cron:*/5 * * * * root /usr/bin/notifier
> 5c61af4af86ea364615093377f21d820 /etc/init.d/cron
> 5c61af4af86ea364615093377f21d820 /etc/rc.d/S90cron
> ************** cron
> ############## date
> == Current time ==
> Tue Mar 12 18:20:27 CET 2019
> == NTP synchronization ==
> 12 Mar 18:20:35 ntpdate[6211]: no server suitable for synchronization found
> 12 Mar 18:20:43 ntpdate[6224]: no server suitable for synchronization found
> 12 Mar 18:20:51 ntpdate[6226]: no server suitable for synchronization found
> Exiting, name server cannot be used: Try again (-3)12 Mar 18:20:56 ntpdate[6238]: name server cannot be used: Try again (-3)
> Exiting, name server cannot be used: Try again (-3)12 Mar 18:21:01 ntpdate[6312]: name server cannot be used: Try again (-3)
> Exiting, name server cannot be used: Try again (-3)12 Mar 18:21:06 ntpdate[6412]: name server cannot be used: Try again (-3)
> ************** date
> ############## disk_full
> Filesystem Size Used Available Use% Mounted on
> /dev/mmcblk0p1 7.3G 342.8M 6.9G 5% /
> tmpfs 1010.8M 1.1M 1009.7M 0% /tmp
> tmpfs 512.0K 0 512.0K 0% /dev
> 104.0K /tmp/luci-indexcache
> 40.0K /tmp/nethist
> 4.0K /tmp/luci-modulecache/6C7563692E76657273696F6E
> 4.0K /tmp/luci-modulecache/6C7563692E74656D706C617465
> 8.0K /tmp/luci-modulecache/6C7563692E737461746973746963732E6461746174726565
> 4.0K /tmp/luci-modulecache/6C7563692E636F6E74726F6C6C65722E7261696E626F772E7261696E626F77
> 12.0K /tmp/luci-modulecache/6C7563692E636F6E74726F6C6C65722E6C7563695F737461746973746963732E6C7563695F73746174697374696373
> 4.0K /tmp/luci-modulecache/6C7563692E636F6E74726F6C6C65722E61646D696E2E756369
> 20.0K /tmp/luci-modulecache/6C7563692E636F6E74726F6C6C65722E61646D696E2E73797374656D
> 8.0K /tmp/luci-modulecache/6C7563692E636F6E74726F6C6C65722E61646D696E2E737461747573
> 4.0K /tmp/luci-modulecache/6C7563692E636F6E74726F6C6C65722E61646D696E2E7365727669636563746C
> 20.0K /tmp/luci-modulecache/6C7563692E636F6E74726F6C6C65722E61646D696E2E6E6574776F726B
> 4.0K /tmp/luci-modulecache/6C7563692E636F6E74726F6C6C65722E61646D696E2E696E646578
> 4.0K /tmp/luci-modulecache/6C7563692E636F6E74726F6C6C65722E61646D696E2E66696C6562726F77736572
> 4.0K /tmp/luci-modulecache/6C7563692E636F6E74726F6C6C65722E776F6C
> 4.0K /tmp/luci-modulecache/6C7563692E636F6E74726F6C6C65722E75706E70
> 4.0K /tmp/luci-modulecache/6C7563692E636F6E74726F6C6C65722E7472616E736D697373696F6E
> 4.0K /tmp/luci-modulecache/6C7563692E636F6E74726F6C6C65722E74696E7970726F7879
> 4.0K /tmp/luci-modulecache/6C7563692E636F6E74726F6C6C65722E73616D6261
> 4.0K /tmp/luci-modulecache/6C7563692E636F6E74726F6C6C65722E6D6A70672D73747265616D6572
> 4.0K /tmp/luci-modulecache/6C7563692E636F6E74726F6C6C65722E6D696E69646C6E61
> 4.0K /tmp/luci-modulecache/6C7563692E636F6E74726F6C6C65722E68645F69646C65
> 4.0K /tmp/luci-modulecache/6C7563692E636F6E74726F6C6C65722E6669726577616C6C
> 12.0K /tmp/luci-modulecache/6C7563692E746F6F6C732E64646E73
> 12.0K /tmp/luci-modulecache/6C7563692E6D6F64656C2E69706B67
> 12.0K /tmp/luci-modulecache/6C7563692E636F6E74726F6C6C65722E64646E73
> 12.0K /tmp/luci-modulecache/6C7563692E636F6E74726F6C6C65722E636F6D6D616E6473
> 4.0K /tmp/luci-modulecache/6C7563692E636F6E74726F6C6C65722E61686370
> 4.0K /tmp/luci-modulecache/6C7563692E6931386E
> 36.0K /tmp/luci-modulecache/6C7563692E64697370617463686572
> 28.0K /tmp/luci-modulecache/6C7563692E737973
> 20.0K /tmp/luci-modulecache/6C7563692E687474702E70726F746F636F6C
> 12.0K /tmp/luci-modulecache/6C7563692E68747470
> 12.0K /tmp/luci-modulecache/6C7563692E6C746E3132
> 4.0K /tmp/luci-modulecache/6C7563692E7367692E636769
> 300.0K /tmp/luci-modulecache
> 0 /tmp/usr/lib/opkg/info
> 0 /tmp/usr/lib/opkg
> 0 /tmp/usr/lib
> 0 /tmp/usr
> 0 /tmp/opkg-lists
> 44.0K /tmp/diagnostics-2019-03-12_aa85b720.out.preparing
> 4.0K /tmp/resolv.conf
> 4.0K /tmp/resolv.conf.auto
> 0 /tmp/.uci-foris-controller
> 4.0K /tmp/logrotate.state
> 0 /tmp/user_notify
> 4.0K /tmp/nethist.stats
> 4.0K /tmp/syslog-ng.pid
> 0 /tmp/syslog-ng.ctl
> 16.0K /tmp/syslog-ng.persist
> 8.0K /tmp/.foris_workdir/dynamic_assets/__jinja2_bcde958736803c91022870ec7d66cae5df29d823.cache
> 4.0K /tmp/.foris_workdir/dynamic_assets/__jinja2_997f1d6de7399cf281f9bbce8a31f2a903f6781e.cache
> 8.0K /tmp/.foris_workdir/dynamic_assets/__jinja2_c98fd12c6ddeb16c4ff727c86eed7fee2e13443d.cache
> 8.0K /tmp/.foris_workdir/dynamic_assets/__jinja2_dabd798edb92dd530e6647bf62fc729ee95ad483.cache
> 4.0K /tmp/.foris_workdir/dynamic_assets/__jinja2_68636774eb3c8a0b0afa974b491d1b603f230500.cache
> 12.0K /tmp/.foris_workdir/dynamic_assets/__jinja2_db8bec0e6f49e3f780d46ff298bf85ee855df17f.cache
> 4.0K /tmp/.foris_workdir/dynamic_assets/__jinja2_9538b1de69f0cbde49cdfd84a8ee517d062854fc.cache
> 8.0K /tmp/.foris_workdir/dynamic_assets/__jinja2_bdc5e2b7d21931309c4036445c111b80aafc7264.cache
> 8.0K /tmp/.foris_workdir/dynamic_assets/__jinja2_c68d724d289f5c1b54e5314790f6ace2f938cfb0.cache
> 4.0K /tmp/.foris_workdir/dynamic_assets/__jinja2_686ddb42735ffae2782f6b04896bd01f32f64792.cache
> 4.0K /tmp/.foris_workdir/dynamic_assets/__jinja2_de371dd3c561dc94ff8d83649ebb1a42fb233c07.cache
> 8.0K /tmp/.foris_workdir/dynamic_assets/__jinja2_f3cfcad5491888841a8e16febe130167b2c8c88f.cache
> 4.0K /tmp/.foris_workdir/dynamic_assets/__jinja2_e7832ba5c55177b7ca117ccd660e0a780352f3ec.cache
> 4.0K /tmp/.foris_workdir/dynamic_assets/__jinja2_8ce45b1b35cfeee0e9511226f5256100d0601654.cache
> 12.0K /tmp/.foris_workdir/dynamic_assets/__jinja2_b3fe21977597f02a2686dee60ad7cf3f4cd84f6d.cache
> 4.0K /tmp/.foris_workdir/dynamic_assets/__jinja2_ebfde1e719f05e382acd17e1d24dc46246c320b8.cache
> 12.0K /tmp/.foris_workdir/dynamic_assets/__jinja2_89728fe0b0ade323ebc0fa1b8b976162315e7eb9.cache
> 4.0K /tmp/.foris_workdir/dynamic_assets/__jinja2_7ba58f56b51288e84fa4f3b0894b807c4ed1f0a8.cache
> 4.0K /tmp/.foris_workdir/dynamic_assets/__jinja2_a299d416587682fcc8a0d995623f89b4c878a4ce.cache
> 4.0K /tmp/.foris_workdir/dynamic_assets/__jinja2_fcdafe959a42ac591b77595a14cf866da91d4817.cache
> 4.0K /tmp/.foris_workdir/dynamic_assets/__jinja2_843b4d695800cb035724bcd9c7cafdea9d65a3cf.cache
> 8.0K /tmp/.foris_workdir/dynamic_assets/__jinja2_496c6ea6d9f22d0823cd4d1697be07a4d9df5f62.cache
> 8.0K /tmp/.foris_workdir/dynamic_assets/__jinja2_0942442e56cb492bcd0cb381613102349cd70185.cache
> 8.0K /tmp/.foris_workdir/dynamic_assets/__jinja2_840ea132a485b7d011ced0792f91bd4dc89fd685.cache
> 8.0K /tmp/.foris_workdir/dynamic_assets/__jinja2_93f0df20e51d7df05e21a6d25954cf18d4f3109f.cache
> 4.0K /tmp/.foris_workdir/dynamic_assets/config/cs/javascript/parsley.messages.js
> 4.0K /tmp/.foris_workdir/dynamic_assets/config/cs/javascript/foris.js
> 8.0K /tmp/.foris_workdir/dynamic_assets/config/cs/javascript
> 4.0K /tmp/.foris_workdir/dynamic_assets/config/en/javascript/parsley.messages.js
> 4.0K /tmp/.foris_workdir/dynamic_assets/config/en/javascript/foris.js
> 8.0K /tmp/.foris_workdir/dynamic_assets/config/en/javascript
> 16.0K /tmp/.foris_workdir/dynamic_assets/config
> 180.0K /tmp/.foris_workdir/dynamic_assets
> 0 /tmp/fastcgi.foris-config.socket-0
> 0 /tmp/pymp-96_d56_a/listener-0_bmuiih
> 0 /tmp/pymp-k7tzqdry/listener-lqlzidmn
> 0 /tmp/mounts
> 0 /tmp/dnsmasq.d
> 4.0K /tmp/hosts/odhcpd
> 4.0K /tmp/hosts/dhcp
> 8.0K /tmp/hosts
> 4.0K /tmp/dhcp.leases
> 0 /tmp/lib/misc
> 0 /tmp/lib
> 4.0K /tmp/resolv.conf.auto.last.md5
> 4.0K /tmp/kresd.config
> 0 /tmp/kresd/tty/5858
> 0 /tmp/kresd/tty
> 76.0K /tmp/kresd/data.mdb
> 4.0K /tmp/kresd/lock.mdb
> 4.0K /tmp/kresd/hints.tmp
> 84.0K /tmp/kresd
> 0 /tmp/empty
> 4.0K /tmp/etc/dnsmasq.conf
> 4.0K /tmp/etc/ssh/sshd_config
> 4.0K /tmp/etc/ssh
> 8.0K /tmp/etc
> 4.0K /tmp/fosquitto.generated.conf
> 0 /tmp/spool/cron/crontabs
> 0 /tmp/spool/cron/atspool
> 0 /tmp/spool/cron/atjobs/.SEQ
> 0 /tmp/spool/cron
> 0 /tmp/spool
> 4.0K /tmp/lvm/cache/.cache
> 4.0K /tmp/lvm/cache
> 4.0K /tmp/lvm
> 4.0K /tmp/TZ
> 4.0K /tmp/libatsha204.lock
> 0 /tmp/.jail
> 0 /tmp/.uci
> 36.0K /tmp/log/messages
> 4.0K /tmp/log/lighttpd/error.log
> 0 /tmp/log/lastlog
> 0 /tmp/log/wtmp
> 40.0K /tmp/log
> 0 /tmp/extroot
> 4.0K /tmp/sysinfo/model
> 4.0K /tmp/sysinfo/board_name
> 8.0K /tmp/sysinfo
> 4.0K /tmp/state/network
> 4.0K /tmp/state
> 0 /tmp/lock/lvm
> 0 /tmp/lock
> 4.0K /tmp/run/resolver.pid
> 4.0K /tmp/run/udhcpc-eth1.pid
> 4.0K /tmp/run/ntpd.pid
> 0 /tmp/run/foris-controller-client.sock
> 4.0K /tmp/run/lighttpd.pid
> 4.0K /tmp/run/dnsmasq.br-lan.dhcp
> 4.0K /tmp/run/cron.pid
> 4.0K /tmp/run/mountd.pid
> 4.0K /tmp/run/resolver.name
> 4.0K /tmp/run/dnsmasq/dnsmasq.pid
> 4.0K /tmp/run/sshd.pid
> 4.0K /tmp/run/atd.pid
> 4.0K /tmp/run/sfpswitch.lock
> 4.0K /tmp/run/fw3.state
> 4.0K /tmp/run/haveged.pid
> 0 /tmp/run/rpcd
> 4.0K /tmp/run/config.md5
> 0 /tmp/run/ubus.sock
> 60.0K /tmp/run
> 0 /tmp/shm
> 944.0K /tmp/
> 944.0K total
> ************** disk_full
> ############## dmesg
> [ 4.933422] sdhci: Secure Digital Host Controller Interface driver
> [ 4.939615] sdhci: Copyright(c) Pierre Ossman
> [ 4.944125] sdhci-pxav3 f10d8000.sdhci: No vmmc regulator found
> [ 4.950059] sdhci-pxav3 f10d8000.sdhci: No vqmmc regulator found
> [ 5.001062] mmc0: SDHCI controller on f10d8000.sdhci [f10d8000.sdhci] using ADMA
> [ 5.008519] sdhci-pltfm: SDHCI platform and OF driver helper
> [ 5.023749] NET: Registered protocol family 10
> [ 5.028799] NET: Registered protocol family 17
> [ 5.033291] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
> [ 5.045947] Bridge firewalling registered
> [ 5.049967] 8021q: 802.1Q VLAN Support v1.8
> [ 5.054239] Registering SWP/SWPB emulation handler
> [ 5.059431] BTRFS: using crc32c-generic for crc32c
> [ 5.065027] Btrfs loaded, integrity-checker=on
> [ 5.070116] mvsw61xx 10.mvsw61xx: Found MV88E6176 at f1072004.mdio-mii:10
> [ 5.076958] mvsw61xx 10.mvsw61xx: Using indirect addressing
> [ 5.095212] mmc0: MAN_BKOPS_EN bit is not set
> [ 5.102721] mmc0: new high speed MMC card at address 0001
> [ 5.108368] mmcblk0: mmc0:0001 H8G4a’ 7.28 GiB
> [ 5.112996] mmcblk0boot0: mmc0:0001 H8G4a’ partition 1 4.00 MiB
> [ 5.119001] mmcblk0boot1: mmc0:0001 H8G4a’ partition 2 4.00 MiB
> [ 5.125055] mmcblk0rpmb: mmc0:0001 H8G4a’ partition 3 4.00 MiB
> [ 5.131956] mmcblk0: p1
> [ 5.153811] armada38x-rtc f10a3800.rtc: setting system clock to 2019-03-12 17:07:23 UTC (1552410443)
> [ 5.163771] Waiting 2 sec before mounting root device...
> [ 7.173689] BTRFS: device fsid 202b74cb-1e26-43fb-8e8f-491214eaf535 devid 1 transid 308 /dev/root
> [ 7.183201] BTRFS info (device mmcblk0p1): disk space caching is enabled
> [ 7.189918] BTRFS: has skinny extents
> [ 7.197847] BTRFS: detected SSD devices, enabling SSD mode
> [ 7.231069] VFS: Mounted root (btrfs filesystem) on device 0:13.
> [ 7.237196] Freeing unused kernel memory: 292K
> [ 7.289063] init: Console is alive
> [ 7.292551] init: - watchdog -
> [ 7.701757] exFAT: Version 1.2.9
> [ 7.719267] JFS: nTxBlock = 8192, nTxLock = 65536
> [ 7.789544] SGI XFS with security attributes, no debug enabled
> [ 7.796641] usbcore: registered new interface driver uas
> [ 7.803465] uhci_hcd: USB Universal Host Controller Interface driver
> [ 7.812987] xhci-hcd f10f0000.usb3: xHCI Host Controller
> [ 7.818325] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
> [ 7.825935] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x00010010
> [ 7.834505] xhci-hcd f10f0000.usb3: irq 46, io mem 0xf10f0000
> [ 7.840532] hub 2-0:1.0: USB hub found
> [ 7.844310] hub 2-0:1.0: 1 port detected
> [ 7.848330] xhci-hcd f10f0000.usb3: xHCI Host Controller
> [ 7.853673] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
> [ 7.861230] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
> [ 7.869552] hub 3-0:1.0: USB hub found
> [ 7.873336] hub 3-0:1.0: 1 port detected
> [ 7.877407] xhci-hcd f10f8000.usb3: xHCI Host Controller
> [ 7.882745] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
> [ 7.890333] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x00010010
> [ 7.898899] xhci-hcd f10f8000.usb3: irq 47, io mem 0xf10f8000
> [ 7.904871] hub 4-0:1.0: USB hub found
> [ 7.908639] hub 4-0:1.0: 1 port detected
> [ 7.912660] xhci-hcd f10f8000.usb3: xHCI Host Controller
> [ 7.917988] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
> [ 7.925526] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
> [ 7.933832] hub 5-0:1.0: USB hub found
> [ 7.937600] hub 5-0:1.0: 1 port detected
> [ 8.295867] init: - preinit -
> [ 11.350032] mount_root: mounting /dev/root
> [ 11.555582] BTRFS info (device mmcblk0p1): disk space caching is enabled
> [ 11.562764] mount_root: loading kmods from internal overlay
> [ 11.773237] block: attempting to load /etc/config/fstab
> [ 11.779603] block: extroot: not configured
> [ 11.786141] procd: - early -
> [ 11.789050] procd: - watchdog -
> [ 11.909684] random: jshn: uninitialized urandom read (4 bytes read, 41 bits of entropy available)
> [ 11.937773] random: jshn: uninitialized urandom read (4 bytes read, 41 bits of entropy available)
> [ 11.976081] random: jshn: uninitialized urandom read (4 bytes read, 41 bits of entropy available)
> [ 12.002252] random: jshn: uninitialized urandom read (4 bytes read, 41 bits of entropy available)
> [ 12.040600] random: jshn: uninitialized urandom read (4 bytes read, 41 bits of entropy available)
> [ 12.066891] random: jshn: uninitialized urandom read (4 bytes read, 41 bits of entropy available)
> [ 12.105090] random: jshn: uninitialized urandom read (4 bytes read, 41 bits of entropy available)
> [ 12.131384] random: jshn: uninitialized urandom read (4 bytes read, 41 bits of entropy available)
> [ 12.169480] random: jshn: uninitialized urandom read (4 bytes read, 41 bits of entropy available)
> [ 12.195545] random: jshn: uninitialized urandom read (4 bytes read, 41 bits of entropy available)
> [ 12.373608] procd: - ubus -
> [ 13.381359] procd: - init -
> [ 13.448887] marvell-cesa f1090000.crypto: CESA device successfully registered
> [ 13.461817] NET: Registered protocol family 38
> [ 13.478249] md: linear personality registered for level -1
> [ 13.484265] md: raid0 personality registered for level 0
> [ 13.490366] md: raid1 personality registered for level 1
> [ 13.496646] md: raid10 personality registered for level 10
> [ 13.502683] async_tx: api initialized (async)
> [ 13.510317] md: raid6 personality registered for level 6
> [ 13.515660] md: raid5 personality registered for level 5
> [ 13.520984] md: raid4 personality registered for level 4
> [ 13.528197] FS-Cache: Loaded
> [ 13.531563] md: multipath personality registered for level -4
> [ 13.539242] NET: Registered protocol family 8
> [ 13.543625] NET: Registered protocol family 20
> [ 13.551855] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
> [ 13.562714] Key type dns_resolver registered
> [ 13.569828] NET: Registered protocol family 33
> [ 13.574301] Key type rxrpc registered
> [ 13.577970] Key type rxrpc_s registered
> [ 13.584976] kAFS: Red Hat AFS client v0.1 registering.
> [ 13.590166] FS-Cache: Netfs 'afs' registered for caching
> [ 13.624353] RPC: Registered named UNIX socket transport module.
> [ 13.630292] RPC: Registered udp transport module.
> [ 13.635026] RPC: Registered tcp transport module.
> [ 13.639740] RPC: Registered tcp NFSv4.1 backchannel transport module.
> [ 13.663832] NFS: Registering the id_resolver key type
> [ 13.668919] Key type id_resolver registered
> [ 13.673127] Key type id_legacy registered
> [ 13.677745] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
> [ 13.686908] ntfs: driver 2.1.32 [Flags: R/O MODULE].
> [ 13.696703] RxRPC: Registered security type 2 'rxkad'
> [ 13.712870] tun: Universal TUN/TAP device driver, 1.6
> [ 13.717938] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
> [ 13.727645] sit: IPv6 over IPv4 tunneling driver
> [ 13.734425] gre: GRE over IPv4 demultiplexor driver
> [ 13.739988] ip_gre: GRE over IPv4 tunneling driver
> [ 13.759210] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
> [ 13.767909] PPP generic driver version 2.4.2
> [ 13.775483] ip6_tables: (C) 2000-2006 Netfilter Core Team
> [ 13.784759] cryptodev: driver 1.8 loaded.
> [ 13.793197] Loading modules backported from Linux version wt-2017-01-31-0-ge882dff19e7f
> [ 13.801259] Backport generated by backports.git backports-20160324-13-g24da7d3c
> [ 13.877502] pci 0000:00:02.0: enabling device (0140 -> 0142)
> [ 13.883388] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
> [ 14.064841] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:02:00.0.bin failed with error -2
> [ 14.075577] ath10k_pci 0000:02:00.0: Falling back to user helper
> [ 14.085760] firmware ath10k!pre-cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
> [ 14.094885] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/cal-pci-0000:02:00.0.bin failed with error -2
> [ 14.105273] ath10k_pci 0000:02:00.0: Falling back to user helper
> [ 14.115243] firmware ath10k!cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
> [ 14.131938] ath10k_pci 0000:02:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
> [ 14.141201] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
> [ 14.150810] ath10k_pci 0000:02:00.0: firmware ver 10.2.4-1.0-00041 api 5 features no-p2p,raw-mode,mfp,allows-mesh-bcast crc32 f43fa422
> [ 14.195554] ath10k_pci 0000:02:00.0: board id is not exist in otp, ignore it
> [ 14.202671] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
> [ 14.213136] ath10k_pci 0000:02:00.0: Falling back to user helper
> [ 14.223210] firmware ath10k!QCA988X!hw2.0!board-2.bin: firmware_loading_store: map pages failed
> [ 14.232888] ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
> [ 15.368796] ath10k_pci 0000:02:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
> [ 15.462386] ath: EEPROM regdomain: 0x0
> [ 15.462392] ath: EEPROM indicates default country code should be used
> [ 15.462394] ath: doing EEPROM country->regdmn map search
> [ 15.462399] ath: country maps to regdmn code: 0x3a
> [ 15.462402] ath: Country alpha2 being used: US
> [ 15.462405] ath: Regpair used: 0x3a
> [ 15.467804] u32 classifier
> [ 15.470522] input device check on
> [ 15.474211] Actions configured
> [ 15.481117] Mirror/redirect action on
> [ 15.487452] GACT probability on
> [ 15.495301] netem: version 1.3
> [ 15.504103] fuse init (API version 7.23)
> [ 15.520477] usbcore: registered new interface driver cdc_wdm
> [ 15.529126] Ebtables v2.0 registered
> [ 15.534043] ip_tables: (C) 2000-2006 Netfilter Core Team
> [ 15.545877] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
> [ 15.724381] Netfilter messages via NETLINK v0.30.
> [ 15.729933] PPP MPPE Compression module registered
> [ 15.735257] NET: Registered protocol family 24
> [ 15.742453] usbcore: registered new interface driver ums-alauda
> [ 15.748676] usbcore: registered new interface driver ums-cypress
> [ 15.755021] usbcore: registered new interface driver ums-datafab
> [ 15.761337] usbcore: registered new interface driver ums-freecom
> [ 15.767671] usbcore: registered new interface driver ums-isd200
> [ 15.773988] usbcore: registered new interface driver ums-jumpshot
> [ 15.780380] usbcore: registered new interface driver ums-karma
> [ 15.786604] usbcore: registered new interface driver ums-sddr09
> [ 15.792892] usbcore: registered new interface driver ums-sddr55
> [ 15.799146] usbcore: registered new interface driver ums-usbat
> [ 15.809363] usbcore: registered new interface driver usbserial
> [ 15.815262] usbcore: registered new interface driver usbserial_generic
> [ 15.821838] usbserial: USB Serial support registered for generic
> [ 15.836637] xt_time: kernel timezone is -0000
> [ 15.854456] usbcore: registered new interface driver cdc_ether
> [ 15.864837] ctnetlink v0.93: registering with nfnetlink.
> [ 15.873527] usbcore: registered new interface driver qmi_wwan
> [ 15.880104] usbcore: registered new interface driver rndis_host
> [ 15.893218] pci 0000:00:01.0: enabling device (0140 -> 0142)
> [ 15.985489] ath: EEPROM regdomain: 0x0
> [ 15.985493] ath: EEPROM indicates default country code should be used
> [ 15.985495] ath: doing EEPROM country->regdmn map search
> [ 15.985500] ath: country maps to regdmn code: 0x3a
> [ 15.985503] ath: Country alpha2 being used: US
> [ 15.985506] ath: Regpair used: 0x3a
> [ 15.997266] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
> [ 15.998628] ieee80211 phy1: Atheros AR9287 Rev:2 mem=0xf1d80000, irq=108
> [ 16.006955] usbcore: registered new interface driver option
> [ 16.012623] usbserial: USB Serial support registered for GSM modem (1-port)
> [ 16.020219] usbcore: registered new interface driver qcserial
> [ 16.026027] usbserial: USB Serial support registered for Qualcomm USB modem
> [ 18.676659] random: nonblocking pool is initialized
> [ 21.309320] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
> [ 21.392742] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
> [ 21.396325] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
> [ 22.822008] device eth0 entered promiscuous mode
> [ 22.823382] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
> [ 22.838633] device eth2 entered promiscuous mode
> [ 24.811150] mvneta f1030000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
> [ 24.811193] br-lan: port 1(eth0) entered forwarding state
> [ 24.811228] br-lan: port 1(eth0) entered forwarding state
> [ 24.811282] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
> [ 24.831271] mvneta f1070000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
> [ 24.831304] br-lan: port 2(eth2) entered forwarding state
> [ 24.831328] br-lan: port 2(eth2) entered forwarding state
> [ 26.811088] br-lan: port 1(eth0) entered forwarding state
> [ 26.831089] br-lan: port 2(eth2) entered forwarding state
> [ 541.921476] mvneta f1034000.ethernet eth1: Link is Up - 100Mbps/Full - flow control off
> [ 553.924626] mvneta f1034000.ethernet eth1: Link is Down
> [ 555.921482] mvneta f1034000.ethernet eth1: Link is Up - 100Mbps/Full - flow control off
> ************** dmesg
> ############## dns
> resolver.common=resolver
> resolver.common.interface='0.0.0.0' '::0'
> resolver.common.port='53'
> resolver.common.keyfile='/etc/root.keys'
> resolver.common.verbose='0'
> resolver.common.msg_buffer_size='4096'
> resolver.common.msg_cache_size='20M'
> resolver.common.net_ipv6='1'
> resolver.common.net_ipv4='1'
> resolver.common.prefered_resolver='kresd'
> resolver.common.prefetch='yes'
> resolver.common.static_domains='1'
> resolver.common.dynamic_domains='0'
> resolver.common.forward_upstream='1'
> resolver.common.ignore_root_key='0'
> resolver.kresd=resolver
> resolver.kresd.rundir='/tmp/kresd'
> resolver.kresd.log_stderr='1'
> resolver.kresd.log_stdout='1'
> resolver.kresd.forks='1'
> resolver.kresd.keep_cache='1'
> resolver.unbound=resolver
> resolver.unbound.outgoing_range='60'
> resolver.unbound.outgoing_num_tcp='1'
> resolver.unbound.incoming_num_tcp='1'
> resolver.unbound.msg_cache_slabs='1'
> resolver.unbound.num_queries_per_thread='30'
> resolver.unbound.rrset_cache_size='100K'
> resolver.unbound.rrset_cache_slabs='1'
> resolver.unbound.infra_cache_slabs='1'
> resolver.unbound.infra_cache_numhosts='200'
> resolver.unbound.access_control='0.0.0.0/0 allow' '::0/0 allow'
> resolver.unbound.pidfile='/var/run/unbound.pid'
> resolver.unbound.root_hints='/etc/unbound/named.cache'
> resolver.unbound.target_fetch_policy='2 1 0 0 0'
> resolver.unbound.harden_short_bufsize='yes'
> resolver.unbound.harden_large_queries='yes'
> resolver.unbound.qname_minimisation='yes'
> resolver.unbound.harden_below_nxdomain='yes'
> resolver.unbound.key_cache_size='100k'
> resolver.unbound.key_cache_slabs='1'
> resolver.unbound.neg_cache_size='10k'
> resolver.unbound.prefetch_key='yes'
> resolver.unbound_remote_control=resolver
> resolver.unbound_remote_control.control_enable='yes'
> resolver.unbound_remote_control.control_use_cert='no'
> resolver.unbound_remote_control.control_interface='127.0.0.1'
> == resolv.conf* ==
> /etc/resolv.conf:search lan
> /etc/resolv.conf:nameserver 127.0.0.1
> /tmp/resolv.conf:search lan
> /tmp/resolv.conf:nameserver 127.0.0.1
> /tmp/resolv.conf.auto:# Interface wan
> /tmp/resolv.conf.auto:nameserver 172.31.30.4
> /tmp/resolv.conf.auto:search cust.in.nbox.cz
> /tmp/resolv.conf.auto.last.md5:4ea08bc3cf55412a12cc719f4ed184dc
> == DNSSEC root key file ==
> -rw-r--r-- 1 root root 556 Mar 12 18:17 /etc/root.keys
> d9ce2496841d62f6b8a2171a5de66c1b /etc/root.keys
> /etc/root.keys:. 3600 DS 19036 8 2 49AAC11D7B6F6446702E54A1607371607A1A41855200FD2CE1CDDE32F24E8FB5 ; Missing:1561033616 ; KeyTag:19036
> /etc/root.keys:. 172800 DNSKEY 257 3 8 AwEAAaz/tAm8yTn4Mfeh5eyI96WSVexTBAvkMgJzkKTOiW1vkIbzxeF3+/4RgWOq7HrxRixHlFlExOLAJr5emLvN7SWXgnLh4+B5xQlNVz8Og8kvArMtNROxVQuCaSnIDdD5LKyWbRd2n9WGe2R8PzgCmr3EgVLrjyBxWezF0jLHwVN8efS3rCj/EWgvIWgb9tarpVUDK/b58Da+sqqls3eNbuv7pr+eoZG+SrDK6nWeL3c6H5Apxz7LjVc1uTIdsIXxuOLYA4/ilBmSVIzuDWfdRUfhHdY6+cn8HFRm+2hM8AnXGXws9555KrUB5qihylGa8subX2Nn6UwNR1AkUTV74bU= ; Valid: ; KeyTag:20326
> == resolver process ==
> 5851 root 1344 S /bin/sh /etc/rc.common /etc/init.d/kresd start
> 5858 root 32196 S /usr/bin/kresd -c /tmp/kresd.config -f 1 /tmp/kresd -a 0.0.0.0 53 -a :: 53 -k /etc/root.keys
> 6457 root 1180 S grep kresd
> == configured trust anchors ==
> > [hold_down_time] => 2592000000
> [add_file] => function: 0xb6818890
> [keep_removed] => 0
> [summary] => function: 0xb68189e0
> [bootstrap_ca] => /etc/kresd/icann-ca.pem
> [set_insecure] => function: 0xb68189b8
> [insecure] => {
> [keysets] => {
> [\0] => {
> [1] => {
> [owner] => \0
> [key_tag] => 19036
> [class] => 1
> [ttl] => 3600
> [state] => Missing
> [rdata] => J\\8\2I\170\193\29{odFp.T\161`sq`z\26A\133R\0\253,\225\205\2222\242N\143\181
> [timer] => 1561033616
> [type] => 43
> [2] => {
> [owner] => \0
> [key_tag] => 20326
> [class] => 1
> [state] => Valid
> [rdata] => \1\1\3\8\3\1\0\1\172\255\180\9\188\2019\2481\247\161\229\236\136\247\165\146U\236S\4\11\2282\2s\144\164\206\137mo\144\134\243\197\225w\251\254\17\129c\170\236z\241F,G\148YD\196\226\192&\190^\152\187\205\237%\151\130r\225\227\224y\197\9...
> [ttl] => 172800
> [type] => 48
> [filename] => /etc/root.keys
> [refresh_ev] => 12
> [owner] => \0
> [add] => function: 0xb6818998
> [bootstrap_url] => https://data.iana.org/root-anchors/root-anchors.xml
> [config] => function: 0xb6818890
> > == resolution attempts ==
> Attempting to resolve api.turris.cz
> ; <<>> DiG 9.11.5-P1 <<>> @127.0.0.1 +dnssec api.turris.cz
> ; (1 server found)
> ;; global options: +cmd
> ;; Got answer:
> ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 61617
> ;; flags: qr rd ra ad; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 1
> ;; OPT PSEUDOSECTION:
> ; EDNS: version: 0, flags: do; udp: 4096
> ;; QUESTION SECTION:
> ;api.turris.cz. IN A
> ;; ANSWER SECTION:
> api.turris.cz. 1651 IN A 217.31.192.101
> api.turris.cz. 1651 IN RRSIG A 13 3 1800 20190320103002 20190306090002 26682 turris.cz. HWcgDfnrDLCYR/D6DaWiAtTCEMmSTItUFERZJP0JiNcDDYgzCZ0wQxWI YZH7JLKVOa9Cy4XrkRiXcDU/0WRX3g==
> ;; Query time: 0 msec
> ;; SERVER: 127.0.0.1#53(127.0.0.1)
> ;; WHEN: Tue Mar 12 18:21:06 CET 2019
> ;; MSG SIZE rcvd: 163
> Attempting to resolve www.google.com
> ; <<>> DiG 9.11.5-P1 <<>> @127.0.0.1 +dnssec www.google.com
> ; (1 server found)
> ;; Got answer:
> ;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 49714
> ;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 1
> ;www.google.com. IN A
> ;; MSG SIZE rcvd: 43
> Attempting to resolve www.facebook.com
> ; <<>> DiG 9.11.5-P1 <<>> @127.0.0.1 +dnssec www.facebook.com
> ; (1 server found)
> ;; Got answer:
> ;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 22477
> ;www.facebook.com. IN A
> ;; MSG SIZE rcvd: 45
> Attempting to resolve www.youtube.com
> ; <<>> DiG 9.11.5-P1 <<>> @127.0.0.1 +dnssec www.youtube.com
> ; (1 server found)
> ;; Got answer:
> ;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 60777
> ;www.youtube.com. IN A
> ;; MSG SIZE rcvd: 44
> Attempting to resolve www.rhybar.cz
> ; <<>> DiG 9.11.5-P1 <<>> @127.0.0.1 +dnssec www.rhybar.cz
> ; (1 server found)
> ;; Got answer:
> ;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 33540
> ;www.rhybar.cz. IN A
> ;; MSG SIZE rcvd: 42
> Attempting to resolve *.wilda.rhybar.0skar.cz
> ; <<>> DiG 9.11.5-P1 <<>> @127.0.0.1 +dnssec *.wilda.rhybar.0skar.cz
> ; (1 server found)
> ;; Got answer:
> ;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 6303
> ;*.wilda.rhybar.0skar.cz. IN A
> ;; MSG SIZE rcvd: 52
> Attempting to resolve *.wilda.nsec.0skar.cz
> ; <<>> DiG 9.11.5-P1 <<>> @127.0.0.1 +dnssec *.wilda.nsec.0skar.cz
> ; (1 server found)
> ;; Got answer:
> ;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 44603
> ;*.wilda.nsec.0skar.cz. IN A
> ;; MSG SIZE rcvd: 50
> Attempting to resolve *.wild.nsec.0skar.cz
> ; <<>> DiG 9.11.5-P1 <<>> @127.0.0.1 +dnssec *.wild.nsec.0skar.cz
> ; (1 server found)
> ;; Got answer:
> ;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 17366
> ;*.wild.nsec.0skar.cz. IN A
> ;; MSG SIZE rcvd: 49
> Attempting to resolve *.wilda.0skar.cz
> ; <<>> DiG 9.11.5-P1 <<>> @127.0.0.1 +dnssec *.wilda.0skar.cz
> ; (1 server found)
> ;; Got answer:
> ;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 55665
> ;*.wilda.0skar.cz. IN A
> Attempting to resolve *.wild.0skar.cz
> ; <<>> DiG 9.11.5-P1 <<>> @127.0.0.1 +dnssec *.wild.0skar.cz
> ; (1 server found)
> ;; Got answer:
> ;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 5463
> ;*.wild.0skar.cz. IN A
> Attempting to resolve www.wilda.nsec.0skar.cz
> ; <<>> DiG 9.11.5-P1 <<>> @127.0.0.1 +dnssec www.wilda.nsec.0skar.cz
> ; (1 server found)
> ;; Got answer:
> ;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 43763
> ;www.wilda.nsec.0skar.cz. IN A
> Attempting to resolve www.wilda.0skar.cz
> ; <<>> DiG 9.11.5-P1 <<>> @127.0.0.1 +dnssec www.wilda.0skar.cz
> ; (1 server found)
> ;; Got answer:
> ;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 16526
> ;www.wilda.0skar.cz. IN A
> ;; MSG SIZE rcvd: 47
> Attempting to resolve *.wilda.rhybar.ecdsa.0skar.cz
> ; <<>> DiG 9.11.5-P1 <<>> @127.0.0.1 +dnssec *.wilda.rhybar.ecdsa.0skar.cz
> ; (1 server found)
> ;; Got answer:
> ;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 54825
> ;*.wilda.rhybar.ecdsa.0skar.cz. IN A
> ;; MSG SIZE rcvd: 58
> ************** dns
> ############## filesystems
> == mount ==
> /dev/mmcblk0p1 on / type btrfs (rw,noatime,ssd,space_cache,commit=5,subvolid=262,subvol=/@)
> proc on /proc type proc (rw,noatime)
> sysfs on /sys type sysfs (rw,noatime)
> none on /sys/fs/cgroup type cgroup (rw,relatime,cpuset,cpu,cpuacct,blkio,memory,devices,freezer,net_cls,pids)
> tmpfs on /tmp type tmpfs (rw,nosuid,nodev,noatime)
> tmpfs on /dev type tmpfs (rw,relatime,size=512k,mode=755)
> devpts on /dev/pts type devpts (rw,relatime,mode=600,ptmxmode=000)
> debugfs on /sys/kernel/debug type debugfs (rw,noatime)
> mountd(pid2277) on /tmp/run/mountd type autofs (rw,relatime,fd=5,pgrp=2275,timeout=60,minproto=5,maxproto=5,indirect)
> == lsblk ==
> NAME KNAME MAJ:MIN FSTYPE MOUNTPOINT LABEL UUID PARTTYPE PARTLABEL PARTUUID PARTFLAGS RA RO RM HOTPLUG MODEL SERIAL SIZE STATE OWNER GROUP MODE ALIGNMENT MIN-IO OPT-IO PHY-SEC LOG-SEC ROTA SCHED RQ-SIZE TYPE DISC-ALN DISC-GRAN DISC-MAX DISC-ZERO WSAME WWN RAND PKNAME HCTL TRAN SUBSYSTEMS REV VENDOR
> mtdblock0 mtdblock0 31:0 128 0 0 0 1M root root brw-r--r-- 0 512 0 512 512 0 deadline 128 disk 0 0B 0B 0 0B 0 block:mtd:spi:spi_master:platform
> mtdblock1 mtdblock1 31:1 128 0 0 0 7M root root brw-r--r-- 0 512 0 512 512 0 deadline 128 disk 0 0B 0B 0 0B 0 block:mtd:spi:spi_master:platform
> mmcblk0 mmcblk0 179:0 128 0 0 1 0x0ea3383c 7.3G root root brw-r--r-- 0 512 0 512 512 0 deadline 128 disk 0 512K 512K 0 0B 0 block:mmc:mmc_host:platform
> `-mmcblk0p1 mmcblk0p1 179:1 btrfs / 202b74cb-1e26-43fb-8e8f-491214eaf535 0x83 f3dbafb4-01 128 0 0 1 7.3G root root brw-r--r-- 0 512 0 512 512 0 deadline 128 part 0 512K 512K 0 0B 0 mmcblk0 block:mmc:mmc_host:platform
> mmcblk0boot0 mmcblk0boot0 179:8 128 1 0 1 4M root root brw-r--r-- 0 512 0 512 512 0 deadline 128 disk 0 512K 512K 0 0B 0 block:mmc:mmc_host:platform
> mmcblk0boot1 mmcblk0boot1 179:16 128 1 0 1 4M root root brw-r--r-- 0 512 0 512 512 0 deadline 128 disk 0 512K 512K 0 0B 0 block:mmc:mmc_host:platform
> mmcblk0rpmb mmcblk0rpmb 179:24 128 0 0 1 4M root root brw-r--r-- 0 512 0 512 512 0 deadline 128 disk 0 512K 512K 0 0B 0 block:mmc:mmc_host:platform
> ************** filesystems
> ############## firewall
> firewall.@defaults[0]=defaults
> firewall.@defaults[0].syn_flood='1'
> firewall.@defaults[0].input='ACCEPT'
> firewall.@defaults[0].output='ACCEPT'
> firewall.@defaults[0].forward='REJECT'
> firewall.@zone[0]=zone
> firewall.@zone[0].name='lan'
> firewall.@zone[0].network='lan'
> firewall.@zone[0].input='ACCEPT'
> firewall.@zone[0].output='ACCEPT'
> firewall.@zone[0].forward='ACCEPT'
> firewall.@zone[1]=zone
> firewall.@zone[1].name='wan'
> firewall.@zone[1].network='wan' 'wan6'
> firewall.@zone[1].input='REJECT'
> firewall.@zone[1].output='ACCEPT'
> firewall.@zone[1].forward='REJECT'
> firewall.@zone[1].masq='1'
> firewall.@zone[1].mtu_fix='1'
> firewall.@forwarding[0]=forwarding
> firewall.@forwarding[0].src='lan'
> firewall.@forwarding[0].dest='wan'
> firewall.@rule[0]=rule
> firewall.@rule[0].name='Allow-DHCP-Renew'
> firewall.@rule[0].src='wan'
> firewall.@rule[0].proto='udp'
> firewall.@rule[0].dest_port='68'
> firewall.@rule[0].target='ACCEPT'
> firewall.@rule[0].family='ipv4'
> firewall.@rule[1]=rule
> firewall.@rule[1].name='Allow-Ping'
> firewall.@rule[1].src='wan'
> firewall.@rule[1].proto='icmp'
> firewall.@rule[1].icmp_type='echo-request'
> firewall.@rule[1].family='ipv4'
> firewall.@rule[1].target='ACCEPT'
> firewall.@rule[2]=rule
> firewall.@rule[2].name='Allow-IGMP'
> firewall.@rule[2].src='wan'
> firewall.@rule[2].proto='igmp'
> firewall.@rule[2].family='ipv4'
> firewall.@rule[2].target='ACCEPT'
> firewall.@rule[3]=rule
> firewall.@rule[3].name='Allow-DHCPv6'
> firewall.@rule[3].src='wan'
> firewall.@rule[3].proto='udp'
> firewall.@rule[3].src_ip='fe80::/10'
> firewall.@rule[3].src_port='547'
> firewall.@rule[3].dest_ip='fe80::/10'
> firewall.@rule[3].dest_port='546'
> firewall.@rule[3].family='ipv6'
> firewall.@rule[3].target='ACCEPT'
> firewall.@rule[4]=rule
> firewall.@rule[4].name='Allow-MLD'
> firewall.@rule[4].src='wan'
> firewall.@rule[4].proto='icmp'
> firewall.@rule[4].src_ip='fe80::/10'
> firewall.@rule[4].icmp_type='130/0' '131/0' '132/0' '143/0'
> firewall.@rule[4].family='ipv6'
> firewall.@rule[4].target='ACCEPT'
> firewall.@rule[5]=rule
> firewall.@rule[5].name='Allow-ICMPv6-Input'
> firewall.@rule[5].src='wan'
> firewall.@rule[5].proto='icmp'
> firewall.@rule[5].icmp_type='echo-request' 'echo-reply' 'destination-unreachable' 'packet-too-big' 'time-exceeded' 'bad-header' 'unknown-header-type' 'router-solicitation' 'neighbour-solicitation' 'router-advertisement' 'neighbour-advertisement'
> firewall.@rule[5].limit='1000/sec'
> firewall.@rule[5].family='ipv6'
> firewall.@rule[5].target='ACCEPT'
> firewall.@rule[6]=rule
> firewall.@rule[6].name='Allow-ICMPv6-Forward'
> firewall.@rule[6].src='wan'
> firewall.@rule[6].dest='*'
> firewall.@rule[6].proto='icmp'
> firewall.@rule[6].icmp_type='echo-request' 'echo-reply' 'destination-unreachable' 'packet-too-big' 'time-exceeded' 'bad-header' 'unknown-header-type'
> firewall.@rule[6].limit='1000/sec'
> firewall.@rule[6].family='ipv6'
> firewall.@rule[6].target='ACCEPT'
> firewall.@include[0]=include
> firewall.@include[0].path='/etc/firewall.user'
> firewall.@include[1]=include
> firewall.@include[1].path='/usr/share/firewall/turris'
> firewall.@include[1].reload='1'
> firewall.@include[2]=include
> firewall.@include[2].path='/etc/firewall.d/with_reload/firewall.include.sh'
> firewall.@include[2].reload='1'
> firewall.@include[3]=include
> firewall.@include[3].path='/etc/firewall.d/without_reload/firewall.include.sh'
> firewall.@include[3].reload='0'
> firewall.@rule[7]=rule
> firewall.@rule[7].src='wan'
> firewall.@rule[7].dest='lan'
> firewall.@rule[7].proto='esp'
> firewall.@rule[7].target='ACCEPT'
> firewall.@rule[8]=rule
> firewall.@rule[8].src='wan'
> firewall.@rule[8].dest='lan'
> firewall.@rule[8].dest_port='500'
> firewall.@rule[8].proto='udp'
> firewall.@rule[8].target='ACCEPT'
> firewall.miniupnpd=include
> firewall.miniupnpd.type='script'
> firewall.miniupnpd.path='/usr/share/miniupnpd/firewall.include'
> firewall.miniupnpd.family='any'
> firewall.miniupnpd.reload='1'
> firewall.turris_wan_6in4_rule=rule
> firewall.turris_wan_6in4_rule.enabled='0'
> uci: Entry not found
> md5sum: can't open '/usr/share/firewall/*': No such file or directory
> -rw-r--r-- 1 root root 352 Feb 18 13:17 /etc/firewall.user
> /etc/firewall.d/with_reload:
> drwxr-xr-x 1 root root 38 Feb 18 13:26 .
> drwxr-xr-x 1 root root 50 Feb 18 13:26 ..
> -rwxr-xr-x 1 root root 524 Feb 18 13:17 firewall.include.sh
> /etc/firewall.d/without_reload:
> -rwxr-xr-x 1 root root 527 Feb 18 13:17 firewall.include.sh
> # Generated by iptables-save v1.6.1 on Tue Mar 12 18:21:07 2019
> *nat
> :PREROUTING ACCEPT [772:108211]
> :INPUT ACCEPT [37:2077]
> :OUTPUT ACCEPT [462:30198]
> :POSTROUTING ACCEPT [47:3222]
> :MINIUPNPD - [0:0]
> :MINIUPNPD-POSTROUTING - [0:0]
> :postrouting_lan_rule - [0:0]
> :postrouting_rule - [0:0]
> :postrouting_wan_rule - [0:0]
> :prerouting_lan_rule - [0:0]
> :prerouting_rule - [0:0]
> :prerouting_wan_rule - [0:0]
> :zone_lan_postrouting - [0:0]
> :zone_lan_prerouting - [0:0]
> :zone_wan_postrouting - [0:0]
> :zone_wan_prerouting - [0:0]
> -A PREROUTING -m comment --comment "!fw3: Custom prerouting rule chain" -j prerouting_rule
> -A PREROUTING -i br-lan -m comment --comment "!fw3" -j zone_lan_prerouting
> -A PREROUTING -i eth1 -m comment --comment "!fw3" -j zone_wan_prerouting
> -A POSTROUTING -m comment --comment "!fw3: Custom postrouting rule chain" -j postrouting_rule
> -A POSTROUTING -o br-lan -m comment --comment "!fw3" -j zone_lan_postrouting
> -A POSTROUTING -o eth1 -m comment --comment "!fw3" -j zone_wan_postrouting
> -A zone_lan_postrouting -m comment --comment "!fw3: Custom lan postrouting rule chain" -j postrouting_lan_rule
> -A zone_lan_prerouting -m comment --comment "!fw3: Custom lan prerouting rule chain" -j prerouting_lan_rule
> -A zone_wan_postrouting -m comment --comment "!fw3: Custom wan postrouting rule chain" -j postrouting_wan_rule
> -A zone_wan_postrouting -j MINIUPNPD-POSTROUTING
> -A zone_wan_postrouting -m comment --comment "!fw3" -j MASQUERADE
> -A zone_wan_prerouting -m comment --comment "!fw3: Custom wan prerouting rule chain" -j prerouting_wan_rule
> -A zone_wan_prerouting -j MINIUPNPD
> COMMIT
> # Completed on Tue Mar 12 18:21:07 2019
> *raw
> :PREROUTING ACCEPT [11158:4271674]
> :OUTPUT ACCEPT [3560:814874]
> :zone_lan_helper - [0:0]
> -A PREROUTING -i br-lan -m comment --comment "!fw3: lan CT helper assignment" -j zone_lan_helper
> COMMIT
> *mangle
> :INPUT ACCEPT [2440:779493]
> :FORWARD ACCEPT [8708:3491637]
> :POSTROUTING ACCEPT [12268:4306511]
> -A FORWARD -o eth1 -p tcp -m tcp --tcp-flags SYN,RST SYN -m comment --comment "!fw3: Zone wan MTU fixing" -j TCPMSS --clamp-mss-to-pmtu
> COMMIT
> *filter
> :INPUT ACCEPT [0:0]
> :FORWARD DROP [0:0]
> :OUTPUT ACCEPT [0:0]
> :MINIUPNPD - [0:0]
> :accept - [0:0]
> :drop - [0:0]
> :forwarding_lan_rule - [0:0]
> :forwarding_rule - [0:0]
> :forwarding_wan_rule - [0:0]
> :input_lan_rule - [0:0]
> :input_rule - [0:0]
> :input_wan_rule - [0:0]
> :output_lan_rule - [0:0]
> :output_rule - [0:0]
> :output_wan_rule - [0:0]
> :reject - [0:0]
> :syn_flood - [0:0]
> :zone_lan_dest_ACCEPT - [0:0]
> :zone_lan_forward - [0:0]
> :zone_lan_input - [0:0]
> :zone_lan_output - [0:0]
> :zone_lan_src_ACCEPT - [0:0]
> :zone_wan_dest_ACCEPT - [0:0]
> :zone_wan_dest_REJECT - [0:0]
> :zone_wan_forward - [0:0]
> :zone_wan_input - [0:0]
> :zone_wan_output - [0:0]
> :zone_wan_src_REJECT - [0:0]
> -A INPUT -i lo -m comment --comment "!fw3" -j ACCEPT
> -A INPUT -m comment --comment "!fw3: Custom input rule chain" -j input_rule
> -A INPUT -m conntrack --ctstate RELATED,ESTABLISHED -m comment --comment "!fw3" -j ACCEPT
> -A INPUT -p tcp -m tcp --tcp-flags FIN,SYN,RST,ACK SYN -m comment --comment "!fw3" -j syn_flood
> -A INPUT -i br-lan -m comment --comment "!fw3" -j zone_lan_input
> -A INPUT -i eth1 -m comment --comment "!fw3" -j zone_wan_input
> -A INPUT -m comment --comment "!fw3" -j accept
> -A FORWARD -m comment --comment "!fw3: Custom forwarding rule chain" -j forwarding_rule
> -A FORWARD -m conntrack --ctstate RELATED,ESTABLISHED -m comment --comment "!fw3" -j ACCEPT
> -A FORWARD -i br-lan -m comment --comment "!fw3" -j zone_lan_forward
> -A FORWARD -i eth1 -m comment --comment "!fw3" -j zone_wan_forward
> -A FORWARD -m comment --comment "!fw3" -j reject
> -A OUTPUT -o lo -m comment --comment "!fw3" -j ACCEPT
> -A OUTPUT -m comment --comment "!fw3: Custom output rule chain" -j output_rule
> -A OUTPUT -m conntrack --ctstate RELATED,ESTABLISHED -m comment --comment "!fw3" -j ACCEPT
> -A OUTPUT -o br-lan -m comment --comment "!fw3" -j zone_lan_output
> -A OUTPUT -o eth1 -m comment --comment "!fw3" -j zone_wan_output
> -A OUTPUT -m comment --comment "!fw3" -j accept
> -A accept -m comment --comment "!fw3" -j ACCEPT
> -A drop -m comment --comment "!fw3" -j DROP
> -A reject -p tcp -m comment --comment "!fw3" -j REJECT --reject-with tcp-reset
> -A reject -m comment --comment "!fw3" -j REJECT --reject-with icmp-port-unreachable
> -A syn_flood -p tcp -m tcp --tcp-flags FIN,SYN,RST,ACK SYN -m limit --limit 25/sec --limit-burst 50 -m comment --comment "!fw3" -j RETURN
> -A syn_flood -m comment --comment "!fw3" -j DROP
> -A zone_lan_dest_ACCEPT -o br-lan -m comment --comment "!fw3" -j accept
> -A zone_lan_forward -m comment --comment "!fw3: Custom lan forwarding rule chain" -j forwarding_lan_rule
> -A zone_lan_forward -m comment --comment "!fw3: Zone lan to wan forwarding policy" -j zone_wan_dest_ACCEPT
> -A zone_lan_forward -m conntrack --ctstate DNAT -m comment --comment "!fw3: Accept port forwards" -j accept
> -A zone_lan_forward -m comment --comment "!fw3" -j zone_lan_dest_ACCEPT
> -A zone_lan_input -m comment --comment "!fw3: Custom lan input rule chain" -j input_lan_rule
> -A zone_lan_input -m conntrack --ctstate DNAT -m comment --comment "!fw3: Accept port redirections" -j accept
> -A zone_lan_input -m comment --comment "!fw3" -j zone_lan_src_ACCEPT
> -A zone_lan_output -m comment --comment "!fw3: Custom lan output rule chain" -j output_lan_rule
> -A zone_lan_output -m comment --comment "!fw3" -j zone_lan_dest_ACCEPT
> -A zone_lan_src_ACCEPT -i br-lan -m conntrack --ctstate NEW,UNTRACKED -m comment --comment "!fw3" -j accept
> -A zone_wan_dest_ACCEPT -o eth1 -m conntrack --ctstate INVALID -m comment --comment "!fw3: Prevent NAT leakage" -j DROP
> -A zone_wan_dest_ACCEPT -o eth1 -m comment --comment "!fw3" -j accept
> -A zone_wan_dest_REJECT -o eth1 -m comment --comment "!fw3" -j reject
> -A zone_wan_forward -m comment --comment "!fw3: Custom wan forwarding rule chain" -j forwarding_wan_rule
> -A zone_wan_forward -p esp -m comment --comment "!fw3: @rule[7]" -j zone_lan_dest_ACCEPT
> -A zone_wan_forward -p udp -m udp --dport 500 -m comment --comment "!fw3: @rule[8]" -j zone_lan_dest_ACCEPT
> -A zone_wan_forward -m conntrack --ctstate DNAT -m comment --comment "!fw3: Accept port forwards" -j accept
> -A zone_wan_forward -j MINIUPNPD
> -A zone_wan_forward -m comment --comment "!fw3" -j zone_wan_dest_REJECT
> -A zone_wan_input -m comment --comment "!fw3: Custom wan input rule chain" -j input_wan_rule
> -A zone_wan_input -p udp -m udp --dport 68 -m comment --comment "!fw3: Allow-DHCP-Renew" -j accept
> -A zone_wan_input -p icmp -m icmp --icmp-type 8 -m comment --comment "!fw3: Allow-Ping" -j accept
> -A zone_wan_input -p igmp -m comment --comment "!fw3: Allow-IGMP" -j accept
> -A zone_wan_input -m conntrack --ctstate DNAT -m comment --comment "!fw3: Accept port redirections" -j accept
> -A zone_wan_input -m comment --comment "!fw3" -j zone_wan_src_REJECT
> -A zone_wan_output -m comment --comment "!fw3: Custom wan output rule chain" -j output_wan_rule
> -A zone_wan_output -m comment --comment "!fw3" -j zone_wan_dest_ACCEPT
> -A zone_wan_src_REJECT -i eth1 -m comment --comment "!fw3" -j reject
> COMMIT
> ************** firewall
> ############## installed
> 6in4 - 24-1
> 6rd - 9-2
> 6to4 - 12-2
> acl - 20160519-1
> ahcpd - 0.53-2
> alsa-lib - 1.1.0-1
> asm1062-fix - 1
> at - 3.1.16-2
> ath10k-firmware-qca988x - 2018-09-06-327ee47ed67e58deb2c76c822221440c36ed952f-1
> attr - 20160302-1
> badblocks - 1.44.3-1
> base-files - 195-r47055
> bash - 4.4.11-2
> bind-client - 9.11.5-P1-1
> bind-dig - 9.11.5-P1-1
> bind-libs - 9.11.5-P1-1
> blkdiscard - 2.29.2-2
> blkid - 2.29.2-2
> block-mount - 2015-05-24-09027fc86babc3986027a0e677aca1b6999a9e14-2
> br2684ctl - 2.5.2-5
> btrfs-progs - 4.17.1-1
> busybox - 1.29.3-1
> bzip2 - 1.0.6-3
> c-rehash - 1.7-3
> ca-bundle - 20180409-2
> ca-certificates - 20180409-2
> cert-backup - 9
> cfdisk - 2.29.2-2
> chat - 2.4.7-11
> cifsmount - 6.4-1
> collectd - 4.10.8-4
> collectd-mod-cpu - 4.10.8-4
> collectd-mod-interface - 4.10.8-4
> collectd-mod-iwinfo - 4.10.8-4
> collectd-mod-load - 4.10.8-4
> collectd-mod-memory - 4.10.8-4
> collectd-mod-network - 4.10.8-4
> collectd-mod-rrdtool - 4.10.8-4
> comgt - 0.32-25
> conntrack-tools - 1.4.2-1
> coreutils - 8.29-2
> coreutils-base64 - 8.29-2
> coreutils-stat - 8.29-2
> create_notification - 58
> cryptsetup-openssl - 1.7.2-1
> curl - 7.62.0-2
> cznic-cacert-bundle - 37
> cznic-repo-keys - 4.1
> cznic-repo-keys-test - 4.1
> davfs2 - 1.5.4-2
> ddns-scripts - 2.7.8-7
> diffutils - 3.3-2
> dnsmasq - 2.78-3
> dnssec-rootkey - 0.0.1-3
> dosfsck - 3.0.28-1
> ds-lite - 7-1
> e2fsprogs - 1.44.3-1
> ebtables - 2.0.10-4-4
> etherwake - 1.09-5
> fdisk - 2.29.2-2
> file - 5.25-1
> firewall - 2018-06-13
> foris - 99.1-3.6-1
> foris-client-bin - 0.9.2-3.6-1
> foris-client-python3 - 0.9.2-3.6-1
> foris-common - 99.1-3.6-1
> foris-config - 99.1-3.6-1
> foris-controller - 0.11-3.6-1
> foris-controller-app - 0.11-3.6-1
> foris-controller-diagnostics-module - 0.4.1-3.6-1
> foris-controller-hotplug - 0.11-3.6-1
> foris-controller-storage-module - 0.2.4-3.6-1
> foris-diagnostics-plugin - 10.5-3.6-1
> foris-diagnostics-plugin-l10n-cs - 10.5-3.6-1
> foris-diagnostics-plugin-l10n-de - 10.5-3.6-1
> foris-l10n-cs - 99.1-3.6-1
> foris-l10n-de - 99.1-3.6-1
> foris-schema-python3 - 0.7.1-3.6-1
> foris-storage-plugin - 1.3-3.6-1
> foris-storage-plugin-l10n-cs - 1.3-3.6-1
> foris-ws - 1.1-3.6-1
> fosquitto - 2
> fstools - 2015-05-24-09027fc86babc3986027a0e677aca1b6999a9e14-2
> fstrim - 2.29.2-2
> fuse-utils - 2.9.8-1
> gettext - 0.19.4-6
> glib2 - 2.46.2-2
> haveged - 1.9.4-1
> hd-idle - 1.04-2
> hdparm - 9.48-1
> hfsfsck - 332.25-1
> hostapd-common - 2016-12-19-8
> htop - 2.0.1-1
> i2c-tools - 3.1.2-1
> ip-full - 4.0.0-5
> ip6tables - 1.6.1-1
> iptables - 1.6.1-1
> iptables-mod-conntrack-extra - 1.6.1-1
> iptables-mod-ipopt - 1.6.1-1
> iw - 3.17-1
> iwinfo - 2016-09-21-fd9e17be0c43bd6b8df5371f0b353747bc563874-2
> jshn - 2015-09-15-1
> jsonfilter - 2014-06-19-cdc760c58077f44fc40adbbe41e1556a67c1b9a9
> kernel - 4.4.169-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ata-ahci - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ata-ahci-platform - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ata-core - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ata-mvebu-ahci - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ath - 4.4.169+2017-01-31-5-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ath10k - 4.4.169+2017-01-31-5-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ath9k - 4.4.169+2017-01-31-5-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ath9k-common - 4.4.169+2017-01-31-5-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-atm - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-bridge - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-cfg80211 - 4.4.169+2017-01-31-5-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-aead - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-authenc - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-cbc - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-ccm - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-cmac - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-crc32c - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-ctr - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-deflate - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-des - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-ecb - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-fcrypt - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-gf128 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-hash - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-hmac - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-iv - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-manager - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-marvell-cesa - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-md4 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-md5 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-null - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-pcbc - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-pcompress - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-rng - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-seqiv - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-sha1 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-sha256 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-sha512 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-user - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-wq - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-crypto-xts - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-cryptodev - 4.4.169+1.8-mvebu-2
> kmod-dm - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-dnsresolver - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ebtables - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fs-afs - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fs-autofs4 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fs-btrfs - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fs-cifs - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fs-configfs - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fs-cramfs - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fs-exfat - 4.4.169+git-20151121-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fs-exportfs - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fs-ext4 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fs-f2fs - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fs-fscache - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fs-hfs - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fs-hfsplus - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fs-isofs - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fs-jfs - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fs-minix - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fs-msdos - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fs-nfs - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fs-nfs-common - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fs-nfs-common-v4 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fs-nfsd - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fs-ntfs - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fs-udf - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fs-vfat - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fs-xfs - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-fuse - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-gre - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-hwmon-core - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-i2c-core - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-i2c-mv64xxx - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ifb - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-input-core - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ip6-tunnel - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ip6tables - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ipt-conntrack - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ipt-conntrack-extra - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ipt-core - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ipt-ipopt - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ipt-nat - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-iptunnel - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-iptunnel4 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-iptunnel6 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ledtrig-default-on - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ledtrig-gpio - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ledtrig-heartbeat - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ledtrig-morse - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ledtrig-netdev - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ledtrig-netfilter - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ledtrig-oneshot - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ledtrig-timer - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ledtrig-transient - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ledtrig-usbdev - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-lib-crc-ccitt - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-lib-crc-itu-t - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-lib-crc16 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-lib-crc32c - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-lib-lzo - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-lib-oid-registry - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-lib-raid6 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-lib-textsearch - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-lib-xor - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-lib-zlib - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-libphy - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-llc - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-mac80211 - 4.4.169+2017-01-31-5-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-md-linear - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-md-mod - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-md-multipath - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-md-raid0 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-md-raid1 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-md-raid10 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-md-raid456 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-mii - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-mmc - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-mppe - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-mvsdio - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nf-conntrack - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nf-conntrack-netlink - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nf-conntrack6 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nf-ipt - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nf-ipt6 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nf-nat - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nf-nathelper - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nf-nathelper-extra - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nfnetlink - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nls-base - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nls-cp1250 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nls-cp1251 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nls-cp437 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nls-cp775 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nls-cp850 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nls-cp852 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nls-cp862 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nls-cp864 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nls-cp866 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nls-cp932 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nls-iso8859-1 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nls-iso8859-13 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nls-iso8859-15 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nls-iso8859-2 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nls-iso8859-6 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nls-iso8859-8 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nls-koi8r - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-nls-utf8 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-ppp - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-pppoa - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-pppoe - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-pppox - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-rxrpc - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-sched - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-sched-core - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-scsi-core - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-sit - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-slhc - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-sound-core - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-stp - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-swconfig - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-switch-mvsw61xx - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-thermal - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-thermal-armada - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-tun - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-usb-core - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-usb-net - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-usb-net-cdc-ether - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-usb-net-qmi-wwan - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-usb-net-rndis - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-usb-serial - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-usb-serial-option - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-usb-serial-qualcomm - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-usb-serial-wwan - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-usb-storage - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-usb-storage-extras - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-usb-storage-uas - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-usb-uhci - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-usb-wdm - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-usb2 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-usb3 - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> kmod-wdt-orion - 4.4.169+2-1-7bc33afbb1b35f5830b2b1b42c9cd8a0-2
> knot-libs - 2.7.3-1
> knot-libzscanner - 2.7.3-1
> knot-resolver - 3.2.1-1
> l10n_supported - 1.3-2
> libacl - 20160519-1
> libatsha204 - 28-3.6-1
> libattr - 20160302-1
> libblkid - 2.29.2-2
> libblobmsg-json - 2015-09-15-1
> libbz2 - 1.0.6-3
> libc - 1.1.15-7
> libcap - 2.24-1
> libcomerr - 1.44.3-1
> libcurl - 7.62.0-2
> libdb47 - 4.7.25.4.NC-5
> libdbi - 0.9.0-4
> libdevmapper - 2.02.145-1
> libelf1 - 0.161-2
> libevent2 - 2.0.22-1
> libexif - 0.6.21-1
> libexpat - 2.1.0-3
> libext2fs - 1.44.3-1
> libfdisk - 2.29.2-2
> libffi - 3.2.1-2
> libffmpeg - 4.0.2-0
> libflac - 1.3.1-3
> libfreetype - 2.5.5-2
> libfuse - 2.9.8-1
> libgcc - 4.8-linaro-7
> libgcrypt - 1.6.1-2
> libgdbm - 1.11-2
> libgmp - 6.1.2-1
> libgnutls - 3.5.14-1
> libgpg-error - 1.12-2
> libhavege - 1.9.4-1
> libid3tag - 0.15.1b-4
> libintl-full - 0.19.4-6
> libip4tc - 1.6.1-1
> libip6tc - 1.6.1-1
> libiwinfo - 2016-09-21-fd9e17be0c43bd6b8df5371f0b353747bc563874-2
> libiwinfo-lua - 2016-09-21-fd9e17be0c43bd6b8df5371f0b353747bc563874-2
> libjpeg - 6b-2
> libjson-c - 0.12-1
> libjson-script - 2015-09-15-1
> libkmod - 20-1
> libldns - 1.6.17-2
> libltdl - 2.4-1
> liblua - 5.1.5-2
> liblzma - 5.2.2-1
> liblzo - 2.08-1
> libmagic - 5.25-1
> libmnl - 1.0.3-2
> libmount - 2.29.2-2
> libncurses - 5.9-2
> libneon - 0.30.0-2
> libnetconf - 11
> libnetfilter-conntrack - 1.0.4-1
> libnetfilter-cthelper - 1.0.0-1
> libnetfilter-cttimeout - 1.0.0-1
> libnetfilter-queue - 1.0.2-1
> libnettle - 3.3-1
> libnfnetlink - 1.0.1-1
> libnfsidmap - 0.25-0
> libnl-tiny - 0.1-4
> libogg - 1.3.2-2
> libopenssl - 1.0.2q-1
> libpcap - 1.9.0-1
> libpcre - 8.41-1
> libpopt - 1.16-1
> libpthread - 1.1.15-7
> libreadline - 6.3-1
> librpc - 2015-04-10-308e9964bfb623773dc0dcc99ef9d18d1551d6ae
> librrd1 - 1.0.50-2
> librt - 1.1.15-7
> libsensors - 3.3.5-3
> libsmartcols - 2.29.2-2
> libspeex - 1.2rc1-1
> libsqlite3 - 3260000-1
> libss - 1.44.3-1
> libstdcpp - 4.8-linaro-7
> libsysfs - 2.1.0-2
> libubox - 2015-09-15-1
> libubus - 2015-05-29-f361bfa5fcb2daadf3b160583ce665024f8d108e
> libubus-lua - 2015-05-29-f361bfa5fcb2daadf3b160583ce665024f8d108e
> libuci - 2015-04-09.2-2
> libuci-lua - 2015-04-09.2-2
> libuclient - 2015-04-14-81fdb8fdf1470e1c7bf3124ff20d17feaeb519ee
> libunbound - 1.8.3-2
> libunistring - 0.9.6-1
> libusb-1.0 - 1.0.19-1
> libuuid - 2.29.2-2
> libuv - 1.12.0-1
> libvorbis - 1.3.6-1
> libwebsockets-openssl - 1.7.5-1
> libwrap - 7.6-1
> libxml2 - 2.9.4-1
> libxslt - 1.1.31-1
> libxtables - 1.6.1-1
> lighttpd - 1.4.50-3
> lighttpd-https-cert - 5
> lighttpd-mod-alias - 1.4.50-3
> lighttpd-mod-cgi - 1.4.50-3
> lighttpd-mod-fastcgi - 1.4.50-3
> lighttpd-mod-openssl - 1.4.50-3
> lighttpd-mod-proxy - 1.4.50-3
> lighttpd-mod-redirect - 1.4.50-3
> lighttpd-mod-setenv - 1.4.50-3
> linux-atm - 2.5.2-5
> lm-sensors - 3.3.5-3
> logrotate - 3.8.1-9
> losetup - 2.29.2-2
> lsblk - 2.29.2-2
> lsof - 4.89-2
> lua - 5.1.5-2
> luajit - 2.0.5-1
> luasec - 0.6-1
> luasocket - 3.0-rc1-20130909-3
> luci - git-18.328.59464-9636605-1
> luci-app-ahcp - git-18.328.59464-9636605-1
> luci-app-commands - git-18.328.59464-9636605-1
> luci-app-ddns - 2.4.8-1
> luci-app-firewall - git-18.328.59464-9636605-1
> luci-app-hd-idle - git-18.328.59464-9636605-1
> luci-app-minidlna - git-18.328.59464-9636605-1
> luci-app-mjpg-streamer - git-18.328.59464-9636605-1
> luci-app-rainbow - 2
> luci-app-samba - git-18.328.59464-9636605-1
> luci-app-statistics - git-18.328.59464-9636605-4
> luci-app-tinyproxy - git-18.328.59464-9636605-1
> luci-app-transmission - git-18.328.59464-9636605-2
> luci-app-upnp - git-18.328.59464-9636605-1
> luci-app-wol - git-18.328.59464-9636605-1
> luci-base - git-18.328.59464-9636605-10
> luci-i18n-ahcp-cs - git-18.328.59464-9636605-1
> luci-i18n-ahcp-de - git-18.328.59464-9636605-1
> luci-i18n-ahcp-en - git-18.328.59464-9636605-1
> luci-i18n-base-cs - git-18.328.59464-9636605-10
> luci-i18n-base-de - git-18.328.59464-9636605-10
> luci-i18n-base-en - git-18.328.59464-9636605-10
> luci-i18n-commands-cs - git-18.328.59464-9636605-1
> luci-i18n-commands-de - git-18.328.59464-9636605-1
> luci-i18n-commands-en - git-18.328.59464-9636605-1
> luci-i18n-ddns-cs - 2.4.8-1
> luci-i18n-ddns-de - 2.4.8-1
> luci-i18n-firewall-cs - git-18.328.59464-9636605-1
> luci-i18n-firewall-de - git-18.328.59464-9636605-1
> luci-i18n-firewall-en - git-18.328.59464-9636605-1
> luci-i18n-hd-idle-cs - git-18.328.59464-9636605-1
> luci-i18n-hd-idle-de - git-18.328.59464-9636605-1
> luci-i18n-hd-idle-en - git-18.328.59464-9636605-1
> luci-i18n-minidlna-cs - git-18.328.59464-9636605-1
> luci-i18n-minidlna-de - git-18.328.59464-9636605-1
> luci-i18n-minidlna-en - git-18.328.59464-9636605-1
> luci-i18n-samba-cs - git-18.328.59464-9636605-1
> luci-i18n-samba-de - git-18.328.59464-9636605-1
> luci-i18n-samba-en - git-18.328.59464-9636605-1
> luci-i18n-statistics-cs - git-18.328.59464-9636605-4
> luci-i18n-statistics-de - git-18.328.59464-9636605-4
> luci-i18n-statistics-en - git-18.328.59464-9636605-4
> luci-i18n-tinyproxy-cs - git-18.328.59464-9636605-1
> luci-i18n-tinyproxy-de - git-18.328.59464-9636605-1
> luci-i18n-tinyproxy-en - git-18.328.59464-9636605-1
> luci-i18n-transmission-cs - git-18.328.59464-9636605-2
> luci-i18n-transmission-de - git-18.328.59464-9636605-2
> luci-i18n-transmission-en - git-18.328.59464-9636605-2
> luci-i18n-upnp-cs - git-18.328.59464-9636605-1
> luci-i18n-upnp-de - git-18.328.59464-9636605-1
> luci-i18n-upnp-en - git-18.328.59464-9636605-1
> luci-i18n-wol-cs - git-18.328.59464-9636605-1
> luci-i18n-wol-de - git-18.328.59464-9636605-1
> luci-i18n-wol-en - git-18.328.59464-9636605-1
> luci-lib-ip - git-18.328.59464-9636605-1
> luci-lib-jsonc - git-18.328.59464-9636605-1
> luci-lib-nixio - git-18.328.59464-9636605-1
> luci-mod-admin-full - git-18.328.59464-9636605-3
> luci-proto-3g - git-18.328.59464-9636605-1
> luci-proto-ipv6 - git-18.328.59464-9636605-1
> luci-proto-openconnect - git-18.328.59464-9636605-1
> luci-proto-ppp - git-18.328.59464-9636605-1
> luci-proto-relay - git-18.328.59464-9636605-1
> luci-proto-vpnc - 1.0.0-2
> luci-theme-bootstrap - git-18.328.59464-9636605-1
> lvm2 - 2.02.145-1
> mdadm - 4.0-5
> minidlna - 1.2.1-3
> miniupnpd - 2.1.20180706-1
> mjpg-streamer - r182-9
> mkdosfs - 3.0.28-1
> mkhfs - 332.25-1
> mosquitto-ssl - 1.5.3-3
> mount-utils - 2.29.2-2
> mountd - 0.1-6
> msmtp - 1.6.2-2
> nethist - 14
> netifd - 2016-12-23-64a655d8ffa9f0cea1bbdd35cac6b3b99b865270
> nfs-kernel-server - 2.1.1-2
> nfs-kernel-server-utils - 2.1.1-2
> ntfs-3g - 2015.3.14-1-fuseint
> ntfs-3g-utils - 2015.3.14-1-fuseint
> ntpdate - 4.2.8p12-1
> nuci - 161-1
> nuci-nethist - 161-1
> odhcp6c - 2018-07-14-15
> odhcpd - 2015-05-21-2ebf6c8216287983779c8ec6597d30893b914a7c
> oneshot - 26
> openconnect - 7.06-5
> openssh-client - 7.9p1-1
> openssh-client-utils - 7.9p1-1
> openssh-keygen - 7.9p1-1
> openssh-moduli - 7.9p1-1
> openssh-server - 7.9p1-1
> openssh-sftp-client - 7.9p1-1
> openssh-sftp-server - 7.9p1-1
> openssl-util - 1.0.2q-1
> openvpn-openssl - 2.4.6-2
> opkg - 6
> partx-utils - 2.29.2-2
> pciutils - 3.5.1-1
> portmap - 6.0-4
> ppp - 2.4.7-11
> ppp-mod-pppoa - 2.4.7-11
> ppp-mod-pppoe - 2.4.7-11
> pptpd - 1.4.0-3
> procd - 2015-08-19-b6618ffab8ed4981c57f53929276559698541462-1
> procd-nand - 2015-08-19-b6618ffab8ed4981c57f53929276559698541462-1
> psmisc - 22.16-1
> python-base - 2.7.12-10
> python-light - 2.7.12-10
> python-logging - 2.7.12-10
> python-multiprocessing - 2.7.12-10
> python3 - 3.6.0-3.6-3
> python3-asyncio - 3.6.0-3.6-3
> python3-base - 3.6.0-3.6-3
> python3-bottle - 0.12.13-3.6-1
> python3-bottle-i18n - 0.1.5-3.6-3
> python3-codecs - 3.6.0-3.6-3
> python3-ctypes - 3.6.0-3.6-3
> python3-dbm - 3.6.0-3.6-3
> python3-decimal - 3.6.0-3.6-3
> python3-dev - 3.6.0-3.6-3
> python3-distutils - 3.6.0-3.6-3
> python3-email - 3.6.0-3.6-3
> python3-flup - 1.0.3-3.6-1
> python3-gdbm - 3.6.0-3.6-3
> python3-jinja2 - 2.10-3.6-1
> python3-jsonschema - 2.6.0-3.6-1
> python3-lib2to3 - 3.6.0-3.6-3
> python3-light - 3.6.0-3.6-3
> python3-logging - 3.6.0-3.6-3
> python3-lzma - 3.6.0-3.6-3
> python3-markupsafe - 1.0-3.6-1
> python3-multiprocessing - 3.6.0-3.6-3
> python3-ncurses - 3.6.0-3.6-3
> python3-openssl - 3.6.0-3.6-3
> python3-paho-mqtt - 1.2.3-3.6-3
> python3-pbkdf2 - 1.3-3.6-3
> python3-prctl - 1.6.1-3.6-1
> python3-pydoc - 3.6.0-3.6-3
> python3-setuptools - 40.6.2-3.6-2
> python3-sqlite3 - 3.6.0-3.6-3
> python3-turrishw - 0.4.1-3.6-1
> python3-ubus - 0.1-3.6-1
> python3-uci - 0.3-3.6-1
> python3-unittest - 3.6.0-3.6-3
> python3-websockets - 7.0-3.6-1
> python3-xml - 3.6.0-3.6-3
> rainbow-omnia - 3.1
> relayd - 2015-03-13-2970ff60bac6b70ecb682779d5c776dc559dc0b9
> resize2fs - 1.44.3-1
> resolveip - 2
> resolver-conf - 0.0.1-27
> rpcd - 2015-05-17-3d655417ab44d93aad56a6d4a668daf24b127b84-2
> rrdtool1 - 1.0.50-2
> rsync - 3.1.3-1
> rsyncd - 3.1.3-1
> samba36-client - 3.6.25-11
> samba36-server - 3.6.25-11
> schnapps - 1.6-2
> server-uplink - 5
> sfpswitch - 6
> shadow - 4.2.1-5
> shadow-chage - 4.2.1-5
> shadow-common - 4.2.1-5
> shadow-groupadd - 4.2.1-5
> shadow-groupdel - 4.2.1-5
> shadow-groupmod - 4.2.1-5
> shadow-groups - 4.2.1-5
> shadow-passwd - 4.2.1-5
> shadow-su - 4.2.1-5
> shadow-useradd - 4.2.1-5
> shadow-userdel - 4.2.1-5
> shadow-usermod - 4.2.1-5
> shadow-utils - 4.2.1-5
> smartd - 6.5-1
> smartmontools - 6.5-1
> socat - 1.7.3.2-3
> sqm-scripts - 1.0.7-3
> sshfs - 2.5-2
> start-indicator - 1
> swap-utils - 2.29.2-2
> swconfig - 15
> switch-branch - 1.6-1
> sysfsutils - 2.1.0-2
> syslog-ng3 - 3.19.1-4
> tar - 1.29-3
> tc - 4.0.0-5
> tcpdump - 4.9.2-1
> terminfo - 5.9-2
> thermometer - 3
> tinyproxy - 1.8.3-2
> turris-diagnostics - 9.1-1
> turris-maintain - 4
> turris-version - 3.11.2
> turris-webapps - 1-6
> ubi-utils - 1.5.1-2
> uboot-envtools - 2018.03-3
> ubox - 2015-07-14-907d046c8929fb74e5a3502a9498198695e62ad8
> ubusd - 2015-05-29-f361bfa5fcb2daadf3b160583ce665024f8d108e
> uclibcxx - 0.2.4-3
> uclient-fetch - 2015-04-14-81fdb8fdf1470e1c7bf3124ff20d17feaeb519ee
> udev - 173-1
> update_mac - 1
> updater-ng - 60.4.7-3.6-1
> updater-ng-localrepo - 60.4.7-3.6-1
> updater-ng-opkg - 60.4.7-3.6-1
> updater-ng-supervisor - 60.4.7-3.6-1
> uqmi - 2015-09-09-c61815319c1c0e76898048a19151f30844a6989c
> usb-modeswitch - 2014-08-26-993a9a542791953c4804f7ddbb3a07756738e37a
> usbutils - 007-1
> user-notify - 58
> user-notify-l10n-cs - 1.0.7-1
> user-notify-l10n-de - 1.0.7-1
> userlists - 11.7
> userlists-l10n-cs - 1.0.7-1
> userlists-l10n-de - 1.0.7-1
> usign - 2015-05-08-cf8dcdb8a4e874c77f3e9a8e9b643e8c17b19131
> vim-full - 8.1-1
> vixie-cron - 7-3
> vpnc - 0.5.3.r550-5
> vpnc-scripts - 20151220-1
> watchdog_adjust - 3
> wget - 1.20.1-1
> wireless-tools - 29-5
> wol - 0.7.1-3
> wpad - 2016-12-19-8
> xfs-fsck - 3.1.7-2
> xfs-growfs - 3.1.7-2
> xfs-mkfs - 3.1.7-2
> xz - 5.2.2-1
> xz-utils - 5.2.2-1
> zlib - 1.2.8-1
> ************** installed
> ############## lshw
> == cpuinfo ==
> processor : 0
> model name : ARMv7 Processor rev 1 (v7l)
> BogoMIPS : 50.00
> Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpd32
> CPU implementer : 0x41
> CPU architecture: 7
> CPU variant : 0x4
> CPU part : 0xc09
> CPU revision : 1
> processor : 1
> BogoMIPS : 50.00
> CPU architecture: 7
> CPU variant : 0x4
> CPU part : 0xc09
> CPU revision : 1
> Hardware : Marvell Armada 380/385 (Device Tree)
> Revision : 0000
> Serial : 0000000000000000
> == meminfo ==
> MemTotal: 2070072 kB
> MemFree: 1827312 kB
> MemAvailable: 1839108 kB
> Buffers: 2424 kB
> Cached: 63820 kB
> SwapCached: 0 kB
> Active: 167088 kB
> Inactive: 23680 kB
> Active(anon): 125344 kB
> Inactive(anon): 576 kB
> Active(file): 41744 kB
> Inactive(file): 23104 kB
> Unevictable: 0 kB
> Mlocked: 0 kB
> HighTotal: 1310720 kB
> HighFree: 1179824 kB
> LowTotal: 759352 kB
> LowFree: 647488 kB
> SwapTotal: 0 kB
> SwapFree: 0 kB
> Dirty: 0 kB
> Writeback: 0 kB
> AnonPages: 124704 kB
> Mapped: 15980 kB
> Shmem: 1160 kB
> Slab: 15676 kB
> SReclaimable: 6292 kB
> SUnreclaim: 9384 kB
> KernelStack: 1432 kB
> PageTables: 1708 kB
> NFS_Unstable: 0 kB
> Bounce: 0 kB
> WritebackTmp: 0 kB
> CommitLimit: 1035036 kB
> Committed_AS: 296536 kB
> VmallocTotal: 245760 kB
> VmallocUsed: 0 kB
> VmallocChunk: 0 kB
> == lsusb ==
> Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
> Device Descriptor:
> bLength 18
> bDescriptorType 1
> bcdUSB 3.00
> bDeviceClass 9 Hub
> bDeviceSubClass 0 Unused
> bDeviceProtocol 3
> bMaxPacketSize0 9
> idVendor 0x1d6b Linux Foundation
> idProduct 0x0003 3.0 root hub
> bcdDevice 4.04
> iManufacturer 3 Linux 4.4.169-7bc33afbb1b35f5830b2b1b42c9cd8a0-2 xhci-hcd
> iProduct 2 xHCI Host Controller
> iSerial 1 f10f8000.usb3
> bNumConfigurations 1
> Configuration Descriptor:
> bLength 9
> bDescriptorType 2
> wTotalLength 31
> bNumInterfaces 1
> bConfigurationValue 1
> iConfiguration 0
> bmAttributes 0xe0
> Self Powered
> Remote Wakeup
> MaxPower 0mA
> Interface Descriptor:
> bLength 9
> bDescriptorType 4
> bInterfaceNumber 0
> bAlternateSetting 0
> bNumEndpoints 1
> bInterfaceClass 9 Hub
> bInterfaceSubClass 0 Unused
> bInterfaceProtocol 0 Full speed (or root) hub
> iInterface 0
> Endpoint Descriptor:
> bLength 7
> bDescriptorType 5
> bEndpointAddress 0x81 EP 1 IN
> bmAttributes 3
> Transfer Type Interrupt
> Synch Type None
> Usage Type Data
> wMaxPacketSize 0x0004 1x 4 bytes
> bInterval 12
> bMaxBurst 0
> Hub Descriptor:
> bLength 12
> bDescriptorType 42
> nNbrPorts 1
> wHubCharacteristic 0x000a
> No power switching (usb 1.0)
> Per-port overcurrent protection
> bPwrOn2PwrGood 10 * 2 milli seconds
> bHubContrCurrent 0 milli Ampere
> bHubDecLat 0.0 micro seconds
> wHubDelay 0 nano seconds
> DeviceRemovable 0x00
> Hub Port Status:
> Port 1: 0000.02a0 5Gbps power Rx.Detect
> Binary Object Store Descriptor:
> bLength 5
> bDescriptorType 15
> wTotalLength 15
> bNumDeviceCaps 1
> SuperSpeed USB Device Capability:
> bLength 10
> bDescriptorType 16
> bDevCapabilityType 3
> bmAttributes 0x00
> wSpeedsSupported 0x0008
> Device can operate at SuperSpeed (5Gbps)
> bFunctionalitySupport 3
> Lowest fully-functional device speed is SuperSpeed (5Gbps)
> bU1DevExitLat 0 micro seconds
> bU2DevExitLat 0 micro seconds
> Device Status: 0x0001
> Self Powered
> Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
> Device Descriptor:
> bLength 18
> bDescriptorType 1
> bcdUSB 2.00
> bDeviceClass 9 Hub
> bDeviceProtocol 1 Single TT
> bMaxPacketSize0 64
> idProduct 0x0002 2.0 root hub
> bcdDevice 4.04
> bLength 9
> bDescriptorType 2
> wTotalLength 25
> bNumInterfaces 1
> iConfiguration 0
> bmAttributes 0xe0
> Self Powered
> Remote Wakeup
> MaxPower 0mA
> bLength 9
> bDescriptorType 4
> bInterfaceNumber 0
> bAlternateSetting 0
> bNumEndpoints 1
> iInterface 0
> bLength 7
> bDescriptorType 5
> bmAttributes 3
> Synch Type None
> Usage Type Data
> bInterval 12
> Hub Descriptor:
> bLength 9
> bDescriptorType 41
> nNbrPorts 1
> TT think time 8 FS bits
> PortPwrCtrlMask 0xff
> Hub Port Status:
> Port 1: 0000.0100 power
> Self Powered
> Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
> Device Descriptor:
> bLength 18
> bDescriptorType 1
> bcdUSB 3.00
> bDeviceClass 9 Hub
> bDeviceProtocol 3
> bMaxPacketSize0 9
> bcdDevice 4.04
> iSerial 1 f10f0000.usb3
> bLength 9
> bDescriptorType 2
> wTotalLength 31
> bNumInterfaces 1
> iConfiguration 0
> bmAttributes 0xe0
> Self Powered
> Remote Wakeup
> MaxPower 0mA
> bLength 9
> bDescriptorType 4
> bInterfaceNumber 0
> bAlternateSetting 0
> bNumEndpoints 1
> iInterface 0
> bLength 7
> bDescriptorType 5
> bmAttributes 3
> Synch Type None
> Usage Type Data
> bInterval 12
> bMaxBurst 0
> Hub Descriptor:
> bLength 12
> bDescriptorType 42
> nNbrPorts 1
> Hub Port Status:
> bLength 5
> bDescriptorType 15
> wTotalLength 15
> bNumDeviceCaps 1
> bLength 10
> bDescriptorType 16
> bmAttributes 0x00
> Self Powered
> Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
> Device Descriptor:
> bLength 18
> bDescriptorType 1
> bcdUSB 2.00
> bDeviceClass 9 Hub
> bMaxPacketSize0 64
> bcdDevice 4.04
> bLength 9
> bDescriptorType 2
> wTotalLength 25
> bNumInterfaces 1
> iConfiguration 0
> bmAttributes 0xe0
> Self Powered
> Remote Wakeup
> MaxPower 0mA
> bLength 9
> bDescriptorType 4
> bInterfaceNumber 0
> bAlternateSetting 0
> bNumEndpoints 1
> iInterface 0
> bLength 7
> bDescriptorType 5
> bmAttributes 3
> Synch Type None
> Usage Type Data
> bInterval 12
> Hub Descriptor:
> bLength 9
> bDescriptorType 41
> nNbrPorts 1
> Hub Port Status:
> Self Powered
> Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
> Device Descriptor:
> bLength 18
> bDescriptorType 1
> bcdUSB 2.00
> bDeviceClass 9 Hub
> bMaxPacketSize0 64
> bcdDevice 4.04
> iManufacturer 3 Linux 4.4.169-7bc33afbb1b35f5830b2b1b42c9cd8a0-2 ehci_hcd
> iProduct 2 EHCI Host Controller
> iSerial 1 f1058000.usb
> bLength 9
> bDescriptorType 2
> wTotalLength 25
> bNumInterfaces 1
> iConfiguration 0
> bmAttributes 0xe0
> Self Powered
> Remote Wakeup
> MaxPower 0mA
> bLength 9
> bDescriptorType 4
> bInterfaceNumber 0
> bAlternateSetting 0
> bNumEndpoints 1
> iInterface 0
> bLength 7
> bDescriptorType 5
> bmAttributes 3
> Synch Type None
> Usage Type Data
> bInterval 12
> Hub Descriptor:
> bLength 9
> bDescriptorType 41
> nNbrPorts 1
> wHubCharacteristic 0x0009
> Per-port power switching
> Hub Port Status:
> Self Powered
> == lspci ==
> 00:01.0 PCI bridge: Marvell Technology Group Ltd. Device 6820 (rev 04) (prog-if 00 [Normal decode])
> Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
> Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
> Latency: 0, Cache Line Size: 64 bytes
> Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
> I/O behind bridge: 0000f000-00000fff
> Memory behind bridge: e0000000-e00fffff
> Prefetchable memory behind bridge: 00000000-000fffff
> Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
> BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
> PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
> Capabilities: [40] Express (v2) Root Port (Slot+), MSI 00
> DevCap: MaxPayload 128 bytes, PhantFunc 0
> ExtTag- RBE+
> DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
> RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
> MaxPayload 128 bytes, MaxReadReq 512 bytes
> DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
> LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <256ns, L1 unlimited
> ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
> LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
> ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
> LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
> SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
> Slot #0, PowerLimit 0.000W; Interlock- NoCompl-
> SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
> Control: AttnInd Unknown, PwrInd Unknown, Power- Interlock-
> SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
> Changed: MRL- PresDet- LinkState-
> RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna- CRSVisible-
> RootCap: CRSVisible-
> RootSta: PME ReqID 0000, PMEStatus- PMEPending-
> DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR-, OBFF Not Supported ARIFwd-
> DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd-
> LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
> Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
> Compliance De-emphasis: -6dB
> LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
> EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
> lspci: Unable to load libkmod resources: error -12
> 00:02.0 PCI bridge: Marvell Technology Group Ltd. Device 6820 (rev 04) (prog-if 00 [Normal decode])
> Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
> Memory behind bridge: e0200000-e04fffff
> ExtTag- RBE+
> 00:03.0 PCI bridge: Marvell Technology Group Ltd. Device 6820 (rev 04) (prog-if 00 [Normal decode])
> Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
> Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
> Memory behind bridge: fff00000-000fffff
> ExtTag- RBE+
> 01:00.0 Network controller: Qualcomm Atheros AR9287 Wireless Network Adapter (PCI-Express) (rev 01)
> Subsystem: Qualcomm Atheros Device 30a4
> Interrupt: pin A routed to IRQ 108
> Region 0: Memory at e0000000 (64-bit, non-prefetchable) [size=64K]
> Capabilities: [40] Power Management version 3
> Flags: PMEClk- DSI- D1+ D2- AuxCurrent=375mA PME(D0+,D1+,D2-,D3hot+,D3cold-)
> Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
> Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit-
> Address: 00000000 Data: 0000
> Capabilities: [60] Express (v2) Legacy Endpoint, MSI 00
> DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
> ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
> RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
> LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <512ns, L1 <64us
> LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
> DevCap2: Completion Timeout: Not Supported, TimeoutDis+, LTR-, OBFF Not Supported
> Capabilities: [100 v1] Advanced Error Reporting
> UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
> UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
> UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
> CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
> CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
> AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
> Capabilities: [140 v1] Virtual Channel
> Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
> Arb: Fixed- WRR32- WRR64- WRR128-
> Ctrl: ArbSelect=Fixed
> Status: InProgress-
> VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
> Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
> Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
> Status: NegoPending- InProgress-
> Capabilities: [160 v1] Device Serial Number 00-15-17-ff-ff-24-14-12
> Capabilities: [170 v1] Power Budgeting <?>
> Kernel driver in use: ath9k
> 02:00.0 Network controller: Qualcomm Atheros QCA986x/988x 802.11ac Wireless Network Adapter
> Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
> Interrupt: pin A routed to IRQ 120
> Region 0: Memory at e0200000 (64-bit, non-prefetchable) [size=2M]
> Expansion ROM at e0400000 [disabled] [size=64K]
> Capabilities: [40] Power Management version 2
> Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
> Capabilities: [50] MSI: Enable+ Count=1/8 Maskable+ 64bit-
> Address: f1020a04 Data: 0f10
> Masking: 00fe00fe Pending: 00000000
> Capabilities: [70] Express (v2) Endpoint, MSI 00
> DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 <64us
> ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0.000W
> LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <4us, L1 <64us
> AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
> Status: InProgress-
> Capabilities: [160 v1] Device Serial Number 00-00-00-00-00-00-00-00
> Kernel driver in use: ath10k_pci
> == sensors ==
> armada_thermal-virtual-0
> Adapter: Virtual device
> temp1: +72.7°C
> ************** lshw
> ############## messages
> /var/log/messages
> 2019-03-12 18:07:50 notice syslog-ng[2144]: syslog-ng starting up; version='3.19.1'
> 2019-03-12 18:07:50 info kernel[]: [ 4.901380] i2c i2c-0: Added multiplexed i2c bus 7
> 2019-03-12 18:07:50 info kernel[]: [ 4.908203] i2c i2c-0: Added multiplexed i2c bus 8
> 2019-03-12 18:07:50 info kernel[]: [ 4.913015] pca954x 0-0070: registered 8 multiplexed busses for I2C mux pca9547
> 2019-03-12 18:07:50 info kernel[]: [ 4.920595] orion_wdt: Initial timeout 171 sec
> 2019-03-12 18:07:50 err kernel[]: [ 4.925185] cpu: dev_pm_opp_of_cpumask_add_table: couldn't find opp table for cpu:0, -19
> 2019-03-12 18:07:50 info kernel[]: [ 4.933422] sdhci: Secure Digital Host Controller Interface driver
> 2019-03-12 18:07:50 info kernel[]: [ 4.939615] sdhci: Copyright(c) Pierre Ossman
> 2019-03-12 18:07:50 info kernel[]: [ 4.944125] sdhci-pxav3 f10d8000.sdhci: No vmmc regulator found
> 2019-03-12 18:07:50 info kernel[]: [ 4.950059] sdhci-pxav3 f10d8000.sdhci: No vqmmc regulator found
> 2019-03-12 18:07:50 info kernel[]: [ 5.001062] mmc0: SDHCI controller on f10d8000.sdhci [f10d8000.sdhci] using ADMA
> 2019-03-12 18:07:50 info kernel[]: [ 5.008519] sdhci-pltfm: SDHCI platform and OF driver helper
> 2019-03-12 18:07:50 info kernel[]: [ 5.023749] NET: Registered protocol family 10
> 2019-03-12 18:07:50 info kernel[]: [ 5.028799] NET: Registered protocol family 17
> 2019-03-12 18:07:50 info kernel[]: [ 5.033291] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
> 2019-03-12 18:07:50 notice kernel[]: [ 5.045947] Bridge firewalling registered
> 2019-03-12 18:07:50 info kernel[]: [ 5.049967] 8021q: 802.1Q VLAN Support v1.8
> 2019-03-12 18:07:50 notice kernel[]: [ 5.054239] Registering SWP/SWPB emulation handler
> 2019-03-12 18:07:50 warning kernel[]: [ 5.059431] BTRFS: using crc32c-generic for crc32c
> 2019-03-12 18:07:50 info kernel[]: [ 5.065027] Btrfs loaded, integrity-checker=on
> 2019-03-12 18:07:50 info kernel[]: [ 5.070116] mvsw61xx 10.mvsw61xx: Found MV88E6176 at f1072004.mdio-mii:10
> 2019-03-12 18:07:50 info kernel[]: [ 5.076958] mvsw61xx 10.mvsw61xx: Using indirect addressing
> 2019-03-12 18:07:50 info kernel[]: [ 5.095212] mmc0: MAN_BKOPS_EN bit is not set
> 2019-03-12 18:07:50 info kernel[]: [ 5.102721] mmc0: new high speed MMC card at address 0001
> 2019-03-12 18:07:50 info kernel[]: [ 5.108368] mmcblk0: mmc0:0001 H8G4a’ 7.28 GiB
> 2019-03-12 18:07:50 info kernel[]: [ 5.112996] mmcblk0boot0: mmc0:0001 H8G4a’ partition 1 4.00 MiB
> 2019-03-12 18:07:50 info kernel[]: [ 5.119001] mmcblk0boot1: mmc0:0001 H8G4a’ partition 2 4.00 MiB
> 2019-03-12 18:07:50 info kernel[]: [ 5.125055] mmcblk0rpmb: mmc0:0001 H8G4a’ partition 3 4.00 MiB
> 2019-03-12 18:07:50 info kernel[]: [ 5.131956] mmcblk0: p1
> 2019-03-12 18:07:50 info kernel[]: [ 5.153811] armada38x-rtc f10a3800.rtc: setting system clock to 2019-03-12 17:07:23 UTC (1552410443)
> 2019-03-12 18:07:50 info kernel[]: [ 5.163771] Waiting 2 sec before mounting root device...
> 2019-03-12 18:07:50 info kernel[]: [ 7.173689] BTRFS: device fsid 202b74cb-1e26-43fb-8e8f-491214eaf535 devid 1 transid 308 /dev/root
> 2019-03-12 18:07:50 info kernel[]: [ 7.183201] BTRFS info (device mmcblk0p1): disk space caching is enabled
> 2019-03-12 18:07:50 info kernel[]: [ 7.189918] BTRFS: has skinny extents
> 2019-03-12 18:07:50 info kernel[]: [ 7.197847] BTRFS: detected SSD devices, enabling SSD mode
> 2019-03-12 18:07:50 info kernel[]: [ 7.231069] VFS: Mounted root (btrfs filesystem) on device 0:13.
> 2019-03-12 18:07:50 info kernel[]: [ 7.237196] Freeing unused kernel memory: 292K
> 2019-03-12 18:07:50 info kernel[]: 7.289063] init: Console is alive
> 2019-03-12 18:07:50 info kernel[]: 7.292551] init: - watchdog -
> 2019-03-12 18:07:50 info kernel[]: [ 7.701757] exFAT: Version 1.2.9
> 2019-03-12 18:07:50 info kernel[]: [ 7.719267] JFS: nTxBlock = 8192, nTxLock = 65536
> 2019-03-12 18:07:50 info kernel[]: [ 7.789544] SGI XFS with security attributes, no debug enabled
> 2019-03-12 18:07:50 info kernel[]: [ 7.796641] usbcore: registered new interface driver uas
> 2019-03-12 18:07:50 info kernel[]: [ 7.803465] uhci_hcd: USB Universal Host Controller Interface driver
> 2019-03-12 18:07:50 info kernel[]: [ 7.812987] xhci-hcd f10f0000.usb3: xHCI Host Controller
> 2019-03-12 18:07:50 info kernel[]: [ 7.818325] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
> 2019-03-12 18:07:50 info kernel[]: [ 7.825935] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x00010010
> 2019-03-12 18:07:50 info kernel[]: [ 7.834505] xhci-hcd f10f0000.usb3: irq 46, io mem 0xf10f0000
> 2019-03-12 18:07:50 info kernel[]: [ 7.840532] hub 2-0:1.0: USB hub found
> 2019-03-12 18:07:50 info kernel[]: [ 7.844310] hub 2-0:1.0: 1 port detected
> 2019-03-12 18:07:50 info kernel[]: [ 7.848330] xhci-hcd f10f0000.usb3: xHCI Host Controller
> 2019-03-12 18:07:50 info kernel[]: [ 7.853673] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
> 2019-03-12 18:07:50 info kernel[]: [ 7.861230] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
> 2019-03-12 18:07:50 info kernel[]: [ 7.869552] hub 3-0:1.0: USB hub found
> 2019-03-12 18:07:50 info kernel[]: [ 7.873336] hub 3-0:1.0: 1 port detected
> 2019-03-12 18:07:50 info kernel[]: [ 7.877407] xhci-hcd f10f8000.usb3: xHCI Host Controller
> 2019-03-12 18:07:50 info kernel[]: [ 7.882745] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
> 2019-03-12 18:07:50 info kernel[]: [ 7.890333] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x00010010
> 2019-03-12 18:07:50 info kernel[]: [ 7.898899] xhci-hcd f10f8000.usb3: irq 47, io mem 0xf10f8000
> 2019-03-12 18:07:50 info kernel[]: [ 7.904871] hub 4-0:1.0: USB hub found
> 2019-03-12 18:07:50 info kernel[]: [ 7.908639] hub 4-0:1.0: 1 port detected
> 2019-03-12 18:07:50 info kernel[]: [ 7.912660] xhci-hcd f10f8000.usb3: xHCI Host Controller
> 2019-03-12 18:07:50 info kernel[]: [ 7.917988] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
> 2019-03-12 18:07:50 info kernel[]: [ 7.925526] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
> 2019-03-12 18:07:50 info kernel[]: [ 7.933832] hub 5-0:1.0: USB hub found
> 2019-03-12 18:07:50 info kernel[]: [ 7.937600] hub 5-0:1.0: 1 port detected
> 2019-03-12 18:07:50 info kernel[]: 8.295867] init: - preinit -
> 2019-03-12 18:07:50 notice kernel[]: 11.350032] mount_root: mounting /dev/root
> 2019-03-12 18:07:50 info kernel[]: [ 11.555582] BTRFS info (device mmcblk0p1): disk space caching is enabled
> 2019-03-12 18:07:50 info kernel[]: 11.562764] mount_root: loading kmods from internal overlay
> 2019-03-12 18:07:50 info kernel[]: 11.773237] block: attempting to load /etc/config/fstab
> 2019-03-12 18:07:50 info kernel[]: 11.779603] block: extroot: not configured
> 2019-03-12 18:07:50 info kernel[]: 11.786141] procd: - early -
> 2019-03-12 18:07:50 info kernel[]: 11.789050] procd: - watchdog -
> 2019-03-12 18:07:50 notice kernel[]: [ 11.909684] random: jshn: uninitialized urandom read (4 bytes read, 41 bits of entropy available)
> 2019-03-12 18:07:50 notice kernel[]: [ 11.937773] random: jshn: uninitialized urandom read (4 bytes read, 41 bits of entropy available)
> 2019-03-12 18:07:50 notice kernel[]: [ 11.976081] random: jshn: uninitialized urandom read (4 bytes read, 41 bits of entropy available)
> 2019-03-12 18:07:50 notice kernel[]: [ 12.002252] random: jshn: uninitialized urandom read (4 bytes read, 41 bits of entropy available)
> 2019-03-12 18:07:50 notice kernel[]: [ 12.040600] random: jshn: uninitialized urandom read (4 bytes read, 41 bits of entropy available)
> 2019-03-12 18:07:50 notice kernel[]: [ 12.066891] random: jshn: uninitialized urandom read (4 bytes read, 41 bits of entropy available)
> 2019-03-12 18:07:50 notice kernel[]: [ 12.105090] random: jshn: uninitialized urandom read (4 bytes read, 41 bits of entropy available)
> 2019-03-12 18:07:50 notice kernel[]: [ 12.131384] random: jshn: uninitialized urandom read (4 bytes read, 41 bits of entropy available)
> 2019-03-12 18:07:50 notice kernel[]: [ 12.169480] random: jshn: uninitialized urandom read (4 bytes read, 41 bits of entropy available)
> 2019-03-12 18:07:50 notice kernel[]: [ 12.195545] random: jshn: uninitialized urandom read (4 bytes read, 41 bits of entropy available)
> 2019-03-12 18:07:50 info kernel[]: 12.373608] procd: - ubus -
> 2019-03-12 18:07:50 info kernel[]: 13.381359] procd: - init -
> 2019-03-12 18:07:50 info kernel[]: [ 13.448887] marvell-cesa f1090000.crypto: CESA device successfully registered
> 2019-03-12 18:07:50 info kernel[]: [ 13.461817] NET: Registered protocol family 38
> 2019-03-12 18:07:50 info kernel[]: [ 13.478249] md: linear personality registered for level -1
> 2019-03-12 18:07:50 info kernel[]: [ 13.484265] md: raid0 personality registered for level 0
> 2019-03-12 18:07:50 info kernel[]: [ 13.490366] md: raid1 personality registered for level 1
> 2019-03-12 18:07:50 info kernel[]: [ 13.496646] md: raid10 personality registered for level 10
> 2019-03-12 18:07:50 info kernel[]: [ 13.502683] async_tx: api initialized (async)
> 2019-03-12 18:07:50 info kernel[]: [ 13.510317] md: raid6 personality registered for level 6
> 2019-03-12 18:07:50 info kernel[]: [ 13.515660] md: raid5 personality registered for level 5
> 2019-03-12 18:07:50 info kernel[]: [ 13.520984] md: raid4 personality registered for level 4
> 2019-03-12 18:07:50 notice kernel[]: [ 13.528197] FS-Cache: Loaded
> 2019-03-12 18:07:50 info kernel[]: [ 13.531563] md: multipath personality registered for level -4
> 2019-03-12 18:07:50 info kernel[]: [ 13.539242] NET: Registered protocol family 8
> 2019-03-12 18:07:50 info kernel[]: [ 13.543625] NET: Registered protocol family 20
> 2019-03-12 18:07:50 info kernel[]: [ 13.551855] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
> 2019-03-12 18:07:50 notice kernel[]: [ 13.562714] Key type dns_resolver registered
> 2019-03-12 18:07:50 info kernel[]: [ 13.569828] NET: Registered protocol family 33
> 2019-03-12 18:07:50 notice kernel[]: [ 13.574301] Key type rxrpc registered
> 2019-03-12 18:07:50 notice kernel[]: [ 13.577970] Key type rxrpc_s registered
> 2019-03-12 18:07:50 info kernel[]: [ 13.584976] kAFS: Red Hat AFS client v0.1 registering.
> 2019-03-12 18:07:50 notice kernel[]: [ 13.590166] FS-Cache: Netfs 'afs' registered for caching
> 2019-03-12 18:07:50 info kernel[]: [ 13.624353] RPC: Registered named UNIX socket transport module.
> 2019-03-12 18:07:50 info kernel[]: [ 13.630292] RPC: Registered udp transport module.
> 2019-03-12 18:07:50 info kernel[]: [ 13.635026] RPC: Registered tcp transport module.
> 2019-03-12 18:07:50 info kernel[]: [ 13.639740] RPC: Registered tcp NFSv4.1 backchannel transport module.
> 2019-03-12 18:07:50 notice kernel[]: [ 13.663832] NFS: Registering the id_resolver key type
> 2019-03-12 18:07:50 notice kernel[]: [ 13.668919] Key type id_resolver registered
> 2019-03-12 18:07:50 notice kernel[]: [ 13.673127] Key type id_legacy registered
> 2019-03-12 18:07:50 info kernel[]: [ 13.677745] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
> 2019-03-12 18:07:50 info kernel[]: [ 13.686908] ntfs: driver 2.1.32 [Flags: R/O MODULE].
> 2019-03-12 18:07:50 notice kernel[]: [ 13.696703] RxRPC: Registered security type 2 'rxkad'
> 2019-03-12 18:07:50 info kernel[]: [ 13.712870] tun: Universal TUN/TAP device driver, 1.6
> 2019-03-12 18:07:50 info kernel[]: [ 13.717938] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
> 2019-03-12 18:07:50 info kernel[]: [ 13.727645] sit: IPv6 over IPv4 tunneling driver
> 2019-03-12 18:07:50 info kernel[]: [ 13.734425] gre: GRE over IPv4 demultiplexor driver
> 2019-03-12 18:07:50 info kernel[]: [ 13.739988] ip_gre: GRE over IPv4 tunneling driver
> 2019-03-12 18:07:50 info kernel[]: [ 13.759210] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
> 2019-03-12 18:07:50 info kernel[]: [ 13.767909] PPP generic driver version 2.4.2
> 2019-03-12 18:07:50 info kernel[]: [ 13.775483] ip6_tables: (C) 2000-2006 Netfilter Core Team
> 2019-03-12 18:07:50 info kernel[]: [ 13.784759] cryptodev: driver 1.8 loaded.
> 2019-03-12 18:07:50 info kernel[]: [ 13.793197] Loading modules backported from Linux version wt-2017-01-31-0-ge882dff19e7f
> 2019-03-12 18:07:50 info kernel[]: [ 13.801259] Backport generated by backports.git backports-20160324-13-g24da7d3c
> 2019-03-12 18:07:50 info kernel[]: [ 13.877502] pci 0000:00:02.0: enabling device (0140 -> 0142)
> 2019-03-12 18:07:50 info kernel[]: [ 13.883388] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
> 2019-03-12 18:07:50 warning kernel[]: [ 14.064841] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:02:00.0.bin failed with error -2
> 2019-03-12 18:07:50 warning kernel[]: [ 14.075577] ath10k_pci 0000:02:00.0: Falling back to user helper
> 2019-03-12 18:07:50 err kernel[]: [ 14.085760] firmware ath10k!pre-cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
> 2019-03-12 18:07:50 warning kernel[]: [ 14.094885] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/cal-pci-0000:02:00.0.bin failed with error -2
> 2019-03-12 18:07:50 warning kernel[]: [ 14.105273] ath10k_pci 0000:02:00.0: Falling back to user helper
> 2019-03-12 18:07:50 err kernel[]: [ 14.115243] firmware ath10k!cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
> 2019-03-12 18:07:50 info kernel[]: [ 14.131938] ath10k_pci 0000:02:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
> 2019-03-12 18:07:50 info kernel[]: [ 14.141201] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
> 2019-03-12 18:07:50 info kernel[]: [ 14.150810] ath10k_pci 0000:02:00.0: firmware ver 10.2.4-1.0-00041 api 5 features no-p2p,raw-mode,mfp,allows-mesh-bcast crc32 f43fa422
> 2019-03-12 18:07:50 warning kernel[]: [ 14.195554] ath10k_pci 0000:02:00.0: board id is not exist in otp, ignore it
> 2019-03-12 18:07:50 warning kernel[]: [ 14.202671] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
> 2019-03-12 18:07:50 warning kernel[]: [ 14.213136] ath10k_pci 0000:02:00.0: Falling back to user helper
> 2019-03-12 18:07:50 err kernel[]: [ 14.223210] firmware ath10k!QCA988X!hw2.0!board-2.bin: firmware_loading_store: map pages failed
> 2019-03-12 18:07:50 info kernel[]: [ 14.232888] ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
> 2019-03-12 18:07:50 info kernel[]: [ 15.368796] ath10k_pci 0000:02:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
> 2019-03-12 18:07:50 debug kernel[]: [ 15.462386] ath: EEPROM regdomain: 0x0
> 2019-03-12 18:07:50 debug kernel[]: [ 15.462392] ath: EEPROM indicates default country code should be used
> 2019-03-12 18:07:50 debug kernel[]: [ 15.462394] ath: doing EEPROM country->regdmn map search
> 2019-03-12 18:07:50 debug kernel[]: [ 15.462399] ath: country maps to regdmn code: 0x3a
> 2019-03-12 18:07:50 debug kernel[]: [ 15.462402] ath: Country alpha2 being used: US
> 2019-03-12 18:07:50 debug kernel[]: [ 15.462405] ath: Regpair used: 0x3a
> 2019-03-12 18:07:50 info kernel[]: [ 15.467804] u32 classifier
> 2019-03-12 18:07:50 info kernel[]: [ 15.470522] input device check on
> 2019-03-12 18:07:50 info kernel[]: [ 15.474211] Actions configured
> 2019-03-12 18:07:50 info kernel[]: [ 15.481117] Mirror/redirect action on
> 2019-03-12 18:07:50 info kernel[]: [ 15.487452] GACT probability on
> 2019-03-12 18:07:50 info kernel[]: [ 15.495301] netem: version 1.3
> 2019-03-12 18:07:50 info kernel[]: [ 15.504103] fuse init (API version 7.23)
> 2019-03-12 18:07:50 info kernel[]: [ 15.520477] usbcore: registered new interface driver cdc_wdm
> 2019-03-12 18:07:50 info kernel[]: [ 15.529126] Ebtables v2.0 registered
> 2019-03-12 18:07:50 info kernel[]: [ 15.534043] ip_tables: (C) 2000-2006 Netfilter Core Team
> 2019-03-12 18:07:50 info kernel[]: [ 15.545877] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
> 2019-03-12 18:07:50 info kernel[]: [ 15.724381] Netfilter messages via NETLINK v0.30.
> 2019-03-12 18:07:50 info kernel[]: [ 15.729933] PPP MPPE Compression module registered
> 2019-03-12 18:07:50 info kernel[]: [ 15.735257] NET: Registered protocol family 24
> 2019-03-12 18:07:50 info kernel[]: [ 15.742453] usbcore: registered new interface driver ums-alauda
> 2019-03-12 18:07:50 info kernel[]: [ 15.748676] usbcore: registered new interface driver ums-cypress
> 2019-03-12 18:07:50 info kernel[]: [ 15.755021] usbcore: registered new interface driver ums-datafab
> 2019-03-12 18:07:50 info kernel[]: [ 15.761337] usbcore: registered new interface driver ums-freecom
> 2019-03-12 18:07:50 info kernel[]: [ 15.767671] usbcore: registered new interface driver ums-isd200
> 2019-03-12 18:07:50 info kernel[]: [ 15.773988] usbcore: registered new interface driver ums-jumpshot
> 2019-03-12 18:07:50 info kernel[]: [ 15.780380] usbcore: registered new interface driver ums-karma
> 2019-03-12 18:07:50 info kernel[]: [ 15.786604] usbcore: registered new interface driver ums-sddr09
> 2019-03-12 18:07:50 info kernel[]: [ 15.792892] usbcore: registered new interface driver ums-sddr55
> 2019-03-12 18:07:50 info kernel[]: [ 15.799146] usbcore: registered new interface driver ums-usbat
> 2019-03-12 18:07:50 info kernel[]: [ 15.809363] usbcore: registered new interface driver usbserial
> 2019-03-12 18:07:50 info kernel[]: [ 15.815262] usbcore: registered new interface driver usbserial_generic
> 2019-03-12 18:07:50 info kernel[]: [ 15.821838] usbserial: USB Serial support registered for generic
> 2019-03-12 18:07:50 info kernel[]: [ 15.836637] xt_time: kernel timezone is -0000
> 2019-03-12 18:07:50 info kernel[]: [ 15.854456] usbcore: registered new interface driver cdc_ether
> 2019-03-12 18:07:50 info kernel[]: [ 15.864837] ctnetlink v0.93: registering with nfnetlink.
> 2019-03-12 18:07:50 info kernel[]: [ 15.873527] usbcore: registered new interface driver qmi_wwan
> 2019-03-12 18:07:50 info kernel[]: [ 15.880104] usbcore: registered new interface driver rndis_host
> 2019-03-12 18:07:50 info kernel[]: [ 15.893218] pci 0000:00:01.0: enabling device (0140 -> 0142)
> 2019-03-12 18:07:50 debug kernel[]: [ 15.985489] ath: EEPROM regdomain: 0x0
> 2019-03-12 18:07:50 debug kernel[]: [ 15.985493] ath: EEPROM indicates default country code should be used
> 2019-03-12 18:07:50 debug kernel[]: [ 15.985495] ath: doing EEPROM country->regdmn map search
> 2019-03-12 18:07:50 debug kernel[]: [ 15.985500] ath: country maps to regdmn code: 0x3a
> 2019-03-12 18:07:50 debug kernel[]: [ 15.985503] ath: Country alpha2 being used: US
> 2019-03-12 18:07:50 debug kernel[]: [ 15.985506] ath: Regpair used: 0x3a
> 2019-03-12 18:07:50 debug kernel[]: [ 15.997266] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
> 2019-03-12 18:07:50 info kernel[]: [ 15.998628] ieee80211 phy1: Atheros AR9287 Rev:2 mem=0xf1d80000, irq=108
> 2019-03-12 18:07:50 info kernel[]: [ 16.006955] usbcore: registered new interface driver option
> 2019-03-12 18:07:50 info kernel[]: [ 16.012623] usbserial: USB Serial support registered for GSM modem (1-port)
> 2019-03-12 18:07:50 info kernel[]: [ 16.020219] usbcore: registered new interface driver qcserial
> 2019-03-12 18:07:50 info kernel[]: [ 16.026027] usbserial: USB Serial support registered for Qualcomm USB modem
> 2019-03-12 18:07:50 notice kernel[]: [ 18.676659] random: nonblocking pool is initialized
> 2019-03-12 18:07:50 info kernel[]: [ 21.309320] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
> 2019-03-12 18:07:50 info kernel[]: [ 21.392742] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
> 2019-03-12 18:07:50 info kernel[]: [ 21.396325] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
> 2019-03-12 18:07:50 info kernel[]: [ 22.822008] device eth0 entered promiscuous mode
> 2019-03-12 18:07:50 info kernel[]: [ 22.823382] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
> 2019-03-12 18:07:50 info kernel[]: [ 22.838633] device eth2 entered promiscuous mode
> 2019-03-12 18:07:50 info kernel[]: [ 24.811150] mvneta f1030000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
> 2019-03-12 18:07:50 info kernel[]: [ 24.811193] br-lan: port 1(eth0) entered forwarding state
> 2019-03-12 18:07:50 info kernel[]: [ 24.811228] br-lan: port 1(eth0) entered forwarding state
> 2019-03-12 18:07:50 info kernel[]: [ 24.811282] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
> 2019-03-12 18:07:50 info kernel[]: [ 24.831271] mvneta f1070000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
> 2019-03-12 18:07:50 info kernel[]: [ 24.831304] br-lan: port 2(eth2) entered forwarding state
> 2019-03-12 18:07:50 info kernel[]: [ 24.831328] br-lan: port 2(eth2) entered forwarding state
> 2019-03-12 18:07:50 info kernel[]: [ 26.811088] br-lan: port 1(eth0) entered forwarding state
> 2019-03-12 18:07:50 info kernel[]: [ 26.831089] br-lan: port 2(eth2) entered forwarding state
> 2019-03-12 18:07:50 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:07:55 err ntpdate[2776]: name server cannot be used: Try again (-3)
> 2019-03-12 18:08:00 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:08:00 err kresd[2206]: [ ta ] active refresh failed for . with rcode: 2
> 2019-03-12 18:08:00 info kresd[2206]: [ ta ] next refresh for . in 1 hours
> 2019-03-12 18:08:01 info /usr/sbin/cron[2788]: (root) CMD (nethist_stats.lua)
> 2019-03-12 18:08:01 info /usr/sbin/cron[2787]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
> 2019-03-12 18:08:10 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:08:20 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:08:30 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:08:40 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:08:50 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:09:00 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:09:01 info /usr/sbin/cron[2819]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
> 2019-03-12 18:09:10 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:09:22 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:09:34 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:09:44 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:09:54 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:10:01 info /usr/sbin/cron[2851]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
> 2019-03-12 18:10:01 info /usr/sbin/cron[2852]: (root) CMD ( /usr/bin/notifier)
> 2019-03-12 18:10:01 info /usr/sbin/cron[2853]: (root) CMD (nethist_stats.lua)
> 2019-03-12 18:10:06 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:10:18 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:10:30 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:10:42 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:10:54 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:11:01 info /usr/sbin/cron[2918]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
> 2019-03-12 18:11:04 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:11:14 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:11:24 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:11:36 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:11:48 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:12:00 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:12:01 info /usr/sbin/cron[2951]: (root) CMD (/usr/sbin/logrotate -s /tmp/logrotate.state /etc/logrotate.conf)
> 2019-03-12 18:12:01 info /usr/sbin/cron[2952]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
> 2019-03-12 18:12:01 info /usr/sbin/cron[2953]: (root) CMD (nethist_stats.lua)
> 2019-03-12 18:12:12 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:12:24 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:12:36 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:12:48 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:13:00 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:13:01 info /usr/sbin/cron[2986]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
> 2019-03-12 18:13:12 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:13:25 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:13:35 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:13:45 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:13:55 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:13:55 info dnsmasq[2378]: started, version 2.78 DNS disabled
> 2019-03-12 18:13:55 warning dnsmasq[2378]: overflow: 4 log entries lost
> 2019-03-12 18:13:55 info dnsmasq-dhcp[2378]: DHCPNAK(br-lan) 192.168.0.103 88:d7:f6:3e:a9:73 wrong network
> 2019-03-12 18:13:55 warning odhcpd[2014]: DHCPV6 SOLICIT IA_NA from 00010001208094e088d7f63ea973 on br-lan: ok fd6b:f264:f775::ed0/128
> 2019-03-12 18:13:56 warning odhcpd[2014]: DHCPV6 REQUEST IA_NA from 00010001208094e088d7f63ea973 on br-lan: ok fd6b:f264:f775::ed0/128
> 2019-03-12 18:13:58 warning odhcpd[2014]: DHCPV6 CONFIRM IA_NA from 00010001208094e088d7f63ea973 on br-lan: not on-link fd6b:f264:f775::ed0/128
> 2019-03-12 18:13:58 warning odhcpd[2014]: DHCPV6 SOLICIT IA_NA from 00010001208094e088d7f63ea973 on br-lan: ok fd6b:f264:f775::ed0/128
> 2019-03-12 18:13:59 info dnsmasq-dhcp[2378]: DHCPDISCOVER(br-lan) 88:d7:f6:3e:a9:73
> 2019-03-12 18:13:59 info dnsmasq-dhcp[2378]: DHCPOFFER(br-lan) 192.168.1.113 88:d7:f6:3e:a9:73
> 2019-03-12 18:13:59 info dnsmasq-dhcp[2378]: read /etc/ethers - 0 addresses
> 2019-03-12 18:13:59 info dnsmasq-dhcp[2144]: Last message 'read /etc/ethers - 0' repeated 2 times, suppressed by syslog-ng on turris
> 2019-03-12 18:13:59 info dnsmasq-dhcp[2378]: DHCPREQUEST(br-lan) 192.168.1.113 88:d7:f6:3e:a9:73
> 2019-03-12 18:13:59 info dnsmasq-dhcp[2378]: DHCPACK(br-lan) 192.168.1.113 88:d7:f6:3e:a9:73 ZVELA-PC
> 2019-03-12 18:13:59 warning odhcpd[2014]: DHCPV6 REQUEST IA_NA from 00010001208094e088d7f63ea973 on br-lan: ok fd6b:f264:f775::ed0/128
> 2019-03-12 18:14:01 info /usr/sbin/cron[3029]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
> 2019-03-12 18:14:01 info /usr/sbin/cron[3030]: (root) CMD (nethist_stats.lua)
> 2019-03-12 18:14:07 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:14:19 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:14:31 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:14:43 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:14:55 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:15:01 info /usr/sbin/cron[3125]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
> 2019-03-12 18:15:01 info /usr/sbin/cron[3126]: (root) CMD ( /usr/bin/notifier)
> 2019-03-12 18:15:05 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:15:17 err kresd[2206]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:15:22 err kresd[3293]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:15:22 err kresd[3293]: [detect_time_skew] cannot resolve '.' NS
> 2019-03-12 18:15:32 err kresd[3293]: [ ta ] active refresh failed for . with rcode: 2
> 2019-03-12 18:15:32 info kresd[3293]: [ ta ] next refresh for . in 1 hours
> 2019-03-12 18:15:32 err kresd[3293]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:15:35 err foris-controller[2259]: WARNING:turrishw:unsupported TOS version (on omnia): 3
> 2019-03-12 18:15:40 err foris-controller[2144]: Last message 'WARNING:turrishw:uns' repeated 3 times, suppressed by syslog-ng on turris
> 2019-03-12 18:15:41 err foris-controller[2259]: WARNING:turrishw:unsupported TOS version (on omnia): 3
> 2019-03-12 18:15:42 err foris-controller[2144]: Last message 'WARNING:turrishw:uns' repeated 1 times, suppressed by syslog-ng on turris
> 2019-03-12 18:15:42 err kresd[3293]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:15:49 err foris-controller[2259]: WARNING:turrishw:unsupported TOS version (on omnia): 3
> 2019-03-12 18:15:52 err foris-controller[2144]: Last message 'WARNING:turrishw:uns' repeated 3 times, suppressed by syslog-ng on turris
> 2019-03-12 18:15:52 err kresd[3293]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:16:01 info /usr/sbin/cron[3504]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
> 2019-03-12 18:16:01 info /usr/sbin/cron[3505]: (root) CMD (nethist_stats.lua)
> 2019-03-12 18:16:02 err kresd[3293]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:16:12 err kresd[3293]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:16:19 notice netifd[]: Network device 'eth1' link is up
> 2019-03-12 18:16:19 notice netifd[]: Interface 'wan' has link connectivity
> 2019-03-12 18:16:19 notice netifd[]: Interface 'wan' is setting up now
> 2019-03-12 18:16:19 info kernel[]: [ 541.921476] mvneta f1034000.ethernet eth1: Link is Up - 100Mbps/Full - flow control off
> 2019-03-12 18:16:19 notice netifd[]: wan (3521): udhcpc: started, v1.29.3
> 2019-03-12 18:16:19 notice netifd[]: wan (3521): udhcpc: sending discover
> 2019-03-12 18:16:22 notice netifd[2144]: Last message 'wan (3521): udhcpc: ' repeated 1 times, suppressed by syslog-ng on turris
> 2019-03-12 18:16:22 err kresd[3293]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:16:25 notice netifd[]: wan (3521): udhcpc: sending discover
> 2019-03-12 18:16:29 notice netifd[2144]: Last message 'wan (3521): udhcpc: ' repeated 1 times, suppressed by syslog-ng on turris
> 2019-03-12 18:16:29 err foris-controller[2259]: WARNING:turrishw:unsupported TOS version (on omnia): 3
> 2019-03-12 18:16:31 err foris-controller[2144]: Last message 'WARNING:turrishw:uns' repeated 5 times, suppressed by syslog-ng on turris
> 2019-03-12 18:16:31 notice netifd[]: Network device 'eth1' link is down
> 2019-03-12 18:16:31 notice netifd[]: Interface 'wan' has link connectivity loss
> 2019-03-12 18:16:31 info kernel[]: [ 553.924626] mvneta f1034000.ethernet eth1: Link is Down
> 2019-03-12 18:16:31 notice netifd[]: wan (3521): udhcpc: sending discover
> 2019-03-12 18:16:31 notice netifd[]: wan (3521): udhcpc: received SIGTERM
> 2019-03-12 18:16:32 err kresd[3293]: [priming] cannot resolve '.' NS, next priming query in 10 seconds
> 2019-03-12 18:16:33 notice netifd[]: Network device 'eth1' link is up
> 2019-03-12 18:16:33 notice netifd[]: Interface 'wan' has link connectivity
> 2019-03-12 18:16:33 notice netifd[]: Interface 'wan' is setting up now
> 2019-03-12 18:16:33 info kernel[]: [ 555.921482] mvneta f1034000.ethernet eth1: Link is Up - 100Mbps/Full - flow control off
> 2019-03-12 18:16:33 notice netifd[]: wan (4060): udhcpc: started, v1.29.3
> 2019-03-12 18:16:33 notice netifd[]: wan (4060): udhcpc: sending discover
> 2019-03-12 18:16:33 notice netifd[]: wan (4060): udhcpc: sending select for 10.130.12.84
> 2019-03-12 18:16:34 notice netifd[]: wan (4060): udhcpc: lease of 10.130.12.84 obtained, lease time 21600
> 2019-03-12 18:16:34 notice netifd[]: Interface 'wan6' is enabled
> 2019-03-12 18:16:34 notice netifd[]: Network alias 'eth1' link is up
> 2019-03-12 18:16:34 notice netifd[]: Interface 'wan6' has link connectivity
> 2019-03-12 18:16:34 notice netifd[]: Interface 'wan6' is setting up now
> 2019-03-12 18:16:34 notice netifd[]: Interface 'wan6' is now up
> 2019-03-12 18:16:34 notice netifd[]: Interface 'wan' is now up
> 2019-03-12 18:16:34 notice firewall[]: Reloading firewall due to ifup of wan (eth1)
> 2019-03-12 18:16:34 info dnsmasq[2378]: exiting on receipt of SIGTERM
> 2019-03-12 18:16:34 info dnsmasq[4163]: started, version 2.78 DNS disabled
> 2019-03-12 18:16:34 info dnsmasq[4163]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC loop-detect inotify
> 2019-03-12 18:16:34 info dnsmasq-dhcp[4163]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
> 2019-03-12 18:16:34 info dnsmasq-dhcp[4163]: read /etc/ethers - 0 addresses
> 2019-03-12 18:16:36 notice firewall[]: Reloading firewall due to ifup of wan6 (eth1)
> 2019-03-12 18:16:47 info kresd[4422]: [ ta ] key: 19036 state: Missing
> 2019-03-12 18:16:47 info kresd[4422]: [ ta ] key: 20326 state: Valid
> 2019-03-12 18:16:47 info kresd[4422]: [ ta ] next refresh for . in 1 hours
> 2019-03-12 18:16:49 err foris-controller[2259]: WARNING:turrishw:unsupported TOS version (on omnia): 3
> 2019-03-12 18:16:53 err foris-controller[2144]: Last message 'WARNING:turrishw:uns' repeated 3 times, suppressed by syslog-ng on turris
> 2019-03-12 18:16:54 err foris-controller[2259]: WARNING:turrishw:unsupported TOS version (on omnia): 3
> 2019-03-12 18:16:58 err foris-controller[2144]: Last message 'WARNING:turrishw:uns' repeated 3 times, suppressed by syslog-ng on turris
> 2019-03-12 18:17:01 info /usr/sbin/cron[4636]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
> 2019-03-12 18:17:55 info kresd[5095]: [ ta ] key: 19036 state: Missing
> 2019-03-12 18:17:55 info kresd[5095]: [ ta ] key: 20326 state: Valid
> 2019-03-12 18:17:55 info kresd[5095]: [ ta ] next refresh for . in 1 hours
> 2019-03-12 18:18:01 info /usr/sbin/cron[5215]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
> 2019-03-12 18:18:01 info /usr/sbin/cron[5216]: (root) CMD (nethist_stats.lua)
> 2019-03-12 18:19:01 info /usr/sbin/cron[5371]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
> 2019-03-12 18:20:01 info /usr/sbin/cron[5648]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
> 2019-03-12 18:20:01 info /usr/sbin/cron[5649]: (root) CMD ( /usr/bin/notifier)
> 2019-03-12 18:20:01 info /usr/sbin/cron[5651]: (root) CMD (nethist_stats.lua)
> 2019-03-12 18:20:33 err kresd[5858]: [ ta ] active refresh failed for . with rcode: 2
> 2019-03-12 18:20:33 info kresd[5858]: [ ta ] next refresh for . in 1 hours
> 2019-03-12 18:21:01 info /usr/sbin/cron[6414]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
> 2019-03-12 18:21:06 info kresd[5858]: trust_anchors
> 2019-03-12 18:21:06 info kresd[5858]: [hold_down_time] => 2592000000
> 2019-03-12 18:21:06 info kresd[5858]: [add_file] => function: 0xb6818890
> 2019-03-12 18:21:06 info kresd[5858]: [keep_removed] => 0
> 2019-03-12 18:21:06 info kresd[5858]: [summary] => function: 0xb68189e0
> 2019-03-12 18:21:06 info kresd[5858]: [bootstrap_ca] => /etc/kresd/icann-ca.pem
> 2019-03-12 18:21:06 info kresd[5858]: [set_insecure] => function: 0xb68189b8
> 2019-03-12 18:21:06 info kresd[5858]: [insecure] => {
> 2019-03-12 18:21:06 info kresd[5858]: }
> 2019-03-12 18:21:06 info kresd[5858]: [keysets] => {
> 2019-03-12 18:21:06 info kresd[5858]: [\0] => {
> 2019-03-12 18:21:06 info kresd[5858]: [1] => {
> 2019-03-12 18:21:06 info kresd[5858]: [owner] => \0
> 2019-03-12 18:21:06 info kresd[5858]: [key_tag] => 19036
> 2019-03-12 18:21:06 info kresd[5858]: [class] => 1
> 2019-03-12 18:21:06 info kresd[5858]: [ttl] => 3600
> 2019-03-12 18:21:06 info kresd[5858]: [state] => Missing
> 2019-03-12 18:21:06 info kresd[5858]: [rdata] => J\\8\2I\170\193\29{odFp.T\161`sq`z\26A\133R\0\253,\225\205\2222\242N\143\181
> 2019-03-12 18:21:06 info kresd[5858]: [timer] => 1561033616
> 2019-03-12 18:21:06 info kresd[5858]: [type] => 43
> 2019-03-12 18:21:06 info kresd[5858]: [2] => {
> 2019-03-12 18:21:06 info kresd[5858]: [key_tag] => 20326
> 2019-03-12 18:21:06 info kresd[5858]: [state] => Valid
> 2019-03-12 18:21:06 info kresd[5858]: [rdata] => \1\1\3\8\3\1\0\1\172\255\180\9\188\2019\2481\247\161\229\236\136\247\165\146U\236S\4\11\2282\2s\144\164\206\137mo\144\134\243\197\225w\251\254\17\129c\170\236z\241F,G\148YD\196\226\192&\190^\152\187\205\237%\151\130r\225\227\224y\197\9...
> 2019-03-12 18:21:06 info kresd[5858]: [ttl] => 172800
> 2019-03-12 18:21:06 info kresd[5858]: [type] => 48
> 2019-03-12 18:21:06 info kresd[5858]: [filename] => /etc/root.keys
> 2019-03-12 18:21:06 info kresd[5858]: [refresh_ev] => 12
> 2019-03-12 18:21:06 info kresd[5858]: [add] => function: 0xb6818998
> 2019-03-12 18:21:06 info kresd[5858]: [bootstrap_url] => https://data.iana.org/root-anchors/root-anchors.xml
> 2019-03-12 18:21:06 info kresd[5858]: [config] => function: 0xb6818890
> ************** messages
> ############## network
> wireless.radio0=wifi-device
> wireless.radio0.type='mac80211'
> wireless.radio0.channel='11'
> wireless.radio0.country='CZ'
> wireless.radio0.hwmode='11g'
> wireless.radio0.macaddr='04:f0:21:23:2b:2a'
> wireless.radio0.htmode='HT20'
> wireless.radio0.disabled='1'
> wireless.@wifi-iface[0]=wifi-iface
> wireless.@wifi-iface[0].device='radio0'
> wireless.@wifi-iface[0].network='lan'
> wireless.@wifi-iface[0].mode='ap'
> wireless.@wifi-iface[0].ssid='Turris'
> wireless.@wifi-iface[0].encryption='none'
> wireless.radio1=wifi-device
> wireless.radio1.type='mac80211'
> wireless.radio1.channel='36'
> wireless.radio1.country='CZ'
> wireless.radio1.hwmode='11a'
> wireless.radio1.macaddr='04:f0:21:24:24:c5'
> wireless.radio1.htmode='VHT80'
> wireless.radio1.disabled='1'
> wireless.@wifi-iface[1]=wifi-iface
> wireless.@wifi-iface[1].device='radio1'
> wireless.@wifi-iface[1].network='lan'
> wireless.@wifi-iface[1].mode='ap'
> wireless.@wifi-iface[1].ssid='Turris'
> wireless.@wifi-iface[1].encryption='none'
> network.loopback=interface
> network.loopback.ifname='lo'
> network.loopback.proto='static'
> network.loopback.ipaddr='127.0.0.1'
> network.loopback.netmask='255.0.0.0'
> network.globals=globals
> network.globals.ula_prefix='fd6b:f264:f775::/48'
> network.lan=interface
> network.lan.ifname='eth0 eth2'
> network.lan.force_link='1'
> network.lan.type='bridge'
> network.lan.proto='static'
> network.lan.ipaddr='192.168.1.1'
> network.lan.netmask='255.255.255.0'
> network.lan.ip6assign='60'
> network.wan=interface
> network.wan.ifname='eth1'
> network.wan.proto='dhcp'
> network.wan.ipv6='0'
> network.wan6=interface
> network.wan6.proto='none'
> network.wan6.ifname='@wan'
> network.@switch[0]=switch
> network.@switch[0].name='switch0'
> network.@switch[0].reset='1'
> network.@switch[0].enable_vlan='1'
> network.@switch_vlan[0]=switch_vlan
> network.@switch_vlan[0].device='switch0'
> network.@switch_vlan[0].vlan='1'
> network.@switch_vlan[0].ports='0 1 2 3 5'
> network.@switch_vlan[1]=switch_vlan
> network.@switch_vlan[1].device='switch0'
> network.@switch_vlan[1].vlan='2'
> network.@switch_vlan[1].ports='4 6'
> ipv4:
> 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN qlen 1
> inet 127.0.0.1/8 scope host lo
> valid_lft forever preferred_lft forever
> 3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP qlen 532
> inet 10.130.12.84/22 brd 10.130.15.255 scope global eth1
> 14: br-lan: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP qlen 1000
> inet 192.168.1.1/24 brd 192.168.1.255 scope global br-lan
> default via 10.130.12.1 dev eth1 src 10.130.12.84
> 10.130.12.0/22 dev eth1 scope link src 10.130.12.84
> 10.130.12.1 dev eth1 scope link src 10.130.12.84
> 192.168.1.0/24 dev br-lan scope link src 192.168.1.1
> ipv6:
> 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 state UNKNOWN qlen 1
> inet6 ::1/128 scope host
> 14: br-lan: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 state UP qlen 1000
> inet6 fd6b:f264:f775::1/60 scope global
> inet6 fe80::da58:d7ff:fe00:6192/64 scope link
> fd6b:f264:f775::/64 dev br-lan metric 1024
> unreachable fd6b:f264:f775::/48 dev lo metric 2147483647 error -113
> fe80::/64 dev br-lan metric 256
> unreachable default dev lo metric -1 error -101
> ff00::/8 dev br-lan metric 256
> ************** network
> ############## nikola
> modules/module.sh: line 8: /usr/share/nikola/bin/nikola.sh: not found
> ************** nikola
> ############## processes
> PID USER VSZ STAT COMMAND
> 1 root 1368 S /sbin/procd
> 2 root 0 SW [kthreadd]
> 3 root 0 SW [ksoftirqd/0]
> 4 root 0 SW [kworker/0:0]
> 5 root 0 SW< [kworker/0:0H]
> 7 root 0 SW [rcu_sched]
> 8 root 0 SW [rcu_bh]
> 9 root 0 SW [migration/0]
> 10 root 0 SW [migration/1]
> 11 root 0 SW [ksoftirqd/1]
> 13 root 0 SW< [kworker/1:0H]
> 14 root 0 SW< [netns]
> 15 root 0 SW [kworker/u4:1]
> 37 root 0 SW [kworker/u4:3]
> 183 root 0 SW< [writeback]
> 185 root 0 SW< [crypto]
> 186 root 0 SW< [bioset]
> 188 root 0 SW< [kblockd]
> 196 root 0 SW< [ata_sff]
> 232 root 0 SW [kworker/1:1]
> 242 root 0 SW [kswapd0]
> 243 root 0 SW< [vmstat]
> 293 root 0 SW [fsnotify_mark]
> 359 root 0 SW [kworker/0:1]
> 365 root 0 SW< [bioset]
> 366 root 0 SW< [bioset]
> 367 root 0 SW< [bioset]
> 368 root 0 SW< [bioset]
> 369 root 0 SW< [bioset]
> 370 root 0 SW< [bioset]
> 371 root 0 SW< [bioset]
> 372 root 0 SW< [bioset]
> 373 root 0 SW< [bioset]
> 374 root 0 SW< [bioset]
> 375 root 0 SW< [bioset]
> 376 root 0 SW< [bioset]
> 377 root 0 SW< [bioset]
> 378 root 0 SW< [bioset]
> 379 root 0 SW< [bioset]
> 380 root 0 SW< [bioset]
> 431 root 0 SW [scsi_eh_0]
> 432 root 0 SW< [scsi_tmf_0]
> 435 root 0 SW [scsi_eh_1]
> 436 root 0 SW< [scsi_tmf_1]
> 448 root 0 SW [spi0]
> 453 root 0 SW< [bioset]
> 458 root 0 SW< [bioset]
> 574 root 0 SW [irq/94-8-0071]
> 583 root 0 SW [irq/45-mmc0]
> 610 root 0 SW< [ipv6_addrconf]
> 622 root 0 SW< [bioset]
> 630 root 0 SW< [deferwq]
> 633 root 0 SW< [bioset]
> 635 root 0 SW [mmcqd/0]
> 636 root 0 SW< [bioset]
> 637 root 0 SW [mmcqd/0boot0]
> 638 root 0 SW< [bioset]
> 639 root 0 SW [mmcqd/0boot1]
> 640 root 0 SW< [bioset]
> 641 root 0 SW [mmcqd/0rpmb]
> 653 root 0 SW< [btrfs-worker]
> 655 root 0 SW< [btrfs-worker-hi]
> 656 root 0 SW< [btrfs-delalloc]
> 657 root 0 SW< [btrfs-flush_del]
> 658 root 0 SW< [btrfs-cache]
> 659 root 0 SW< [btrfs-submit]
> 660 root 0 SW< [btrfs-fixup]
> 661 root 0 SW< [btrfs-endio]
> 662 root 0 SW< [btrfs-endio-met]
> 663 root 0 SW< [btrfs-endio-met]
> 664 root 0 SW< [btrfs-endio-rai]
> 665 root 0 SW< [btrfs-endio-rep]
> 666 root 0 SW< [btrfs-rmw]
> 667 root 0 SW< [btrfs-endio-wri]
> 668 root 0 SW< [btrfs-freespace]
> 669 root 0 SW< [btrfs-delayed-m]
> 670 root 0 SW< [btrfs-readahead]
> 671 root 0 SW< [btrfs-qgroup-re]
> 672 root 0 SW< [btrfs-extent-re]
> 673 root 0 SW [btrfs-cleaner]
> 674 root 0 SW [btrfs-transacti]
> 675 root 0 SW< [kworker/0:1H]
> 677 root 0 SW< [kworker/1:1H]
> 696 root 0 SW [jfsIO]
> 697 root 0 SW [jfsCommit]
> 698 root 0 SW [jfsCommit]
> 699 root 0 SW [jfsSync]
> 709 root 0 SW< [xfsalloc]
> 710 root 0 SW< [xfs_mru_cache]
> 759 root 0 SW< [kworker/u5:1]
> 760 root 0 SW< [kworker/u5:2]
> 985 root 844 S /sbin/ubusd
> 1098 root 716 S /sbin/askfirst /bin/ash --login
> 1134 root 0 SW [irq/41-f1090000]
> 1135 root 0 SW [irq/42-f1090000]
> 1211 root 0 SW< [md]
> 1222 root 0 SW< [raid5wq]
> 1241 root 0 SW< [kafs_vlupdated]
> 1242 root 0 SW< [kafs_callbackd]
> 1243 root 0 SW< [kafsd]
> 1248 root 0 SW< [cifsiod]
> 1263 root 0 SW< [rpciod]
> 1269 root 0 SW< [nfsiod]
> 1378 root 0 SW< [cryptodev_queue]
> 1402 root 0 SW< [cfg80211]
> 1407 root 0 SW< [ath10k_wq]
> 1408 root 0 SW< [ath10k_aux_wq]
> 1763 root 1280 S /sbin/rpcd
> 1795 root 1564 S /usr/sbin/haveged -w 1024 -d 32 -i 32 -v 1
> 1846 root 4780 S {sfpswitch.py} /usr/bin/python /usr/sbin/sfpswitch.py --nodaemon
> 1871 root 1552 S /sbin/netifd
> 2014 root 1124 S /usr/sbin/odhcpd
> 2048 nobody 792 S /usr/sbin/atd -f
> 2060 mosquitt 2892 S mosquitto -c /tmp/fosquitto.generated.conf
> 2086 root 716 S nethist
> 2134 root 2792 S /usr/sbin/sshd -f /var/etc/ssh/sshd_config
> 2144 root 9124 S /usr/sbin/syslog-ng -F
> 2249 root 23572 S {foris-ws} /usr/bin/python3.6 /usr/bin/foris-ws -a ubus --host 127.0.0.1 --port 9080 ubus --path /var/run
> 2259 root 20844 S {foris-controlle} /usr/bin/python3.6 /usr/bin/foris-controller -b openwrt -C /var/run/foris-controller-cl
> 2269 root 4868 S /usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf
> 2277 root 936 S /sbin/mountd -f
> 2310 root 764 S /usr/sbin/cron -n
> 2323 root 1756 S /usr/sbin/smartd -q never
> 2337 root 1112 S< /sbin/ntpd -n -N -S /usr/sbin/ntpd-hotplug -p 217.31.202.100 -p 195.113.144.201 -p 195.113.144.238 -p 200
> 2355 root 18156 S {foris-controlle} /usr/bin/python3.6 /usr/bin/foris-controller -b openwrt -C /var/run/foris-controller-cl
> 2364 root 18488 S {foris-controlle} /usr/bin/python3.6 /usr/bin/foris-controller -b openwrt -C /var/run/foris-controller-cl
> 2469 root 26164 S {foris} /usr/bin/python3.6 /usr/bin/foris -s flup -a config -b ubus --bus-socket /var/run/ubus.sock
> 2475 root 0 SW [kworker/1:3]
> 2534 root 20912 S {foris-controlle} /usr/bin/python3.6 /usr/bin/foris-controller -b openwrt -C /var/run/foris-controller-cl
> 2535 root 20912 S {foris-controlle} /usr/bin/python3.6 /usr/bin/foris-controller -b openwrt -C /var/run/foris-controller-cl
> 2536 root 21016 S {foris-controlle} /usr/bin/python3.6 /usr/bin/foris-controller -b openwrt -C /var/run/foris-controller-cl
> 2537 root 21068 S {foris-controlle} /usr/bin/python3.6 /usr/bin/foris-controller -b openwrt -C /var/run/foris-controller-cl
> 2540 root 21016 S {foris-controlle} /usr/bin/python3.6 /usr/bin/foris-controller -b openwrt -C /var/run/foris-controller-cl
> 2544 root 21180 S {foris-controlle} /usr/bin/python3.6 /usr/bin/foris-controller -b openwrt -C /var/run/foris-controller-cl
> 2545 root 20912 S {foris-controlle} /usr/bin/python3.6 /usr/bin/foris-controller -b openwrt -C /var/run/foris-controller-cl
> 2546 root 20912 S {foris-controlle} /usr/bin/python3.6 /usr/bin/foris-controller -b openwrt -C /var/run/foris-controller-cl
> 2550 root 20964 S {foris-controlle} /usr/bin/python3.6 /usr/bin/foris-controller -b openwrt -C /var/run/foris-controller-cl
> 2553 root 21016 S {foris-controlle} /usr/bin/python3.6 /usr/bin/foris-controller -b openwrt -C /var/run/foris-controller-cl
> 2555 root 20912 S {foris-controlle} /usr/bin/python3.6 /usr/bin/foris-controller -b openwrt -C /var/run/foris-controller-cl
> 2560 root 20912 S {foris-controlle} /usr/bin/python3.6 /usr/bin/foris-controller -b openwrt -C /var/run/foris-controller-cl
> 2561 root 21036 S {foris-controlle} /usr/bin/python3.6 /usr/bin/foris-controller -b openwrt -C /var/run/foris-controller-cl
> 2562 root 21176 S {foris-controlle} /usr/bin/python3.6 /usr/bin/foris-controller -b openwrt -C /var/run/foris-controller-cl
> 2563 root 21084 S {foris-controlle} /usr/bin/python3.6 /usr/bin/foris-controller -b openwrt -C /var/run/foris-controller-cl
> 2571 root 21068 S {foris-controlle} /usr/bin/python3.6 /usr/bin/foris-controller -b openwrt -C /var/run/foris-controller-cl
> 3102 root 0 SW [kworker/u4:0]
> 3103 root 0 SW< [kworker/u5:0]
> 4060 root 1108 S udhcpc -p /var/run/udhcpc-eth1.pid -s /lib/netifd/dhcp.script -f -t 0 -i eth1 -C -O 212
> 4163 nobody 1168 S /usr/sbin/dnsmasq -C /var/etc/dnsmasq.conf -k -x /var/run/dnsmasq/dnsmasq.pid
> 5851 root 1344 S /bin/sh /etc/rc.common /etc/init.d/kresd start
> 5853 root 1180 S sleep 60
> 5858 root 32196 S /usr/bin/kresd -c /tmp/kresd.config -f 1 /tmp/kresd -a 0.0.0.0 53 -a :: 53 -k /etc/root.keys
> 6077 root 1188 S /bin/sh /usr/share/diagnostics/diagnostics.sh -o /tmp/diagnostics-2019-03-12_aa85b720.out atsha certs cro
> 6418 root 2516 S {luci} /usr/bin/lua /www/cgi-bin/luci
> 6436 root 1108 S sh -c $(which nslookup) localhost 2>&1 | grep -qF "(null)"
> 6437 root 1108 S /bin/nslookup localhost
> 6438 root 1108 S grep -qF (null)
> 6519 root 1180 S /bin/sh modules/module.sh ./modules/processes.module run
> 6520 root 1200 S tail -n 100000
> 6521 root 1180 R {ps} busybox ps w
> ************** processes
> ############## services
> "atd": {
> "instances": {
> "instance1": {
> "running": true,
> "pid": 2048,
> "command": [
> "\/usr\/sbin\/atd",
> "-f"
> "respawn": {
> "threshold": 3600,
> "timeout": 5,
> "retry": 5
> "cron": {
> "instances": {
> "instance1": {
> "running": true,
> "pid": 2310,
> "command": [
> "\/usr\/sbin\/cron",
> "-n"
> "respawn": {
> "threshold": 3600,
> "timeout": 5,
> "retry": 5
> "dnsmasq": {
> "instances": {
> "instance1": {
> "running": true,
> "pid": 4163,
> "command": [
> "\/usr\/sbin\/dnsmasq",
> "-C",
> "\/var\/etc\/dnsmasq.conf",
> "-k",
> "-x",
> "\/var\/run\/dnsmasq\/dnsmasq.pid"
> "respawn": {
> "threshold": 3600,
> "timeout": 5,
> "retry": 5
> "triggers": [
> "config.change",
> "if",
> "eq",
> "package",
> "dhcp"
> "run_script",
> "\/etc\/init.d\/dnsmasq",
> "reload"
> "firewall": {
> "triggers": [
> "config.change",
> "if",
> "eq",
> "package",
> "firewall"
> "run_script",
> "\/etc\/init.d\/firewall",
> "reload"
> "validate": [
> "package": "firewall",
> "type": "rule",
> "rules": {
> "dest": "string",
> "dest_port": "or(port, portrange)",
> "proto": "or(uinteger, string)",
> "src": "string",
> "src_port": "or(port, portrange)",
> "target": "string"
> "type": "redirect",
> "rules": {
> "dest": "string",
> "dest_ip": "cidr",
> "src": "string",
> "src_dport": "or(port, portrange)",
> "src_ip": "cidr",
> "target": "or(SNAT, DNAT)"
> "foris-controller": {
> "instances": {
> "instance1": {
> "running": true,
> "pid": 2259,
> "command": [
> "\/usr\/bin\/foris-controller",
> "-b",
> "openwrt",
> "-C",
> "\/var\/run\/foris-controller-client.sock",
> "ubus",
> "--path",
> "\/var\/run\/ubus.sock"
> "respawn": {
> "threshold": 3600,
> "timeout": 5,
> "retry": 5
> "foris-ws": {
> "instances": {
> "instance1": {
> "running": true,
> "pid": 2249,
> "command": [
> "\/usr\/bin\/foris-ws",
> "-a",
> "ubus",
> "--host",
> "127.0.0.1",
> "--port",
> "9080",
> "ubus",
> "--path",
> "respawn": {
> "threshold": 3600,
> "timeout": 5,
> "retry": 5
> "fosquitto": {
> "instances": {
> "instance1": {
> "running": true,
> "pid": 2060,
> "command": [
> "mosquitto",
> "-c",
> "\/tmp\/fosquitto.generated.conf"
> "triggers": [
> "config.change",
> "if",
> "eq",
> "package",
> "fosquitto"
> "run_script",
> "\/etc\/init.d\/fosquitto",
> "reload"
> "hd-idle": {
> "kresd": {
> "instances": {
> "instance1": {
> "running": true,
> "pid": 5858,
> "command": [
> "\/usr\/bin\/kresd",
> "-c",
> "\/tmp\/kresd.config",
> "-f",
> "1",
> "\/tmp\/kresd",
> "-a",
> "0.0.0.0#53",
> "-a",
> "::#53",
> "-k",
> "\/etc\/root.keys"
> "respawn": {
> "threshold": 3600,
> "timeout": 5,
> "retry": 5
> "triggers": [
> "config.change",
> "if",
> "eq",
> "package",
> "dhcp"
> "run_script",
> "\/etc\/init.d\/kresd",
> "reload"
> "lighttpd": {
> "instances": {
> "instance1": {
> "running": true,
> "pid": 2269,
> "command": [
> "\/usr\/sbin\/lighttpd",
> "-D",
> "-f",
> "\/etc\/lighttpd\/lighttpd.conf"
> "respawn": {
> "threshold": 120,
> "timeout": 2,
> "retry": 5
> "nethist": {
> "instances": {
> "instance1": {
> "running": true,
> "pid": 2086,
> "command": [
> "nethist"
> "respawn": {
> "threshold": 0,
> "timeout": 5,
> "retry": 5
> "network": {
> "instances": {
> "instance1": {
> "running": true,
> "pid": 1871,
> "command": [
> "\/sbin\/netifd"
> "limits": {
> "core": "unlimited"
> "respawn": {
> "threshold": 3600,
> "timeout": 5,
> "retry": 5
> "triggers": [
> "config.change",
> "if",
> "eq",
> "package",
> "network"
> "run_script",
> "\/etc\/init.d\/network",
> "reload"
> "config.change",
> "if",
> "eq",
> "package",
> "wireless"
> "run_script",
> "reload"
> "validate": [
> "package": "network",
> "type": "switch_vlan",
> "rules": {
> "device": "string",
> "ports": "list(ports)",
> "vlan": "uinteger"
> "type": "switch",
> "rules": {
> "enable": "bool",
> "enable_vlan": "bool",
> "name": "string",
> "reset": "bool"
> "type": "rule6",
> "rules": {
> "action": "or(prohibit, unreachable, blackhole, throw)",
> "dest": "cidr6",
> "goto": "range(0,65535)",
> "in": "string",
> "invert": "bool",
> "lookup": "or(range(0,65535),string)",
> "mark": "string",
> "out": "string",
> "src": "cidr6",
> "tos": "range(0,31)"
> "type": "rule",
> "rules": {
> "dest": "cidr4",
> "in": "string",
> "invert": "bool",
> "mark": "string",
> "out": "string",
> "src": "cidr4",
> "type": "route6",
> "rules": {
> "gateway": "ip6addr",
> "interface": "string",
> "metric": "uinteger",
> "mtu": "uinteger",
> "table": "or(range(0,65535),string)",
> "target": "cidr6"
> "type": "route",
> "rules": {
> "gateway": "ip4addr",
> "mtu": "uinteger",
> "netmask": "netmask4",
> "target": "cidr4"
> "type": "atm-bridge",
> "rules": {
> "atmdev": "uinteger",
> "encaps": "or(llc, vc)",
> "payload": "or(bridged, routed)",
> "unit": "uinteger",
> "vci": "range(32, 65535)",
> "vpi": "range(0, 255)"
> "odhcpd": {
> "instances": {
> "instance1": {
> "running": true,
> "pid": 2014,
> "command": [
> "\/usr\/sbin\/odhcpd"
> "respawn": {
> "threshold": 3600,
> "timeout": 5,
> "retry": 5
> "triggers": [
> "config.change",
> "if",
> "eq",
> "package",
> "dhcp"
> "run_script",
> "\/etc\/init.d\/odhcpd",
> "reload"
> "relayd": {
> "triggers": [
> "config.change",
> "if",
> "eq",
> "package",
> "network"
> "run_script",
> "\/etc\/init.d\/relayd",
> "reload"
> "rpcd": {
> "instances": {
> "instance1": {
> "running": true,
> "pid": 1763,
> "command": [
> "\/sbin\/rpcd"
> "sfpswitch": {
> "instances": {
> "instance1": {
> "running": true,
> "pid": 1846,
> "command": [
> "\/usr\/sbin\/sfpswitch.py",
> "--nodaemon"
> "respawn": {
> "threshold": 3600,
> "timeout": 5,
> "retry": 5
> "syslog-ng": {
> "instances": {
> "instance1": {
> "running": true,
> "pid": 2144,
> "command": [
> "\/usr\/sbin\/syslog-ng",
> "-F"
> "respawn": {
> "threshold": 3600,
> "timeout": 5,
> "retry": 5
> "sysntpd": {
> "instances": {
> "instance1": {
> "running": true,
> "pid": 2337,
> "command": [
> "\/sbin\/ntpd",
> "-n",
> "-N",
> "-S",
> "\/usr\/sbin\/ntpd-hotplug",
> "-p",
> "217.31.202.100",
> "-p",
> "195.113.144.201",
> "-p",
> "195.113.144.238",
> "-p",
> "2001:1488:ffff::100",
> "-p",
> "ntp.nic.cz",
> "-p",
> "0.openwrt.pool.ntp.org",
> "-p",
> "1.openwrt.pool.ntp.org",
> "-p",
> "2.openwrt.pool.ntp.org",
> "-p",
> "3.openwrt.pool.ntp.org"
> "respawn": {
> "threshold": 3600,
> "timeout": 5,
> "retry": 5
> "validate": [
> "package": "system",
> "type": "timeserver",
> "rules": {
> "dhcp_interface": "list(string)",
> "enable_server": "bool",
> "enabled": "bool",
> "server": "list(host)",
> "use_dhcp": "bool"
> "system": {
> "triggers": [
> "config.change",
> "if",
> "eq",
> "package",
> "system"
> "run_script",
> "\/etc\/init.d\/system",
> "reload"
> "validate": [
> "type": "system",
> "rules": {
> "buffersize": "uinteger",
> "conloglevel": "uinteger",
> "hostname": "string",
> "timezone": "string",
> "zonename": "string"
> "ubus": {
> "instances": {
> "instance1": {
> "running": true,
> "pid": 985,
> "command": [
> "\/sbin\/ubusd"
> "respawn": {
> "threshold": 3600,
> "timeout": 1,
> "retry": 0
> "usbmode": {
> "instances": {
> "instance1": {
> "running": false,
> "command": [
> "\/sbin\/usbmode",
> "-s"
> drwxr-xr-x 1 root root 1086 Feb 20 13:33 .
> drwxr-xr-x 1 root root 1762 Mar 12 18:20 ..
> lrwxrwxrwx 1 root root 17 Feb 18 13:27 K00rainbow -> ../init.d/rainbow
> lrwxrwxrwx 1 root root 25 Feb 18 13:27 K00start-indicator -> ../init.d/start-indicator
> lrwxrwxrwx 1 root root 17 Feb 20 13:29 K10hd-idle -> ../init.d/hd-idle
> lrwxrwxrwx 1 root root 18 Feb 20 13:29 K1foris-ws -> ../init.d/foris-ws
> lrwxrwxrwx 1 root root 14 Feb 20 13:29 K50sshd -> ../init.d/sshd
> lrwxrwxrwx 1 root root 16 Feb 18 13:27 K85odhcpd -> ../init.d/odhcpd
> lrwxrwxrwx 1 root root 17 Feb 18 13:27 K90network -> ../init.d/network
> lrwxrwxrwx 1 root root 13 Feb 20 13:29 K90srv -> ../init.d/srv
> lrwxrwxrwx 1 root root 14 Feb 20 13:26 K98boot -> ../init.d/boot
> lrwxrwxrwx 1 root root 16 Feb 20 13:26 K99umount -> ../init.d/umount
> lrwxrwxrwx 1 root root 20 Feb 20 13:26 S00sysfixtime -> ../init.d/sysfixtime
> lrwxrwxrwx 1 root root 14 Feb 20 13:26 S10boot -> ../init.d/boot
> lrwxrwxrwx 1 root root 16 Feb 20 13:26 S10system -> ../init.d/system
> lrwxrwxrwx 1 root root 16 Feb 20 13:26 S11sysctl -> ../init.d/sysctl
> lrwxrwxrwx 1 root root 25 Feb 18 13:27 S11watchdog_adjust -> ../init.d/watchdog_adjust
> lrwxrwxrwx 1 root root 14 Feb 20 13:29 S12rpcd -> ../init.d/rpcd
> lrwxrwxrwx 1 root root 20 Feb 20 13:29 S12update_mac -> ../init.d/update_mac
> lrwxrwxrwx 1 root root 17 Feb 18 13:27 S13haveged -> ../init.d/haveged
> lrwxrwxrwx 1 root root 14 Feb 20 13:29 S15lvm2 -> ../init.d/lvm2
> lrwxrwxrwx 1 root root 20 Feb 18 13:27 S19btrfs-scan -> ../init.d/btrfs-scan
> lrwxrwxrwx 1 root root 17 Feb 18 13:27 S19dnsmasq -> ../init.d/dnsmasq
> lrwxrwxrwx 1 root root 18 Feb 18 13:27 S19firewall -> ../init.d/firewall
> lrwxrwxrwx 1 root root 19 Feb 18 13:27 S19sfpswitch -> ../init.d/sfpswitch
> lrwxrwxrwx 1 root root 17 Feb 18 13:27 S20network -> ../init.d/network
> lrwxrwxrwx 1 root root 17 Feb 20 13:29 S20usbmode -> ../init.d/usbmode
> lrwxrwxrwx 1 root root 24 Feb 20 13:26 S25led_autoconfig -> ../init.d/led_autoconfig
> lrwxrwxrwx 1 root root 21 Feb 20 13:29 S35asm1062-fix -> ../init.d/asm1062-fix
> lrwxrwxrwx 1 root root 16 Feb 18 13:27 S35odhcpd -> ../init.d/odhcpd
> lrwxrwxrwx 1 root root 15 Feb 20 13:29 S40fstab -> ../init.d/fstab
> lrwxrwxrwx 1 root root 13 Feb 20 13:29 S40srv -> ../init.d/srv
> lrwxrwxrwx 1 root root 13 Feb 20 13:29 S50atd -> ../init.d/atd
> lrwxrwxrwx 1 root root 19 Feb 20 13:29 S50fosquitto -> ../init.d/fosquitto
> lrwxrwxrwx 1 root root 17 Feb 20 13:29 S50hd-idle -> ../init.d/hd-idle
> lrwxrwxrwx 1 root root 21 Feb 20 13:29 S50libatsha204 -> ../init.d/libatsha204
> lrwxrwxrwx 1 root root 17 Feb 20 13:29 S50nethist -> ../init.d/nethist
> lrwxrwxrwx 1 root root 14 Feb 20 13:29 S50sshd -> ../init.d/sshd
> lrwxrwxrwx 1 root root 19 Feb 20 13:26 S50syslog-ng -> ../init.d/syslog-ng
> lrwxrwxrwx 1 root root 17 Feb 20 13:29 S60ntpdate -> ../init.d/ntpdate
> lrwxrwxrwx 1 root root 18 Feb 20 13:26 S60resolver -> ../init.d/resolver
> lrwxrwxrwx 1 root root 18 Feb 20 13:29 S69foris-ws -> ../init.d/foris-ws
> lrwxrwxrwx 1 root root 26 Feb 20 13:29 S70foris-controller -> ../init.d/foris-controller
> lrwxrwxrwx 1 root root 18 Feb 20 13:29 S80lighttpd -> ../init.d/lighttpd
> lrwxrwxrwx 1 root root 16 Feb 20 13:29 S80mountd -> ../init.d/mountd
> lrwxrwxrwx 1 root root 16 Feb 18 13:27 S80relayd -> ../init.d/relayd
> lrwxrwxrwx 1 root root 17 Feb 20 13:24 S85updater -> ../init.d/updater
> lrwxrwxrwx 1 root root 14 Feb 18 13:27 S90cron -> ../init.d/cron
> lrwxrwxrwx 1 root root 14 Feb 20 13:26 S95done -> ../init.d/done
> lrwxrwxrwx 1 root root 16 Feb 20 13:29 S95smartd -> ../init.d/smartd
> lrwxrwxrwx 1 root root 17 Feb 20 13:33 S98sysntpd -> ../init.d/sysntpd
> lrwxrwxrwx 1 root root 17 Feb 18 13:27 S99rainbow -> ../init.d/rainbow
> lrwxrwxrwx 1 root root 19 Feb 20 13:26 S99setup_led -> ../init.d/setup_led
> lrwxrwxrwx 1 root root 25 Feb 18 13:27 S99start-indicator -> ../init.d/start-indicator
> ************** services
> ############## turris_version
> == current ==
> 3.11.2
> == factory ==
> 3.11
> ************** turris_version
> ############## turris_webs
> curl --verbose --cacert /etc/ssl/turris.pem https://api.turris.cz/ > /dev/null
> % Total % Received % Xferd Average Speed Time Time Time Current
> Dload Upload Total Spent Left Speed
> 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0* TLSv1.2 (OUT), TLS header, Certificate Status (22):
> } [5 bytes data]
> * TLSv1.2 (OUT), TLS handshake, Client hello (1):
> } [512 bytes data]
> * OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to api.turris.cz:443
> curl: (35) OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to api.turris.cz:443
> curl --verbose --cacert /etc/ssl/www_turris_cz_ca.pem --cert-status https://www.turris.cz/ > /dev/null
> * Couldn't resolve host 'www.turris.cz'
> curl: (6) Couldn't resolve host 'www.turris.cz'
> ************** turris_webs
> ############## uboot
> Warning: Bad CRC, using default environment
> bootcmd=run distro_bootcmd
> bootdelay=2
> baudrate=115200
> arch=sandbox
> cpu=sandbox
> board=sandbox
> board_name=sandbox
> stdin=serial,cros-ec-keyb,usbkbd
> stdout=serial,vidconsole
> stderr=serial,vidconsole
> ethaddr=00:00:11:22:33:44
> eth1addr=00:00:11:22:33:45
> eth3addr=00:00:11:22:33:46
> eth5addr=00:00:11:22:33:47
> ipaddr=1.2.3.4
> host_boot=if host dev ${devnum}; then setenv devtype host; run scan_dev_for_boot_part; fi
> boot_net_pci_enum=pci enum
> boot_net_usb_start=usb start
> usb_boot=usb start; if usb dev ${devnum}; then setenv devtype usb; run scan_dev_for_boot_part; fi
> sata_boot=if sata dev ${devnum}; then setenv devtype sata; run scan_dev_for_boot_part; fi
> scsi_init=if ${scsi_need_init}; then setenv scsi_need_init false; scsi scan; fi
> scsi_boot=run scsi_init; if scsi dev ${devnum}; then setenv devtype scsi; run scan_dev_for_boot_part; fi
> ide_boot=if ide dev ${devnum}; then setenv devtype ide; run scan_dev_for_boot_part; fi
> boot_prefixes=/ /boot/
> boot_scripts=boot.scr.uimg boot.scr
> boot_script_dhcp=boot.scr.uimg
> boot_targets=host1 host0
> boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}extlinux/extlinux.conf
> scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}extlinux/extlinux.conf; then echo Found ${prefix}extlinux/extlinux.conf; run boot_extlinux; echo SCRIPT FAILED: continuing...; fi
> boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
> scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done
> scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;
> scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done
> bootcmd_host1=setenv devnum 1; run host_boot
> bootcmd_host0=setenv devnum 0; run host_boot
> distro_bootcmd=setenv scsi_need_init; for target in ${boot_targets}; do run bootcmd_${target}; done
> bootm_size=0x10000000
> kernel_addr_r=0x1000000
> fdt_addr_r=0xc00000
> ramdisk_addr_r=0x2000000
> scriptaddr=0x1000
> pxefile_addr_r=0x2000
> ************** uboot
> ############## uname
> Linux turris 4.4.169-7bc33afbb1b35f5830b2b1b42c9cd8a0-2 #1 SMP Mon Jan 14 15:04:33 CET 2019 armv7l GNU/Linux
> ************** uname
> ############## updater
> == Updater execution ==
> Argument -n ignored.
> No updater crashlog file (/tmp/updater_crash.log)
> == Updater configuration ==
> ## /etc/updater/conf.d/base.lua ##
> This file is part of updater-ng. Don't edit it.
> local branch = ""
> local lists
> local datacollection_enabled = false
> if uci then
> local cursor = uci.cursor()
> branch = cursor:get("updater", "override", "branch")
> if branch then
> WARN("Branch overriden to " .. branch)
> branch = "-" .. branch
> else
> branch = ""
> end
> lists = cursor:get("updater", "pkglists", "lists")
> -- TODO this can also be for example yes but this should work in default
> datacollection_enabled = cursor:get("foris", "eula", "agreed_collect") == '1'
> else
> ERROR("UCI library is not available. Not processing user lists.")
> end
> -- Verify contract
> if not datacollection_enabled then
> local contract_valid = io.open('/usr/share/server-uplink/contract_valid', 'r')
> if not contract_valid then -- Try to generate it
> os.execute('/usr/share/server-uplink/contract_valid.sh')
> end
> if contract_valid then
> local contract_content = contract_valid:read()
> datacollection_enabled = contract_content == 'valid'
> contract_valid:close()
> else
> WARN("Contract wasn't verified")
> -- For Turris 1.x expect in default valid contract
> datacollection_enabled = model:match("^[Tt]urris$")
> end
> end
> -- Guess what board this is.
> local base_model = ""
> if model then
> if model:match("Turris Mox") then
> base_model = "mox"
> elseif model:match("[Oo]mnia") then
> base_model = "omnia"
> elseif model:match("[Tt]urris") then
> base_model = "turris"
> end
> end
> -- Definitions common url base
> local base_url = "https://repo.turris.cz/" .. base_model .. branch .. "/lists/"
> -- Reused options for remotely fetched scripts
> local script_options = {
> security = "Remote",
> ca = system_cas,
> crl = no_crl,
> pubkey = {
> "file:///etc/updater/keys/release.pub",
> "file:///etc/updater/keys/standby.pub",
> "file:///etc/updater/keys/test.pub" -- It is normal for this one to not be present in production systems
> -- The distribution base script. It contains the repository and bunch of basic packages
> Script("base", base_url .. "base.lua", script_options)
> -- Data collection list
> if datacollection_enabled then
> Script("base", base_url .. "i_agree_datacollect.lua", script_options)
> end
> -- Additional enabled distribution lists
> if lists then
> if type(lists) == "string" then -- if there is single list then uci returns just a string
> lists = {lists}
> end
> -- Go through user lists and pull them in.
> local exec_list = {} -- We want to run userlist only once even if it's defined multiple times
> if type(lists) == "table" then
> for _, l in ipairs(lists) do
> if exec_list[l] then
> WARN("User list " .. l .. " specified multiple times")
> else
> Script("userlist-" .. l, base_url .. l .. ".lua", script_options)
> exec_list[l] = true
> end
> end
> end
> end
> ## /etc/updater/conf.d/example.lua ##
> This is example configuration file. You can use it as quick reference for your own
> configurations.
> You can create any additional file in same directory as this file
> (/etc/updater/conf.d) and use it for your configuration.
> Note that this is Lua 5.1 so you can write any Lua code to these configuration
> files and it will be executed as part of updater execution.
> Full reference to language it self can be found here:
> https://turris.pages.labs.nic.cz/updater/docs/language.html
> To add repository you have to call Repository command.
> First argument must be name of repository (duplicate names are not allowed).
> Second argument must be URL to repository. Use `file://` for local path.
> Third argument is optional table with options for this repository.
> Most important options are following:
> priority: This allows you to specify priority of this repository. Packages are
> preferably taken from repository with higher priority no matter even if there
> is potentially newer version of package. In default all repositories has
> priority 50 and you can specify any value from 0 to 100.
> verification: Specifies verification level. You can specify "none" to have do no
> repository verification or "sig" to check only repository signature or "cert" to
> not check signature but check ssl certificate if https is used. Or use "both" to
> verify both signature and ssl vertificate.
> pubkey: URL to public key used for signature verification.
> --Repository("repo-name", "https://example.com/", { pubkey = "file:///etc/repo.pubkey" })
> To specify that you want to have some package installed you have to use function
> Install.
> It expect packages names as arguments and optional table with additional options.
> You can pass multiple arguments at once to this function and additional options
> will be applied on all of those.
> priority: This allows you to specify how much you want this package. It has to be
> number between 0 and 100 and in default if not specified is set to 50. Updater
> can ignore given package if it's not possible to install it because it collides
> with some other package that is required with higher priority or with Uninstall
> command with higher priority.
> version: Explicitly states that we want to install given packages with some
> specific version. Value has to be a string starting with at least one of these
> characters "=<>". So for example if you want anything newer than version 2.0
> then you can specify ">=2.0" to this option.
> repository: Explicitly states that we want to install given packages from one of
> specified repositories.
> --Install("pkg1mame", "pkg2name", { repository = {"repo-name"} })
> To specify that you don't want to have some package installed you have to use
> function Uninstall.
> priority: See Install command for more information.
> --Uninstall("pkg1name", "pkg2name")
> ## /etc/updater/conf.d/localrepo.lua ##
> This file is part of updater-ng-localrepo. Don't edit it.
> -- Add local repositories (might be missing if not installed or used)
> Script("localrepo", "file:///usr/share/updater/localrepo/localrepo.lua", { ignore = { "missing" } })
> ## /etc/updater/conf.d/opkg.lua ##
> This file is part of updater-ng-opkg. Don't edit it.
> -- Repositories configured in opkg configuration.
> -- We read only customfeeds.conf as that should be only file where user should add additional repositories
> local custom_feed = io.open("/etc/opkg/customfeeds.conf")
> if custom_feed then
> local pubkeys = {}
> for f in pairs(ls('/etc/opkg/keys')) do
> table.insert(pubkeys, "file:///etc/opkg/keys/" .. f)
> end
> for line in custom_feed:lines() do
> if line:match('^%s*src/gz ') then
> local name, feed_uri = line:match('src/gz[%s]+([^%s]+)[%s]+([^%s]+)')
> if name and feed_uri then
> DBG("Adding custom opkg feed " .. name .. " (" .. feed_uri .. ")")
> Repository(name, feed_uri, {pubkey = pubkeys, ignore = {"missing"}})
> else
> WARN("Malformed line in customfeeds.conf:\n" .. line)
> end
> end
> end
> custom_feed:close()
> else
> ERROR("No /etc/opkg/customfeeds.conf file. No opkg feeds are included.")
> end
> ************** updater
> ############## uptime
> 18:21:13 up 14 min, load average: 0.00, 0.02, 0.00
> ************** uptime
