Unstable WiFi on MOX B
After a few hours, my main and guest WiFI are failing. I’m completely unable to connect. I’ve setup the other WiFi to be able to connect and I’ve seen this on /var/log/messages
ath10k_pci failed to submit frame: -28
ath10k_pci failed to transmit frame: -28
ath10k_pci wmi mgmt tx queue is full
Does anyone else has the issue ?
Do you have Management Frame Protection enabled? If so try to turn it off.
No, it’s disabled by default
The pcie wifi on my mox also crashes. After some hours, no data connection any more, i.e. the Symptom is that a connected device all of a sudden cannot even ping the Turris any more (for which the DHCP address was assigned hours earlier).
When I connect via ethernet port to the device, in the logfile, I find lots of error messages from the ath10k_pci driver, see below.
[ 387.537788] kmodloader: done loading kernel modules from /etc/modules.d/*
[19285.274970] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19285.408354] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19285.542073] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19285.675386] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19285.808641] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19285.942093] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19286.075618] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19286.209082] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19286.342619] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19286.476033] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19286.609601] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19286.743090] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19286.876514] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19287.009954] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19287.143447] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19287.276878] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19287.410377] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19287.543966] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19287.677534] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19287.810979] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19287.944447] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19288.077948] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19288.211403] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19288.344884] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19288.414226] ath10k_pci 0000:00:00.0: Cannot communicate with firmware, attempting to fake crash and restart firmware.
[19288.425178] ath10k_pci 0000:00:00.0: firmware crashed! (uuid 0373f901-81cf-4753-924e-b8a907c523d0)
[19288.434448] ath10k_pci 0000:00:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
[19288.444138] ath10k_pci 0000:00:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
[19288.454776] ath10k_pci 0000:00:00.0: firmware ver 10.1-ct-8x-__fW-021-4fa9f30 api 2 features wmi-10.x,has-wmi-mgmt-tx,txstatus-noack,wmi-10.x-CT,ratemask-CT,regdump-CT,txrate-CT,flush-all-CT,pingpong-CT,ch-regs-CT,nop-CT,set-special-CT,get-temp-CT,tx-rc-CT,cust-stats-CT crc32 ca41d135
[19288.480742] ath10k_pci 0000:00:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[19288.488398] ath10k_pci 0000:00:00.0: htt-ver 2.1 wmi-op 2 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
[19288.500054] ath10k_pci 0000:00:00.0: firmware register dump:
[19288.505940] ath10k_pci 0000:00:00.0: [00]: 0x00940750 0x00400C00 0x00980000 0x009B6198
[19288.513807] ath10k_pci 0000:00:00.0: [04]: 0x009B6208 0x009B632C 0x00941B6C 0x00941B20
[19288.522065] ath10k_pci 0000:00:00.0: [08]: 0x00941B00 0x009423A4 0x009422DC 0x009422C4
[19288.530447] ath10k_pci 0000:00:00.0: [12]: 0x00941B90 0x009423F4 0x009423D4 0x009423DC
[19288.538471] ath10k_pci 0000:00:00.0: [16]: 0x009423E4 0x009423EC 0x00942888 0x00942520
[19288.546560] ath10k_pci 0000:00:00.0: [20]: 0x009424FC 0x0094241C 0x00942540 0x00942498
[19288.554848] ath10k_pci 0000:00:00.0: [24]: 0x00942450 0x0094250C 0x009424D0 0x00942750
[19288.563107] ath10k_pci 0000:00:00.0: [28]: 0x00942798 0x00942844 0x009428C4 0x00942594
[19288.571400] ath10k_pci 0000:00:00.0: [32]: 0x0094258C 0x00942C28 0x00942F4C 0x00942F7C
[19288.579511] ath10k_pci 0000:00:00.0: [36]: 0x00942F90 0x00942FE4 0x00942FF8 0x00943040
[19288.587786] ath10k_pci 0000:00:00.0: [40]: 0x0094077C 0x00940790 0x00943084 0x00942F00
[19288.595718] ath10k_pci 0000:00:00.0: [44]: 0x009B6358 0x00942A80 0x00942D40 0x00942D64
[19288.604167] ath10k_pci 0000:00:00.0: [48]: 0x00942D78 0x00942D9C 0x00957E18 0x00957E28
[19288.612078] ath10k_pci 0000:00:00.0: [52]: 0x00957E20 0x00940788 0x009430EC 0x00000000
[19288.620283] ath10k_pci 0000:00:00.0: [56]: 0x00000000 0x00000000 0x00000000 0x00000000
[19288.628566] ath10k_pci 0000:00:00.0: Copy Engine register dump:
[19288.634520] ath10k_pci 0000:00:00.0: [00]: 0x00057400 3 3 3 3
[19288.641608] ath10k_pci 0000:00:00.0: [01]: 0x00057800 24 24 507 508
[19288.648220] ath10k_pci 0000:00:00.0: [02]: 0x00057c00 53 53 44 53
[19288.654977] ath10k_pci 0000:00:00.0: [03]: 0x00058000 0 0 0 0
[19288.661210] ath10k_pci 0000:00:00.0: [04]: 0x00058400 299 299 191 151
[19288.668330] ath10k_pci 0000:00:00.0: [05]: 0x00058800 8 8 59 72
[19288.674764] ath10k_pci 0000:00:00.0: [06]: 0x00058c00 25 25 25 25
[19288.681681] ath10k_pci 0000:00:00.0: [07]: 0x00059000 0 0 0 0
[19288.690417] ath10k_pci 0000:00:00.0: debug log header, dbuf: 0x4125f4 dropped: 0
[19288.698858] ath10k_pci 0000:00:00.0: [0] next: 0x41260c buf: 0x410458 sz: 1500 len: 320 count: 20 free: 0
[19288.709826] ath10k_pci 0000:00:00.0: ath10k_pci ATH10K_DBG_BUFFER:
[19288.715989] ath10k: [0000]: 00E7B37E 0BFC4C20 0000000A 0000000B 00E7B393 0BFC4C20 0000000A 0000000B
[19288.725613] ath10k: [0008]: 00E7B3A7 0BFC4C20 0000000A 0000000B 00E7B3BC 0BFC4C20 0000000A 0000000B
[19288.734729] ath10k: [0016]: 00E7B3D0 0BFC4C20 0000000A 0000000B 00E7B3E5 0BFC4C20 0000000A 0000000B
[19288.744186] ath10k: [0024]: 00E7B3F9 0BFC4C20 0000000A 0000000B 00E7B40E 0BFC4C20 0000000A 0000000B
[19288.753259] ath10k: [0032]: 00E7B422 0BFC4C20 0000000A 0000000B 00E7B437 0BFC4C20 0000000A 0000000B
[19288.762897] ath10k: [0040]: 00E7B44B 0BFC4C20 0000000A 0000000B 00E7B460 0BFC4C20 0000000A 0000000B
[19288.772264] ath10k: [0048]: 00E7B474 0BFC4C20 0000000A 0000000B 00E7B489 0BFC4C20 00000009 0000000B
[19288.781532] ath10k: [0056]: 00E7B4A2 0BFC4C20 0000000A 0000000B 00E7B4B6 0BFC4C20 0000000A 0000000B
[19288.791167] ath10k: [0064]: 00E7B4CB 0BFC4C20 0000000A 0000000B 00E7B4DF 0BFC4C20 0000000A 0000000B
[19288.800280] ath10k: [0072]: 00E7B4F4 0BFC4C20 0000000A 0000000B 00E7B508 0BFC4C20 0000000A 0000000B
[19288.809921] ath10k_pci 0000:00:00.0: ATH10K_END
[19288.815388] ath10k_pci 0000:00:00.0: [1] next: 0x4125f4 buf: 0x410a48 sz: 1500 len: 0 count: 0 free: 0
[19288.849932] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19288.857391] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19288.864698] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19288.873190] ath10k_pci 0000:00:00.0: failed to send wmi nop: -11
[19288.879349] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[19288.886681] ath10k_pci 0000:00:00.0: failed to set beacon mode for vdev 0: -108
[19288.894755] ath10k_pci 0000:00:00.0: failed to set dtim period for vdev 0: -108
[19288.901976] ath10k_pci 0000:00:00.0: removing peer, cleanup-all, deleting: peer ffffffc029743800 vdev: 0 addr: c8:bc:c8:e0:ff:d7
[19288.914253] ath10k_pci 0000:00:00.0: removing peer, cleanup-all, deleting: peer ffffffc03d369200 vdev: 0 addr: ac:bc:32:af:ab:ed
[19288.926155] ath10k_pci 0000:00:00.0: removing peer, cleanup-all, deleting: peer ffffffc03cfa8a00 vdev: 0 addr: 04:f0:21:42:1d:d4
[19289.056996] ieee80211 phy0: Hardware restart was requested
[19289.062422] ath10k_pci 0000:00:00.0: failed to recalculate rts/cts prot for vdev 0: -108
[19289.070824] ath10k_pci 0000:00:00.0: failed to set cts protection for vdev 0: -108
[19289.078768] ath10k_pci 0000:00:00.0: failed to set preamble for vdev 0: -108
[19290.165488] ath10k_pci 0000:00:00.0: 10.1 wmi init: vdevs: 16 peers: 127 tid: 256
[19290.182712] ath10k_pci 0000:00:00.0: wmi print 'P 128 V 8 T 410'
[19290.189160] ath10k_pci 0000:00:00.0: wmi print 'msdu-desc: 1424 sw-crypt: 0'
[19290.196981] ath10k_pci 0000:00:00.0: wmi print 'alloc rem: 26384 iram: 26852'
[19290.273562] ath10k_pci 0000:00:00.0: set-coverage-class, phyclk: 88 value: 0
[19290.291668] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[19290.301378] ath10k_pci 0000:00:00.0: device successfully recovered
[19291.461902] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[19609.528062] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[20020.278324] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[20024.191142] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[20029.408295] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[20032.017048] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[20039.843153] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[20378.880867] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[27266.841400] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[27618.773765] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[33839.597057] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33839.730672] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33839.864256] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33839.997826] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33840.046008] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[33840.131339] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33840.264903] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33840.398441] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33840.532097] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33840.665629] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33840.799077] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33840.932803] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33841.066374] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33841.199976] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33841.333594] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33841.350539] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[33841.467108] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33841.600645] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33841.734198] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33841.867799] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33842.001364] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33842.134928] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33842.268503] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33842.402111] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33842.535684] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33842.654957] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[33842.669106] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33842.802733] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33842.936463] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33843.069900] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33843.203556] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33843.336988] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33843.464986] ath10k_pci 0000:00:00.0: Cannot communicate with firmware, attempting to fake crash and restart firmware.
[33843.470679] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33843.483961] ath10k_pci 0000:00:00.0: firmware crashed! (uuid 8e424a69-3140-45d6-9c08-913ea73af09b)
[33843.493442] ath10k_pci 0000:00:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
[33843.503204] ath10k_pci 0000:00:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
[33843.523925] ath10k_pci 0000:00:00.0: firmware ver 10.1-ct-8x-__fW-021-4fa9f30 api 2 features wmi-10.x,has-wmi-mgmt-tx,txstatus-noack,wmi-10.x-CT,ratemask-CT,regdump-CT,txrate-CT,flush-all-CT,pingpong-CT,ch-regs-CT,nop-CT,set-special-CT,get-temp-CT,tx-rc-CT,cust-stats-CT crc32 ca41d135
[33843.550584] ath10k_pci 0000:00:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[33843.558344] ath10k_pci 0000:00:00.0: htt-ver 2.1 wmi-op 2 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
[33843.570388] ath10k_pci 0000:00:00.0: firmware register dump:
[33843.576326] ath10k_pci 0000:00:00.0: [00]: 0x00940750 0x00400C00 0x00980000 0x009B6198
[33843.584589] ath10k_pci 0000:00:00.0: [04]: 0x009B6208 0x009B632C 0x00941B6C 0x00941B20
[33843.592920] ath10k_pci 0000:00:00.0: [08]: 0x00941B00 0x009423A4 0x009422DC 0x009422C4
[33843.601223] ath10k_pci 0000:00:00.0: [12]: 0x00941B90 0x009423F4 0x009423D4 0x009423DC
[33843.609525] ath10k_pci 0000:00:00.0: [16]: 0x009423E4 0x009423EC 0x00942888 0x00942520
[33843.617822] ath10k_pci 0000:00:00.0: [20]: 0x009424FC 0x0094241C 0x00942540 0x00942498
[33843.626113] ath10k_pci 0000:00:00.0: [24]: 0x00942450 0x0094250C 0x009424D0 0x00942750
[33843.634374] ath10k_pci 0000:00:00.0: [28]: 0x00942798 0x00942844 0x009428C4 0x00942594
[33843.642701] ath10k_pci 0000:00:00.0: [32]: 0x0094258C 0x00942C28 0x00942F4C 0x00942F7C
[33843.651056] ath10k_pci 0000:00:00.0: [36]: 0x00942F90 0x00942FE4 0x00942FF8 0x00943040
[33843.659354] ath10k_pci 0000:00:00.0: [40]: 0x0094077C 0x00940790 0x00943084 0x00942F00
[33843.667652] ath10k_pci 0000:00:00.0: [44]: 0x009B6358 0x00942A80 0x00942D40 0x00942D64
[33843.675952] ath10k_pci 0000:00:00.0: [48]: 0x00942D78 0x00942D9C 0x00957E18 0x00957E28
[33843.684219] ath10k_pci 0000:00:00.0: [52]: 0x00957E20 0x00940788 0x009430EC 0x00000000
[33843.692548] ath10k_pci 0000:00:00.0: [56]: 0x00000000 0x00000000 0x00000000 0x00000000
[33843.700841] ath10k_pci 0000:00:00.0: Copy Engine register dump:
[33843.707152] ath10k_pci 0000:00:00.0: [00]: 0x00057400 3 3 3 3
[33843.713967] ath10k_pci 0000:00:00.0: [01]: 0x00057800 27 27 350 351
[33843.720815] ath10k_pci 0000:00:00.0: [02]: 0x00057c00 41 41 92 105
[33843.727661] ath10k_pci 0000:00:00.0: [03]: 0x00058000 14 14 14 14
[33843.734477] ath10k_pci 0000:00:00.0: [04]: 0x00058400 6641 6641 34 250
[33843.741507] ath10k_pci 0000:00:00.0: [05]: 0x00058800 4 4 312 324
[33843.748357] ath10k_pci 0000:00:00.0: [06]: 0x00058c00 28 28 28 28
[33843.755206] ath10k_pci 0000:00:00.0: [07]: 0x00059000 0 0 0 0
[33843.764070] ath10k_pci 0000:00:00.0: debug log header, dbuf: 0x4125f4 dropped: 0
[33843.773043] ath10k_pci 0000:00:00.0: [0] next: 0x41260c buf: 0x410458 sz: 1500 len: 672 count: 42 free: 0
[33843.784218] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[33843.791960] ath10k_pci 0000:00:00.0: ath10k_pci ATH10K_DBG_BUFFER:
[33843.798439] ath10k: [0000]: 0196306F 0BFC4C20 0000000A 0000000B 01963083 0BFC4C20 0000000A 0000000B
[33843.808007] ath10k: [0008]: 01963098 0BFC4C20 0000000A 0000000B 019630AC 0BFC4C20 0000000A 0000000B
[33843.817576] ath10k: [0016]: 019630C1 0BFC4C20 0000000A 0000000B 019630D5 0BFC4C20 0000000A 0000000B
[33843.827148] ath10k: [0024]: 019630EA 0BFC4C20 0000000A 0000000B 019630FE 0BFC4C20 0000000A 0000000B
[33843.836708] ath10k: [0032]: 01963113 0BFC4C20 0000000A 0000000B 01963127 0BFC4C20 0000000A 0000000B
[33843.846271] ath10k: [0040]: 0196313C 0BFC4C20 0000000A 0000000B 01963150 0BFC4C20 0000000A 0000000B
[33843.855843] ath10k: [0048]: 01963165 0BFC4C20 0000000A 0000000B 01963179 0BFC4C20 0000000A 0000000B
[33843.865416] ath10k: [0056]: 0196318E 0BFC4C20 0000000A 0000000B 019631A2 0BFC4C20 0000000A 0000000B
[33843.874977] ath10k: [0064]: 019631B7 0BFC4C20 0000000A 0000000B 019631CB 0BFC4C20 0000000A 0000000B
[33843.884511] ath10k: [0072]: 019631E0 0BFC4C20 0000000A 0000000B 019631F4 0BFC4C20 0000000A 0000000B
[33843.894079] ath10k: [0080]: 01963209 0BFC4C20 0000000A 0000000B 0196321D 0BFC4C20 0000000A 0000000B
[33843.903640] ath10k: [0088]: 01963232 0BFC4C20 0000000A 0000000B 01963246 0BFC4C20 0000000A 0000000B
[33843.913215] ath10k: [0096]: 0196325B 0BFC4C20 0000000A 0000000B 0196326F 0BFC4C20 0000000A 0000000B
[33843.922779] ath10k: [0104]: 01963284 0BFC4C20 0000000A 0000000B 01963298 0BFC4C20 0000000A 0000000B
[33843.932346] ath10k: [0112]: 019632AD 0BFC4C20 0000000A 0000000B 019632C1 0BFC4C20 0000000A 0000000B
[33843.941913] ath10k: [0120]: 019632D6 0BFC4C20 0000000A 0000000B 019632EA 0BFC4C20 0000000A 0000000B
[33843.951480] ath10k: [0128]: 019632FF 0BFC4C20 0000000A 0000000B 01963313 0BFC4C20 0000000A 0000000B
[33843.961040] ath10k: [0136]: 01963328 0BFC4C20 0000000A 0000000B 0196333C 0BFC4C20 0000000A 0000000B
[33843.970606] ath10k: [0144]: 01963351 0BFC4C20 0000000A 0000000B 01963365 0BFC4C20 0000000A 0000000B
[33843.980186] ath10k: [0152]: 0196337A 0BFC4C20 0000000A 0000000B 0196338E 0BFC4C20 0000000A 0000000B
[33843.989753] ath10k: [0160]: 019633A3 0BFC4C20 0000000A 0000000B 019633B7 0BFC4C20 0000000A 0000000B
[33843.999303] ath10k_pci 0000:00:00.0: ATH10K_END
[33844.005147] ath10k_pci 0000:00:00.0: [1] next: 0x4125f4 buf: 0x410a48 sz: 1500 len: 16 count: 1 free: 0
[33844.016113] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[33844.023812] ath10k_pci 0000:00:00.0: ath10k_pci ATH10K_DBG_BUFFER:
[33844.030320] ath10k: [0000]: 0196346F 0BFC4C20 0000000A 0000000B
[33844.036596] ath10k_pci 0000:00:00.0: ATH10K_END
[33844.067142] ath10k_pci 0000:00:00.0: failed to send wmi nop: -11
[33844.075484] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33844.082954] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33844.090879] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33844.098267] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[33844.106020] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33844.138477] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33844.272061] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33844.405610] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33844.539185] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33844.672752] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33844.732495] ath10k_pci 0000:00:00.0: failed to set beacon mode for vdev 0: -108
[33844.740480] ath10k_pci 0000:00:00.0: failed to set dtim period for vdev 0: -108
[33844.748862] ath10k_pci 0000:00:00.0: failed to recalculate rts/cts prot for vdev 0: -108
[33844.757312] ath10k_pci 0000:00:00.0: failed to set cts protection for vdev 0: -108
[33844.765219] ath10k_pci 0000:00:00.0: failed to set preamble for vdev 0: -108
[33844.806331] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33844.939811] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33845.073491] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33845.206944] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33845.263928] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[33845.340665] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[33845.374717] ath10k_pci 0000:00:00.0: failed to transmit management frame via WMI: -108
[33845.383191] ath10k_pci 0000:00:00.0: removing peer, cleanup-all, deleting: peer ffffffc02f1e3400 vdev: 0 addr: c8:bc:c8:e0:ff:d7
[33845.395549] ath10k_pci 0000:00:00.0: removing peer, cleanup-all, deleting: peer ffffffc029742a00 vdev: 0 addr: ac:bc:32:af:ab:ed
[33845.407872] ath10k_pci 0000:00:00.0: removing peer, cleanup-all, deleting: peer ffffffc029743200 vdev: 0 addr: 04:f0:21:42:1d:d4
[33845.544730] ieee80211 phy0: Hardware restart was requested
[33846.603782] ath10k_pci 0000:00:00.0: 10.1 wmi init: vdevs: 16 peers: 127 tid: 256
[33846.620986] ath10k_pci 0000:00:00.0: wmi print 'P 128 V 8 T 410'
[33846.627117] ath10k_pci 0000:00:00.0: wmi print 'msdu-desc: 1424 sw-crypt: 0'
[33846.635051] ath10k_pci 0000:00:00.0: wmi print 'alloc rem: 26384 iram: 26852'
[33846.720914] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[33846.733287] ath10k_pci 0000:00:00.0: device successfully recovered
[33847.900291] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[33854.410665] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[34158.226918] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[34160.835678] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[34162.139834] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[34512.908709] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[34514.212791] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[34872.816271] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[41760.535376] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[42112.525147] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[46620.179236] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46620.312634] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46620.446268] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46620.579879] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46620.713379] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46620.846740] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46620.980323] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46621.075803] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[46621.113802] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46621.247391] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46621.380928] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46621.514528] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46621.648093] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46621.781824] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46621.915412] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46622.049069] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46622.182693] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46622.316420] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46622.380688] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[46622.449998] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46622.583566] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46622.717079] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46622.850801] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46622.984314] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46623.118012] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46623.251690] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46623.385299] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46623.518883] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46623.652496] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46623.685504] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[46623.712851] ath10k_pci 0000:00:00.0: Cannot communicate with firmware, attempting to fake crash and restart firmware.
[46623.724119] ath10k_pci 0000:00:00.0: firmware crashed! (uuid fb2336b4-98b6-4797-8c70-12a96c5527f1)
[46623.733601] ath10k_pci 0000:00:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
[46623.743023] ath10k_pci 0000:00:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
[46623.754065] ath10k_pci 0000:00:00.0: firmware ver 10.1-ct-8x-__fW-021-4fa9f30 api 2 features wmi-10.x,has-wmi-mgmt-tx,txstatus-noack,wmi-10.x-CT,ratemask-CT,regdump-CT,txrate-CT,flush-all-CT,pingpong-CT,ch-regs-CT,nop-CT,set-special-CT,get-temp-CT,tx-rc-CT,cust-stats-CT crc32 ca41d135
[46623.779904] ath10k_pci 0000:00:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[46623.787502] ath10k_pci 0000:00:00.0: htt-ver 2.1 wmi-op 2 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
[46623.799265] ath10k_pci 0000:00:00.0: firmware register dump:
[46623.805061] ath10k_pci 0000:00:00.0: [00]: 0x00940750 0x00400C00 0x00980000 0x009B6198
[46623.813350] ath10k_pci 0000:00:00.0: [04]: 0x009B6208 0x009B632C 0x00941B6C 0x00941B20
[46623.821374] ath10k_pci 0000:00:00.0: [08]: 0x00941B00 0x009423A4 0x009422DC 0x009422C4
[46623.829486] ath10k_pci 0000:00:00.0: [12]: 0x00941B90 0x009423F4 0x009423D4 0x009423DC
[46623.837872] ath10k_pci 0000:00:00.0: [16]: 0x009423E4 0x009423EC 0x00942888 0x00942520
[46623.845692] ath10k_pci 0000:00:00.0: [20]: 0x009424FC 0x0094241C 0x00942540 0x00942498
[46623.854069] ath10k_pci 0000:00:00.0: [24]: 0x00942450 0x0094250C 0x009424D0 0x00942750
[46623.862415] ath10k_pci 0000:00:00.0: [28]: 0x00942798 0x00942844 0x009428C4 0x00942594
[46623.870349] ath10k_pci 0000:00:00.0: [32]: 0x0094258C 0x00942C28 0x00942F4C 0x00942F7C
[46623.878906] ath10k_pci 0000:00:00.0: [36]: 0x00942F90 0x00942FE4 0x00942FF8 0x00943040
[46623.887124] ath10k_pci 0000:00:00.0: [40]: 0x0094077C 0x00940790 0x00943084 0x00942F00
[46623.895347] ath10k_pci 0000:00:00.0: [44]: 0x009B6358 0x00942A80 0x00942D40 0x00942D64
[46623.903203] ath10k_pci 0000:00:00.0: [48]: 0x00942D78 0x00942D9C 0x00957E18 0x00957E28
[46623.911743] ath10k_pci 0000:00:00.0: [52]: 0x00957E20 0x00940788 0x009430EC 0x00000000
[46623.919875] ath10k_pci 0000:00:00.0: [56]: 0x00000000 0x00000000 0x00000000 0x00000000
[46623.927987] ath10k_pci 0000:00:00.0: Copy Engine register dump:
[46623.934105] ath10k_pci 0000:00:00.0: [00]: 0x00057400 3 3 3 3
[46623.940840] ath10k_pci 0000:00:00.0: [01]: 0x00057800 25 25 28 29
[46623.947433] ath10k_pci 0000:00:00.0: [02]: 0x00057c00 38 38 28 38
[46623.954194] ath10k_pci 0000:00:00.0: [03]: 0x00058000 13 13 13 13
[46623.960734] ath10k_pci 0000:00:00.0: [04]: 0x00058400 6855 6855 141 101
[46623.967316] ath10k_pci 0000:00:00.0: [05]: 0x00058800 29 29 115 125
[46623.973987] ath10k_pci 0000:00:00.0: [06]: 0x00058c00 23 23 23 23
[46623.980807] ath10k_pci 0000:00:00.0: [07]: 0x00059000 0 0 0 0
[46623.989598] ath10k_pci 0000:00:00.0: debug log header, dbuf: 0x4125f4 dropped: 0
[46623.998036] ath10k_pci 0000:00:00.0: [0] next: 0x41260c buf: 0x410458 sz: 1500 len: 192 count: 12 free: 0
[46624.008991] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[46624.016583] ath10k_pci 0000:00:00.0: ath10k_pci ATH10K_DBG_BUFFER:
[46624.023070] ath10k: [0000]: 022F5AF5 0BFC4C20 0000000A 0000000B 022F5B0A 0BFC4C20 0000000A 0000000B
[46624.032183] ath10k: [0008]: 022F5B1E 0BFC4C20 0000000A 0000000B 022F5B33 0BFC4C20 0000000A 0000000B
[46624.041880] ath10k: [0016]: 022F5B47 0BFC4C20 0000000A 0000000B 022F5B5C 0BFC4C20 0000000A 0000000B
[46624.051225] ath10k: [0024]: 022F5B70 0BFC4C20 0000000A 0000000B 022F5B85 0BFC4C20 0000000A 0000000B
[46624.060393] ath10k: [0032]: 022F5B99 0BFC4C20 0000000A 0000000B 022F5BAE 0BFC4C20 0000000A 0000000B
[46624.069864] ath10k: [0040]: 022F5BC2 0BFC4C20 0000000A 0000000B 022F5BD7 0BFC4C20 0000000A 0000000B
[46624.079412] ath10k_pci 0000:00:00.0: ATH10K_END
[46624.085005] ath10k_pci 0000:00:00.0: [1] next: 0x4125f4 buf: 0x410a48 sz: 1500 len: 0 count: 0 free: 0
[46624.119358] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46624.126917] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46624.134473] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[46624.142117] ath10k_pci 0000:00:00.0: failed to send wmi nop: -11
[46624.148408] ath10k_pci 0000:00:00.0: removing peer, cleanup-all, deleting: peer ffffffc02978e600 vdev: 0 addr: c8:bc:c8:e0:ff:d7
[46624.160511] ath10k_pci 0000:00:00.0: removing peer, cleanup-all, deleting: peer ffffffc03cfe7000 vdev: 0 addr: ac:bc:32:af:ab:ed
[46624.172478] ath10k_pci 0000:00:00.0: removing peer, cleanup-all, deleting: peer ffffffc03cfe6400 vdev: 0 addr: 04:f0:21:42:1d:d4
[46624.302617] ieee80211 phy0: Hardware restart was requested
[46624.308526] ath10k_pci 0000:00:00.0: failed to set beacon mode for vdev 0: -108
[46624.316115] ath10k_pci 0000:00:00.0: failed to set dtim period for vdev 0: -108
[46625.368712] ath10k_pci 0000:00:00.0: 10.1 wmi init: vdevs: 16 peers: 127 tid: 256
[46625.386483] ath10k_pci 0000:00:00.0: wmi print 'P 128 V 8 T 410'
[46625.392586] ath10k_pci 0000:00:00.0: wmi print 'msdu-desc: 1424 sw-crypt: 0'
[46625.400160] ath10k_pci 0000:00:00.0: wmi print 'alloc rem: 26384 iram: 26852'
[46625.488789] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[46625.500345] ath10k_pci 0000:00:00.0: device successfully recovered
[46626.656291] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[46647.507559] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[46939.314196] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[48491.291331] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[48492.595856] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[49006.652125] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[49362.954379] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[53350.385369] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[54646.980119] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[61168.027743] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61168.161714] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61168.295571] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61168.429479] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61168.563511] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61168.697396] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61168.831405] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61168.851893] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[61168.965262] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61169.099376] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61169.233144] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61169.367240] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61169.501206] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61169.635179] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61169.769210] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61169.903352] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61170.037192] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61170.155487] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[61170.171099] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61170.305055] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61170.439006] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61170.572948] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61170.706780] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61170.840763] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61170.974499] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61171.081415] ath10k_pci 0000:00:00.0: Cannot communicate with firmware, attempting to fake crash and restart firmware.
[61171.092569] ath10k_pci 0000:00:00.0: firmware crashed! (uuid 690a1e4f-102b-4f13-a3e1-8e790ceb10f3)
[61171.101782] ath10k_pci 0000:00:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
[61171.111352] ath10k_pci 0000:00:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
[61171.122338] ath10k_pci 0000:00:00.0: firmware ver 10.1-ct-8x-__fW-021-4fa9f30 api 2 features wmi-10.x,has-wmi-mgmt-tx,txstatus-noack,wmi-10.x-CT,ratemask-CT,regdump-CT,txrate-CT,flush-all-CT,pingpong-CT,ch-regs-CT,nop-CT,set-special-CT,get-temp-CT,tx-rc-CT,cust-stats-CT crc32 ca41d135
[61171.148346] ath10k_pci 0000:00:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[61171.155720] ath10k_pci 0000:00:00.0: htt-ver 2.1 wmi-op 2 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
[61171.167543] ath10k_pci 0000:00:00.0: firmware register dump:
[61171.173068] ath10k_pci 0000:00:00.0: [00]: 0x00940750 0x00400C00 0x00980000 0x009B6198
[61171.181443] ath10k_pci 0000:00:00.0: [04]: 0x009B6208 0x009B632C 0x00941B6C 0x00941B20
[61171.189612] ath10k_pci 0000:00:00.0: [08]: 0x00941B00 0x009423A4 0x009422DC 0x009422C4
[61171.197992] ath10k_pci 0000:00:00.0: [12]: 0x00941B90 0x009423F4 0x009423D4 0x009423DC
[61171.205859] ath10k_pci 0000:00:00.0: [16]: 0x009423E4 0x009423EC 0x00942888 0x00942520
[61171.213950] ath10k_pci 0000:00:00.0: [20]: 0x009424FC 0x0094241C 0x00942540 0x00942498
[61171.222596] ath10k_pci 0000:00:00.0: [24]: 0x00942450 0x0094250C 0x009424D0 0x00942750
[61171.230529] ath10k_pci 0000:00:00.0: [28]: 0x00942798 0x00942844 0x009428C4 0x00942594
[61171.238733] ath10k_pci 0000:00:00.0: [32]: 0x0094258C 0x00942C28 0x00942F4C 0x00942F7C
[61171.247024] ath10k_pci 0000:00:00.0: [36]: 0x00942F90 0x00942FE4 0x00942FF8 0x00943040
[61171.255025] ath10k_pci 0000:00:00.0: [40]: 0x0094077C 0x00940790 0x00943084 0x00942F00
[61171.263317] ath10k_pci 0000:00:00.0: [44]: 0x009B6358 0x00942A80 0x00942D40 0x00942D64
[61171.271495] ath10k_pci 0000:00:00.0: [48]: 0x00942D78 0x00942D9C 0x00957E18 0x00957E28
[61171.279677] ath10k_pci 0000:00:00.0: [52]: 0x00957E20 0x00940788 0x009430EC 0x00000000
[61171.287798] ath10k_pci 0000:00:00.0: [56]: 0x00000000 0x00000000 0x00000000 0x00000000
[61171.296345] ath10k_pci 0000:00:00.0: Copy Engine register dump:
[61171.302320] ath10k_pci 0000:00:00.0: [00]: 0x00057400 3 3 3 3
[61171.309061] ath10k_pci 0000:00:00.0: [01]: 0x00057800 15 15 210 211
[61171.315472] ath10k_pci 0000:00:00.0: [02]: 0x00057c00 39 39 93 103
[61171.322133] ath10k_pci 0000:00:00.0: [03]: 0x00058000 2 2 2 2
[61171.328771] ath10k_pci 0000:00:00.0: [04]: 0x00058400 2359 2359 197 157
[61171.335981] ath10k_pci 0000:00:00.0: [05]: 0x00058800 19 19 229 243
[61171.342326] ath10k_pci 0000:00:00.0: [06]: 0x00058c00 26 26 26 26
[61171.349052] ath10k_pci 0000:00:00.0: [07]: 0x00059000 0 0 0 0
[61171.357933] ath10k_pci 0000:00:00.0: debug log header, dbuf: 0x4125f4 dropped: 0
[61171.366382] ath10k_pci 0000:00:00.0: [0] next: 0x41260c buf: 0x410458 sz: 1500 len: 720 count: 45 free: 0
[61171.377277] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[61171.384972] ath10k_pci 0000:00:00.0: ath10k_pci ATH10K_DBG_BUFFER:
[61171.391021] ath10k: [0000]: 02DD6ED5 0BFC4C20 0000000A 0000000B 02DD6EE9 0BFC4C20 0000000A 0000000B
[61171.400399] ath10k: [0008]: 02DD6EFE 0BFC4C20 0000000A 0000000B 02DD6F12 0BFC4C20 0000000A 0000000B
[61171.410026] ath10k: [0016]: 02DD6F27 0BFC4C20 0000000A 0000000B 02DD6F3B 0BFC4C20 0000000A 0000000B
[61171.419287] ath10k: [0024]: 02DD6F50 0BFC4C20 0000000A 0000000B 02DD6F64 0BFC4C20 0000000A 0000000B
[61171.428747] ath10k: [0032]: 02DD6F79 0BFC4C20 0000000A 0000000B 02DD6F8D 0BFC4C20 0000000A 0000000B
[61171.437920] ath10k: [0040]: 02DD6FA2 0BFC4C20 0000000A 0000000B 02DD6FB6 0BFC4C20 0000000A 0000000B
[61171.447198] ath10k: [0048]: 02DD6FCB 0BFC4C20 0000000A 0000000B 02DD6FDF 0BFC4C20 0000000A 0000000B
[61171.456727] ath10k: [0056]: 02DD6FF4 0BFC4C20 0000000A 0000000B 02DD7008 0BFC4C20 0000000A 0000000B
[61171.466095] ath10k: [0064]: 02DD701D 0BFC4C20 0000000A 0000000B 02DD7031 0BFC4C20 0000000A 0000000B
[61171.475180] ath10k: [0072]: 02DD7046 0BFC4C20 0000000A 0000000B 02DD705A 0BFC4C20 0000000A 0000000B
[61171.484728] ath10k: [0080]: 02DD706F 0BFC4C20 0000000A 0000000B 02DD7083 0BFC4C20 0000000A 0000000B
[61171.494081] ath10k: [0088]: 02DD7098 0BFC4C20 0000000A 0000000B 02DD70AC 0BFC4C20 0000000A 0000000B
[61171.503538] ath10k: [0096]: 02DD70C3 0BFC4C20 0000000A 0000000B 02DD70D7 0BFC4C20 0000000A 0000000B
[61171.512623] ath10k: [0104]: 02DD70EC 0BFC4C20 0000000A 0000000B 02DD7100 0BFC4C20 0000000A 0000000B
[61171.522439] ath10k: [0112]: 02DD7115 0BFC4C20 0000000A 0000000B 02DD7129 0BFC4C20 0000000A 0000000B
[61171.531463] ath10k: [0120]: 02DD713E 0BFC4C20 0000000A 0000000B 02DD7152 0BFC4C20 0000000A 0000000B
[61171.540992] ath10k: [0128]: 02DD7167 0BFC4C20 0000000A 0000000B 02DD717B 0BFC4C20 0000000A 0000000B
[61171.550460] ath10k: [0136]: 02DD7190 0BFC4C20 0000000A 0000000B 02DD71A4 0BFC4C20 0000000A 0000000B
[61171.559824] ath10k: [0144]: 02DD71B9 0BFC4C20 0000000A 0000000B 02DD71CD 0BFC4C20 0000000A 0000000B
[61171.568907] ath10k: [0152]: 02DD71F1 0BFC4C20 0000000A 0000000B 02DD7206 0BFC4C20 0000000A 0000000B
[61171.578366] ath10k: [0160]: 02DD721A 0BFC4C20 0000000A 0000000B 02DD722F 0BFC4C20 0000000A 0000000B
[61171.587632] ath10k: [0168]: 02DD7243 0BFC4C20 0000000A 0000000B 02DD7258 0BFC4C20 0000000A 0000000B
[61171.596999] ath10k: [0176]: 02DD726C 0BFC4C20 0000000A 0000000B
[61171.603023] ath10k_pci 0000:00:00.0: ATH10K_END
[61171.608823] ath10k_pci 0000:00:00.0: [1] next: 0x4125f4 buf: 0x410a48 sz: 1500 len: 80 count: 5 free: 0
[61171.619515] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[61171.626931] ath10k_pci 0000:00:00.0: ath10k_pci ATH10K_DBG_BUFFER:
[61171.633414] ath10k: [0000]: 02DD72D3 0BFC4C20 0000000A 0000000B 02DD72E7 0BFC4C20 0000000A 0000000B
[61171.642944] ath10k: [0008]: 02DD72FC 0BFC4C20 0000000A 0000000B 02DD7310 0BFC4C20 0000000A 0000000B
[61171.652335] ath10k: [0016]: 02DD7325 0BFC4C20 0000000A 0000000B
[61171.658290] ath10k_pci 0000:00:00.0: ATH10K_END
[61171.687578] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61171.695276] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61171.702834] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61171.710460] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[61171.718021] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61171.725792] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61171.734010] ath10k_pci 0000:00:00.0: failed to set beacon mode for vdev 0: -11
[61171.741397] ath10k_pci 0000:00:00.0: failed to set dtim period for vdev 0: -108
[61171.748915] ath10k_pci 0000:00:00.0: failed to send wmi nop: -108
[61171.755051] ath10k_pci 0000:00:00.0: failed to recalculate rts/cts prot for vdev 0: -108
[61171.763640] ath10k_pci 0000:00:00.0: failed to set cts protection for vdev 0: -108
[61171.771122] ath10k_pci 0000:00:00.0: failed to set preamble for vdev 0: -108
[61171.778970] ath10k_pci 0000:00:00.0: removing peer, cleanup-all, deleting: peer ffffffc02978e600 vdev: 0 addr: c8:bc:c8:e0:ff:d7
[61171.791135] ath10k_pci 0000:00:00.0: removing peer, cleanup-all, deleting: peer ffffffc02978fa00 vdev: 0 addr: ac:bc:32:af:ab:ed
[61171.803101] ath10k_pci 0000:00:00.0: removing peer, cleanup-all, deleting: peer ffffffc02978f800 vdev: 0 addr: 04:f0:21:42:1d:d4
[61171.815223] ath10k_pci 0000:00:00.0: SWBA overrun on vdev 0, skipped old beacon
[61171.962892] ieee80211 phy0: Hardware restart was requested
[61173.038633] ath10k_pci 0000:00:00.0: 10.1 wmi init: vdevs: 16 peers: 127 tid: 256
[61173.055792] ath10k_pci 0000:00:00.0: wmi print 'P 128 V 8 T 410'
[61173.062025] ath10k_pci 0000:00:00.0: wmi print 'msdu-desc: 1424 sw-crypt: 0'
[61173.069788] ath10k_pci 0000:00:00.0: wmi print 'alloc rem: 26384 iram: 26852'
[61173.156757] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[61173.168489] ath10k_pci 0000:00:00.0: device successfully recovered
[61174.339501] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[61491.929780] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[61494.543644] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[61495.850602] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[61533.747771] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[61549.434777] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[61550.742024] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[61907.620319] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[68780.363195] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[69127.530703] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[75739.152311] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[76027.746282] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[76256.282383] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[76423.447959] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[76663.728047] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[76772.119865] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[76829.581675] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[77182.222470] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
[78176.335716] ath10k_pci 0000:00:00.0: dropping dbg buffer due to crash since read
root@turris:~#
I am on the Stable branch with this MOX, today after 14+ hours of uptime since the last update:
ath10k_pci 0000:00:00.0: wmi mgmt tx queue is full
ath10k_pci 0000:00:00.0: failed to transmit packet, dropping: -28
ath10k_pci 0000:00:00.0: failed to submit frame: -28
ath10k_pci 0000:00:00.0: failed to transmit frame: -28
it printed these messages over and over for an hour.
after 4.0.1 still unstable
[163447.584525] ath10k_pci 0000:02:00.0: SWBA overrun on vdev 0, skipped old beacon
[163447.646236] ath10k_pci 0000:02:00.0: dropping dbg buffer due to crash since read
[163447.686767] ath10k_pci 0000:02:00.0: SWBA overrun on vdev 0, skipped old beacon
[163447.713142] ath10k_pci 0000:02:00.0: Cannot communicate with firmware, attempting to fake crash and restart firmware.
[163447.724365] ath10k_pci 0000:02:00.0: firmware crashed! (uuid 4b8c71da-af3d-4fae-9150-f792b60b0016)
[163447.733688] ath10k_pci 0000:02:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
[163447.743310] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
[163447.756715] ath10k_pci 0000:02:00.0: firmware ver 10.1-ct-8x-__fW-021-4fa9f30 api 2 features wmi-10.x,has-wmi-mgmt-tx,txstatus-noack,wmi-10.x-CT,ratemask-CT,re
[163447.783152] ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[163447.790818] ath10k_pci 0000:02:00.0: htt-ver 2.1 wmi-op 2 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
[163447.802722] ath10k_pci 0000:02:00.0: firmware register dump:
then there is register dump, can share over email if needed or if someone will fix (openwrt?)
frankly MOX (Turris) would be a cool thing if the wifi modules (the sdio isn’t stable as well) would be 100% working (note that I have a factory default config, just populated SSID and password)
and if kresd would be interchangeable to dnsmasq (if you don’t want to fight kresd configs and weird behavior anymore) I’d say Turris is a cool thing, now it’s just meh :wink:
It’s not just meh for me as my ethernet ports does not work as well. This whole thing is kind of a disaster.
(tickets opened at support, no answer)
ethernet ports work nicely for me (I have super ethernet) and I get full 1G from them,
but then you can get 1G eth switch for a fraction of mox price :wink:
I have same issue with pcie wifi and also something wrong with my ethernet porst?
these messages are repeatedly shown in dmesg
[128771.654590] br-lan: port 2(lan2) entered disabled state
[128774.252208] mv88e6085 d0032004.mdio-mii:02 lan2: Link is Up - 1Gbps/Full - flow control rx/tx
[128774.261486] br-lan: port 2(lan2) entered blocking state
[128774.267093] br-lan: port 2(lan2) entered forwarding state
[145557.446262] mv88e6085 d0032004.mdio-mii:02 lan2: Link is Down
[145557.452713] br-lan: port 2(lan2) entered disabled state
[145559.085634] mv88e6085 d0032004.mdio-mii:02 lan2: Link is Up - 10Mbps/Full - flow control rx/tx
[145559.095101] br-lan: port 2(lan2) entered blocking state
[145559.100737] br-lan: port 2(lan2) entered forwarding state
It’s just not really finished its development yet. I think we have to be patient. Let’s just hope that there not too many hardware bugs and the remaining bugs can be solved in Software (possible, though unfortunately not quite sure).
yeah, I hope it will be finished soon, too.
My wireless is also unstable. It crashed periodically and my wife is already pissed since the old cheapo router for 50€ was more stable than the Mox Turris (for example - 11 crashed in the last 3 days).
root@turris:/tmp/log# grep crashed messages
Dec 15 16:40:13 turris kernel: [162644.124381] ath10k_pci 0000:00:00.0: firmware crashed! (uuid ab1f8a62-5516-43c8-b4b8-a3ee8a788872)
Dec 15 17:58:19 turris kernel: [167329.777693] ath10k_pci 0000:00:00.0: firmware crashed! (uuid 8dfbd101-3a90-4c45-94ab-ef62b9598a28)
Dec 16 16:58:04 turris kernel: [250107.281984] ath10k_pci 0000:00:00.0: firmware crashed! (uuid e910025f-9285-4440-bdf2-9b9b19cb79f5)
Dec 16 18:56:54 turris kernel: [257236.424288] ath10k_pci 0000:00:00.0: firmware crashed! (uuid 555207d0-93a2-430a-bb25-28d592ef71f1)
Dec 17 08:52:30 turris kernel: [307367.664458] ath10k_pci 0000:00:00.0: firmware crashed! (uuid c7ec2834-9a2b-4a98-a5d3-6ec30aad1d30)
Dec 17 10:50:19 turris kernel: [314436.524051] ath10k_pci 0000:00:00.0: firmware crashed! (uuid 082d8019-b945-4ba4-9b61-0cd7136a9eda)
Dec 17 17:22:40 turris kernel: [337975.369248] ath10k_pci 0000:00:00.0: firmware crashed! (uuid c4d5a8d7-1a5b-4930-b84b-3d179e1f247e)
Dec 17 21:45:51 turris kernel: [353764.857118] ath10k_pci 0000:00:00.0: firmware crashed! (uuid 7dbca7e9-ac83-48fe-a28c-9d731cebbe30)
Dec 18 01:21:04 turris kernel: [366675.976630] ath10k_pci 0000:00:00.0: firmware crashed! (uuid 74437236-9e51-456a-a0a5-1979a0c76fbf)
Dec 18 08:51:57 turris kernel: [393726.579796] ath10k_pci 0000:00:00.0: firmware crashed! (uuid 535d5a92-eaab-4b95-8bf1-27722bb695a6)
Dec 18 20:08:55 turris kernel: [434340.713270] ath10k_pci 0000:00:00.0: firmware crashed! (uuid 0a275d8d-663f-4da4-a2aa-3563e491822a)
Please make this a high priority. A wireless router with unstable wireless connection is like a car without an engine.
Turris Version: 4.0.2
Turris OS branch: hbs
Kernel version: 4.14.156
I have the very same problem - turris MOX P-A-B with WLE900VX and TOS HBS v4.0.3 installed.
Today my WiFi failed the first time after a uptime of ca. 8 days:
I generated a log and will send it to tech.support@turris.cz
If this happens again I will try to replace Candela Technologies-drivers/-firmware with normal one.
Do you all experience still the same problem?
How can I check if Management Frame Protection is enabled? And how can I turn it off/on?
Have a look in luci -> wireless-> edit your respective SSID -> choose tab security. There you have a toggle field for enable/disable 802.11w
fwiw I run “stable” with following workaround (or similar, just switch to htt driver):
opkg update
opkg remove ath10k-firmware-qca988x
opkg remove kmod-ath10k
opkg install ath10k-firmware-qca988x-ct-htt
Support answered my email with diagnostics file - they stated that there might be problems with either my network or my wifi-card (which is a WLE900VX borrowed from one of my TO’s).
And it hit me again - this time after ca. 24 days of uptime :face_with_symbols_over_mouth: So now I am switching to plain ath10k stuff - will report again, if it is still not stable…
@Taz: I cannot seem to find ath10k-firmware-qca988x-ct-htt - where did you download it?
it is in MOX repos, so no extra sources
root@mox:~# opkg list | grep htt
ath10k-firmware-qca988x-ct-htt - 2018-05-12-952afa49-1.2
That’s mysterious - it didn’t find it yesterday but now it does. Anyways - thanks :slight_smile:
I’ll stay with plain ath10k and report issues here if any.
