The latest release of Turris OS 5.0.0 finally allows to execute unprivileged LXC containers. While LUCI support would be nice, currently the sole option is the command line on the Turris itself. Let’s get started by setting up an unprivileged container called “test”:
As multiple tutorials [1][2] describe it already, first we need to set up the LXC environment:
# append idmaps to lxc default config
$ echo "lxc.idmap = u 0 100000 65536" >> /etc/lxc/default.conf
$ echo "lxc.idmap = g 0 100000 65536" >> /etc/lxc/default.conf
# set subuid if not present
$ echo "root:100000:65536" > /etc/subuid
# set subgid if not present
$ echo "root:100000:65536" > /etc/subgid
Even if “default” LXC packages are already installed, we still require the ones that enable us to support unprivileged containers:
$ opkg update
$ opkg install lxc-unprivileged
$ opkg install lxc-usernsexec
In theory, everything should be in place now. But issuing lxc-create fails:
$ lxc-create -t download -n test
Setting up the GPG keyring
Downloading the image index
ERROR: Failed to download http://repo.turris.cz/lxc//meta/1.0/index-user
lxc-create: test: lxccontainer.c: create_run_template: 1617 Failed to create container from template
lxc-create: test: tools/lxc_create.c: main: 327 Failed to create container test
Seems to be as if the official Turris repository does not support it yet. Consequently, let us use the repository of images.linuxcontainers.org:
$ lxc-create --quiet \
--name test \
--bdev best \
--template download \
--dist archlinux \
--release current \
--arch armhf \
--server images.linuxcontainers.org \
--no-validate
After the command succeeds, there should be a container without root:root permissions:
$ ls -l /srv/lxc/ | grep test
drwxrwx--- 3 100000 100000 4096 Mar 22 11:47 test
Let us execute it:
$ lxc-start -n test
lxc-start: test: lxccontainer.c: wait_on_daemonized_start: 842 Received container state "ABORTING" instead of "RUNNING"
lxc-start: test: tools/lxc_start.c: main: 330 The container failed to start
lxc-start: test: tools/lxc_start.c: main: 333 To get more details, run the container in foreground mode
lxc-start: test: tools/lxc_start.c: main: 336 Additional information can be obtained by setting the --logfile and --logpriority options
root@turris:/mnt# lxc-start -n test -F
lxc-start: test: utils.c: safe_mount: 1179 Operation not permitted - Failed to mount "proc" onto "/usr/lib/lxc/rootfs/proc"
lxc-start: test: conf.c: lxc_mount_auto_mounts: 724 Operation not permitted - Failed to mount "proc" on "/usr/lib/lxc/rootfs/proc" with flags 14
lxc-start: test: conf.c: lxc_setup: 3539 Failed to setup first automatic mounts
lxc-start: test: start.c: do_start: 1263 Failed to setup container "test"
lxc-start: test: sync.c: __sync_wait: 62 An error occurred in another process (expected sequence number 5)
lxc-start: test: start.c: __lxc_start: 1939 Failed to spawn container "test"
Quite a mess. As mentioned [3], the reason on Turris OS 5.0.0 seems to be:
Failure to mount proc is usually a sign of the kernel’s overmounting protection preventing the mount.
So let us fix it until Turris OS is fixed:
$ mkdir -p /mnt/lxc-unpriv-fix/proc
$ mount -t proc none /mnt/lxc-unpriv-fix/proc
$ mkdir -p /mnt/lxc-unpriv-fix/sys
$ mount -t sysfs none /mnt/lxc-unpriv-fix/sys
Issue left: auto-start
Make above sys/proc issue permanent
$ cat < EOF > cat /etc/rc.local
# Put your custom commands here that should be executed once
# the system init finished. By default this file does nothing.
exit 0
EOF
/etc/init.d/lxc-auto does sadly not function for me, as the container exits after successful creation, any ideas? I suspect the init.d system…
