Hi everybody,
I started to have an issue with one of WLANs on my Turris Omnia (Indiegogo version)
- sometimes if a device connects it gets disconnected immediately, it reconnects, gets disconnected, … After some time the connection succeeds eventually
- sometimes an already connected client just starts disconnecting/reconnecting without any obvious reason
- turning the radio off/on on the client or just connecting to another WLAN and then back to the problematic one helps in most cases
- it happens on 2.4 as well as 5 GHz radios
It’s more or less perfectly reproducible if the client roams over to another AP (OpenWRT 21.2) and then back. Another WLAN with the same config works without any issues. Both WLANs are configured on 2.4 and 5 GHz as well as on the other AP incl 802.11r.
If I face the issue, I can see the following (redacted):
/var/log/messages
2022-04-16T19:57:54+02:00 turris hostapd: wlan1-5: STA XX:XX:XX:XX:XX:XX IEEE 802.11: authentication OK (open system)
2022-04-16T19:57:54+02:00 turris hostapd: wlan1-5: STA XX:XX:XX:XX:XX:XX MLME: MLME-AUTHENTICATE.indication(XX:XX:XX:XX:XX:XX, OPEN_SYSTEM)
2022-04-16T19:57:54+02:00 turris hostapd: wlan1-5: STA XX:XX:XX:XX:XX:XX MLME: MLME-DELETEKEYS.request(XX:XX:XX:XX:XX:XX)
2022-04-16T19:57:54+02:00 turris hostapd: wlan1-5: STA XX:XX:XX:XX:XX:XX IEEE 802.11: authenticated
2022-04-16T19:57:54+02:00 turris hostapd: wlan1-5: STA XX:XX:XX:XX:XX:XX IEEE 802.11: association OK (aid 1)
2022-04-16T19:57:54+02:00 turris hostapd: wlan1-5: STA XX:XX:XX:XX:XX:XX IEEE 802.11: associated (aid 1)
2022-04-16T19:57:54+02:00 turris hostapd: wlan1-5: STA XX:XX:XX:XX:XX:XX MLME: MLME-ASSOCIATE.indication(XX:XX:XX:XX:XX:XX)
2022-04-16T19:57:54+02:00 turris hostapd: wlan1-5: STA XX:XX:XX:XX:XX:XX IEEE 802.11: binding station to interface ‘wlan1-5’
2022-04-16T19:57:54+02:00 turris hostapd: wlan1-5: STA XX:XX:XX:XX:XX:XX WPA: event 1 notification
2022-04-16T19:57:54+02:00 turris hostapd: wlan1-5: STA XX:XX:XX:XX:XX:XX WPA: start authentication
2022-04-16T19:57:54+02:00 turris hostapd: wlan1-5: STA XX:XX:XX:XX:XX:XX IEEE 802.1X: unauthorizing port
2022-04-16T19:57:54+02:00 turris hostapd: wlan1-5: STA XX:XX:XX:XX:XX:XX WPA: sending 1/4 msg of 4-Way Handshake
2022-04-16T19:57:54+02:00 turris hostapd: wlan1-5: STA XX:XX:XX:XX:XX:XX WPA: received EAPOL-Key frame (2/4 Pairwise)
2022-04-16T19:57:54+02:00 turris hostapd: wlan1-5: STA XX:XX:XX:XX:XX:XX WPA: sending 3/4 msg of 4-Way Handshake
2022-04-16T19:57:54+02:00 turris hostapd: wlan1-5: STA XX:XX:XX:XX:XX:XX WPA: received EAPOL-Key frame (4/4 Pairwise)
2022-04-16T19:57:54+02:00 turris hostapd: wlan1-5: AP-STA-CONNECTED XX:XX:XX:XX:XX:XX
2022-04-16T19:57:54+02:00 turris hostapd: wlan1-5: STA XX:XX:XX:XX:XX:XX IEEE 802.1X: authorizing port
2022-04-16T19:57:54+02:00 turris hostapd: wlan1-5: STA XX:XX:XX:XX:XX:XX RADIUS: starting accounting session E3C542565C32124B
2022-04-16T19:57:54+02:00 turris hostapd: wlan1-5: STA XX:XX:XX:XX:XX:XX WPA: pairwise key handshake completed (RSN)
2022-04-16T21:57:54+02:00 turris dnsmasq-dhcp[9039]: DHCPREQUEST(br-lan) xxx.xxx.xxx.xxx XX:XX:XX:XX:XX:XX
2022-04-16T21:57:54+02:00 turris dnsmasq-dhcp[9039]: DHCPACK(br-lan) xxx.xxx.xxx.xxx XX:XX:XX:XX:XX:XX XM9TPro
2022-04-16T19:57:56+02:00 turris hostapd: wlan1-5: AP-STA-DISCONNECTED XX:XX:XX:XX:XX:XX
2022-04-16T19:57:56+02:00 turris hostapd: wlan1-5: STA XX:XX:XX:XX:XX:XX WPA: event 3 notification
2022-04-16T19:57:56+02:00 turris hostapd: wlan1-5: STA XX:XX:XX:XX:XX:XX IEEE 802.1X: unauthorizing port
2022-04-16T19:57:56+02:00 turris hostapd: wlan1-5: STA XX:XX:XX:XX:XX:XX IEEE 802.11: deauthenticated
2022-04-16T19:57:56+02:00 turris hostapd: wlan1-5: STA XX:XX:XX:XX:XX:XX MLME: MLME-DEAUTHENTICATE.indication(XX:XX:XX:XX:XX:XX, 3)
2022-04-16T19:57:56+02:00 turris hostapd: wlan1-5: STA XX:XX:XX:XX:XX:XX MLME: MLME-DELETEKEYS.request(XX:XX:XX:XX:XX:XX)
2022-04-16T19:57:58+02:00 turris hostapd: wlan1-24: STA XX:XX:XX:XX:XX:XX IEEE 802.11: authentication OK (open system)
2022-04-16T19:57:58+02:00 turris hostapd: wlan1-24: STA XX:XX:XX:XX:XX:XX MLME: MLME-AUTHENTICATE.indication(XX:XX:XX:XX:XX:XX, OPEN_SYSTEM)
2022-04-16T19:57:58+02:00 turris hostapd: wlan1-24: STA XX:XX:XX:XX:XX:XX MLME: MLME-DELETEKEYS.request(XX:XX:XX:XX:XX:XX)
2022-04-16T19:57:58+02:00 turris hostapd: wlan1-24: STA XX:XX:XX:XX:XX:XX IEEE 802.11: authenticated
2022-04-16T19:57:58+02:00 turris hostapd: wlan1-24: STA XX:XX:XX:XX:XX:XX IEEE 802.11: association OK (aid 3)
2022-04-16T19:57:58+02:00 turris hostapd: wlan1-24: STA XX:XX:XX:XX:XX:XX IEEE 802.11: associated (aid 3)
2022-04-16T19:57:58+02:00 turris hostapd: wlan1-24: STA XX:XX:XX:XX:XX:XX MLME: MLME-ASSOCIATE.indication(XX:XX:XX:XX:XX:XX)
2022-04-16T19:57:58+02:00 turris hostapd: wlan1-24: STA XX:XX:XX:XX:XX:XX IEEE 802.11: binding station to interface ‘wlan1-24’
2022-04-16T19:57:58+02:00 turris hostapd: wlan1-24: STA XX:XX:XX:XX:XX:XX WPA: event 1 notification
2022-04-16T19:57:58+02:00 turris hostapd: wlan1-24: STA XX:XX:XX:XX:XX:XX WPA: start authentication
2022-04-16T19:57:58+02:00 turris hostapd: wlan1-24: STA XX:XX:XX:XX:XX:XX IEEE 802.1X: unauthorizing port
2022-04-16T19:57:58+02:00 turris hostapd: wlan1-24: STA XX:XX:XX:XX:XX:XX WPA: sending 1/4 msg of 4-Way Handshake
2022-04-16T19:57:58+02:00 turris hostapd: wlan1-24: STA XX:XX:XX:XX:XX:XX WPA: received EAPOL-Key frame (2/4 Pairwise)
2022-04-16T19:57:58+02:00 turris hostapd: wlan1-24: STA XX:XX:XX:XX:XX:XX WPA: sending 3/4 msg of 4-Way Handshake
2022-04-16T19:57:58+02:00 turris hostapd: wlan1-24: STA XX:XX:XX:XX:XX:XX WPA: received EAPOL-Key frame (4/4 Pairwise)
2022-04-16T19:57:58+02:00 turris hostapd: wlan1-24: AP-STA-CONNECTED XX:XX:XX:XX:XX:XX
2022-04-16T19:57:58+02:00 turris hostapd: wlan1-24: STA XX:XX:XX:XX:XX:XX IEEE 802.1X: authorizing port
2022-04-16T19:57:58+02:00 turris hostapd: wlan1-24: STA XX:XX:XX:XX:XX:XX RADIUS: starting accounting session 2C2B2FFE162BC042
2022-04-16T19:57:58+02:00 turris hostapd: wlan1-24: STA XX:XX:XX:XX:XX:XX WPA: pairwise key handshake completed (RSN)
2022-04-16T21:57:58+02:00 turris dnsmasq-dhcp[9039]: DHCPREQUEST(br-lan) xxx.xxx.xxx.xxx XX:XX:XX:XX:XX:XX
2022-04-16T21:57:58+02:00 turris dnsmasq-dhcp[9039]: DHCPACK(br-lan) xxx.xxx.xxx.xxx XX:XX:XX:XX:XX:XX XM9TPro
2022-04-16T19:58:00+02:00 turris hostapd: wlan1-24: AP-STA-DISCONNECTED XX:XX:XX:XX:XX:XX
2022-04-16T19:58:00+02:00 turris hostapd: wlan1-24: STA XX:XX:XX:XX:XX:XX WPA: event 3 notification
2022-04-16T19:58:00+02:00 turris hostapd: wlan1-24: STA XX:XX:XX:XX:XX:XX IEEE 802.1X: unauthorizing port
2022-04-16T19:58:00+02:00 turris hostapd: wlan1-24: STA XX:XX:XX:XX:XX:XX IEEE 802.11: deauthenticated
2022-04-16T19:58:00+02:00 turris hostapd: wlan1-24: STA XX:XX:XX:XX:XX:XX MLME: MLME-DEAUTHENTICATE.indication(XX:XX:XX:XX:XX:XX, 3)
2022-04-16T19:58:00+02:00 turris hostapd: wlan1-24: STA XX:XX:XX:XX:XX:XX MLME: MLME-DELETEKEYS.request(XX:XX:XX:XX:XX:XX)
… over and over again …
iw event
wlan1-5 (phy #0): unknown event 60
wlan1-5: new station XX:XX:XX:XX:XX:XX
wlan1-5: del station XX:XX:XX:XX:XX:XX
wlan1-24 (phy #1): unknown event 60
wlan1-24: new station XX:XX:XX:XX:XX:XX
wlan1-24: del station XX:XX:XX:XX:XX:XX
I also ran a tcpdump and could see the client communicating on the network (ARP, DHCP, (M)DNS, HTTP, ICMP) before it’s connection closed. Just a few KB of data in both directions.
My config of the 2 WLANs (redacted - both SSIDs are just small caps ASCII letters):
/etc/config/wireless
config wifi-device ‘radio0’
option type ‘mac80211’
option channel ‘36’
option hwmode ‘11a’
option macaddr ‘XX:XX:XX:XX:XX:XX’
option country ‘CZ’
option log_level ‘0’
config wifi-iface ‘default_radio0’
option ifname ‘wlan1-5’
option device ‘radio0’
option network ‘lan’
option mode ‘ap’
option ssid ‘XXXXXXXXXXXXX’
option encryption ‘psk2+tkip+aes’
option key ‘XXXXXXXXXXXXX’
option isolate ‘1’
option ieee80211r ‘1’
option ft_over_ds ‘1’
option ft_psk_generate_local ‘1’
option mobility_domain ‘1234’
config wifi-iface ‘guest_radio0’
option ifname ‘wlan2-5’
option mode ‘ap’
option ssid ‘YYYYYYYYYYYYY’
option key ‘YYYYYYYYYYYYY’
option wmm ‘1’
option isolate ‘1’
option mobility_domain ‘5678’
config wifi-device ‘radio1’
option channel ‘11’
option hwmode ‘11g’
option htmode ‘HT20’
option country ‘CZ’
config wifi-iface ‘default_radio1’
option ifname ‘wlan1-24’
option device ‘radio1’
option mode ‘ap’
option wmm ‘1’
option isolate ‘1’
config wifi-iface ‘guest_radio1’
option ifname ‘wlan2-24’
option mode ‘ap’
option wmm ‘1’
option isolate ‘1’
Already tried to (without any success obviously):
- drop 802.11r (and the other router)
- disable radio0 / radio1
- dropped the wireless config and regenerated it from scratch
- use uncle Google of course
Does anyone have any idea what could be causing this issue an/or how to further troubleshoot?
Thanks for any inputs
Tom
