Decided to examine the differences in dmesg
before and after the device has been attached to the router:
- Removed the device
- Rebooted
dmesg >> dmesg.0.txt
- Attached device
dmesg >> dmesg.1.txt
The difference between the files:
@@ -1,4 +1,8 @@
+[ 9.506862] sda: sda1 sda2
+[ 9.510594] sd 2:0:0:0: [sda] Attached SCSI disk
+[ 12.144651] mount_root: mounting /dev/root
+[ 12.264750] BTRFS info (device mmcblk0p1): disk space caching is enabled
+[ 12.271873] mount_root: loading kmods from internal overlay
[ 12.486870] block: attempting to load /etc/config/fstab
[ 12.492991] block: extroot: not configured
[ 12.499559] procd: - early -
@@ -219,6 +223,3 @@
[ 50.004177] mvneta f1034000.ethernet eth1: Link is Down
[ 51.001154] mvneta f1034000.ethernet eth1: Link is Up - 100Mbps/Full - flow control off
[ 61.251281] pppoe-wan: renamed from ppp0
-[ 269.632997] usb 4-1: new high-speed USB device number 2 using xhci-hcd
-[ 269.792763] xhci-hcd f10f8000.usb3: ERROR: unexpected command completion code 0x11.
-[ 269.800500] usb 4-1: can't set config #1, error -22
dmesg.0.txt
[ 12.603541] random: jshn: uninitialized urandom read (4 bytes read, 50 bits of entropy available)
[ 12.631545] random: jshn: uninitialized urandom read (4 bytes read, 50 bits of entropy available)
[ 12.666959] random: jshn: uninitialized urandom read (4 bytes read, 50 bits of entropy available)
[ 12.691350] random: jshn: uninitialized urandom read (4 bytes read, 50 bits of entropy available)
[ 12.726535] random: jshn: uninitialized urandom read (4 bytes read, 50 bits of entropy available)
[ 12.750949] random: jshn: uninitialized urandom read (4 bytes read, 50 bits of entropy available)
[ 12.785953] random: jshn: uninitialized urandom read (4 bytes read, 50 bits of entropy available)
[ 12.810407] random: jshn: uninitialized urandom read (4 bytes read, 50 bits of entropy available)
[ 12.845717] random: jshn: uninitialized urandom read (4 bytes read, 50 bits of entropy available)
[ 13.072615] procd: - watchdog -
[ 13.076092] procd: - ubus -
[ 13.180719] EXT4-fs (sda2): mounting ext3 file system using the ext4 subsystem
[ 13.206824] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts:
[ 14.081483] procd: - init -
[ 14.150002] marvell-cesa f1090000.crypto: CESA device successfully registered
[ 14.162658] NET: Registered protocol family 38
[ 14.179587] md: linear personality registered for level -1
[ 14.185514] md: raid0 personality registered for level 0
[ 14.191774] md: raid1 personality registered for level 1
[ 14.197958] md: raid10 personality registered for level 10
[ 14.203895] async_tx: api initialized (async)
[ 14.211213] md: raid6 personality registered for level 6
[ 14.216540] md: raid5 personality registered for level 5
[ 14.221888] md: raid4 personality registered for level 4
[ 14.229137] FS-Cache: Loaded
[ 14.232556] md: multipath personality registered for level -4
[ 14.239529] NET: Registered protocol family 8
[ 14.243928] NET: Registered protocol family 20
[ 14.252136] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 14.263022] Key type dns_resolver registered
[ 14.270157] NET: Registered protocol family 33
[ 14.274642] Key type rxrpc registered
[ 14.278312] Key type rxrpc_s registered
[ 14.285227] kAFS: Red Hat AFS client v0.1 registering.
[ 14.290417] FS-Cache: Netfs 'afs' registered for caching
[ 14.324581] RPC: Registered named UNIX socket transport module.
[ 14.330519] RPC: Registered udp transport module.
[ 14.335256] RPC: Registered tcp transport module.
[ 14.339969] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 14.350423] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[ 14.360186] RxRPC: Registered security type 2 'rxkad'
[ 14.376796] tun: Universal TUN/TAP device driver, 1.6
[ 14.381895] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 14.392215] sit: IPv6 over IPv4 tunneling driver
[ 14.398964] gre: GRE over IPv4 demultiplexor driver
[ 14.404704] ip_gre: GRE over IPv4 tunneling driver
[ 14.424576] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 14.432857] PPP generic driver version 2.4.2
[ 14.440139] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 14.449850] cryptodev: driver 1.8 loaded.
[ 14.458480] Loading modules backported from Linux version wt-2016-10-03-1-g6fcb1a6
[ 14.466110] Backport generated by backports.git backports-20160324-9-g0e38f5c
[ 14.544436] pci 0000:00:02.0: enabling device (0140 -> 0142)
[ 14.550317] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[ 14.723262] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:02:00.0.bin failed with error -2
[ 14.733997] ath10k_pci 0000:02:00.0: Falling back to user helper
[ 14.743619] firmware ath10k!pre-cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
[ 14.752762] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/cal-pci-0000:02:00.0.bin failed with error -2
[ 14.763149] ath10k_pci 0000:02:00.0: Falling back to user helper
[ 14.772603] firmware ath10k!cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
[ 14.789251] ath10k_pci 0000:02:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
[ 14.798525] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
[ 14.808140] ath10k_pci 0000:02:00.0: firmware ver 10.2.4.70.54 api 5 features no-p2p,raw-mode,mfp crc32 9d340dd9
[ 14.858464] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
[ 14.868933] ath10k_pci 0000:02:00.0: Falling back to user helper
[ 14.878538] firmware ath10k!QCA988X!hw2.0!board-2.bin: firmware_loading_store: map pages failed
[ 14.887494] ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[ 16.029404] ath10k_pci 0000:02:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
[ 16.111782] ath: EEPROM regdomain: 0x0
[ 16.111788] ath: EEPROM indicates default country code should be used
[ 16.111791] ath: doing EEPROM country->regdmn map search
[ 16.111795] ath: country maps to regdmn code: 0x3a
[ 16.111798] ath: Country alpha2 being used: US
[ 16.111800] ath: Regpair used: 0x3a
[ 16.117277] u32 classifier
[ 16.119998] input device check on
[ 16.123685] Actions configured
[ 16.127757] Mirror/redirect action on
[ 16.135499] netem: version 1.3
[ 16.143676] fuse init (API version 7.23)
[ 16.160927] usbcore: registered new interface driver cdc_wdm
[ 16.170137] Ebtables v2.0 registered
[ 16.175208] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 16.187172] nf_conntrack version 0.5.0 (16117 buckets, 64468 max)
[ 16.373957] Netfilter messages via NETLINK v0.30.
[ 16.379492] PPP MPPE Compression module registered
[ 16.384863] NET: Registered protocol family 24
[ 16.392751] usbcore: registered new interface driver ums-alauda
[ 16.399530] usbcore: registered new interface driver ums-cypress
[ 16.406470] usbcore: registered new interface driver ums-datafab
[ 16.413292] usbcore: registered new interface driver ums-freecom
[ 16.420161] usbcore: registered new interface driver ums-isd200
[ 16.427093] usbcore: registered new interface driver ums-jumpshot
[ 16.434045] usbcore: registered new interface driver ums-karma
[ 16.441079] usbcore: registered new interface driver ums-sddr09
[ 16.447903] usbcore: registered new interface driver ums-sddr55
[ 16.454863] usbcore: registered new interface driver ums-usbat
[ 16.466725] usbcore: registered new interface driver usbserial
[ 16.472627] usbcore: registered new interface driver usbserial_generic
[ 16.479194] usbserial: USB Serial support registered for generic
[ 16.493983] xt_time: kernel timezone is -0000
[ 16.512252] usbcore: registered new interface driver cdc_ether
[ 16.522679] ctnetlink v0.93: registering with nfnetlink.
[ 16.531690] usbcore: registered new interface driver qmi_wwan
[ 16.538604] usbcore: registered new interface driver rndis_host
[ 16.552000] pci 0000:00:01.0: enabling device (0140 -> 0142)
[ 16.644527] ath: EEPROM regdomain: 0x0
[ 16.644532] ath: EEPROM indicates default country code should be used
[ 16.644535] ath: doing EEPROM country->regdmn map search
[ 16.644539] ath: country maps to regdmn code: 0x3a
[ 16.644541] ath: Country alpha2 being used: US
[ 16.644544] ath: Regpair used: 0x3a
[ 16.656347] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
[ 16.657697] ieee80211 phy1: Atheros AR9287 Rev:2 mem=0xf1d00000, irq=108
[ 16.666262] usbcore: registered new interface driver option
[ 16.671929] usbserial: USB Serial support registered for GSM modem (1-port)
[ 16.679608] usbcore: registered new interface driver qcserial
[ 16.685422] usbserial: USB Serial support registered for Qualcomm USB modem
[ 24.948615] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 25.032261] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 25.035739] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
[ 25.117929] random: nonblocking pool is initialized
[ 26.673825] device eth0 entered promiscuous mode
[ 26.674779] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[ 26.699815] device eth2 entered promiscuous mode
[ 26.782148] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 27.090255] ath: EEPROM regdomain: 0x80cb
[ 27.090264] ath: EEPROM indicates we should expect a country code
[ 27.090267] ath: doing EEPROM country->regdmn map search
[ 27.090270] ath: country maps to regdmn code: 0x36
[ 27.090273] ath: Country alpha2 being used: CZ
[ 27.090275] ath: Regpair used: 0x36
[ 27.090279] ath: regdomain 0x80cb dynamically updated by user
[ 27.090327] ath: EEPROM regdomain: 0x80cb
[ 27.090330] ath: EEPROM indicates we should expect a country code
[ 27.090333] ath: doing EEPROM country->regdmn map search
[ 27.090335] ath: country maps to regdmn code: 0x36
[ 27.090338] ath: Country alpha2 being used: CZ
[ 27.090340] ath: Regpair used: 0x36
[ 27.090343] ath: regdomain 0x80cb dynamically updated by user
[ 27.093475] ath: EEPROM regdomain: 0x8348
[ 27.093482] ath: EEPROM indicates we should expect a country code
[ 27.093486] ath: doing EEPROM country->regdmn map search
[ 27.093489] ath: country maps to regdmn code: 0x3a
[ 27.093492] ath: Country alpha2 being used: US
[ 27.093494] ath: Regpair used: 0x3a
[ 27.093498] ath: regdomain 0x8348 dynamically updated by user
[ 27.093546] ath: EEPROM regdomain: 0x8348
[ 27.093550] ath: EEPROM indicates we should expect a country code
[ 27.093553] ath: doing EEPROM country->regdmn map search
[ 27.093555] ath: country maps to regdmn code: 0x3a
[ 27.093558] ath: Country alpha2 being used: US
[ 27.093560] ath: Regpair used: 0x3a
[ 27.093562] ath: regdomain 0x8348 dynamically updated by user
[ 28.670589] mvneta f1030000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 29.000582] mvneta f1070000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
[ 29.491439] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 29.491516] br-lan: port 1(eth0) entered forwarding state
[ 29.491543] br-lan: port 1(eth0) entered forwarding state
[ 29.491579] br-lan: port 2(eth2) entered forwarding state
[ 29.491589] br-lan: port 2(eth2) entered forwarding state
[ 29.492042] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[ 29.509520] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
[ 29.510437] device wlan1 entered promiscuous mode
[ 29.510468] br-lan: port 3(wlan1) entered forwarding state
[ 29.510485] br-lan: port 3(wlan1) entered forwarding state
[ 29.510716] ath: EEPROM regdomain: 0x80cb
[ 29.510721] ath: EEPROM indicates we should expect a country code
[ 29.510724] ath: doing EEPROM country->regdmn map search
[ 29.510727] ath: country maps to regdmn code: 0x36
[ 29.510730] ath: Country alpha2 being used: CZ
[ 29.510733] ath: Regpair used: 0x36
[ 29.510736] ath: regdomain 0x80cb dynamically updated by user
[ 29.510777] ath: EEPROM regdomain: 0x80cb
[ 29.510779] ath: EEPROM indicates we should expect a country code
[ 29.510782] ath: doing EEPROM country->regdmn map search
[ 29.510784] ath: country maps to regdmn code: 0x36
[ 29.510787] ath: Country alpha2 being used: CZ
[ 29.510789] ath: Regpair used: 0x36
[ 29.510792] ath: regdomain 0x80cb dynamically updated by user
[ 29.511200] device wlan0 entered promiscuous mode
[ 29.511707] ath: EEPROM regdomain: 0x8348
[ 29.511712] ath: EEPROM indicates we should expect a country code
[ 29.511716] ath: doing EEPROM country->regdmn map search
[ 29.511719] ath: country maps to regdmn code: 0x3a
[ 29.511722] ath: Country alpha2 being used: US
[ 29.511725] ath: Regpair used: 0x3a
[ 29.511728] ath: regdomain 0x8348 dynamically updated by user
[ 29.511771] ath: EEPROM regdomain: 0x8348
[ 29.511774] ath: EEPROM indicates we should expect a country code
[ 29.511777] ath: doing EEPROM country->regdmn map search
[ 29.511780] ath: country maps to regdmn code: 0x3a
[ 29.511783] ath: Country alpha2 being used: US
[ 29.511785] ath: Regpair used: 0x3a
[ 29.511788] ath: regdomain 0x8348 dynamically updated by user
[ 29.575591] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[ 29.868023] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 29.868078] br-lan: port 4(wlan0) entered forwarding state
[ 29.868099] br-lan: port 4(wlan0) entered forwarding state
[ 31.001002] mvneta f1034000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
[ 31.001020] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 31.490567] br-lan: port 2(eth2) entered forwarding state
[ 31.490596] br-lan: port 1(eth0) entered forwarding state
[ 31.500561] br-lan: port 3(wlan1) entered forwarding state
[ 31.860573] br-lan: port 4(wlan0) entered forwarding state
[ 33.004142] mvneta f1034000.ethernet eth1: Link is Down
[ 35.001015] mvneta f1034000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
[ 37.004153] mvneta f1034000.ethernet eth1: Link is Down
[ 39.000998] mvneta f1034000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
[ 41.004157] mvneta f1034000.ethernet eth1: Link is Down
[ 44.001075] mvneta f1034000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
[ 44.435629] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 46.004191] mvneta f1034000.ethernet eth1: Link is Down
[ 48.001013] mvneta f1034000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
dmesg.1.txt
