after upgrade to 7.0.0 the command wg-quick up vpn
stopped working. It says:
[#] ip -6 rule add table main suppress_prefixlength 0
[#] ip6tables-restore -n
Warning: Extension CONNMARK revision 0 not supported, missing kernel module?
Warning: Extension CONNMARK is not supported, missing kernel module?
ip6tables-restore: line 7 failed
[#] resolvconf -d vpn -f
Looks like this one is missing?
$ zcat /proc/config.gz | grep CONFIG_NETFILTER_XT_MATCH_CONNMARK
# CONFIG_NETFILTER_XT_MATCH_CONNMARK is not set
And maybe this one?
$ zcat /proc/config.gz | grep CONFIG_NET_VRF
# CONFIG_NET_VRF is not set
Kernel version is 5.15.148, Tue Apr 2 01:04:13 2024
