For those who haven’t gotten it yet, changelog. Also includes kernel update 4.4.59+4-1-627f0117679bc72ef5e58881035f567a-4
• logrotate: fix default configuration
• openvpn: update to the newer version
• mdadm: fix mail notifications
• curl: fix CVE-2017-7407
• bird: fix user creation
• kernel: fix CVE-2017-7184
• ntpd: update to the latest version
• knot-resolver: update to the latest version
Looks like the OpenVPN service, previously enabled and managed through the Turris normal web UI, didn’t start after this update.
/etc/init.d/openvpn start and then an /etc/init.d/openvpn enable worked and got it surviving a reboot.
(But I’d only enabled OpenVPN after the previous kernel update and hadn’t rebooted, so I can’t swear that the initial download and run had enabled it to start after reboots).
A word of notice: if you have certificate revocation lists with improper expiration dates, openVPN will now refuse to start (behavioral change in 2.4).
turris omnia router still does not boot back up with wifi (say after this update) , i have to reboot the turris a 2nd time in order for it to come back online. any fixes for that?
Do you use SSL/TLS and authentication when send mail to the smtp/relay server?
If I try to send non-authenticated I will get an error message in foris. When I send with auth I get an ok in foris but error in the log and no email.
And I’m using the same config I’ve used since start.
I also selup an account with the same information in my email program and sent it perfectly to my ISPs relay over SSL/TLS but via notifier it seems to only generate an error.
Anyone know is it is possible to get verbose logging for the notifier email progress?
