I installed the Turris Shield recently. There is a red LED blinking at the front side (next to the USB ports) The red colour in combination with blinking may indicate some sort of problem. But this may be just a bad design decision.
I can’t find any details on this. Any ideas?
Thank you
The red LED heartbeat blinking indicates normal status (probably without any problems)
