We just released a Turris OS 7.1.1 to the hbt testing branch! It contains a few fixes for Turris OS 7.1.0. Namely, it reinstalls libevent2 as it is rumored to help on Turris 1.x with unbound. We also made json parsing more robust in Turris Webapps (initial landing page on your router). There is also a little bit of extra polishing of LibreSpeed plugin in reForis. Take a look
Hopefully, it will just help to fix a few issues people encountered in 7.1.0, we are working on more, but wanted to release those few ASAP.
If you run into something new, please let us know, otherwise, we will release this on Monday.
MOX classic, HBK branch, .5 GB, 2x WiFi, simple config. All seems OK.
There was small qlitch: clicking on āAdvanced administrationā in reForis to go to LuCI displayed status info only without any menu of LuCIā¦ only after forcing previous LuCI panel from history (Mozilla Firefox) LuCI menu was shownā¦
The Luci thing happens when youāre not logged in. I think some plugins install pages which do not require authentication, and Luci decides that it has something to show you without login, so it does. But it forgets to display the login button.
Thanks for explanation - such possibility didnāt come to my mind
Anyhow, Firefox āsharesā login info - i.e. I can for example open another Google aplication (Calendar) when Iām logged into Mailā¦ probably, Chrome behave another way
This is a Turris-specific behavior. They have one login for reforis, pakon amd other services, and Luci might be affected (but it has a separate password, so maybe not).
7.1.0ā 7.1.1 RC1 update okay. No noticeable cable/wifi/internet interruption. Restart was not needed.
DNS worked for me before and it still works.
I havenāt noticed any spurious DHCP option on LAN interface as somebody mentioned.
Turris Omnia 2017, 1 GB RAM, dead eMMC, system running from mSATA SSD, original wifi cards, UBoot 2022.10. Storage plugin enabled, LXC containers, tor relay, USB HDD shared over samba4 and minidlna, Syncthing, SQM, Hardwario gateway + MQTT IoT bridge, OpenVPN, PPtP VPN, Strongswan IKEv2 VPN, morce.
I did not get the MCU upgrade notification this timeā¦
