Turris OS 7.0 is out!
@ssdnvv Yup. The packages changed name convention. You have to delete jool-tools kmod-jool and install new packages with the name jool-netfilter something
opkg update > /dev/null && opkg list | grep jool | awk '{print $1;}' on TOS 7.0 to figure out new names
But does it matter?
the kernel is already newer than the one in openwrt 23.05 and the turris does get security updates, or not?
Well V is right in that case EOL means no upstream updates. So no security updates as well. But Turris team is known to backport important stuff sometimes from newer openwrt releases. And sometimes I see @Pepe pushing stuff downstream for Turris even he doesnt have to to that. Maybe some sentimentšŸ˜‰
+1 on the issue with transmission. Current 22.03 is on transmission 4.03.5. Supposedly 4.04 should fix this. Details in MR here: Use a map container to store peers in `tr_swarm` by tearfur Ā· Pull Request #5645 Ā· transmission/transmission Ā· GitHub
New 4.04 is already on 23.05 branch, should be easy enough to backport this, as @Pepe already took care of pushing the 4.04 version: transmission: update to 4.0.4 Ā· openwrt/packages@2dd9b92 Ā· GitHub
Should be worth a try, @miska
Looks like I am set for an automatic update to Turris 7.0, however, I keep getting the following error:
Updater execution failed:
INFO:Target Turris OS: 7.0.0
line not found
line not found
line not found
line not found
line not found
ERROR:
inconsistent: Requested package luci-i18n-vpn-policy-routing-en that is not available.
@willcycle If you actually want to spend time reading I recommend this:
I tried running your suggested command to install luci-app-pbr luci-i18n-pbr-en --nodeps. This is the response I get and it still won’t update,
/$ opkg install luci-app-pbr luci-i18n-pbr-en --nodeps
Package luci-app-pbr (1.1.1-7) installed in root is up to date.
Package luci-i18n-pbr-en (git-24.080.71914-adc7330) installed in root is up to date.
The error also occurs for me!
Is there already a solution?
Try uninstalling the problematic package. You already installed an alternative, but the old one still stinks around…
The solution may be in post 97 :wink:
I tried uninstalling ā€˜luci-i18n-vpnbypass-en’ in an effort to get past the error but no joy. The router keeps trying to update every few hours with this error:
line not found
line not found
line not found
line not found
line not found
ERROR:
I’ll have to turn off automatic updates until this issue gets resolved.
but
Something not right here :slight_smile:
Agreed. I confirmed the package was gone. I am thinking there might be some config file where it’s still listed but have no idea what I could check.
/etc/updater/conf.d/opkg-auto.lua is usually the place to look
Turris team doesn’t usually update packages.
And because they write it on the wiki, no other security vulnerabilities have been introduced. Especially if that was the intention from the start, right?
Turris 1.1 - just for info
  1. Auto updated from latest stable 6.x version to 7.0 few days ago, but I think that router didn“t restarted at all
  2. Few days later I noticed that Foris, Luci, SSH, Samba shares are not working, but WLANs and LANs are ok and DHCP server running.
  3. Yesterday I disconnected power plug, but now is router dead. LEDs are blinking, but no LAN and WLAN at all, no IPs from DHCP
I have new Omnia 2020 here for replacement so I finally decided to setup it from scratch. Now I have some troubles here:
  1. Connection wizard went smooth - enabled updates and confirmed them in Foris
  2. One hour later, no restart performed after update, so I restarted manually.
  3. After restart is Omnia in boot loop
  4. Factory reset
  5. I disabled updates
  6. I connected with SSH and tried pkgupdate, but there are errors.
  7. After restart Omnia ends in boot loop and is dead like my Turris 1.1
Is possible to update OMNIA from 4.0.1 with latest medkit via reset mode 4? Will I brick OMNIA? What else can i do?
root@turris:~# pkgupdate
WARN:There's no extra option condition for a install
INFO:Queue install of libgcc/core/11.2.0-4
INFO:Queue install of libc/core/1.2.3-4
INFO:Queue install of ca-certificates/base/20230311-1
INFO:Queue install of base64c/turrispackages/0.2.1-4
INFO:Queue install of libopenssl/base/1.1.1w-1
INFO:Queue install of libexpat/packages/2.5.0-1
INFO:Queue install of libbz2/base/1.0.8-1
INFO:Queue install of libpthread/core/1.2.3-4
INFO:Queue install of liblzma/packages/5.4.1-1
INFO:Queue install of zlib/base/1.2.11-6
INFO:Queue install of libarchive/packages/3.5.3-3
INFO:Queue install of liburiparser/turrispackages/0.9.7-2
INFO:Queue install of ca-bundle/base/20230311-1
INFO:Queue install of libnghttp2/packages/1.44.0-1
INFO:Queue install of libcurl/packages/8.6.0-1
INFO:Queue install of libevent2/base/2.1.12-1
INFO:Queue install of liblua/base/5.1.5-10
INFO:Queue install of libubox/base/2022-05-15-d2223ef9-1
INFO:Queue install of libuci/base/2021-10-22-f84f49f0-6
INFO:Queue install of libuci-lua/base/2021-10-22-f84f49f0-6
INFO:Queue install of updater-ng/turrispackages/70.2.0-2
Press return to continue, CTRL+C to abort
INFO:Downloading packages
INFO:Executing preupdate hook: 05_schnapps.sh
Snapshot number 22 created
INFO:Unpacking download packages
INFO:Checking for file collisions between packages
INFO:Running pre-install and pre-rm scripts and merging packages to root file system
WARN:Config file /etc/config/updater modified by the user. Backing up the new one into /etc/config/updater-opkg
INFO:Removing packages and leftover files
INFO:Running post-install and post-rm scripts
INFO:Running postinst of libgcc
INFO:Running postinst of libc
INFO:Running postinst of ca-certificates
INFO:Running postinst of base64c
INFO:Running postinst of libopenssl
INFO:Running postinst of libexpat
INFO:Running postinst of libbz2
INFO:Running postinst of libpthread
INFO:Running postinst of liblzma
INFO:Running postinst of zlib
INFO:Running postinst of libarchive
INFO:Running postinst of liburiparser
INFO:Running postinst of ca-bundle
INFO:Running postinst of libnghttp2
INFO:Running postinst of libcurl
INFO:Running postinst of libevent2
INFO:Running postinst of liblua
INFO:Running postinst of libubox
INFO:Running postinst of libuci
INFO:Running postinst of libuci-lua
INFO:Running postinst of updater-ng
INFO:Cleaning up control files
Error loading shared library libssl.so.1.0.0: No such file or directory (needed by /usr/bin/openssl)
Error loading shared library libcrypto.so.1.0.0: No such file or directory (needed by /usr/bin/openssl)
Error relocating /usr/bin/openssl: TS_REQ_set_version: symbol not found
Error relocating /usr/bin/openssl: X509_subject_name_hash_old: symbol not found
Error relocating /usr/bin/openssl: ASN1_ENUMERATED_set: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_client_CA_list: symbol not found
Error relocating /usr/bin/openssl: EVP_DecryptFinal_ex: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_copy_parameters: symbol not found
Error relocating /usr/bin/openssl: sk_shift: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_CTX_init: symbol not found
Error relocating /usr/bin/openssl: NETSCAPE_SPKI_set_pubkey: symbol not found
Error relocating /usr/bin/openssl: i2b_PrivateKey_bio: symbol not found
Error relocating /usr/bin/openssl: SSL_export_keying_material: symbol not found
Error relocating /usr/bin/openssl: X509_LOOKUP_file: symbol not found
Error relocating /usr/bin/openssl: ASN1_TIME_print: symbol not found
Error relocating /usr/bin/openssl: SSL_state: symbol not found
Error relocating /usr/bin/openssl: EVP_PBE_find: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_CTX_new: symbol not found
Error relocating /usr/bin/openssl: SHA256: symbol not found
Error relocating /usr/bin/openssl: b2i_PrivateKey_bio: symbol not found
Error relocating /usr/bin/openssl: ASN1_STRING_length: symbol not found
Error relocating /usr/bin/openssl: X509_CRL_get_ext_d2i: symbol not found
Error relocating /usr/bin/openssl: CMS_uncompress: symbol not found
Error relocating /usr/bin/openssl: lh_free: symbol not found
Error relocating /usr/bin/openssl: EC_GROUP_set_asn1_flag: symbol not found
Error relocating /usr/bin/openssl: X509_gmtime_adj: symbol not found
Error relocating /usr/bin/openssl: SSL_get_error: symbol not found
Error relocating /usr/bin/openssl: DSA_sign: symbol not found
Error relocating /usr/bin/openssl: CRYPTO_strdup: symbol not found
Error relocating /usr/bin/openssl: X509_POLICY_NODE_print: symbol not found
Error relocating /usr/bin/openssl: BIO_f_md: symbol not found
Error relocating /usr/bin/openssl: SSL_get_fd: symbol not found
Error relocating /usr/bin/openssl: BN_dec2bn: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_encrypt_init: symbol not found
Error relocating /usr/bin/openssl: ASN1_TYPE_new: symbol not found
Error relocating /usr/bin/openssl: RAND_status: symbol not found
Error relocating /usr/bin/openssl: EC_GROUP_get_cofactor: symbol not found
Error relocating /usr/bin/openssl: BIO_f_zlib: symbol not found
Error relocating /usr/bin/openssl: PEM_read_bio_X509_CRL: symbol not found
Error relocating /usr/bin/openssl: BIO_set_callback: symbol not found
Error relocating /usr/bin/openssl: X509_REQ_print_ex: symbol not found
Error relocating /usr/bin/openssl: SSL_check_chain: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_base_id: symbol not found
Error relocating /usr/bin/openssl: OCSP_RESPONSE_print: symbol not found
Error relocating /usr/bin/openssl: ASN1_TYPE_get: symbol not found
Error relocating /usr/bin/openssl: ECDSA_sign: symbol not found
Error relocating /usr/bin/openssl: X509_REVOKED_set_revocationDate: symbol not found
Error relocating /usr/bin/openssl: OCSP_REQUEST_free: symbol not found
Error relocating /usr/bin/openssl: X509_add1_trust_object: symbol not found
Error relocating /usr/bin/openssl: RSA_print: symbol not found
Error relocating /usr/bin/openssl: PKCS12_free: symbol not found
Error relocating /usr/bin/openssl: i2a_ASN1_OBJECT: symbol not found
Error relocating /usr/bin/openssl: TXT_DB_create_index: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_srp_strength: symbol not found
Error relocating /usr/bin/openssl: X509_NAME_print_ex_fp: symbol not found
Error relocating /usr/bin/openssl: BIO_new_fp: symbol not found
Error relocating /usr/bin/openssl: SSL_set_srp_server_param: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set1_param: symbol not found
Error relocating /usr/bin/openssl: ENGINE_free: symbol not found
Error relocating /usr/bin/openssl: DES_crypt: symbol not found
Error relocating /usr/bin/openssl: CRYPTO_free: symbol not found
Error relocating /usr/bin/openssl: SRP_create_verifier: symbol not found
Error relocating /usr/bin/openssl: X509_VERIFY_PARAM_set_purpose: symbol not found
Error relocating /usr/bin/openssl: OBJ_txt2nid: symbol not found
Error relocating /usr/bin/openssl: SRP_check_known_gN_param: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_paramgen: symbol not found
Error relocating /usr/bin/openssl: OBJ_txt2obj: symbol not found
Error relocating /usr/bin/openssl: BN_hex2bn: symbol not found
Error relocating /usr/bin/openssl: X509_NAME_add_entry: symbol not found
Error relocating /usr/bin/openssl: X509_REQ_get_pubkey: symbol not found
Error relocating /usr/bin/openssl: RAND_seed: symbol not found
Error relocating /usr/bin/openssl: sk_pop_free: symbol not found
Error relocating /usr/bin/openssl: CMS_get1_certs: symbol not found
Error relocating /usr/bin/openssl: EC_GROUP_set_point_conversion_form: symbol not found
Error relocating /usr/bin/openssl: NETSCAPE_SPKI_sign: symbol not found
Error relocating /usr/bin/openssl: TS_REQ_free: symbol not found
Error relocating /usr/bin/openssl: TS_MSG_IMPRINT_new: symbol not found
Error relocating /usr/bin/openssl: CMS_decrypt: symbol not found
Error relocating /usr/bin/openssl: X509_get0_pubkey_bitstr: symbol not found
Error relocating /usr/bin/openssl: X509_cmp_time: symbol not found
Error relocating /usr/bin/openssl: X509_check_host: symbol not found
Error relocating /usr/bin/openssl: ASN1_item_unpack: symbol not found
Error relocating /usr/bin/openssl: EVP_MD_size: symbol not found
Error relocating /usr/bin/openssl: UI_process: symbol not found
Error relocating /usr/bin/openssl: TS_RESP_set_status_info: symbol not found
Error relocating /usr/bin/openssl: CONF_modules_load: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_keygen: symbol not found
Error relocating /usr/bin/openssl: OBJ_sn2nid: symbol not found
Error relocating /usr/bin/openssl: i2d_X509_NAME: symbol not found
Error relocating /usr/bin/openssl: OCSP_request_sign: symbol not found
Error relocating /usr/bin/openssl: PKCS7_verify: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_CTX_get0_parent_ctx: symbol not found
Error relocating /usr/bin/openssl: SSL_SESSION_get0_peer: symbol not found
Error relocating /usr/bin/openssl: BUF_MEM_grow: symbol not found
Error relocating /usr/bin/openssl: OCSP_copy_nonce: symbol not found
Error relocating /usr/bin/openssl: DES_ede3_cbc_encrypt: symbol not found
Error relocating /usr/bin/openssl: SRP_VBASE_init: symbol not found
Error relocating /usr/bin/openssl: d2i_PrivateKey_bio: symbol not found
Error relocating /usr/bin/openssl: RAND_load_file: symbol not found
Error relocating /usr/bin/openssl: CMS_add1_ReceiptRequest: symbol not found
Error relocating /usr/bin/openssl: OBJ_obj2nid: symbol not found
Error relocating /usr/bin/openssl: lh_retrieve: symbol not found
Error relocating /usr/bin/openssl: sk_free: symbol not found
Error relocating /usr/bin/openssl: SSL_write: symbol not found
Error relocating /usr/bin/openssl: ERR_peek_last_error: symbol not found
Error relocating /usr/bin/openssl: BN_set_word: symbol not found
Error relocating /usr/bin/openssl: UI_ctrl: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_info_callback: symbol not found
Error relocating /usr/bin/openssl: CMS_get1_ReceiptRequest: symbol not found
Error relocating /usr/bin/openssl: RSA_public_encrypt: symbol not found
Error relocating /usr/bin/openssl: SMIME_read_PKCS7: symbol not found
Error relocating /usr/bin/openssl: X509_CRL_diff: symbol not found
Error relocating /usr/bin/openssl: SSL_COMP_get_name: symbol not found
Error relocating /usr/bin/openssl: EC_POINT_point2bn: symbol not found
Error relocating /usr/bin/openssl: UI_new_method: symbol not found
Error relocating /usr/bin/openssl: SSL_certs_clear: symbol not found
Error relocating /usr/bin/openssl: RSA_check_key: symbol not found
Error relocating /usr/bin/openssl: ENGINE_set_default: symbol not found
Error relocating /usr/bin/openssl: OCSP_REQ_CTX_add1_header: symbol not found
Error relocating /usr/bin/openssl: X509_alias_get0: symbol not found
Error relocating /usr/bin/openssl: d2i_X509_REQ_bio: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_ECPKParameters: symbol not found
Error relocating /usr/bin/openssl: EC_GROUP_free: symbol not found
Error relocating /usr/bin/openssl: b2i_PublicKey_bio: symbol not found
Error relocating /usr/bin/openssl: SSL_CONF_CTX_finish: symbol not found
Error relocating /usr/bin/openssl: DH_generate_parameters_ex: symbol not found
Error relocating /usr/bin/openssl: PKCS12_set_mac: symbol not found
Error relocating /usr/bin/openssl: i2d_X509: symbol not found
Error relocating /usr/bin/openssl: ASN1_d2i_bio: symbol not found
Error relocating /usr/bin/openssl: PKCS12_get_attr_gen: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_new_mac_key: symbol not found
Error relocating /usr/bin/openssl: X509_get_ext_by_OBJ: symbol not found
Error relocating /usr/bin/openssl: SSLv23_client_method: symbol not found
Error relocating /usr/bin/openssl: ERR_peek_error: symbol not found
Error relocating /usr/bin/openssl: ERR_remove_thread_state: symbol not found
Error relocating /usr/bin/openssl: EVP_CIPHER_nid: symbol not found
Error relocating /usr/bin/openssl: SSL_set_msg_callback: symbol not found
Error relocating /usr/bin/openssl: sk_value: symbol not found
Error relocating /usr/bin/openssl: RC2_cbc_encrypt: symbol not found
Error relocating /usr/bin/openssl: CRYPTO_set_mem_functions: symbol not found
Error relocating /usr/bin/openssl: PKCS7_decrypt: symbol not found
Error relocating /usr/bin/openssl: NETSCAPE_SPKI_b64_encode: symbol not found
Error relocating /usr/bin/openssl: OCSP_CERTID_free: symbol not found
Error relocating /usr/bin/openssl: NCONF_new: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_X509_REQ_NEW: symbol not found
Error relocating /usr/bin/openssl: X509_add1_reject_object: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_get1_DSA: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_psk_client_callback: symbol not found
Error relocating /usr/bin/openssl: SSL_get_selected_srtp_profile: symbol not found
Error relocating /usr/bin/openssl: X509_CRL_print: symbol not found
Error relocating /usr/bin/openssl: SSL_get_srp_g: symbol not found
Error relocating /usr/bin/openssl: CRYPTO_malloc: symbol not found
Error relocating /usr/bin/openssl: SSL_free: symbol not found
Error relocating /usr/bin/openssl: X509_VERIFY_PARAM_new: symbol not found
Error relocating /usr/bin/openssl: OCSP_BASICRESP_free: symbol not found
Error relocating /usr/bin/openssl: ERR_print_errors: symbol not found
Error relocating /usr/bin/openssl: BIO_new_fd: symbol not found
Error relocating /usr/bin/openssl: X509_REQ_get_extensions: symbol not found
Error relocating /usr/bin/openssl: EVP_md5: symbol not found
Error relocating /usr/bin/openssl: SSLv23_server_method: symbol not found
Error relocating /usr/bin/openssl: OCSP_request_add0_id: symbol not found
Error relocating /usr/bin/openssl: X509_PURPOSE_get_count: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_load_locations: symbol not found
Error relocating /usr/bin/openssl: EVP_DigestFinal_ex: symbol not found
Error relocating /usr/bin/openssl: i2d_RSA_PUBKEY_bio: symbol not found
Error relocating /usr/bin/openssl: SSL_get_SSL_CTX: symbol not found
Error relocating /usr/bin/openssl: BIO_new_accept: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_tmp_rsa_callback: symbol not found
Error relocating /usr/bin/openssl: X509_NAME_entry_count: symbol not found
Error relocating /usr/bin/openssl: NETSCAPE_SPKI_free: symbol not found
Error relocating /usr/bin/openssl: X509_delete_ext: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_add_lookup: symbol not found
Error relocating /usr/bin/openssl: OCSP_REQUEST_print: symbol not found
Error relocating /usr/bin/openssl: ENGINE_init: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_use_psk_identity_hint: symbol not found
Error relocating /usr/bin/openssl: PKCS7_new: symbol not found
Error relocating /usr/bin/openssl: X509_PURPOSE_get_id: symbol not found
Error relocating /usr/bin/openssl: UI_method_set_reader: symbol not found
Error relocating /usr/bin/openssl: RAND_egd: symbol not found
Error relocating /usr/bin/openssl: EVP_BytesToKey: symbol not found
Error relocating /usr/bin/openssl: X509_CRL_http_nbio: symbol not found
Error relocating /usr/bin/openssl: OCSP_response_status: symbol not found
Error relocating /usr/bin/openssl: TXT_DB_insert: symbol not found
Error relocating /usr/bin/openssl: CRYPTO_cleanup_all_ex_data: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_srp_cb_arg: symbol not found
Error relocating /usr/bin/openssl: DSA_new: symbol not found
Error relocating /usr/bin/openssl: ENGINE_cleanup: symbol not found
Error relocating /usr/bin/openssl: BN_new: symbol not found
Error relocating /usr/bin/openssl: RSA_generate_key_ex: symbol not found
Error relocating /usr/bin/openssl: RSA_size: symbol not found
Error relocating /usr/bin/openssl: CMS_ContentInfo_print_ctx: symbol not found
Error relocating /usr/bin/openssl: s2i_ASN1_INTEGER: symbol not found
Error relocating /usr/bin/openssl: X509_PURPOSE_get0_name: symbol not found
Error relocating /usr/bin/openssl: CAST_cbc_encrypt: symbol not found
Error relocating /usr/bin/openssl: PEM_read_bio_CMS: symbol not found
Error relocating /usr/bin/openssl: CONF_free: symbol not found
Error relocating /usr/bin/openssl: X509_NAME_add_entry_by_NID: symbol not found
Error relocating /usr/bin/openssl: X509_CRL_set_lastUpdate: symbol not found
Error relocating /usr/bin/openssl: TS_REQ_print_bio: symbol not found
Error relocating /usr/bin/openssl: ASN1_UTCTIME_free: symbol not found
Error relocating /usr/bin/openssl: OCSP_check_nonce: symbol not found
Error relocating /usr/bin/openssl: UI_add_verify_string: symbol not found
Error relocating /usr/bin/openssl: d2i_RSAPublicKey_bio: symbol not found
Error relocating /usr/bin/openssl: OCSP_id_get0_info: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_RSAPublicKey: symbol not found
Error relocating /usr/bin/openssl: X509_issuer_name_hash: symbol not found
Error relocating /usr/bin/openssl: CMS_RecipientInfo_type: symbol not found
Error relocating /usr/bin/openssl: PKCS12_create: symbol not found
Error relocating /usr/bin/openssl: EVP_aes_256_cbc: symbol not found
Error relocating /usr/bin/openssl: RC4_options: symbol not found
Error relocating /usr/bin/openssl: SRP_VBASE_get1_by_user: symbol not found
Error relocating /usr/bin/openssl: PKCS7_add_certificate: symbol not found
Error relocating /usr/bin/openssl: X509_set_version: symbol not found
Error relocating /usr/bin/openssl: SMIME_read_CMS: symbol not found
Error relocating /usr/bin/openssl: CMS_data_create: symbol not found
Error relocating /usr/bin/openssl: DSA_print: symbol not found
Error relocating /usr/bin/openssl: PKCS12_certbag2x509: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_srp_username_callback: symbol not found
Error relocating /usr/bin/openssl: BN_is_prime_ex: symbol not found
Error relocating /usr/bin/openssl: X509_VERIFY_PARAM_set_time: symbol not found
Error relocating /usr/bin/openssl: X509_NAME_ENTRY_get_data: symbol not found
Error relocating /usr/bin/openssl: X509_subject_name_hash: symbol not found
Error relocating /usr/bin/openssl: NETSCAPE_CERT_SEQUENCE_new: symbol not found
Error relocating /usr/bin/openssl: X509_VERIFY_PARAM_add0_policy: symbol not found
Error relocating /usr/bin/openssl: BN_bn2dec: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_PKCS8: symbol not found
Error relocating /usr/bin/openssl: SSL_SESSION_set1_id_context: symbol not found
Error relocating /usr/bin/openssl: BIO_push: symbol not found
Error relocating /usr/bin/openssl: PKCS8_decrypt: symbol not found
Error relocating /usr/bin/openssl: EVP_rc2_40_cbc: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_callback_ctrl: symbol not found
Error relocating /usr/bin/openssl: TS_CONF_set_clock_precision_digits: symbol not found
Error relocating /usr/bin/openssl: SSL_set_session_id_context: symbol not found
Error relocating /usr/bin/openssl: OBJ_nid2obj: symbol not found
Error relocating /usr/bin/openssl: EVP_aes_192_cbc: symbol not found
Error relocating /usr/bin/openssl: SSL_CIPHER_get_id: symbol not found
Error relocating /usr/bin/openssl: SSL_select_next_proto: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_verify: symbol not found
Error relocating /usr/bin/openssl: SSL_get_cipher_list: symbol not found
Error relocating /usr/bin/openssl: X509_CRL_digest: symbol not found
Error relocating /usr/bin/openssl: X509_set_serialNumber: symbol not found
Error relocating /usr/bin/openssl: EC_KEY_get0_public_key: symbol not found
Error relocating /usr/bin/openssl: CMS_add0_recipient_password: symbol not found
Error relocating /usr/bin/openssl: SSL_CIPHER_description: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_CTX_cleanup: symbol not found
Error relocating /usr/bin/openssl: TS_RESP_create_response: symbol not found
Error relocating /usr/bin/openssl: SRP_user_pwd_free: symbol not found
Error relocating /usr/bin/openssl: ENGINE_get_name: symbol not found
Error relocating /usr/bin/openssl: SSL_clear: symbol not found
Error relocating /usr/bin/openssl: X509_NAME_oneline: symbol not found
Error relocating /usr/bin/openssl: BIO_f_nbio_test: symbol not found
Error relocating /usr/bin/openssl: d2i_X509_bio: symbol not found
Error relocating /usr/bin/openssl: AES_set_encrypt_key: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_CTX_get_explicit_policy: symbol not found
Error relocating /usr/bin/openssl: SSL_callback_ctrl: symbol not found
Error relocating /usr/bin/openssl: CMS_verify: symbol not found
Error relocating /usr/bin/openssl: X509_ALGOR_new: symbol not found
Error relocating /usr/bin/openssl: BN_num_bits: symbol not found
Error relocating /usr/bin/openssl: NCONF_load_bio: symbol not found
Error relocating /usr/bin/openssl: UI_create_method: symbol not found
Error relocating /usr/bin/openssl: X509_check_ip_asc: symbol not found
Error relocating /usr/bin/openssl: ENGINE_ctrl_cmd: symbol not found
Error relocating /usr/bin/openssl: TS_VERIFY_CTX_new: symbol not found
Error relocating /usr/bin/openssl: UI_free: symbol not found
Error relocating /usr/bin/openssl: BIO_read: symbol not found
Error relocating /usr/bin/openssl: X509_get_ext: symbol not found
Error relocating /usr/bin/openssl: TS_TST_INFO_free: symbol not found
Error relocating /usr/bin/openssl: SSL_CONF_CTX_set_flags: symbol not found
Error relocating /usr/bin/openssl: X509_reject_clear: symbol not found
Error relocating /usr/bin/openssl: OpenSSLDie: symbol not found
Error relocating /usr/bin/openssl: SSL_SESSION_print: symbol not found
Error relocating /usr/bin/openssl: DTLSv1_2_server_method: symbol not found
Error relocating /usr/bin/openssl: PBE2PARAM_free: symbol not found
Error relocating /usr/bin/openssl: RSA_new_method: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_quiet_shutdown: symbol not found
Error relocating /usr/bin/openssl: BUF_MEM_new: symbol not found
Error relocating /usr/bin/openssl: NCONF_get_number_e: symbol not found
Error relocating /usr/bin/openssl: i2d_PKCS12_bio: symbol not found
Error relocating /usr/bin/openssl: PKCS7_sign_add_signer: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_tlsext_use_srtp: symbol not found
Error relocating /usr/bin/openssl: CMS_verify_receipt: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_print_public: symbol not found
Error relocating /usr/bin/openssl: ASN1_INTEGER_new: symbol not found
Error relocating /usr/bin/openssl: OBJ_nid2sn: symbol not found
Error relocating /usr/bin/openssl: X509_get1_ocsp: symbol not found
Error relocating /usr/bin/openssl: CMS_decrypt_set1_password: symbol not found
Error relocating /usr/bin/openssl: EVP_sha1: symbol not found
Error relocating /usr/bin/openssl: X509V3_parse_list: symbol not found
Error relocating /usr/bin/openssl: d2i_CMS_bio: symbol not found
Error relocating /usr/bin/openssl: X509_VERIFY_PARAM_set1_host: symbol not found
Error relocating /usr/bin/openssl: TS_REQ_set_policy_id: symbol not found
Error relocating /usr/bin/openssl: OPENSSL_load_builtin_modules: symbol not found
Error relocating /usr/bin/openssl: PEM_read_bio_ECPKParameters: symbol not found
Error relocating /usr/bin/openssl: X509_CRL_set_version: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_next_proto_select_cb: symbol not found
Error relocating /usr/bin/openssl: X509_REQ_new: symbol not found
Error relocating /usr/bin/openssl: BIO_f_base64: symbol not found
Error relocating /usr/bin/openssl: TS_RESP_CTX_free: symbol not found
Error relocating /usr/bin/openssl: CRYPTO_gcm128_release: symbol not found
Error relocating /usr/bin/openssl: RC4: symbol not found
Error relocating /usr/bin/openssl: ENGINE_ctrl_cmd_string: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_asn1_find_str: symbol not found
Error relocating /usr/bin/openssl: X509V3_EXT_add_nconf: symbol not found
Error relocating /usr/bin/openssl: BN_bin2bn: symbol not found
Error relocating /usr/bin/openssl: RAND_bytes: symbol not found
Error relocating /usr/bin/openssl: RSA_free: symbol not found
Error relocating /usr/bin/openssl: UI_method_get_reader: symbol not found
Error relocating /usr/bin/openssl: d2i_X509_CRL_bio: symbol not found
Error relocating /usr/bin/openssl: i2d_RSA_NET: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_CTX_new: symbol not found
Error relocating /usr/bin/openssl: X509_get_ext_count: symbol not found
Error relocating /usr/bin/openssl: SSL_get_shared_sigalgs: symbol not found
Error relocating /usr/bin/openssl: ASN1_STRING_data: symbol not found
Error relocating /usr/bin/openssl: PKCS7_sign: symbol not found
Error relocating /usr/bin/openssl: OCSP_REQ_CTX_free: symbol not found
Error relocating /usr/bin/openssl: SSL_set_shutdown: symbol not found
Error relocating /usr/bin/openssl: X509_get_subject_name: symbol not found
Error relocating /usr/bin/openssl: EVP_des_ede3_wrap: symbol not found
Error relocating /usr/bin/openssl: BIO_printf: symbol not found
Error relocating /usr/bin/openssl: BN_generate_prime_ex: symbol not found
Error relocating /usr/bin/openssl: d2i_PKCS8_bio: symbol not found
Error relocating /usr/bin/openssl: PEM_read_bio_PUBKEY: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_free: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_print_private: symbol not found
Error relocating /usr/bin/openssl: X509_SIG_free: symbol not found
Error relocating /usr/bin/openssl: ENGINE_get_digests: symbol not found
Error relocating /usr/bin/openssl: SSL_get_peer_cert_chain: symbol not found
Error relocating /usr/bin/openssl: X509_get_issuer_name: symbol not found
Error relocating /usr/bin/openssl: EC_GROUP_get_curve_GFp: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_DSAparams: symbol not found
Error relocating /usr/bin/openssl: SSL_SESSION_get_id: symbol not found
Error relocating /usr/bin/openssl: X509_NAME_delete_entry: symbol not found
Error relocating /usr/bin/openssl: EVP_aes_256_wrap: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_decrypt: symbol not found
Error relocating /usr/bin/openssl: i2d_SSL_SESSION: symbol not found
Error relocating /usr/bin/openssl: SSL_has_matching_session_id: symbol not found
Error relocating /usr/bin/openssl: BIO_dump: symbol not found
Error relocating /usr/bin/openssl: X509_REVOKED_set_serialNumber: symbol not found
Error relocating /usr/bin/openssl: X509_REQ_add1_attr_by_txt: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_session_id_context: symbol not found
Error relocating /usr/bin/openssl: EVP_MD_do_all_sorted: symbol not found
Error relocating /usr/bin/openssl: ERR_reason_error_string: symbol not found
Error relocating /usr/bin/openssl: EVP_aes_192_wrap: symbol not found
Error relocating /usr/bin/openssl: DTLS_client_method: symbol not found
Error relocating /usr/bin/openssl: SRP_VBASE_new: symbol not found
Error relocating /usr/bin/openssl: TS_REQ_set_nonce: symbol not found
Error relocating /usr/bin/openssl: EVP_DigestInit: symbol not found
Error relocating /usr/bin/openssl: SSL_get_version: symbol not found
Error relocating /usr/bin/openssl: X509_keyid_set1: symbol not found
Error relocating /usr/bin/openssl: TS_CONF_set_tsa_name: symbol not found
Error relocating /usr/bin/openssl: NCONF_get_string: symbol not found
Error relocating /usr/bin/openssl: CMS_ReceiptRequest_free: symbol not found
Error relocating /usr/bin/openssl: EVP_Cipher: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_get1_EC_KEY: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_add_client_custom_ext: symbol not found
Error relocating /usr/bin/openssl: i2d_PKCS8_bio: symbol not found
Error relocating /usr/bin/openssl: TS_RESP_CTX_set_status_info: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_CTX_get0_policy_tree: symbol not found
Error relocating /usr/bin/openssl: X509_CRL_add1_ext_i2d: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_CTX_get_keygen_info: symbol not found
Error relocating /usr/bin/openssl: EVP_aes_128_wrap: symbol not found
Error relocating /usr/bin/openssl: BIO_new_ssl: symbol not found
Error relocating /usr/bin/openssl: SSL_use_certificate: symbol not found
Error relocating /usr/bin/openssl: X509_REQ_set_version: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_CTX_get_app_data: symbol not found
Error relocating /usr/bin/openssl: ASN1_TYPE_free: symbol not found
Error relocating /usr/bin/openssl: BF_set_key: symbol not found
Error relocating /usr/bin/openssl: i2d_RSAPrivateKey_bio: symbol not found
Error relocating /usr/bin/openssl: HMAC_CTX_init: symbol not found
Error relocating /usr/bin/openssl: HMAC_CTX_cleanup: symbol not found
Error relocating /usr/bin/openssl: sk_push: symbol not found
Error relocating /usr/bin/openssl: SSL_set_SSL_CTX: symbol not found
Error relocating /usr/bin/openssl: sk_new_null: symbol not found
Error relocating /usr/bin/openssl: BIO_number_written: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_get_by_subject: symbol not found
Error relocating /usr/bin/openssl: OCSP_id_issuer_cmp: symbol not found
Error relocating /usr/bin/openssl: BN_CTX_free: symbol not found
Error relocating /usr/bin/openssl: X509_NAME_hash: symbol not found
Error relocating /usr/bin/openssl: EC_GROUP_get_order: symbol not found
Error relocating /usr/bin/openssl: OCSP_cert_to_id: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_RSA_PUBKEY: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_asn1_get0: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_CTX_free: symbol not found
Error relocating /usr/bin/openssl: X509_set_issuer_name: symbol not found
Error relocating /usr/bin/openssl: TS_VERIFY_CTX_free: symbol not found
Error relocating /usr/bin/openssl: X509_PURPOSE_get0: symbol not found
Error relocating /usr/bin/openssl: d2i_TS_REQ_bio: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_sess_set_new_cb: symbol not found
Error relocating /usr/bin/openssl: CONF_modules_unload: symbol not found
Error relocating /usr/bin/openssl: OCSP_resp_find_status: symbol not found
Error relocating /usr/bin/openssl: ENGINE_get_ciphers: symbol not found
Error relocating /usr/bin/openssl: PEM_read_bio_DSAparams: symbol not found
Error relocating /usr/bin/openssl: SSL_get_wbio: symbol not found
Error relocating /usr/bin/openssl: i2b_PublicKey_bio: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_verify_recover: symbol not found
Error relocating /usr/bin/openssl: PKCS12_parse: symbol not found
Error relocating /usr/bin/openssl: CMS_digest_verify: symbol not found
Error relocating /usr/bin/openssl: X509_LOOKUP_ctrl: symbol not found
Error relocating /usr/bin/openssl: X509_CRL_free: symbol not found
Error relocating /usr/bin/openssl: UI_destroy_method: symbol not found
Error relocating /usr/bin/openssl: i2d_ECPrivateKey_bio: symbol not found
Error relocating /usr/bin/openssl: d2i_PKCS12_bio: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_cookie_verify_cb: symbol not found
Error relocating /usr/bin/openssl: ASN1_INTEGER_to_BN: symbol not found
Error relocating /usr/bin/openssl: DES_ncbc_encrypt: symbol not found
Error relocating /usr/bin/openssl: RAND_write_file: symbol not found
Error relocating /usr/bin/openssl: i2d_PKCS8_PRIV_KEY_INFO_bio: symbol not found
Error relocating /usr/bin/openssl: CMS_add1_signer: symbol not found
Error relocating /usr/bin/openssl: BN_add_word: symbol not found
Error relocating /usr/bin/openssl: OPENSSL_cleanse: symbol not found
Error relocating /usr/bin/openssl: DSA_free: symbol not found
Error relocating /usr/bin/openssl: X509_get_default_cert_area: symbol not found
Error relocating /usr/bin/openssl: SSL_library_init: symbol not found
Error relocating /usr/bin/openssl: d2i_RSAPrivateKey: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_CTX_set_cert: symbol not found
Error relocating /usr/bin/openssl: d2i_OCSP_RESPONSE: symbol not found
Error relocating /usr/bin/openssl: ASN1_GENERALIZEDTIME_print: symbol not found
Error relocating /usr/bin/openssl: EVP_CIPHER_CTX_init: symbol not found
Error relocating /usr/bin/openssl: PEM_read_bio_PKCS7: symbol not found
Error relocating /usr/bin/openssl: EVP_DigestVerifyInit: symbol not found
Error relocating /usr/bin/openssl: BIO_new_socket: symbol not found
Error relocating /usr/bin/openssl: EVP_DigestSignInit: symbol not found
Error relocating /usr/bin/openssl: ENGINE_get_DH: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_add1_attr_by_NID: symbol not found
Error relocating /usr/bin/openssl: BIO_s_null: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_srp_username: symbol not found
Error relocating /usr/bin/openssl: BIO_f_ssl: symbol not found
Error relocating /usr/bin/openssl: SSL_get_client_CA_list: symbol not found
Error relocating /usr/bin/openssl: UI_method_set_closer: symbol not found
Error relocating /usr/bin/openssl: SSL_read: symbol not found
Error relocating /usr/bin/openssl: X509_VERIFY_PARAM_set_depth: symbol not found
Error relocating /usr/bin/openssl: i2d_TS_REQ_bio: symbol not found
Error relocating /usr/bin/openssl: X509_verify_cert_error_string: symbol not found
Error relocating /usr/bin/openssl: X509_NAME_ENTRY_get_object: symbol not found
Error relocating /usr/bin/openssl: BIO_set_callback_arg: symbol not found
Error relocating /usr/bin/openssl: SSL_SESSION_free: symbol not found
Error relocating /usr/bin/openssl: EVP_DigestInit_ex: symbol not found
Error relocating /usr/bin/openssl: ASN1_TIME_set_string: symbol not found
Error relocating /usr/bin/openssl: ERR_error_string_n: symbol not found
Error relocating /usr/bin/openssl: i2d_ASN1_TYPE: symbol not found
Error relocating /usr/bin/openssl: OCSP_cert_id_new: symbol not found
Error relocating /usr/bin/openssl: OCSP_REQ_CTX_new: symbol not found
Error relocating /usr/bin/openssl: GENERAL_NAME_free: symbol not found
Error relocating /usr/bin/openssl: PEM_read_bio_EC_PUBKEY: symbol not found
Error relocating /usr/bin/openssl: X509_PURPOSE_get0_sname: symbol not found
Error relocating /usr/bin/openssl: PBEPARAM_free: symbol not found
Error relocating /usr/bin/openssl: BIO_s_connect: symbol not found
Error relocating /usr/bin/openssl: HMAC_Update: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_CTX_get_current_cert: symbol not found
Error relocating /usr/bin/openssl: CMS_EncryptedData_decrypt: symbol not found
Error relocating /usr/bin/openssl: SSL_get_current_cipher: symbol not found
Error relocating /usr/bin/openssl: PEM_read_bio_DHparams: symbol not found
Error relocating /usr/bin/openssl: X509_CRL_set_nextUpdate: symbol not found
Error relocating /usr/bin/openssl: PKCS12_unpack_p7encdata: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_next_protos_advertised_cb: symbol not found
Error relocating /usr/bin/openssl: d2i_PKCS7_bio: symbol not found
Error relocating /usr/bin/openssl: X509_get_serialNumber: symbol not found
Error relocating /usr/bin/openssl: ENGINE_get_RSA: symbol not found
Error relocating /usr/bin/openssl: DH_new: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_ctrl: symbol not found
Error relocating /usr/bin/openssl: EVP_CIPHER_iv_length: symbol not found
Error relocating /usr/bin/openssl: ASN1_TIME_diff: symbol not found
Error relocating /usr/bin/openssl: NETSCAPE_SPKI_verify: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_derive_init: symbol not found
Error relocating /usr/bin/openssl: SSL_new: symbol not found
Error relocating /usr/bin/openssl: EC_GROUP_set_seed: symbol not found
Error relocating /usr/bin/openssl: i2d_X509_REQ_bio: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_PKCS7_stream: symbol not found
Error relocating /usr/bin/openssl: EC_curve_nist2nid: symbol not found
Error relocating /usr/bin/openssl: SSL_version: symbol not found
Error relocating /usr/bin/openssl: ASN1_STRING_cmp: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_CTX_set_flags: symbol not found
Error relocating /usr/bin/openssl: X509_verify: symbol not found
Error relocating /usr/bin/openssl: BN_free: symbol not found
Error relocating /usr/bin/openssl: X509_policy_tree_get0_policies: symbol not found
Error relocating /usr/bin/openssl: AES_cbc_encrypt: symbol not found
Error relocating /usr/bin/openssl: EC_KEY_generate_key: symbol not found
Error relocating /usr/bin/openssl: X509V3_add_value: symbol not found
Error relocating /usr/bin/openssl: NETSCAPE_X509_free: symbol not found
Error relocating /usr/bin/openssl: BIO_socket_ioctl: symbol not found
Error relocating /usr/bin/openssl: OPENSSL_add_all_algorithms_noconf: symbol not found
Error relocating /usr/bin/openssl: ASN1_INTEGER_set: symbol not found
Error relocating /usr/bin/openssl: ASN1_UNIVERSALSTRING_to_string: symbol not found
Error relocating /usr/bin/openssl: CONF_load: symbol not found
Error relocating /usr/bin/openssl: TS_RESP_print_bio: symbol not found
Error relocating /usr/bin/openssl: CAST_set_key: symbol not found
Error relocating /usr/bin/openssl: SSL_set_connect_state: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_use_certificate_file: symbol not found
Error relocating /usr/bin/openssl: X509_ocspid_print: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_CTX_get_error: symbol not found
Error relocating /usr/bin/openssl: BIO_f_buffer: symbol not found
Error relocating /usr/bin/openssl: OCSP_basic_add1_status: symbol not found
Error relocating /usr/bin/openssl: lh_node_stats_bio: symbol not found
Error relocating /usr/bin/openssl: ENGINE_get_pkey_asn1_meth_str: symbol not found
Error relocating /usr/bin/openssl: SSL_shutdown: symbol not found
Error relocating /usr/bin/openssl: BIO_set_flags: symbol not found
Error relocating /usr/bin/openssl: X509_sign_ctx: symbol not found
Error relocating /usr/bin/openssl: ASN1_UTCTIME_set_string: symbol not found
Error relocating /usr/bin/openssl: ASN1_ENUMERATED_free: symbol not found
Error relocating /usr/bin/openssl: OBJ_create_objects: symbol not found
Error relocating /usr/bin/openssl: EC_GROUP_new_by_curve_name: symbol not found
Error relocating /usr/bin/openssl: EC_GROUP_check: symbol not found
Error relocating /usr/bin/openssl: SSL_COMP_free_compression_methods: symbol not found
Error relocating /usr/bin/openssl: OCSP_crl_reason_str: symbol not found
Error relocating /usr/bin/openssl: OBJ_cleanup: symbol not found
Error relocating /usr/bin/openssl: X509_EXTENSION_get_object: symbol not found
Error relocating /usr/bin/openssl: X509_INFO_free: symbol not found
Error relocating /usr/bin/openssl: AES_ige_encrypt: symbol not found
Error relocating /usr/bin/openssl: PEM_read_bio_SSL_SESSION: symbol not found
Error relocating /usr/bin/openssl: BIO_pop: symbol not found
Error relocating /usr/bin/openssl: OCSP_sendreq_new: symbol not found
Error relocating /usr/bin/openssl: X509_REQ_check_private_key: symbol not found
Error relocating /usr/bin/openssl: TS_CONF_set_certs: symbol not found
Error relocating /usr/bin/openssl: OCSP_basic_verify: symbol not found
Error relocating /usr/bin/openssl: TLSv1_1_client_method: symbol not found
Error relocating /usr/bin/openssl: SSL_state_string_long: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_CTX_set_app_data: symbol not found
Error relocating /usr/bin/openssl: X509_policy_tree_get0_user_policies: symbol not found
Error relocating /usr/bin/openssl: OCSP_request_onereq_count: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_CTX_ctrl: symbol not found
Error relocating /usr/bin/openssl: EVP_EncryptUpdate: symbol not found
Error relocating /usr/bin/openssl: SSL_set_debug: symbol not found
Error relocating /usr/bin/openssl: CRYPTO_gcm128_setiv: symbol not found
Error relocating /usr/bin/openssl: DTLSv1_client_method: symbol not found
Error relocating /usr/bin/openssl: EC_GROUP_get_point_conversion_form: symbol not found
Error relocating /usr/bin/openssl: DTLSv1_server_method: symbol not found
Error relocating /usr/bin/openssl: EVP_cleanup: symbol not found
Error relocating /usr/bin/openssl: SMIME_write_CMS: symbol not found
Error relocating /usr/bin/openssl: TXT_DB_read: symbol not found
Error relocating /usr/bin/openssl: X509_print_ex: symbol not found
Error relocating /usr/bin/openssl: EVP_DigestSignFinal: symbol not found
Error relocating /usr/bin/openssl: ERR_clear_error: symbol not found
Error relocating /usr/bin/openssl: RSA_PKCS1_SSLeay: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_verify: symbol not found
Error relocating /usr/bin/openssl: TS_CONF_get_tsa_section: symbol not found
Error relocating /usr/bin/openssl: PKCS12_verify_mac: symbol not found
Error relocating /usr/bin/openssl: GENERAL_NAMES_free: symbol not found
Error relocating /usr/bin/openssl: i2d_TS_RESP_bio: symbol not found
Error relocating /usr/bin/openssl: X509_verify_cert: symbol not found
Error relocating /usr/bin/openssl: X509_get_pubkey: symbol not found
Error relocating /usr/bin/openssl: ENGINE_register_all_complete: symbol not found
Error relocating /usr/bin/openssl: X509_trust_clear: symbol not found
Error relocating /usr/bin/openssl: BN_bn2hex: symbol not found
Error relocating /usr/bin/openssl: BN_rshift1: symbol not found
Error relocating /usr/bin/openssl: CMS_EncryptedData_encrypt: symbol not found
Error relocating /usr/bin/openssl: CONF_get_section: symbol not found
Error relocating /usr/bin/openssl: CRYPTO_gcm128_new: symbol not found
Error relocating /usr/bin/openssl: SSLeay: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_X509: symbol not found
Error relocating /usr/bin/openssl: SSL_get_sigalgs: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_CTX_new_id: symbol not found
Error relocating /usr/bin/openssl: BN_mod_exp: symbol not found
Error relocating /usr/bin/openssl: d2i_EC_PUBKEY_bio: symbol not found
Error relocating /usr/bin/openssl: X509_LOOKUP_hash_dir: symbol not found
Error relocating /usr/bin/openssl: PEM_read_bio_ECPrivateKey: symbol not found
Error relocating /usr/bin/openssl: ERR_free_strings: symbol not found
Error relocating /usr/bin/openssl: PKCS7_encrypt: symbol not found
Error relocating /usr/bin/openssl: i2d_EC_PUBKEY_bio: symbol not found
Error relocating /usr/bin/openssl: OCSP_basic_sign: symbol not found
Error relocating /usr/bin/openssl: DHparams_print: symbol not found
Error relocating /usr/bin/openssl: i2d_PKCS7_bio_stream: symbol not found
Error relocating /usr/bin/openssl: d2i_PUBKEY_bio: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_derive: symbol not found
Error relocating /usr/bin/openssl: BN_CTX_new: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_print_params: symbol not found
Error relocating /usr/bin/openssl: UI_construct_prompt: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_X509_AUX: symbol not found
Error relocating /usr/bin/openssl: ENGINE_ctrl: symbol not found
Error relocating /usr/bin/openssl: PKCS7_final: symbol not found
Error relocating /usr/bin/openssl: ASN1_tag2str: symbol not found
Error relocating /usr/bin/openssl: OCSP_response_create: symbol not found
Error relocating /usr/bin/openssl: BUF_memdup: symbol not found
Error relocating /usr/bin/openssl: OCSP_parse_url: symbol not found
Error relocating /usr/bin/openssl: SSL_CONF_cmd: symbol not found
Error relocating /usr/bin/openssl: BIO_number_read: symbol not found
Error relocating /usr/bin/openssl: NCONF_get_section: symbol not found
Error relocating /usr/bin/openssl: i2d_X509_CRL_bio: symbol not found
Error relocating /usr/bin/openssl: DH_free: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_set_default_paths: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_free: symbol not found
Error relocating /usr/bin/openssl: UI_method_get_closer: symbol not found
Error relocating /usr/bin/openssl: EVP_DigestUpdate: symbol not found
Error relocating /usr/bin/openssl: BIO_sock_should_retry: symbol not found
Error relocating /usr/bin/openssl: OCSP_SINGLERESP_add1_ext_i2d: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_save_parameters: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_sess_set_remove_cb: symbol not found
Error relocating /usr/bin/openssl: ENGINE_get_RAND: symbol not found
Error relocating /usr/bin/openssl: PKCS7_free: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_cert_cb: symbol not found
Error relocating /usr/bin/openssl: CMS_RecipientInfo_kari_get0_ctx: symbol not found
Error relocating /usr/bin/openssl: BN_pseudo_rand: symbol not found
Error relocating /usr/bin/openssl: OCSP_response_status_str: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_default_verify_paths: symbol not found
Error relocating /usr/bin/openssl: PEM_read_bio_X509_REQ: symbol not found
Error relocating /usr/bin/openssl: lh_new: symbol not found
Error relocating /usr/bin/openssl: OCSP_RESPONSE_free: symbol not found
Error relocating /usr/bin/openssl: X509_CRL_sort: symbol not found
Error relocating /usr/bin/openssl: EC_KEY_get0_group: symbol not found
Error relocating /usr/bin/openssl: SSL_accept: symbol not found
Error relocating /usr/bin/openssl: CMS_sign: symbol not found
Error relocating /usr/bin/openssl: BIO_test_flags: symbol not found
Error relocating /usr/bin/openssl: SSL_renegotiate: symbol not found
Error relocating /usr/bin/openssl: i2d_DSAPrivateKey_bio: symbol not found
Error relocating /usr/bin/openssl: SSL_get0_alpn_selected: symbol not found
Error relocating /usr/bin/openssl: X509_ALGOR_free: symbol not found
Error relocating /usr/bin/openssl: SSL_CONF_cmd_argv: symbol not found
Error relocating /usr/bin/openssl: i2d_X509_bio: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_new: symbol not found
Error relocating /usr/bin/openssl: PEM_read_bio_X509_AUX: symbol not found
Error relocating /usr/bin/openssl: ASN1_INTEGER_get: symbol not found
Error relocating /usr/bin/openssl: HMAC: symbol not found
Error relocating /usr/bin/openssl: PEM_read_bio_PKCS8_PRIV_KEY_INFO: symbol not found
Error relocating /usr/bin/openssl: UI_add_input_string: symbol not found
Error relocating /usr/bin/openssl: BN_print: symbol not found
Error relocating /usr/bin/openssl: EVP_MD_CTX_set_flags: symbol not found
Error relocating /usr/bin/openssl: X509_VERIFY_PARAM_set_flags: symbol not found
Error relocating /usr/bin/openssl: TS_RESP_new: symbol not found
Error relocating /usr/bin/openssl: d2i_RSA_NET: symbol not found
Error relocating /usr/bin/openssl: EVP_CIPHER_CTX_set_padding: symbol not found
Error relocating /usr/bin/openssl: TLSv1_client_method: symbol not found
Error relocating /usr/bin/openssl: TS_MSG_IMPRINT_set_msg: symbol not found
Error relocating /usr/bin/openssl: X509_NAME_new: symbol not found
Error relocating /usr/bin/openssl: X509V3_set_nconf: symbol not found
Error relocating /usr/bin/openssl: RSA_public_decrypt: symbol not found
Error relocating /usr/bin/openssl: X509_VERIFY_PARAM_set1_ip_asc: symbol not found
Error relocating /usr/bin/openssl: EVP_read_pw_string: symbol not found
Error relocating /usr/bin/openssl: SSL_set_accept_state: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_get1_RSA: symbol not found
Error relocating /usr/bin/openssl: X509_NAME_add_entry_by_txt: symbol not found
Error relocating /usr/bin/openssl: BUF_strlcpy: symbol not found
Error relocating /usr/bin/openssl: EVP_get_digestbyname: symbol not found
Error relocating /usr/bin/openssl: EC_KEY_precompute_mult: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_CMS_stream: symbol not found
Error relocating /usr/bin/openssl: X509_time_adj_ex: symbol not found
Error relocating /usr/bin/openssl: TS_REQ_set_msg_imprint: symbol not found
Error relocating /usr/bin/openssl: ASN1_parse_dump: symbol not found
Error relocating /usr/bin/openssl: EC_KEY_set_asn1_flag: symbol not found
Error relocating /usr/bin/openssl: AES_options: symbol not found
Error relocating /usr/bin/openssl: EVP_MD_type: symbol not found
Error relocating /usr/bin/openssl: UI_OpenSSL: symbol not found
Error relocating /usr/bin/openssl: ENGINE_get_DSA: symbol not found
Error relocating /usr/bin/openssl: NCONF_load: symbol not found
Error relocating /usr/bin/openssl: ENGINE_get_next: symbol not found
Error relocating /usr/bin/openssl: SSL_get_peer_certificate: symbol not found
Error relocating /usr/bin/openssl: BN_options: symbol not found
Error relocating /usr/bin/openssl: PKCS12_decrypt_skey: symbol not found
Error relocating /usr/bin/openssl: OBJ_NAME_do_all_sorted: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_paramgen_init: symbol not found
Error relocating /usr/bin/openssl: X509_NAME_get_entry: symbol not found
Error relocating /usr/bin/openssl: DSA_generate_parameters_ex: symbol not found
Error relocating /usr/bin/openssl: SSL_get_certificate: symbol not found
Error relocating /usr/bin/openssl: TXT_DB_write: symbol not found
Error relocating /usr/bin/openssl: BIO_get_retry_reason: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_PKCS8_PRIV_KEY_INFO: symbol not found
Error relocating /usr/bin/openssl: PEM_read_bio_NETSCAPE_CERT_SEQUENCE: symbol not found
Error relocating /usr/bin/openssl: BIO_new_connect: symbol not found
Error relocating /usr/bin/openssl: TS_RESP_free: symbol not found
Error relocating /usr/bin/openssl: BUF_MEM_free: symbol not found
Error relocating /usr/bin/openssl: BIO_new: symbol not found
Error relocating /usr/bin/openssl: RSA_verify: symbol not found
Error relocating /usr/bin/openssl: BIO_ctrl: symbol not found
Error relocating /usr/bin/openssl: ECPKParameters_print: symbol not found
Error relocating /usr/bin/openssl: OBJ_nid2ln: symbol not found
Error relocating /usr/bin/openssl: RAND_cleanup: symbol not found
Error relocating /usr/bin/openssl: X509_CRL_add0_revoked: symbol not found
Error relocating /usr/bin/openssl: TS_MSG_IMPRINT_set_algo: symbol not found
Error relocating /usr/bin/openssl: BF_cbc_encrypt: symbol not found
Error relocating /usr/bin/openssl: BIO_free: symbol not found
Error relocating /usr/bin/openssl: SRP_get_default_gN: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_load_verify_locations: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_asn1_find: symbol not found
Error relocating /usr/bin/openssl: EVP_md4: symbol not found
Error relocating /usr/bin/openssl: OCSP_cert_status_str: symbol not found
Error relocating /usr/bin/openssl: COMP_zlib_cleanup: symbol not found
Error relocating /usr/bin/openssl: EC_GROUP_method_of: symbol not found
Error relocating /usr/bin/openssl: CMS_compress: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_cookie_generate_cb: symbol not found
Error relocating /usr/bin/openssl: TLSv1_2_server_method: symbol not found
Error relocating /usr/bin/openssl: b2i_PVK_bio: symbol not found
Error relocating /usr/bin/openssl: EC_METHOD_get_field_type: symbol not found
Error relocating /usr/bin/openssl: SSL_get_shared_ciphers: symbol not found
Error relocating /usr/bin/openssl: X509_get_ext_d2i: symbol not found
Error relocating /usr/bin/openssl: X509_to_X509_REQ: symbol not found
Error relocating /usr/bin/openssl: OCSP_BASICRESP_new: symbol not found
Error relocating /usr/bin/openssl: EVP_DecryptInit_ex: symbol not found
Error relocating /usr/bin/openssl: RAND_pseudo_bytes: symbol not found
Error relocating /usr/bin/openssl: OCSP_sendreq_nbio: symbol not found
Error relocating /usr/bin/openssl: RC4_set_key: symbol not found
Error relocating /usr/bin/openssl: SSL_CIPHER_find: symbol not found
Error relocating /usr/bin/openssl: EVP_EncryptFinal_ex: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_SSL_SESSION: symbol not found
Error relocating /usr/bin/openssl: X509_NAME_dup: symbol not found
Error relocating /usr/bin/openssl: TS_RESP_verify_response: symbol not found
Error relocating /usr/bin/openssl: ASN1_GENERALIZEDTIME_free: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_CTX_trusted_stack: symbol not found
Error relocating /usr/bin/openssl: X509_alias_set1: symbol not found
Error relocating /usr/bin/openssl: X509_REQ_set_subject_name: symbol not found
Error relocating /usr/bin/openssl: UI_method_set_writer: symbol not found
Error relocating /usr/bin/openssl: UI_get0_user_data: symbol not found
Error relocating /usr/bin/openssl: SSL_get_srp_username: symbol not found
Error relocating /usr/bin/openssl: ASN1_item_i2d_bio: symbol not found
Error relocating /usr/bin/openssl: SSL_ctrl: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_CTX_set0_crls: symbol not found
Error relocating /usr/bin/openssl: ASN1_generate_nconf: symbol not found
Error relocating /usr/bin/openssl: BN_to_ASN1_INTEGER: symbol not found
Error relocating /usr/bin/openssl: EVP_MD_CTX_init: symbol not found
Error relocating /usr/bin/openssl: SMIME_write_PKCS7: symbol not found
Error relocating /usr/bin/openssl: X509_VERIFY_PARAM_free: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_client_cert_engine: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_DSAPrivateKey: symbol not found
Error relocating /usr/bin/openssl: X509_NAME_ENTRY_free: symbol not found
Error relocating /usr/bin/openssl: EVP_ripemd160: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_set1_DSA: symbol not found
Error relocating /usr/bin/openssl: TS_RESP_get_token: symbol not found
Error relocating /usr/bin/openssl: ASN1_GENERALIZEDTIME_set_string: symbol not found
Error relocating /usr/bin/openssl: SSL_load_client_CA_file: symbol not found
Error relocating /usr/bin/openssl: ASN1_i2d_bio: symbol not found
Error relocating /usr/bin/openssl: BUF_reverse: symbol not found
Error relocating /usr/bin/openssl: TS_CONF_set_serial: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_CTX_get_error_depth: symbol not found
Error relocating /usr/bin/openssl: EVP_get_cipherbyname: symbol not found
Error relocating /usr/bin/openssl: CMS_get0_signers: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_size: symbol not found
Error relocating /usr/bin/openssl: string_to_hex: symbol not found
Error relocating /usr/bin/openssl: lh_stats_bio: symbol not found
Error relocating /usr/bin/openssl: BIO_gets: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio: symbol not found
Error relocating /usr/bin/openssl: a2i_ASN1_INTEGER: symbol not found
Error relocating /usr/bin/openssl: i2d_OCSP_RESPONSE: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_sign_init: symbol not found
Error relocating /usr/bin/openssl: ASN1_ENUMERATED_new: symbol not found
Error relocating /usr/bin/openssl: SSL_get_ciphers: symbol not found
Error relocating /usr/bin/openssl: X509V3_EXT_CRL_add_nconf: symbol not found
Error relocating /usr/bin/openssl: OBJ_create: symbol not found
Error relocating /usr/bin/openssl: SSL_alert_type_string_long: symbol not found
Error relocating /usr/bin/openssl: ASN1_PRINTABLE_type: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_srp_client_pwd_callback: symbol not found
Error relocating /usr/bin/openssl: DSAparams_dup: symbol not found
Error relocating /usr/bin/openssl: EVP_Digest: symbol not found
Error relocating /usr/bin/openssl: BN_bn2bin: symbol not found
Error relocating /usr/bin/openssl: ASN1_UTCTIME_new: symbol not found
Error relocating /usr/bin/openssl: EC_get_builtin_curves: symbol not found
Error relocating /usr/bin/openssl: EVP_EncryptInit_ex: symbol not found
Error relocating /usr/bin/openssl: X509V3_EXT_REQ_add_nconf: symbol not found
Error relocating /usr/bin/openssl: RSA_new: symbol not found
Error relocating /usr/bin/openssl: X509_REQ_print: symbol not found
Error relocating /usr/bin/openssl: PEM_read_bio_Parameters: symbol not found
Error relocating /usr/bin/openssl: SSL_cache_hit: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_set_flags: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_new: symbol not found
Error relocating /usr/bin/openssl: SSL_pending: symbol not found
Error relocating /usr/bin/openssl: SSL_CONF_CTX_new: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_sign: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_get_default_digest_nid: symbol not found
Error relocating /usr/bin/openssl: BF_options: symbol not found
Error relocating /usr/bin/openssl: TLSv1_1_server_method: symbol not found
Error relocating /usr/bin/openssl: CMS_set1_eContentType: symbol not found
Error relocating /usr/bin/openssl: SSL_CONF_CTX_free: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_RSAPrivateKey: symbol not found
Error relocating /usr/bin/openssl: TS_CONF_set_policies: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_DHparams: symbol not found
Error relocating /usr/bin/openssl: EVP_CIPHER_CTX_ctrl: symbol not found
Error relocating /usr/bin/openssl: SSL_get_srp_N: symbol not found
Error relocating /usr/bin/openssl: DTLSv1_2_client_method: symbol not found
Error relocating /usr/bin/openssl: X509_http_nbio: symbol not found
Error relocating /usr/bin/openssl: SSL_get0_next_proto_negotiated: symbol not found
Error relocating /usr/bin/openssl: PBKDF2PARAM_free: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_use_PrivateKey_file: symbol not found
Error relocating /usr/bin/openssl: DH_check: symbol not found
Error relocating /usr/bin/openssl: NETSCAPE_CERT_SEQUENCE_free: symbol not found
Error relocating /usr/bin/openssl: SSL_set_verify: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_X509_CRL: symbol not found
Error relocating /usr/bin/openssl: X509_NAME_get_index_by_OBJ: symbol not found
Error relocating /usr/bin/openssl: TS_RESP_set_tst_info: symbol not found
Error relocating /usr/bin/openssl: X509_VERIFY_PARAM_set1_email: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_cipher_list: symbol not found
Error relocating /usr/bin/openssl: CMS_data: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_PKCS7: symbol not found
Error relocating /usr/bin/openssl: TS_CONF_load_certs: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_sess_set_get_cb: symbol not found
Error relocating /usr/bin/openssl: TS_TST_INFO_print_bio: symbol not found
Error relocating /usr/bin/openssl: EC_GROUP_get_curve_name: symbol not found
Error relocating /usr/bin/openssl: BIO_dump_indent: symbol not found
Error relocating /usr/bin/openssl: SSL_is_server: symbol not found
Error relocating /usr/bin/openssl: i2b_PVK_bio: symbol not found
Error relocating /usr/bin/openssl: X509_check_private_key: symbol not found
Error relocating /usr/bin/openssl: EVP_DigestFinal: symbol not found
Error relocating /usr/bin/openssl: d2i_SSL_SESSION: symbol not found
Error relocating /usr/bin/openssl: X509_PURPOSE_get_by_sname: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_new: symbol not found
Error relocating /usr/bin/openssl: EC_curve_nid2nist: symbol not found
Error relocating /usr/bin/openssl: CMS_encrypt: symbol not found
Error relocating /usr/bin/openssl: BIO_int_ctrl: symbol not found
Error relocating /usr/bin/openssl: i2d_X509_PUBKEY: symbol not found
Error relocating /usr/bin/openssl: CMS_decrypt_set1_pkey: symbol not found
Error relocating /usr/bin/openssl: DES_options: symbol not found
Error relocating /usr/bin/openssl: d2i_PKCS8_PRIV_KEY_INFO_bio: symbol not found
Error relocating /usr/bin/openssl: EVP_aes_128_cbc: symbol not found
Error relocating /usr/bin/openssl: i2d_PUBKEY_bio: symbol not found
Error relocating /usr/bin/openssl: RC2_set_key: symbol not found
Error relocating /usr/bin/openssl: X509_check_purpose: symbol not found
Error relocating /usr/bin/openssl: CRYPTO_set_mem_debug_functions: symbol not found
Error relocating /usr/bin/openssl: ENGINE_get_first: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_NETSCAPE_CERT_SEQUENCE: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_asn1_get0_info: symbol not found
Error relocating /usr/bin/openssl: X509_REVOKED_add1_ext_i2d: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_EC_PUBKEY: symbol not found
Error relocating /usr/bin/openssl: BIO_snprintf: symbol not found
Error relocating /usr/bin/openssl: EC_KEY_free: symbol not found
Error relocating /usr/bin/openssl: X509_OBJECT_free_contents: symbol not found
Error relocating /usr/bin/openssl: X509_REQ_verify: symbol not found
Error relocating /usr/bin/openssl: NETSCAPE_SPKI_print: symbol not found
Error relocating /usr/bin/openssl: RSA_private_encrypt: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_generate_session_id: symbol not found
Error relocating /usr/bin/openssl: EVP_PKCS82PKEY: symbol not found
Error relocating /usr/bin/openssl: X509_free: symbol not found
Error relocating /usr/bin/openssl: EVP_des_ede3_cbc: symbol not found
Error relocating /usr/bin/openssl: ENGINE_finish: symbol not found
Error relocating /usr/bin/openssl: OCSP_check_validity: symbol not found
Error relocating /usr/bin/openssl: X509_NAME_get_index_by_NID: symbol not found
Error relocating /usr/bin/openssl: X509_CRL_verify: symbol not found
Error relocating /usr/bin/openssl: TS_CONF_set_accuracy: symbol not found
Error relocating /usr/bin/openssl: SSL_CONF_CTX_set_ssl_ctx: symbol not found
Error relocating /usr/bin/openssl: BN_cmp: symbol not found
Error relocating /usr/bin/openssl: X509_REQ_add1_attr_by_NID: symbol not found
Error relocating /usr/bin/openssl: DSA_generate_key: symbol not found
Error relocating /usr/bin/openssl: BIO_get_callback_arg: symbol not found
Error relocating /usr/bin/openssl: X509_NAME_print_ex: symbol not found
Error relocating /usr/bin/openssl: TS_CONF_set_ess_cert_id_chain: symbol not found
Error relocating /usr/bin/openssl: HMAC_Final: symbol not found
Error relocating /usr/bin/openssl: BIO_f_cipher: symbol not found
Error relocating /usr/bin/openssl: OCSP_request_add1_nonce: symbol not found
Error relocating /usr/bin/openssl: TS_STATUS_INFO_new: symbol not found
Error relocating /usr/bin/openssl: sk_num: symbol not found
Error relocating /usr/bin/openssl: SSL_get_servername_type: symbol not found
Error relocating /usr/bin/openssl: ASN1_STRING_set_default_mask_asc: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_verify_init: symbol not found
Error relocating /usr/bin/openssl: lh_strhash: symbol not found
Error relocating /usr/bin/openssl: SSL_use_PrivateKey: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_PrivateKey: symbol not found
Error relocating /usr/bin/openssl: SHA1: symbol not found
Error relocating /usr/bin/openssl: ASN1_OBJECT_free: symbol not found
Error relocating /usr/bin/openssl: GENERAL_NAME_get0_value: symbol not found
Error relocating /usr/bin/openssl: CMS_ReceiptRequest_create0: symbol not found
Error relocating /usr/bin/openssl: EVP_CIPHER_key_length: symbol not found
Error relocating /usr/bin/openssl: SSL_get_session: symbol not found
Error relocating /usr/bin/openssl: X509_set_pubkey: symbol not found
Error relocating /usr/bin/openssl: X509_digest: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_add_crl: symbol not found
Error relocating /usr/bin/openssl: UI_method_set_opener: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_DHxparams: symbol not found
Error relocating /usr/bin/openssl: RSA_set_default_method: symbol not found
Error relocating /usr/bin/openssl: SSL_connect: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_free: symbol not found
Error relocating /usr/bin/openssl: TS_REQ_new: symbol not found
Error relocating /usr/bin/openssl: X509_add_ext: symbol not found
Error relocating /usr/bin/openssl: SSLeay_version: symbol not found
Error relocating /usr/bin/openssl: X509_check_email: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_X509_REQ: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_encrypt: symbol not found
Error relocating /usr/bin/openssl: lh_insert: symbol not found
Error relocating /usr/bin/openssl: EVP_CIPHER_CTX_set_flags: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_CTX_get1_chain: symbol not found
Error relocating /usr/bin/openssl: SSL_load_error_strings: symbol not found
Error relocating /usr/bin/openssl: X509_set_subject_name: symbol not found
Error relocating /usr/bin/openssl: i2d_PKCS7_bio: symbol not found
Error relocating /usr/bin/openssl: X509V3_set_ctx: symbol not found
Error relocating /usr/bin/openssl: HMAC_Init_ex: symbol not found
Error relocating /usr/bin/openssl: EVP_MD_CTX_md: symbol not found
Error relocating /usr/bin/openssl: EC_GROUP_get0_generator: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_ECPrivateKey: symbol not found
Error relocating /usr/bin/openssl: TS_RESP_verify_token: symbol not found
Error relocating /usr/bin/openssl: TS_RESP_get_tst_info: symbol not found
Error relocating /usr/bin/openssl: DES_set_key_unchecked: symbol not found
Error relocating /usr/bin/openssl: SSL_set_session: symbol not found
Error relocating /usr/bin/openssl: EC_KEY_new: symbol not found
Error relocating /usr/bin/openssl: BUF_strdup: symbol not found
Error relocating /usr/bin/openssl: TLSv1_server_method: symbol not found
Error relocating /usr/bin/openssl: X509_REQ_sign_ctx: symbol not found
Error relocating /usr/bin/openssl: X509_sign: symbol not found
Error relocating /usr/bin/openssl: TXT_DB_get_by_index: symbol not found
Error relocating /usr/bin/openssl: DSAparams_print: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_keygen_init: symbol not found
Error relocating /usr/bin/openssl: CMS_decrypt_set1_key: symbol not found
Error relocating /usr/bin/openssl: PKCS7_to_TS_TST_INFO: symbol not found
Error relocating /usr/bin/openssl: ASN1_TIME_new: symbol not found
Error relocating /usr/bin/openssl: OCSP_REQUEST_new: symbol not found
Error relocating /usr/bin/openssl: UI_set_result: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_bits: symbol not found
Error relocating /usr/bin/openssl: ENGINE_get_pkey_meths: symbol not found
Error relocating /usr/bin/openssl: ERR_get_error: symbol not found
Error relocating /usr/bin/openssl: PKCS7_SIGNED_new: symbol not found
Error relocating /usr/bin/openssl: ASN1_item_d2i_bio: symbol not found
Error relocating /usr/bin/openssl: OCSP_onereq_get0_id: symbol not found
Error relocating /usr/bin/openssl: RSA_sign: symbol not found
Error relocating /usr/bin/openssl: GENERAL_NAME_print: symbol not found
Error relocating /usr/bin/openssl: CMS_add0_recipient_key: symbol not found
Error relocating /usr/bin/openssl: i2d_DSA_PUBKEY_bio: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_missing_parameters: symbol not found
Error relocating /usr/bin/openssl: d2i_ECPrivateKey_bio: symbol not found
Error relocating /usr/bin/openssl: TS_CONF_set_ordering: symbol not found
Error relocating /usr/bin/openssl: UI_get_input_flags: symbol not found
Error relocating /usr/bin/openssl: EC_GROUP_get_degree: symbol not found
Error relocating /usr/bin/openssl: UI_method_get_writer: symbol not found
Error relocating /usr/bin/openssl: PEM_X509_INFO_read_bio: symbol not found
Error relocating /usr/bin/openssl: EVP_CIPHER_do_all_sorted: symbol not found
Error relocating /usr/bin/openssl: EVP_CIPHER_flags: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_Parameters: symbol not found
Error relocating /usr/bin/openssl: BUF_MEM_grow_clean: symbol not found
Error relocating /usr/bin/openssl: BIO_free_all: symbol not found
Error relocating /usr/bin/openssl: i2d_RSAPublicKey_bio: symbol not found
Error relocating /usr/bin/openssl: CRYPTO_realloc: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_set1_param: symbol not found
Error relocating /usr/bin/openssl: d2i_TS_RESP_bio: symbol not found
Error relocating /usr/bin/openssl: CMS_SignerInfo_get0_pkey_ctx: symbol not found
Error relocating /usr/bin/openssl: TS_REQ_to_TS_VERIFY_CTX: symbol not found
Error relocating /usr/bin/openssl: EVP_rc2_64_cbc: symbol not found
Error relocating /usr/bin/openssl: NETSCAPE_SPKI_new: symbol not found
Error relocating /usr/bin/openssl: EVP_MD_flags: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_use_PrivateKey: symbol not found
Error relocating /usr/bin/openssl: SSL_alert_desc_string_long: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_get_cert_store: symbol not found
Error relocating /usr/bin/openssl: X509_get1_email: symbol not found
Error relocating /usr/bin/openssl: SSL_get_servername: symbol not found
Error relocating /usr/bin/openssl: BIO_puts: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_decrypt_init: symbol not found
Error relocating /usr/bin/openssl: UI_get_string_type: symbol not found
Error relocating /usr/bin/openssl: CRYPTO_mem_ctrl: symbol not found
Error relocating /usr/bin/openssl: BIO_new_dgram: symbol not found
Error relocating /usr/bin/openssl: EVP_DecryptUpdate: symbol not found
Error relocating /usr/bin/openssl: NETSCAPE_SPKI_get_pubkey: symbol not found
Error relocating /usr/bin/openssl: SHA512: symbol not found
Error relocating /usr/bin/openssl: PKCS8_PRIV_KEY_INFO_free: symbol not found
Error relocating /usr/bin/openssl: X509_EXTENSION_free: symbol not found
Error relocating /usr/bin/openssl: EVP_des_cbc: symbol not found
Error relocating /usr/bin/openssl: lh_node_usage_stats_bio: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_CTX_set_cb: symbol not found
Error relocating /usr/bin/openssl: BUF_strlcat: symbol not found
Error relocating /usr/bin/openssl: ASN1_GENERALIZEDTIME_new: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_CTX_ctrl_str: symbol not found
Error relocating /usr/bin/openssl: CMS_sign_receipt: symbol not found
Error relocating /usr/bin/openssl: i2d_PrivateKey_bio: symbol not found
Error relocating /usr/bin/openssl: ERR_load_crypto_strings: symbol not found
Error relocating /usr/bin/openssl: CMS_ReceiptRequest_get0_values: symbol not found
Error relocating /usr/bin/openssl: DTLS_server_method: symbol not found
Error relocating /usr/bin/openssl: X509_issuer_name_hash_old: symbol not found
Error relocating /usr/bin/openssl: PEM_read_bio_PrivateKey: symbol not found
Error relocating /usr/bin/openssl: PEM_read_bio_PKCS8: symbol not found
Error relocating /usr/bin/openssl: ASN1_TIME_free: symbol not found
Error relocating /usr/bin/openssl: CMS_RecipientInfo_get0_pkey_ctx: symbol not found
Error relocating /usr/bin/openssl: ENGINE_load_builtin_engines: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_check_private_key: symbol not found
Error relocating /usr/bin/openssl: OPENSSL_uni2asc: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_set_lookup_crls_cb: symbol not found
Error relocating /usr/bin/openssl: X509_REQ_free: symbol not found
Error relocating /usr/bin/openssl: CMS_get0_SignerInfos: symbol not found
Error relocating /usr/bin/openssl: ASN1_INTEGER_free: symbol not found
Error relocating /usr/bin/openssl: PEM_read_bio_X509: symbol not found
Error relocating /usr/bin/openssl: EC_KEY_set_group: symbol not found
Error relocating /usr/bin/openssl: PKCS12_unpack_p7data: symbol not found
Error relocating /usr/bin/openssl: ECDSA_verify: symbol not found
Error relocating /usr/bin/openssl: CRYPTO_mem_leaks: symbol not found
Error relocating /usr/bin/openssl: X509_REQ_set_pubkey: symbol not found
Error relocating /usr/bin/openssl: TS_RESP_CTX_add_failure_info: symbol not found
Error relocating /usr/bin/openssl: TS_CONF_set_crypto_device: symbol not found
Error relocating /usr/bin/openssl: EC_KEY_print: symbol not found
Error relocating /usr/bin/openssl: SSL_CIPHER_get_version: symbol not found
Error relocating /usr/bin/openssl: TS_CONF_set_def_policy: symbol not found
Error relocating /usr/bin/openssl: ENGINE_load_public_key: symbol not found
Error relocating /usr/bin/openssl: CMS_digest_create: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_get0_asn1: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_psk_server_callback: symbol not found
Error relocating /usr/bin/openssl: PEM_read_bio_RSAPublicKey: symbol not found
Error relocating /usr/bin/openssl: ERR_get_string_table: symbol not found
Error relocating /usr/bin/openssl: DSA_dup_DH: symbol not found
Error relocating /usr/bin/openssl: TLSv1_2_client_method: symbol not found
Error relocating /usr/bin/openssl: PKCS12_unpack_authsafes: symbol not found
Error relocating /usr/bin/openssl: CMS_add1_recipient_cert: symbol not found
Error relocating /usr/bin/openssl: X509_CRL_new: symbol not found
Error relocating /usr/bin/openssl: EVP_rc2_cbc: symbol not found
Error relocating /usr/bin/openssl: EC_KEY_set_conv_form: symbol not found
Error relocating /usr/bin/openssl: UI_method_get_opener: symbol not found
Error relocating /usr/bin/openssl: DSA_verify: symbol not found
Error relocating /usr/bin/openssl: SSL_CIPHER_get_name: symbol not found
Error relocating /usr/bin/openssl: i2d_CMS_bio_stream: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_derive_set_peer: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_use_certificate: symbol not found
Error relocating /usr/bin/openssl: OCSP_REQ_CTX_set1_req: symbol not found
Error relocating /usr/bin/openssl: CRYPTO_gcm128_aad: symbol not found
Error relocating /usr/bin/openssl: BIO_write: symbol not found
Error relocating /usr/bin/openssl: CRYPTO_set_locking_callback: symbol not found
Error relocating /usr/bin/openssl: OCSP_REQUEST_add_ext: symbol not found
Error relocating /usr/bin/openssl: ASN1_STRING_set: symbol not found
Error relocating /usr/bin/openssl: BIO_s_file: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_DSA_PUBKEY: symbol not found
Error relocating /usr/bin/openssl: NCONF_free: symbol not found
Error relocating /usr/bin/openssl: TS_MSG_IMPRINT_free: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_id: symbol not found
Error relocating /usr/bin/openssl: ERR_print_errors_fp: symbol not found
Error relocating /usr/bin/openssl: EVP_CipherInit_ex: symbol not found
Error relocating /usr/bin/openssl: SSL_do_handshake: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_verify_recover_init: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_alpn_protos: symbol not found
Error relocating /usr/bin/openssl: X509_NAME_hash_old: symbol not found
Error relocating /usr/bin/openssl: SSL_get_verify_result: symbol not found
Error relocating /usr/bin/openssl: TS_RESP_CTX_new: symbol not found
Error relocating /usr/bin/openssl: GENERAL_NAMES_new: symbol not found
Error relocating /usr/bin/openssl: TS_REQ_set_cert_req: symbol not found
Error relocating /usr/bin/openssl: RSA_private_decrypt: symbol not found
Error relocating /usr/bin/openssl: sk_delete: symbol not found
Error relocating /usr/bin/openssl: OCSP_REQ_CTX_http: symbol not found
Error relocating /usr/bin/openssl: X509_STORE_set_verify_cb: symbol not found
Error relocating /usr/bin/openssl: TXT_DB_free: symbol not found
Error relocating /usr/bin/openssl: ECDH_compute_key: symbol not found
Error relocating /usr/bin/openssl: PKCS8_encrypt: symbol not found
Error relocating /usr/bin/openssl: SSL_get_current_expansion: symbol not found
Error relocating /usr/bin/openssl: d2i_ASN1_TYPE: symbol not found
Error relocating /usr/bin/openssl: EVP_MD_CTX_cleanup: symbol not found
Error relocating /usr/bin/openssl: NETSCAPE_SPKI_b64_decode: symbol not found
Error relocating /usr/bin/openssl: TS_STATUS_INFO_free: symbol not found
Error relocating /usr/bin/openssl: ENGINE_load_private_key: symbol not found
Error relocating /usr/bin/openssl: a2i_GENERAL_NAME: symbol not found
Error relocating /usr/bin/openssl: BIO_new_file: symbol not found
Error relocating /usr/bin/openssl: ENGINE_get_id: symbol not found
Error relocating /usr/bin/openssl: BIO_s_mem: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_use_serverinfo_file: symbol not found
Error relocating /usr/bin/openssl: X509_NAME_free: symbol not found
Error relocating /usr/bin/openssl: RAND_file_name: symbol not found
Error relocating /usr/bin/openssl: CMS_final: symbol not found
Error relocating /usr/bin/openssl: PKCS7_print_ctx: symbol not found
Error relocating /usr/bin/openssl: TS_CONF_set_signer_key: symbol not found
Error relocating /usr/bin/openssl: X509_REVOKED_new: symbol not found
Error relocating /usr/bin/openssl: EVP_DigestVerifyFinal: symbol not found
Error relocating /usr/bin/openssl: SSL_get_rbio: symbol not found
Error relocating /usr/bin/openssl: EC_KEY_new_by_curve_name: symbol not found
Error relocating /usr/bin/openssl: X509_CRL_set_issuer_name: symbol not found
Error relocating /usr/bin/openssl: SSL_get_current_compression: symbol not found
Error relocating /usr/bin/openssl: TS_CONF_set_signer_cert: symbol not found
Error relocating /usr/bin/openssl: CRYPTO_set_mem_debug_options: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_CTX_free: symbol not found
Error relocating /usr/bin/openssl: TS_CONF_set_digests: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_srp_verify_param_callback: symbol not found
Error relocating /usr/bin/openssl: PEM_write_bio_PUBKEY: symbol not found
Error relocating /usr/bin/openssl: i2a_ASN1_INTEGER: symbol not found
Error relocating /usr/bin/openssl: CMS_ContentInfo_free: symbol not found
Error relocating /usr/bin/openssl: X509_CRL_sign_ctx: symbol not found
Error relocating /usr/bin/openssl: ENGINE_by_id: symbol not found
Error relocating /usr/bin/openssl: X509_email_free: symbol not found
Error relocating /usr/bin/openssl: EVP_CIPHER_CTX_cleanup: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY2PKCS8_broken: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_set1_RSA: symbol not found
Error relocating /usr/bin/openssl: EVP_PKEY_asn1_get_count: symbol not found
Error relocating /usr/bin/openssl: SSL_set_bio: symbol not found
Error relocating /usr/bin/openssl: OCSP_request_onereq_get0: symbol not found
Error relocating /usr/bin/openssl: X509_ALGOR_get0: symbol not found
Error relocating /usr/bin/openssl: PKCS7_get0_signers: symbol not found
Error relocating /usr/bin/openssl: SSL_CTX_set_alpn_select_cb: symbol not found
Error relocating /usr/bin/openssl: X509_new: symbol not found
Error relocating /usr/bin/openssl: OCSP_response_get1_basic: symbol not found
Error relocating /usr/bin/openssl: X509_print: symbol not found
Error relocating /usr/bin/openssl: CRYPTO_dbg_realloc: symbol not found
Error relocating /usr/bin/openssl: PKCS12_SAFEBAG_free: symbol not found
Error relocating /usr/bin/openssl: d2i_OCSP_REQUEST: symbol not found
Error relocating /usr/bin/openssl: i2d_ECPKParameters: symbol not found
Error relocating /usr/bin/openssl: SSL_SESSION_new: symbol not found
Error relocating /usr/bin/openssl: BIO_debug_callback: symbol not found
Error relocating /usr/bin/openssl: DSA_new: symbol not found
Error relocating /usr/bin/openssl: OCSP_RESPONSE_new: symbol not found
Error relocating /usr/bin/openssl: CRYPTO_dbg_malloc: symbol not found
Error relocating /usr/bin/openssl: CRYPTO_dbg_get_options: symbol not found
Error relocating /usr/bin/openssl: CRYPTO_dbg_free: symbol not found
Error relocating /usr/bin/openssl: PBE2PARAM_it: symbol not found
Error relocating /usr/bin/openssl: X509V3_conf_free: symbol not found
Error relocating /usr/bin/openssl: i2d_OCSP_REQUEST: symbol not found
Error relocating /usr/bin/openssl: d2i_ECPKParameters: symbol not found
Error relocating /usr/bin/openssl: d2i_DSAparams: symbol not found
Error relocating /usr/bin/openssl: PBKDF2PARAM_it: symbol not found
Error relocating /usr/bin/openssl: NETSCAPE_X509_it: symbol not found
Error relocating /usr/bin/openssl: i2d_DHxparams: symbol not found
Error relocating /usr/bin/openssl: d2i_DHparams: symbol not found
Error relocating /usr/bin/openssl: i2d_DHparams: symbol not found
Error relocating /usr/bin/openssl: AES_encrypt: symbol not found
Error relocating /usr/bin/openssl: i2d_DSAparams: symbol not found
Error relocating /usr/bin/openssl: PBEPARAM_it: symbol not found
Error relocating /usr/bin/openssl: CRYPTO_dbg_set_options: symbol not found
Error relocating /usr/bin/openssl: DIST_POINT_free: symbol not found
Error relocating /usr/bin/openssl: d2i_DHxparams: symbol not found
Error loading shared library libcrypto.so.1.0.0: No such file or directory (needed by /usr/bin/atsha204cmd)
Error loading shared library libssl.so.1.0.0: No such file or directory (needed by /usr/lib/libunbound.so.8)
Error loading shared library libcrypto.so.1.0.0: No such file or directory (needed by /usr/lib/libunbound.so.8)
Error loading shared library libcrypto.so.1.0.0: No such file or directory (needed by /usr/lib/libatsha204.so)
Error relocating /usr/lib/libunbound.so.8: SSL_CTX_set_client_CA_list: symbol not found
Error relocating /usr/lib/libunbound.so.8: SHA256: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_get_error: symbol not found
Error relocating /usr/lib/libunbound.so.8: o2i_ECPublicKey: symbol not found
Error relocating /usr/lib/libunbound.so.8: CRYPTO_free: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_write: symbol not found
Error relocating /usr/lib/libunbound.so.8: X509_VERIFY_PARAM_set_hostflags: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSLv23_client_method: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_free: symbol not found
Error relocating /usr/lib/libunbound.so.8: EVP_md5: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSLv23_server_method: symbol not found
Error relocating /usr/lib/libunbound.so.8: EVP_DigestFinal_ex: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_CTX_use_certificate_chain_file: symbol not found
Error relocating /usr/lib/libunbound.so.8: DSA_new: symbol not found
Error relocating /usr/lib/libunbound.so.8: BN_new: symbol not found
Error relocating /usr/lib/libunbound.so.8: EVP_aes_256_cbc: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_set_fd: symbol not found
Error relocating /usr/lib/libunbound.so.8: EVP_sha512: symbol not found
Error relocating /usr/lib/libunbound.so.8: EVP_VerifyFinal: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_CTX_callback_ctrl: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_CTX_set_verify: symbol not found
Error relocating /usr/lib/libunbound.so.8: DSA_SIG_new: symbol not found
Error relocating /usr/lib/libunbound.so.8: EVP_sha1: symbol not found
Error relocating /usr/lib/libunbound.so.8: X509_VERIFY_PARAM_set1_host: symbol not found
Error relocating /usr/lib/libunbound.so.8: BN_bin2bn: symbol not found
Error relocating /usr/lib/libunbound.so.8: RAND_bytes: symbol not found
Error relocating /usr/lib/libunbound.so.8: EVP_PKEY_free: symbol not found
Error relocating /usr/lib/libunbound.so.8: EVP_DigestInit: symbol not found
Error relocating /usr/lib/libunbound.so.8: SHA512_Update: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_read: symbol not found
Error relocating /usr/lib/libunbound.so.8: EVP_DigestInit_ex: symbol not found
Error relocating /usr/lib/libunbound.so.8: ERR_error_string_n: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_CTX_ctrl: symbol not found
Error relocating /usr/lib/libunbound.so.8: EVP_CIPHER_iv_length: symbol not found
Error relocating /usr/lib/libunbound.so.8: DSA_SIG_free: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_new: symbol not found
Error relocating /usr/lib/libunbound.so.8: BN_free: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_set_connect_state: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_shutdown: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_get0_param: symbol not found
Error relocating /usr/lib/libunbound.so.8: X509_print_ex: symbol not found
Error relocating /usr/lib/libunbound.so.8: ERR_clear_error: symbol not found
Error relocating /usr/lib/libunbound.so.8: EVP_DigestUpdate: symbol not found
Error relocating /usr/lib/libunbound.so.8: SHA384: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_CTX_new: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_set_accept_state: symbol not found
Error relocating /usr/lib/libunbound.so.8: EVP_MD_CTX_destroy: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_get_peer_certificate: symbol not found
Error relocating /usr/lib/libunbound.so.8: BIO_new: symbol not found
Error relocating /usr/lib/libunbound.so.8: BIO_ctrl: symbol not found
Error relocating /usr/lib/libunbound.so.8: BIO_free: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_CTX_load_verify_locations: symbol not found
Error relocating /usr/lib/libunbound.so.8: EVP_DecryptInit_ex: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_ctrl: symbol not found
Error relocating /usr/lib/libunbound.so.8: EVP_MD_CTX_init: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_load_client_CA_file: symbol not found
Error relocating /usr/lib/libunbound.so.8: SHA512_Final: symbol not found
Error relocating /usr/lib/libunbound.so.8: EVP_EncryptInit_ex: symbol not found
Error relocating /usr/lib/libunbound.so.8: RSA_new: symbol not found
Error relocating /usr/lib/libunbound.so.8: EVP_PKEY_new: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_CTX_use_PrivateKey_file: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_set_verify: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_CTX_set_cipher_list: symbol not found
Error relocating /usr/lib/libunbound.so.8: EC_KEY_free: symbol not found
Error relocating /usr/lib/libunbound.so.8: EVP_PKEY_assign: symbol not found
Error relocating /usr/lib/libunbound.so.8: X509_free: symbol not found
Error relocating /usr/lib/libunbound.so.8: SHA1: symbol not found
Error relocating /usr/lib/libunbound.so.8: EVP_sha384: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_CTX_free: symbol not found
Error relocating /usr/lib/libunbound.so.8: i2d_DSA_SIG: symbol not found
Error relocating /usr/lib/libunbound.so.8: HMAC_Init_ex: symbol not found
Error relocating /usr/lib/libunbound.so.8: ERR_get_error: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_CTX_check_private_key: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_CTX_get_verify_mode: symbol not found
Error relocating /usr/lib/libunbound.so.8: BIO_write: symbol not found
Error relocating /usr/lib/libunbound.so.8: EVP_sha256: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_do_handshake: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_get_verify_result: symbol not found
Error relocating /usr/lib/libunbound.so.8: SSL_get_verify_mode: symbol not found
Error relocating /usr/lib/libunbound.so.8: EVP_dss1: symbol not found
Error relocating /usr/lib/libunbound.so.8: EVP_MD_CTX_cleanup: symbol not found
Error relocating /usr/lib/libunbound.so.8: BIO_s_mem: symbol not found
Error relocating /usr/lib/libunbound.so.8: EC_KEY_new_by_curve_name: symbol not found
Error relocating /usr/lib/libunbound.so.8: EVP_MD_CTX_create: symbol not found
Error relocating /usr/lib/libunbound.so.8: SHA512_Init: symbol not found
Error relocating /usr/lib/libatsha204.so: SHA256: symbol not found
Error relocating /usr/lib/libatsha204.so: HMAC: symbol not found
Error relocating /usr/lib/libatsha204.so: EVP_sha256: symbol not found
Error relocating /usr/bin/atsha204cmd: SHA256_Init: symbol not found
Error relocating /usr/bin/atsha204cmd: SHA256_Final: symbol not found
Error relocating /usr/bin/atsha204cmd: SHA256_Update: symbol not found
crypto-wrapper: error: Failed to run command 'atsha204cmd serial-number'
ERROR:Reading crypto-wrapper output failed!
line not found
line not found
line not found
ERROR:
runtime: [string "file:////etc/updater/conf.d/turris.lua"]:107: bad argument #1 to 'sub' (string expected, got nil)
INFO:Executing postupdate hook: 95_schnapps.sh
Snapshot number 23 created
INFO:Executing postupdate hook: 99_approvals_cleanup
INFO:Executing postupdate hook: cleanup_rc_d.sh
root@turris:~#
Setup from scratch and finally boot-loop, you said?
Yes. Changed only passwords, test connection in foris, allow ssh, pkgupdate and boot loop.
The world has changed. Time to roll back this update.
