Turris 1.1, simple config without wifi - VLANs, guest network, OpenVPN, Samba, MiniDLNA, SQM, DNS over TLS.
The upgrade took place without any major problems. After the first reboot everything ran without any problem. But after a few hours I noticed that reForis stopped working. Unfortunately, I did not copy the error message that appeared in the browser. But since the next restart, the problem has not repeated.
Thank you and hats off to the whole Turris team.
The only thing I noticed, and it is still the same problem in my case that I already confided during the upgrade to version 6.5.1, is that the factory image did not update, even though I have checked âLatest firmwareâ and âFactory imageâ in Packages in reForis for a long time.
And schnapps pretends not to know what itâs running on.
root@turris254:~# schnapps factory-version
5.3.0
root@turris254:~# schnapps update-factory
Don't know what device I am, can't update my factory image
Maybe thatâs why it did nothing. What could it be? According to the log I recorded during the upgrade, 96_firmware_updater was executed.
On turris 1.x, the problem is that you canât connect to any tracker or peer (it keeps saying connecting) + high cpu load.
No, transmission-daemon 4.0.4 doesnât solve the problem.
So far our investigaions into transmission revealed, that downloading via magnet links is broken, but if you download torrent file manually and upload it to transmission, it works. Regarding 100% CPU usage, in some tests, disabling uPnP and uTP helped (--no-portmap and --no-utp cmdline options). But not all the time, we are looking into it, but so far no luck.
failing signature verification - i experienced the same on my MOX when doing a fresh usb flash installation today⌠signature check failed when loading the packages list.
my âquick n dirtyâ workaround was switching to hbt branch. then the signature check passed.
on my omnia, i didn´t have this issue, but i upgraded from 6 to 7 and didn´t do a completely fresh installationâŚ
Mine (Omnia AP upgraded some time ago during the delayed update time) went just fine. Upgrade->Reboot all is working.
Mine (Main Omnia router went fine as well) but be sure to not to use new DHCP options. In 22.03 new instances options for each interface dont work. So this update fixed some old bugs but introduced new ones probabbly fixed in 23.03 already.
Time will tell. Thank you Turris team. The upgrade went smooth. At least for me.
we tried with @miska to find some bug why it is not working, but without success still. Some torrents works, some not. Sometimes it works with copied url, sometimes not and works only from uploaded torrent file⌠really weird behaviour. Last what we didnât try is downgradeâŚI will try to downgrade it to v3 and let you know. If transmission works on v3. we will send it to the next version as temp. solution.
