7.0.2 → 7.0.3 RC1 update okay (no new problems introduced), no unintended cable/wifi or internet downtime. Restart was needed.
Transmission is still hogging the CPU.
When the firmware got updated, the router flashed all LEDs green. But after the reboot, it again set LED brightness to 0%. I guess this would scare someone who doesn’t have the serial link attached during the update. I’d say this has to be resolved before the updated is pushed to public. So far, it happened to me every time the MCU or U-Boot got updated via updater.
Turris Omnia 2017, 1 GB RAM, dead eMMC, system running from mSATA SSD, original wifi cards, UBoot 2024.10-rc3. Storage plugin enabled, LXC containers, tor relay, USB HDD shared over samba4 and minidlna, Syncthing, SQM, Hardwario gateway + MQTT IoT bridge, OpenVPN, PPtP VPN, Strongswan IKEv2 VPN, morce.
Current boot log after the update:
BootROM - 1.73
Booting from SPI flash
U-Boot SPL 2024.10-rc3-OpenWrt-r20343+127-4e1d1b7df0 (Sep 13 2024 - 01:38:50 +0000)
High speed PHY - Version: 2.0
MiniPCIe/mSATA card detection... mSATA
WWAN slot configuration... PCIe+USB2.0
Detected Device ID 6820
board SerDes lanes topology details:
| Lane # | Speed | Type |
| 0 | 6 | SATA0 |
| 1 | 5 | USB3 HOST0 |
| 2 | 5 | PCIe1 |
| 3 | 5 | USB3 HOST1 |
| 4 | 5 | PCIe2 |
| 5 | 0 | SGMII2 |
mv_ddr: 14.0.0
DDR3 Training Sequence - Switching XBAR Window to FastPath Window
mv_ddr: completed successfully
Trying to boot from SPI
U-Boot 2024.10-rc3-OpenWrt-r20343+127-4e1d1b7df0 (Sep 13 2024 - 01:38:50 +0000), Build: jenkins-TurrisOS-packages-hbk-omnia-1216
SoC: MV88F6820-A0 at 1600 MHz
DRAM: 1 GiB (800 MHz, 32-bit, 2T, ECC not enabled)
Core: 89 devices, 31 uclasses, devicetree: separate
WDT: Started watchdog@20300 with servicing every 1000ms (60s timeout)
MMC: mv_sdh: 0
Loading Environment from SPIFlash... SF: Detected s25fl164k with page size 256 Bytes, erase size 4 KiB, total 8 MiB
OK
Model: Turris Omnia
MCU type: STM32
MCU version: b5a8a24e007eb72be16aeb3fff6f03ec647023e4/e44032e4c49337f77583d1caaf1b4b3682e878f7
RAM size: 1024 MiB
Board version: unknown
Serial Number: ****
Disabling MCU watchdog... disabled
Regdomain set to **
pcie1.0: Link up
pcie2.0: Link up
Net: eth0: ethernet@70000, eth1: ethernet@30000, eth2: ethernet@34000 [PRIME], eth3: lan0, eth4: lan1, eth5: lan2, eth6: lan3, eth7: lan4
Hit any key to stop autoboot: 0
scanning bus for devices...
Target spinup took 0 ms.
SATA link 1 timeout.
AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
flags: 64bit ncq led only pmp fbss pio slum part sxs
Device 0: (0:0) Vendor: ATA Prod.: KINGSTON SUV500M Rev: 0030
Type: Hard Disk
Capacity: 114473.4 MB = 111.7 GB (234441648 x 512)
Type: Hard Disk
... is now current device
Scanning scsi 0:1...
Found U-Boot script /boot.scr
1199 bytes read in 36 ms (32.2 KiB/s)
## Executing script at 01800000
gpio: pin gpio@71_4 (gpio 52) value is 1
21434 bytes read in 32 ms (653.3 KiB/s)
4281584 bytes read in 108 ms (37.8 MiB/s)
Kernel image @ 0x1000000 [ 0x000000 - 0x4154f0 ]
## Flattened Device Tree blob at 02000000
Booting using the fdt blob at 0x2000000
Working FDT set to 2000000
Loading Device Tree to 0fff7000, end 0ffff3b9 ... OK
Working FDT set to fff7000
Starting kernel ...
