Turris OS 7.0.2 is released!
Dear Turris users,
we just released a small fixup release. It contains the following changes:
:pushpin: Updates
• knot-resolver: Update to 5.7.4 and 6.0.8 - security updates
:bug: Bug Fixes
• tvheadend: Fix init script and websockets
We don’t expect any issues given the size of the update, but if you encounter some, please let us know! This release was released using staged updates as a fixup, so you might get it with slight delay depending on your luck up to three days after the initial release.
This actually seems to have failed on my router. The device restarted a few times after the update and finally settled with an long notification:
update execution failed
Updater execution failed:
INFO:Detected existing journal. Trying to recover it.
INFO:Removing packages and leftover files
INFO:Running post-install and post-rm scripts
INFO:Running postinst of knot-resolver
Called /etc/init.d/kresd stop
remove dhcp script
job 6 at Wed Aug  7 15:36:00 2024
Called /etc/init.d/kresd start
remove dhcp script
resolver.kresd.hostname_config was already converted to list
+ '[' -z  ]
+ /etc/init.d/dnsmasq restart
udhcpc: started, v1.35.0
udhcpc: broadcasting discover
udhcpc: no lease, failing
+ sleep 2
+ uci -q get resolver.kresd.static_domains
+ stat_dom=
+ '[' '!' -z  ]
+ /etc/init.d/resolver restart
+ uci show resolver.kresd.hostname_config
uci: Entry not found
+ hostnames=
+ echo
+ + wc -c
tr -cd ''"'"
+ item_count=0
+ '[' 0 -gt 2 ]
+ '[' 0 '==' 0 ]
+ echo 'resolver.kresd.hostname_config was already converted to list'
+ uci -q get resolver.common.prefered_resolver
+ '[' kresd '=' kresd ]
+ uci -q get resolver.common.forward_upstream
+ egrep -q '(1|yes|true|enabled|on)'
+ ping -c 1 repo.turris.cz
INFO:Running postinst of kernel
INFO:Running postinst of kmod-nls-base
INFO:Running postinst of kmod-usb-core
INFO:Running postinst of kmod-usb-serial
INFO:Running postinst of kmod-usb-serial-wwan
INFO:Running postinst of kmod-usb-serial-qualcomm
INFO:Running postinst of kmod-ikconfig
INFO:Running postinst of hostapd-common
INFO:Running postinst of kmod-crypto-hash
INFO:Running postinst of kmod-crypto-null
INFO:Running postinst of kmod-crypto-gf128
INFO:Running postinst of kmod-crypto-ghash
INFO:Running postinst of kmod-crypto-sha256
INFO:Running postinst of kmod-crypto-aead
INFO:Running postinst of kmod-crypto-manager
INFO:Running postinst of kmod-crypto-hmac
INFO:Running postinst of kmod-crypto-rng
INFO:Running postinst of kmod-crypto-seqiv
INFO:Running postinst of kmod-crypto-ctr
INFO:Running postinst of kmod-crypto-gcm
INFO:Running postinst of kmod-crypto-ccm
INFO:Running postinst of kmod-crypto-cmac
INFO:Running postinst of wireless-regdb
INFO:Running postinst of kmod-cfg80211
INFO:Running postinst of kmod-mac80211
INFO:Running postinst of kmod-ath
INFO:Running postinst of kmod-ath9k-common
INFO:Running postinst of kmod-i2c-core
INFO:Running postinst of kmod-regmap-core
INFO:Running postinst of kmod-regmap-i2c
INFO:Running postinst of kmod-gpio-pca953x
INFO:Running postinst of kmod-eeprom-at24
INFO:Running postinst of kmod-i2c-mux
INFO:Running postinst of kmod-i2c-mux-pca954x
INFO:Running postinst of liblua
INFO:Running postinst of lua
INFO:Running postinst of kmod-ath10k
INFO:Running postinst of kmod-nf-conntrack
INFO:Running postinst of kmod-nf-flow
INFO:Running postinst of kmod-nf-log
INFO:Running postinst of kmod-nf-ipt
INFO:Running postinst of kmod-nf-reject
INFO:Running postinst of kmod-ipt-core
INFO:Running postinst of kmod-ipt-offload
INFO:Running postinst of kmod-usb-ehci
INFO:Running postinst of kmod-usb2
INFO:Running postinst of kmod-scsi-core
INFO:Running postinst of kmod-usb-storage
INFO:Running postinst of kmod-hwmon-core
INFO:Running postinst of kmod-thermal
INFO:Running postinst of kmod-mt76-core
INFO:Running postinst of kmod-mt76-connac
INFO:Running postinst of kmod-mt7615-common
INFO:Running postinst of kmod-mt7915e
INFO:Running postinst of kmod-br-netfilter
INFO:Running postinst of kmod-nf-nat
INFO:Running postinst of kmod-nf-nathelper
INFO:Running postinst of kmod-usb-storage-uas
INFO:Running postinst of kmod-ledtrig-gpio
INFO:Running postinst of kmod-turris-omnia-mcu
INFO:Running postinst of kmod-leds-turris-omnia
INFO:Running postinst of kmod-nf-log6
INFO:Running postinst of kmod-nf-ipt6
INFO:Running postinst of kmod-nf-reject6
INFO:Running postinst of kmod-ip6tables
INFO:Running postinst of kmod-ipt-nat
INFO:Running postinst of kmod-nf-conntrack6
INFO:Running postinst of kmod-ipt-conntrack
INFO:Running postinst of kmod-crypto-acompress
INFO:Running postinst of kmod-lib-zstd
INFO:Running postinst of kmod-lib-xor
INFO:Running postinst of kmod-lib-raid6
INFO:Running postinst of kmod-lib-zlib-deflate
INFO:Running postinst of kmod-lib-zlib-inflate
INFO:Running postinst of kmod-lib-lzo
INFO:Running postinst of kmod-crypto-crc32c
INFO:Running postinst of kmod-lib-crc32c
INFO:Running postinst of kmod-fs-btrfs
INFO:Running postinst of base-files
+ uci set 'updater.turris=turris'
+ uci set 'updater.turris.mode=branch'
+ uci set 'updater.turris.branch=hbs'
+ sed -i 's|https://repo\.turris\.cz/.*/\([^/]*\)/packages/|https://repo\.turris\.cz/hbs/\1/packages/|' /etc/opkg/distfeeds.conf
+ uci commit updater.turris
+ set +x
INFO:Running postinst of kmod-ledtrig-oneshot
INFO:Running postinst of kmod-ledtrig-transient
INFO:Running postinst of omnia-generic-support
INFO:Running postinst of kmod-usb-storage-extras
setting up led wan
setting up led pci1
setting up led pci2
setting up led pci3
setting up led wan
setting up led pci1
setting up led pci2
setting up led pci3
setting up led wan
setting up led pci1
setting up led pci2
setting up led pci3
setting up led wan
setting up led pci1
setting up led pci2
setting up led pci3
setting up led wan
setting up led pci1
setting up led pci2
setting up led pci3
setting up led wan
setting up led pci1
setting up led pci2
setting up led pci3
setting up led wan
setting up led pci1
setting up led pci2
setting up led pci3
setting up led wan
setting up led pci1
setting up led pci2
setting up led pci3
setting up led wan
setting up led pci1
setting up led pci2
setting up led pci3
setting up led wan
setting up led pci1
setting up led pci2
setting up led pci3
setting up led wan
setting up led pci1
setting up led pci2
setting up led pci3
setting up led wan
setting up led pci1
setting up led pci2
setting up led pci3
setting up led wan
setting up led pci1
setting up led pci2
setting up led pci3
setting up led wan
setting up led pci1
setting up led pci2
setting up led pci3
setting up led wan
setting up led pci1
setting up led pci2
setting up led pci3
setting up led wan
setting up led pci1
setting up led pci2
setting up led pci3
INFO:Running postinst of kmod-ipt-raw6
INFO:Running postinst of kmod-nf-nat6
INFO:Running postinst of kmod-ipt-nat6
INFO:Running postinst of kmod-iptunnel6
INFO:Running postinst of kmod-ip6-tunnel
INFO:Running postinst of luci-base
INFO:Running postinst of ddns-scripts-services
INFO:Running postinst of luci-mod-network
INFO:Running postinst of luci-mod-status
INFO:Running postinst of kmod-nfnetlink
INFO:Running postinst of kmod-ipt-ipset
INFO:Running postinst of luci-theme-bootstrap
INFO:Running postinst of wpad-openssl
INFO:Running postinst of kmod-nls-utf8
INFO:Running postinst of kmod-ata-core
INFO:Running postinst of kmod-ata-ahci
INFO:Running postinst of kmod-ipt-ipopt
INFO:Running postinst of kmod-ifb
INFO:Running postinst of kmod-sched-core
'radio0' is disabled
'radio1' is disabled
INFO:Running postinst of kmod-sched-cake
INFO:Running postinst of kmod-lib-crc-ccitt
INFO:Running postinst of kmod-slhc
INFO:Running postinst of kmod-ppp
INFO:Running postinst of kmod-netlink-diag
INFO:Running postinst of kmod-pppox
INFO:Running postinst of kmod-pppoe
INFO:Running postinst of kmod-iptunnel4
INFO:Running postinst of kmod-sit
INFO:Running postinst of kmod-nf-conntrack-netlink
INFO:Running postinst of kmod-nfnetlink-log
INFO:Running postinst of kmod-ipt-nflog
INFO:Running postinst of kmod-ebtables
INFO:Running postinst of kmod-udptunnel6
INFO:Running postinst of kmod-udptunnel4
INFO:Running postinst of kmod-crypto-kpp
INFO:Running postinst of kmod-crypto-lib-curve25519
INFO:Running postinst of kmod-crypto-lib-poly1305
INFO:Running postinst of kmod-crypto-lib-chacha20
INFO:Running postinst of kmod-crypto-lib-chacha20poly1305
INFO:Running postinst of kmod-wireguard
INFO:Running postinst of kmod-crypto-md5
INFO:Running postinst of turris-version
INFO:Running postinst of luci-i18n-base-en
/usr/lib/opkg/info//luci-i18n-base-en.postinst: .: line 2: can't open '/etc/uci-defaults/luci-i18n-base-en': No such file or directory
INFO:Running postinst of luci-i18n-bcp38-en
/usr/lib/opkg/info//luci-i18n-bcp38-en.postinst: .: line 2: can't open '/etc/uci-defaults/luci-i18n-bcp38-en': No such file or directory
INFO:Running postinst of luci-i18n-ahcp-en
/usr/lib/opkg/info//luci-i18n-ahcp-en.postinst: .: line 2: can't open '/etc/uci-defaults/luci-i18n-ahcp-en': No such file or directory
INFO:Running postinst of luci-i18n-commands-en
/usr/lib/opkg/info//luci-i18n-commands-en.postinst: .: line 2: can't open '/etc/uci-defaults/luci-i18n-commands-en': No such file or directory
INFO:Running postinst of luci-i18n-opkg-en
/usr/lib/opkg/info//luci-i18n-opkg-en.postinst: .: line 2: can't open '/etc/uci-defaults/luci-i18n-opkg-en': No such file or directory
INFO:Running postinst of luci-i18n-ddns-en
/usr/lib/opkg/info//luci-i18n-ddns-en.postinst: .: line 2: can't open '/etc/uci-defaults/luci-i18n-ddns-en': No such file or directory
INFO:Running postinst of luci-i18n-firewall-en
/usr/lib/opkg/info//luci-i18n-firewall-en.postinst: .: line 2: can't open '/etc/uci-defaults/luci-i18n-firewall-en': No such file or directory
INFO:Running postinst of luci-i18n-statistics-en
/usr/lib/opkg/info//luci-i18n-statistics-en.postinst: .: line 2: can't open '/etc/uci-defaults/luci-i18n-statistics-en': No such file or directory
INFO:Running postinst of luci-i18n-upnp-en
/usr/lib/opkg/info//luci-i18n-upnp-en.postinst: .: line 2: can't open '/etc/uci-defaults/luci-i18n-upnp-en': No such file or directory
INFO:Running postinst of luci-i18n-sqm-en
/usr/lib/opkg/info//luci-i18n-sqm-en.postinst: .: line 2: can't open '/etc/uci-defaults/luci-i18n-sqm-en': No such file or directory
INFO:Cleaning up control files
ERROR:
runtime: [string "requests"]:451: [string "utils"]:443: Unable to finish URI (https://repo.turris.cz/hbs/omnia/lists/pkglists/datacollect.lua): Download failed: Failed to connect to repo.turris.cz port 443 after 3 ms: Error
line not found
line not found
line not found
So I’m not sure if it updated or not. At least it’s not restarting anymore in the middle of a work day lol
TO 2016, HBS branch, 2 GB, 2x WiFi, HaaS, RIPE Atlas, Sentinel, lxc, SSD (logs etc), simple config, all seems OK.
Turris MOX classic, all fine.
Thanks.
Btw, how to stop those awesome updates and reboots during a day?
I have set (/reforis/package-management/update-settings) that automaticly install updates but restarts to be made at 5:30 (AM).
No matter if autoupdates or delay updates are there, the turris always reboots during the worst moment (meeting, multiplayers game, ssh seasson, …) gosh :frowning: :frowning:
Aug  7 16:15:45 xsoft-turris updater-supervisor: Running pkgupdate
Aug  7 16:15:49 xsoft-turris updater[8930]: repository.lua.lua:47 (Globals): Target Turris OS: 7.0.2
Hi @andrei,
I would like to ask you what was/is your previous version of TOS? (7.0.1, 7.0.0?), seems as unfinished update process.
Try to run: “pkgupdate --reinstall-all”
And let me please know if it is helps you.
Omnia - I can’t get to reForis, Luci, SSH. No ping to router. No internet access from LAN. I restarted router couple of times. No luck. Previous snapshot situation doesn’t solved. Only helps factory reset, flash to 7.0.2 through USB, sets params…
I had the same issue. Turris rebooted during online meetings etc…
So I have enabled the “Update approval needed” feature of “Package Management - Update settings” of reForis user interface.
Now I receive a mail notification that an update is available and I can act accordingly. When convenient, I log to reForis and approve the update in the “Updates” section of “Package Management”.
Not as smooth as automatic update at 3:00, but works for me.
Turris Omnia, update from 7.0.1 to 7.0.2.
No issues observed.
Thank you for the continuous support!
Had to rollback to 7.0.1.
Was at my lab when I lost VPN to Omnia at home. It didn’t come back. No access to LAN, very inconvenient. At home, Turris said reboot needed. Rebooted twice, no joy, WAN didn’t come up. Deleted ancient snapshots, just in case I was running out of space. Switched back to update approval. Rolled back to 7.0.1.
Update was auto-installed 7.0.2 again (the snapshot had the old config I guess). Manual reboot. Now it works.
Previous version was 7.0.1
I ran this and the device rebooted a lot of times from/during postinst hooks (I was watching with logread -f), but there’s no error message this time and AFAICT everything is fine. Thanks!
The device should definitely not restart without warning though.
Yes, rolling back switches everything, including configuration.
I saw new installed version 7.0.2 on my Turris 1.x, only needed action was reboot. After reboot all inside networks(VLANs-wired/wireless) lost connectivity to outside. Another reboot didn’t helped. Reforis overview for IP connectivity and IP getaway connectivity were OK. I noticed missing pkg/sw firewall, so I ran “pkgupdate --reinstall-all” and then all returned to normal.
Soo, observation here, this is supposed to be a fixup/small update, yet I’m seeing kernel packages getting updated. What’s up with that? @miska
I noticed the same. And its just different hash but the exact same version number. I skipped update for now on my main Omnia as I have to recompile kernel with one patch to have constant connectivity but good I noticed update mail and didnt allow the update. On the other Omnia acting as a AP I let it go and all seems ok.
Cant update to 7.0.2
root@hlogw:~# pkgupdate
WARN:Couldn't read the status file: [string "backend"]:1226: [string "backend"]:278: attempt to concatenate local 'pkg_name' (a nil value)
INFO:Target Turris OS: 7.0.2
WARN:Request not satisfied to install package: luci-app-banip
line not found
line not found
line not found
ERROR:
root@hlogw:~# pkgupdate -e DBG
DEBUG:src/lib/events.c:554 (run_util_init):Dumping busybox to: /tmp/updater-busybox-gAPmgh/busybox
DEBUG:src/lib/locks.c:45 (lua_acquire):Trying to get a lock at /var/lock/opkg.lock
DEBUG:backend.lua:394 (status_parse):Parsing status file /usr/lib/opkg/status
DEBUG:src/lib/locks.c:82 (lua_lock_release):Released lock at /var/lock/opkg.lock
WARN:sandbox.lua:113 (load_state_vars):Couldn't read the status file: [string "backend"]:1226: [string "backend"]:278: attempt to concatenate local 'pkg_name' (a nil value)
DEBUG:requests.lua:453 (Globals):Running script file:////etc/updater/conf.d/turris-pkglists.lua
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/pkglists/net_monitoring.lua)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/pkglists/net_monitoring.lua.sig)
DEBUG:src/lib/uri.c:606 (list_pubkey_collect):Unable to get pubkey file:///etc/updater/keys/test.pub: Unable to open local file for reading
DEBUG:requests.lua:453 (Globals):Running script https://repo.turris.cz/hbs/mox/lists/pkglists/net_monitoring.lua
DEBUG:requests.lua:339 (submit):Request install of librespeed-cli
DEBUG:requests.lua:339 (submit):Request install of dev-detect
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/pkglists/luci_controls.lua)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/pkglists/luci_controls.lua.sig)
DEBUG:requests.lua:453 (Globals):Running script https://repo.turris.cz/hbs/mox/lists/pkglists/luci_controls.lua
DEBUG:requests.lua:339 (submit):Request install of luci-app-ahcp
DEBUG:requests.lua:339 (submit):Request install of luci-app-bcp38
DEBUG:requests.lua:339 (submit):Request install of luci-proto-relay
DEBUG:requests.lua:339 (submit):Request install of luci-app-tinyproxy
DEBUG:requests.lua:339 (submit):Request install of luci-app-upnp
DEBUG:requests.lua:339 (submit):Request install of luci-app-wireguard
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/pkglists/hardening.lua)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/pkglists/hardening.lua.sig)
DEBUG:requests.lua:453 (Globals):Running script https://repo.turris.cz/hbs/mox/lists/pkglists/hardening.lua
DEBUG:requests.lua:339 (submit):Request install of common_passwords
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/pkglists/datacollect.lua)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/pkglists/datacollect.lua.sig)
DEBUG:requests.lua:453 (Globals):Running script https://repo.turris.cz/hbs/mox/lists/pkglists/datacollect.lua
DEBUG:requests.lua:339 (submit):Request install of turris-survey
DEBUG:requests.lua:339 (submit):Request install of sentinel-dynfw-client
DEBUG:requests.lua:339 (submit):Request install of sentinel-fwlogs
DEBUG:requests.lua:339 (submit):Request install of sentinel-minipot
DEBUG:requests.lua:339 (submit):Request install of haas-proxy
DEBUG:requests.lua:453 (Globals):Running script file:////etc/updater/conf.d/turris.lua
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/release_date)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/release_date.sig)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/base.lua)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/base.lua.sig)
DEBUG:requests.lua:453 (Globals):Running script https://repo.turris.cz/hbs/mox/lists/base.lua
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/repository.lua)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/repository.lua.sig)
DEBUG:requests.lua:453 (Globals):Running script repository.lua
INFO:repository.lua.lua:47 (Globals):Target Turris OS: 7.0.2
DEBUG:repository.lua.lua:48 (Globals):Current Turris OS: 7.0.0
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/updater.lua)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/updater.lua.sig)
DEBUG:requests.lua:453 (Globals):Running script updater.lua
DEBUG:requests.lua:339 (submit):Request install of updater-ng
DEBUG:requests.lua:339 (submit):Request install of updater-supervisor
DEBUG:requests.lua:339 (submit):Request install of updater-drivers
DEBUG:requests.lua:339 (submit):Request install of updater-opkg-wrapper
DEBUG:requests.lua:339 (submit):Request install of switch-branch
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/base-min.lua)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/base-min.lua.sig)
DEBUG:requests.lua:453 (Globals):Running script base-min.lua
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/base-fix.lua)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/base-fix.lua.sig)
DEBUG:requests.lua:453 (Globals):Running script base-fix.lua
DEBUG:requests.lua:339 (submit):Request install of fix-updater-v65.0-alternatives-update
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/migrate5x.lua)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/migrate5x.lua.sig)
DEBUG:requests.lua:453 (Globals):Running script migrate5x.lua
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/base-conditional.lua)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/base-conditional.lua.sig)
DEBUG:requests.lua:453 (Globals):Running script base-conditional.lua
DEBUG:requests.lua:339 (submit):Request install of openvpn-hotplug
DEBUG:requests.lua:339 (submit):Request install of kmod-ath9k
DEBUG:requests.lua:339 (submit):Request install of kmod-ath10k
DEBUG:requests.lua:339 (submit):Request install of kmod-mt7915e
DEBUG:requests.lua:339 (submit):Request install of kmod-ipt-offload
DEBUG:requests.lua:339 (submit):Request install of kmod-nf-flow
DEBUG:requests.lua:339 (submit):Request install of kmod-nf-nathelper
DEBUG:requests.lua:339 (submit):Request install of kmod-br-netfilter
DEBUG:requests.lua:339 (submit):Request install of kmod-usb2
DEBUG:requests.lua:339 (submit):Request install of kmod-usb-storage
DEBUG:requests.lua:339 (submit):Request install of kmod-usb-storage-uas
DEBUG:requests.lua:339 (submit):Request install of kmod-usb-storage-extras
DEBUG:requests.lua:339 (submit):Request install of kmod-ikconfig
DEBUG:requests.lua:339 (submit):Request install of kmod-i2c-pxa
DEBUG:requests.lua:339 (submit):Request install of kmod-rtc-ds1307
DEBUG:requests.lua:339 (submit):Request install of kmod-gpio-button-hotplug
DEBUG:requests.lua:339 (submit):Request install of kmod-mwlwifi
DEBUG:requests.lua:339 (submit):Request install of kmod-mwifiex-sdio
DEBUG:requests.lua:339 (submit):Request install of kmod-btmrvl
DEBUG:requests.lua:339 (submit):Request install of mox-support
DEBUG:requests.lua:339 (submit):Request install of zram-swap
DEBUG:requests.lua:339 (submit):Request install of fstools
DEBUG:requests.lua:339 (submit):Request install of base-files
DEBUG:requests.lua:339 (submit):Request install of busybox
DEBUG:requests.lua:339 (submit):Request install of procd
DEBUG:requests.lua:339 (submit):Request install of ubus
DEBUG:requests.lua:339 (submit):Request install of uci
DEBUG:requests.lua:339 (submit):Request install of netifd
DEBUG:requests.lua:339 (submit):Request install of firewall
DEBUG:requests.lua:339 (submit):Request install of dns-resolver
DEBUG:requests.lua:339 (submit):Request install of ebtables
DEBUG:requests.lua:339 (submit):Request install of dnsmasq-full
DEBUG:requests.lua:339 (submit):Request install of odhcpd
DEBUG:requests.lua:339 (submit):Request install of odhcp6c
DEBUG:requests.lua:339 (submit):Request install of urandom-seed
DEBUG:requests.lua:339 (submit):Request install of turris-defaults
DEBUG:requests.lua:339 (submit):Request install of cronie
DEBUG:requests.lua:339 (submit):Request install of syslog-ng
DEBUG:requests.lua:339 (submit):Request install of logrotate
DEBUG:requests.lua:339 (submit):Request install of knot-resolver
DEBUG:requests.lua:339 (submit):Request install of dnssec-rootkey
DEBUG:requests.lua:339 (submit):Request install of cznic-repo-keys
DEBUG:requests.lua:339 (submit):Request install of ca-certificates
DEBUG:requests.lua:339 (submit):Request install of ppp
DEBUG:requests.lua:339 (submit):Request install of ppp-mod-pppoe
DEBUG:requests.lua:339 (submit):Request install of ds-lite
DEBUG:requests.lua:339 (submit):Request install of 6in4
DEBUG:requests.lua:339 (submit):Request install of 6rd
DEBUG:requests.lua:339 (submit):Request install of ip-full
DEBUG:requests.lua:339 (submit):Request install of tc
DEBUG:requests.lua:339 (submit):Request install of genl
DEBUG:requests.lua:339 (submit):Request install of ip-bridge
DEBUG:requests.lua:339 (submit):Request install of ss
DEBUG:requests.lua:339 (submit):Request install of nstat
DEBUG:requests.lua:339 (submit):Request install of devlink
DEBUG:requests.lua:339 (submit):Request install of rdma
DEBUG:requests.lua:339 (submit):Request install of iputils-ping
DEBUG:requests.lua:339 (submit):Request install of iputils-tracepath
DEBUG:requests.lua:339 (submit):Request install of iptables
DEBUG:requests.lua:339 (submit):Request install of ip6tables
DEBUG:requests.lua:339 (submit):Request install of conntrack
DEBUG:requests.lua:339 (submit):Request install of bind-client
DEBUG:requests.lua:339 (submit):Request install of bind-dig
DEBUG:requests.lua:339 (submit):Request install of umdns
DEBUG:requests.lua:339 (submit):Request install of shadow
DEBUG:requests.lua:339 (submit):Request install of shadow-utils
DEBUG:requests.lua:339 (submit):Request install of uboot-envtools
DEBUG:requests.lua:339 (submit):Request install of i2c-tools
DEBUG:requests.lua:339 (submit):Request install of openssh-server
DEBUG:requests.lua:339 (submit):Request install of openssh-sftp-server
DEBUG:requests.lua:339 (submit):Request install of openssh-moduli
DEBUG:requests.lua:339 (submit):Request uninstall of dropbear
DEBUG:requests.lua:339 (submit):Request install of pciutils
DEBUG:requests.lua:339 (submit):Request install of usbutils
DEBUG:requests.lua:339 (submit):Request install of lsof
DEBUG:requests.lua:339 (submit):Request install of btrfs-progs
DEBUG:requests.lua:339 (submit):Request install of lm-sensors
DEBUG:requests.lua:339 (submit):Request install of turris-version
DEBUG:requests.lua:339 (submit):Request install of start-indicator
DEBUG:requests.lua:339 (submit):Request install of turris-utils
DEBUG:requests.lua:339 (submit):Request install of user-notify
DEBUG:requests.lua:339 (submit):Request install of watchdog_adjust
DEBUG:requests.lua:339 (submit):Request install of turris-diagnostics
DEBUG:requests.lua:339 (submit):Request install of turris-diagnostics-web
DEBUG:requests.lua:339 (submit):Request install of rainbow
DEBUG:requests.lua:339 (submit):Request install of mox-otp
DEBUG:requests.lua:339 (submit):Request install of schnapps
DEBUG:requests.lua:339 (submit):Request install of turris-snapshots-web
DEBUG:requests.lua:339 (submit):Request install of hostapd-common
DEBUG:requests.lua:339 (submit):Request install of wireless-tools
DEBUG:requests.lua:339 (submit):Request install of wpad-openssl
DEBUG:requests.lua:339 (submit):Request install of iw
DEBUG:requests.lua:339 (submit):Request install of iwinfo
DEBUG:requests.lua:339 (submit):Request install of kmod-ath10k-ct
DEBUG:requests.lua:339 (submit):Request install of mwifiex-sdio-firmware
DEBUG:requests.lua:339 (submit):Request install of ath10k-firmware-qca988x-ct
DEBUG:requests.lua:339 (submit):Request install of zoneinfo-core
DEBUG:requests.lua:339 (submit):Request install of zoneinfo-atlantic
DEBUG:requests.lua:339 (submit):Request install of zoneinfo-asia
DEBUG:requests.lua:339 (submit):Request install of zoneinfo-africa
DEBUG:requests.lua:339 (submit):Request install of zoneinfo-australia-nz
DEBUG:requests.lua:339 (submit):Request install of zoneinfo-europe
DEBUG:requests.lua:339 (submit):Request install of zoneinfo-northamerica
DEBUG:requests.lua:339 (submit):Request install of zoneinfo-india
DEBUG:requests.lua:339 (submit):Request install of zoneinfo-pacific
DEBUG:requests.lua:339 (submit):Request install of zoneinfo-poles
DEBUG:requests.lua:339 (submit):Request install of zoneinfo-simple
DEBUG:requests.lua:339 (submit):Request install of zoneinfo-southamerica
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/luci.lua)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/luci.lua.sig)
DEBUG:requests.lua:453 (Globals):Running script luci.lua
DEBUG:requests.lua:339 (submit):Request install of luci-base
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-base-en
DEBUG:requests.lua:339 (submit):Request install of luci-mod-dashboard
DEBUG:requests.lua:339 (submit):Request install of luci-app-commands
DEBUG:requests.lua:339 (submit):Request install of luci-proto-ipv6
DEBUG:requests.lua:339 (submit):Request install of luci-proto-ppp
DEBUG:requests.lua:339 (submit):Request install of resolver-debug
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-acl-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-acme-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-adblock-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-advanced-reboot-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-ahcp-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-aria2-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-attendedsysupgrade-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-banip-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-bcp38-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-bmx7-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-clamav-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-commands-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-cshark-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-dcwapd-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-ddns-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-diag-core-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-dnscrypt-proxy-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-dockerman-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-dump1090-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-dynapoint-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-eoip-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-firewall-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-frpc-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-frps-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-fwknopd-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-hd-idle-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-https-dns-proxy-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-ksmbd-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-lxc-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-minidlna-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-mjpg-streamer-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-mwan3-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-nextdns-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-nft-qos-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-nlbwmon-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-ntpc-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-nut-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-ocserv-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-olsr-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-omcproxy-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-openvpn-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-opkg-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-p910nd-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-pagekitec-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-polipo-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-privoxy-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-qos-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-radicale-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-radicale2-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-rp-pppoe-server-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-samba4-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-ser2net-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-shadowsocks-libev-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-shairplay-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-simple-adblock-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-smartdns-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-splash-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-sqm-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-squid-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-statistics-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-tinyproxy-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-transmission-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-travelmate-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-ttyd-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-udpxy-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-uhttpd-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-unbound-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-upnp-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-vnstat-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-vnstat2-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-vpnbypass-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-pbr-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-watchcat-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-wifischedule-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-wireguard-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-wol-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-xinetd-en
DEBUG:requests.lua:339 (submit):Request install of luci-i18n-yggdrasil-en
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/foris.lua)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/foris.lua.sig)
DEBUG:requests.lua:453 (Globals):Running script foris.lua
DEBUG:requests.lua:339 (submit):Request install of lighttpd-https-cert
DEBUG:requests.lua:339 (submit):Request install of reforis
DEBUG:requests.lua:339 (submit):Request install of reforis-storage-plugin
DEBUG:requests.lua:339 (submit):Request install of reforis-netboot-plugin
DEBUG:requests.lua:339 (submit):Request install of reforis-openvpn-plugin
DEBUG:requests.lua:339 (submit):Request install of reforis-data-collection-plugin
DEBUG:requests.lua:339 (submit):Request install of reforis-haas-plugin
DEBUG:requests.lua:339 (submit):Request install of reforis-nextcloud-plugin
DEBUG:requests.lua:339 (submit):Request install of reforis-netmetr-plugin
DEBUG:requests.lua:339 (submit):Request install of reforis-diagnostics-plugin
DEBUG:requests.lua:339 (submit):Request install of reforis-snapshots-plugin
DEBUG:requests.lua:339 (submit):Request install of reforis-librespeed-plugin
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/terminal-apps.lua)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/terminal-apps.lua.sig)
DEBUG:requests.lua:453 (Globals):Running script terminal-apps.lua
DEBUG:requests.lua:339 (submit):Request install of turris-motd
DEBUG:requests.lua:339 (submit):Request install of bash
DEBUG:requests.lua:339 (submit):Request install of terminfo
DEBUG:requests.lua:339 (submit):Request install of vim-full
DEBUG:requests.lua:339 (submit):Request install of coreutils
DEBUG:requests.lua:339 (submit):Request install of diffutils
DEBUG:requests.lua:339 (submit):Request install of openssl-util
DEBUG:requests.lua:339 (submit):Request install of htop
DEBUG:requests.lua:339 (submit):Request install of psmisc
DEBUG:requests.lua:339 (submit):Request install of procps-ng-top
DEBUG:requests.lua:339 (submit):Request install of procps-ng-ps
DEBUG:requests.lua:339 (submit):Request install of curl
DEBUG:requests.lua:339 (submit):Request install of wget-ssl
DEBUG:requests.lua:339 (submit):Request install of tcpdump
DEBUG:requests.lua:339 (submit):Request install of rsync
DEBUG:requests.lua:339 (submit):Request install of partx-utils
DEBUG:requests.lua:339 (submit):Request install of blkid
DEBUG:requests.lua:339 (submit):Request install of lsblk
DEBUG:requests.lua:339 (submit):Request install of openssh-client
DEBUG:requests.lua:339 (submit):Request install of openssh-client-utils
DEBUG:requests.lua:339 (submit):Request install of openssh-sftp-client
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/webapps.lua)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/webapps.lua.sig)
DEBUG:requests.lua:453 (Globals):Running script webapps.lua
DEBUG:requests.lua:339 (submit):Request install of turris-webapps
DEBUG:requests.lua:339 (submit):Request install of turris-webapps-syncthing
DEBUG:requests.lua:339 (submit):Request install of turris-webapps-luci
DEBUG:requests.lua:339 (submit):Request install of turris-webapps-tvheadend
DEBUG:requests.lua:339 (submit):Request install of turris-webapps-netdata
DEBUG:requests.lua:339 (submit):Request install of turris-webapps-nextcloud
DEBUG:requests.lua:339 (submit):Request install of turris-webapps-transmission
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/localization.lua.sig)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/localization.lua)
DEBUG:requests.lua:453 (Globals):Running script localization.lua
DEBUG:requests.lua:339 (submit):Request install of opkg
DEBUG:requests.lua:339 (submit):Request install of libustream-openssl
DEBUG:requests.lua:339 (submit):Request uninstall of wget-nossl
DEBUG:requests.lua:453 (Globals):Running script file:////etc/updater/conf.d/example.lua
DEBUG:requests.lua:453 (Globals):Running script file:////etc/updater/conf.d/drivers.lua
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/drivers/usb.lua)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/drivers/usb.lua.sig)
DEBUG:requests.lua:453 (Globals):Running script https://repo.turris.cz/hbs/mox/lists/drivers/usb.lua
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/drivers/classes.lua)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/drivers/classes.lua.sig)
DEBUG:requests.lua:453 (Globals):Running script classes.lua
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/drivers/pci.lua)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/drivers/pci.lua.sig)
DEBUG:requests.lua:453 (Globals):Running script https://repo.turris.cz/hbs/mox/lists/drivers/pci.lua
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/drivers/sdio.lua)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/lists/drivers/sdio.lua.sig)
DEBUG:requests.lua:453 (Globals):Running script https://repo.turris.cz/hbs/mox/lists/drivers/sdio.lua
DEBUG:requests.lua:453 (Globals):Running script file:////etc/updater/conf.d/opkg.lua
DEBUG:requests.lua:453 (Globals):Running script file:////etc/updater/conf.d/localrepo.lua
DEBUG:requests.lua:453 (Globals):Running script file:////etc/updater/conf.d/switch-branch.lua
DEBUG:requests.lua:453 (Globals):Running script file:////etc/updater/conf.d/opkg-auto.lua
DEBUG:requests.lua:339 (submit):Request install of mc
DEBUG:requests.lua:339 (submit):Request install of luci-proto-wireguard
DEBUG:requests.lua:339 (submit):Request install of nmap
DEBUG:requests.lua:339 (submit):Request install of nping
DEBUG:requests.lua:339 (submit):Request install of moreutils
DEBUG:requests.lua:339 (submit):Request install of procps-ng-watch
DEBUG:requests.lua:339 (submit):Request install of prometheus-node-exporter-lua
DEBUG:requests.lua:339 (submit):Request install of prometheus-node-exporter-lua-openwrt
DEBUG:requests.lua:339 (submit):Request install of prometheus-node-exporter-lua-textfile
DEBUG:requests.lua:339 (submit):Request install of prometheus-node-exporter-lua-uci_dhcp_host
DEBUG:requests.lua:339 (submit):Request install of prometheus-node-exporter-lua-wifi
DEBUG:requests.lua:339 (submit):Request install of prometheus-node-exporter-lua-wifi_stations
DEBUG:requests.lua:339 (submit):Request install of iftop
DEBUG:requests.lua:339 (submit):Request install of turris-nor-update
DEBUG:requests.lua:339 (submit):Request install of noping
DEBUG:requests.lua:339 (submit):Request install of luci-app-banip
DEBUG:postprocess.lua:88 (get_repos):Downloading repositories indexes
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/packages/node/Packages.sig)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/packages/base/Packages.sig)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/packages/routing/Packages)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/packages/luci/Packages.sig)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/packages/cesnet/Packages.sig)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/packages/packages/Packages.sig)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/packages/turrispackages/Packages.sig)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/packages/routing/Packages.sig)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/packages/cesnet/Packages)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/packages/node/Packages)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/packages/telephony/Packages.sig)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/packages/core/Packages.sig)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/packages/base/Packages)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/packages/turrispackages/Packages)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/packages/luci/Packages)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/packages/telephony/Packages)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/packages/packages/Packages)
DEBUG:src/lib/download.c:78 (download_check_info):Download succesfull (https://repo.turris.cz/hbs/mox/packages/core/Packages)
DEBUG:postprocess.lua:52 (Globals):Parsing index luci/https://repo.turris.cz/hbs/mox/packages/luci/Packages
DEBUG:postprocess.lua:52 (Globals):Parsing index packages/https://repo.turris.cz/hbs/mox/packages/packages/Packages
DEBUG:postprocess.lua:52 (Globals):Parsing index routing/https://repo.turris.cz/hbs/mox/packages/routing/Packages
DEBUG:postprocess.lua:52 (Globals):Parsing index core/https://repo.turris.cz/hbs/mox/packages/core/Packages
DEBUG:postprocess.lua:52 (Globals):Parsing index cesnet/https://repo.turris.cz/hbs/mox/packages/cesnet/Packages
DEBUG:postprocess.lua:52 (Globals):Parsing index turrispackages/https://repo.turris.cz/hbs/mox/packages/turrispackages/Packages
DEBUG:postprocess.lua:52 (Globals):Parsing index telephony/https://repo.turris.cz/hbs/mox/packages/telephony/Packages
DEBUG:postprocess.lua:52 (Globals):Parsing index base/https://repo.turris.cz/hbs/mox/packages/base/Packages
DEBUG:postprocess.lua:52 (Globals):Parsing index node/https://repo.turris.cz/hbs/mox/packages/node/Packages
DEBUG:postprocess.lua:293 (pkg_aggregate):Aggregating packages together
DEBUG:planner.lua:566 (Globals):Resolving Install and Uninstall requests
DEBUG:planner.lua:578 (Globals):Denying packages without any candidate
DEBUG:planner.lua:585 (Globals):Forcing penalty on expressions with free alternatives
DEBUG:planner.lua:597 (Globals):Deducing minimal set of required packages
WARN:planner.lua:498 (Globals):Request not satisfied to install package: luci-app-banip
line not found
line not found
line not found
ERROR:src/pkgupdate/main.c:151 (main):
DEBUG:src/lib/events.c:572 (run_util_clean):Removing temporally busybox from: /tmp/updater-busybox-gAPmgh/busybox
Could be that a small bugfix is being done in the kernel source. These happen on other operating systems all the time. Nothing to worry about.
On another note; Ran the update on my Turris Omnia and everything is fine.
We did not change anything related to the kernel, but some changes were made in OpenWrt. So this is most likely related to this. It is still considered a small fixup release for us, as we only changed a few things.
7.0.2 RC1 → 7.0.2 update okay (even kresd6 works again). No noticeable cable/wifi/internet interruption. Restart was needed.
Turris Omnia 2017, 1 GB RAM, dead eMMC, system running from mSATA SSD, original wifi cards, UBoot 2022.10. Storage plugin enabled, LXC containers, tor relay, USB HDD shared over samba4 and minidlna, Syncthing, SQM, Hardwario gateway + MQTT IoT bridge, OpenVPN, PPtP VPN, Strongswan IKEv2 VPN, morce, kresd6.
