Okay, so I’ve put my second Indiegogo 1GB Omnia on a serial cable and ran the update including all the firmware goodies, one by one. In bold, I emphasize things I consider to be issues to be looked into by the team.
1. Initial state:
$ strings /dev/mtd0 | grep 'U-Boot 20'
U-Boot 2015.10-rc2 for db-88f682
U-Boot 2015.10-rc2 (Aug 18 2016 - 20:43:35 +0200)
$ sha256sum /dev/mtd0
c3fcbb64d3c24ab04954af4db8d5bd9414f3163cdaf506f2c6fb056169c1b833 /dev/mtd0
$ sha256sum /dev/mtd1
323914a0504700d23b5bf96fcd5fa899441f5a86f2335c7be5734af8cb088409 /dev/mtd1
$ schnapps factory-version
5.0.0
I first switched to HBT without selecting any new package lists and rebooted. No issues as expected.
2. I checked the “Latest firmware” meta checkbox in Reforis and nothing else, installed the packages and rebooted.
No issues, but no firmware update (as expected).
3. I checked “Factory image”.
Nothing happened. This one doesn’t install any packages on its behalf, so the postupdate hook did not run.
This is a bit unexpected, but will rectify itself with any following update or package install.
I ran the postupdate hook manually. After that,
6.4.4
So the postupdate hook updated the schnappshot to latest stable TOS version, while leaving the rescue image the same (as expected).
After reboot everything okay.
4. I checked “MCU” and installed the packages.
It went well, but the LEDs were left in a very unusual blinking pattern. The blinking pattern stopped at reboot. However, there was not “reboot needed” notifiaction generated by the MCU package list (I think it should be in case an update of the MCU actually happened).
The first boot attempt failed at DDR training (@mbehun):
U-Boot SPL 2015.10-rc2 (Aug 18 2016 - 20:43:35)
High speed PHY - Version: 2.0
SERDES0 card detect: SATA
Initialize Turris board topology
Detected Device ID 6820
board SerDes lanes topology details:
| Lane # | Speed | Type |
| 0 | 6 | SATA0 |
| 1 | 5 | USB3 HOST0 |
| 2 | 5 | PCIe1 |
| 3 | 5 | USB3 HOST1 |
| 4 | 5 | PCIe2 |
| 5 | 0 | SGMII2 |
poll_op_execute: TIMEOUT
:** Link is Gen1, check the EP capability
PCIe, Idx 1: remains Gen1
PCIe, Idx 2: remains Gen1
DDR3 Training Sequence - Ver TIP-1.29.0
Memory config in EEPROM: 0x01
ddr3_tip_pbs_rx failure CS #0
Title: I/F# , Tj, Calibration_n0, Calibration_p0, Calibration_n1, Calibration_p1, Calibration_n2, Calibration_p2,CS0 ,
VWTx, VWRx, WL_tot, WL_ADLL, WL_PH, RL_Tot, RL_ADLL, RL_PH, RL_Smp, Cen_tx, Cen_rx, Vref, DQVref, PBSTx-Pad0,PBSTx-Pad1,PBSTx-Pad2,PBSTx-Pad3,PBSTx-Pad4,PBSTx-Pad5,PBSTx-Pad6,PBSTx-Pad7,PBSTx-Pad8,PBSTx-Pad9,PBSTx-Pad10, PBSRx-Pad0,PBSRx-Pad1,PBSRx-Pad2,PBSRx-Pad3,PBSRx-Pad4,PBSRx-Pad5,PBSRx-Pad6,PBSRx-Pad7,PBSRx-Pad8,PBSRx-Pad9,PBSRx-Pad10,
Data: 0,75,19,15,20,17,20,20,CS0 ,
0,0,10,10,0,422,6,1,6,23,10,4,0, 63,63,63,63,31,31,63,63,63,63,63, 0,0,0,0,0,0,0,0,0,0,0, 0,0,0,0,0,0,0,0,0,0,0,
0,0,6,6,0,420,4,1,6,19,10,4,0, 63,63,63,63,31,31,63,63,63,63,63, 0,0,0,0,0,0,0,0,0,0,0, 0,2,2,8,0,0,5,8,8,8,0,
0,0,6,6,0,419,3,1,6,19,10,4,0, 63,63,63,63,31,31,63,63,63,63,63, 0,0,0,0,0,0,0,0,0,0,0, 3,1,1,9,0,0,0,1,6,6,0,
0,0,10,10,0,422,6,1,6,23,10,4,0, 63,63,63,63,31,31,63,63,63,63,63, 0,0,0,0,0,0,0,0,0,0,0, 0,1,0,0,0,0,0,0,0,0,0,
Run_alg: tuning failed 0
DDR3 run algorithm - FAILED 0x1
DDR3 Training Sequence - FAILED
<<< 30 second wait here, the watchdog kicked in automatically >>>
| 0 | 6 | SATA0 |
| 2 | 5 | PCIe1 |
| 4 | 5 | PCIe2 |
| 5 | 0 | SGMII2 |
DDR3 Training Sequence - Switching XBAR Window to FastPath Window
DDR3 Training Sequence - Ended Successfully
U-Boot 2015.10-rc2 (Aug 18 2016 - 20:43:35 +0200), Build: jenkins-omnia-master-23
SoC: MV88F6820-A0
Watchdog enabled
I2C: ready
SPI: ready
DRAM: 1 GiB (ECC not enabled)
Enabling Armada 385 watchdog.
Disabling MCU startup watchdog.
Regdomain set to **
MMC: mv_sdh: 0
SF: Detected S25FL164K with page size 256 Bytes, erase size 64 KiB, total 8 MiB
PCI:
00:01.0 - 168c:003c - Network controller
PCI:
01:00.0 - 11ab:6820 - Memory controller
01:01.0 - 168c:002e - Network controller
Model: Marvell Armada 385 GP
Board: Turris Omnia SN: 0000000B000061B6
Regdomain set to **
SCSI: MVEBU SATA INIT
Target spinup took 0 ms.
SATA link 1 timeout.
AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
flags: 64bit ncq led only pmp fbss pio slum part sxs
Net: neta2
Hit any key to stop autoboot: 0
Setting bus to 1
BOOT eMMC FS
scanning bus for devices...
Device 0: (0:0) Vendor: ATA Prod.: KINGSTON SUV500M Rev: 0030
Type: Hard Disk
Capacity: 114473.4 MB = 111.7 GB (234441648 x 512)
Found 1 device(s).
BtrFS init: Max node or leaf size 16384
4331048 bytes read in 152 ms (27.2 MiB/s)
21434 bytes read in 108 ms (193.4 KiB/s)
Kernel image @ 0x1000000 [ 0x000000 - 0x421628 ]
## Flattened Device Tree blob at 02000000
Booting using the fdt blob at 0x2000000
Loading Device Tree to 0fff7000, end 0ffff3b9 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.15.142 (packaging@turris.cz) (arm-openwrt-linux-muslgnueabi-gcc (OpenWrt GCC 8.4.0 r16881+135-4a1d8ef55c) 8.4.0, GNU ld (GNU Binutils) 2.34) #0 SMP Thu Dec 21 07:34:52 2023
[ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Turris Omnia
<<< Normal boot followed >>>
5. I checked “U-Boot and rescue image” and installed the packages.
When the update finished, all LEDs went dark (0% brightness), but the router normally ran. After a reboot, the LEDs remained dark, but the router booted without any other issues.
I’ve manually adjusted the LED brightness using the button, which brought them to life, but all of them were white (I waited for a few minutes, still all white).
After another reboot, LEDs finally worked as they should.
Also:
U-Boot 2022.10-rc4-OpenWrt-r16653+119-44ce70f0e2 (Sep 15 2022 - 18:21:35 +0000)
f1c7561ca24a6ecec8ad6f30ca488587c002092bd0654b1c853ed2581b092b29 /dev/mtd0
76c6b46ca5e48d38f105d62d06ccfcf7fd107439ce535c21f02c302c4e9d64b3 /dev/mtd1
$ omnia-mcutool -v
Bootloader version: b5a8a24e007eb72be16aeb3fff6f03ec647023e4
Application version: 67eddc9540526d0a9d9660f7a7867af9a28a68d6
MCU type: STM32
Board firmware type: stm32-rev23-user-regulator
Features: 0x1f6e
EXT_CMDS
WDT_PING
LED_STATE_EXT
LED_GAMMA_CORRECTION
NEW_INT_API
FLASHING
NEW_MESSAGE_API
BRIGHTNESS_INT
POWEROFF_WAKEUP
CAN_OLD_MESSAGE_API
Application firmware length: 21400 Bytes
Application firmware checksum: 0xfeeb0f31
$ fw_printenv
Warning: Bad CRC, using default environment
bootcmd=bootp; setenv bootargs root=/dev/nfs nfsroot=${serverip}:${rootpath} ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off; bootm
bootdelay=5
baudrate=115200
Yes, fw_printenv
doesn’t work after the update. I tried all of these combinations in /etc/fw_env.config
/dev/mtd0 0xc0000 0x10000 0x40000
/dev/mtd0 0xf0000 0x10000 0x10000
/dev/mtd2 0x0 0x10000 0x10000
Does it mean the firmware upgrade did not migrate my custom SSD boot environment and uses the default (but how could the router boot from the SSD then)? I no longer have the serial cable attached, so can’t check or call saveenv
manually in U-Boot.
Differences to the update of my other Omnia
- Wifi interfaces did not get renamed (I have the same mPCIe cards in the same order in both routers).
- No problem with BTRFS partitions vs. U-Boot. But on the second Omnia, I have only a single partition on the SSD, and that was not found to be problematic.
