Tried, but OS6.5.1 and 6.5.2 are kernel panicking on Turris 1.1
U-Boot 2015.04-04654-gbcfb33e-dirty (Jun 26 2015 - 12:50:49)
CPU0: P2020E, Version: 2.1, (0x80ea0021)
Core: e500, Version: 5.1, (0x80211051)
Clock Configuration:
CPU0:1200 MHz, CPU1:1200 MHz,
CCB:600 MHz,
DDR:400 MHz (800 MT/s data rate) (Asynchronous), LBC:37.500 MHz
L1: D-cache 32 KiB enabled
I-cache 32 KiB enabled
wdt status 00000005 reset
Watchdog enabled
Board: TURRIS CPLD: V4.1 PCBA: V4.0
Error, wrong i2c adapter 2 max 2 possible
in: 200
out: 0
io_config: 255
rom_loc: nor upper bank
SD/MMC : 4-bit Mode
eSPI : Enabled
I2C: Error, wrong i2c adapter 2 max 2 possible
ready
SPI: ready
DRAM: Error, wrong i2c adapter 2 max 2 possible
Detected UDIMM 9905594-009.A00LF
WARNING: Calling __hwconfig without a buffer and before environment is ready
2 GiB (DDR3, 64-bit, CL=6, ECC off)
Flash: 16 MiB
L2: 512 KiB enabled
NAND: 256 MiB
MMC: FSL_SDHC: 0
PCIe1: Root Complex of mini PCIe SLOT, x1 gen1, regs @ 0xffe0a000
01:00.0 - 168c:003c - Network controller
PCIe1: Bus 00 - 01
PCIe2: Root Complex of PCIe SLOT, x1 gen1, regs @ 0xffe09000
03:00.0 - 168c:0030 - Network controller
PCIe2: Bus 02 - 03
PCIe3: Root Complex of PCIe SLOT, x1 gen1, regs @ 0xffe08000
05:00.0 - 104c:8241 - Serial bus controller
PCIe3: Bus 04 - 05
In: serial
Out: serial
Err: serial
Net: Phy 5 not found
PHY reset timed out
eTSEC1
Error: eTSEC1 address not set.
, eTSEC2
Error: eTSEC2 address not set.
, eTSEC3 [PRIME]
Error: eTSEC3 address not set.
Hit any key to stop autoboot: 1 0
BOOT NAND
reading zImage
5929661 bytes read in 264 ms (21.4 MiB/s)
wdt status 00000003
reading fdt
13731 bytes read in 14 ms (957 KiB/s)
WARNING: adjusting available memory to 30000000
## Booting kernel from Legacy Image at 02100000 ...
Image Name: Linux-5.15.147
Created: 2024-02-14 8:12:14 UTC
Image Type: PowerPC Linux Kernel Image (gzip compressed)
Data Size: 5929597 Bytes = 5.7 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 02000000
Booting using the fdt blob at 0x2000000
Uncompressing Kernel Image ... OK
Loading Device Tree to 03ff9000, end 03fff5a2 ... OK
WARNING: could not find compatible node fsl-usb2-dr
[ 0.000000] Memory CAM mapping: 256/256/256 Mb, residual: 1280Mb
[ 0.000000] Linux version 5.15.147 (packaging@turris.cz) (powerpc-openwrt-linux-muslspe-gcc (OpenWrt GCC 8.4.0 r16881+135-4a1d8ef55c) 8.4.0, GNU ld (GNU Binutils) 2.34) #0 SMP Wed Feb 14 08:12:14 2024
[ 0.000000] Using P2020RDB-PC machine description
[ 0.000000] printk: bootconsole [udbg0] enabled
[ 0.000000] CPU maps initialized for 1 thread per core
[ 0.000000] -----------------------------------------------------
[ 0.000000] phys_mem_size = 0x80000000
[ 0.000000] dcache_bsize = 0x20
[ 0.000000] icache_bsize = 0x20
[ 0.000000] cpu_features = 0x0000000010010108
[ 0.000000] possible = 0x0000000010010108
[ 0.000000] always = 0x0000000010010108
[ 0.000000] cpu_user_features = 0x84e08000 0x08000000
[ 0.000000] mmu_features = 0x00020010
mpc85xx_rdb_setup_arch()
[ 0.000000] ioremap() called early from of_iomap+0x48/0x80. Use early_ioremap() instead
[ 0.000000] MPC85xx RDB board from Freescale Semiconductor
[ 0.000000] barrier-nospec: using isync; sync as speculation barrier
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] HighMem [mem 0x0000000030000000-0x000000007fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] MMU: Allocated 1088 bytes of context maps for 255 contexts
[ 0.000000] percpu: Embedded 11 pages/cpu s13868 r8192 d22996 u45056
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 522560
[ 0.000000] Kernel command line: root=/dev/mmcblk0p2 rootwait rw rootfstype=btrfs rootflags=subvol=@,commit=5 console=ttyS0,115200
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Kernel virtual memory layout:
[ 0.000000] * 0xffbbf000..0xfffff000 : fixmap
[ 0.000000] * 0xff400000..0xff800000 : highmem PTEs
[ 0.000000] * 0xff3fe000..0xff400000 : early ioremap
[ 0.000000] * 0xf1000000..0xff3fe000 : vmalloc & ioremap
[ 0.000000] Memory: 1998976K/2097152K available (9544K kernel code, 728K rwdata, 1996K rodata, 256K init, 276K bss, 98176K reserved, 0K cma-reserved, 1310712K highmem)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 512, nr_irqs: 512, preallocated irqs: 16
[ 0.000000] mpic: Setting up MPIC " OpenPIC " version 1.2 at ffe40000, max 2 CPUs
[ 0.000000] mpic: ISU size: 256, shift: 8, mask: ff
[ 0.000000] mpic: Initializing for 256 sources
[ 0.000004] clocksource: timebase: mask: 0xffffffffffffffff max_cycles: 0x114c1bade8, max_idle_ns: 440795203839 ns
[ 0.010295] clocksource: timebase mult[d555555] shift[24] registered
[ 0.016765] Console: colour dummy device 80x25
[ 0.021148] pid_max: default: 32768 minimum: 301
[ 0.025841] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.033095] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.041506] mpic: requesting IPIs...
[ 0.045676] e500 family performance monitor hardware support registered
[ 0.052306] rcu: Hierarchical SRCU implementation.
[ 0.057171] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.064875] smp: Bringing up secondary CPUs ...
[ 0.069952] smp: Brought up 1 node, 2 CPUs
[ 0.074400] devtmpfs: initialized
[ 0.079666] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.089436] futex hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.096989] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.103421] thermal_sys: Registered thermal governor 'step_wise'
[ 0.111088] Machine: Turris 1.x
[ 0.120142] SoC family: QorIQ
[ 0.123097] SoC ID: svr:0x80ea0021, Revision: 2.1
[ 0.129160] Found FSL PCI host bridge at 0x00000000ffe08000. Firmware bus number: 0->1
[ 0.136997] PCI host bridge /pcie@ffe08000 (primary) ranges:
[ 0.142665] MEM 0x00000000c0000000..0x00000000c01fffff -> 0x00000000c0000000
[ 0.149865] IO 0x00000000ffc20000..0x00000000ffc2ffff -> 0x0000000000000000
[ 0.157015] /pcie@ffe08000: PCICSRBAR @ 0xfff00000
[ 0.161773] setup_pci_atmu: end of DRAM 80000000
[ 0.166753] Found FSL PCI host bridge at 0x00000000ffe09000. Firmware bus number: 0->1
[ 0.174599] PCI host bridge /pcie@ffe09000 ranges:
[ 0.179465] MEM 0x00000000a0000000..0x00000000bfffffff -> 0x00000000a0000000
[ 0.186694] IO 0x00000000ffc10000..0x00000000ffc1ffff -> 0x0000000000000000
[ 0.193815] /pcie@ffe09000: PCICSRBAR @ 0xfff00000
[ 0.198591] setup_pci_atmu: end of DRAM 80000000
[ 0.203552] Found FSL PCI host bridge at 0x00000000ffe0a000. Firmware bus number: 0->1
[ 0.211397] PCI host bridge /pcie@ffe0a000 ranges:
[ 0.216264] MEM 0x0000000080000000..0x000000009fffffff -> 0x0000000080000000
[ 0.223482] IO 0x00000000ffc00000..0x00000000ffc0ffff -> 0x0000000000000000
[ 0.230613] /pcie@ffe0a000: PCICSRBAR @ 0xfff00000
[ 0.235390] setup_pci_atmu: end of DRAM 80000000
[ 0.241044] software IO TLB: tearing down default memory pool
[ 0.253590] PCI: Probing PCI hardware
[ 0.257302] fsl-pci ffe08000.pcie: PCI host bridge to bus 0002:00
[ 0.263317] pci_bus 0002:00: root bus resource [io 0x0000-0xffff]
[ 0.269503] pci_bus 0002:00: root bus resource [mem 0xc0000000-0xc01fffff]
[ 0.276357] pci_bus 0002:00: root bus resource [bus 00-ff]
[ 0.281841] pci_bus 0002:00: busn_res: [bus 00-ff] end is updated to ff
[ 0.288466] pci 0002:00:00.0: [1957:0070] type 01 class 0x060400
[ 0.294455] pci 0002:00:00.0: reg 0x10: [mem 0xfff00000-0xffffffff]
[ 0.300741] pci 0002:00:00.0: supports D1 D2
[ 0.304966] pci 0002:00:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.312640] pci 0002:01:00.0: [104c:8241] type 00 class 0x0c0330
[ 0.318593] pci 0002:01:00.0: reg 0x10: [mem 0xc0000000-0xc000ffff 64bit]
[ 0.325356] pci 0002:01:00.0: reg 0x18: [mem 0xc0010000-0xc0011fff 64bit]
[ 0.332228] pci 0002:01:00.0: supports D1 D2
[ 0.336412] pci 0002:01:00.0: PME# supported from D0 D1 D2 D3hot
[ 0.342448] pci 0002:01:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0002:00:00.0 (capable of 4.000 Gb/s with 5.0 GT/s PCIe x1 link)
[ 0.388134] pci 0002:00:00.0: PCI bridge to [bus 01-ff]
[ 0.393280] pci 0002:00:00.0: bridge window [io 0x0000-0x0fff]
[ 0.399377] pci 0002:00:00.0: bridge window [mem 0xc0000000-0xc00fffff]
[ 0.406151] pci_bus 0002:01: busn_res: [bus 01-ff] end is updated to 01
[ 0.412762] pci_bus 0002:00: busn_res: [bus 00-ff] end is updated to 01
[ 0.419478] fsl-pci ffe09000.pcie: PCI host bridge to bus 0001:02
[ 0.425500] pci_bus 0001:02: root bus resource [io 0x20000-0x2ffff] (bus address [0x0000-0xffff])
[ 0.434442] pci_bus 0001:02: root bus resource [mem 0xa0000000-0xbfffffff]
[ 0.441317] pci_bus 0001:02: root bus resource [bus 02-ff]
[ 0.446787] pci_bus 0001:02: busn_res: [bus 02-ff] end is updated to ff
[ 0.453417] pci 0001:02:00.0: [1957:0070] type 01 class 0x060400
[ 0.459397] pci 0001:02:00.0: reg 0x10: [mem 0xfff00000-0xffffffff]
[ 0.465699] pci 0001:02:00.0: supports D1 D2
[ 0.469911] pci 0001:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.477458] pci 0001:02:00.0: Primary bus is hard wired to 0
[ 0.483033] pci 0001:02:00.0: bridge configuration invalid ([bus 01-01]), reconfiguring
[ 0.491124] pci 0001:03:00.0: [168c:0030] type 00 class 0x028000
[ 0.497065] pci 0001:03:00.0: reg 0x10: [mem 0xa0000000-0xa001ffff 64bit]
[ 0.503870] pci 0001:03:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ 0.510592] pci 0001:03:00.0: supports D1
[ 0.514532] pci 0001:03:00.0: PME# supported from D0 D1 D3hot
[ 0.545361] pci 0001:02:00.0: PCI bridge to [bus 03-ff]
[ 0.550506] pci 0001:02:00.0: bridge window [io 0x20000-0x20fff]
[ 0.556777] pci 0001:02:00.0: bridge window [mem 0xa0000000-0xa00fffff]
[ 0.563551] pci_bus 0001:03: busn_res: [bus 03-ff] end is updated to 03
[ 0.570162] pci_bus 0001:02: busn_res: [bus 02-ff] end is updated to 03
[ 0.576863] fsl-pci ffe0a000.pcie: PCI host bridge to bus 0000:04
[ 0.582884] pci_bus 0000:04: root bus resource [io 0x40000-0x4ffff] (bus address [0x0000-0xffff])
[ 0.591827] pci_bus 0000:04: root bus resource [mem 0x80000000-0x9fffffff]
[ 0.598702] pci_bus 0000:04: root bus resource [bus 04-ff]
[ 0.604172] pci_bus 0000:04: busn_res: [bus 04-ff] end is updated to ff
[ 0.610802] pci 0000:04:00.0: [1957:0070] type 01 class 0x060400
[ 0.616782] pci 0000:04:00.0: reg 0x10: [mem 0xfff00000-0xffffffff]
[ 0.623083] pci 0000:04:00.0: supports D1 D2
[ 0.627296] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.634847] pci 0000:04:00.0: Primary bus is hard wired to 0
[ 0.640423] pci 0000:04:00.0: bridge configuration invalid ([bus 01-01]), reconfiguring
[ 0.648515] pci 0000:05:00.0: [168c:003c] type 00 class 0x028000
[ 0.654455] pci 0000:05:00.0: reg 0x10: [mem 0x80000000-0x801fffff 64bit]
[ 0.661260] pci 0000:05:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ 0.667981] pci 0000:05:00.0: supports D1 D2
[ 0.703015] pci 0000:04:00.0: PCI bridge to [bus 05-ff]
[ 0.708161] pci 0000:04:00.0: bridge window [io 0x40000-0x40fff]
[ 0.714432] pci 0000:04:00.0: bridge window [mem 0x80000000-0x801fffff]
[ 0.721205] pci_bus 0000:05: busn_res: [bus 05-ff] end is updated to 05
[ 0.727817] pci_bus 0000:04: busn_res: [bus 04-ff] end is updated to 05
[ 0.734473] PCI: Cannot allocate resource region 0 of device 0002:00:00.0, will remap
[ 0.742250] PCI: Cannot allocate resource region 0 of device 0001:02:00.0, will remap
[ 0.750064] PCI: Cannot allocate resource region 0 of device 0000:04:00.0, will remap
[ 0.757936] pci 0002:00:00.0: BAR 0: no space for [mem size 0x00100000]
[ 0.764491] pci 0002:00:00.0: BAR 0: failed to assign [mem size 0x00100000]
[ 0.771457] pci 0002:00:00.0: PCI bridge to [bus 01]
[ 0.776402] pci 0002:00:00.0: bridge window [io 0x0000-0xffff]
[ 0.782501] pci 0002:00:00.0: bridge window [mem 0xc0000000-0xc01fffff]
[ 0.789269] pci_bus 0002:00: Some PCI device resources are unassigned, try booting with pci=realloc
[ 0.798317] pci_bus 0002:00: resource 4 [io 0x0000-0xffff]
[ 0.803872] pci_bus 0002:00: resource 5 [mem 0xc0000000-0xc01fffff]
[ 0.810138] pci_bus 0002:01: resource 0 [io 0x0000-0xffff]
[ 0.815695] pci_bus 0002:01: resource 1 [mem 0xc0000000-0xc01fffff]
[ 0.821965] pci 0001:02:00.0: BAR 0: no space for [mem size 0x00100000]
[ 0.828561] pci 0001:02:00.0: BAR 0: failed to assign [mem size 0x00100000]
[ 0.835527] pci 0001:03:00.0: BAR 6: assigned [mem 0xa0020000-0xa002ffff pref]
[ 0.842732] pci 0001:02:00.0: PCI bridge to [bus 03]
[ 0.847695] pci 0001:02:00.0: bridge window [io 0x20000-0x2ffff]
[ 0.853947] pci 0001:02:00.0: bridge window [mem 0xa0000000-0xbfffffff]
[ 0.860741] pci_bus 0001:02: Some PCI device resources are unassigned, try booting with pci=realloc
[ 0.869768] pci_bus 0001:02: resource 4 [io 0x20000-0x2ffff]
[ 0.875513] pci_bus 0001:02: resource 5 [mem 0xa0000000-0xbfffffff]
[ 0.881765] pci_bus 0001:03: resource 0 [io 0x20000-0x2ffff]
[ 0.887508] pci_bus 0001:03: resource 1 [mem 0xa0000000-0xbfffffff]
[ 0.893766] pci 0000:04:00.0: BAR 0: no space for [mem size 0x00100000]
[ 0.900376] pci 0000:04:00.0: BAR 0: failed to assign [mem size 0x00100000]
[ 0.907326] pci 0000:05:00.0: BAR 6: assigned [mem 0x80200000-0x8020ffff pref]
[ 0.914547] pci 0000:04:00.0: PCI bridge to [bus 05]
[ 0.919495] pci 0000:04:00.0: bridge window [io 0x40000-0x4ffff]
[ 0.925761] pci 0000:04:00.0: bridge window [mem 0x80000000-0x9fffffff]
[ 0.932535] pci_bus 0000:04: Some PCI device resources are unassigned, try booting with pci=realloc
[ 0.941587] pci_bus 0000:04: resource 4 [io 0x40000-0x4ffff]
[ 0.947312] pci_bus 0000:04: resource 5 [mem 0x80000000-0x9fffffff]
[ 0.953579] pci_bus 0000:05: resource 0 [io 0x40000-0x4ffff]
[ 0.959309] pci_bus 0000:05: resource 1 [mem 0x80000000-0x9fffffff]
[ 0.973169] raid6: skip pq benchmark and using algorithm int32x8
[ 0.979100] raid6: using intx1 recovery algorithm
[ 0.984242] SCSI subsystem initialized
[ 0.988021] usbcore: registered new interface driver usbfs
[ 0.993446] usbcore: registered new interface driver hub
[ 0.998760] usbcore: registered new device driver usb
[ 1.003821] EDAC MC: Ver: 3.0.0
[ 1.007926] clocksource: Switched to clocksource timebase
[ 1.018373] NET: Registered PF_INET protocol family
[ 1.023337] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 1.031489] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 1.039788] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 1.047507] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.055295] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.062454] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.068808] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.075369] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.082546] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 1.088184] pci 0002:00:00.0: enabling device (0106 -> 0107)
[ 1.093868] PCI: CLS 32 bytes, default 32
[ 1.099455] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 1.108821] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.114633] jffs2: version 2.2 (NAND) (SUMMARY) (ZLIB) (LZO) (LZMA) (RTIME) (RUBIN) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 1.126617] xor: measuring software checksum speed
[ 1.137594] 8regs : 1574 MB/sec
[ 1.149688] 8regs_prefetch : 1258 MB/sec
[ 1.160213] 32regs : 1573 MB/sec
[ 1.171553] 32regs_prefetch : 1391 MB/sec
[ 1.175822] xor: using function: 8regs (1574 MB/sec)
[ 1.180858] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 1.189399] pcieport 0002:00:00.0: AER: enabled with IRQ 24
[ 1.195055] pcieport 0001:02:00.0: enabling device (0106 -> 0107)
[ 1.201500] pcieport 0001:02:00.0: AER: enabled with IRQ 25
[ 1.207148] pcieport 0000:04:00.0: enabling device (0106 -> 0107)
[ 1.213579] pcieport 0000:04:00.0: AER: enabled with IRQ 26
[ 1.219417] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 1.228337] printk: console [ttyS0] disabled
[ 1.232556] serial8250.0: ttyS0 at MMIO 0xffe04500 (irq = 42, base_baud = 37500000) is a 16550A
[ 1.241279] printk: console [ttyS0] enabled
[ 1.249597] printk: bootconsole [udbg0] disabled
[ 1.259100] serial8250.0: ttyS1 at MMIO 0xffe04600 (irq = 42, base_baud = 37500000) is a 16550A
[ 1.268491] printk: console [ttyS0] disabled
[ 1.272858] printk: console [ttyS0] enabled
[ 1.277478] ffe04600.serial: ttyS1 at MMIO 0xffe04600 (irq = 42, base_baud = 37500000) is a 16550
[ 1.287011] Loading iSCSI transport class v2.0-870.
[ 1.293998] physmap-flash ef000000.nor: physmap platform flash device: [mem 0xef000000-0xefffffff]
[ 1.303183] ef000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000001 Chip ID 0x002101
[ 1.313223] Amd/Fujitsu Extended Query Table at 0x0040
[ 1.318409] Amd/Fujitsu Extended Query version 1.3.
[ 1.323463] number of CFI chips: 1
[ 1.327260] 7 fixed-partitions partitions found on MTD device ef000000.nor
[ 1.334174] Creating 7 MTD partitions on "ef000000.nor":
[ 1.339521] 0x000000000000-0x000000020000 : "dtb"
[ 1.344734] 0x000000020000-0x0000001c0000 : "kernel"
[ 1.350211] 0x0000001c0000-0x000000340000 : "rescue"
[ 1.355567] 0x000000340000-0x000000e40000 : "factory"
[ 1.361049] 0x000000e40000-0x000000f00000 : "certificates"
[ 1.366930] 0x000000f20000-0x000000f40000 : "u-boot-env"
[ 1.372681] 0x000000f40000-0x000001000000 : "u-boot"
[ 1.380565] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
[ 1.386935] nand: Micron MT29F2G08ABAEAWP
[ 1.390971] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 1.399726] Bad block table found at page 131008, version 0x01
[ 1.406468] Bad block table found at page 130944, version 0x01
[ 1.413072] 1 fixed-partitions partitions found on MTD device ff800000.flash
[ 1.420153] Creating 1 MTD partitions on "ff800000.flash":
[ 1.425643] 0x000000000000-0x000010000000 : "rootfs"
[ 1.431805] mtd: setting mtd7 (rootfs) as root device
[ 1.437223] mtdsplit: no squashfs found in "rootfs"
[ 1.442419] eLBC NAND device at 0xff800000, bank 1
[ 1.447849] fsl_espi ffe07000.spi: irq = 59
[ 1.459466] fsl-gianfar ffe24000.ethernet: Using random MAC address: fa:d7:9e:16:06:c5
[ 1.467730] fsl-gianfar ffe24000.ethernet: enabled errata workarounds, flags: 0x4
[ 1.485640] fsl-gianfar ffe24000.ethernet eth0: mac: fa:d7:9e:16:06:c5
[ 1.492224] fsl-gianfar ffe24000.ethernet eth0: Running with NAPI enabled
[ 1.499030] fsl-gianfar ffe24000.ethernet eth0: RX BD ring size for Q[0]: 256
[ 1.506172] fsl-gianfar ffe24000.ethernet eth0: TX BD ring size for Q[0]: 256
[ 1.513513] fsl-gianfar ffe25000.ethernet: Using random MAC address: 66:48:14:eb:9d:bb
[ 1.521801] fsl-gianfar ffe25000.ethernet: enabled errata workarounds, flags: 0x4
[ 1.539691] fsl-gianfar ffe25000.ethernet eth1: mac: 66:48:14:eb:9d:bb
[ 1.546233] fsl-gianfar ffe25000.ethernet eth1: Running with NAPI enabled
[ 1.553044] fsl-gianfar ffe25000.ethernet eth1: RX BD ring size for Q[0]: 256
[ 1.560195] fsl-gianfar ffe25000.ethernet eth1: TX BD ring size for Q[0]: 256
[ 1.567516] fsl-gianfar ffe26000.ethernet: Using random MAC address: 96:f4:81:19:20:bf
[ 1.575468] fsl-gianfar ffe26000.ethernet: enabled errata workarounds, flags: 0x4
[ 1.593318] fsl-gianfar ffe26000.ethernet eth2: mac: 96:f4:81:19:20:bf
[ 1.599877] fsl-gianfar ffe26000.ethernet eth2: Running with NAPI enabled
[ 1.606670] fsl-gianfar ffe26000.ethernet eth2: RX BD ring size for Q[0]: 256
[ 1.613818] fsl-gianfar ffe26000.ethernet eth2: TX BD ring size for Q[0]: 256
[ 1.621133] ucc_geth_driver: QE UCC Gigabit Ethernet Controller
[ 1.627141] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.633763] ehci-pci: EHCI PCI platform driver
[ 1.638599] fsl-ehci: Freescale EHCI Host controller driver
[ 1.644239] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
[ 1.650892] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
[ 1.658189] fsl-ehci fsl-ehci.0: irq 28, io mem 0xffe22000
[ 1.687936] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
[ 1.694062] hub 1-0:1.0: USB hub found
[ 1.697856] hub 1-0:1.0: 1 port detected
[ 1.702284] usbcore: registered new interface driver uas
[ 1.707680] usbcore: registered new interface driver usb-storage
[ 1.713919] i2c_dev: i2c /dev entries driver
[ 1.718361] mpc-i2c ffe03000.i2c: timeout 1000000 us
[ 1.723575] i2c i2c-0: of_i2c: modalias failure on /soc@ffe00000/i2c@3000/power-control@2a
[ 1.731886] i2c i2c-0: Failed to create I2C device for /soc@ffe00000/i2c@3000/power-control@2a
[ 1.740527] i2c i2c-0: of_i2c: modalias failure on /soc@ffe00000/i2c@3000/eeprom@32
[ 1.748209] i2c i2c-0: Failed to create I2C device for /soc@ffe00000/i2c@3000/eeprom@32
[ 1.756415] i2c i2c-0: of_i2c: modalias failure on /soc@ffe00000/i2c@3000/eeprom@57
[ 1.764099] i2c i2c-0: Failed to create I2C device for /soc@ffe00000/i2c@3000/eeprom@57
[ 1.772593] mpc-i2c ffe03100.i2c: timeout 1000000 us
[ 1.777990] booke_wdt: powerpc book-e watchdog driver loaded
[ 1.783901] Freescale(R) MPC85xx EDAC driver, (C) 2006 Montavista Software
[ 1.791016] fsl_mc_err_probe: No ECC DIMMs discovered
[ 1.796617] EDAC DEVICE0: Giving out device to module MPC85xx_edac controller mpc85xx_l2_err: DEV mpc85xx_l2_err (INTERRUPT)
[ 1.807903] MPC85xx_edac acquired irq 16 for L2 Err
[ 1.812795] MPC85xx_edac L2 err registered
[ 1.817225] EDAC PCI0: Giving out device to module MPC85xx_edac controller mpc85xx_pci_err: DEV mpc85xx-pci-edac.0.auto (INTERRUPT)
[ 1.829100] MPC85xx_edac acquired irq 24 for PCI Err
[ 1.834065] MPC85xx_edac PCI err registered
[ 1.838318] EDAC PCI1: Giving out device to module MPC85xx_edac controller mpc85xx_pci_err: DEV mpc85xx-pci-edac.1.auto (INTERRUPT)
[ 1.850180] MPC85xx_edac acquired irq 25 for PCI Err
[ 1.855145] MPC85xx_edac PCI err registered
[ 1.859394] EDAC PCI2: Giving out device to module MPC85xx_edac controller mpc85xx_pci_err: DEV mpc85xx-pci-edac.2.auto (INTERRUPT)
[ 1.871264] MPC85xx_edac acquired irq 26 for PCI Err
[ 1.876229] MPC85xx_edac PCI err registered
[ 1.880706] sdhci: Secure Digital Host Controller Interface driver
[ 1.886893] sdhci: Copyright(c) Pierre Ossman
[ 1.891257] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.897189] sdhci-esdhc ffe2e000.sdhc: Got CD GPIO
[ 1.897552] NET: Registered PF_INET6 protocol family
[ 1.902081] mmc0 bounce up to 128 segments into one, max segment size 65536 bytes
[ 1.908309] Segment Routing with IPv6
[ 1.918189] In-situ OAM (IOAM) with IPv6
[ 1.922165] NET: Registered PF_PACKET protocol family
[ 1.927269] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.938094] mmc0: SDHCI controller on ffe2e000.sdhc [ffe2e000.sdhc] using DMA
[ 1.940398] 8021q: 802.1Q VLAN Support v1.8
[ 1.951687] drmem: No dynamic reconfiguration memory found
[ 1.959964] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
[ 2.019837] mmc0: new high speed SDHC card at address 59b4
[ 2.025821] mmcblk0: mmc0:59b4 SD 7.36 GiB
[ 2.036613] mmcblk0: p1 p2
[ 2.047976] usb 1-1: new high-speed USB device number 2 using fsl-ehci
[ 2.075029] device eth1 entered promiscuous mode
[ 2.079800] device eth0 entered promiscuous mode
[ 2.089043] qca8k mdio@ffe24520:10: configuring for fixed/rgmii-id link mode
[ 2.100862] qca8k mdio@ffe24520:10: configuring for fixed/rgmii-id link mode
[ 2.110623] qca8k mdio@ffe24520:10: Link is Up - 1Gbps/Full - flow control off
[ 2.119182] qca8k mdio@ffe24520:10: Link is Up - 1Gbps/Full - flow control off
[ 2.201236] qca8k mdio@ffe24520:10 lan5 (uninitialized): PHY [qca8k-0.0:01] driver [Qualcomm Atheros 8337 internal PHY] (irq=POLL)
[ 2.278771] hub 1-1:1.0: USB hub found
[ 2.282691] hub 1-1:1.0: 2 ports detected
[ 2.291258] qca8k mdio@ffe24520:10 lan4 (uninitialized): PHY [qca8k-0.0:02] driver [Qualcomm Atheros 8337 internal PHY] (irq=POLL)
[ 2.381242] qca8k mdio@ffe24520:10 lan3 (uninitialized): PHY [qca8k-0.0:03] driver [Qualcomm Atheros 8337 internal PHY] (irq=POLL)
[ 2.471245] qca8k mdio@ffe24520:10 lan2 (uninitialized): PHY [qca8k-0.0:04] driver [Qualcomm Atheros 8337 internal PHY] (irq=POLL)
[ 2.561236] qca8k mdio@ffe24520:10 lan1 (uninitialized): PHY [qca8k-0.0:05] driver [Qualcomm Atheros 8337 internal PHY] (irq=POLL)
[ 2.573516] DSA: tree 0 setup
[ 2.583423] BTRFS: device fsid 102f5ee7-4016-4565-9718-be41bd28e459 devid 1 transid 1088038 /dev/root scanned by swapper/0 (1)
[ 2.606614] BTRFS info (device mmcblk0p2): using crc32c (crc32c-generic) checksum algorithm
[ 2.615074] BTRFS info (device mmcblk0p2): disk space caching is enabled
[ 2.621810] BTRFS info (device mmcblk0p2): has skinny extents
[ 2.627591] usb 1-1.1: new full-speed USB device number 3 using fsl-ehci
[ 2.741348] BTRFS info (device mmcblk0p2): enabling ssd optimizations
[ 2.804843] VFS: Mounted root (btrfs filesystem) on device 0:14.
[ 2.817825] devtmpfs: mounted
[ 2.821096] Freeing unused kernel image (initmem) memory: 256K
[ 2.826936] This architecture does not have kernel memory protection.
[ 2.833406] Run /sbin/init as init process
[ 3.132399] init: Console is alive
[ 3.135927] init: - watchdog -
\00[ 15.257176] procd: - watchdog -
[ 15.267706] procd: - ubus -
[ 15.306779] random: ubusd: uninitialized urandom read (4 bytes read)
[ 15.320722] random: ubusd: uninitialized urandom read (4 bytes read)
[ 15.327274] random: ubusd: uninitialized urandom read (4 bytes read)
[ 15.335026] procd: - init -
Please press Enter to activate this console.
[ 16.610612] random: crng init done
[ 16.614025] random: 15 urandom warning(s) missed due to ratelimiting
[ 20.263303] kmodloader: loading kernel modules from /etc/modules.d/*
[ 20.395546] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 20.433614] pca953x 0-0018: supply vcc not found, using dummy regulator
[ 20.440479] pca953x 0-0018: using no AI
[ 20.447832] GACT probability on
[ 20.452072] Mirror/redirect action on
[ 20.461273] u32 classifier
[ 20.463996] input device check on
[ 20.467653] Actions configured
[ 20.480112] Bridge firewalling registered
[ 20.484960] Loading modules backported from Linux version v5.15.81-0-ge4a7232c917c
[ 20.492606] Backport generated by backports.git v5.15.81-1-0-ge1867d55
[ 20.507373] lm90 0-004c: supply vcc not found, using dummy regulator
[ 20.515261] hwmon hwmon0: temp1_input not attached to any thermal zone
[ 20.521860] hwmon hwmon0: temp2_input not attached to any thermal zone
[ 20.532345] pps pps0: new PPS source ptp0
[ 20.543183] rtc-ds1307 0-006f: registered as rtc0
[ 20.548899] rtc-ds1307 0-006f: setting system clock to 2024-02-16T13:08:24 UTC (1708088904)
[ 20.559723] usbcore: registered new interface driver ums-alauda
[ 20.566082] usbcore: registered new interface driver ums-cypress
[ 20.572624] usbcore: registered new interface driver ums-datafab
[ 20.579263] usbcore: registered new interface driver ums-freecom
[ 20.585777] usbcore: registered new interface driver ums-isd200
[ 20.592207] usbcore: registered new interface driver ums-jumpshot
[ 20.598787] usbcore: registered new interface driver ums-karma
[ 20.605221] usbcore: registered new interface driver ums-sddr09
[ 20.611750] usbcore: registered new interface driver ums-sddr55
[ 20.618245] usbcore: registered new interface driver ums-usbat
[ 20.631094] xt_time: kernel timezone is -0000
[ 20.695909] PPP generic driver version 2.4.2
[ 20.701416] NET: Registered PF_PPPOX protocol family
[ 20.728258] ath10k_pci 0000:05:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[ 21.144941] ath10k_pci 0000:05:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
[ 21.154223] ath10k_pci 0000:05:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
[ 21.163923] ath10k_pci 0000:05:00.0: firmware ver 10.2.4-1.0-00047 api 5 features no-p2p,raw-mode,mfp,allows-mesh-bcast crc32 35bd9258
[ 21.294520] ath10k_pci 0000:05:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[ 22.438154] ath10k_pci 0000:05:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
[ 22.740275] ieee80211 phy1: Atheros AR9300 Rev:3 mem=0xf2c20000, irq=37
[ 22.748052] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 27.049785] fsl-gianfar ffe25000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
[ 27.061889] qca8k mdio@ffe24520:10 lan1: configuring for phy/gmii link mode
[ 27.069330] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 27.084676] br-guest: port 1(lan1.3) entered blocking state
[ 27.090308] br-guest: port 1(lan1.3) entered disabled state
[ 27.096087] device lan1.3 entered promiscuous mode
[ 27.100925] device lan1 entered promiscuous mode
[ 27.105999] qca8k mdio@ffe24520:10 lan1: Link is Up - 1Gbps/Full - flow control rx/tx
[ 27.119393] IPv6: ADDRCONF(NETDEV_CHANGE): lan1: link becomes ready
[ 27.130435] br-lan: port 1(lan1) entered blocking state
[ 27.135686] br-lan: port 1(lan1) entered disabled state
[ 27.154953] br-guest: port 1(lan1.3) entered blocking state
[ 27.160566] br-guest: port 1(lan1.3) entered forwarding state
[ 27.181613] br-lan: port 1(lan1) entered blocking state
[ 27.186868] br-lan: port 1(lan1) entered forwarding state
[ 27.194437] IPv6: ADDRCONF(NETDEV_CHANGE): br-guest: link becomes ready
[ 27.213046] qca8k mdio@ffe24520:10 lan2: configuring for phy/gmii link mode
[ 27.222451] qca8k mdio@ffe24520:10 lan2: Link is Up - 100Mbps/Full - flow control rx/tx
[ 27.230852] br-lan: port 2(lan2) entered blocking state
[ 27.236119] br-lan: port 2(lan2) entered disabled state
[ 27.249905] device lan2 entered promiscuous mode
[ 27.260681] br-lan: port 2(lan2) entered blocking state
[ 27.265929] br-lan: port 2(lan2) entered forwarding state
[ 27.294561] qca8k mdio@ffe24520:10 lan3: configuring for phy/gmii link mode
[ 27.304368] br-lan: port 3(lan3) entered blocking state
[ 27.309723] br-lan: port 3(lan3) entered disabled state
[ 27.321534] device lan3 entered promiscuous mode
[ 27.342559] qca8k mdio@ffe24520:10 lan4: configuring for phy/gmii link mode
[ 27.357269] br-lan: port 4(lan4) entered blocking state
[ 27.362609] br-lan: port 4(lan4) entered disabled state
[ 27.376385] device lan4 entered promiscuous mode
[ 27.384855] qca8k mdio@ffe24520:10 lan5: configuring for phy/gmii link mode
[ 27.402078] br-lan: port 5(lan5) entered blocking state
[ 27.407355] br-lan: port 5(lan5) entered disabled state
[ 27.419072] device lan5 entered promiscuous mode
[ 28.121952] ath: EEPROM regdomain: 0x80cb
[ 28.125974] ath: EEPROM indicates we should expect a country code
[ 28.132112] ath: doing EEPROM country->regdmn map search
[ 28.137431] ath: country maps to regdmn code: 0x37
[ 28.142232] ath: Country alpha2 being used: CZ
[ 28.146679] ath: Regpair used: 0x37
[ 28.150172] ath: regdomain 0x80cb dynamically updated by user
[ 28.156002] ath: EEPROM regdomain: 0x80cb
[ 28.160025] ath: EEPROM indicates we should expect a country code
[ 28.166132] ath: doing EEPROM country->regdmn map search
[ 28.171453] ath: country maps to regdmn code: 0x37
[ 28.176246] ath: Country alpha2 being used: CZ
[ 28.180703] ath: Regpair used: 0x37
[ 28.184195] ath: regdomain 0x80cb dynamically updated by user
[ 30.167004] ath10k_pci 0000:05:00.0: pdev param 0 not supported by firmware
[ 30.200000] br-lan: port 6(wlan0) entered blocking state
[ 30.205334] br-lan: port 6(wlan0) entered disabled state
[ 30.210914] device wlan0 entered promiscuous mode
[ 30.667149] br-lan: port 7(wlan1) entered blocking state
[ 30.672545] br-lan: port 7(wlan1) entered disabled state
[ 30.678116] device wlan1 entered promiscuous mode
[ 30.682979] br-lan: port 7(wlan1) entered blocking state
[ 30.688326] br-lan: port 7(wlan1) entered forwarding state
[ 30.764986] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[ 30.890553] br-guest: port 2(wlan1-1) entered blocking state
[ 30.896272] br-guest: port 2(wlan1-1) entered disabled state
[ 30.902207] device wlan1-1 entered promiscuous mode
[ 30.916593] br-guest: port 2(wlan1-1) entered blocking state
[ 30.922332] br-guest: port 2(wlan1-1) entered forwarding state
[ 30.997302] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1-1: link becomes ready
Router Turris successfully started.
[ 46.187948] BUG: scheduling while atomic: foris-controlle/3238/0x00000100
[ 46.194781] Modules linked in: ath9k ath9k_common xt_connlimit pppoe ppp_async nf_conncount iptable_nat ath9k_hw ath10k_pci ath10k_core ath xt_state xt_nat xt_helper xt_conntrack xt_connmark xt_connbytes xt_REDIRECT xt_MASQUERADE xt_FLOWOFFLOAD xt_CT pppox ppp_generic nf_nat_ftp nf_nat nf_flow_table nf_conntrack_netlink nf_conntrack_ftp nf_conntrack mt7915e mt76_connac_lib mt76 mac80211 ipt_REJECT ebtable_nat ebtable_filter ebtable_broute cfg80211 xt_time xt_tcpudp xt_tcpmss xt_statistic xt_recent xt_multiport xt_mark xt_mac xt_limit xt_length xt_hl xt_ecn xt_dscp xt_comment xt_TCPMSS xt_LOG xt_HL xt_DSCP xt_CLASSIFY ums_usbat ums_sddr55 ums_sddr09 ums_karma ums_jumpshot ums_isd200 ums_freecom ums_datafab ums_cypress ums_alauda slhc sch_cake rtc_ds1307 ptp_qoriq nf_reject_ipv4 nf_log_syslog nf_defrag_ipv6 nf_defrag_ipv4 lm90 iptable_raw iptable_mangle iptable_filter ipt_ECN ip_tables hwmon ebtables ebt_vlan ebt_stp ebt_redirect ebt_pkttype ebt_mark_m ebt_mark ebt_limit ebt_among
[ 46.195128] ebt_802_3 crc_ccitt compat br_netfilter sch_tbf sch_ingress sch_htb sch_hfsc em_u32 cls_u32 cls_route cls_matchall cls_fw cls_flow cls_basic act_skbedit act_mirred act_gact configs gpio_pca953x regmap_i2c xt_set ip_set_list_set ip_set_hash_netportnet ip_set_hash_netport ip_set_hash_netnet ip_set_hash_netiface ip_set_hash_net ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ipmac ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 ifb sit ip6_tunnel netlink_diag tunnel6 tunnel4 ip_tunnel nls_utf8 sha256_ppc_spe seqiv jitterentropy_rng drbg md5_ppc hmac cmac gpio_keys leds_turris_1x leds_gpio xhci_plat_hcd xhci_pci xhci_hcd ahci libahci libata ehci_platform button_hotplug ptp pps_core
[ 46.359114] CPU: 0 PID: 3238 Comm: foris-controlle Not tainted 5.15.147 #0
[ 46.366012] Call Trace:
[ 46.368453] [efff3d90] [c050dab0] dump_stack_lvl+0x4c/0x6c (unreliable)
[ 46.375086] [efff3db0] [c0062cf0] __schedule_bug+0x54/0x6c
[ 46.380578] [efff3dc0] [c094b67c] __schedule+0x3b4/0x5e4
[ 46.385903] [efff3e10] [c094b910] schedule+0x64/0xe0
[ 46.390872] [efff3e30] [c094bc54] schedule_preempt_disabled+0x10/0x20
[ 46.397320] [efff3e40] [c094d5b4] __mutex_lock.isra.14+0x480/0x49c
[ 46.403507] [efff3e90] [f113c664] 0xf113c664
[ 46.407783] [efff3ec0] [c070a18c] led_timer_function+0x98/0x1cc
[ 46.413712] [efff3ee0] [c00afec4] call_timer_fn.isra.35+0x24/0x84
[ 46.419813] [efff3f00] [c00b0220] run_timer_softirq+0x2fc/0x388
[ 46.425738] [efff3f90] [c0951df0] __do_softirq+0x150/0x298
[ 46.431229] [efff3ff0] [c00053d0] do_softirq_own_stack+0x34/0x4c
[ 46.437244] [c3a2bed0] [c000a774] timer_interrupt+0x1c8/0x2b0
[ 46.443000] [c3a2bef0] [c003e7a4] irq_exit+0x88/0xc4
[ 46.447977] [c3a2bf10] [c000138c] Decrementer+0x14c/0x160
[ 46.453380] --- interrupt: 900 at 0xb78389dc
[ 46.457649] NIP: b78389dc LR: b78366c0 CTR: b78359b0
[ 46.462699] REGS: c3a2bf20 TRAP: 0900 Not tainted (5.15.147)
[ 46.468620] MSR: 0202d000 <VEC,CE,EE,PR,ME> CR: 40002448 XER: 20000000
[ 46.475430]
[ 46.475430] GPR00: b78383f4 bfcaa460 b7bab18c 01e769d8 00ec8a08 01e6cf60 00000000 00000000
[ 46.475430] GPR08: 00000020 0000005e b7a46a48 bfcaa460 40002444 00000000 00000000 b7b9f010
[ 46.475430] GPR16: 00e944e0 00000003 00eab178 00eca56c bfcaa4a8 00eca55c 0000005f 00eca564
[ 46.475430] GPR24: 00eb0198 00eb0380 00eb0120 00eca428 00eb0134 b7b01080 b7ab5c08 00eca56c
[ 46.510396] NIP [b78389dc] 0xb78389dc
[ 46.514055] LR [b78366c0] 0xb78366c0
[ 46.517628] --- interrupt: 900
[ 46.533272] Oops: Exception in kernel mode, sig: 4 [#1]
[ 46.538520] BE PAGE_SIZE=4K SMP NR_CPUS=2 P2020RDB-PC
[ 46.543573] Modules linked in: ath9k ath9k_common xt_connlimit pppoe ppp_async nf_conncount iptable_nat ath9k_hw ath10k_pci ath10k_core ath xt_state xt_nat xt_helper xt_conntrack xt_connmark xt_connbytes xt_REDIRECT xt_MASQUERADE xt_FLOWOFFLOAD xt_CT pppox ppp_generic nf_nat_ftp nf_nat nf_flow_table nf_conntrack_netlink nf_conntrack_ftp nf_conntrack mt7915e mt76_connac_lib mt76 mac80211 ipt_REJECT ebtable_nat ebtable_filter ebtable_broute cfg80211 xt_time xt_tcpudp xt_tcpmss xt_statistic xt_recent xt_multiport xt_mark xt_mac xt_limit xt_length xt_hl xt_ecn xt_dscp xt_comment xt_TCPMSS xt_LOG xt_HL xt_DSCP xt_CLASSIFY ums_usbat ums_sddr55 ums_sddr09 ums_karma ums_jumpshot ums_isd200 ums_freecom ums_datafab ums_cypress ums_alauda slhc sch_cake rtc_ds1307 ptp_qoriq nf_reject_ipv4 nf_log_syslog nf_defrag_ipv6 nf_defrag_ipv4 lm90 iptable_raw iptable_mangle iptable_filter ipt_ECN ip_tables hwmon ebtables ebt_vlan ebt_stp ebt_redirect ebt_pkttype ebt_mark_m ebt_mark ebt_limit ebt_among
[ 46.543880] ebt_802_3 crc_ccitt compat br_netfilter sch_tbf sch_ingress sch_htb sch_hfsc em_u32 cls_u32 cls_route cls_matchall cls_fw cls_flow cls_basic act_skbedit act_mirred act_gact configs gpio_pca953x regmap_i2c xt_set ip_set_list_set ip_set_hash_netportnet ip_set_hash_netport ip_set_hash_netnet ip_set_hash_netiface ip_set_hash_net ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ipmac ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 ifb sit ip6_tunnel netlink_diag tunnel6 tunnel4 ip_tunnel nls_utf8 sha256_ppc_spe seqiv jitterentropy_rng drbg md5_ppc hmac cmac gpio_keys leds_turris_1x leds_gpio xhci_plat_hcd xhci_pci xhci_hcd ahci libahci libata ehci_platform button_hotplug ptp pps_core
[ 46.707750] CPU: 0 PID: 3238 Comm: foris-controlle Tainted: G W 5.15.147 #0
[ 46.716023] NIP: c3b5f3c0 LR: c3b5f3c0 CTR: c0074a68
[ 46.721073] REGS: efff3ce0 TRAP: 0700 Tainted: G W (5.15.147)
[ 46.728385] MSR: 02021000 <VEC,CE,ME> CR: 00000000 XER: 00000000
[ 46.734669]
[ 46.734669] GPR00: 00000000 efff3dc0 c2ac1a40 c2acc600 c3b5f3c0 c8c13f20 00000000 00000000
[ 46.734669] GPR08: 00021000 0000003c 82000444 78eff3a0 22000242 00074028 c11db000 00000000
[ 46.734669] GPR16: 00000000 c0c7c200 c090ef08 cdb60540 efff3d50 00000001 c0c2884c ff3eaeb8
[ 46.734669] GPR24: c11db000 c090f468 00000000 c3b5f3c0 efff3dd0 c07507d8 f1156000 c18ba588
[ 46.769639] NIP [c3b5f3c0] 0xc3b5f3c0
[ 46.773301] LR [c3b5f3c0] 0xc3b5f3c0
[ 46.776874] Call Trace:
[ 46.779315] [efff3df4] [efff3df4] 0xefff3df4
[ 46.783587] [efff3df4] [efff3df4] 0xefff3df4
[ 46.787859] [efff3df4] [efff3df4] 0xefff3df4
[ 46.792131] [efff3df4] [efff3df4] 0xefff3df4
[ 46.796402] [efff3df4] [efff3df4] 0xefff3df4
[ 46.800674] [efff3df4] [efff3df4] 0xefff3df4
[ 46.804946] [efff3df4] [efff3df4] 0xefff3df4
[ 46.809218] [efff3df4] [efff3df4] 0xefff3df4
[ 46.813490] [efff3df4] [efff3df4] 0xefff3df4
[ 46.817762] [efff3df4] [efff3df4] 0xefff3df4
[ 46.822033] [efff3df4] [efff3df4] 0xefff3df4
[ 46.826305] [efff3df4] [efff3df4] 0xefff3df4
[ 46.830576] [efff3df4] [efff3df4] 0xefff3df4
[ 46.834848] [efff3df4] [efff3df4] 0xefff3df4
[ 46.839120] [efff3df4] [efff3df4] 0xefff3df4
[ 46.843392] [efff3df4] [efff3df4] 0xefff3df4
[ 46.847663] [efff3df4] [efff3df4] 0xefff3df4
[ 46.851935] [efff3df4] [efff3df4] 0xefff3df4
[ 46.856207] [efff3df4] [efff3df4] 0xefff3df4
[ 46.860478] [efff3df4] [efff3df4] 0xefff3df4
[ 46.864750] [efff3df4] [efff3df4] 0xefff3df4
[ 46.869022] [efff3df4] [efff3df4] 0xefff3df4
[ 46.873294] [efff3df4] [efff3df4] 0xefff3df4
[ 46.877565] [efff3df4] [efff3df4] 0xefff3df4
[ 46.881837] [efff3df4] [efff3df4] 0xefff3df4
[ 46.886109] [efff3df4] [efff3df4] 0xefff3df4
[ 46.890381] [efff3df4] [efff3df4] 0xefff3df4
[ 46.894652] [efff3df4] [efff3df4] 0xefff3df4
[ 46.898924] [efff3df4] [efff3df4] 0xefff3df4
[ 46.903196] [efff3df4] [efff3df4] 0xefff3df4
[ 46.907467] [efff3df4] [efff3df4] 0xefff3df4
[ 46.911739] [efff3df4] [efff3df4] 0xefff3df4
[ 46.916011] [efff3df4] [efff3df4] 0xefff3df4
[ 46.920283] [efff3df4] [efff3df4] 0xefff3df4
[ 46.924554] [efff3df4] [efff3df4] 0xefff3df4
[ 46.928826] [efff3df4] [efff3df4] 0xefff3df4
[ 46.933097] [efff3df4] [efff3df4] 0xefff3df4
[ 46.937369] [efff3df4] [efff3df4] 0xefff3df4
[ 46.941641] [efff3df4] [efff3df4] 0xefff3df4
[ 46.945913] [efff3df4] [efff3df4] 0xefff3df4
[ 46.950185] [efff3df4] [efff3df4] 0xefff3df4
[ 46.954456] [efff3df4] [efff3df4] 0xefff3df4
[ 46.958728] [efff3df4] [efff3df4] 0xefff3df4
[ 46.963000] [efff3df4] [efff3df4] 0xefff3df4
[ 46.967271] [efff3df4] [efff3df4] 0xefff3df4
[ 46.971543] [efff3df4] [efff3df4] 0xefff3df4
[ 46.975815] [efff3df4] [efff3df4] 0xefff3df4
[ 46.980086] [efff3df4] [efff3df4] 0xefff3df4
[ 46.984358] [efff3df4] [efff3df4] 0xefff3df4
[ 46.988630] [efff3df4] [efff3df4] 0xefff3df4
[ 46.992901] [efff3df4] [efff3df4] 0xefff3df4
[ 46.997173] [efff3df4] [efff3df4] 0xefff3df4
[ 47.001444] [efff3df4] [efff3df4] 0xefff3df4
[ 47.005716] [efff3df4] [efff3df4] 0xefff3df4
[ 47.009988] [efff3df4] [efff3df4] 0xefff3df4
[ 47.014259] [efff3df4] [efff3df4] 0xefff3df4
[ 47.018531] [efff3df4] [efff3df4] 0xefff3df4
[ 47.022802] [efff3df4] [efff3df4] 0xefff3df4
[ 47.027074] [efff3df4] [efff3df4] 0xefff3df4
[ 47.031346] [efff3df4] [efff3df4] 0xefff3df4
[ 47.035617] [efff3df4] [efff3df4] 0xefff3df4
[ 47.039889] [efff3df4] [efff3df4] 0xefff3df4
[ 47.044160] [efff3df4] [efff3df4] 0xefff3df4
[ 47.048432] [efff3df4] [efff3df4] 0xefff3df4
[ 47.052704] Instruction dump:
[ 47.055668] XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX
[ 47.063428] XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX
[ 47.071192] ---[ end trace 828e5b35f2a50948 ]---
[ 47.075807]
[ 48.077304] Kernel panic - not syncing: Fatal exception
[ 48.082534] Rebooting in 3 seconds..
CCB:600 MHz,
Watchdog enabled
in: 200
out: 0
io_config: 255
SD/MMC : 4-bit Mode
eSPI : Enabled
ready
SPI: ready
Flash: 16 MiB
L2: 512 KiB enabled
NAND: 256 MiB
MMC: FSL_SDHC: 0
PCIe1: Bus 00 - 01
PCIe2: Bus 02 - 03
PCIe3: Bus 04 - 05
In: serial
Out: serial
Err: serial
PHY reset timed out
eTSEC1
, eTSEC2
, eTSEC3 [PRIME]
BOOT NAND
reading zImage
5929661 bytes read in 263 ms (21.5 MiB/s)
wdt status 00000003
reading fdt
[ 0.000005] clocksource: timebase: mask: 0xffffffffffffffff max_cycles: 0x114c1bade8, max_idle_ns: 440795203839 ns
[ 0.021149] pid_max: default: 32768 minimum: 301
[ 0.025840] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.033094] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.041507] mpic: requesting IPIs...
[ 0.045677] e500 family performance monitor hardware support registered
[ 0.064874] smp: Bringing up secondary CPUs ...
[ 0.069950] smp: Brought up 1 node, 2 CPUs
[ 0.074398] devtmpfs: initialized
[ 0.079660] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.089430] futex hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.096984] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.103415] thermal_sys: Registered thermal governor 'step_wise'
[ 0.111084] Machine: Turris 1.x
[ 0.120138] SoC family: QorIQ
[ 0.123093] SoC ID: svr:0x80ea0021, Revision: 2.1
[ 0.129155] Found FSL PCI host bridge at 0x00000000ffe08000. Firmware bus number: 0->1
[ 0.136992] PCI host bridge /pcie@ffe08000 (primary) ranges:
[ 0.142660] MEM 0x00000000c0000000..0x00000000c01fffff -> 0x00000000c0000000
[ 0.149859] IO 0x00000000ffc20000..0x00000000ffc2ffff -> 0x0000000000000000
[ 0.157010] /pcie@ffe08000: PCICSRBAR @ 0xfff00000
[ 0.161767] setup_pci_atmu: end of DRAM 80000000
[ 0.166747] Found FSL PCI host bridge at 0x00000000ffe09000. Firmware bus number: 0->1
[ 0.174593] PCI host bridge /pcie@ffe09000 ranges:
[ 0.179458] MEM 0x00000000a0000000..0x00000000bfffffff -> 0x00000000a0000000
[ 0.186688] IO 0x00000000ffc10000..0x00000000ffc1ffff -> 0x0000000000000000
[ 0.193809] /pcie@ffe09000: PCICSRBAR @ 0xfff00000
[ 0.198585] setup_pci_atmu: end of DRAM 80000000
[ 0.203545] Found FSL PCI host bridge at 0x00000000ffe0a000. Firmware bus number: 0->1
[ 0.211391] PCI host bridge /pcie@ffe0a000 ranges:
[ 0.216257] MEM 0x0000000080000000..0x000000009fffffff -> 0x0000000080000000
[ 0.223475] IO 0x00000000ffc00000..0x00000000ffc0ffff -> 0x0000000000000000
[ 0.230607] /pcie@ffe0a000: PCICSRBAR @ 0xfff00000
[ 0.235384] setup_pci_atmu: end of DRAM 80000000
[ 0.241041] software IO TLB: tearing down default memory pool
[ 0.253575] PCI: Probing PCI hardware
[ 0.257288] fsl-pci ffe08000.pcie: PCI host bridge to bus 0002:00
[ 0.263303] pci_bus 0002:00: root bus resource [io 0x0000-0xffff]
[ 0.269489] pci_bus 0002:00: root bus resource [mem 0xc0000000-0xc01fffff]
[ 0.276343] pci_bus 0002:00: root bus resource [bus 00-ff]
[ 0.281827] pci_bus 0002:00: busn_res: [bus 00-ff] end is updated to ff
[ 0.288452] pci 0002:00:00.0: [1957:0070] type 01 class 0x060400
[ 0.294441] pci 0002:00:00.0: reg 0x10: [mem 0xfff00000-0xffffffff]
[ 0.300727] pci 0002:00:00.0: supports D1 D2
[ 0.304951] pci 0002:00:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.312632] pci 0002:01:00.0: [104c:8241] type 00 class 0x0c0330
[ 0.318586] pci 0002:01:00.0: reg 0x10: [mem 0xc0000000-0xc000ffff 64bit]
[ 0.325348] pci 0002:01:00.0: reg 0x18: [mem 0xc0010000-0xc0011fff 64bit]
[ 0.332220] pci 0002:01:00.0: supports D1 D2
[ 0.336405] pci 0002:01:00.0: PME# supported from D0 D1 D2 D3hot
[ 0.342441] pci 0002:01:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0002:00:00.0 (capable of 4.000 Gb/s with 5.0 GT/s PCIe x1 link)
[ 0.388127] pci 0002:00:00.0: PCI bridge to [bus 01-ff]
[ 0.393273] pci 0002:00:00.0: bridge window [io 0x0000-0x0fff]
[ 0.399370] pci 0002:00:00.0: bridge window [mem 0xc0000000-0xc00fffff]
[ 0.406144] pci_bus 0002:01: busn_res: [bus 01-ff] end is updated to 01
[ 0.412755] pci_bus 0002:00: busn_res: [bus 00-ff] end is updated to 01
[ 0.419471] fsl-pci ffe09000.pcie: PCI host bridge to bus 0001:02
[ 0.425493] pci_bus 0001:02: root bus resource [io 0x20000-0x2ffff] (bus address [0x0000-0xffff])
[ 0.434435] pci_bus 0001:02: root bus resource [mem 0xa0000000-0xbfffffff]
[ 0.441311] pci_bus 0001:02: root bus resource [bus 02-ff]
[ 0.446780] pci_bus 0001:02: busn_res: [bus 02-ff] end is updated to ff
[ 0.453410] pci 0001:02:00.0: [1957:0070] type 01 class 0x060400
[ 0.459390] pci 0001:02:00.0: reg 0x10: [mem 0xfff00000-0xffffffff]
[ 0.465692] pci 0001:02:00.0: supports D1 D2
[ 0.469904] pci 0001:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.477451] pci 0001:02:00.0: Primary bus is hard wired to 0
[ 0.483027] pci 0001:02:00.0: bridge configuration invalid ([bus 01-01]), reconfiguring
[ 0.491118] pci 0001:03:00.0: [168c:0030] type 00 class 0x028000
[ 0.497058] pci 0001:03:00.0: reg 0x10: [mem 0xa0000000-0xa001ffff 64bit]
[ 0.503863] pci 0001:03:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ 0.510584] pci 0001:03:00.0: supports D1
[ 0.514525] pci 0001:03:00.0: PME# supported from D0 D1 D3hot
[ 0.545354] pci 0001:02:00.0: PCI bridge to [bus 03-ff]
[ 0.550499] pci 0001:02:00.0: bridge window [io 0x20000-0x20fff]
[ 0.556770] pci 0001:02:00.0: bridge window [mem 0xa0000000-0xa00fffff]
[ 0.563544] pci_bus 0001:03: busn_res: [bus 03-ff] end is updated to 03
[ 0.570155] pci_bus 0001:02: busn_res: [bus 02-ff] end is updated to 03
[ 0.576855] fsl-pci ffe0a000.pcie: PCI host bridge to bus 0000:04
[ 0.582877] pci_bus 0000:04: root bus resource [io 0x40000-0x4ffff] (bus address [0x0000-0xffff])
[ 0.591819] pci_bus 0000:04: root bus resource [mem 0x80000000-0x9fffffff]
[ 0.598694] pci_bus 0000:04: root bus resource [bus 04-ff]
[ 0.604164] pci_bus 0000:04: busn_res: [bus 04-ff] end is updated to ff
[ 0.610794] pci 0000:04:00.0: [1957:0070] type 01 class 0x060400
[ 0.616774] pci 0000:04:00.0: reg 0x10: [mem 0xfff00000-0xffffffff]
[ 0.623075] pci 0000:04:00.0: supports D1 D2
[ 0.627288] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.634836] pci 0000:04:00.0: Primary bus is hard wired to 0
[ 0.640411] pci 0000:04:00.0: bridge configuration invalid ([bus 01-01]), reconfiguring
[ 0.648502] pci 0000:05:00.0: [168c:003c] type 00 class 0x028000
[ 0.654443] pci 0000:05:00.0: reg 0x10: [mem 0x80000000-0x801fffff 64bit]
[ 0.661248] pci 0000:05:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ 0.667969] pci 0000:05:00.0: supports D1 D2
[ 0.703003] pci 0000:04:00.0: PCI bridge to [bus 05-ff]
[ 0.708148] pci 0000:04:00.0: bridge window [io 0x40000-0x40fff]
[ 0.714419] pci 0000:04:00.0: bridge window [mem 0x80000000-0x801fffff]
[ 0.721193] pci_bus 0000:05: busn_res: [bus 05-ff] end is updated to 05
[ 0.727804] pci_bus 0000:04: busn_res: [bus 04-ff] end is updated to 05
[ 0.734461] PCI: Cannot allocate resource region 0 of device 0002:00:00.0, will remap
[ 0.742238] PCI: Cannot allocate resource region 0 of device 0001:02:00.0, will remap
[ 0.750052] PCI: Cannot allocate resource region 0 of device 0000:04:00.0, will remap
[ 0.757924] pci 0002:00:00.0: BAR 0: no space for [mem size 0x00100000]
[ 0.764479] pci 0002:00:00.0: BAR 0: failed to assign [mem size 0x00100000]
[ 0.771444] pci 0002:00:00.0: PCI bridge to [bus 01]
[ 0.776390] pci 0002:00:00.0: bridge window [io 0x0000-0xffff]
[ 0.782488] pci 0002:00:00.0: bridge window [mem 0xc0000000-0xc01fffff]
[ 0.789256] pci_bus 0002:00: Some PCI device resources are unassigned, try booting with pci=realloc
[ 0.798305] pci_bus 0002:00: resource 4 [io 0x0000-0xffff]
[ 0.803859] pci_bus 0002:00: resource 5 [mem 0xc0000000-0xc01fffff]
[ 0.810125] pci_bus 0002:01: resource 0 [io 0x0000-0xffff]
[ 0.815682] pci_bus 0002:01: resource 1 [mem 0xc0000000-0xc01fffff]
[ 0.821953] pci 0001:02:00.0: BAR 0: no space for [mem size 0x00100000]
[ 0.828549] pci 0001:02:00.0: BAR 0: failed to assign [mem size 0x00100000]
[ 0.835515] pci 0001:03:00.0: BAR 6: assigned [mem 0xa0020000-0xa002ffff pref]
[ 0.842720] pci 0001:02:00.0: PCI bridge to [bus 03]
[ 0.847683] pci 0001:02:00.0: bridge window [io 0x20000-0x2ffff]
[ 0.853934] pci 0001:02:00.0: bridge window [mem 0xa0000000-0xbfffffff]
[ 0.860728] pci_bus 0001:02: Some PCI device resources are unassigned, try booting with pci=realloc
[ 0.869755] pci_bus 0001:02: resource 4 [io 0x20000-0x2ffff]
[ 0.875501] pci_bus 0001:02: resource 5 [mem 0xa0000000-0xbfffffff]
[ 0.881752] pci_bus 0001:03: resource 0 [io 0x20000-0x2ffff]
[ 0.887496] pci_bus 0001:03: resource 1 [mem 0xa0000000-0xbfffffff]
[ 0.893753] pci 0000:04:00.0: BAR 0: no space for [mem size 0x00100000]
[ 0.900363] pci 0000:04:00.0: BAR 0: failed to assign [mem size 0x00100000]
[ 0.907313] pci 0000:05:00.0: BAR 6: assigned [mem 0x80200000-0x8020ffff pref]
[ 0.914534] pci 0000:04:00.0: PCI bridge to [bus 05]
[ 0.919482] pci 0000:04:00.0: bridge window [io 0x40000-0x4ffff]
[ 0.925748] pci 0000:04:00.0: bridge window [mem 0x80000000-0x9fffffff]
[ 0.932522] pci_bus 0000:04: Some PCI device resources are unassigned, try booting with pci=realloc
[ 0.941575] pci_bus 0000:04: resource 4 [io 0x40000-0x4ffff]
[ 0.947300] pci_bus 0000:04: resource 5 [mem 0x80000000-0x9fffffff]
[ 0.953567] pci_bus 0000:05: resource 0 [io 0x40000-0x4ffff]
[ 0.959296] pci_bus 0000:05: resource 1 [mem 0x80000000-0x9fffffff]
[ 0.973160] raid6: skip pq benchmark and using algorithm int32x8
[ 0.979090] raid6: using intx1 recovery algorithm
[ 0.984233] SCSI subsystem initialized
[ 0.988012] usbcore: registered new interface driver usbfs
[ 0.993437] usbcore: registered new interface driver hub
[ 0.998751] usbcore: registered new device driver usb
[ 1.003812] EDAC MC: Ver: 3.0.0
[ 1.007915] clocksource: Switched to clocksource timebase
[ 1.018360] NET: Registered PF_INET protocol family
[ 1.023325] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 1.031474] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 1.039773] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 1.047492] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.055281] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.062439] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.068793] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.075355] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.082531] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 1.088169] pci 0002:00:00.0: enabling device (0106 -> 0107)
[ 1.093854] PCI: CLS 32 bytes, default 32
[ 1.099444] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 1.108809] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.114621] jffs2: version 2.2 (NAND) (SUMMARY) (ZLIB) (LZO) (LZMA) (RTIME) (RUBIN) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 1.126603] xor: measuring software checksum speed
[ 1.137581] 8regs : 1574 MB/sec
[ 1.149673] 8regs_prefetch : 1258 MB/sec
[ 1.160199] 32regs : 1573 MB/sec
[ 1.171538] 32regs_prefetch : 1391 MB/sec
[ 1.175807] xor: using function: 8regs (1574 MB/sec)
[ 1.180843] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 1.189385] pcieport 0002:00:00.0: AER: enabled with IRQ 24
[ 1.195041] pcieport 0001:02:00.0: enabling device (0106 -> 0107)
[ 1.201481] pcieport 0001:02:00.0: AER: enabled with IRQ 25
[ 1.207132] pcieport 0000:04:00.0: enabling device (0106 -> 0107)
[ 1.213520] pcieport 0000:04:00.0: AER: enabled with IRQ 26
[ 1.219359] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 1.228120] printk: console [ttyS0] disabled
[ 1.232343] serial8250.0: ttyS0 at MMIO 0xffe04500 (irq = 42, base_baud = 37500000) is a 16550A
[ 1.241064] printk: console [ttyS0] enabled
[ 1.249378] printk: bootconsole [udbg0] disabled
[ 1.258879] serial8250.0: ttyS1 at MMIO 0xffe04600 (irq = 42, base_baud = 37500000) is a 16550A
[ 1.268179] printk: console [ttyS0] disabled
[ 1.272547] printk: console [ttyS0] enabled
[ 1.277172] ffe04600.serial: ttyS1 at MMIO 0xffe04600 (irq = 42, base_baud = 37500000) is a 16550
[ 1.286683] Loading iSCSI transport class v2.0-870.
[ 1.294135] physmap-flash ef000000.nor: physmap platform flash device: [mem 0xef000000-0xefffffff]
[ 1.303327] ef000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000001 Chip ID 0x002101
[ 1.313367] Amd/Fujitsu Extended Query Table at 0x0040
[ 1.318553] Amd/Fujitsu Extended Query version 1.3.
[ 1.323608] number of CFI chips: 1
[ 1.327402] 7 fixed-partitions partitions found on MTD device ef000000.nor
[ 1.334310] Creating 7 MTD partitions on "ef000000.nor":
[ 1.339648] 0x000000000000-0x000000020000 : "dtb"
[ 1.344865] 0x000000020000-0x0000001c0000 : "kernel"
[ 1.350274] 0x0000001c0000-0x000000340000 : "rescue"
[ 1.355636] 0x000000340000-0x000000e40000 : "factory"
[ 1.361168] 0x000000e40000-0x000000f00000 : "certificates"
[ 1.367074] 0x000000f20000-0x000000f40000 : "u-boot-env"
[ 1.372828] 0x000000f40000-0x000001000000 : "u-boot"
[ 1.380715] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
[ 1.387086] nand: Micron MT29F2G08ABAEAWP
[ 1.391125] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 1.399885] Bad block table found at page 131008, version 0x01
[ 1.406626] Bad block table found at page 130944, version 0x01
[ 1.413234] 1 fixed-partitions partitions found on MTD device ff800000.flash
[ 1.420318] Creating 1 MTD partitions on "ff800000.flash":
[ 1.425808] 0x000000000000-0x000010000000 : "rootfs"
[ 1.431981] mtd: setting mtd7 (rootfs) as root device
[ 1.437399] mtdsplit: no squashfs found in "rootfs"
[ 1.442589] eLBC NAND device at 0xff800000, bank 1
[ 1.448063] fsl_espi ffe07000.spi: irq = 59
[ 1.457716] fsl-gianfar ffe24000.ethernet: Using random MAC address: 4e:1f:71:5a:98:f2
[ 1.466030] fsl-gianfar ffe24000.ethernet: enabled errata workarounds, flags: 0x4
[ 1.483953] fsl-gianfar ffe24000.ethernet eth0: mac: 4e:1f:71:5a:98:f2
[ 1.490515] fsl-gianfar ffe24000.ethernet eth0: Running with NAPI enabled
[ 1.497309] fsl-gianfar ffe24000.ethernet eth0: RX BD ring size for Q[0]: 256
[ 1.504458] fsl-gianfar ffe24000.ethernet eth0: TX BD ring size for Q[0]: 256
[ 1.511784] fsl-gianfar ffe25000.ethernet: Using random MAC address: f2:22:1c:39:27:aa
[ 1.520065] fsl-gianfar ffe25000.ethernet: enabled errata workarounds, flags: 0x4
[ 1.537976] fsl-gianfar ffe25000.ethernet eth1: mac: f2:22:1c:39:27:aa
[ 1.544519] fsl-gianfar ffe25000.ethernet eth1: Running with NAPI enabled
[ 1.551324] fsl-gianfar ffe25000.ethernet eth1: RX BD ring size for Q[0]: 256
[ 1.558476] fsl-gianfar ffe25000.ethernet eth1: TX BD ring size for Q[0]: 256
[ 1.565796] fsl-gianfar ffe26000.ethernet: Using random MAC address: 72:ea:bf:14:a8:87
[ 1.573748] fsl-gianfar ffe26000.ethernet: enabled errata workarounds, flags: 0x4
[ 1.591608] fsl-gianfar ffe26000.ethernet eth2: mac: 72:ea:bf:14:a8:87
[ 1.598168] fsl-gianfar ffe26000.ethernet eth2: Running with NAPI enabled
[ 1.604961] fsl-gianfar ffe26000.ethernet eth2: RX BD ring size for Q[0]: 256
[ 1.612110] fsl-gianfar ffe26000.ethernet eth2: TX BD ring size for Q[0]: 256
[ 1.619427] ucc_geth_driver: QE UCC Gigabit Ethernet Controller
[ 1.625433] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.632054] ehci-pci: EHCI PCI platform driver
[ 1.636877] fsl-ehci: Freescale EHCI Host controller driver
[ 1.642539] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
[ 1.649186] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
[ 1.656474] fsl-ehci fsl-ehci.0: irq 28, io mem 0xffe22000
[ 1.687943] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
[ 1.694066] hub 1-0:1.0: USB hub found
[ 1.697858] hub 1-0:1.0: 1 port detected
[ 1.702296] usbcore: registered new interface driver uas
[ 1.707689] usbcore: registered new interface driver usb-storage
[ 1.713942] i2c_dev: i2c /dev entries driver
[ 1.718382] mpc-i2c ffe03000.i2c: timeout 1000000 us
[ 1.723609] i2c i2c-0: of_i2c: modalias failure on /soc@ffe00000/i2c@3000/power-control@2a
[ 1.731921] i2c i2c-0: Failed to create I2C device for /soc@ffe00000/i2c@3000/power-control@2a
[ 1.740566] i2c i2c-0: of_i2c: modalias failure on /soc@ffe00000/i2c@3000/eeprom@32
[ 1.748249] i2c i2c-0: Failed to create I2C device for /soc@ffe00000/i2c@3000/eeprom@32
[ 1.756465] i2c i2c-0: of_i2c: modalias failure on /soc@ffe00000/i2c@3000/eeprom@57
[ 1.764151] i2c i2c-0: Failed to create I2C device for /soc@ffe00000/i2c@3000/eeprom@57
[ 1.772641] mpc-i2c ffe03100.i2c: timeout 1000000 us
[ 1.778044] booke_wdt: powerpc book-e watchdog driver loaded
[ 1.783962] Freescale(R) MPC85xx EDAC driver, (C) 2006 Montavista Software
[ 1.791063] fsl_mc_err_probe: No ECC DIMMs discovered
[ 1.796653] EDAC DEVICE0: Giving out device to module MPC85xx_edac controller mpc85xx_l2_err: DEV mpc85xx_l2_err (INTERRUPT)
[ 1.807955] MPC85xx_edac acquired irq 16 for L2 Err
[ 1.812834] MPC85xx_edac L2 err registered
[ 1.817256] EDAC PCI0: Giving out device to module MPC85xx_edac controller mpc85xx_pci_err: DEV mpc85xx-pci-edac.0.auto (INTERRUPT)
[ 1.829135] MPC85xx_edac acquired irq 24 for PCI Err
[ 1.834101] MPC85xx_edac PCI err registered
[ 1.838356] EDAC PCI1: Giving out device to module MPC85xx_edac controller mpc85xx_pci_err: DEV mpc85xx-pci-edac.1.auto (INTERRUPT)
[ 1.850224] MPC85xx_edac acquired irq 25 for PCI Err
[ 1.855189] MPC85xx_edac PCI err registered
[ 1.859447] EDAC PCI2: Giving out device to module MPC85xx_edac controller mpc85xx_pci_err: DEV mpc85xx-pci-edac.2.auto (INTERRUPT)
[ 1.871311] MPC85xx_edac acquired irq 26 for PCI Err
[ 1.876276] MPC85xx_edac PCI err registered
[ 1.880759] sdhci: Secure Digital Host Controller Interface driver
[ 1.886945] sdhci: Copyright(c) Pierre Ossman
[ 1.891310] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.897245] sdhci-esdhc ffe2e000.sdhc: Got CD GPIO
[ 1.897604] NET: Registered PF_INET6 protocol family
[ 1.902133] mmc0 bounce up to 128 segments into one, max segment size 65536 bytes
[ 1.908351] Segment Routing with IPv6
[ 1.918273] In-situ OAM (IOAM) with IPv6
[ 1.922250] NET: Registered PF_PACKET protocol family
[ 1.927357] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.938089] mmc0: SDHCI controller on ffe2e000.sdhc [ffe2e000.sdhc] using DMA
[ 1.940502] 8021q: 802.1Q VLAN Support v1.8
[ 1.951745] drmem: No dynamic reconfiguration memory found
[ 1.960016] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
[ 2.019197] mmc0: new high speed SDHC card at address 59b4
[ 2.025192] mmcblk0: mmc0:59b4 SD 7.36 GiB
[ 2.035969] mmcblk0: p1 p2
[ 2.047966] usb 1-1: new high-speed USB device number 2 using fsl-ehci
[ 2.075015] device eth1 entered promiscuous mode
[ 2.079768] device eth0 entered promiscuous mode
[ 2.088036] qca8k mdio@ffe24520:10: configuring for fixed/rgmii-id link mode
[ 2.100087] qca8k mdio@ffe24520:10: configuring for fixed/rgmii-id link mode
[ 2.109839] qca8k mdio@ffe24520:10: Link is Up - 1Gbps/Full - flow control off
[ 2.118396] qca8k mdio@ffe24520:10: Link is Up - 1Gbps/Full - flow control off
[ 2.191222] qca8k mdio@ffe24520:10 lan5 (uninitialized): PHY [qca8k-0.0:01] driver [Qualcomm Atheros 8337 internal PHY] (irq=POLL)
[ 2.281272] qca8k mdio@ffe24520:10 lan4 (uninitialized): PHY [qca8k-0.0:02] driver [Qualcomm Atheros 8337 internal PHY] (irq=POLL)
[ 2.294666] hub 1-1:1.0: USB hub found
[ 2.298600] hub 1-1:1.0: 2 ports detected
[ 2.381227] qca8k mdio@ffe24520:10 lan3 (uninitialized): PHY [qca8k-0.0:03] driver [Qualcomm Atheros 8337 internal PHY] (irq=POLL)
[ 2.481223] qca8k mdio@ffe24520:10 lan2 (uninitialized): PHY [qca8k-0.0:04] driver [Qualcomm Atheros 8337 internal PHY] (irq=POLL)
[ 2.571229] qca8k mdio@ffe24520:10 lan1 (uninitialized): PHY [qca8k-0.0:05] driver [Qualcomm Atheros 8337 internal PHY] (irq=POLL)
[ 2.583519] DSA: tree 0 setup
[ 2.593444] BTRFS: device fsid 102f5ee7-4016-4565-9718-be41bd28e459 devid 1 transid 1088041 /dev/root scanned by swapper/0 (1)
[ 2.616653] BTRFS info (device mmcblk0p2): using crc32c (crc32c-generic) checksum algorithm
[ 2.625124] BTRFS info (device mmcblk0p2): disk space caching is enabled
[ 2.631858] BTRFS info (device mmcblk0p2): has skinny extents
[ 2.647941] usb 1-1.1: new full-speed USB device number 3 using fsl-ehci
[ 2.753855] BTRFS info (device mmcblk0p2): enabling ssd optimizations
[ 2.817652] VFS: Mounted root (btrfs filesystem) on device 0:14.
[ 2.830439] devtmpfs: mounted
[ 2.833687] Freeing unused kernel image (initmem) memory: 256K
[ 2.839555] This architecture does not have kernel memory protection.
[ 2.846009] Run /sbin/init as init process
[ 3.146035] init: Console is alive
[ 3.149586] init: - watchdog -
[ 4.892972] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 4.917435] pps_core: LinuxPPS API ver. 1 registered
[ 4.922453] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 4.932618] PTP clock support registered
[ 4.937231] Button Hotplug driver version 0.4.1
[ 4.942995] ehci-platform: EHCI generic platform driver
[ 4.960833] xhci_hcd 0002:01:00.0: xHCI Host Controller
[ 4.966092] xhci_hcd 0002:01:00.0: new USB bus registered, assigned bus number 2
[ 4.973723] xhci_hcd 0002:01:00.0: hcc params 0x0270f06d hci version 0x96 quirks 0x0000000004000000
[ 4.983142] xhci_hcd 0002:01:00.0: xHCI Host Controller
[ 4.988395] xhci_hcd 0002:01:00.0: new USB bus registered, assigned bus number 3
[ 4.995804] xhci_hcd 0002:01:00.0: Host supports USB 3.0 SuperSpeed
[ 5.002620] hub 2-0:1.0: USB hub found
[ 5.006421] hub 2-0:1.0: 4 ports detected
[ 5.010866] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[ 5.019481] hub 3-0:1.0: USB hub found
[ 5.023279] hub 3-0:1.0: 4 ports detected
[ 5.032631] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 5.050167] init: - preinit -
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
rm: can't remove '/tmp/tmp.piPjOn': No such file or directory
[ 7.436357] mount_root: mounting /dev/root
[ 8.064754] urandom-seed: Seeding with /etc/urandom.seed
Scanning for Btrfs filesystems
[ 8.890903] mtdblock: MTD device 'rootfs' is NAND, please consider using UBI block devices instead.
reg[ 9.491927] BTRFS info: devid 1 device path /dev/root changed to /dev/mmcblk0p2 scanned by btrfs (496)
istered: /dev/mmcblk0p2
[ 9.505133] procd: - early -
[ 9.508093] procd: - watchdog -
[ 10.072947] procd: - watchdog -
[ 10.083476] procd: - ubus -
[ 10.122632] random: ubusd: uninitialized urandom read (4 bytes read)
[ 10.136714] random: ubusd: uninitialized urandom read (4 bytes read)
[ 10.143311] random: ubusd: uninitialized urandom read (4 bytes read)
[ 10.151200] procd: - init -
[ 11.656059] random: crng init done
[ 11.659495] random: 15 urandom warning(s) missed due to ratelimiting
[ 15.318853] kmodloader: loading kernel modules from /etc/modules.d/*
[ 15.451896] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 15.490330] pca953x 0-0018: supply vcc not found, using dummy regulator
[ 15.497110] pca953x 0-0018: using no AI
[ 15.503759] GACT probability on
[ 15.507605] Mirror/redirect action on
[ 15.518544] u32 classifier
[ 15.521261] input device check on
[ 15.524919] Actions configured
[ 15.537001] Bridge firewalling registered
[ 15.541960] Loading modules backported from Linux version v5.15.81-0-ge4a7232c917c
[ 15.549591] Backport generated by backports.git v5.15.81-1-0-ge1867d55
[ 15.566870] lm90 0-004c: supply vcc not found, using dummy regulator
[ 15.574754] hwmon hwmon0: temp1_input not attached to any thermal zone
[ 15.581363] hwmon hwmon0: temp2_input not attached to any thermal zone
[ 15.591890] pps pps0: new PPS source ptp0
[ 15.602706] rtc-ds1307 0-006f: registered as rtc0
[ 15.608427] rtc-ds1307 0-006f: setting system clock to 2024-02-16T13:09:16 UTC (1708088956)
[ 15.618987] usbcore: registered new interface driver ums-alauda
[ 15.625348] usbcore: registered new interface driver ums-cypress
[ 15.631993] usbcore: registered new interface driver ums-datafab
[ 15.638492] usbcore: registered new interface driver ums-freecom
[ 15.644986] usbcore: registered new interface driver ums-isd200
[ 15.651418] usbcore: registered new interface driver ums-jumpshot
[ 15.657980] usbcore: registered new interface driver ums-karma
[ 15.664425] usbcore: registered new interface driver ums-sddr09
[ 15.670935] usbcore: registered new interface driver ums-sddr55
[ 15.677385] usbcore: registered new interface driver ums-usbat
[ 15.690237] xt_time: kernel timezone is -0000
[ 15.754947] PPP generic driver version 2.4.2
[ 15.760069] NET: Registered PF_PPPOX protocol family
[ 15.786799] ath10k_pci 0000:05:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[ 16.224348] ath10k_pci 0000:05:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
[ 16.233725] ath10k_pci 0000:05:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
[ 16.243898] ath10k_pci 0000:05:00.0: firmware ver 10.2.4-1.0-00047 api 5 features no-p2p,raw-mode,mfp,allows-mesh-bcast crc32 35bd9258
[ 16.374360] ath10k_pci 0000:05:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[ 17.514249] ath10k_pci 0000:05:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
[ 17.784957] ieee80211 phy1: Atheros AR9300 Rev:3 mem=0xf2c00000, irq=37
[ 17.792203] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 22.152244] qca8k mdio@ffe24520:10 lan1: configuring for phy/gmii link mode
[ 22.159674] fsl-gianfar ffe25000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
[ 22.168052] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 22.186162] qca8k mdio@ffe24520:10 lan1: Link is Up - 1Gbps/Full - flow control rx/tx
[ 22.194281] br-guest: port 1(lan1.3) entered blocking state
[ 22.199926] br-guest: port 1(lan1.3) entered disabled state
[ 22.205747] device lan1.3 entered promiscuous mode
[ 22.210573] device lan1 entered promiscuous mode
[ 22.216756] IPv6: ADDRCONF(NETDEV_CHANGE): lan1: link becomes ready
[ 22.225367] br-guest: port 1(lan1.3) entered blocking state
[ 22.230987] br-guest: port 1(lan1.3) entered forwarding state
[ 22.244732] br-lan: port 1(lan1) entered blocking state
[ 22.250023] br-lan: port 1(lan1) entered disabled state
[ 22.267852] br-lan: port 1(lan1) entered blocking state
[ 22.273136] br-lan: port 1(lan1) entered forwarding state
[ 22.288427] qca8k mdio@ffe24520:10 lan2: configuring for phy/gmii link mode
[ 22.297825] qca8k mdio@ffe24520:10 lan2: Link is Up - 100Mbps/Full - flow control rx/tx
[ 22.308290] br-lan: port 2(lan2) entered blocking state
[ 22.313540] br-lan: port 2(lan2) entered disabled state
[ 22.324540] device lan2 entered promiscuous mode
[ 22.338048] br-lan: port 2(lan2) entered blocking state
[ 22.343303] br-lan: port 2(lan2) entered forwarding state
[ 22.380414] qca8k mdio@ffe24520:10 lan3: configuring for phy/gmii link mode
[ 22.393820] br-lan: port 3(lan3) entered blocking state
[ 22.399105] br-lan: port 3(lan3) entered disabled state
[ 22.420193] device lan3 entered promiscuous mode
[ 22.441601] qca8k mdio@ffe24520:10 lan4: configuring for phy/gmii link mode
[ 22.451367] br-lan: port 4(lan4) entered blocking state
[ 22.456657] br-lan: port 4(lan4) entered disabled state
[ 22.470468] device lan4 entered promiscuous mode
[ 22.493730] qca8k mdio@ffe24520:10 lan5: configuring for phy/gmii link mode
[ 22.504850] br-lan: port 5(lan5) entered blocking state
[ 22.510135] br-lan: port 5(lan5) entered disabled state
[ 22.518273] device lan5 entered promiscuous mode
[ 23.106310] ath: EEPROM regdomain: 0x80cb
[ 23.110367] ath: EEPROM indicates we should expect a country code
[ 23.116489] ath: doing EEPROM country->regdmn map search
[ 23.121819] ath: country maps to regdmn code: 0x37
[ 23.126614] ath: Country alpha2 being used: CZ
[ 23.131131] ath: Regpair used: 0x37
[ 23.134637] ath: regdomain 0x80cb dynamically updated by user
[ 23.140484] ath: EEPROM regdomain: 0x80cb
[ 23.144501] ath: EEPROM indicates we should expect a country code
[ 23.150611] ath: doing EEPROM country->regdmn map search
[ 23.155925] ath: country maps to regdmn code: 0x37
[ 23.160725] ath: Country alpha2 being used: CZ
[ 23.165172] ath: Regpair used: 0x37
[ 23.168676] ath: regdomain 0x80cb dynamically updated by user
[ 23.247959] IPv6: ADDRCONF(NETDEV_CHANGE): br-guest: link becomes ready
[ 24.001363] br-lan: port 6(wlan1) entered blocking state
[ 24.006714] br-lan: port 6(wlan1) entered disabled state
[ 24.012318] device wlan1 entered promiscuous mode
[ 24.017186] br-lan: port 6(wlan1) entered blocking state
[ 24.022559] br-lan: port 6(wlan1) entered forwarding state
[ 24.128909] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[ 24.452239] br-guest: port 2(wlan1-1) entered blocking state
[ 24.457960] br-guest: port 2(wlan1-1) entered disabled state
[ 24.463824] device wlan1-1 entered promiscuous mode
[ 24.488549] br-guest: port 2(wlan1-1) entered blocking state
[ 24.494241] br-guest: port 2(wlan1-1) entered forwarding state
[ 24.500761] br-guest: port 2(wlan1-1) entered disabled state
[ 24.605005] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1-1: link becomes ready
[ 24.611797] br-guest: port 2(wlan1-1) entered blocking state
[ 24.617505] br-guest: port 2(wlan1-1) entered forwarding state
[ 26.567638] ath10k_pci 0000:05:00.0: pdev param 0 not supported by firmware
[ 26.591829] br-lan: port 7(wlan0) entered blocking state
[ 26.597214] br-lan: port 7(wlan0) entered disabled state
[ 26.602752] device wlan0 entered promiscuous mode
[ 38.437947] BUG: scheduling while atomic: sh/4133/0x00000100
[ 38.443633] Modules linked in: ath9k ath9k_common xt_connlimit pppoe ppp_async nf_conncount iptable_nat ath9k_hw ath10k_pci ath10k_core ath xt_state xt_nat xt_helper xt_conntrack xt_connmark xt_connbytes xt_REDIRECT xt_MASQUERADE xt_FLOWOFFLOAD xt_CT pppox ppp_generic nf_nat_ftp nf_nat nf_flow_table nf_conntrack_netlink nf_conntrack_ftp nf_conntrack mt7915e mt76_connac_lib mt76 mac80211 ipt_REJECT ebtable_nat ebtable_filter ebtable_broute cfg80211 xt_time xt_tcpudp xt_tcpmss xt_statistic xt_recent xt_multiport xt_mark xt_mac xt_limit xt_length xt_hl xt_ecn xt_dscp xt_comment xt_TCPMSS xt_LOG xt_HL xt_DSCP xt_CLASSIFY ums_usbat ums_sddr55 ums_sddr09 ums_karma ums_jumpshot ums_isd200 ums_freecom ums_datafab ums_cypress ums_alauda slhc sch_cake rtc_ds1307 ptp_qoriq nf_reject_ipv4 nf_log_syslog nf_defrag_ipv6 nf_defrag_ipv4 lm90 iptable_raw iptable_mangle iptable_filter ipt_ECN ip_tables hwmon ebtables ebt_vlan ebt_stp ebt_redirect ebt_pkttype ebt_mark_m ebt_mark ebt_limit ebt_among
[ 38.443954] ebt_802_3 crc_ccitt compat br_netfilter sch_tbf sch_ingress sch_htb sch_hfsc em_u32 cls_u32 cls_route cls_matchall cls_fw cls_flow cls_basic act_skbedit act_mirred act_gact configs gpio_pca953x regmap_i2c xt_set ip_set_list_set ip_set_hash_netportnet ip_set_hash_netport ip_set_hash_netnet ip_set_hash_netiface ip_set_hash_net ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ipmac ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 ifb sit ip6_tunnel netlink_diag tunnel6 tunnel4 ip_tunnel nls_utf8 sha256_ppc_spe seqiv jitterentropy_rng drbg md5_ppc hmac cmac gpio_keys leds_turris_1x leds_gpio xhci_plat_hcd xhci_pci xhci_hcd ahci libahci libata ehci_platform button_hotplug ptp pps_core
[ 38.607924] CPU: 0 PID: 4133 Comm: sh Not tainted 5.15.147 #0
[ 38.613689] Call Trace:
[ 38.616130] [efff3d90] [c050dab0] dump_stack_lvl+0x4c/0x6c (unreliable)
[ 38.622768] [efff3db0] [c0062cf0] __schedule_bug+0x54/0x6c
[ 38.628259] [efff3dc0] [c094b67c] __schedule+0x3b4/0x5e4
[ 38.633584] [efff3e10] [c094b910] schedule+0x64/0xe0
[ 38.638553] [efff3e30] [c094bc54] schedule_preempt_disabled+0x10/0x20
[ 38.645001] [efff3e40] [c094d5b4] __mutex_lock.isra.14+0x480/0x49c
[ 38.651189] [efff3e90] [f1132664] 0xf1132664
[ 38.655466] [efff3ec0] [c070a18c] led_timer_function+0x98/0x1cc
[ 38.661394] [efff3ee0] [c00afec4] call_timer_fn.isra.35+0x24/0x84
[ 38.667494] [efff3f00] [c00b0220] run_timer_softirq+0x2fc/0x388
[ 38.673418] [efff3f90] [c0951df0] __do_softirq+0x150/0x298
[ 38.678909] [efff3ff0] [c00053d0] do_softirq_own_stack+0x34/0x4c
[ 38.684924] [c3bd5ed0] [c000a774] timer_interrupt+0x1c8/0x2b0
[ 38.690680] [c3bd5ef0] [c003e7a4] irq_exit+0x88/0xc4
[ 38.695657] [c3bd5f10] [c000138c] Decrementer+0x14c/0x160
[ 38.701060] --- interrupt: 900 at 0xc30950
[ 38.705155] NIP: 00c30950 LR: 00c0c090 CTR: b7843edc
[ 38.710205] REGS: c3bd5f20 TRAP: 0900 Not tainted (5.15.147)
[ 38.716127] MSR: 0202d000 <VEC,CE,EE,PR,ME> CR: 20004242 XER: 00000000
[ 38.722935]
[ 38.722935] GPR00: 00c0c090 bfe20810 b789718c 00000000 00000000 20002242 00000000 00000000
[ 38.722935] GPR08: 00000000 00000000 00000000 bfe208b0 40004242 00000000 00000000 bfe77f8c
[ 38.722935] GPR16: 008dd0ec 00000000 00000020 b78739a4 b789028c 00c369f8 00c60038 00c60088
[ 38.722935] GPR24: bfe208c0 00c60038 00000000 00000000 00000001 00c60d20 00c5fb2c 00c60900
[ 38.757898] NIP [00c30950] 0xc30950
[ 38.761384] LR [00c0c090] 0xc0c090
[ 38.764783] --- interrupt: 900
[ 38.847941] BUG: scheduling while atomic: foris-controlle/3246/0x00000100
[ 38.854755] Modules linked in: ath9k ath9k_common xt_connlimit pppoe ppp_async nf_conncount iptable_nat ath9k_hw ath10k_pci ath10k_core ath xt_state xt_nat xt_helper xt_conntrack xt_connmark xt_connbytes xt_REDIRECT xt_MASQUERADE xt_FLOWOFFLOAD xt_CT pppox ppp_generic nf_nat_ftp nf_nat nf_flow_table nf_conntrack_netlink nf_conntrack_ftp nf_conntrack mt7915e mt76_connac_lib mt76 mac80211 ipt_REJECT ebtable_nat ebtable_filter ebtable_broute cfg80211 xt_time xt_tcpudp xt_tcpmss xt_statistic xt_recent xt_multiport xt_mark xt_mac xt_limit xt_length xt_hl xt_ecn xt_dscp xt_comment xt_TCPMSS xt_LOG xt_HL xt_DSCP xt_CLASSIFY ums_usbat ums_sddr55 ums_sddr09 ums_karma ums_jumpshot ums_isd200 ums_freecom ums_datafab ums_cypress ums_alauda slhc sch_cake rtc_ds1307 ptp_qoriq nf_reject_ipv4 nf_log_syslog nf_defrag_ipv6 nf_defrag_ipv4 lm90 iptable_raw iptable_mangle iptable_filter ipt_ECN ip_tables hwmon ebtables ebt_vlan ebt_stp ebt_redirect ebt_pkttype ebt_mark_m ebt_mark ebt_limit ebt_among
[ 38.855070] ebt_802_3 crc_ccitt compat br_netfilter sch_tbf sch_ingress sch_htb sch_hfsc em_u32 cls_u32 cls_route cls_matchall cls_fw cls_flow cls_basic act_skbedit act_mirred act_gact configs gpio_pca953x regmap_i2c xt_set ip_set_list_set ip_set_hash_netportnet ip_set_hash_netport ip_set_hash_netnet ip_set_hash_netiface ip_set_hash_net ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ipmac ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 ifb sit ip6_tunnel netlink_diag tunnel6 tunnel4 ip_tunnel nls_utf8 sha256_ppc_spe seqiv jitterentropy_rng drbg md5_ppc hmac cmac gpio_keys leds_turris_1x leds_gpio xhci_plat_hcd xhci_pci xhci_hcd ahci libahci libata ehci_platform button_hotplug ptp pps_core
[ 39.019030] CPU: 0 PID: 3246 Comm: foris-controlle Tainted: G W 5.15.147 #0
[ 39.027308] Call Trace:
[ 39.029749] [efff3d90] [c050dab0] dump_stack_lvl+0x4c/0x6c (unreliable)
[ 39.036383] [efff3db0] [c0062cf0] __schedule_bug+0x54/0x6c
[ 39.041876] [efff3dc0] [c094b67c] __schedule+0x3b4/0x5e4
[ 39.047200] [efff3e10] [c094b910] schedule+0x64/0xe0
[ 39.052170] [efff3e30] [c094bc54] schedule_preempt_disabled+0x10/0x20
[ 39.058617] [efff3e40] [c094d5b4] __mutex_lock.isra.14+0x480/0x49c
[ 39.064806] [efff3e90] [f1132664] 0xf1132664
[ 39.069082] [efff3ec0] [c070a18c] led_timer_function+0x98/0x1cc
[ 39.075010] [efff3ee0] [c00afec4] call_timer_fn.isra.35+0x24/0x84
[ 39.081111] [efff3f00] [c00b0220] run_timer_softirq+0x2fc/0x388
[ 39.087036] [efff3f90] [c0951df0] __do_softirq+0x150/0x298
[ 39.092527] [efff3ff0] [c00053d0] do_softirq_own_stack+0x34/0x4c
[ 39.098542] [c2a37ed0] [c000a774] timer_interrupt+0x1c8/0x2b0
[ 39.104298] [c2a37ef0] [c003e7a4] irq_exit+0x88/0xc4
[ 39.109276] [c2a37f10] [c000138c] Decrementer+0x14c/0x160
[ 39.114678] --- interrupt: 900 at 0xb7a196a8
[ 39.118947] NIP: b7a196a8 LR: b7a19670 CTR: b7a50c64
[ 39.123998] REGS: c2a37f20 TRAP: 0900 Tainted: G W (5.15.147)
[ 39.131309] MSR: 0202d000 <VEC,CE,EE,PR,ME> CR: 44002288 XER: 00000000
[ 39.138119]
[ 39.138119] GPR00: b7a1972c bfec94f0 b7c9018c 00000001 00000800 01424d48 80000003 00cb1be4
[ 39.138119] GPR08: 00000038 00cb1be0 bfec9508 bfec9520 44002288 00000000 00000000 b7c84010
[ 39.138119] GPR16: 012a5990 00000003 00b05178 01424d48 bfec95b8 01424d3c 000000a1 01424d40
[ 39.138119] GPR24: 0128dcc8 0128dd10 00000000 80000003 01424d48 b7b9f250 b7b9ac08 00cb1ba8
[ 39.173086] NIP [b7a196a8] 0xb7a196a8
[ 39.176745] LR [b7a19670] 0xb7a19670
[ 39.180318] --- interrupt: 900
[ 39.183451] Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: __schedule+0x5e4/0x5e4
[ 39.193383] CPU: 0 PID: 4133 Comm: sh Tainted: G W 5.15.147 #0
[ 39.200525] Call Trace:
[ 39.202965] [efff3d30] [c050dab0] dump_stack_lvl+0x4c/0x6c (unreliable)
[ 39.209591] [efff3d50] [c003914c] panic+0x138/0x300
[ 39.214474] [efff3db0] [c094afd8] rcu_dynticks_inc+0x0/0x4c
[ 39.220052] [efff3dc0] [c094b8ac] schedule+0x0/0xe0
[ 39.224934] [efff3e10] [c094b910] schedule+0x64/0xe0
[ 39.229903] [efff3e30] [c094bc54] schedule_preempt_disabled+0x10/0x20
[ 39.236351] [efff3e40] [c094d5b4] __mutex_lock.isra.14+0x480/0x49c
[ 39.242538] [efff3e90] [f1132664] 0xf1132664
[ 39.246813] [efff3ec0] [c070a18c] led_timer_function+0x98/0x1cc
[ 39.252739] [efff3ee0] [c00afec4] call_timer_fn.isra.35+0x24/0x84
[ 39.258839] [efff3f00] [c00b0220] run_timer_softirq+0x2fc/0x388
[ 39.264764] [efff3f90] [c0951df0] __do_softirq+0x150/0x298
[ 39.270254] [efff3ff0] [c00053d0] do_softirq_own_stack+0x34/0x4c
[ 39.276273] Rebooting in 3 seconds..
U-Boot 2015.04-04654-gbcfb33e-dirty (Jun 26 2015 - 12:50:49)
CPU0: P2020E, Version: 2.1, (0x80ea0021)
Core: e500, Version: 5.1, (0x80211051)
Clock Configuration:
CPU0:1200 MHz, CPU1:1200 MHz,
CCB:600 MHz,
DDR:400 MHz (800 MT/s data rate) (Asynchronous), LBC:37.500 MHz
L1: D-cache 32 KiB enabled
I-cache 32 KiB enabled
wdt status 00000005 reset
Watchdog enabled
Board: TURRIS CPLD: V4.1 PCBA: V4.0
Error, wrong i2c adapter 2 max 2 possible
in: 200
out: 0
io_config: 255
rom_loc: nor upper bank
SD/MMC : 4-bit Mode
eSPI : Enabled
I2C: Error, wrong i2c adapter 2 max 2 possible
ready
SPI: ready
DRAM: Error, wrong i2c adapter 2 max 2 possible
Detected UDIMM 9905594-009.A00LF
WARNING: Calling __hwconfig without a buffer and before environment is ready
2 GiB (DDR3, 64-bit, CL=6, ECC off)
Flash: 16 MiB
L2: 512 KiB enabled
NAND: 256 MiB
MMC: FSL_SDHC: 0
PCIe1: Root Complex of mini PCIe SLOT, x1 gen1, regs @ 0xffe0a000
01:00.0 - 168c:003c - Network controller
PCIe1: Bus 00 - 01
PCIe2: Root Complex of PCIe SLOT, x1 gen1, regs @ 0xffe09000
03:00.0 - 168c:0030 - Network controller
PCIe2: Bus 02 - 03
PCIe3: Root Complex of PCIe SLOT, x1 gen1, regs @ 0xffe08000
05:00.0 - 104c:8241 - Serial bus controller
PCIe3: Bus 04 - 05
In: serial
Out: serial
Err: serial
Net: Phy 5 not found
PHY reset timed out
eTSEC1
Error: eTSEC1 address not set.
, eTSEC2
Error: eTSEC2 address not set.
, eTSEC3 [PRIME]
Error: eTSEC3 address not set.
Hit any key to stop autoboot: 1 0
