Turris OS 6.5.1 is out!
Dear Turris users,
we just released Turris OS version 6.5.1. It is really small fix for 6.5 addressing mainly OpenVPN client issue. But while at it, we already did a kernel update, so it is part of the release as well. We also updated a little bit a description for Firmware Updates to stress that it is dangerous action and some skills might be needed to recover.
Full release notes are as follows:
:pushpin: Updates
• kernel: Updated to version 5.15.147
:bug: Bug Fixes
• openvpn-client: Fix configuration path and make client work again
As always, if you encounter some issue, don’t hesitate to let us know.
Turris Omnia 2020. 2x Wifi, 1TB SSD, AdBlock, Wireguard, Samba, MiniDLNA, NetData. Firmware was already on the latest with 6.5.0 release.
No issues.
Thank you guys.
I must have misunderstood something. I thought that when I checked Latest Firmware > Factory Image after upgrading to 6.5.0, that the next time I upgrade, version 6.5.1 will automatically be set as the factory image. But the schnapps factory-image command still lists version 5.3.0. And the schnapps update-factory command still gives ā€˜Don’t know what device I am, can’t update my factory image’.
What am I doing wrong?
I am on Turris 1.1
It is written in MakeFile … (https://gitlab.nic.cz/turris/os/packages/-/blob/master/utils/firmware-updater/Makefile) …
ā€œScript that makes sure you have the latest U-Boot, rescue system and MCU firmware if applicable.
Apart from that updates factory image whenever new major version comes out.ā€
TO 2016, HBS branch, 2 GB, SSD 256 GB, 2x WiFi, HaaS, RIPE Atlas, Sentinel, lxc (test), simple config, all seems OK.
Very valuable update, indeed!
I upgraded to 6.5.0 on my routers (Omnia 2016 1GB, Omnia 2019 2GB and MOX). Everything OK. I then updated the firmware with ā€œnor-updateā€. Without error messages. A query with ā€œstrings /dev/mtd0 | grep U-Bootā€ brings the following result: ā€œU-Boot SPL 2022.10-rc4-OpenWrt-r16653+119-44ce70f0e2 (Sep 15 2022 - 18:21:35 +0000)ā€. On the Omnia routers I see in the system log:
Feb 5 17:06:27 turris-wl kernel: [ 10.797338] turris-omnia-mcu 1-002a: Your board’s MCU firmware does not support the feature reading feature.
Feb 5 17:06:27 turris-wl kernel: [ 10.807244] turris-omnia-mcu 1-002a: MCU type STM32
Feb 5 17:06:27 turris-wl kernel: [ 10.816225] turris-omnia-mcu 1-002a: MCU bootloader firmware version hash: b5a8a24e007eb72be16aeb3fff6f03ec647023e4
Feb 5 17:06:27 turris-wl kernel: [ 10.818348] random: crng init done
Feb 5 17:06:27 turris-wl kernel: [ 10.828958] turris-omnia-mcu 1-002a: MCU application firmware version hash: b5a8a24e007eb72be16aeb3fff6f03ec647023e4
Feb 5 17:06:27 turris-wl kernel: [ 10.830115] random: 34 urandom warning(s) missed due to ratelimiting
Feb 5 17:06:27 turris-wl kernel: [ 10.840651] turris-omnia-mcu 1-002a: Your board’s MCU firmware does not support the extended control and status feature.
Feb 5 17:06:27 turris-wl kernel: [ 10.857930] turris-omnia-mcu 1-002a: Your board’s MCU firmware does not support the watchdog pinging feature.
Feb 5 17:06:27 turris-wl kernel: [ 10.867873] turris-omnia-mcu 1-002a: Your board’s MCU firmware does not support the peripheral LED pins reading feature.
Feb 5 17:06:27 turris-wl kernel: [ 10.878772] turris-omnia-mcu 1-002a: Your board’s MCU firmware does not support the new interrupt API feature.
Feb 5 17:06:27 turris-wl kernel: [ 10.888800] turris-omnia-mcu 1-002a: Your board’s MCU firmware does not support the poweroff and wakeup feature.
Feb 5 17:06:27 turris-wl kernel: [ 10.899001] turris-omnia-mcu 1-002a: Consider upgrading MCU firmware with the omnia-mcutool utility.
Feb 5 17:06:27 turris-wl kernel: [ 10.909887] leds-turris-omnia 1-002b: Your board’s MCU firmware does not support the LED gamma correction feature.
Feb 5 17:06:27 turris-wl kernel: [ 10.920331] leds-turris-omnia 1-002b: Consider upgrading MCU firmware with the omnia-mcutool utility."
I have now updated to version 6.5.1 and I also get the same error messages. What could be the reason or is everything OK?
You can update your MCU firmware with omnia-mcutool --upgrade.
Thank you ā€œbamfā€, it works !
Probably this is not the best place for a bug report, but Squid segfaults. I can’t even invoke it with a configuration check switch, or something like that.
root:/etc/squid# cat /etc/os-release
NAME="TurrisOS"
VERSION="6.5.1"
ID="turrisos"
ID_LIKE="lede openwrt"
PRETTY_NAME="TurrisOS 6.5.1"
VERSION_ID="6.5.1"
HOME_URL="https://www.turris.cz/"
BUG_URL="https://gitlab.nic.cz/groups/turris/-/issues/"
SUPPORT_URL="https://www.turris.cz/support/"
BUILD_ID="r16881+135-4a1d8ef55c"
OPENWRT_BOARD="mvebu/cortexa9"
OPENWRT_ARCH="arm_cortex-a9_vfpv3-d16"
OPENWRT_TAINTS="busybox"
OPENWRT_DEVICE_MANUFACTURER="CZ.NIC"
OPENWRT_DEVICE_MANUFACTURER_URL="https://www.turris.cz/"
OPENWRT_DEVICE_PRODUCT="Turris Omnia"
OPENWRT_DEVICE_REVISION="v0"
OPENWRT_RELEASE="TurrisOS 6.5.1 4a1d8ef55cbf247f06dae8e958eb8eb42f1882a5"
root:/etc/squid# /usr/sbin/squid
Segmentation fault
root:/etc/squid# echo $?
139
root:/etc/squid#
Thanks for reporting. I can confirm that it really crashes. I’ve created an issue for further investigation.
Many thanks Lukas! I also did an strace, but did not get any wiser, just saw it does not even try to pick up the configuration. :slight_smile:
I think there is a little typo bug in 0001-base-files-Better-IPv6-defaults.patch patch to /bin/config_generate
Line 179 call set network.$1.ip6ifaceif='eui64' but netifd only support option ip6ifaceid not ip6ifaceif .
My IPv6 config is still working OK with option ip6ifaceif 'eui64' in /etc/config/network .
Regards,
Laurent
Lot of typos in the last months.
Thank you for your report. It doesn’t break anything if not set, it is just a little improvement over the default. We will fix that in 7.0.
My turris 1.1 is kernel panicking right after start after update :sleepy:
U-Boot 2015.04-04654-gbcfb33e-dirty (Jun 26 2015 - 12:50:49)
CPU0:  P2020E, Version: 2.1, (0x80ea0021)
Core:  e500, Version: 5.1, (0x80211051)
Clock Configuration:
       CPU0:1200 MHz, CPU1:1200 MHz,
       CCB:600  MHz,
       DDR:400  MHz (800 MT/s data rate) (Asynchronous), LBC:37.500 MHz
L1:    D-cache 32 KiB enabled
       I-cache 32 KiB enabled
wdt status 00000005 reset
       Watchdog enabled
Board: TURRIS CPLD: V4.1 PCBA: V4.0
Error, wrong i2c adapter 2 max 2 possible
in: 56
out: 0
io_config: 255
rom_loc: nor upper bank
SD/MMC : 4-bit Mode
eSPI : Enabled
I2C:   Error, wrong i2c adapter 2 max 2 possible
ready
SPI:   ready
DRAM:  Error, wrong i2c adapter 2 max 2 possible
Detected UDIMM 9905594-009.A00LF
WARNING: Calling __hwconfig without a buffer and before environment is ready
2 GiB (DDR3, 64-bit, CL=6, ECC off)
Flash: 16 MiB
L2:    512 KiB enabled
NAND:  256 MiB
MMC:   FSL_SDHC: 0
PCIe1: Root Complex of mini PCIe SLOT, x1 gen1, regs @ 0xffe0a000
  01:00.0     - 168c:003c - Network controller
PCIe1: Bus 00 - 01
PCIe2: Root Complex of PCIe SLOT, x1 gen1, regs @ 0xffe09000
  03:00.0     - 168c:0030 - Network controller
PCIe2: Bus 02 - 03
PCIe3: Root Complex of PCIe SLOT, x1 gen1, regs @ 0xffe08000
  05:00.0     - 104c:8241 - Serial bus controller
PCIe3: Bus 04 - 05
In:    serial
Out:   serial
Err:   serial
Net:   Phy 5 not found
PHY reset timed out
eTSEC1
Error: eTSEC1 address not set.
, eTSEC2
Error: eTSEC2 address not set.
, eTSEC3 [PRIME]
Error: eTSEC3 address not set.
Hit any key to stop autoboot:  1  0
BOOT NAND
reading zImage
5929661 bytes read in 262 ms (21.6 MiB/s)
wdt status 00000003
reading fdt
13731 bytes read in 13 ms (1 MiB/s)
WARNING: adjusting available memory to 30000000
## Booting kernel from Legacy Image at 02100000 ...
   Image Name:   Linux-5.15.147
   Created:      2024-02-02   1:42:18 UTC
   Image Type:   PowerPC Linux Kernel Image (gzip compressed)
   Data Size:    5929597 Bytes = 5.7 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 02000000
   Booting using the fdt blob at 0x2000000
   Uncompressing Kernel Image ... OK
   Loading Device Tree to 03ff9000, end 03fff5a2 ... OK
WARNING: could not find compatible node fsl-usb2-dr
[    0.000000] Memory CAM mapping: 256/256/256 Mb, residual: 1280Mb
[    0.000000] Linux version 5.15.147 (packaging@turris.cz) (powerpc-openwrt-linux-muslspe-gcc (OpenWrt GCC 8.4.0 r16881+135-4a1d8ef55c) 8.4.0, GNU ld (GNU Binutils) 2.34) #0 SMP Fri Feb 2 01:42:18 2024
[    0.000000] Using P2020RDB-PC machine description
[    0.000000] printk: bootconsole [udbg0] enabled
[    0.000000] CPU maps initialized for 1 thread per core
[    0.000000] -----------------------------------------------------
[    0.000000] phys_mem_size     = 0x80000000
[    0.000000] dcache_bsize      = 0x20
[    0.000000] icache_bsize      = 0x20
[    0.000000] cpu_features      = 0x0000000010010108
[    0.000000]   possible        = 0x0000000010010108
[    0.000000]   always          = 0x0000000010010108
[    0.000000] cpu_user_features = 0x84e08000 0x08000000
[    0.000000] mmu_features      = 0x00020010
mpc85xx_rdb_setup_arch()
[    0.000000] ioremap() called early from of_iomap+0x48/0x80. Use early_ioremap() instead
[    0.000000] MPC85xx RDB board from Freescale Semiconductor
[    0.000000] barrier-nospec: using isync; sync as speculation barrier
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000000000000-0x000000002fffffff]
[    0.000000]   HighMem  [mem 0x0000000030000000-0x000000007fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000007fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[    0.000000] MMU: Allocated 1088 bytes of context maps for 255 contexts
[    0.000000] percpu: Embedded 11 pages/cpu s13868 r8192 d22996 u45056
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 522560
[    0.000000] Kernel command line: root=/dev/mmcblk0p2 rootwait rw rootfstype=btrfs rootflags=subvol=@,commit=5 console=ttyS0,115200
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Kernel virtual memory layout:
[    0.000000]   * 0xffbbf000..0xfffff000  : fixmap
[    0.000000]   * 0xff400000..0xff800000  : highmem PTEs
[    0.000000]   * 0xff3fe000..0xff400000  : early ioremap
[    0.000000]   * 0xf1000000..0xff3fe000  : vmalloc & ioremap
[    0.000000] Memory: 1998976K/2097152K available (9544K kernel code, 728K rwdata, 1996K rodata, 256K init, 276K bss, 98176K reserved, 0K cma-reserved, 1310712K highmem)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 512, nr_irqs: 512, preallocated irqs: 16
[    0.000000] mpic: Setting up MPIC " OpenPIC  " version 1.2 at ffe40000, max 2 CPUs
[    0.000000] mpic: ISU size: 256, shift: 8, mask: ff
[    0.000000] mpic: Initializing for 256 sources
[    0.000005] clocksource: timebase: mask: 0xffffffffffffffff max_cycles: 0x114c1bade8, max_idle_ns: 440795203839 ns
[    0.010295] clocksource: timebase mult[d555555] shift[24] registered
[    0.016765] Console: colour dummy device 80x25
[    0.021149] pid_max: default: 32768 minimum: 301
[    0.025840] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.033094] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.041504] mpic: requesting IPIs...
[    0.045676] e500 family performance monitor hardware support registered
[    0.052305] rcu: Hierarchical SRCU implementation.
[    0.057169] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[    0.064873] smp: Bringing up secondary CPUs ...
[    0.069950] smp: Brought up 1 node, 2 CPUs
[    0.074395] devtmpfs: initialized
[    0.079662] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.089433] futex hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.096986] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.103417] thermal_sys: Registered thermal governor 'step_wise'
[    0.111085] Machine: Turris 1.x
[    0.120139] SoC family: QorIQ
[    0.123093] SoC ID: svr:0x80ea0021, Revision: 2.1
[    0.129156] Found FSL PCI host bridge at 0x00000000ffe08000. Firmware bus number: 0->1
[    0.136993] PCI host bridge /pcie@ffe08000 (primary) ranges:
[    0.142661]  MEM 0x00000000c0000000..0x00000000c01fffff -> 0x00000000c0000000
[    0.149861]   IO 0x00000000ffc20000..0x00000000ffc2ffff -> 0x0000000000000000
[    0.157011] /pcie@ffe08000: PCICSRBAR @ 0xfff00000
[    0.161769] setup_pci_atmu: end of DRAM 80000000
[    0.166748] Found FSL PCI host bridge at 0x00000000ffe09000. Firmware bus number: 0->1
[    0.174595] PCI host bridge /pcie@ffe09000  ranges:
[    0.179460]  MEM 0x00000000a0000000..0x00000000bfffffff -> 0x00000000a0000000
[    0.186690]   IO 0x00000000ffc10000..0x00000000ffc1ffff -> 0x0000000000000000
[    0.193811] /pcie@ffe09000: PCICSRBAR @ 0xfff00000
[    0.198587] setup_pci_atmu: end of DRAM 80000000
[    0.203547] Found FSL PCI host bridge at 0x00000000ffe0a000. Firmware bus number: 0->1
[    0.211393] PCI host bridge /pcie@ffe0a000  ranges:
[    0.216259]  MEM 0x0000000080000000..0x000000009fffffff -> 0x0000000080000000
[    0.223477]   IO 0x00000000ffc00000..0x00000000ffc0ffff -> 0x0000000000000000
[    0.230608] /pcie@ffe0a000: PCICSRBAR @ 0xfff00000
[    0.235385] setup_pci_atmu: end of DRAM 80000000
[    0.241038] software IO TLB: tearing down default memory pool
[    0.253549] PCI: Probing PCI hardware
[    0.257262] fsl-pci ffe08000.pcie: PCI host bridge to bus 0002:00
[    0.263277] pci_bus 0002:00: root bus resource [io  0x0000-0xffff]
[    0.269463] pci_bus 0002:00: root bus resource [mem 0xc0000000-0xc01fffff]
[    0.276317] pci_bus 0002:00: root bus resource [bus 00-ff]
[    0.281801] pci_bus 0002:00: busn_res: [bus 00-ff] end is updated to ff
[    0.288426] pci 0002:00:00.0: [1957:0070] type 01 class 0x060400
[    0.294414] pci 0002:00:00.0: reg 0x10: [mem 0xfff00000-0xffffffff]
[    0.300700] pci 0002:00:00.0: supports D1 D2
[    0.304925] pci 0002:00:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.312599] pci 0002:01:00.0: [104c:8241] type 00 class 0x0c0330
[    0.318552] pci 0002:01:00.0: reg 0x10: [mem 0xc0000000-0xc000ffff 64bit]
[    0.325315] pci 0002:01:00.0: reg 0x18: [mem 0xc0010000-0xc0011fff 64bit]
[    0.332187] pci 0002:01:00.0: supports D1 D2
[    0.336371] pci 0002:01:00.0: PME# supported from D0 D1 D2 D3hot
[    0.342407] pci 0002:01:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0002:00:00.0 (capable of 4.000 Gb/s with 5.0 GT/s PCIe x1 link)
[    0.388090] pci 0002:00:00.0: PCI bridge to [bus 01-ff]
[    0.393235] pci 0002:00:00.0:   bridge window [io  0x0000-0x0fff]
[    0.399332] pci 0002:00:00.0:   bridge window [mem 0xc0000000-0xc00fffff]
[    0.406106] pci_bus 0002:01: busn_res: [bus 01-ff] end is updated to 01
[    0.412717] pci_bus 0002:00: busn_res: [bus 00-ff] end is updated to 01
[    0.419434] fsl-pci ffe09000.pcie: PCI host bridge to bus 0001:02
[    0.425456] pci_bus 0001:02: root bus resource [io  0x20000-0x2ffff] (bus address [0x0000-0xffff])
[    0.434398] pci_bus 0001:02: root bus resource [mem 0xa0000000-0xbfffffff]
[    0.441273] pci_bus 0001:02: root bus resource [bus 02-ff]
[    0.446743] pci_bus 0001:02: busn_res: [bus 02-ff] end is updated to ff
[    0.453373] pci 0001:02:00.0: [1957:0070] type 01 class 0x060400
[    0.459353] pci 0001:02:00.0: reg 0x10: [mem 0xfff00000-0xffffffff]
[    0.465655] pci 0001:02:00.0: supports D1 D2
[    0.469867] pci 0001:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.477413] pci 0001:02:00.0: Primary bus is hard wired to 0
[    0.482989] pci 0001:02:00.0: bridge configuration invalid ([bus 01-01]), reconfiguring
[    0.491080] pci 0001:03:00.0: [168c:0030] type 00 class 0x028000
[    0.497021] pci 0001:03:00.0: reg 0x10: [mem 0xa0000000-0xa001ffff 64bit]
[    0.503826] pci 0001:03:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[    0.510547] pci 0001:03:00.0: supports D1
[    0.514487] pci 0001:03:00.0: PME# supported from D0 D1 D3hot
[    0.545317] pci 0001:02:00.0: PCI bridge to [bus 03-ff]
[    0.550462] pci 0001:02:00.0:   bridge window [io  0x20000-0x20fff]
[    0.556733] pci 0001:02:00.0:   bridge window [mem 0xa0000000-0xa00fffff]
[    0.563507] pci_bus 0001:03: busn_res: [bus 03-ff] end is updated to 03
[    0.570118] pci_bus 0001:02: busn_res: [bus 02-ff] end is updated to 03
[    0.576818] fsl-pci ffe0a000.pcie: PCI host bridge to bus 0000:04
[    0.582840] pci_bus 0000:04: root bus resource [io  0x40000-0x4ffff] (bus address [0x0000-0xffff])
[    0.591782] pci_bus 0000:04: root bus resource [mem 0x80000000-0x9fffffff]
[    0.598658] pci_bus 0000:04: root bus resource [bus 04-ff]
[    0.604127] pci_bus 0000:04: busn_res: [bus 04-ff] end is updated to ff
[    0.610758] pci 0000:04:00.0: [1957:0070] type 01 class 0x060400
[    0.616737] pci 0000:04:00.0: reg 0x10: [mem 0xfff00000-0xffffffff]
[    0.623038] pci 0000:04:00.0: supports D1 D2
[    0.627251] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.634800] pci 0000:04:00.0: Primary bus is hard wired to 0
[    0.640376] pci 0000:04:00.0: bridge configuration invalid ([bus 01-01]), reconfiguring
[    0.648467] pci 0000:05:00.0: [168c:003c] type 00 class 0x028000
[    0.654408] pci 0000:05:00.0: reg 0x10: [mem 0x80000000-0x801fffff 64bit]
[    0.661212] pci 0000:05:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[    0.667933] pci 0000:05:00.0: supports D1 D2
[    0.702970] pci 0000:04:00.0: PCI bridge to [bus 05-ff]
[    0.708115] pci 0000:04:00.0:   bridge window [io  0x40000-0x40fff]
[    0.714386] pci 0000:04:00.0:   bridge window [mem 0x80000000-0x801fffff]
[    0.721160] pci_bus 0000:05: busn_res: [bus 05-ff] end is updated to 05
[    0.727771] pci_bus 0000:04: busn_res: [bus 04-ff] end is updated to 05
[    0.734427] PCI: Cannot allocate resource region 0 of device 0002:00:00.0, will remap
[    0.742204] PCI: Cannot allocate resource region 0 of device 0001:02:00.0, will remap
[    0.750019] PCI: Cannot allocate resource region 0 of device 0000:04:00.0, will remap
[    0.757891] pci 0002:00:00.0: BAR 0: no space for [mem size 0x00100000]
[    0.764446] pci 0002:00:00.0: BAR 0: failed to assign [mem size 0x00100000]
[    0.771412] pci 0002:00:00.0: PCI bridge to [bus 01]
[    0.776357] pci 0002:00:00.0:   bridge window [io  0x0000-0xffff]
[    0.782456] pci 0002:00:00.0:   bridge window [mem 0xc0000000-0xc01fffff]
[    0.789224] pci_bus 0002:00: Some PCI device resources are unassigned, try booting with pci=realloc
[    0.798272] pci_bus 0002:00: resource 4 [io  0x0000-0xffff]
[    0.803827] pci_bus 0002:00: resource 5 [mem 0xc0000000-0xc01fffff]
[    0.810093] pci_bus 0002:01: resource 0 [io  0x0000-0xffff]
[    0.815650] pci_bus 0002:01: resource 1 [mem 0xc0000000-0xc01fffff]
[    0.821920] pci 0001:02:00.0: BAR 0: no space for [mem size 0x00100000]
[    0.828516] pci 0001:02:00.0: BAR 0: failed to assign [mem size 0x00100000]
[    0.835482] pci 0001:03:00.0: BAR 6: assigned [mem 0xa0020000-0xa002ffff pref]
[    0.842687] pci 0001:02:00.0: PCI bridge to [bus 03]
[    0.847650] pci 0001:02:00.0:   bridge window [io  0x20000-0x2ffff]
[    0.853901] pci 0001:02:00.0:   bridge window [mem 0xa0000000-0xbfffffff]
[    0.860695] pci_bus 0001:02: Some PCI device resources are unassigned, try booting with pci=realloc
[    0.869723] pci_bus 0001:02: resource 4 [io  0x20000-0x2ffff]
[    0.875468] pci_bus 0001:02: resource 5 [mem 0xa0000000-0xbfffffff]
[    0.881719] pci_bus 0001:03: resource 0 [io  0x20000-0x2ffff]
[    0.887463] pci_bus 0001:03: resource 1 [mem 0xa0000000-0xbfffffff]
[    0.893720] pci 0000:04:00.0: BAR 0: no space for [mem size 0x00100000]
[    0.900330] pci 0000:04:00.0: BAR 0: failed to assign [mem size 0x00100000]
[    0.907280] pci 0000:05:00.0: BAR 6: assigned [mem 0x80200000-0x8020ffff pref]
[    0.914501] pci 0000:04:00.0: PCI bridge to [bus 05]
[    0.919449] pci 0000:04:00.0:   bridge window [io  0x40000-0x4ffff]
[    0.925716] pci 0000:04:00.0:   bridge window [mem 0x80000000-0x9fffffff]
[    0.932489] pci_bus 0000:04: Some PCI device resources are unassigned, try booting with pci=realloc
[    0.941542] pci_bus 0000:04: resource 4 [io  0x40000-0x4ffff]
[    0.947267] pci_bus 0000:04: resource 5 [mem 0x80000000-0x9fffffff]
[    0.953534] pci_bus 0000:05: resource 0 [io  0x40000-0x4ffff]
[    0.959263] pci_bus 0000:05: resource 1 [mem 0x80000000-0x9fffffff]
[    0.973146] raid6: skip pq benchmark and using algorithm int32x8
[    0.979113] raid6: using intx1 recovery algorithm
[    0.984179] SCSI subsystem initialized
[    0.987963] usbcore: registered new interface driver usbfs
[    0.993410] usbcore: registered new interface driver hub
[    0.998689] usbcore: registered new device driver usb
[    1.003777] EDAC MC: Ver: 3.0.0
[    1.007878] clocksource: Switched to clocksource timebase
[    1.018315] NET: Registered PF_INET protocol family
[    1.023279] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    1.031428] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    1.039727] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    1.047444] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    1.055233] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    1.062398] TCP: Hash tables configured (established 8192 bind 8192)
[    1.068751] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.075311] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.082485] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    1.088126] pci 0002:00:00.0: enabling device (0106 -> 0107)
[    1.093809] PCI: CLS 32 bytes, default 32
[    1.098588] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    1.107922] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.113752] jffs2: version 2.2 (NAND) (SUMMARY) (ZLIB) (LZO) (LZMA) (RTIME) (RUBIN) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    1.125765] xor: measuring software checksum speed
[    1.136758]    8regs           :  1574 MB/sec
[    1.148855]    8regs_prefetch  :  1258 MB/sec
[    1.159381]    32regs          :  1573 MB/sec
[    1.170720]    32regs_prefetch :  1391 MB/sec
[    1.174988] xor: using function: 8regs (1574 MB/sec)
[    1.180017] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    1.188650] pcieport 0002:00:00.0: AER: enabled with IRQ 24
[    1.194305] pcieport 0001:02:00.0: enabling device (0106 -> 0107)
[    1.200777] pcieport 0001:02:00.0: AER: enabled with IRQ 25
[    1.206423] pcieport 0000:04:00.0: enabling device (0106 -> 0107)
[    1.212767] pcieport 0000:04:00.0: AER: enabled with IRQ 26
[    1.218638] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[    1.227707] printk: console [ttyS0] disabled
\CA+HH\90\901.231958] serial8250.0: ttyS0 at MMIO 0xffe04500 (irq = 42, base_baud = 37500000) is a 16550A
[    1.240607] printk: console [ttyS0] enabled
[    1.248932] printk: bootconsole [udbg0] disabled
[    1.258481] serial8250.0: ttyS1 at MMIO 0xffe04600 (irq = 42, base_baud = 37500000) is a 16550A
[    1.267762] printk: console [ttyS0] disabled
[    1.272153] printk: console [ttyS0] enabled
[    1.276779] ffe04600.serial: ttyS1 at MMIO 0xffe04600 (irq = 42, base_baud = 37500000) is a 16550
[    1.286341] Loading iSCSI transport class v2.0-870.
[    1.293567] physmap-flash ef000000.nor: physmap platform flash device: [mem 0xef000000-0xefffffff]
[    1.302751] ef000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000001 Chip ID 0x002101
[    1.312782] Amd/Fujitsu Extended Query Table at 0x0040
[    1.317965]   Amd/Fujitsu Extended Query version 1.3.
[    1.323020] number of CFI chips: 1
[    1.326809] 7 fixed-partitions partitions found on MTD device ef000000.nor
[    1.333713] Creating 7 MTD partitions on "ef000000.nor":
[    1.339039] 0x000000000000-0x000000020000 : "dtb"
[    1.344267] 0x000000020000-0x0000001c0000 : "kernel"
[    1.349675] 0x0000001c0000-0x000000340000 : "rescue"
[    1.355036] 0x000000340000-0x000000e40000 : "factory"
[    1.360545] 0x000000e40000-0x000000f00000 : "certificates"
[    1.366427] 0x000000f20000-0x000000f40000 : "u-boot-env"
[    1.372191] 0x000000f40000-0x000001000000 : "u-boot"
[    1.380124] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
[    1.386495] nand: Micron MT29F2G08ABAEAWP
[    1.390523] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[    1.399269] Bad block table found at page 131008, version 0x01
[    1.406011] Bad block table found at page 130944, version 0x01
[    1.412615] 1 fixed-partitions partitions found on MTD device ff800000.flash
[    1.419690] Creating 1 MTD partitions on "ff800000.flash":
[    1.425180] 0x000000000000-0x000010000000 : "rootfs"
[    1.431347] mtd: setting mtd7 (rootfs) as root device
[    1.436773] mtdsplit: no squashfs found in "rootfs"
[    1.441961] eLBC NAND device at 0xff800000, bank 1
[    1.447399] fsl_espi ffe07000.spi: irq = 59
[    1.458273] fsl-gianfar ffe24000.ethernet: Using random MAC address: a6:02:bc:28:5d:4d
[    1.466537] fsl-gianfar ffe24000.ethernet: enabled errata workarounds, flags: 0x4
[    1.484446] fsl-gianfar ffe24000.ethernet eth0: mac: a6:02:bc:28:5d:4d
[    1.491016] fsl-gianfar ffe24000.ethernet eth0: Running with NAPI enabled
[    1.497811] fsl-gianfar ffe24000.ethernet eth0: RX BD ring size for Q[0]: 256
[    1.504963] fsl-gianfar ffe24000.ethernet eth0: TX BD ring size for Q[0]: 256
[    1.512286] fsl-gianfar ffe25000.ethernet: Using random MAC address: 52:62:e5:fe:38:7f
[    1.520551] fsl-gianfar ffe25000.ethernet: enabled errata workarounds, flags: 0x4
[    1.538445] fsl-gianfar ffe25000.ethernet eth1: mac: 52:62:e5:fe:38:7f
[    1.544990] fsl-gianfar ffe25000.ethernet eth1: Running with NAPI enabled
[    1.551794] fsl-gianfar ffe25000.ethernet eth1: RX BD ring size for Q[0]: 256
[    1.558942] fsl-gianfar ffe25000.ethernet eth1: TX BD ring size for Q[0]: 256
[    1.566260] fsl-gianfar ffe26000.ethernet: Using random MAC address: a6:d7:e7:78:99:c3
[    1.574208] fsl-gianfar ffe26000.ethernet: enabled errata workarounds, flags: 0x4
[    1.592041] fsl-gianfar ffe26000.ethernet eth2: mac: a6:d7:e7:78:99:c3
[    1.598592] fsl-gianfar ffe26000.ethernet eth2: Running with NAPI enabled
[    1.605384] fsl-gianfar ffe26000.ethernet eth2: RX BD ring size for Q[0]: 256
[    1.612530] fsl-gianfar ffe26000.ethernet eth2: TX BD ring size for Q[0]: 256
[    1.619846] ucc_geth_driver: QE UCC Gigabit Ethernet Controller
[    1.625857] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.632472] ehci-pci: EHCI PCI platform driver
[    1.637285] fsl-ehci: Freescale EHCI Host controller driver
[    1.642937] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
[    1.649583] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
[    1.656866] fsl-ehci fsl-ehci.0: irq 28, io mem 0xffe22000
[    1.697877] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
[    1.704001] hub 1-0:1.0: USB hub found
[    1.707794] hub 1-0:1.0: 1 port detected
[    1.712314] usbcore: registered new interface driver uas
[    1.717713] usbcore: registered new interface driver usb-storage
[    1.723956] i2c_dev: i2c /dev entries driver
[    1.728404] mpc-i2c ffe03000.i2c: timeout 1000000 us
[    1.733628] i2c i2c-0: of_i2c: modalias failure on /soc@ffe00000/i2c@3000/power-control@2a
[    1.741939] i2c i2c-0: Failed to create I2C device for /soc@ffe00000/i2c@3000/power-control@2a
[    1.750601] i2c i2c-0: of_i2c: modalias failure on /soc@ffe00000/i2c@3000/eeprom@32
[    1.758281] i2c i2c-0: Failed to create I2C device for /soc@ffe00000/i2c@3000/eeprom@32
[    1.766470] i2c i2c-0: of_i2c: modalias failure on /soc@ffe00000/i2c@3000/eeprom@57
[    1.774155] i2c i2c-0: Failed to create I2C device for /soc@ffe00000/i2c@3000/eeprom@57
[    1.782645] mpc-i2c ffe03100.i2c: timeout 1000000 us
[    1.788145] booke_wdt: powerpc book-e watchdog driver loaded
[    1.794041] Freescale(R) MPC85xx EDAC driver, (C) 2006 Montavista Software
[    1.801168] fsl_mc_err_probe: No ECC DIMMs discovered
[    1.806769] EDAC DEVICE0: Giving out device to module MPC85xx_edac controller mpc85xx_l2_err: DEV mpc85xx_l2_err (INTERRUPT)
[    1.818118] MPC85xx_edac acquired irq 16 for L2 Err
[    1.822997] MPC85xx_edac L2 err registered
[    1.827423] EDAC PCI0: Giving out device to module MPC85xx_edac controller mpc85xx_pci_err: DEV mpc85xx-pci-edac.0.auto (INTERRUPT)
[    1.839300] MPC85xx_edac acquired irq 24 for PCI Err
[    1.844265] MPC85xx_edac PCI err registered
[    1.848523] EDAC PCI1: Giving out device to module MPC85xx_edac controller mpc85xx_pci_err: DEV mpc85xx-pci-edac.1.auto (INTERRUPT)
[    1.860389] MPC85xx_edac acquired irq 25 for PCI Err
[    1.865354] MPC85xx_edac PCI err registered
[    1.869609] EDAC PCI2: Giving out device to module MPC85xx_edac controller mpc85xx_pci_err: DEV mpc85xx-pci-edac.2.auto (INTERRUPT)
[    1.881481] MPC85xx_edac acquired irq 26 for PCI Err
[    1.886446] MPC85xx_edac PCI err registered
[    1.890923] sdhci: Secure Digital Host Controller Interface driver
[    1.897113] sdhci: Copyright(c) Pierre Ossman
[    1.901484] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.907423] sdhci-esdhc ffe2e000.sdhc: Got CD GPIO
[    1.907782] NET: Registered PF_INET6 protocol family
[    1.912316] mmc0 bounce up to 128 segments into one, max segment size 65536 bytes
[    1.918460] Segment Routing with IPv6
[    1.928439] In-situ OAM (IOAM) with IPv6
[    1.932420] NET: Registered PF_PACKET protocol family
[    1.937527] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    1.948031] mmc0: SDHCI controller on ffe2e000.sdhc [ffe2e000.sdhc] using DMA
[    1.950703] 8021q: 802.1Q VLAN Support v1.8
[    1.961948] drmem: No dynamic reconfiguration memory found
[    1.970218] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
[    2.042636] mmc0: new high speed SDHC card at address 59b4
[    2.048298] usb 1-1: new high-speed USB device number 2 using fsl-ehci
[    2.055182] mmcblk0: mmc0:59b4 SD    7.36 GiB
[    2.065812]  mmcblk0: p1 p2
[    2.084071] device eth1 entered promiscuous mode
[    2.088850] device eth0 entered promiscuous mode
[    2.097998] qca8k mdio@ffe24520:10: configuring for fixed/rgmii-id link mode
[    2.110066] qca8k mdio@ffe24520:10: configuring for fixed/rgmii-id link mode
[    2.119819] qca8k mdio@ffe24520:10: Link is Up - 1Gbps/Full - flow control off
[    2.128399] qca8k mdio@ffe24520:10: Link is Up - 1Gbps/Full - flow control off
[    2.201182] qca8k mdio@ffe24520:10 lan5 (uninitialized): PHY [qca8k-0.0:01] driver [Qualcomm Atheros 8337 internal PHY] (irq=POLL)
[    2.291210] qca8k mdio@ffe24520:10 lan4 (uninitialized): PHY [qca8k-0.0:02] driver [Qualcomm Atheros 8337 internal PHY] (irq=POLL)
[    2.298733] hub 1-1:1.0: USB hub found
[    2.306879] hub 1-1:1.0: 2 ports detected
[    2.381192] qca8k mdio@ffe24520:10 lan3 (uninitialized): PHY [qca8k-0.0:03] driver [Qualcomm Atheros 8337 internal PHY] (irq=POLL)
[    2.471185] qca8k mdio@ffe24520:10 lan2 (uninitialized): PHY [qca8k-0.0:04] driver [Qualcomm Atheros 8337 internal PHY] (irq=POLL)
[    2.561184] qca8k mdio@ffe24520:10 lan1 (uninitialized): PHY [qca8k-0.0:05] driver [Qualcomm Atheros 8337 internal PHY] (irq=POLL)
[    2.573450] DSA: tree 0 setup
[    2.583109] BTRFS: device fsid 102f5ee7-4016-4565-9718-be41bd28e459 devid 1 transid 1087963 /dev/root scanned by swapper/0 (1)
[    2.606274] BTRFS info (device mmcblk0p2): using crc32c (crc32c-generic) checksum algorithm
[    2.614729] BTRFS info (device mmcblk0p2): disk space caching is enabled
[    2.621453] BTRFS info (device mmcblk0p2): has skinny extents
[    2.739180] BTRFS info (device mmcblk0p2): enabling ssd optimizations
[    2.801530] VFS: Mounted root (btrfs filesystem) on device 0:14.
[    2.814178] devtmpfs: mounted
[    2.817416] Freeing unused kernel image (initmem) memory: 256K
[    2.823279] This architecture does not have kernel memory protection.
[    2.829744] Run /sbin/init as init process
[    3.123557] init: Console is alive
[    3.127084] init: - watchdog -
[    4.805209] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[    4.829368] pps_core: LinuxPPS API ver. 1 registered
[    4.834349] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    4.844519] PTP clock support registered
[    4.849178] Button Hotplug driver version 0.4.1
[    4.854898] ehci-platform: EHCI generic platform driver
[    4.872739] xhci_hcd 0002:01:00.0: xHCI Host Controller
[    4.878055] xhci_hcd 0002:01:00.0: new USB bus registered, assigned bus number 2
[    4.885611] xhci_hcd 0002:01:00.0: hcc params 0x0270f06d hci version 0x96 quirks 0x0000000004000000
[    4.895073] xhci_hcd 0002:01:00.0: xHCI Host Controller
[    4.900328] xhci_hcd 0002:01:00.0: new USB bus registered, assigned bus number 3
[    4.907734] xhci_hcd 0002:01:00.0: Host supports USB 3.0 SuperSpeed
[    4.914555] hub 2-0:1.0: USB hub found
[    4.918386] hub 2-0:1.0: 4 ports detected
[    4.922824] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.931418] hub 3-0:1.0: USB hub found
[    4.935220] hub 3-0:1.0: 4 ports detected
[    4.944551] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[    4.953068] init: - preinit -
[    5.207915] usb 2-1: new full-speed USB device number 2 using xhci_hcd
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
[    5.411730] random: procd: uninitialized urandom read (4 bytes read)
[    7.333644] mount_root: mounting /dev/root
[    7.827603] urandom-seed: Seeding with /etc/urandom.seed
Scanning for Btrfs filesystems
[    8.644868] mtdblock: MTD device 'rootfs' is NAND, please consider using UBI block devices instead.
reg[    9.241804] BTRFS info: devid 1 device path /dev/root changed to /dev/mmcblk0p2 scanned by btrfs (504)
istered: /dev/mmcblk0p2
[    9.255005] procd: - early -
[    9.257972] procd: - watchdog -
[    9.829153] procd: - watchdog -
[    9.839640] procd: - ubus -
[    9.878036] random: ubusd: uninitialized urandom read (4 bytes read)
[    9.892639] random: ubusd: uninitialized urandom read (4 bytes read)
[    9.899220] random: ubusd: uninitialized urandom read (4 bytes read)
[    9.907067] procd: - init -
Please press Enter to activate this console.
[   11.418183] random: crng init done
[   11.421597] random: 15 urandom warning(s) missed due to ratelimiting
[   15.065516] kmodloader: loading kernel modules from /etc/modules.d/*
[   15.197796] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[   15.237591] pca953x 0-0018: supply vcc not found, using dummy regulator
[   15.244451] pca953x 0-0018: using no AI
[   15.252487] GACT probability on
[   15.257316] Mirror/redirect action on
[   15.266700] u32 classifier
[   15.269489]     input device check on
[   15.273161]     Actions configured
[   15.285476] Bridge firewalling registered
[   15.290706] Loading modules backported from Linux version v5.15.81-0-ge4a7232c917c
[   15.298384] Backport generated by backports.git v5.15.81-1-0-ge1867d55
[   15.314169] lm90 0-004c: supply vcc not found, using dummy regulator
[   15.322122] hwmon hwmon0: temp1_input not attached to any thermal zone
[   15.328728] hwmon hwmon0: temp2_input not attached to any thermal zone
[   15.339758] pps pps0: new PPS source ptp0
[   15.350652] rtc-ds1307 0-006f: registered as rtc0
[   15.356368] rtc-ds1307 0-006f: setting system clock to 2024-02-16T12:23:20 UTC (1708086200)
[   15.366997] usbcore: registered new interface driver ums-alauda
[   15.373397] usbcore: registered new interface driver ums-cypress
[   15.379959] usbcore: registered new interface driver ums-datafab
[   15.386407] usbcore: registered new interface driver ums-freecom
[   15.392931] usbcore: registered new interface driver ums-isd200
[   15.399344] usbcore: registered new interface driver ums-jumpshot
[   15.405865] usbcore: registered new interface driver ums-karma
[   15.412315] usbcore: registered new interface driver ums-sddr09
[   15.418840] usbcore: registered new interface driver ums-sddr55
[   15.425287] usbcore: registered new interface driver ums-usbat
[   15.438148] xt_time: kernel timezone is -0000
[   15.504186] PPP generic driver version 2.4.2
[   15.509225] NET: Registered PF_PPPOX protocol family
[   15.535994] ath10k_pci 0000:05:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[   15.960524] ath10k_pci 0000:05:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
[   15.969838] ath10k_pci 0000:05:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
[   15.979911] ath10k_pci 0000:05:00.0: firmware ver 10.2.4-1.0-00047 api 5 features no-p2p,raw-mode,mfp,allows-mesh-bcast crc32 35bd9258
[   16.110393] ath10k_pci 0000:05:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[   17.250012] ath10k_pci 0000:05:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
[   17.550316] ieee80211 phy1: Atheros AR9300 Rev:3 mem=0xf2c20000, irq=37
[   17.557349] kmodloader: done loading kernel modules from /etc/modules.d/*
[   21.959098] fsl-gianfar ffe25000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
[   21.967411] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[   21.975648] qca8k mdio@ffe24520:10 lan1: configuring for phy/gmii link mode
[   21.986331] br-guest: port 1(lan1.3) entered blocking state
[   21.992010] br-guest: port 1(lan1.3) entered disabled state
[   21.997835] device lan1.3 entered promiscuous mode
[   22.002675] device lan1 entered promiscuous mode
[   22.010510] qca8k mdio@ffe24520:10 lan1: Link is Up - 1Gbps/Full - flow control rx/tx
[   22.023216] IPv6: ADDRCONF(NETDEV_CHANGE): lan1: link becomes ready
[   22.033503] br-lan: port 1(lan1) entered blocking state
[   22.038820] br-lan: port 1(lan1) entered disabled state
[   22.051865] br-guest: port 1(lan1.3) entered blocking state
[   22.057465] br-guest: port 1(lan1.3) entered forwarding state
[   22.070256] br-lan: port 1(lan1) entered blocking state
[   22.075514] br-lan: port 1(lan1) entered forwarding state
[   22.081280] IPv6: ADDRCONF(NETDEV_CHANGE): br-guest: link becomes ready
[   22.100339] qca8k mdio@ffe24520:10 lan2: configuring for phy/gmii link mode
[   22.109801] qca8k mdio@ffe24520:10 lan2: Link is Up - 100Mbps/Full - flow control rx/tx
[   22.125034] br-lan: port 2(lan2) entered blocking state
[   22.130371] br-lan: port 2(lan2) entered disabled state
[   22.136958] device lan2 entered promiscuous mode
[   22.153702] br-lan: port 2(lan2) entered blocking state
[   22.158980] br-lan: port 2(lan2) entered forwarding state
[   22.174584] qca8k mdio@ffe24520:10 lan3: configuring for phy/gmii link mode
[   22.188026] br-lan: port 3(lan3) entered blocking state
[   22.193272] br-lan: port 3(lan3) entered disabled state
[   22.199694] device lan3 entered promiscuous mode
[   22.214135] qca8k mdio@ffe24520:10 lan4: configuring for phy/gmii link mode
[   22.226400] br-lan: port 4(lan4) entered blocking state
[   22.231682] br-lan: port 4(lan4) entered disabled state
[   22.253822] device lan4 entered promiscuous mode
[   22.270575] qca8k mdio@ffe24520:10 lan5: configuring for phy/gmii link mode
[   22.280366] br-lan: port 5(lan5) entered blocking state
[   22.285609] br-lan: port 5(lan5) entered disabled state
[   22.303092] device lan5 entered promiscuous mode
[   23.080020] ath: EEPROM regdomain: 0x80cb
[   23.084042] ath: EEPROM indicates we should expect a country code
[   23.090195] ath: doing EEPROM country->regdmn map search
[   23.095520] ath: country maps to regdmn code: 0x37
[   23.100348] ath: Country alpha2 being used: CZ
[   23.104823] ath: Regpair used: 0x37
[   23.108348] ath: regdomain 0x80cb dynamically updated by user
[   23.114189] ath: EEPROM regdomain: 0x80cb
[   23.118244] ath: EEPROM indicates we should expect a country code
[   23.124361] ath: doing EEPROM country->regdmn map search
[   23.129685] ath: country maps to regdmn code: 0x37
[   23.134494] ath: Country alpha2 being used: CZ
[   23.138970] ath: Regpair used: 0x37
[   23.142460] ath: regdomain 0x80cb dynamically updated by user
[   23.811796] br-lan: port 6(wlan1) entered blocking state
[   23.817160] br-lan: port 6(wlan1) entered disabled state
[   23.822758] device wlan1 entered promiscuous mode
[   23.827564] br-lan: port 6(wlan1) entered blocking state
[   23.832898] br-lan: port 6(wlan1) entered forwarding state
[   23.942117] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[   24.110462] br-guest: port 2(wlan1-1) entered blocking state
[   24.116146] br-guest: port 2(wlan1-1) entered disabled state
[   24.122154] device wlan1-1 entered promiscuous mode
[   24.138252] br-guest: port 2(wlan1-1) entered blocking state
[   24.143942] br-guest: port 2(wlan1-1) entered forwarding state
[   24.155590] br-guest: port 2(wlan1-1) entered disabled state
[   24.308805] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1-1: link becomes ready
[   24.315510] br-guest: port 2(wlan1-1) entered blocking state
[   24.321209] br-guest: port 2(wlan1-1) entered forwarding state
[   26.551304] ath10k_pci 0000:05:00.0: pdev param 0 not supported by firmware
[   26.574813] br-lan: port 7(wlan0) entered blocking state
[   26.580223] br-lan: port 7(wlan0) entered disabled state
[   26.585785] device wlan0 entered promiscuous mode
[   26.590646] br-lan: port 7(wlan0) entered blocking state
[   26.595985] br-lan: port 7(wlan0) entered forwarding state
[   26.606286] br-lan: port 7(wlan0) entered disabled state
Router Turris successfully started.
[   41.591357] BUG: scheduling while atomic: foris-notify/4148/0x00000100
[   41.597912] Modules linked in: ath9k ath9k_common xt_connlimit pppoe ppp_async nf_conncount iptable_nat ath9k_hw ath10k_pci ath10k_core ath xt_state xt_nat xt_helper xt_conntrack xt_connmark xt_connbytes xt_REDIRECT xt_MASQUERADE xt_FLOWOFFLOAD xt_CT pppox ppp_generic nf_nat_ftp nf_nat nf_flow_table nf_conntrack_netlink nf_conntrack_ftp nf_conntrack mt7915e mt76_connac_lib mt76 mac80211 ipt_REJECT ebtable_nat ebtable_filter ebtable_broute cfg80211 xt_time xt_tcpudp xt_tcpmss xt_statistic xt_recent xt_multiport xt_mark xt_mac xt_limit xt_length xt_hl xt_ecn xt_dscp xt_comment xt_TCPMSS xt_LOG xt_HL xt_DSCP xt_CLASSIFY ums_usbat ums_sddr55 ums_sddr09 ums_karma ums_jumpshot ums_isd200 ums_freecom ums_datafab ums_cypress ums_alauda slhc sch_cake rtc_ds1307 ptp_qoriq nf_reject_ipv4 nf_log_syslog nf_defrag_ipv6 nf_defrag_ipv4 lm90 iptable_raw iptable_mangle iptable_filter ipt_ECN ip_tables hwmon ebtables ebt_vlan ebt_stp ebt_redirect ebt_pkttype ebt_mark_m ebt_mark ebt_limit ebt_among
[   41.598256]  ebt_802_3 crc_ccitt compat br_netfilter sch_tbf sch_ingress sch_htb sch_hfsc em_u32 cls_u32 cls_route cls_matchall cls_fw cls_flow cls_basic act_skbedit act_mirred act_gact configs gpio_pca953x regmap_i2c xt_set ip_set_list_set ip_set_hash_netportnet ip_set_hash_netport ip_set_hash_netnet ip_set_hash_netiface ip_set_hash_net ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ipmac ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 ifb sit ip6_tunnel netlink_diag tunnel6 tunnel4 ip_tunnel nls_utf8 sha256_ppc_spe seqiv jitterentropy_rng drbg md5_ppc hmac cmac gpio_keys leds_turris_1x leds_gpio xhci_plat_hcd xhci_pci xhci_hcd ahci libahci libata ehci_platform button_hotplug ptp pps_core
[   41.762205] CPU: 0 PID: 4148 Comm: foris-notify Not tainted 5.15.147 #0
[   41.768837] Call Trace:
[   41.771277] [efff3d90] [c050dab0] dump_stack_lvl+0x4c/0x6c (unreliable)
[   41.777911] [efff3db0] [c0062cf0] __schedule_bug+0x54/0x6c
[   41.783402] [efff3dc0] [c094b67c] __schedule+0x3b4/0x5e4
[   41.788727] [efff3e10] [c094b910] schedule+0x64/0xe0
[   41.793696] [efff3e30] [c094bc54] schedule_preempt_disabled+0x10/0x20
[   41.800144] [efff3e40] [c094d5b4] __mutex_lock.isra.14+0x480/0x49c
[   41.806331] [efff3e90] [f1132664] 0xf1132664
[   41.810606] [efff3ec0] [c070a18c] led_timer_function+0x98/0x1cc
[   41.816533] [efff3ee0] [c00afec4] call_timer_fn.isra.35+0x24/0x84
[   41.822634] [efff3f00] [c00b0220] run_timer_softirq+0x2fc/0x388
[   41.828559] [efff3f90] [c0951df0] __do_softirq+0x150/0x298
[   41.834049] [efff3ff0] [c00053d0] do_softirq_own_stack+0x34/0x4c
[   41.840065] [c8003ed0] [c000a774] timer_interrupt+0x1c8/0x2b0
[   41.845821] [c8003ef0] [c003e7a4] irq_exit+0x88/0xc4
[   41.850798] [c8003f10] [c000138c] Decrementer+0x14c/0x160
[   41.856201] --- interrupt: 900 at 0xb7a5ac90
[   41.860470] NIP:  b7a5ac90 LR: b7a5ab4c CTR: b79e8280
[   41.865519] REGS: c8003f20 TRAP: 0900   Not tainted  (5.15.147)
[   41.871439] MSR:  0202d000 <VEC,CE,EE,PR,ME>  CR: 44002484  XER: 00000000
[   41.878249]
[   41.878249] GPR00: b7a5aa38 bf97ada0 b7d3d18c 00000000 00000009 13efd169 bf97adb8 0126dd88
[   41.878249] GPR08: b7c84460 2f69c95e 2f69c95e bf97ada0 44002888 00000000 00000000 b7d31010
[   41.878249] GPR16: b7c81720 01238514 00b00c18 012f6b08 bf97aef8 0139072c 01399128 01390744
[   41.878249] GPR24: 01399128 13efd169 0129db00 012386a0 012f6b08 00000018 b7c6637c 013993a8
[   41.913220] NIP [b7a5ac90] 0xb7a5ac90
[   41.916880] LR [b7a5ab4c] 0xb7a5ab4c
[   41.920452] --- interrupt: 900
[   41.931684] Oops: Exception in kernel mode, sig: 4 [#1]
[   41.936931] BE PAGE_SIZE=4K SMP NR_CPUS=2 P2020RDB-PC
[   41.941985] Modules linked in: ath9k ath9k_common xt_connlimit pppoe ppp_async nf_conncount iptable_nat ath9k_hw ath10k_pci ath10k_core ath xt_state xt_nat xt_helper xt_conntrack xt_connmark xt_connbytes xt_REDIRECT xt_MASQUERADE xt_FLOWOFFLOAD xt_CT pppox ppp_generic nf_nat_ftp nf_nat nf_flow_table nf_conntrack_netlink nf_conntrack_ftp nf_conntrack mt7915e mt76_connac_lib mt76 mac80211 ipt_REJECT ebtable_nat ebtable_filter ebtable_broute cfg80211 xt_time xt_tcpudp xt_tcpmss xt_statistic xt_recent xt_multiport xt_mark xt_mac xt_limit xt_length xt_hl xt_ecn xt_dscp xt_comment xt_TCPMSS xt_LOG xt_HL xt_DSCP xt_CLASSIFY ums_usbat ums_sddr55 ums_sddr09 ums_karma ums_jumpshot ums_isd200 ums_freecom ums_datafab ums_cypress ums_alauda slhc sch_cake rtc_ds1307 ptp_qoriq nf_reject_ipv4 nf_log_syslog nf_defrag_ipv6 nf_defrag_ipv4 lm90 iptable_raw iptable_mangle iptable_filter ipt_ECN ip_tables hwmon ebtables ebt_vlan ebt_stp ebt_redirect ebt_pkttype ebt_mark_m ebt_mark ebt_limit ebt_among
[   41.942300]  ebt_802_3 crc_ccitt compat br_netfilter sch_tbf sch_ingress sch_htb sch_hfsc em_u32 cls_u32 cls_route cls_matchall cls_fw cls_flow cls_basic act_skbedit act_mirred act_gact configs gpio_pca953x regmap_i2c xt_set ip_set_list_set ip_set_hash_netportnet ip_set_hash_netport ip_set_hash_netnet ip_set_hash_netiface ip_set_hash_net ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ipmac ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 ifb sit ip6_tunnel netlink_diag tunnel6 tunnel4 ip_tunnel nls_utf8 sha256_ppc_spe seqiv jitterentropy_rng drbg md5_ppc hmac cmac gpio_keys leds_turris_1x leds_gpio xhci_plat_hcd xhci_pci xhci_hcd ahci libahci libata ehci_platform button_hotplug ptp pps_core
[   42.106177] CPU: 1 PID: 4148 Comm: foris-notify Tainted: G        W         5.15.147 #0
[   42.114189] NIP:  efff3d80 LR: efff3d80 CTR: c006dcec
[   42.119239] REGS: efff3ce0 TRAP: 0700   Tainted: G        W          (5.15.147)
[   42.126552] MSR:  02021000 <VEC,CE,ME>  CR: c24f72a0  XER: 00000000
[   42.132834]
[   42.132834] GPR00: c24f72a0 efff3dc0 c22e6040 c2478000 efff3d80 c2c39f20 00000000 00000001
[   42.132834] GPR08: 00021000 0000003c 82004424 b73b4030 22004242 c0c2816c efff3e84 efff3e1c
[   42.132834] GPR16: efff3dc0 c00769e4 00000000 c29e2054 efff3d50 000001c6 000001c6 00001c94
[   42.132834] GPR24: efff3d80 eedc9c00 0002c580 c11cbe20 efff3d60 c00de8e8 00000000 c29af0f8
[   42.167804] NIP [efff3d80] 0xefff3d80
[   42.171466] LR [efff3d80] 0xefff3d80
[   42.175039] Call Trace:
[   42.177480] Instruction dump:
[   42.180446] XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX
[   42.188208] XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX
[   42.195972] ---[ end trace 0a70bdfadba7ca55 ]---
[   42.200587]
[   43.202084] Kernel panic - not syncing: Fatal exception
[   43.207313] Rebooting in 3 seconds..
       CCB:600  MHz,
       Watchdog enabled
in: 200
out: 0
io_config: 255
SD/MMC : 4-bit Mode
eSPI : Enabled
ready
SPI:   ready
Flash: 16 MiB
L2:    512 KiB enabled
NAND:  256 MiB
MMC:   FSL_SDHC: 0
PCIe1: Bus 00 - 01
PCIe2: Bus 02 - 03
PCIe3: Bus 04 - 05
In:    serial
Out:   serial
Err:   serial
PHY reset timed out
eTSEC1
, eTSEC2
, eTSEC3 [PRIME]
BOOT NAND
reading zImage
5929661 bytes read in 263 ms (21.5 MiB/s)
wdt status 00000003
reading fdt
Or should I report it to gitlab somewhere?
Contact Turris support via e-mail.
