miska
April 6, 2023, 11:56am
1
Dear Turris users,
We just released a new Turris OS version 6.3.1. It is only a small release fixing the update on some Turris 1.x routers which had the Netmetr option enabled in reForis.
Bug Fixes
Not requesting LibreSpeed on Turris OS 1.x when Netmetr is enabled
We appreciate any feedback about this release.
Great! Have you fixed the issues with IGMP multicast traffic?
peci1
April 6, 2023, 9:36pm
4
I don’t think so, although the kernel was updated.
pete
April 7, 2023, 7:37am
5
I am finding it strange that the kernel was updated. This was not mentioned in the release notes.
Version is the same, only the git hash has changed:
Updated package kernel from version 5.15.96-1-7ae6c583111057ca5817d84a0b8d6809 to version 5.15.96-1-59c7aae3065e1430c1f2c7c63d04911e
Turris Omnia 2020 v6.3.0 → v6.3.1
No problems so far and also rebooted the device after the update was installed.
LXC, WiFi, mSATA mounts, DDNS… everything works just fine so far.
Hi All
Turris Omnia 2020 1go v6.3.0 → v6.3.1
Multi LANs, LXC, Internal Storage, RIPE Atlas, IPV4/IPV6 → Ok All good
Thanks for the updates …
OK2SLC
April 11, 2023, 5:42am
8
MOX - LibreSpeed “Autostart Settings” is working now but Pakon does not generate anything…
Thanks for all the efforts all these years.
system
Closed
April 26, 2023, 11:57am
10
This topic was automatically closed after 20 days. New replies are no longer allowed.
