Dear Turris users,
Turris OS 6.2.1 bugfix release is out, the only significant change being a reForis LAN page issue fix.
Bug Fixes
- Fixed reForis LAN page issue with missing DHCPv6 leases
Known issues
Although the LAN page as a whole should now behave correctly, DHCPv6 lease expiration is incorrectly shown in 1970-01-01 00:00
+ remaining lease time form instead of the correct expiration date and time. We are working on a fix (corresponding GitLab issue).
Your device will be updated automatically unless you have automatic updates disabled or use update approvals. As always, we will appreciate any feedback regarding this release.
