For me this update was a fail. Omnia Indiegogo, 2GB, NAS (1xHDD, 1xSSD), LXC, Transmission, USB hub w/android phone:
The SATA disks did not mount after update. Tried multiple reboots, and also a hard shutdown, unplug and restart (this usually helps), but no bueno this time. Had to roll back to 5.4.3, which works fine.
System log:
Oct 1 22:25:50 turris syslog-ng[7856]: syslog-ng starting up; version=‘3.38.1’
Oct 1 22:25:50 turris kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Oct 1 22:25:50 turris kernel: [ 0.000000] Linux version 4.14.294 (packaging@turris.cz) (gcc version 7.5.0 (OpenWrt GCC 7.5.0 r11431+100-83b0e20711)) #0 SMP Tue Sep 27 09:11:47 2022
Oct 1 22:25:50 turris kernel: [ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d
Oct 1 22:25:50 turris kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Oct 1 22:25:50 turris kernel: [ 0.000000] OF: fdt: Machine model: Turris Omnia
Oct 1 22:25:50 turris kernel: [ 0.000000] Memory policy: Data cache writealloc
Oct 1 22:25:50 turris kernel: [ 0.000000] On node 0 totalpages: 524288
Oct 1 22:25:50 turris kernel: [ 0.000000] free_area_init_node: node 0, pgdat c0b3c840, node_mem_map eedf9000
Oct 1 22:25:50 turris kernel: [ 0.000000] Normal zone: 1728 pages used for memmap
Oct 1 22:25:50 turris kernel: [ 0.000000] Normal zone: 0 pages reserved
Oct 1 22:25:50 turris kernel: [ 0.000000] Normal zone: 196608 pages, LIFO batch:31
Oct 1 22:25:50 turris kernel: [ 0.000000] HighMem zone: 327680 pages, LIFO batch:31
Oct 1 22:25:50 turris kernel: [ 0.000000] percpu: Embedded 11 pages/cpu s15436 r8192 d21428 u45056
Oct 1 22:25:50 turris kernel: [ 0.000000] pcpu-alloc: s15436 r8192 d21428 u45056 alloc=114096
Oct 1 22:25:50 turris kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1
Oct 1 22:25:50 turris kernel: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 522560
Oct 1 22:25:50 turris kernel: [ 0.000000] Kernel command line: earlyprintk console=ttyS0,115200 rootfstype=btrfs rootdelay=2 root=b301 rootflags=subvol=@,commit=5 rw cfg80211.freg=**
Oct 1 22:25:50 turris kernel: [ 0.000000] Bootloader command line not present
Oct 1 22:25:50 turris kernel: [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
Oct 1 22:25:50 turris kernel: [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Oct 1 22:25:50 turris kernel: [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Oct 1 22:25:50 turris kernel: [ 0.000000] Memory: 2066960K/2097152K available (7168K kernel code, 244K rwdata, 1700K rodata, 1024K init, 259K bss, 30192K reserved, 0K cma-reserved, 1310720K highmem)
Oct 1 22:25:50 turris kernel: [ 0.000000] Virtual kernel memory layout:
Oct 1 22:25:50 turris kernel: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Oct 1 22:25:50 turris kernel: [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
Oct 1 22:25:50 turris kernel: [ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
Oct 1 22:25:50 turris kernel: [ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
Oct 1 22:25:50 turris kernel: [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
Oct 1 22:25:50 turris kernel: [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
Oct 1 22:25:50 turris kernel: [ 0.000000] .text : 0xc0008000 - 0xc0800000 (8160 kB)
Oct 1 22:25:50 turris kernel: [ 0.000000] .init : 0xc0a00000 - 0xc0b00000 (1024 kB)
Oct 1 22:25:50 turris kernel: [ 0.000000] .data : 0xc0b00000 - 0xc0b3d140 ( 245 kB)
Oct 1 22:25:50 turris kernel: [ 0.000000] .bss : 0xc0b3d140 - 0xc0b7e110 ( 260 kB)
Oct 1 22:25:50 turris kernel: [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Oct 1 22:25:50 turris kernel: [ 0.000000] Hierarchical RCU implementation.
Oct 1 22:25:50 turris kernel: [ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
Oct 1 22:25:50 turris kernel: [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
Oct 1 22:25:50 turris kernel: [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Oct 1 22:25:50 turris kernel: [ 0.000000] L2C: DT/platform modifies aux control register: 0x06070000 → 0x16070000
Oct 1 22:25:50 turris kernel: [ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
Oct 1 22:25:50 turris kernel: [ 0.000000] L2C-310 full line of zeros enabled for Cortex-A9
Oct 1 22:25:50 turris kernel: [ 0.000000] L2C-310 D prefetch enabled, offset 1 lines
Oct 1 22:25:50 turris kernel: [ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
Oct 1 22:25:50 turris kernel: [ 0.000000] L2C-310 Coherent cache controller enabled, 16 ways, 1024 kB
Oct 1 22:25:50 turris kernel: [ 0.000000] L2C-310 Coherent: CACHE_ID 0x410054c9, AUX_CTRL 0x56070001
Oct 1 22:25:50 turris kernel: [ 0.000006] sched_clock: 64 bits at 800MHz, resolution 1ns, wraps every 4398046511103ns
Oct 1 22:25:50 turris kernel: [ 0.000016] clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0xb881274fa3, max_idle_ns: 440795210636 ns
Oct 1 22:25:50 turris kernel: [ 0.000029] Switching to timer-based delay loop, resolution 1ns
Oct 1 22:25:50 turris kernel: [ 0.000160] Ignoring duplicate/late registration of read_current_timer delay
Oct 1 22:25:50 turris kernel: [ 0.000167] clocksource: armada_370_xp_clocksource: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
Oct 1 22:25:50 turris kernel: [ 0.000353] Console: colour dummy device 80x30
Oct 1 22:25:50 turris kernel: [ 0.000372] Calibrating delay loop (skipped), value calculated using timer frequency… 1600.00 BogoMIPS (lpj=8000000)
Oct 1 22:25:50 turris kernel: [ 0.000379] pid_max: default: 32768 minimum: 301
Oct 1 22:25:50 turris kernel: [ 0.000440] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Oct 1 22:25:50 turris kernel: [ 0.000446] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
Oct 1 22:25:50 turris kernel: [ 0.000731] CPU: Testing write buffer coherency: ok
Oct 1 22:25:50 turris kernel: [ 0.000743] CPU0: Spectre v2: using BPIALL workaround
Oct 1 22:25:50 turris kernel: [ 0.000876] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Oct 1 22:25:50 turris kernel: [ 0.001030] Setting up static identity map for 0x100000 - 0x100060
Oct 1 22:25:50 turris kernel: [ 0.001106] mvebu-soc-id: MVEBU SoC ID=0x6820, Rev=0x4
Oct 1 22:25:50 turris kernel: [ 0.001183] mvebu-pmsu: Initializing Power Management Service Unit
Oct 1 22:25:50 turris kernel: [ 0.001241] Hierarchical SRCU implementation.
Oct 1 22:25:50 turris kernel: [ 0.001394] smp: Bringing up secondary CPUs …
Oct 1 22:25:50 turris kernel: [ 0.001562] Booting CPU 1
Oct 1 22:25:50 turris kernel: [ 0.001719] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Oct 1 22:25:50 turris kernel: [ 0.001722] CPU1: Spectre v2: using BPIALL workaround
Oct 1 22:25:50 turris kernel: [ 0.001778] smp: Brought up 1 node, 2 CPUs
Oct 1 22:25:50 turris kernel: [ 0.001783] SMP: Total of 2 processors activated (3200.00 BogoMIPS).
Oct 1 22:25:50 turris kernel: [ 0.001787] CPU: All CPU(s) started in SVC mode.
Oct 1 22:25:50 turris kernel: [ 0.002335] devtmpfs: initialized
Oct 1 22:25:50 turris kernel: [ 0.003938] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
Oct 1 22:25:50 turris kernel: [ 0.003995] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Oct 1 22:25:50 turris kernel: [ 0.004004] futex hash table entries: 512 (order: 3, 32768 bytes)
Oct 1 22:25:50 turris kernel: [ 0.004055] xor: measuring software checksum speed
Oct 1 22:25:50 turris kernel: [ 0.100067] arm4regs : 2392.000 MB/sec
Oct 1 22:25:50 turris kernel: [ 0.200067] 8regs : 1934.800 MB/sec
Oct 1 22:25:50 turris kernel: [ 0.300066] 32regs : 2050.400 MB/sec
Oct 1 22:25:50 turris kernel: [ 0.400066] neon : 1836.800 MB/sec
Oct 1 22:25:50 turris kernel: [ 0.400070] xor: using function: arm4regs (2392.000 MB/sec)
Oct 1 22:25:50 turris kernel: [ 0.400075] pinctrl core: initialized pinctrl subsystem
Oct 1 22:25:50 turris kernel: [ 0.400594] NET: Registered protocol family 16
Oct 1 22:25:50 turris kernel: [ 0.401096] DMA: preallocated 256 KiB pool for atomic coherent allocations
Oct 1 22:25:50 turris kernel: [ 0.401660] cpuidle: using governor ladder
Oct 1 22:25:50 turris kernel: [ 0.401759] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
Oct 1 22:25:50 turris kernel: [ 0.401763] hw-breakpoint: maximum watchpoint size is 4 bytes.
Oct 1 22:25:50 turris kernel: [ 0.401883] mvebu-pmsu: CPU hotplug support is currently broken on Armada 38x: disabling
Oct 1 22:25:50 turris kernel: [ 0.401890] mvebu-pmsu: CPU idle is currently broken on Armada 38x: disabling
Oct 1 22:25:50 turris kernel: [ 0.570226] raid6: int32x1 gen() 171 MB/s
Oct 1 22:25:50 turris kernel: [ 0.740129] raid6: int32x1 xor() 243 MB/s
Oct 1 22:25:50 turris kernel: [ 0.910095] raid6: int32x2 gen() 255 MB/s
Oct 1 22:25:50 turris kernel: [ 1.080119] raid6: int32x2 xor() 288 MB/s
Oct 1 22:25:50 turris kernel: [ 1.250243] raid6: int32x4 gen() 305 MB/s
Oct 1 22:25:50 turris kernel: [ 1.420127] raid6: int32x4 xor() 263 MB/s
Oct 1 22:25:50 turris kernel: [ 1.590146] raid6: int32x8 gen() 328 MB/s
Oct 1 22:25:50 turris kernel: [ 1.760114] raid6: int32x8 xor() 229 MB/s
Oct 1 22:25:50 turris kernel: [ 1.930069] raid6: neonx1 gen() 1111 MB/s
Oct 1 22:25:50 turris kernel: [ 2.100073] raid6: neonx1 xor() 1057 MB/s
Oct 1 22:25:50 turris kernel: [ 2.270071] raid6: neonx2 gen() 1303 MB/s
Oct 1 22:25:50 turris kernel: [ 2.440073] raid6: neonx2 xor() 1351 MB/s
Oct 1 22:25:50 turris kernel: [ 2.610088] raid6: neonx4 gen() 1070 MB/s
Oct 1 22:25:50 turris kernel: [ 2.780091] raid6: neonx4 xor() 1329 MB/s
Oct 1 22:25:50 turris kernel: [ 2.950071] raid6: neonx8 gen() 1014 MB/s
Oct 1 22:25:50 turris kernel: [ 3.120077] raid6: neonx8 xor() 914 MB/s
Oct 1 22:25:50 turris kernel: [ 3.120081] raid6: using algorithm neonx2 gen() 1303 MB/s
Oct 1 22:25:50 turris kernel: [ 3.120084] raid6: … xor() 1351 MB/s, rmw enabled
Oct 1 22:25:50 turris kernel: [ 3.120087] raid6: using neon recovery algorithm
Oct 1 22:25:50 turris kernel: [ 3.120380] SCSI subsystem initialized
Oct 1 22:25:50 turris kernel: [ 3.120510] libata version 3.00 loaded.
Oct 1 22:25:50 turris kernel: [ 3.120611] usbcore: registered new interface driver usbfs
Oct 1 22:25:50 turris kernel: [ 3.120640] usbcore: registered new interface driver hub
Oct 1 22:25:50 turris kernel: [ 3.120660] usbcore: registered new device driver usb
Oct 1 22:25:50 turris kernel: [ 3.121386] clocksource: Switched to clocksource arm_global_timer
Oct 1 22:25:50 turris kernel: [ 3.125798] NET: Registered protocol family 2
Oct 1 22:25:50 turris kernel: [ 3.125925] IP idents hash table entries: 16384 (order: 5, 131072 bytes)
Oct 1 22:25:50 turris kernel: [ 3.126386] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
Oct 1 22:25:50 turris kernel: [ 3.126424] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
Oct 1 22:25:50 turris kernel: [ 3.126485] TCP: Hash tables configured (established 8192 bind 8192)
Oct 1 22:25:50 turris kernel: [ 3.126537] UDP hash table entries: 512 (order: 2, 16384 bytes)
Oct 1 22:25:50 turris kernel: [ 3.126563] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Oct 1 22:25:50 turris kernel: [ 3.126660] NET: Registered protocol family 1
Oct 1 22:25:50 turris kernel: [ 3.126676] PCI: CLS 0 bytes, default 64
Oct 1 22:25:50 turris kernel: [ 3.126987] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
Oct 1 22:25:50 turris kernel: [ 3.128061] Crashlog allocated RAM at address 0x3f00000
Oct 1 22:25:50 turris kernel: [ 3.128199] workingset: timestamp_bits=14 max_order=19 bucket_order=5
Oct 1 22:25:50 turris kernel: [ 3.130128] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Oct 1 22:25:50 turris kernel: [ 3.130138] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Oct 1 22:25:50 turris kernel: [ 3.132659] bounce: pool size: 64 pages
Oct 1 22:25:50 turris kernel: [ 3.132671] io scheduler noop registered
Oct 1 22:25:50 turris kernel: [ 3.132675] io scheduler deadline registered (default)
Oct 1 22:25:50 turris kernel: [ 3.132757] io scheduler bfq registered
Oct 1 22:25:50 turris kernel: [ 3.133219] armada-38x-pinctrl f1018000.pinctrl: registered pinctrl driver
Oct 1 22:25:50 turris kernel: [ 3.134307] mvebu-pcie soc:pcie: PCI host bridge to bus 0000:00
Oct 1 22:25:50 turris kernel: [ 3.134318] pci_bus 0000:00: root bus resource [io 0x1000-0xfffff]
Oct 1 22:25:50 turris kernel: [ 3.134323] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xe7ffffff]
Oct 1 22:25:50 turris kernel: [ 3.134329] pci_bus 0000:00: root bus resource [bus 00-ff]
Oct 1 22:25:50 turris kernel: [ 3.134346] pci 0000:00:01.0: [11ab:6820] type 01 class 0x060400
Oct 1 22:25:50 turris kernel: [ 3.134435] pci 0000:00:02.0: [11ab:6820] type 01 class 0x060400
Oct 1 22:25:50 turris kernel: [ 3.134505] pci 0000:00:03.0: [11ab:6820] type 01 class 0x060400
Oct 1 22:25:50 turris kernel: [ 3.134581] PCI: bus0: Fast back to back transfers disabled
Oct 1 22:25:50 turris kernel: [ 3.134587] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Oct 1 22:25:50 turris kernel: [ 3.134594] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Oct 1 22:25:50 turris kernel: [ 3.134600] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Oct 1 22:25:50 turris kernel: [ 3.134651] pci 0000:01:00.0: [168c:002e] type 00 class 0x028000
Oct 1 22:25:50 turris kernel: [ 3.134679] pci 0000:01:00.0: reg 0x10: [mem 0xe8000000-0xe800ffff 64bit]
Oct 1 22:25:50 turris kernel: [ 3.134768] pci 0000:01:00.0: supports D1
Oct 1 22:25:50 turris kernel: [ 3.134772] pci 0000:01:00.0: PME# supported from D0 D1 D3hot
Oct 1 22:25:50 turris kernel: [ 3.134829] PCI: bus1: Fast back to back transfers disabled
Oct 1 22:25:50 turris kernel: [ 3.134836] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
Oct 1 22:25:50 turris kernel: [ 3.134886] pci 0000:02:00.0: [168c:003c] type 00 class 0x028000
Oct 1 22:25:50 turris kernel: [ 3.134911] pci 0000:02:00.0: reg 0x10: [mem 0xea000000-0xea1fffff 64bit]
Oct 1 22:25:50 turris kernel: [ 3.134939] pci 0000:02:00.0: reg 0x30: [mem 0xea200000-0xea20ffff pref]
Oct 1 22:25:50 turris kernel: [ 3.135000] pci 0000:02:00.0: supports D1 D2
Oct 1 22:25:50 turris kernel: [ 3.135055] PCI: bus2: Fast back to back transfers disabled
Oct 1 22:25:50 turris kernel: [ 3.135062] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
Oct 1 22:25:50 turris kernel: [ 3.135110] pci 0000:03:00.0: [1b21:0612] type 00 class 0x010601
Oct 1 22:25:50 turris kernel: [ 3.135129] pci 0000:03:00.0: reg 0x10: [io 0xfffffff8-0xffffffff]
Oct 1 22:25:50 turris kernel: [ 3.135136] pci 0000:03:00.0: reg 0x14: [io 0xfffffffc-0xffffffff]
Oct 1 22:25:50 turris kernel: [ 3.135144] pci 0000:03:00.0: reg 0x18: [io 0xfffffff8-0xffffffff]
Oct 1 22:25:50 turris kernel: [ 3.135151] pci 0000:03:00.0: reg 0x1c: [io 0xfffffffc-0xffffffff]
Oct 1 22:25:50 turris kernel: [ 3.135159] pci 0000:03:00.0: reg 0x20: [io 0xffffffe0-0xffffffff]
Oct 1 22:25:50 turris kernel: [ 3.135166] pci 0000:03:00.0: reg 0x24: [mem 0xec000000-0xec0001ff]
Oct 1 22:25:50 turris kernel: [ 3.135174] pci 0000:03:00.0: reg 0x30: [mem 0xec010000-0xec01ffff pref]
Oct 1 22:25:50 turris kernel: [ 3.135270] PCI: bus3: Fast back to back transfers disabled
Oct 1 22:25:50 turris kernel: [ 3.135276] pci_bus 0000:03: busn_res: [bus 03-ff] end is updated to 03
Oct 1 22:25:50 turris kernel: [ 3.135298] pci 0000:00:01.0: BAR 8: assigned [mem 0xe0000000-0xe00fffff]
Oct 1 22:25:50 turris kernel: [ 3.135304] pci 0000:00:02.0: BAR 8: assigned [mem 0xe0200000-0xe04fffff]
Oct 1 22:25:50 turris kernel: [ 3.135309] pci 0000:00:03.0: BAR 8: assigned [mem 0xe0100000-0xe01fffff]
Oct 1 22:25:50 turris kernel: [ 3.135314] pci 0000:00:03.0: BAR 7: assigned [io 0x10000-0x10fff]
Oct 1 22:25:50 turris kernel: [ 3.135321] pci 0000:01:00.0: BAR 0: assigned [mem 0xe0000000-0xe000ffff 64bit]
Oct 1 22:25:50 turris kernel: [ 3.135331] pci 0000:00:01.0: PCI bridge to [bus 01]
Oct 1 22:25:50 turris kernel: [ 3.135338] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xe00fffff]
Oct 1 22:25:50 turris kernel: [ 3.135346] pci 0000:02:00.0: BAR 0: assigned [mem 0xe0200000-0xe03fffff 64bit]
Oct 1 22:25:50 turris kernel: [ 3.135356] pci 0000:02:00.0: BAR 6: assigned [mem 0xe0400000-0xe040ffff pref]
Oct 1 22:25:50 turris kernel: [ 3.135361] pci 0000:00:02.0: PCI bridge to [bus 02]
Oct 1 22:25:50 turris kernel: [ 3.135366] pci 0000:00:02.0: bridge window [mem 0xe0200000-0xe04fffff]
Oct 1 22:25:50 turris kernel: [ 3.135373] pci 0000:03:00.0: BAR 6: assigned [mem 0xe0100000-0xe010ffff pref]
Oct 1 22:25:50 turris kernel: [ 3.135378] pci 0000:03:00.0: BAR 5: assigned [mem 0xe0110000-0xe01101ff]
Oct 1 22:25:50 turris kernel: [ 3.135385] pci 0000:03:00.0: BAR 4: assigned [io 0x10000-0x1001f]
Oct 1 22:25:50 turris kernel: [ 3.135391] pci 0000:03:00.0: BAR 0: assigned [io 0x10020-0x10027]
Oct 1 22:25:50 turris kernel: [ 3.135397] pci 0000:03:00.0: BAR 2: assigned [io 0x10028-0x1002f]
Oct 1 22:25:50 turris kernel: [ 3.135403] pci 0000:03:00.0: BAR 1: assigned [io 0x10030-0x10033]
Oct 1 22:25:50 turris kernel: [ 3.135409] pci 0000:03:00.0: BAR 3: assigned [io 0x10034-0x10037]
Oct 1 22:25:50 turris kernel: [ 3.135415] pci 0000:00:03.0: PCI bridge to [bus 03]
Oct 1 22:25:50 turris kernel: [ 3.135419] pci 0000:00:03.0: bridge window [io 0x10000-0x10fff]
Oct 1 22:25:50 turris kernel: [ 3.135424] pci 0000:00:03.0: bridge window [mem 0xe0100000-0xe01fffff]
Oct 1 22:25:50 turris kernel: [ 3.135656] mv_xor f1060800.xor: Marvell shared XOR driver
Oct 1 22:25:50 turris kernel: [ 3.191930] mv_xor f1060800.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
Oct 1 22:25:50 turris kernel: [ 3.192053] mv_xor f1060900.xor: Marvell shared XOR driver
Oct 1 22:25:50 turris kernel: [ 3.251823] mv_xor f1060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
Oct 1 22:25:50 turris kernel: [ 3.252053] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Oct 1 22:25:50 turris kernel: [ 3.253250] console [ttyS0] disabled
Oct 1 22:25:50 turris kernel: [ 3.273323] f1012000.serial: ttyS0 at MMIO 0xf1012000 (irq = 22, base_baud = 15625000) is a 16550A
Oct 1 22:25:50 turris kernel: [ 4.233795] console [ttyS0] enabled
Oct 1 22:25:50 turris kernel: [ 4.257549] f1012100.serial: ttyS1 at MMIO 0xf1012100 (irq = 23, base_baud = 15625000) is a 16550A
Oct 1 22:25:50 turris kernel: [ 4.268412] loop: module loaded
Oct 1 22:25:50 turris kernel: [ 4.271738] ahci 0000:03:00.0: version 3.0
Oct 1 22:25:50 turris kernel: [ 4.271751] pci 0000:00:03.0: enabling device (0140 → 0143)
Oct 1 22:25:50 turris kernel: [ 4.277511] ahci 0000:03:00.0: SSS flag set, parallel bus scan disabled
Oct 1 22:25:50 turris kernel: [ 4.284180] ahci 0000:03:00.0: AHCI 0001.0200 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
Oct 1 22:25:50 turris kernel: [ 4.292297] ahci 0000:03:00.0: flags: 64bit ncq sntf stag led clo pmp pio slum part ccc sxs
Oct 1 22:25:50 turris kernel: [ 4.301214] scsi host0: ahci
Oct 1 22:25:50 turris kernel: [ 4.304280] scsi host1: ahci
Oct 1 22:25:50 turris kernel: [ 4.307232] ata1: SATA max UDMA/133 abar m512@0xe0110000 port 0xe0110100 irq 52
Oct 1 22:25:50 turris kernel: [ 4.314576] ata2: SATA max UDMA/133 abar m512@0xe0110000 port 0xe0110180 irq 52
Oct 1 22:25:50 turris kernel: [ 4.322223] ahci-mvebu f10a8000.sata: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl platform mode
Oct 1 22:25:50 turris kernel: [ 4.331294] ahci-mvebu f10a8000.sata: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
Oct 1 22:25:50 turris kernel: [ 4.340443] scsi host2: ahci-mvebu
Oct 1 22:25:50 turris kernel: [ 4.344019] scsi host3: ahci-mvebu
Oct 1 22:25:50 turris kernel: [ 4.347496] ata3: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x100 irq 44
Oct 1 22:25:50 turris kernel: [ 4.355452] ata4: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x180 irq 44
Oct 1 22:25:50 turris kernel: [ 4.364180] m25p80 spi0.0: s25fl164k (8192 Kbytes)
Oct 1 22:25:50 turris kernel: [ 4.369056] 2 fixed-partitions partitions found on MTD device spi0.0
Oct 1 22:25:50 turris kernel: [ 4.375438] Creating 2 MTD partitions on “spi0.0”:
Oct 1 22:25:50 turris kernel: [ 4.380240] 0x000000000000-0x000000100000 : “U-Boot”
Oct 1 22:25:50 turris kernel: [ 4.385576] 0x000000100000-0x000000800000 : “Rescue system”
Oct 1 22:25:50 turris kernel: [ 4.392688] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
Oct 1 22:25:50 turris kernel: [ 4.553975] mvneta f1070000.ethernet eth0: Using hardware mac address d8:58:d7:00:5c:e7
Oct 1 22:25:50 turris kernel: [ 4.562737] mvneta f1030000.ethernet eth1: Using hardware mac address d8:58:d7:00:5c:e5
Oct 1 22:25:50 turris kernel: [ 4.571445] mvneta f1034000.ethernet eth2: Using hardware mac address d8:58:d7:00:5c:e6
Oct 1 22:25:50 turris kernel: [ 4.579614] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
Oct 1 22:25:50 turris kernel: [ 4.586167] ehci-pci: EHCI PCI platform driver
Oct 1 22:25:50 turris kernel: [ 4.590651] ehci-platform: EHCI generic platform driver
Oct 1 22:25:50 turris kernel: [ 4.595960] ehci-orion: EHCI orion driver
Oct 1 22:25:50 turris kernel: [ 4.600069] orion-ehci f1058000.usb: EHCI Host Controller
Oct 1 22:25:50 turris kernel: [ 4.605499] orion-ehci f1058000.usb: new USB bus registered, assigned bus number 1
Oct 1 22:25:50 turris kernel: [ 4.613134] orion-ehci f1058000.usb: irq 40, io mem 0xf1058000
Oct 1 22:25:50 turris kernel: [ 4.641392] orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00
Oct 1 22:25:50 turris kernel: [ 4.647613] hub 1-0:1.0: USB hub found
Oct 1 22:25:50 turris kernel: [ 4.651398] hub 1-0:1.0: 1 port detected
Oct 1 22:25:50 turris kernel: [ 4.655680] xhci-hcd f10f0000.usb3: xHCI Host Controller
Oct 1 22:25:50 turris kernel: [ 4.661013] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
Oct 1 22:25:50 turris kernel: [ 4.668585] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
Oct 1 22:25:50 turris kernel: [ 4.677856] xhci-hcd f10f0000.usb3: irq 46, io mem 0xf10f0000
Oct 1 22:25:50 turris kernel: [ 4.683876] hub 2-0:1.0: USB hub found
Oct 1 22:25:50 turris kernel: [ 4.687647] hub 2-0:1.0: 1 port detected
Oct 1 22:25:50 turris kernel: [ 4.691686] xhci-hcd f10f0000.usb3: xHCI Host Controller
Oct 1 22:25:50 turris kernel: [ 4.692523] ata3: SATA link down (SStatus 0 SControl 300)
Oct 1 22:25:50 turris kernel: [ 4.697015] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
Oct 1 22:25:50 turris kernel: [ 4.702460] ata4: SATA link down (SStatus 0 SControl 300)
Oct 1 22:25:50 turris kernel: [ 4.709932] xhci-hcd f10f0000.usb3: Host supports USB 3.0 SuperSpeed
Oct 1 22:25:50 turris kernel: [ 4.721854] usb usb3: We don’t know the algorithms for LPM for this host, disabling LPM.
Oct 1 22:25:50 turris kernel: [ 4.730166] hub 3-0:1.0: USB hub found
Oct 1 22:25:50 turris kernel: [ 4.733951] hub 3-0:1.0: 1 port detected
Oct 1 22:25:50 turris kernel: [ 4.738045] xhci-hcd f10f8000.usb3: xHCI Host Controller
Oct 1 22:25:50 turris kernel: [ 4.743387] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
Oct 1 22:25:50 turris kernel: [ 4.750935] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
Oct 1 22:25:50 turris kernel: [ 4.760201] xhci-hcd f10f8000.usb3: irq 47, io mem 0xf10f8000
Oct 1 22:25:50 turris kernel: [ 4.766186] hub 4-0:1.0: USB hub found
Oct 1 22:25:50 turris kernel: [ 4.769956] hub 4-0:1.0: 1 port detected
Oct 1 22:25:50 turris kernel: [ 4.774002] xhci-hcd f10f8000.usb3: xHCI Host Controller
Oct 1 22:25:50 turris kernel: [ 4.779331] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
Oct 1 22:25:50 turris kernel: [ 4.786847] xhci-hcd f10f8000.usb3: Host supports USB 3.0 SuperSpeed
Oct 1 22:25:50 turris kernel: [ 4.793337] usb usb5: We don’t know the algorithms for LPM for this host, disabling LPM.
Oct 1 22:25:50 turris kernel: [ 4.801668] hub 5-0:1.0: USB hub found
Oct 1 22:25:50 turris kernel: [ 4.805438] hub 5-0:1.0: 1 port detected
Oct 1 22:25:50 turris kernel: [ 4.809567] usbcore: registered new interface driver usb-storage
Oct 1 22:25:50 turris kernel: [ 4.816025] armada38x-rtc f10a3800.rtc: registered as rtc0
Oct 1 22:25:50 turris kernel: [ 4.821668] i2c /dev entries driver
Oct 1 22:25:50 turris kernel: [ 4.835656] (NULL device ): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
Oct 1 22:25:50 turris kernel: [ 4.848271] orion_wdt: Initial timeout 171 sec
Oct 1 22:25:50 turris kernel: [ 4.853010] sdhci: Secure Digital Host Controller Interface driver
Oct 1 22:25:50 turris kernel: [ 4.859204] sdhci: Copyright(c) Pierre Ossman
Oct 1 22:25:50 turris kernel: [ 4.921408] mmc0: SDHCI controller on f10d8000.sdhci [f10d8000.sdhci] using ADMA
Oct 1 22:25:50 turris kernel: [ 4.928909] sdhci-pltfm: SDHCI platform and OF driver helper
Oct 1 22:25:50 turris kernel: [ 4.935528] marvell-cesa f1090000.crypto: CESA device successfully registered
Oct 1 22:25:50 turris kernel: [ 4.943123] NET: Registered protocol family 10
Oct 1 22:25:50 turris kernel: [ 4.949222] Segment Routing with IPv6
Oct 1 22:25:50 turris kernel: [ 4.952939] NET: Registered protocol family 17
Oct 1 22:25:50 turris kernel: [ 4.957414] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Oct 1 22:25:50 turris kernel: [ 4.971496] 8021q: 802.1Q VLAN Support v1.8
Oct 1 22:25:50 turris kernel: [ 4.975756] Registering SWP/SWPB emulation handler
Oct 1 22:25:50 turris kernel: [ 4.981944] Btrfs loaded, crc32c=crc32c-generic
Oct 1 22:25:50 turris kernel: [ 4.987410] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
Oct 1 22:25:50 turris kernel: [ 4.991403] usb 2-1: new high-speed USB device number 2 using xhci-hcd
Oct 1 22:25:50 turris kernel: [ 5.048036] mmc0: new high speed MMC card at address 0001
Oct 1 22:25:50 turris kernel: [ 5.053642] mmcblk0: mmc0:0001 H8G4a� 7.28 GiB
Oct 1 22:25:50 turris kernel: [ 5.058286] mmcblk0boot0: mmc0:0001 H8G4a� partition 1 4.00 MiB
Oct 1 22:25:50 turris kernel: [ 5.064364] mmcblk0boot1: mmc0:0001 H8G4a� partition 2 4.00 MiB
Oct 1 22:25:50 turris kernel: [ 5.070359] mmcblk0rpmb: mmc0:0001 H8G4a� partition 3 4.00 MiB, chardev (250:0)
Oct 1 22:25:50 turris kernel: [ 5.078774] mmcblk0: p1
Oct 1 22:25:50 turris kernel: [ 5.144017] DSA: switch 0 0 parsed
Oct 1 22:25:50 turris kernel: [ 5.147433] DSA: tree 0 parsed
Oct 1 22:25:50 turris kernel: [ 5.183887] hub 2-1:1.0: USB hub found
Oct 1 22:25:50 turris kernel: [ 5.187805] hub 2-1:1.0: 4 ports detected
Oct 1 22:25:50 turris kernel: [ 5.372629] usb 3-1: new SuperSpeed USB device number 2 using xhci-hcd
Oct 1 22:25:50 turris kernel: [ 5.486613] hub 3-1:1.0: USB hub found
Oct 1 22:25:50 turris kernel: [ 5.490574] hub 3-1:1.0: 4 ports detected
Oct 1 22:25:50 turris kernel: [ 5.591386] usb 2-1.1: new high-speed USB device number 3 using xhci-hcd
Oct 1 22:25:50 turris kernel: [ 5.733910] hub 2-1.1:1.0: USB hub found
Oct 1 22:25:50 turris kernel: [ 5.738006] hub 2-1.1:1.0: 4 ports detected
Oct 1 22:25:50 turris kernel: [ 5.861384] usb 2-1.2: new high-speed USB device number 4 using xhci-hcd
Oct 1 22:25:50 turris kernel: [ 5.868414] mv88e6085 f1072004.mdio-mii:10 lan0 (uninitialized): PHY [mv88e6xxx-1:00] driver [Marvell 88E1540]
Oct 1 22:25:50 turris kernel: [ 5.995473] mv88e6085 f1072004.mdio-mii:10 lan1 (uninitialized): PHY [mv88e6xxx-1:01] driver [Marvell 88E1540]
Oct 1 22:25:50 turris kernel: [ 6.137713] mv88e6085 f1072004.mdio-mii:10 lan2 (uninitialized): PHY [mv88e6xxx-1:02] driver [Marvell 88E1540]
Oct 1 22:25:50 turris kernel: [ 6.142568] usb 3-1.1: new SuperSpeed USB device number 3 using xhci-hcd
Oct 1 22:25:50 turris kernel: [ 6.266457] hub 3-1.1:1.0: USB hub found
Oct 1 22:25:50 turris kernel: [ 6.270534] hub 3-1.1:1.0: 4 ports detected
Oct 1 22:25:50 turris kernel: [ 6.287717] mv88e6085 f1072004.mdio-mii:10 lan3 (uninitialized): PHY [mv88e6xxx-1:03] driver [Marvell 88E1540]
Oct 1 22:25:50 turris kernel: [ 6.371385] usb 2-1.1.3: new high-speed USB device number 5 using xhci-hcd
Oct 1 22:25:50 turris kernel: [ 6.426182] mv88e6085 f1072004.mdio-mii:10 lan4 (uninitialized): PHY [mv88e6xxx-1:04] driver [Marvell 88E1540]
Oct 1 22:25:50 turris kernel: [ 6.446094] armada38x-rtc f10a3800.rtc: setting system clock to 2022-10-01 20:21:34 UTC (1664655694)
Oct 1 22:25:50 turris kernel: [ 6.455607] Waiting 2 sec before mounting root device…
Oct 1 22:25:50 turris kernel: [ 6.621385] usb 2-1.3: new high-speed USB device number 6 using xhci-hcd
Oct 1 22:25:50 turris kernel: [ 6.871384] usb 2-1.1.4: new high-speed USB device number 7 using xhci-hcd
Oct 1 22:25:50 turris kernel: [ 7.131383] usb 2-1.4: new high-speed USB device number 8 using xhci-hcd
Oct 1 22:25:50 turris kernel: [ 7.451390] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Oct 1 22:25:50 turris kernel: [ 7.479572] ata1.00: ATA-8: WDC WD1001FALS-00J7B1, 05.00K05, max UDMA/133
Oct 1 22:25:50 turris kernel: [ 7.486386] ata1.00: 1953525168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
Oct 1 22:25:50 turris kernel: [ 7.494968] ata1.00: configured for UDMA/133
Oct 1 22:25:50 turris kernel: [ 7.499435] scsi 0:0:0:0: Direct-Access ATA WDC WD1001FALS-0 0K05 PQ: 0 ANSI: 5
Oct 1 22:25:50 turris kernel: [ 7.507946] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
Oct 1 22:25:50 turris kernel: [ 7.515678] sd 0:0:0:0: [sda] Write Protect is off
Oct 1 22:25:50 turris kernel: [ 7.520481] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Oct 1 22:25:50 turris kernel: [ 7.520523] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
Oct 1 22:25:50 turris kernel: [ 7.567159] sda: sda1
Oct 1 22:25:50 turris kernel: [ 7.569925] sd 0:0:0:0: [sda] Attached SCSI disk
Oct 1 22:25:50 turris kernel: [ 8.011388] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Oct 1 22:25:50 turris kernel: [ 8.018300] ata2.00: ATA-10: ADATA SU800, R0427ANR, max UDMA/133
Oct 1 22:25:50 turris kernel: [ 8.024326] ata2.00: 500118192 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
Oct 1 22:25:50 turris kernel: [ 8.031860] ata2.00: configured for UDMA/133
Oct 1 22:25:50 turris kernel: [ 8.036272] scsi 1:0:0:0: Direct-Access ATA ADATA SU800 7ANR PQ: 0 ANSI: 5
Oct 1 22:25:50 turris kernel: [ 8.044729] sd 1:0:0:0: [sdb] 500118192 512-byte logical blocks: (256 GB/238 GiB)
Oct 1 22:25:50 turris kernel: [ 8.052261] sd 1:0:0:0: [sdb] Write Protect is off
Oct 1 22:25:50 turris kernel: [ 8.057064] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
Oct 1 22:25:50 turris kernel: [ 8.057101] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
Oct 1 22:25:50 turris kernel: [ 39.571391] ata2.00: exception Emask 0x0 SAct 0x4 SErr 0x0 action 0x6 frozen
Oct 1 22:25:50 turris kernel: [ 39.578465] ata2.00: cmd 60/08:10:00:00:00/00:00:00:00:00/40 tag 2 ncq dma 4096 in
Oct 1 22:25:50 turris kernel: [ 39.578465] res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Oct 1 22:25:50 turris kernel: [ 39.593462] ata2: hard resetting link
Oct 1 22:25:50 turris kernel: [ 40.101386] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Oct 1 22:25:50 turris kernel: [ 40.108672] ata2.00: configured for UDMA/133
Oct 1 22:25:50 turris kernel: [ 40.112959] ata2.00: device reported invalid CHS sector 0
Oct 1 22:25:50 turris kernel: [ 40.118375] ata2: EH complete
Oct 1 22:25:50 turris kernel: [ 40.121715] sdb: detected capacity change from 0 to 256060514304
Oct 1 22:25:50 turris kernel: [ 40.121778] sd 1:0:0:0: [sdb] Attached SCSI disk
Oct 1 22:25:50 turris kernel: [ 40.135230] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
Oct 1 22:25:50 turris kernel: [ 40.142482] F2FS-fs (mmcblk0p1): Can’t find valid F2FS filesystem in 1th superblock
Oct 1 22:25:50 turris kernel: [ 40.150333] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
Oct 1 22:25:50 turris kernel: [ 40.157575] F2FS-fs (mmcblk0p1): Can’t find valid F2FS filesystem in 2th superblock
Oct 1 22:25:50 turris kernel: [ 40.165285] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
Oct 1 22:25:50 turris kernel: [ 40.172528] F2FS-fs (mmcblk0p1): Can’t find valid F2FS filesystem in 1th superblock
Oct 1 22:25:50 turris kernel: [ 40.180201] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
Oct 1 22:25:50 turris kernel: [ 40.187442] F2FS-fs (mmcblk0p1): Can’t find valid F2FS filesystem in 2th superblock
Oct 1 22:25:50 turris kernel: [ 40.196064] BTRFS: device fsid dbc782c9-0902-4240-b51a-6f2bc8b7fa69 devid 1 transid 68091 /dev/root
Oct 1 22:25:50 turris kernel: [ 40.205759] BTRFS info (device mmcblk0p1): disk space caching is enabled
Oct 1 22:25:50 turris kernel: [ 40.212488] BTRFS info (device mmcblk0p1): has skinny extents
Oct 1 22:25:50 turris kernel: [ 40.223963] BTRFS info (device mmcblk0p1): enabling ssd optimizations
Oct 1 22:25:50 turris kernel: [ 40.237075] VFS: Mounted root (btrfs filesystem) on device 0:12.
Oct 1 22:25:50 turris kernel: [ 40.243467] devtmpfs: mounted
Oct 1 22:25:50 turris kernel: [ 40.247007] Freeing unused kernel memory: 1024K
Oct 1 22:25:50 turris kernel: 40.330785] init: Console is alive
Oct 1 22:25:50 turris kernel: 40.334274] init: - watchdog -
Oct 1 22:25:50 turris kernel: 40.645166] kmodloader: loading kernel modules from /etc/modules-boot.d/
Oct 1 22:25:50 turris kernel: [ 40.657859] exFAT: Version 1.2.9
Oct 1 22:25:50 turris kernel: [ 40.673477] SGI XFS with ACLs, security attributes, no debug enabled
Oct 1 22:25:50 turris kernel: [ 40.682417] usbcore: registered new interface driver uas
Oct 1 22:25:50 turris kernel: 40.687819] kmodloader: done loading kernel modules from /etc/modules-boot.d/
Oct 1 22:25:50 turris kernel: 40.705246] init: - preinit -
Oct 1 22:25:50 turris kernel: 42.795225] mount_root: mounting /dev/root
Oct 1 22:25:50 turris kernel: [ 42.799857] BTRFS info (device mmcblk0p1): disk space caching is enabled
Oct 1 22:25:50 turris kernel: 42.807440] mount_root: loading kmods from internal overlay
Oct 1 22:25:50 turris kernel: 42.825789] kmodloader: loading kernel modules from //etc/modules-boot.d/*
Oct 1 22:25:50 turris kernel: 42.833772] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
Oct 1 22:25:50 turris kernel: [ 74.131400] ata1.00: exception Emask 0x0 SAct 0x800000 SErr 0x0 action 0x6 frozen
Oct 1 22:25:50 turris kernel: [ 74.138913] ata1.00: cmd 60/08:b8:78:00:00/00:00:00:00:00/40 tag 23 ncq dma 4096 in
Oct 1 22:25:50 turris kernel: [ 74.138913] res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Oct 1 22:25:50 turris kernel: [ 74.153998] ata1: hard resetting link
Oct 1 22:25:50 turris kernel: [ 84.151919] ata1: softreset failed (1st FIS failed)
Oct 1 22:25:50 turris kernel: [ 84.156808] ata1: hard resetting link
Oct 1 22:25:50 turris kernel: [ 94.151923] ata1: softreset failed (1st FIS failed)
Oct 1 22:25:50 turris kernel: [ 94.156811] ata1: hard resetting link
Oct 1 22:25:50 turris kernel: [ 129.151909] ata1: softreset failed (1st FIS failed)
Oct 1 22:25:50 turris kernel: [ 129.156802] ata1: limiting SATA link speed to 1.5 Gbps
Oct 1 22:25:50 turris kernel: [ 129.161955] ata1: hard resetting link
Oct 1 22:25:50 turris kernel: [ 134.161382] ata1: softreset failed (1st FIS failed)
Oct 1 22:25:50 turris kernel: [ 134.166271] ata1: reset failed, giving up
Oct 1 22:25:50 turris kernel: [ 134.170289] ata1.00: disabled
Oct 1 22:25:50 turris kernel: [ 134.173275] ata1: EH complete
Oct 1 22:25:50 turris kernel: [ 134.176267] sd 0:0:0:0: [sda] tag#24 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 134.184560] sd 0:0:0:0: [sda] tag#24 CDB: opcode=0x28 28 00 00 00 00 78 00 00 08 00
Oct 1 22:25:50 turris kernel: [ 134.192237] print_req_error: I/O error, dev sda, sector 120
Oct 1 22:25:50 turris kernel: [ 134.197865] sd 0:0:0:0: [sda] tag#25 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 134.206156] sd 0:0:0:0: [sda] tag#25 CDB: opcode=0x28 28 00 00 00 00 78 00 00 08 00
Oct 1 22:25:50 turris kernel: [ 134.213834] print_req_error: I/O error, dev sda, sector 120
Oct 1 22:25:50 turris kernel: [ 134.219418] Buffer I/O error on dev sda, logical block 15, async page read
Oct 1 22:25:50 turris kernel: [ 134.226502] sd 0:0:0:0: [sda] tag#26 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 134.234796] sd 0:0:0:0: [sda] tag#26 CDB: opcode=0x28 28 00 74 70 6d 00 00 00 08 00
Oct 1 22:25:50 turris kernel: [ 134.242474] print_req_error: I/O error, dev sda, sector 1953524992
Oct 1 22:25:50 turris kernel: [ 134.248696] sd 0:0:0:0: [sda] tag#27 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 134.256987] sd 0:0:0:0: [sda] tag#27 CDB: opcode=0x28 28 00 74 70 6d 00 00 00 08 00
Oct 1 22:25:50 turris kernel: [ 134.264663] print_req_error: I/O error, dev sda, sector 1953524992
Oct 1 22:25:50 turris kernel: [ 134.270856] Buffer I/O error on dev sda, logical block 244190624, async page read
Oct 1 22:25:50 turris kernel: [ 134.278443] sd 0:0:0:0: [sda] tag#28 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 134.286736] sd 0:0:0:0: [sda] tag#28 CDB: opcode=0x28 28 00 00 00 08 00 00 00 20 00
Oct 1 22:25:50 turris kernel: [ 134.294412] print_req_error: I/O error, dev sda, sector 2048
Oct 1 22:25:50 turris kernel: [ 134.300149] sd 0:0:0:0: [sda] tag#29 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 134.308441] sd 0:0:0:0: [sda] tag#29 CDB: opcode=0x28 28 00 00 00 08 00 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 134.316118] print_req_error: I/O error, dev sda, sector 2048
Oct 1 22:25:50 turris kernel: [ 134.321792] Buffer I/O error on dev sda1, logical block 0, async page read
Oct 1 22:25:50 turris kernel: [ 134.328688] sd 0:0:0:0: [sda] tag#30 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 134.336978] sd 0:0:0:0: [sda] tag#30 CDB: opcode=0x28 28 00 00 00 08 01 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 134.344653] print_req_error: I/O error, dev sda, sector 2049
Oct 1 22:25:50 turris kernel: [ 134.350323] Buffer I/O error on dev sda1, logical block 1, async page read
Oct 1 22:25:50 turris kernel: [ 134.357226] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 134.365426] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 00 08 02 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 134.373016] print_req_error: I/O error, dev sda, sector 2050
Oct 1 22:25:50 turris kernel: [ 134.378687] Buffer I/O error on dev sda1, logical block 2, async page read
Oct 1 22:25:50 turris kernel: [ 134.385586] sd 0:0:0:0: [sda] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 134.393787] sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 00 00 08 03 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 134.401376] print_req_error: I/O error, dev sda, sector 2051
Oct 1 22:25:50 turris kernel: [ 134.407047] Buffer I/O error on dev sda1, logical block 3, async page read
Oct 1 22:25:50 turris kernel: [ 134.413946] sd 0:0:0:0: [sda] tag#2 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 134.422147] sd 0:0:0:0: [sda] tag#2 CDB: opcode=0x28 28 00 00 00 08 04 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 134.429733] print_req_error: I/O error, dev sda, sector 2052
Oct 1 22:25:50 turris kernel: [ 134.435408] Buffer I/O error on dev sda1, logical block 4, async page read
Oct 1 22:25:50 turris kernel: [ 134.442304] Buffer I/O error on dev sda1, logical block 5, async page read
Oct 1 22:25:50 turris kernel: [ 134.449197] Buffer I/O error on dev sda1, logical block 6, async page read
Oct 1 22:25:50 turris kernel: [ 134.456093] Buffer I/O error on dev sda1, logical block 7, async page read
Oct 1 22:25:50 turris kernel: [ 165.651391] ata2.00: exception Emask 0x0 SAct 0x40 SErr 0x2000000 action 0x6 frozen
Oct 1 22:25:50 turris kernel: [ 165.659073] ata2.00: cmd 60/20:30:00:00:00/00:00:00:00:00/40 tag 6 ncq dma 16384 in
Oct 1 22:25:50 turris kernel: [ 165.659073] res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Oct 1 22:25:50 turris kernel: [ 165.674155] ata2: hard resetting link
Oct 1 22:25:50 turris kernel: [ 175.671919] ata2: softreset failed (1st FIS failed)
Oct 1 22:25:50 turris kernel: [ 175.676807] ata2: hard resetting link
Oct 1 22:25:50 turris kernel: [ 185.671918] ata2: softreset failed (1st FIS failed)
Oct 1 22:25:50 turris kernel: [ 185.676806] ata2: hard resetting link
Oct 1 22:25:50 turris kernel: [ 220.671386] ata2: softreset failed (1st FIS failed)
Oct 1 22:25:50 turris kernel: [ 220.676279] ata2: limiting SATA link speed to 3.0 Gbps
Oct 1 22:25:50 turris kernel: [ 220.681433] ata2: hard resetting link
Oct 1 22:25:50 turris kernel: [ 225.681919] ata2: softreset failed (1st FIS failed)
Oct 1 22:25:50 turris kernel: [ 225.686808] ata2: reset failed, giving up
Oct 1 22:25:50 turris kernel: [ 225.690825] ata2.00: disabled
Oct 1 22:25:50 turris kernel: [ 225.693809] ata2: EH complete
Oct 1 22:25:50 turris kernel: [ 225.696791] scsi_io_completion: 12 callbacks suppressed
Oct 1 22:25:50 turris kernel: [ 225.696798] sd 1:0:0:0: [sdb] tag#7 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 225.710236] sd 1:0:0:0: [sdb] tag#7 CDB: opcode=0x28 28 00 00 00 00 00 00 00 20 00
Oct 1 22:25:50 turris kernel: [ 225.717825] print_req_error: 12 callbacks suppressed
Oct 1 22:25:50 turris kernel: [ 225.717827] print_req_error: I/O error, dev sdb, sector 0
Oct 1 22:25:50 turris kernel: [ 225.728240] sd 1:0:0:0: [sdb] tag#8 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 225.736444] sd 1:0:0:0: [sdb] tag#8 CDB: opcode=0x28 28 00 00 00 00 00 00 00 08 00
Oct 1 22:25:50 turris kernel: [ 225.744034] print_req_error: I/O error, dev sdb, sector 0
Oct 1 22:25:50 turris kernel: [ 225.749443] buffer_io_error: 8 callbacks suppressed
Oct 1 22:25:50 turris kernel: [ 225.749445] Buffer I/O error on dev sdb, logical block 0, async page read
Oct 1 22:25:50 turris kernel: [ 225.761309] sd 1:0:0:0: [sdb] tag#9 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 225.769516] sd 1:0:0:0: [sdb] tag#9 CDB: opcode=0x28 28 00 1d cf 32 00 00 00 08 00
Oct 1 22:25:50 turris kernel: [ 225.777108] print_req_error: I/O error, dev sdb, sector 500118016
Oct 1 22:25:50 turris kernel: [ 225.783247] sd 1:0:0:0: [sdb] tag#10 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 225.791537] sd 1:0:0:0: [sdb] tag#10 CDB: opcode=0x28 28 00 1d cf 32 00 00 00 08 00
Oct 1 22:25:50 turris kernel: [ 225.799210] print_req_error: I/O error, dev sdb, sector 500118016
Oct 1 22:25:50 turris kernel: [ 225.805321] Buffer I/O error on dev sdb, logical block 62514752, async page read
Oct 1 22:25:50 turris kernel: 225.813715] block: attempting to load /etc/config/fstab
Oct 1 22:25:50 turris kernel: 225.820657] block: extroot: not configured
Oct 1 22:25:50 turris kernel: [ 225.836924] random: procd: uninitialized urandom read (4 bytes read)
Oct 1 22:25:50 turris kernel: 226.028967] urandom-seed: Seeding with /etc/urandom.seed
Oct 1 22:25:50 turris kernel: [ 226.362093] sd 0:0:0:0: [sda] tag#18 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 226.370384] sd 0:0:0:0: [sda] tag#18 CDB: opcode=0x28 28 00 74 70 6d 00 00 00 08 00
Oct 1 22:25:50 turris kernel: [ 226.378070] print_req_error: I/O error, dev sda, sector 1953524992
Oct 1 22:25:50 turris kernel: [ 226.384337] sd 0:0:0:0: [sda] tag#19 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 226.392630] sd 0:0:0:0: [sda] tag#19 CDB: opcode=0x28 28 00 74 70 6d 00 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 226.400303] print_req_error: I/O error, dev sda, sector 1953524992
Oct 1 22:25:50 turris kernel: [ 226.406501] Buffer I/O error on dev sda1, logical block 1953522944, async page read
Oct 1 22:25:50 turris kernel: [ 226.414185] sd 0:0:0:0: [sda] tag#20 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 226.422473] sd 0:0:0:0: [sda] tag#20 CDB: opcode=0x28 28 00 74 70 6d 01 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 226.430145] print_req_error: I/O error, dev sda, sector 1953524993
Oct 1 22:25:50 turris kernel: [ 226.436342] Buffer I/O error on dev sda1, logical block 1953522945, async page read
Oct 1 22:25:50 turris kernel: [ 226.444025] sd 0:0:0:0: [sda] tag#21 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 226.452314] sd 0:0:0:0: [sda] tag#21 CDB: opcode=0x28 28 00 74 70 6d 02 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 226.459986] print_req_error: I/O error, dev sda, sector 1953524994
Oct 1 22:25:50 turris kernel: [ 226.466183] Buffer I/O error on dev sda1, logical block 1953522946, async page read
Oct 1 22:25:50 turris kernel: [ 226.473864] sd 0:0:0:0: [sda] tag#22 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 226.482153] sd 0:0:0:0: [sda] tag#22 CDB: opcode=0x28 28 00 74 70 6d 03 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 226.489825] print_req_error: I/O error, dev sda, sector 1953524995
Oct 1 22:25:50 turris kernel: [ 226.496023] Buffer I/O error on dev sda1, logical block 1953522947, async page read
Oct 1 22:25:50 turris kernel: [ 226.503705] sd 0:0:0:0: [sda] tag#23 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 226.511993] sd 0:0:0:0: [sda] tag#23 CDB: opcode=0x28 28 00 74 70 6d 04 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 226.519665] print_req_error: I/O error, dev sda, sector 1953524996
Oct 1 22:25:50 turris kernel: [ 226.525861] Buffer I/O error on dev sda1, logical block 1953522948, async page read
Oct 1 22:25:50 turris kernel: [ 226.533541] Buffer I/O error on dev sda1, logical block 1953522949, async page read
Oct 1 22:25:50 turris kernel: [ 226.541217] Buffer I/O error on dev sda1, logical block 1953522950, async page read
Oct 1 22:25:50 turris kernel: [ 226.548897] Buffer I/O error on dev sda1, logical block 1953522951, async page read
Oct 1 22:25:50 turris kernel: 226.559507] procd: - early -
Oct 1 22:25:50 turris kernel: 226.562627] procd: - watchdog -
Oct 1 22:25:50 turris kernel: [ 226.716162] random: jshn: uninitialized urandom read (4 bytes read)
Oct 1 22:25:50 turris kernel: [ 226.764083] random: jshn: uninitialized urandom read (4 bytes read)
Oct 1 22:25:50 turris kernel: [ 226.851939] random: jshn: uninitialized urandom read (4 bytes read)
Oct 1 22:25:50 turris kernel: [ 226.899052] random: jshn: uninitialized urandom read (4 bytes read)
Oct 1 22:25:50 turris kernel: [ 226.946308] random: jshn: uninitialized urandom read (4 bytes read)
Oct 1 22:25:50 turris kernel: 227.197993] procd: - watchdog -
Oct 1 22:25:50 turris kernel: 227.201234] procd: - ubus -
Oct 1 22:25:50 turris kernel: 227.255472] procd: - init -
Oct 1 22:25:50 turris kernel: 227.574549] kmodloader: loading kernel modules from /etc/modules.d/*
Oct 1 22:25:50 turris kernel: [ 227.620552] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-devel@redhat.com
Oct 1 22:25:50 turris kernel: [ 227.632969] Key type dns_resolver registered
Oct 1 22:25:50 turris kernel: [ 227.645947] Key type cifs.idmap registered
Oct 1 22:25:50 turris kernel: [ 227.661091] RPC: Registered named UNIX socket transport module.
Oct 1 22:25:50 turris kernel: [ 227.667057] RPC: Registered udp transport module.
Oct 1 22:25:50 turris kernel: [ 227.671777] RPC: Registered tcp transport module.
Oct 1 22:25:50 turris kernel: [ 227.676491] RPC: Registered tcp NFSv4.1 backchannel transport module.
Oct 1 22:25:50 turris kernel: [ 227.687261] ntfs: driver 2.1.32 [Flags: R/O MODULE].
Oct 1 22:25:50 turris kernel: [ 227.693897] tun: Universal TUN/TAP device driver, 1.6
Oct 1 22:25:50 turris kernel: [ 227.706938] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
Oct 1 22:25:50 turris kernel: [ 227.733186] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
Oct 1 22:25:50 turris kernel: [ 227.744746] NFS: Registering the id_resolver key type
Oct 1 22:25:50 turris kernel: [ 227.749840] Key type id_resolver registered
Oct 1 22:25:50 turris kernel: [ 227.754065] Key type id_legacy registered
Oct 1 22:25:50 turris kernel: [ 227.766280] ip6_tables: (C) 2000-2006 Netfilter Core Team
Oct 1 22:25:50 turris kernel: [ 227.777849] Netfilter messages via NETLINK v0.30.
Oct 1 22:25:50 turris kernel: [ 227.788279] ip_set: protocol 6
Oct 1 22:25:50 turris kernel: [ 227.819718] i2c i2c-0: Added multiplexed i2c bus 1
Oct 1 22:25:50 turris kernel: [ 227.824910] i2c i2c-0: Added multiplexed i2c bus 2
Oct 1 22:25:50 turris kernel: [ 227.830466] i2c i2c-0: Added multiplexed i2c bus 3
Oct 1 22:25:50 turris kernel: [ 227.837205] i2c i2c-0: Added multiplexed i2c bus 4
Oct 1 22:25:50 turris kernel: [ 227.844334] i2c i2c-0: Added multiplexed i2c bus 5
Oct 1 22:25:50 turris kernel: [ 227.849560] i2c i2c-0: Added multiplexed i2c bus 6
Oct 1 22:25:50 turris kernel: [ 227.854848] i2c i2c-0: Added multiplexed i2c bus 7
Oct 1 22:25:50 turris kernel: [ 227.861706] pca953x 8-0071: 8-0071 supply vcc not found, using dummy regulator
Oct 1 22:25:50 turris kernel: [ 227.871210] i2c i2c-0: Added multiplexed i2c bus 8
Oct 1 22:25:50 turris kernel: [ 227.876050] pca954x 0-0070: registered 8 multiplexed busses for I2C mux pca9547
Oct 1 22:25:50 turris kernel: [ 227.885508] Mirror/redirect action on
Oct 1 22:25:50 turris kernel: [ 227.893663] u32 classifier
Oct 1 22:25:50 turris kernel: [ 227.896381] input device check on
Oct 1 22:25:50 turris kernel: [ 227.900058] Actions configured
Oct 1 22:25:50 turris kernel: [ 227.906998] sch_cake: Unknown symbol nf_conntrack_find_get (err 0)
Oct 1 22:25:50 turris kernel: [ 227.912361] random: crng init done
Oct 1 22:25:50 turris kernel: [ 227.913319] sch_cake: Unknown symbol nf_ct_get_tuplepr (err 0)
Oct 1 22:25:50 turris kernel: [ 227.916611] random: 24 urandom warning(s) missed due to ratelimiting
Oct 1 22:25:50 turris kernel: [ 227.943980] fuse init (API version 7.26)
Oct 1 22:25:50 turris kernel: [ 227.954202] Bridge firewalling registered
Oct 1 22:25:50 turris kernel: [ 227.959198] Loading modules backported from Linux version v4.19.237-0-ga6e4a1818efa
Oct 1 22:25:50 turris kernel: [ 227.966908] Backport generated by backports.git v4.19.237-1-0-gffb89fd9
Oct 1 22:25:50 turris kernel: [ 227.978837] Ebtables v2.0 registered
Oct 1 22:25:50 turris kernel: [ 227.983782] ip_tables: (C) 2000-2006 Netfilter Core Team
Oct 1 22:25:50 turris kernel: [ 227.996737] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
Oct 1 22:25:50 turris kernel: [ 228.006651] ctnetlink v0.93: registering with nfnetlink.
Oct 1 22:25:50 turris kernel: [ 228.037018] usbcore: registered new interface driver ums-alauda
Oct 1 22:25:50 turris kernel: [ 228.043889] usbcore: registered new interface driver ums-cypress
Oct 1 22:25:50 turris kernel: [ 228.050462] usbcore: registered new interface driver ums-datafab
Oct 1 22:25:50 turris kernel: [ 228.057264] usbcore: registered new interface driver ums-freecom
Oct 1 22:25:50 turris kernel: [ 228.064026] usbcore: registered new interface driver ums-isd200
Oct 1 22:25:50 turris kernel: [ 228.070604] usbcore: registered new interface driver ums-jumpshot
Oct 1 22:25:50 turris kernel: [ 228.077445] usbcore: registered new interface driver ums-karma
Oct 1 22:25:50 turris kernel: [ 228.084033] usbcore: registered new interface driver ums-sddr09
Oct 1 22:25:50 turris kernel: [ 228.090627] usbcore: registered new interface driver ums-sddr55
Oct 1 22:25:50 turris kernel: [ 228.097309] usbcore: registered new interface driver ums-usbat
Oct 1 22:25:50 turris kernel: [ 228.104067] usbcore: registered new interface driver usblp
Oct 1 22:25:50 turris kernel: [ 228.111370] usbcore: registered new interface driver usbserial
Oct 1 22:25:50 turris kernel: [ 228.117338] usbcore: registered new interface driver usbserial_generic
Oct 1 22:25:50 turris kernel: [ 228.123964] usbserial: USB Serial support registered for generic
Oct 1 22:25:50 turris kernel: [ 228.146202] xt_time: kernel timezone is -0000
Oct 1 22:25:50 turris kernel: [ 228.152332] at24 1-0054: 8192 byte 24c64 EEPROM, writable, 1 bytes/write
Oct 1 22:25:50 turris kernel: [ 228.195926] PPP generic driver version 2.4.2
Oct 1 22:25:50 turris kernel: [ 228.201131] NET: Registered protocol family 24
Oct 1 22:25:50 turris kernel: [ 228.223036] ath10k 4.19 driver, optimized for CT firmware, probing pci device: 0x3c.
Oct 1 22:25:50 turris kernel: [ 228.233023] pci 0000:00:02.0: enabling device (0140 → 0142)
Oct 1 22:25:50 turris kernel: [ 228.241024] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
Oct 1 22:25:50 turris kernel: [ 228.474516] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/fwcfg-pci-0000:02:00.0.txt failed with error -2
Oct 1 22:25:50 turris kernel: [ 228.485092] ath10k_pci 0000:02:00.0: Falling back to user helper
Oct 1 22:25:50 turris kernel: [ 228.742420] firmware ath10k!fwcfg-pci-0000:02:00.0.txt: firmware_loading_store: map pages failed
Oct 1 22:25:50 turris kernel: [ 228.751351] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:02:00.0.bin failed with error -2
Oct 1 22:25:50 turris kernel: [ 228.762090] ath10k_pci 0000:02:00.0: Falling back to user helper
Oct 1 22:25:50 turris kernel: [ 228.772796] firmware ath10k!pre-cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
Oct 1 22:25:50 turris kernel: [ 228.781894] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/cal-pci-0000:02:00.0.bin failed with error -2
Oct 1 22:25:50 turris kernel: [ 228.792313] ath10k_pci 0000:02:00.0: Falling back to user helper
Oct 1 22:25:50 turris kernel: [ 228.802990] firmware ath10k!cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
Oct 1 22:25:50 turris kernel: [ 228.811813] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/ct-firmware-5.bin failed with error -2
Oct 1 22:25:50 turris kernel: [ 228.822810] ath10k_pci 0000:02:00.0: Falling back to user helper
Oct 1 22:25:50 turris kernel: [ 228.833430] firmware ath10k!QCA988X!hw2.0!ct-firmware-5.bin: firmware_loading_store: map pages failed
Oct 1 22:25:50 turris kernel: [ 228.842789] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/ct-firmware-2.bin failed with error -2
Oct 1 22:25:50 turris kernel: [ 228.853794] ath10k_pci 0000:02:00.0: Falling back to user helper
Oct 1 22:25:50 turris kernel: [ 228.864390] firmware ath10k!QCA988X!hw2.0!ct-firmware-2.bin: firmware_loading_store: map pages failed
Oct 1 22:25:50 turris kernel: [ 228.873746] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/firmware-6.bin failed with error -2
Oct 1 22:25:50 turris kernel: [ 228.884483] ath10k_pci 0000:02:00.0: Falling back to user helper
Oct 1 22:25:50 turris kernel: [ 228.895013] firmware ath10k!QCA988X!hw2.0!firmware-6.bin: firmware_loading_store: map pages failed
Oct 1 22:25:50 turris kernel: [ 228.904119] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/firmware-5.bin failed with error -2
Oct 1 22:25:50 turris kernel: [ 228.914853] ath10k_pci 0000:02:00.0: Falling back to user helper
Oct 1 22:25:50 turris kernel: [ 228.925530] firmware ath10k!QCA988X!hw2.0!firmware-5.bin: firmware_loading_store: map pages failed
Oct 1 22:25:50 turris kernel: [ 228.934628] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/firmware-4.bin failed with error -2
Oct 1 22:25:50 turris kernel: [ 228.945372] ath10k_pci 0000:02:00.0: Falling back to user helper
Oct 1 22:25:50 turris kernel: [ 228.956152] firmware ath10k!QCA988X!hw2.0!firmware-4.bin: firmware_loading_store: map pages failed
Oct 1 22:25:50 turris kernel: [ 228.965242] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/firmware-3.bin failed with error -2
Oct 1 22:25:50 turris kernel: [ 228.975985] ath10k_pci 0000:02:00.0: Falling back to user helper
Oct 1 22:25:50 turris kernel: [ 228.986524] firmware ath10k!QCA988X!hw2.0!firmware-3.bin: firmware_loading_store: map pages failed
Oct 1 22:25:50 turris kernel: [ 229.003527] ath10k_pci 0000:02:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
Oct 1 22:25:50 turris kernel: [ 229.012793] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
Oct 1 22:25:50 turris kernel: [ 229.022150] ath10k_pci 0000:02:00.0: firmware ver 10.1-ct-8x-__fW-022-538f0906 api 2 features wmi-10.x,has-wmi-mgmt-tx,mfp,txstatus-noack,wmi-10.x-CT,ratemask-CT,txrate-CT,get-temp-CT,tx-rc-CT,cust-stats-CT,retry-gt2-CT,txrate2-CT,beacon-cb-CT,wmi-block-ack-CT crc32 e1c91a74
Oct 1 22:25:50 turris kernel: [ 229.074180] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
Oct 1 22:25:50 turris kernel: [ 229.084649] ath10k_pci 0000:02:00.0: Falling back to user helper
Oct 1 22:25:50 turris kernel: [ 229.095443] firmware ath10k!QCA988X!hw2.0!board-2.bin: firmware_loading_store: map pages failed
Oct 1 22:25:50 turris kernel: [ 229.105210] ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
Oct 1 22:25:50 turris kernel: [ 230.021540] ath10k_pci 0000:02:00.0: 10.1 wmi init: vdevs: 16 peers: 127 tid: 256
Oct 1 22:25:50 turris kernel: [ 230.038613] ath10k_pci 0000:02:00.0: wmi print ‘P 128 V 8 T 410’
Oct 1 22:25:50 turris kernel: [ 230.044664] ath10k_pci 0000:02:00.0: wmi print ‘msdu-desc: 1424 sw-crypt: 0 ct-sta: 0’
Oct 1 22:25:50 turris kernel: [ 230.052694] ath10k_pci 0000:02:00.0: wmi print ‘alloc rem: 20984 iram: 25656’
Oct 1 22:25:50 turris kernel: [ 230.118624] ath10k_pci 0000:02:00.0: htt-ver 2.1 wmi-op 2 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
Oct 1 22:25:50 turris kernel: [ 230.131169] ath10k_pci 0000:02:00.0: NOTE: Firmware DBGLOG output disabled in debug_mask: 0x10000000
Oct 1 22:25:50 turris kernel: [ 230.242718] ath: EEPROM regdomain: 0x0
Oct 1 22:25:50 turris kernel: [ 230.242722] ath: EEPROM indicates default country code should be used
Oct 1 22:25:50 turris kernel: [ 230.242723] ath: doing EEPROM country->regdmn map search
Oct 1 22:25:50 turris kernel: [ 230.242727] ath: country maps to regdmn code: 0x3a
Oct 1 22:25:50 turris kernel: [ 230.242729] ath: Country alpha2 being used: US
Oct 1 22:25:50 turris kernel: [ 230.242730] ath: Regpair used: 0x3a
Oct 1 22:25:50 turris kernel: [ 230.255830] usbcore: registered new interface driver qcserial
Oct 1 22:25:50 turris kernel: [ 230.261631] usbserial: USB Serial support registered for Qualcomm USB modem
Oct 1 22:25:50 turris kernel: [ 230.274451] pci 0000:00:01.0: enabling device (0140 → 0142)
Oct 1 22:25:50 turris kernel: [ 230.367787] ath: EEPROM regdomain: 0x0
Oct 1 22:25:50 turris kernel: [ 230.367795] ath: EEPROM indicates default country code should be used
Oct 1 22:25:50 turris kernel: [ 230.367797] ath: doing EEPROM country->regdmn map search
Oct 1 22:25:50 turris kernel: [ 230.367803] ath: country maps to regdmn code: 0x3a
Oct 1 22:25:50 turris kernel: [ 230.367808] ath: Country alpha2 being used: US
Oct 1 22:25:50 turris kernel: [ 230.367812] ath: Regpair used: 0x3a
Oct 1 22:25:50 turris kernel: [ 230.380107] ieee80211 phy1: Selected rate control algorithm ‘minstrel_ht’
Oct 1 22:25:50 turris kernel: [ 230.381235] ieee80211 phy1: Atheros AR9287 Rev:2 mem=0xf1460000, irq=81
Oct 1 22:25:50 turris kernel: 230.389541] kmodloader: done loading kernel modules from /etc/modules.d/*
Oct 1 22:25:50 turris kernel: [ 231.018835] scsi_io_completion: 447 callbacks suppressed
Oct 1 22:25:50 turris kernel: [ 231.018848] sd 0:0:0:0: [sda] tag#9 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 231.032412] sd 0:0:0:0: [sda] tag#9 CDB: opcode=0x28 28 00 00 00 00 00 00 01 00 00
Oct 1 22:25:50 turris kernel: [ 231.040000] print_req_error: 447 callbacks suppressed
Oct 1 22:25:50 turris kernel: [ 231.040002] print_req_error: I/O error, dev sda, sector 0
Oct 1 22:25:50 turris kernel: [ 231.054311] sd 0:0:0:0: [sda] tag#11 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 231.062614] sd 0:0:0:0: [sda] tag#11 CDB: opcode=0x28 28 00 00 00 08 00 00 01 00 00
Oct 1 22:25:50 turris kernel: [ 231.070288] print_req_error: I/O error, dev sda, sector 2048
Oct 1 22:25:50 turris kernel: [ 231.084584] sd 1:0:0:0: [sdb] tag#28 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 231.092889] sd 1:0:0:0: [sdb] tag#28 CDB: opcode=0x28 28 00 00 00 00 00 00 01 00 00
Oct 1 22:25:50 turris kernel: [ 231.100564] print_req_error: I/O error, dev sdb, sector 0
Oct 1 22:25:50 turris kernel: [ 231.113646] sd 0:0:0:0: [sda] tag#13 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 231.121963] sd 0:0:0:0: [sda] tag#13 CDB: opcode=0x28 28 00 00 00 00 00 00 01 00 00
Oct 1 22:25:50 turris kernel: [ 231.129639] print_req_error: I/O error, dev sda, sector 0
Oct 1 22:25:50 turris kernel: [ 231.135367] sd 0:0:0:0: [sda] tag#14 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 231.143670] sd 0:0:0:0: [sda] tag#14 CDB: opcode=0x28 28 00 00 00 00 00 00 01 00 00
Oct 1 22:25:50 turris kernel: [ 231.151344] print_req_error: I/O error, dev sda, sector 0
Oct 1 22:25:50 turris kernel: [ 231.161716] sd 0:0:0:0: [sda] tag#16 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 231.170012] sd 0:0:0:0: [sda] tag#16 CDB: opcode=0x28 28 00 00 00 08 00 00 01 00 00
Oct 1 22:25:50 turris kernel: [ 231.177700] print_req_error: I/O error, dev sda, sector 2048
Oct 1 22:25:50 turris kernel: [ 231.192195] sd 1:0:0:0: [sdb] tag#30 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 231.200492] sd 1:0:0:0: [sdb] tag#30 CDB: opcode=0x28 28 00 00 00 00 00 00 01 00 00
Oct 1 22:25:50 turris kernel: [ 231.208180] print_req_error: I/O error, dev sdb, sector 0
Oct 1 22:25:50 turris kernel: [ 231.213820] sd 1:0:0:0: [sdb] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 231.222029] sd 1:0:0:0: [sdb] tag#0 CDB: opcode=0x28 28 00 00 00 00 00 00 01 00 00
Oct 1 22:25:50 turris kernel: [ 231.229615] print_req_error: I/O error, dev sdb, sector 0
Oct 1 22:25:50 turris kernel: [ 231.276753] sd 0:0:0:0: [sda] tag#20 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 231.285058] sd 0:0:0:0: [sda] tag#20 CDB: opcode=0x28 28 00 00 00 00 00 00 01 00 00
Oct 1 22:25:50 turris kernel: [ 231.292736] print_req_error: I/O error, dev sda, sector 0
Oct 1 22:25:50 turris kernel: [ 231.302483] sd 0:0:0:0: [sda] tag#22 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 231.310777] sd 0:0:0:0: [sda] tag#22 CDB: opcode=0x28 28 00 00 00 08 00 00 01 00 00
Oct 1 22:25:50 turris kernel: [ 231.318462] print_req_error: I/O error, dev sda, sector 2048
Oct 1 22:25:50 turris kernel: [ 233.033524] IPv6: ADDRCONF(NETDEV_UP): br-guest_turris: link is not ready
Oct 1 22:25:50 turris kernel: [ 233.046816] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
Oct 1 22:25:50 turris kernel: [ 233.202600] mvneta f1034000.ethernet eth2: PHY [f1072004.mdio-mii:01] driver [Marvell 88E1510]
Oct 1 22:25:50 turris kernel: [ 233.211402] mvneta f1034000.ethernet eth2: configuring for phy/sgmii link mode
Oct 1 22:25:50 turris kernel: [ 233.219065] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
Oct 1 22:25:50 turris kernel: [ 233.227037] br-lan: port 1(eth2.1234) entered blocking state
Oct 1 22:25:50 turris kernel: [ 233.232767] br-lan: port 1(eth2.1234) entered disabled state
Oct 1 22:25:50 turris kernel: [ 233.238578] device eth2.1234 entered promiscuous mode
Oct 1 22:25:50 turris kernel: [ 233.243687] device eth2 entered promiscuous mode
Oct 1 22:25:50 turris kernel: [ 233.252087] mvneta f1030000.ethernet eth1: configuring for fixed/rgmii link mode
Oct 1 22:25:50 turris kernel: [ 233.260026] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
Oct 1 22:25:50 turris kernel: [ 233.265969] mvneta f1030000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
Oct 1 22:25:50 turris kernel: [ 233.275817] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
Oct 1 22:25:50 turris kernel: [ 233.283323] mv88e6085 f1072004.mdio-mii:10 lan0: configuring for phy/gmii link mode
Oct 1 22:25:50 turris kernel: [ 233.291786] br-lan: port 2(lan0) entered blocking state
Oct 1 22:25:50 turris kernel: [ 233.297040] br-lan: port 2(lan0) entered disabled state
Oct 1 22:25:50 turris kernel: [ 233.310633] device lan0 entered promiscuous mode
Oct 1 22:25:50 turris kernel: [ 233.315304] device eth1 entered promiscuous mode
Oct 1 22:25:50 turris kernel: [ 233.373824] buffer_io_error: 341 callbacks suppressed
Oct 1 22:25:50 turris kernel: [ 233.373829] Buffer I/O error on dev sda1, logical block 1953522944, async page read
Oct 1 22:25:50 turris kernel: [ 233.386584] Buffer I/O error on dev sda1, logical block 1953522945, async page read
Oct 1 22:25:50 turris kernel: [ 233.394265] Buffer I/O error on dev sda1, logical block 1953522946, async page read
Oct 1 22:25:50 turris kernel: [ 233.401945] Buffer I/O error on dev sda1, logical block 1953522947, async page read
Oct 1 22:25:50 turris kernel: [ 233.409621] Buffer I/O error on dev sda1, logical block 1953522948, async page read
Oct 1 22:25:50 turris kernel: [ 233.417300] Buffer I/O error on dev sda1, logical block 1953522949, async page read
Oct 1 22:25:50 turris kernel: [ 233.424978] Buffer I/O error on dev sda1, logical block 1953522950, async page read
Oct 1 22:25:50 turris kernel: [ 233.432662] Buffer I/O error on dev sda1, logical block 1953522951, async page read
Oct 1 22:25:50 turris kernel: [ 233.448788] Buffer I/O error on dev sdb, logical block 62514752, async page read
Oct 1 22:25:50 turris kernel: [ 233.477004] mv88e6085 f1072004.mdio-mii:10 lan1: configuring for phy/gmii link mode
Oct 1 22:25:50 turris kernel: [ 233.509421] br-lan: port 3(lan1) entered blocking state
Oct 1 22:25:50 turris kernel: [ 233.514686] br-lan: port 3(lan1) entered disabled state
Oct 1 22:25:50 turris kernel: [ 233.572656] device lan1 entered promiscuous mode
Oct 1 22:25:50 turris kernel: [ 233.878332] mv88e6085 f1072004.mdio-mii:10 lan2: configuring for phy/gmii link mode
Oct 1 22:25:50 turris kernel: [ 233.888745] br-lan: port 4(lan2) entered blocking state
Oct 1 22:25:50 turris kernel: [ 233.894006] br-lan: port 4(lan2) entered disabled state
Oct 1 22:25:50 turris kernel: [ 233.910484] Buffer I/O error on dev sda1, logical block 1953522944, async page read
Oct 1 22:25:50 turris kernel: [ 233.920100] device lan2 entered promiscuous mode
Oct 1 22:25:50 turris kernel: [ 233.985853] mv88e6085 f1072004.mdio-mii:10 lan3: configuring for phy/gmii link mode
Oct 1 22:25:50 turris kernel: [ 233.994206] br-lan: port 5(lan3) entered blocking state
Oct 1 22:25:50 turris kernel: [ 233.999457] br-lan: port 5(lan3) entered disabled state
Oct 1 22:25:50 turris kernel: [ 234.011798] device lan3 entered promiscuous mode
Oct 1 22:25:50 turris kernel: [ 234.071085] mvneta f1070000.ethernet eth0: configuring for fixed/rgmii link mode
Oct 1 22:25:50 turris kernel: [ 234.078948] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Oct 1 22:25:50 turris kernel: [ 234.084911] mvneta f1070000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
Oct 1 22:25:50 turris kernel: [ 234.093451] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Oct 1 22:25:50 turris kernel: [ 234.117180] mv88e6085 f1072004.mdio-mii:10 lan4: configuring for phy/gmii link mode
Oct 1 22:25:50 turris kernel: [ 234.129624] br-lan: port 6(lan4) entered blocking state
Oct 1 22:25:50 turris kernel: [ 234.134892] br-lan: port 6(lan4) entered disabled state
Oct 1 22:25:50 turris kernel: [ 234.167150] device lan4 entered promiscuous mode
Oct 1 22:25:50 turris kernel: [ 234.171793] device eth0 entered promiscuous mode
Oct 1 22:25:50 turris kernel: [ 234.232728] IPv6: ADDRCONF(NETDEV_UP): eth2.3456: link is not ready
Oct 1 22:25:50 turris kernel: [ 234.715595] ath: EEPROM regdomain: 0x82bf
Oct 1 22:25:50 turris kernel: [ 234.715599] ath: EEPROM indicates we should expect a country code
Oct 1 22:25:50 turris kernel: [ 234.715601] ath: doing EEPROM country->regdmn map search
Oct 1 22:25:50 turris kernel: [ 234.715604] ath: country maps to regdmn code: 0x37
Oct 1 22:25:50 turris kernel: [ 234.715606] ath: Country alpha2 being used: SK
Oct 1 22:25:50 turris kernel: [ 234.715607] ath: Regpair used: 0x37
Oct 1 22:25:50 turris kernel: [ 234.715610] ath: regdomain 0x82bf dynamically updated by user
Oct 1 22:25:50 turris kernel: [ 234.715662] ath: EEPROM regdomain: 0x82bf
Oct 1 22:25:50 turris kernel: [ 234.715664] ath: EEPROM indicates we should expect a country code
Oct 1 22:25:50 turris kernel: [ 234.715666] ath: doing EEPROM country->regdmn map search
Oct 1 22:25:50 turris kernel: [ 234.715668] ath: country maps to regdmn code: 0x37
Oct 1 22:25:50 turris kernel: [ 234.715669] ath: Country alpha2 being used: SK
Oct 1 22:25:50 turris kernel: [ 234.715671] ath: Regpair used: 0x37
Oct 1 22:25:50 turris kernel: [ 234.715672] ath: regdomain 0x82bf dynamically updated by user
Oct 1 22:25:50 turris kernel: [ 234.777673] ath: EEPROM regdomain: 0x8188
Oct 1 22:25:50 turris kernel: [ 234.777677] ath: EEPROM indicates we should expect a country code
Oct 1 22:25:50 turris kernel: [ 234.777678] ath: doing EEPROM country->regdmn map search
Oct 1 22:25:50 turris kernel: [ 234.777680] ath: country maps to regdmn code: 0x40
Oct 1 22:25:50 turris kernel: [ 234.777683] ath: Country alpha2 being used: JP
Oct 1 22:25:50 turris kernel: [ 234.777684] ath: Regpair used: 0x40
Oct 1 22:25:50 turris kernel: [ 234.777686] ath: regdomain 0x8188 dynamically updated by user
Oct 1 22:25:50 turris kernel: [ 234.777736] ath: EEPROM regdomain: 0x8188
Oct 1 22:25:50 turris kernel: [ 234.777738] ath: EEPROM indicates we should expect a country code
Oct 1 22:25:50 turris kernel: [ 234.777739] ath: doing EEPROM country->regdmn map search
Oct 1 22:25:50 turris kernel: [ 234.777741] ath: country maps to regdmn code: 0x40
Oct 1 22:25:50 turris kernel: [ 234.777743] ath: Country alpha2 being used: JP
Oct 1 22:25:50 turris kernel: [ 234.777744] ath: Regpair used: 0x40
Oct 1 22:25:50 turris kernel: [ 234.777746] ath: regdomain 0x8188 dynamically updated by user
Oct 1 22:25:50 turris kernel: [ 236.471812] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
Oct 1 22:25:50 turris kernel: [ 237.100066] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 1Gbps/Full - flow control rx/tx
Oct 1 22:25:50 turris kernel: [ 237.354959] ath10k_pci 0000:02:00.0: 10.1 wmi init: vdevs: 16 peers: 127 tid: 256
Oct 1 22:25:50 turris kernel: [ 237.372102] ath10k_pci 0000:02:00.0: wmi print ‘P 128 V 8 T 410’
Oct 1 22:25:50 turris kernel: [ 237.378227] ath10k_pci 0000:02:00.0: wmi print ‘msdu-desc: 1424 sw-crypt: 0 ct-sta: 0’
Oct 1 22:25:50 turris kernel: [ 237.386281] ath10k_pci 0000:02:00.0: wmi print ‘alloc rem: 20984 iram: 25656’
Oct 1 22:25:50 turris kernel: [ 237.452232] ath10k_pci 0000:02:00.0: pdev param 0 not supported by firmware
Oct 1 22:25:50 turris kernel: [ 237.467356] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Oct 1 22:25:50 turris kernel: [ 237.491237] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
Oct 1 22:25:50 turris kernel: [ 237.498045] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Oct 1 22:25:50 turris kernel: [ 237.504602] br-lan: port 2(lan0) entered blocking state
Oct 1 22:25:50 turris kernel: [ 237.509865] br-lan: port 2(lan0) entered forwarding state
Oct 1 22:25:50 turris kernel: [ 237.524629] br-lan: port 1(eth2.1234) entered blocking state
Oct 1 22:25:50 turris kernel: [ 237.530321] br-lan: port 1(eth2.1234) entered forwarding state
Oct 1 22:25:50 turris kernel: [ 237.536401] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.3456: link becomes ready
Oct 1 22:25:50 turris kernel: [ 237.543265] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Oct 1 22:25:50 turris kernel: [ 237.560578] br-lan: port 7(wlan0) entered blocking state
Oct 1 22:25:50 turris kernel: [ 237.565953] br-lan: port 7(wlan0) entered disabled state
Oct 1 22:25:50 turris kernel: [ 237.567489] scsi_io_completion: 45 callbacks suppressed
Oct 1 22:25:50 turris kernel: [ 237.567499] sd 0:0:0:0: [sda] tag#3 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 237.571422] device wlan0 entered promiscuous mode
Oct 1 22:25:50 turris kernel: [ 237.576536] sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x28 28 00 74 70 6d 00 00 00 08 00
Oct 1 22:25:50 turris kernel: [ 237.597036] print_req_error: 45 callbacks suppressed
Oct 1 22:25:50 turris kernel: [ 237.597039] print_req_error: I/O error, dev sda, sector 1953524992
Oct 1 22:25:50 turris kernel: [ 237.610365] sd 0:0:0:0: [sda] tag#4 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 237.618602] sd 0:0:0:0: [sda] tag#4 CDB: opcode=0x28 28 00 74 70 6d 00 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 237.626228] print_req_error: I/O error, dev sda, sector 1953524992
Oct 1 22:25:50 turris kernel: [ 237.632487] sd 0:0:0:0: [sda] tag#5 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 237.640708] sd 0:0:0:0: [sda] tag#5 CDB: opcode=0x28 28 00 74 70 6d 01 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 237.648319] print_req_error: I/O error, dev sda, sector 1953524993
Oct 1 22:25:50 turris kernel: [ 237.654569] sd 0:0:0:0: [sda] tag#6 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 237.662799] sd 0:0:0:0: [sda] tag#6 CDB: opcode=0x28 28 00 74 70 6d 02 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 237.670396] print_req_error: I/O error, dev sda, sector 1953524994
Oct 1 22:25:50 turris kernel: [ 237.676636] sd 0:0:0:0: [sda] tag#7 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 237.684857] sd 0:0:0:0: [sda] tag#7 CDB: opcode=0x28 28 00 74 70 6d 03 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 237.692467] print_req_error: I/O error, dev sda, sector 1953524995
Oct 1 22:25:50 turris kernel: [ 237.698728] sd 0:0:0:0: [sda] tag#8 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 237.706953] sd 0:0:0:0: [sda] tag#8 CDB: opcode=0x28 28 00 74 70 6d 04 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 237.714563] print_req_error: I/O error, dev sda, sector 1953524996
Oct 1 22:25:50 turris kernel: [ 237.720793] sd 0:0:0:0: [sda] tag#9 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 237.729027] sd 0:0:0:0: [sda] tag#9 CDB: opcode=0x28 28 00 74 70 6d 05 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 237.736643] print_req_error: I/O error, dev sda, sector 1953524997
Oct 1 22:25:50 turris kernel: [ 237.742884] sd 0:0:0:0: [sda] tag#10 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 237.751176] sd 0:0:0:0: [sda] tag#10 CDB: opcode=0x28 28 00 74 70 6d 06 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 237.758886] print_req_error: I/O error, dev sda, sector 1953524998
Oct 1 22:25:50 turris kernel: [ 237.765135] sd 0:0:0:0: [sda] tag#11 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 237.773457] sd 0:0:0:0: [sda] tag#11 CDB: opcode=0x28 28 00 74 70 6d 07 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 237.781157] print_req_error: I/O error, dev sda, sector 1953524999
Oct 1 22:25:50 turris kernel: [ 237.790694] br-lan: port 8(wlan1) entered blocking state
Oct 1 22:25:50 turris kernel: [ 237.796052] br-lan: port 8(wlan1) entered disabled state
Oct 1 22:25:50 turris kernel: [ 237.801650] device wlan1 entered promiscuous mode
Oct 1 22:25:50 turris kernel: [ 237.808308] ath: EEPROM regdomain: 0x82bf
Oct 1 22:25:50 turris kernel: [ 237.808311] ath: EEPROM indicates we should expect a country code
Oct 1 22:25:50 turris kernel: [ 237.808314] ath: doing EEPROM country->regdmn map search
Oct 1 22:25:50 turris kernel: [ 237.808316] ath: country maps to regdmn code: 0x37
Oct 1 22:25:50 turris kernel: [ 237.808318] ath: Country alpha2 being used: SK
Oct 1 22:25:50 turris kernel: [ 237.808319] ath: Regpair used: 0x37
Oct 1 22:25:50 turris kernel: [ 237.808322] ath: regdomain 0x82bf dynamically updated by user
Oct 1 22:25:50 turris kernel: [ 237.808375] ath: EEPROM regdomain: 0x82bf
Oct 1 22:25:50 turris kernel: [ 237.808377] ath: EEPROM indicates we should expect a country code
Oct 1 22:25:50 turris kernel: [ 237.808379] ath: doing EEPROM country->regdmn map search
Oct 1 22:25:50 turris kernel: [ 237.808381] ath: country maps to regdmn code: 0x37
Oct 1 22:25:50 turris kernel: [ 237.808382] ath: Country alpha2 being used: SK
Oct 1 22:25:50 turris kernel: [ 237.808383] ath: Regpair used: 0x37
Oct 1 22:25:50 turris kernel: [ 237.808385] ath: regdomain 0x82bf dynamically updated by user
Oct 1 22:25:50 turris kernel: [ 237.809334] ath: EEPROM regdomain: 0x8188
Oct 1 22:25:50 turris kernel: [ 237.809336] ath: EEPROM indicates we should expect a country code
Oct 1 22:25:50 turris kernel: [ 237.809338] ath: doing EEPROM country->regdmn map search
Oct 1 22:25:50 turris kernel: [ 237.809340] ath: country maps to regdmn code: 0x40
Oct 1 22:25:50 turris kernel: [ 237.809343] ath: Country alpha2 being used: JP
Oct 1 22:25:50 turris kernel: [ 237.809344] ath: Regpair used: 0x40
Oct 1 22:25:50 turris kernel: [ 237.809346] ath: regdomain 0x8188 dynamically updated by user
Oct 1 22:25:50 turris kernel: [ 237.809395] ath: EEPROM regdomain: 0x8188
Oct 1 22:25:50 turris kernel: [ 237.809396] ath: EEPROM indicates we should expect a country code
Oct 1 22:25:50 turris kernel: [ 237.809398] ath: doing EEPROM country->regdmn map search
Oct 1 22:25:50 turris kernel: [ 237.809400] ath: country maps to regdmn code: 0x40
Oct 1 20:25:50 turris procd: /etc/rc.d/S60resolver: job 1 at Sat Oct 1 22:27:00 2022
Oct 1 22:25:50 turris kernel: [ 237.809401] ath: Country alpha2 being used: JP
Oct 1 22:25:50 turris kernel: [ 237.809402] ath: Regpair used: 0x40
Oct 1 22:25:50 turris kernel: [ 237.809404] ath: regdomain 0x8188 dynamically updated by user
Oct 1 22:25:50 turris kernel: [ 237.809756] sd 1:0:0:0: [sdb] tag#19 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 237.818109] sd 1:0:0:0: [sdb] tag#19 CDB: opcode=0x28 28 00 1d cf 32 00 00 00 08 00
Oct 1 22:25:50 turris kernel: [ 237.825823] print_req_error: I/O error, dev sdb, sector 500118016
Oct 1 22:25:50 turris kernel: [ 239.561455] buffer_io_error: 44 callbacks suppressed
Oct 1 22:25:50 turris kernel: [ 239.561464] Buffer I/O error on dev sda1, logical block 1953522944, async page read
Oct 1 22:25:50 turris kernel: [ 239.574167] Buffer I/O error on dev sda1, logical block 1953522945, async page read
Oct 1 22:25:50 turris kernel: [ 239.581906] Buffer I/O error on dev sda1, logical block 1953522946, async page read
Oct 1 22:25:50 turris kernel: [ 239.589609] Buffer I/O error on dev sda1, logical block 1953522947, async page read
Oct 1 22:25:50 turris kernel: [ 239.597327] Buffer I/O error on dev sda1, logical block 1953522948, async page read
Oct 1 22:25:50 turris kernel: [ 239.605046] Buffer I/O error on dev sda1, logical block 1953522949, async page read
Oct 1 22:25:50 turris kernel: [ 239.612762] Buffer I/O error on dev sda1, logical block 1953522950, async page read
Oct 1 22:25:50 turris kernel: [ 239.620464] Buffer I/O error on dev sda1, logical block 1953522951, async page read
Oct 1 22:25:50 turris kernel: [ 239.653676] Buffer I/O error on dev sdb, logical block 62514752, async page read
Oct 1 22:25:50 turris kernel: [ 240.003056] Buffer I/O error on dev sda1, logical block 1953522944, async page read
Oct 1 22:25:50 turris kernel: [ 244.748901] scsi_io_completion: 56 callbacks suppressed
Oct 1 22:25:50 turris kernel: [ 244.748914] sd 0:0:0:0: [sda] tag#2 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 244.762382] sd 0:0:0:0: [sda] tag#2 CDB: opcode=0x28 28 00 74 70 6d 00 00 00 08 00
Oct 1 22:25:50 turris kernel: [ 244.769980] print_req_error: 56 callbacks suppressed
Oct 1 22:25:50 turris kernel: [ 244.769983] print_req_error: I/O error, dev sda, sector 1953524992
Oct 1 22:25:50 turris kernel: [ 244.870562] sd 0:0:0:0: [sda] tag#3 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 244.878800] sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x28 28 00 74 70 6d 00 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 244.886412] print_req_error: I/O error, dev sda, sector 1953524992
Oct 1 22:25:50 turris kernel: [ 244.892613] buffer_io_error: 26 callbacks suppressed
Oct 1 22:25:50 turris kernel: [ 244.892616] Buffer I/O error on dev sda1, logical block 1953522944, async page read
Oct 1 22:25:50 turris kernel: [ 244.905326] sd 0:0:0:0: [sda] tag#4 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 244.913544] sd 0:0:0:0: [sda] tag#4 CDB: opcode=0x28 28 00 74 70 6d 01 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 244.921134] print_req_error: I/O error, dev sda, sector 1953524993
Oct 1 22:25:50 turris kernel: [ 244.927335] Buffer I/O error on dev sda1, logical block 1953522945, async page read
Oct 1 22:25:50 turris kernel: [ 244.935039] sd 0:0:0:0: [sda] tag#5 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 244.943248] sd 0:0:0:0: [sda] tag#5 CDB: opcode=0x28 28 00 74 70 6d 02 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 244.950836] print_req_error: I/O error, dev sda, sector 1953524994
Oct 1 22:25:50 turris kernel: [ 244.957034] Buffer I/O error on dev sda1, logical block 1953522946, async page read
Oct 1 22:25:50 turris kernel: [ 244.964724] sd 0:0:0:0: [sda] tag#6 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 244.972928] sd 0:0:0:0: [sda] tag#6 CDB: opcode=0x28 28 00 74 70 6d 03 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 244.980518] print_req_error: I/O error, dev sda, sector 1953524995
Oct 1 22:25:50 turris kernel: [ 244.986738] Buffer I/O error on dev sda1, logical block 1953522947, async page read
Oct 1 22:25:50 turris kernel: [ 244.994444] sd 0:0:0:0: [sda] tag#7 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 245.002650] sd 0:0:0:0: [sda] tag#7 CDB: opcode=0x28 28 00 74 70 6d 04 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 245.010241] print_req_error: I/O error, dev sda, sector 1953524996
Oct 1 22:25:50 turris kernel: [ 245.016455] Buffer I/O error on dev sda1, logical block 1953522948, async page read
Oct 1 22:25:50 turris kernel: [ 245.024164] sd 0:0:0:0: [sda] tag#8 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 245.032374] sd 0:0:0:0: [sda] tag#8 CDB: opcode=0x28 28 00 74 70 6d 05 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 245.039969] print_req_error: I/O error, dev sda, sector 1953524997
Oct 1 22:25:50 turris kernel: [ 245.046190] Buffer I/O error on dev sda1, logical block 1953522949, async page read
Oct 1 22:25:50 turris kernel: [ 245.053894] sd 0:0:0:0: [sda] tag#9 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 245.062103] sd 0:0:0:0: [sda] tag#9 CDB: opcode=0x28 28 00 74 70 6d 06 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 245.069691] print_req_error: I/O error, dev sda, sector 1953524998
Oct 1 22:25:50 turris kernel: [ 245.075892] Buffer I/O error on dev sda1, logical block 1953522950, async page read
Oct 1 22:25:50 turris kernel: [ 245.083588] sd 0:0:0:0: [sda] tag#10 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 245.091881] sd 0:0:0:0: [sda] tag#10 CDB: opcode=0x28 28 00 74 70 6d 07 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 245.099554] print_req_error: I/O error, dev sda, sector 1953524999
Oct 1 22:25:50 turris kernel: [ 245.105754] Buffer I/O error on dev sda1, logical block 1953522951, async page read
Oct 1 22:25:50 turris kernel: [ 245.595540] sd 1:0:0:0: [sdb] tag#7 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 245.603760] sd 1:0:0:0: [sdb] tag#7 CDB: opcode=0x28 28 00 1d cf 32 00 00 00 08 00
Oct 1 22:25:50 turris kernel: [ 245.611349] print_req_error: I/O error, dev sdb, sector 500118016
Oct 1 22:25:50 turris kernel: [ 245.667766] Buffer I/O error on dev sdb, logical block 62514752, async page read
Oct 1 22:25:50 turris kernel: [ 246.481352] Buffer I/O error on dev sda1, logical block 1953522944, async page read
Oct 1 22:25:50 turris kernel: [ 247.907783] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Oct 1 22:25:50 turris kernel: [ 247.914264] br-lan: port 8(wlan1) entered blocking state
Oct 1 22:25:50 turris kernel: [ 247.919608] br-lan: port 8(wlan1) entered forwarding state
Oct 1 22:25:50 turris kernel: [ 251.635635] scsi_io_completion: 34 callbacks suppressed
Oct 1 22:25:50 turris kernel: [ 251.635646] sd 0:0:0:0: [sda] tag#12 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 251.649181] sd 0:0:0:0: [sda] tag#12 CDB: opcode=0x28 28 00 74 70 6d 00 00 00 08 00
Oct 1 22:25:50 turris kernel: [ 251.656861] print_req_error: 34 callbacks suppressed
Oct 1 22:25:50 turris kernel: [ 251.656863] print_req_error: I/O error, dev sda, sector 1953524992
Oct 1 22:25:50 turris kernel: [ 251.677555] sd 0:0:0:0: [sda] tag#13 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 251.685855] sd 0:0:0:0: [sda] tag#13 CDB: opcode=0x28 28 00 74 70 6d 00 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 251.693537] print_req_error: I/O error, dev sda, sector 1953524992
Oct 1 22:25:50 turris kernel: [ 251.699734] buffer_io_error: 26 callbacks suppressed
Oct 1 22:25:50 turris kernel: [ 251.699737] Buffer I/O error on dev sda1, logical block 1953522944, async page read
Oct 1 22:25:50 turris kernel: [ 251.712411] sd 0:0:0:0: [sda] tag#14 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 251.720696] sd 0:0:0:0: [sda] tag#14 CDB: opcode=0x28 28 00 74 70 6d 01 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 251.728374] print_req_error: I/O error, dev sda, sector 1953524993
Oct 1 22:25:50 turris kernel: [ 251.734572] Buffer I/O error on dev sda1, logical block 1953522945, async page read
Oct 1 22:25:50 turris kernel: [ 251.742261] sd 0:0:0:0: [sda] tag#15 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 251.750546] sd 0:0:0:0: [sda] tag#15 CDB: opcode=0x28 28 00 74 70 6d 02 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 251.758224] print_req_error: I/O error, dev sda, sector 1953524994
Oct 1 22:25:50 turris kernel: [ 251.764421] Buffer I/O error on dev sda1, logical block 1953522946, async page read
Oct 1 22:25:50 turris kernel: [ 251.772104] sd 0:0:0:0: [sda] tag#16 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 251.780389] sd 0:0:0:0: [sda] tag#16 CDB: opcode=0x28 28 00 74 70 6d 03 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 251.788066] print_req_error: I/O error, dev sda, sector 1953524995
Oct 1 22:25:50 turris kernel: [ 251.794262] Buffer I/O error on dev sda1, logical block 1953522947, async page read
Oct 1 22:25:50 turris kernel: [ 251.801948] sd 0:0:0:0: [sda] tag#17 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 251.810238] sd 0:0:0:0: [sda] tag#17 CDB: opcode=0x28 28 00 74 70 6d 04 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 251.817915] print_req_error: I/O error, dev sda, sector 1953524996
Oct 1 22:25:50 turris kernel: [ 251.824112] Buffer I/O error on dev sda1, logical block 1953522948, async page read
Oct 1 22:25:50 turris kernel: [ 251.831798] sd 0:0:0:0: [sda] tag#18 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 251.840083] sd 0:0:0:0: [sda] tag#18 CDB: opcode=0x28 28 00 74 70 6d 05 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 251.847759] print_req_error: I/O error, dev sda, sector 1953524997
Oct 1 22:25:50 turris kernel: [ 251.853955] Buffer I/O error on dev sda1, logical block 1953522949, async page read
Oct 1 22:25:50 turris kernel: [ 251.861638] sd 0:0:0:0: [sda] tag#19 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 251.869922] sd 0:0:0:0: [sda] tag#19 CDB: opcode=0x28 28 00 74 70 6d 06 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 251.877599] print_req_error: I/O error, dev sda, sector 1953524998
Oct 1 22:25:50 turris kernel: [ 251.883796] Buffer I/O error on dev sda1, logical block 1953522950, async page read
Oct 1 22:25:50 turris kernel: [ 251.891479] sd 0:0:0:0: [sda] tag#20 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 251.899762] sd 0:0:0:0: [sda] tag#20 CDB: opcode=0x28 28 00 74 70 6d 07 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 251.907438] print_req_error: I/O error, dev sda, sector 1953524999
Oct 1 22:25:50 turris kernel: [ 251.913639] Buffer I/O error on dev sda1, logical block 1953522951, async page read
Oct 1 22:25:50 turris kernel: [ 251.922198] sd 1:0:0:0: [sdb] tag#21 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 251.930492] sd 1:0:0:0: [sdb] tag#21 CDB: opcode=0x28 28 00 1d cf 32 00 00 00 08 00
Oct 1 22:25:50 turris kernel: [ 251.938175] print_req_error: I/O error, dev sdb, sector 500118016
Oct 1 22:25:50 turris kernel: [ 251.945401] Buffer I/O error on dev sdb, logical block 62514752, async page read
Oct 1 22:25:50 turris kernel: [ 252.264537] Buffer I/O error on dev sda1, logical block 1953522944, async page read
Oct 1 22:25:50 turris kernel: [ 257.176194] scsi_io_completion: 45 callbacks suppressed
Oct 1 22:25:50 turris kernel: [ 257.176203] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 257.189652] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 74 70 6d 00 00 00 08 00
Oct 1 22:25:50 turris kernel: [ 257.197244] print_req_error: 45 callbacks suppressed
Oct 1 22:25:50 turris kernel: [ 257.197247] print_req_error: I/O error, dev sda, sector 1953524992
Oct 1 22:25:50 turris kernel: [ 257.241961] sd 0:0:0:0: [sda] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 257.250169] sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 74 70 6d 00 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 257.257766] print_req_error: I/O error, dev sda, sector 1953524992
Oct 1 22:25:50 turris kernel: [ 257.263965] buffer_io_error: 35 callbacks suppressed
Oct 1 22:25:50 turris kernel: [ 257.263969] Buffer I/O error on dev sda1, logical block 1953522944, async page read
Oct 1 22:25:50 turris kernel: [ 257.276637] sd 0:0:0:0: [sda] tag#2 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 257.284840] sd 0:0:0:0: [sda] tag#2 CDB: opcode=0x28 28 00 74 70 6d 01 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 257.292461] print_req_error: I/O error, dev sda, sector 1953524993
Oct 1 22:25:50 turris kernel: [ 257.298664] Buffer I/O error on dev sda1, logical block 1953522945, async page read
Oct 1 22:25:50 turris kernel: [ 257.306378] sd 0:0:0:0: [sda] tag#3 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 257.314593] sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x28 28 00 74 70 6d 02 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 257.322191] print_req_error: I/O error, dev sda, sector 1953524994
Oct 1 22:25:50 turris kernel: [ 257.328387] Buffer I/O error on dev sda1, logical block 1953522946, async page read
Oct 1 22:25:50 turris kernel: [ 257.336091] sd 0:0:0:0: [sda] tag#4 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 257.344315] sd 0:0:0:0: [sda] tag#4 CDB: opcode=0x28 28 00 74 70 6d 03 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 257.351910] print_req_error: I/O error, dev sda, sector 1953524995
Oct 1 22:25:50 turris kernel: [ 257.358106] Buffer I/O error on dev sda1, logical block 1953522947, async page read
Oct 1 22:25:50 turris kernel: [ 257.365809] sd 0:0:0:0: [sda] tag#5 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 257.374016] sd 0:0:0:0: [sda] tag#5 CDB: opcode=0x28 28 00 74 70 6d 04 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 257.381608] print_req_error: I/O error, dev sda, sector 1953524996
Oct 1 22:25:50 turris kernel: [ 257.387803] Buffer I/O error on dev sda1, logical block 1953522948, async page read
Oct 1 22:25:50 turris kernel: [ 257.395496] sd 0:0:0:0: [sda] tag#6 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 257.403703] sd 0:0:0:0: [sda] tag#6 CDB: opcode=0x28 28 00 74 70 6d 05 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 257.411290] print_req_error: I/O error, dev sda, sector 1953524997
Oct 1 22:25:50 turris kernel: [ 257.417489] Buffer I/O error on dev sda1, logical block 1953522949, async page read
Oct 1 22:25:50 turris kernel: [ 257.425182] sd 0:0:0:0: [sda] tag#7 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 257.433388] sd 0:0:0:0: [sda] tag#7 CDB: opcode=0x28 28 00 74 70 6d 06 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 257.440975] print_req_error: I/O error, dev sda, sector 1953524998
Oct 1 22:25:50 turris kernel: [ 257.447175] Buffer I/O error on dev sda1, logical block 1953522950, async page read
Oct 1 22:25:50 turris kernel: [ 257.454868] sd 0:0:0:0: [sda] tag#8 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 257.463073] sd 0:0:0:0: [sda] tag#8 CDB: opcode=0x28 28 00 74 70 6d 07 00 00 01 00
Oct 1 22:25:50 turris kernel: [ 257.470660] print_req_error: I/O error, dev sda, sector 1953524999
Oct 1 22:25:50 turris kernel: [ 257.476861] Buffer I/O error on dev sda1, logical block 1953522951, async page read
Oct 1 22:25:50 turris kernel: [ 257.485685] sd 1:0:0:0: [sdb] tag#5 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:25:50 turris kernel: [ 257.493910] sd 1:0:0:0: [sdb] tag#5 CDB: opcode=0x28 28 00 1d cf 32 00 00 00 08 00
Oct 1 22:25:50 turris kernel: [ 257.501505] print_req_error: I/O error, dev sdb, sector 500118016
Oct 1 22:25:50 turris kernel: [ 257.508158] Buffer I/O error on dev sdb, logical block 62514752, async page read
Oct 1 22:25:50 turris kernel: [ 260.520615] Buffer I/O error on dev sda, logical block 0, async page read
Oct 1 20:25:50 turris procd: /etc/rc.d/S60resolver: Called /etc/init.d/kresd start
Oct 1 20:25:50 turris procd: /etc/rc.d/S60resolver: remove dhcp script
Oct 1 20:25:52 turris procd: /etc/rc.d/S61kresd: job 2 at Sat Oct 1 22:27:00 2022
Oct 1 20:25:52 turris procd: /etc/rc.d/S65fosquitto: Generating fosquitto config file in /var/etc/fosquitto.generated.conf
Oct 1 20:25:55 turris collectd[8218]: plugin_load: plugin “iwinfo” successfully loaded.
Oct 1 20:25:55 turris collectd[8218]: plugin_load: plugin “ping” successfully loaded.
Oct 1 20:25:55 turris collectd[8218]: plugin_load: plugin “disk” successfully loaded.
Oct 1 20:25:55 turris collectd[8218]: plugin_load: plugin “memory” successfully loaded.
Oct 1 20:25:55 turris collectd[8218]: plugin_load: plugin “curl” successfully loaded.
Oct 1 20:25:55 turris collectd[8218]: plugin_load: plugin “cpu” successfully loaded.
Oct 1 20:25:55 turris collectd[8218]: plugin_load: plugin “rrdtool” successfully loaded.
Oct 1 20:25:55 turris collectd[8218]: rrdtool plugin: RRASingle = true: creating only AVERAGE RRAs
Oct 1 20:25:55 turris collectd[8218]: plugin_load: plugin “interface” successfully loaded.
Oct 1 20:25:55 turris collectd[8218]: plugin_load: plugin “uptime” successfully loaded.
Oct 1 20:25:55 turris collectd[8218]: plugin_load: plugin “load” successfully loaded.
Oct 1 20:25:55 turris collectd[8218]: plugin_load: plugin “exec” successfully loaded.
Oct 1 20:25:55 turris collectd[8218]: plugin_load: plugin “thermal” successfully loaded.
Oct 1 20:25:55 turris collectd[8218]: Initialization complete, entering read-loop.
Oct 1 20:25:55 turris sshd[8169]: Accepted password for root from 192.168.112.118 port 53643 ssh2
Oct 1 20:25:56 turris ucitrack: Setting up /etc/config/network reload dependency on /etc/config/dhcp
Oct 1 20:25:56 turris ucitrack: Setting up /etc/config/network reload dependency on /etc/config/radvd
Oct 1 20:25:56 turris ucitrack: Setting up /etc/config/wireless reload dependency on /etc/config/network
Oct 1 20:25:56 turris ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/luci-splash
Oct 1 20:25:56 turris ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/qos
Oct 1 20:25:56 turris ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/miniupnpd
Oct 1 20:25:56 turris ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/sqm
Oct 1 20:25:56 turris ucitrack: Setting up /etc/config/dhcp reload dependency on /etc/config/odhcpd
Oct 1 20:25:56 turris ucitrack: Setting up non-init /etc/config/fstab reload handler: /sbin/block mount
Oct 1 20:25:56 turris ucitrack: Setting up /etc/config/system reload trigger for non-procd /etc/init.d/led
Oct 1 20:25:56 turris ucitrack: Setting up /etc/config/system reload dependency on /etc/config/luci_statistics
Oct 1 20:25:56 turris ucitrack: Setting up /etc/config/system reload dependency on /etc/config/dhcp
Oct 1 20:25:57 turris ucitrack: Setting up /etc/config/bcp38 reload dependency on /etc/config/firewall
Oct 1 20:25:58 turris crond[8611]: (CRON) STARTUP (1.5.7)
Oct 1 20:25:58 turris crond[8611]: (CRON) INFO (RANDOM_DELAY will be scaled with factor 63% if used.)
Oct 1 20:25:58 turris crond[8611]: (CRON) INFO (running with inotify support)
Oct 1 20:25:58 turris openvpn(server_turris)[8640]: OpenVPN 2.4.11 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Oct 1 20:25:58 turris openvpn(server_turris)[8640]: library versions: OpenSSL 1.1.1q 5 Jul 2022, LZO 2.10
Oct 1 20:25:58 turris openvpn(server_turris)[8640]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Oct 1 20:25:58 turris openvpn(server_turris)[8640]: Diffie-Hellman initialized with 4096 bit key
Oct 1 20:25:58 turris openvpn(server_turris)[8640]: CRL: loaded 1 CRLs from file /etc/ssl/ca/openvpn/ca.crl
Oct 1 20:25:58 turris netifd: Interface ‘vpn_turris’ is enabled
Oct 1 20:25:58 turris openvpn(server_turris)[8640]: TUN/TAP device tun_turris opened
Oct 1 20:25:58 turris netifd: Network device ‘tun_turris’ link is up
Oct 1 20:25:58 turris openvpn(server_turris)[8640]: TUN/TAP TX queue length set to 100
Oct 1 20:25:58 turris netifd: Interface ‘vpn_turris’ has link connectivity
Oct 1 20:25:58 turris netifd: Interface ‘vpn_turris’ is setting up now
Oct 1 20:25:58 turris openvpn(server_turris)[8640]: /sbin/ifconfig tun_turris 10.111.111.1 pointopoint 10.111.111.2 mtu 1500
Oct 1 20:25:58 turris netifd: Interface ‘vpn_turris’ is now up
Oct 1 20:25:59 turris openvpn(server_turris)[8640]: /usr/libexec/openvpn-hotplug up server_turris tun_turris 1500 1621 10.111.111.1 10.111.111.2 init
Oct 1 20:25:59 turris openvpn(server_turris)[8640]: /sbin/route add -net 10.111.111.0 netmask 255.255.255.0 gw 10.111.111.2
Oct 1 20:25:59 turris openvpn(server_turris)[8640]: Could not determine IPv4/IPv6 protocol. Using AF_INET
Oct 1 20:25:59 turris openvpn(server_turris)[8640]: Socket Buffers: R=[163840->163840] S=[163840->163840]
Oct 1 20:25:59 turris openvpn(server_turris)[8640]: UDPv4 link local (bound): [AF_INET][undef]:1194
Oct 1 20:25:59 turris openvpn(server_turris)[8640]: UDPv4 link remote: [AF_UNSPEC]
Oct 1 20:25:59 turris openvpn(server_turris)[8640]: MULTI: multi_init called, r=256 v=256
Oct 1 20:25:59 turris openvpn(server_turris)[8640]: IFCONFIG POOL: base=10.111.111.4 size=62, ipv6=0
Oct 1 20:25:59 turris openvpn(server_turris)[8640]: IFCONFIG POOL LIST
Oct 1 20:25:59 turris openvpn(server_turris)[8640]: Initialization Sequence Completed
Oct 1 20:25:59 turris smartd[8795]: smartd 7.0 2018-12-30 r4883 [armv7l-linux-4.14.294] (localbuild)
Oct 1 20:25:59 turris smartd[8795]: Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
Oct 1 20:25:59 turris smartd[8795]: Opened configuration file /etc/smartd.conf
Oct 1 20:25:59 turris smartd[8795]: Configuration file /etc/smartd.conf was parsed, found DEVICESCAN, scanning devices
Oct 1 22:25:59 turris kernel: [ 272.040498] program smartd is using a deprecated SCSI ioctl, please convert it to SG_IO
Oct 1 20:25:59 turris smartd[8795]: Device: /dev/sda, opened
Oct 1 20:25:59 turris smartd[8795]: Device: /dev/sda, INQUIRY response less than 36 bytes; skip device
Oct 1 22:25:59 turris kernel: [ 272.057177] program smartd is using a deprecated SCSI ioctl, please convert it to SG_IO
Oct 1 22:25:59 turris kernel: [ 272.081850] program smartd is using a deprecated SCSI ioctl, please convert it to SG_IO
Oct 1 20:25:59 turris smartd[8795]: Device: /dev/sdb, opened
Oct 1 22:25:59 turris kernel: [ 272.093648] program smartd is using a deprecated SCSI ioctl, please convert it to SG_IO
Oct 1 20:25:59 turris smartd[8795]: Device: /dev/sdb, INQUIRY response less than 36 bytes; skip device
Oct 1 20:25:59 turris smartd[8795]: Monitoring 0 ATA/SATA, 0 SCSI/SAS and 0 NVMe devices
Oct 1 20:25:59 turris smartd[8848]: smartd has fork()ed into background mode. New PID=8848.
Oct 1 20:26:00 turris procd: /etc/rc.d/S96led: setting up led wan
Oct 1 20:26:00 turris procd: /etc/rc.d/S96led: setting up led pci1
Oct 1 20:26:00 turris procd: /etc/rc.d/S96led: setting up led pci2
Oct 1 20:26:00 turris procd: /etc/rc.d/S96led: setting up led pci3
Oct 1 20:26:00 turris procd: /etc/rc.d/S96led: setting up led Disk
Oct 1 20:26:01 turris crond[9216]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
Oct 1 20:26:01 turris crond[9215]: (root) CMDEND (/usr/bin/rainbow_button_sync.sh)
Oct 1 20:26:03 turris procd: /etc/rc.d/S99lxc-auto: lxc-start: vaultwarden: tools/lxc_start.c: main: 214 You lack access to /srv/lxc
Oct 1 20:26:03 turris procd: /etc/rc.d/S99lxc-auto: lxc-start: adb-ubuntu: tools/lxc_start.c: main: 214 You lack access to /srv/lxc
Oct 1 20:26:03 turris nmbd[9305]: [2022/10/01 22:26:03.596406, 0] …/…/lib/util/become_daemon.c:136(daemon_ready)
Oct 1 20:26:03 turris nmbd[9305]: daemon_ready: daemon ‘nmbd’ finished starting up and ready to serve connections
Oct 1 20:26:03 turris turris: Router Turris successfully started.
Oct 1 20:26:03 turris smbd[9304]: [2022/10/01 22:26:03.927075, 0] …/…/lib/util/become_daemon.c:136(daemon_ready)
Oct 1 20:26:03 turris smbd[9304]: daemon_ready: daemon ‘smbd’ finished starting up and ready to serve connections
Oct 1 20:26:05 turris procd: /etc/rc.d/S99start-indicator: setting up led wan
Oct 1 20:26:05 turris procd: /etc/rc.d/S99start-indicator: setting up led pci1
Oct 1 20:26:05 turris procd: /etc/rc.d/S99start-indicator: setting up led pci2
Oct 1 20:26:05 turris procd: /etc/rc.d/S99start-indicator: setting up led pci3
Oct 1 20:26:05 turris procd: /etc/rc.d/S99start-indicator: setting up led Disk
Oct 1 20:26:06 turris transmission: Starting with 1033992000 virt mem
Oct 1 22:26:06 turris sentinel: INFO [certgen.action_spec_init:89] Valid certificate found
Oct 1 20:26:06 turris firewall: Reloading firewall due to ifup of wan6 (6in4-wan6)
Oct 1 20:26:07 turris procd: - init complete -
Oct 1 20:26:07 turris wsdd2[9815]: starting.
Oct 1 20:26:07 turris transmission-daemon[9674]: [2022-10-01 22:26:07.766] watchdir:inotify Failed to setup watchdir “/srv/transmission/watch”: No such file or directory (2) (watchdir-inotify.c:171)
Oct 1 20:26:07 turris transmission-daemon[9674]: [2022-10-01 22:26:07.766] watchdir Failed to open directory “/srv/transmission/watch” (2): No such file or directory (watchdir.c:358)
Oct 1 20:26:08 turris openvpn(server_turris)[8640]: event_wait : Interrupted system call (code=4)
Oct 1 20:26:08 turris openvpn(server_turris)[8640]: /sbin/route del -net 10.111.111.0 netmask 255.255.255.0
Oct 1 20:26:08 turris openvpn(server_turris)[8640]: Closing TUN/TAP interface
Oct 1 20:26:08 turris openvpn(server_turris)[8640]: /sbin/ifconfig tun_turris 0.0.0.0
Oct 1 20:26:08 turris netifd: Network device ‘tun_turris’ link is down
Oct 1 20:26:08 turris netifd: Interface ‘vpn_turris’ has link connectivity loss
Oct 1 20:26:08 turris netifd: Interface ‘vpn_turris’ is now down
Oct 1 20:26:08 turris openvpn(server_turris)[8640]: /usr/libexec/openvpn-hotplug down server_turris tun_turris 1500 1621 10.111.111.1 10.111.111.2 init
Oct 1 20:26:08 turris netifd: Interface ‘vpn_turris’ is disabled
Oct 1 20:26:08 turris foris-controller[8162]: WARNING:zeroconf:Error sending through socket 14
Oct 1 20:26:08 turris foris-controller[8162]: Traceback (most recent call last):
Oct 1 20:26:08 turris foris-controller[8162]: File “/usr/lib/python3.7/site-packages/zeroconf/init.py”, line 2826, in send
Oct 1 20:26:08 turris foris-controller[8162]: OSError: [Errno 101] Network unreachable
Oct 1 20:26:09 turris openvpn(server_turris)[8640]: SIGTERM[hard,] received, process exiting
Oct 1 20:26:09 turris openvpn(server_turris)[10032]: OpenVPN 2.4.11 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Oct 1 20:26:09 turris openvpn(server_turris)[10032]: library versions: OpenSSL 1.1.1q 5 Jul 2022, LZO 2.10
Oct 1 20:26:09 turris openvpn(server_turris)[10032]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Oct 1 20:26:09 turris openvpn(server_turris)[10032]: Diffie-Hellman initialized with 4096 bit key
Oct 1 20:26:09 turris openvpn(server_turris)[10032]: CRL: loaded 1 CRLs from file /etc/ssl/ca/openvpn/ca.crl
Oct 1 20:26:09 turris netifd: Interface ‘vpn_turris’ is enabled
Oct 1 20:26:09 turris openvpn(server_turris)[10032]: TUN/TAP device tun_turris opened
Oct 1 20:26:09 turris netifd: Network device ‘tun_turris’ link is up
Oct 1 20:26:09 turris netifd: Interface ‘vpn_turris’ has link connectivity
Oct 1 20:26:09 turris netifd: Interface ‘vpn_turris’ is setting up now
Oct 1 20:26:09 turris openvpn(server_turris)[10032]: TUN/TAP TX queue length set to 100
Oct 1 20:26:09 turris openvpn(server_turris)[10032]: /sbin/ifconfig tun_turris 10.111.111.1 pointopoint 10.111.111.2 mtu 1500
Oct 1 20:26:09 turris netifd: Interface ‘vpn_turris’ is now up
Oct 1 20:26:09 turris openvpn(server_turris)[10032]: /usr/libexec/openvpn-hotplug up server_turris tun_turris 1500 1621 10.111.111.1 10.111.111.2 init
Oct 1 20:26:09 turris foris-controller[8162]: WARNING:zeroconf:Error sending through socket 14
Oct 1 20:26:09 turris foris-controller[8162]: Traceback (most recent call last):
Oct 1 20:26:09 turris foris-controller[8162]: File “/usr/lib/python3.7/site-packages/zeroconf/init.py”, line 2826, in send
Oct 1 20:26:09 turris foris-controller[8162]: OSError: [Errno 19] No such device
Oct 1 20:26:09 turris openvpn(server_turris)[10032]: /sbin/route add -net 10.111.111.0 netmask 255.255.255.0 gw 10.111.111.2
Oct 1 20:26:09 turris openvpn(server_turris)[10032]: Could not determine IPv4/IPv6 protocol. Using AF_INET
Oct 1 20:26:09 turris openvpn(server_turris)[10032]: Socket Buffers: R=[163840->163840] S=[163840->163840]
Oct 1 20:26:09 turris openvpn(server_turris)[10032]: UDPv4 link local (bound): [AF_INET][undef]:1194
Oct 1 20:26:09 turris openvpn(server_turris)[10032]: UDPv4 link remote: [AF_UNSPEC]
Oct 1 20:26:09 turris openvpn(server_turris)[10032]: MULTI: multi_init called, r=256 v=256
Oct 1 20:26:09 turris openvpn(server_turris)[10032]: IFCONFIG POOL: base=10.111.111.4 size=62, ipv6=0
Oct 1 20:26:09 turris openvpn(server_turris)[10032]: IFCONFIG POOL LIST
Oct 1 20:26:09 turris openvpn(server_turris)[10032]: Initialization Sequence Completed
Oct 1 20:26:09 turris sentinel-fwlogs[8966]: ERROR: Packet handling failed: Resource temporarily unavailable
Oct 1 20:26:11 turris openvpn(server_turris)[10032]: 181.174.143.138:1900 TLS: Initial packet from [AF_INET]181.174.143.138:1900, sid=6a22eb44 5adb63fe
Oct 1 20:26:11 turris firewall: Reloading firewall due to ifup of wan (eth2.3456)
Oct 1 20:26:13 turris openvpn(server_turris)[10032]: event_wait : Interrupted system call (code=4)
Oct 1 20:26:13 turris openvpn(server_turris)[10032]: /sbin/route del -net 10.111.111.0 netmask 255.255.255.0
Oct 1 20:26:13 turris openvpn(server_turris)[10032]: Closing TUN/TAP interface
Oct 1 20:26:13 turris openvpn(server_turris)[10032]: /sbin/ifconfig tun_turris 0.0.0.0
Oct 1 20:26:13 turris netifd: Network device ‘tun_turris’ link is down
Oct 1 20:26:13 turris netifd: Interface ‘vpn_turris’ has link connectivity loss
Oct 1 20:26:13 turris netifd: Interface ‘vpn_turris’ is now down
Oct 1 20:26:13 turris openvpn(server_turris)[10032]: /usr/libexec/openvpn-hotplug down server_turris tun_turris 1500 1621 10.111.111.1 10.111.111.2 init
Oct 1 20:26:13 turris netifd: Interface ‘vpn_turris’ is disabled
Oct 1 20:26:13 turris openvpn(server_turris)[10032]: SIGTERM[hard,] received, process exiting
Oct 1 20:26:13 turris openvpn(server_turris)[10644]: OpenVPN 2.4.11 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Oct 1 20:26:13 turris openvpn(server_turris)[10644]: library versions: OpenSSL 1.1.1q 5 Jul 2022, LZO 2.10
Oct 1 20:26:13 turris openvpn(server_turris)[10644]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Oct 1 20:26:13 turris openvpn(server_turris)[10644]: Diffie-Hellman initialized with 4096 bit key
Oct 1 20:26:13 turris openvpn(server_turris)[10644]: CRL: loaded 1 CRLs from file /etc/ssl/ca/openvpn/ca.crl
Oct 1 20:26:13 turris openvpn(server_turris)[10644]: TUN/TAP device tun_turris opened
Oct 1 20:26:13 turris netifd: Interface ‘vpn_turris’ is enabled
Oct 1 20:26:13 turris netifd: Network device ‘tun_turris’ link is up
Oct 1 20:26:13 turris netifd: Interface ‘vpn_turris’ is setting up now
Oct 1 20:26:13 turris netifd: Interface ‘vpn_turris’ is now up
Oct 1 20:26:13 turris openvpn(server_turris)[10644]: TUN/TAP TX queue length set to 100
Oct 1 20:26:13 turris openvpn(server_turris)[10644]: /sbin/ifconfig tun_turris 10.111.111.1 pointopoint 10.111.111.2 mtu 1500
Oct 1 20:26:13 turris openvpn(server_turris)[10644]: /usr/libexec/openvpn-hotplug up server_turris tun_turris 1500 1621 10.111.111.1 10.111.111.2 init
Oct 1 20:26:13 turris openvpn(server_turris)[10644]: /sbin/route add -net 10.111.111.0 netmask 255.255.255.0 gw 10.111.111.2
Oct 1 20:26:13 turris openvpn(server_turris)[10644]: Could not determine IPv4/IPv6 protocol. Using AF_INET
Oct 1 20:26:13 turris openvpn(server_turris)[10644]: Socket Buffers: R=[163840->163840] S=[163840->163840]
Oct 1 20:26:13 turris openvpn(server_turris)[10644]: UDPv4 link local (bound): [AF_INET][undef]:1194
Oct 1 20:26:13 turris openvpn(server_turris)[10644]: UDPv4 link remote: [AF_UNSPEC]
Oct 1 20:26:13 turris openvpn(server_turris)[10644]: MULTI: multi_init called, r=256 v=256
Oct 1 20:26:13 turris openvpn(server_turris)[10644]: IFCONFIG POOL: base=10.111.111.4 size=62, ipv6=0
Oct 1 20:26:13 turris openvpn(server_turris)[10644]: IFCONFIG POOL LIST
Oct 1 20:26:13 turris openvpn(server_turris)[10644]: Initialization Sequence Completed
Oct 1 22:25:30 turris dnsmasq[6921]: started, version 2.80 DNS disabled
Oct 1 22:26:13 turris dnsmasq[6921]: overflow: 18 log entries lost
Oct 1 20:26:16 turris transmission-daemon[9674]: [2022-10-01 22:26:16.762] watchdir Failed to open directory “/srv/transmission/watch” (2): No such file or directory (watchdir.c:358)
Oct 1 22:26:25 turris kernel: [ 297.845385] scsi_io_completion: 27 callbacks suppressed
Oct 1 22:26:25 turris kernel: [ 297.845396] sd 0:0:0:0: [sda] tag#25 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:26:25 turris kernel: [ 297.858947] sd 0:0:0:0: [sda] tag#25 CDB: opcode=0x28 28 00 00 00 00 00 00 00 20 00
Oct 1 22:26:25 turris kernel: [ 297.866642] print_req_error: 27 callbacks suppressed
Oct 1 22:26:25 turris kernel: [ 297.866645] print_req_error: I/O error, dev sda, sector 0
Oct 1 22:26:25 turris kernel: [ 297.882137] sd 0:0:0:0: [sda] tag#26 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:26:25 turris kernel: [ 297.890454] sd 0:0:0:0: [sda] tag#26 CDB: opcode=0x28 28 00 00 00 00 00 00 00 08 00
Oct 1 22:26:25 turris kernel: [ 297.898139] print_req_error: I/O error, dev sda, sector 0
Oct 1 22:26:25 turris kernel: [ 297.903566] buffer_io_error: 19 callbacks suppressed
Oct 1 22:26:25 turris kernel: [ 297.903569] Buffer I/O error on dev sda, logical block 0, async page read
Oct 1 22:26:25 turris kernel: [ 297.920156] sd 0:0:0:0: [sda] tag#27 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:26:25 turris kernel: [ 297.928473] sd 0:0:0:0: [sda] tag#27 CDB: opcode=0x28 28 00 74 70 6d 00 00 00 08 00
Oct 1 22:26:25 turris kernel: [ 297.936157] print_req_error: I/O error, dev sda, sector 1953524992
Oct 1 22:26:25 turris kernel: [ 297.946673] sd 0:0:0:0: [sda] tag#28 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:26:25 turris kernel: [ 297.954989] sd 0:0:0:0: [sda] tag#28 CDB: opcode=0x28 28 00 74 70 6d 00 00 00 08 00
Oct 1 22:26:25 turris kernel: [ 297.962663] print_req_error: I/O error, dev sda, sector 1953524992
Oct 1 22:26:25 turris kernel: [ 297.968867] Buffer I/O error on dev sda, logical block 244190624, async page read
Oct 1 22:26:25 turris kernel: [ 297.985391] sd 0:0:0:0: [sda] tag#29 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:26:25 turris kernel: [ 297.993702] sd 0:0:0:0: [sda] tag#29 CDB: opcode=0x28 28 00 00 00 08 00 00 00 20 00
Oct 1 22:26:25 turris kernel: [ 298.001376] print_req_error: I/O error, dev sda, sector 2048
Oct 1 22:26:25 turris kernel: [ 298.011364] sd 0:0:0:0: [sda] tag#30 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:26:25 turris kernel: [ 298.019681] sd 0:0:0:0: [sda] tag#30 CDB: opcode=0x28 28 00 00 00 08 00 00 00 01 00
Oct 1 22:26:25 turris kernel: [ 298.027372] print_req_error: I/O error, dev sda, sector 2048
Oct 1 22:26:25 turris kernel: [ 298.033064] Buffer I/O error on dev sda1, logical block 0, async page read
Oct 1 22:26:25 turris kernel: [ 298.039990] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:26:25 turris kernel: [ 298.048207] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 00 08 01 00 00 01 00
Oct 1 22:26:25 turris kernel: [ 298.055801] print_req_error: I/O error, dev sda, sector 2049
Oct 1 22:26:25 turris kernel: [ 298.061474] Buffer I/O error on dev sda1, logical block 1, async page read
Oct 1 22:26:25 turris kernel: [ 298.068417] sd 0:0:0:0: [sda] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:26:25 turris kernel: [ 298.076632] sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 00 00 08 02 00 00 01 00
Oct 1 22:26:25 turris kernel: [ 298.084228] print_req_error: I/O error, dev sda, sector 2050
Oct 1 22:26:25 turris kernel: [ 298.089903] Buffer I/O error on dev sda1, logical block 2, async page read
Oct 1 22:26:25 turris kernel: [ 298.096816] sd 0:0:0:0: [sda] tag#2 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:26:25 turris kernel: [ 298.105023] sd 0:0:0:0: [sda] tag#2 CDB: opcode=0x28 28 00 00 00 08 03 00 00 01 00
Oct 1 22:26:25 turris kernel: [ 298.112615] print_req_error: I/O error, dev sda, sector 2051
Oct 1 22:26:25 turris kernel: [ 298.118287] Buffer I/O error on dev sda1, logical block 3, async page read
Oct 1 22:26:25 turris kernel: [ 298.125191] sd 0:0:0:0: [sda] tag#3 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Oct 1 22:26:25 turris kernel: [ 298.133395] sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x28 28 00 00 00 08 04 00 00 01 00
Oct 1 22:26:25 turris kernel: [ 298.140985] print_req_error: I/O error, dev sda, sector 2052
Oct 1 22:26:25 turris kernel: [ 298.146669] Buffer I/O error on dev sda1, logical block 4, async page read
Oct 1 22:26:25 turris kernel: [ 298.153577] Buffer I/O error on dev sda1, logical block 5, async page read
Oct 1 22:26:25 turris kernel: [ 298.160471] Buffer I/O error on dev sda1, logical block 6, async page read
Oct 1 22:26:25 turris kernel: [ 298.167370] Buffer I/O error on dev sda1, logical block 7, async page read
Oct 1 20:26:26 turris collectd[8218]: rrdtool plugin: rrd_update_r failed: /srv/rrd/turris/disk-mmcblk0boot1/disk_time.rrd: opening ‘/srv/rrd/turris/disk-mmcblk0boot1/disk_time.rrd’: No such file or directory
Oct 1 22:26:26 turris kernel: [ 298.924415] program smartctl is using a deprecated SCSI ioctl, please convert it to SG_IO
Oct 1 22:26:26 turris kernel: [ 298.940924] program smartctl is using a deprecated SCSI ioctl, please convert it to SG_IO
Oct 1 22:26:26 turris kernel: [ 298.965306] program smartctl is using a deprecated SCSI ioctl, please convert it to SG_IO
Oct 1 20:26:26 turris transmission-daemon[9674]: [2022-10-01 22:26:26.763] watchdir Failed to open directory “/srv/transmission/watch” (2): No such file or directory (watchdir.c:358)
Oct 1 22:26:26 turris kernel: [ 299.209660] program smartctl is using a deprecated SCSI ioctl, please convert it to SG_IO
Oct 1 22:26:26 turris kernel: [ 299.223413] program smartctl is using a deprecated SCSI ioctl, please convert it to SG_IO
Oct 1 22:26:26 turris kernel: [ 299.231695] program smartctl is using a deprecated SCSI ioctl, please convert it to SG_IO
Oct 1 20:26:28 turris openvpn(server_turris)[10644]: 181.174.143.138:1900 TLS: Initial packet from [AF_INET]181.174.143.138:1900, sid=6a22eb44 5adb63fe
Oct 1 20:26:36 turris transmission-daemon[9674]: [2022-10-01 22:26:36.757] watchdir Failed to open directory “/srv/transmission/watch” (2): No such file or directory (watchdir.c:358)
