Turris OS 5.3.5 is released!
Dear Turris community,
Last week, we released a new Turris OS version 5.3.5 into the Testing branch, and now, we released it from the testing branch to the stable.
Release notes:
  • Updated kernel to version 4.14.264
  • Updated several packages such as Knot Resolver, nano
  • Additional fix for RTC on Turris 1.x routers
  • Security fixes
    • Prosody
    • uriparser
    • lighttpd
    • ruby
    • nss
This version will be downloaded and applied automatically. If not, then you are probably using approvals or delayed updates, in that case, we suggest to take a look at reForis for pending updates.
We appreciate any feedback regarding this release.
List of known bugs:
Turris HW known bugs:
  • In some cases, Turris MOX and Turris Shield are not correctly rebooted.
    You could try to remove the power supply and plug it back. We are working to have the solution with the manufacturer of SoC (Marvell). In the meantime, you can try this workaround.
And what SDIO warning?
Mox A+D simple setup.
Other than what pepe mention regarding reboot issue everything looks ok.
TO2020, no issues so far.
workaround worked perfect for me, now my Mox reboots OK. I can recomend. Thx !
Hi Pepe,
I’m happy that for the first time I noticed “known bugs” info as a part of release announcement.
Please, keep it in your flow - it is not a shame, but it is allowing people to make wise choice.
Other “mature” manufactures do the same - as example, fresh release notes for QTS firmware from Qnap: QTS 5.0.0.1932 build 20220129 | Poznámky k vydání | QNAP - there are sections:
  • Important Notes
  • Security Updates
  • Fixed Issues
  • Known Issues
  • Other Changes
Part of this report is as well link to the Product Support Status, where you can find manufacturer statement about when will be discontinued support for particular model (no one wants to read about his one, but it’s good to know in advance).
Thanks you and whole Turris team for continuous updates!
I still have the same problem as with 5.3.4 (which I needed to revert) on my MOXs: The WiFi-firmware crashes. It doesn’t matter whether I install ath10k or ath10k-ct drivers…
dmesg
root@MOX:~# dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.264 (packaging@turris.cz) (gcc version 7.5.0 (OpenWrt GCC 7.5.0 r11397+89-524cbcf6f5)) #0 SMP Tue Feb 8 00:27:12 2022
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] Machine model: CZ.NIC Turris Mox Board
[    0.000000] earlycon: ar3700_uart0 at MMIO 0x00000000d0012000 (options '')
[    0.000000] bootconsole [ar3700_uart0] enabled
[    0.000000] On node 0 totalpages: 262144
[    0.000000]   DMA zone: 4096 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 262144 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] random: get_random_bytes called from start_kernel+0x9c/0x494 with crng_init=0
[    0.000000] percpu: Embedded 16 pages/cpu s26648 r8192 d30696 u65536
[    0.000000] pcpu-alloc: s26648 r8192 d30696 u65536 alloc=16*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 258048
[    0.000000] Kernel command line: earlyprintk console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 mangled_fs=btrfs root=PARTUUID=2b574498-01 rootflags=commit=5,subvol=@ rootwait  rw cfg80211.freg=
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
[    0.000000] Memory: 1019816K/1048576K available (7422K kernel code, 476K rwdata, 1940K rodata, 320K init, 304K bss, 28760K reserved, 0K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff80087c0000   (  7424 KB)
[    0.000000]     .rodata : 0xffffff80087c0000 - 0xffffff80089b0000   (  1984 KB)
[    0.000000]       .init : 0xffffff80089b0000 - 0xffffff8008a00000   (   320 KB)
[    0.000000]       .data : 0xffffff8008a00000 - 0xffffff8008a77008   (   477 KB)
[    0.000000]        .bss : 0xffffff8008a77008 - 0xffffff8008ac31a8   (   305 KB)
[    0.000000]     fixed   : 0xffffffbefe7fb000 - 0xffffffbefec00000   (  4116 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf01000000   (    16 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc040000000   (  1024 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  CONFIG_RCU_FANOUT set to non-default value of 32
[    0.000000]  RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: no VLPI support, no direct LPI support
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000d1d40000
[    0.000000] arch_timer: cp15 timer(s) running at 12.50MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049cda, max_idle_ns: 440795202628 ns
[    0.000004] sched_clock: 56 bits at 12MHz, resolution 80ns, wraps every 4398046511080ns
[    0.008427] Console: colour dummy device 80x25
[    0.012937] Calibrating delay loop (skipped), value calculated using timer frequency.. 25.00 BogoMIPS (lpj=125000)
[    0.023586] pid_max: default: 32768 minimum: 301
[    0.028439] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
[    0.035272] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
[    0.043610] ASID allocator initialised with 32768 entries
[    0.049191] Hierarchical SRCU implementation.
[    0.054048] smp: Bringing up secondary CPUs ...
[    0.059007] Detected VIPT I-cache on CPU1
[    0.059037] GICv3: CPU1: found redistributor 1 region 0:0x00000000d1d60000
[    0.059068] CPU1: Booted secondary processor [410fd034]
[    0.059160] smp: Brought up 1 node, 2 CPUs
[    0.079866] SMP: Total of 2 processors activated.
[    0.084713] CPU features: detected: GIC system register CPU interface
[    0.091334] CPU features: detected: 32-bit EL0 Support
[    0.096634] CPU: All CPU(s) started at EL2
[    0.100845] alternatives: patching kernel code
[    0.106181] devtmpfs: initialized
[    0.111689] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.121790] futex hash table entries: 512 (order: 4, 65536 bytes)
[    0.128122] xor: measuring software checksum speed
[    0.233019]    8regs     :  1918.800 MB/sec
[    0.333051]    8regs_prefetch:  1710.400 MB/sec
[    0.433086]    32regs    :  2358.800 MB/sec
[    0.533117]    32regs_prefetch:  1984.400 MB/sec
[    0.537784] xor: using function: 32regs (2358.800 MB/sec)
[    0.543350] pinctrl core: initialized pinctrl subsystem
[    0.549422] NET: Registered protocol family 16
[    0.554987] cpuidle: using governor ladder
[    0.559268] vdso: 2 pages (1 code @ ffffff80087c5000, 1 data @ ffffff8008a04000)
[    0.566838] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.574051] DMA: preallocated 256 KiB pool for atomic allocations
[    0.581562] d0012000.serial: ttyMV0 at MMIO 0xd0012000 (irq = 9, base_baud = 0) is a mvebu-uart
[    0.590508] console [ttyMV0] enabled
[    0.597809] bootconsole [ar3700_uart0] disabled
[    0.787400] raid6: int64x1  gen()   321 MB/s
[    0.957377] raid6: int64x1  xor()   317 MB/s
[    1.127511] raid6: int64x2  gen()   521 MB/s
[    1.297577] raid6: int64x2  xor()   450 MB/s
[    1.467607] raid6: int64x4  gen()   779 MB/s
[    1.637726] raid6: int64x4  xor()   551 MB/s
[    1.807783] raid6: int64x8  gen()   939 MB/s
[    1.977832] raid6: int64x8  xor()   562 MB/s
[    2.147987] raid6: neonx1   gen()   594 MB/s
[    2.317998] raid6: neonx1   xor()   625 MB/s
[    2.488103] raid6: neonx2   gen()   985 MB/s
[    2.658155] raid6: neonx2   xor()   947 MB/s
[    2.828239] raid6: neonx4   gen()  1312 MB/s
[    2.998286] raid6: neonx4   xor()  1171 MB/s
[    3.168370] raid6: neonx8   gen()  1297 MB/s
[    3.338436] raid6: neonx8   xor()  1132 MB/s
[    3.342488] raid6: using algorithm neonx4 gen() 1312 MB/s
[    3.348061] raid6: .... xor() 1171 MB/s, rmw enabled
[    3.353191] raid6: using neon recovery algorithm
[    3.359035] SCSI subsystem initialized
[    3.363370] libata version 3.00 loaded.
[    3.363592] usbcore: registered new interface driver usbfs
[    3.369227] usbcore: registered new interface driver hub
[    3.374639] usbcore: registered new device driver usb
[    3.380126] pxa2xx-i2c d0011000.i2c: could not find pctldev for node /soc/internal-regs@d0000000/pinctrl@13800/i2c1-pins, deferring probe
[    3.394094] clocksource: Switched to clocksource arch_sys_counter
[    3.407803] NET: Registered protocol family 2
[    3.412477] IP idents hash table entries: 16384 (order: 5, 131072 bytes)
[    3.419711] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    3.426905] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[    3.433887] TCP: Hash tables configured (established 8192 bind 8192)
[    3.440242] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    3.446153] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    3.452911] NET: Registered protocol family 1
[    3.457303] PCI: CLS 0 bytes, default 128
[    3.457971] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    3.469697] Crashlog allocated RAM at address 0x3f00000
[    3.475581] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[    3.486366] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    3.492057] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    3.505885] io scheduler noop registered
[    3.509949] io scheduler deadline registered (default)
[    3.515211] io scheduler bfq registered
[    3.522166] OF: PCI: host bridge /soc/pcie@d0070000 ranges:
[    3.527813] OF: PCI:   MEM 0xe8000000..0xefefffff -> 0xe8000000
[    3.533606] OF: PCI:    IO 0xefff0000..0xefffffff -> 0xefff0000
[    3.540181] advk-pcie d0070000.pcie: issuing PERST via reset GPIO for 10ms
[    3.654037] advk-pcie d0070000.pcie: link up
[    3.658333] advk-pcie d0070000.pcie: PCI host bridge to bus 0000:00
[    3.664946] pci_bus 0000:00: root bus resource [bus 00-ff]
[    3.670619] pci_bus 0000:00: root bus resource [mem 0xe8000000-0xefefffff]
[    3.677739] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0xefff0000-0xefffffff])
[    3.687529] pci 0000:00:00.0: [168c:0046] type 00 class 0x028000
[    3.687636] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit]
[    3.687948] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[    3.688116] pci 0000:00:00.0: BAR 0: assigned [mem 0xe8000000-0xe81fffff 64bit]
[    3.696766] mv_xor d0060900.xor: Marvell shared XOR driver
[    3.764631] mv_xor d0060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[    3.834621] mv_xor d0060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[    3.842857] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[    3.851308] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    3.860607] loop: module loaded
[    3.869896] random: fast init done
[    3.878328] m25p80 spi0.0: w25q64dw (8192 Kbytes)
[    3.883068] 5 fixed-partitions partitions found on MTD device spi0.0
[    3.889424] Creating 5 MTD partitions on "spi0.0":
[    3.894265] 0x000000000000-0x000000020000 : "secure-firmware"
[    3.901048] 0x000000020000-0x000000180000 : "u-boot"
[    3.906648] 0x000000180000-0x000000190000 : "u-boot-env"
[    3.912695] 0x000000190000-0x0000007f0000 : "Rescue system"
[    3.918803] 0x0000007f0000-0x000000800000 : "dtb"
[    3.924279] moxtet spi0.1: Found SD Turris Mox CPU module
[    3.929693] moxtet spi0.1: PCIe module found
[    3.937890] mvneta d0030000.ethernet eth0: Using device tree mac address d8:58:d7:00:cf:a2
[    3.946718] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.953208] ehci-pci: EHCI PCI platform driver
[    3.957694] ehci-platform: EHCI generic platform driver
[    3.963210] ehci-orion: EHCI orion driver
[    3.967774] orion-ehci d005e000.usb: EHCI Host Controller
[    3.973388] orion-ehci d005e000.usb: new USB bus registered, assigned bus number 1
[    3.981146] orion-ehci d005e000.usb: irq 12, io mem 0xd005e000
[    4.014046] orion-ehci d005e000.usb: USB 2.0 started, EHCI 1.00
[    4.020626] hub 1-0:1.0: USB hub found
[    4.024197] hub 1-0:1.0: 1 port detected
[    4.029113] usbcore: registered new interface driver usb-storage
[    4.035434] i2c /dev entries driver
[    4.039508] armada_37xx_wdt d0008300.watchdog: Initial timeout 120 sec
[    4.046783] sdhci: Secure Digital Host Controller Interface driver
[    4.052822] sdhci: Copyright(c) Pierre Ossman
[    4.057379] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.063665] xenon-sdhci d00d0000.sdhci: allocated mmc-pwrseq
[    4.069407] xenon-sdhci d00d8000.sdhci: Got CD GPIO
[    4.075667] NET: Registered protocol family 10
[    4.081092] Segment Routing with IPv6
[    4.084710] NET: Registered protocol family 17
[    4.089417] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    4.103179] 8021q: 802.1Q VLAN Support v1.8
[    4.109705] Btrfs loaded, crc32c=crc32c-arm64-ce
[    4.118809] rtc-ds1307 0-006f: registered as rtc0
[    4.123373] i2c i2c-0:  PXA I2C adapter
[    4.127821] xhci-hcd d0058000.usb: xHCI Host Controller
[    4.133159] xhci-hcd d0058000.usb: new USB bus registered, assigned bus number 2
[    4.140968] xhci-hcd d0058000.usb: hcc params 0x0a000998 hci version 0x100 quirks 0x0000000000010010
[    4.150291] xhci-hcd d0058000.usb: irq 11, io mem 0xd0058000
[    4.156545] hub 2-0:1.0: USB hub found
[    4.160003] hub 2-0:1.0: 1 port detected
[    4.164340] xhci-hcd d0058000.usb: xHCI Host Controller
[    4.169613] xhci-hcd d0058000.usb: new USB bus registered, assigned bus number 3
[    4.177196] xhci-hcd d0058000.usb: Host supports USB 3.0  SuperSpeed
[    4.183686] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.192645] hub 3-0:1.0: USB hub found
[    4.196307] hub 3-0:1.0: 1 port detected
[    4.200896] xenon-sdhci d00d0000.sdhci: allocated mmc-pwrseq
[    4.264043] mmc0: SDHCI controller on d00d0000.sdhci [d00d0000.sdhci] using ADMA
[    4.271787] xenon-sdhci d00d8000.sdhci: Got CD GPIO
[    4.344222] mmc1: SDHCI controller on d00d8000.sdhci [d00d8000.sdhci] using ADMA
[    4.357536] armada-37xx-rwtm-mailbox d00b0000.mailbox: Trust Status: 00000000
[    4.437518] Turris Mox serial number 0000000D30009CC5
[    4.442653]            board version 22
[    4.446344]            burned RAM size 1024 MiB
[    4.707612] rtc-ds1307 0-006f: setting system clock to 2022-02-10 22:43:53 UTC (1644533033)
[    4.707676] random: crng init done
[    4.907689] Waiting for root device PARTUUID=2b574498-01...
[    5.045370] xenon-sdhci d00d8000.sdhci: Timing issue might occur in DDR mode
[    5.052785] mmc1: new ultra high speed DDR50 SDHC card at address 0007
[    5.061235] mmcblk1: mmc1:0007 SD8GB 7.42 GiB
[    5.067605]  mmcblk1: p1
[    5.091278] F2FS-fs (mmcblk1p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[    5.098725] F2FS-fs (mmcblk1p1): Can't find valid F2FS filesystem in 1th superblock
[    5.107640] F2FS-fs (mmcblk1p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[    5.114865] F2FS-fs (mmcblk1p1): Can't find valid F2FS filesystem in 2th superblock
[    5.122714] F2FS-fs (mmcblk1p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[    5.130079] F2FS-fs (mmcblk1p1): Can't find valid F2FS filesystem in 1th superblock
[    5.138439] F2FS-fs (mmcblk1p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[    5.145478] F2FS-fs (mmcblk1p1): Can't find valid F2FS filesystem in 2th superblock
[    5.155141] BTRFS: device label turris devid 1 transid 1154 /dev/root
[    5.163724] BTRFS info (device mmcblk1p1): disk space caching is enabled
[    5.170710] BTRFS info (device mmcblk1p1): has skinny extents
[    5.203135] BTRFS info (device mmcblk1p1): enabling ssd optimizations
[    5.224363] VFS: Mounted root (btrfs filesystem) on device 0:12.
[    5.233075] devtmpfs: mounted
[    5.236500] Freeing unused kernel memory: 320K
[    5.375145] init: Console is alive
[    5.378821] init: - watchdog -
[    6.797063] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[    6.992953] usbcore: registered new interface driver uas
[    6.999017] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[    7.009043] init: - preinit -
[    9.221032] mount_root: mounting /dev/root
[   15.829031] BTRFS info (device mmcblk1p1): disk space caching is enabled
[   16.174485] urandom-seed: Seeding with /etc/urandom.seed
[   16.472759] procd: - early -
[   16.475860] procd: - watchdog -
[   17.133663] procd: - watchdog -
[   17.137864] procd: - ubus -
[   17.191987] procd: - init -
[   17.303086] kmodloader: loading kernel modules from /etc/modules.d/*
[   17.325465] zram: Added device: zram0
[   17.341555] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[   17.356834] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   17.367220] Netfilter messages via NETLINK v0.30.
[   17.373551] ip_set: protocol 6
[   17.399866] Loading modules backported from Linux version v4.19.221-0-g5fd3cce374df
[   17.407578] Backport generated by backports.git v4.19.221-1-0-g07fffc43
[   17.446124] hidraw: raw HID events driver (C) Jiri Kosina
[   17.454560] Mirror/redirect action on
[   17.466580] u32 classifier
[   17.469044]     input device check on
[   17.472914]     Actions configured
[   17.483111] sch_cake: Unknown symbol nf_conntrack_find_get (err 0)
[   17.489667] sch_cake: Unknown symbol nf_ct_get_tuplepr (err 0)
[   17.543457] ath10k 4.19 driver, optimized for CT firmware, probing pci device: 0x46.
[   17.552773] ath10k_pci 0000:00:00.0: enabling device (0000 -> 0002)
[   17.560364] ath10k_pci 0000:00:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[   17.735940] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/fwcfg-pci-0000:00:00.0.txt failed with error -2
[   17.746866] ath10k_pci 0000:00:00.0: Falling back to user helper
[   17.959629] firmware ath10k!fwcfg-pci-0000:00:00.0.txt: firmware_loading_store: map pages failed
[   17.969080] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:00:00.0.bin failed with error -2
[   17.980318] ath10k_pci 0000:00:00.0: Falling back to user helper
[   17.996990] firmware ath10k!pre-cal-pci-0000:00:00.0.bin: firmware_loading_store: map pages failed
[   18.006582] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/cal-pci-0000:00:00.0.bin failed with error -2
[   18.017468] ath10k_pci 0000:00:00.0: Falling back to user helper
[   18.032486] firmware ath10k!cal-pci-0000:00:00.0.bin: firmware_loading_store: map pages failed
[   18.041396] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA9984/hw1.0/ct-firmware-5.bin failed with error -2
[   18.052558] ath10k_pci 0000:00:00.0: Falling back to user helper
[   18.067688] firmware ath10k!QCA9984!hw1.0!ct-firmware-5.bin: firmware_loading_store: map pages failed
[   18.077553] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA9984/hw1.0/ct-firmware-2.bin failed with error -2
[   18.088507] ath10k_pci 0000:00:00.0: Falling back to user helper
[   18.103631] firmware ath10k!QCA9984!hw1.0!ct-firmware-2.bin: firmware_loading_store: map pages failed
[   18.113507] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA9984/hw1.0/firmware-6.bin failed with error -2
[   18.124384] ath10k_pci 0000:00:00.0: Falling back to user helper
[   18.139328] firmware ath10k!QCA9984!hw1.0!firmware-6.bin: firmware_loading_store: map pages failed
[   18.176046] ath10k_pci 0000:00:00.0: qca9984/qca9994 hw1.0 target 0x01000000 chip_id 0x00000000 sub 168c:cafe
[   18.186503] ath10k_pci 0000:00:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
[   18.209132] ath10k_pci 0000:00:00.0: firmware ver 10.4b-ct-9984-fW-13-795874169 api 5 features mfp,peer-flow-ctrl,txstatus-noack,wmi-10.x-CT,ratemask-CT,regdump-CT,txrate-CT,flush-all-CT,pingpong-CT,ch-regs-CT,nop-CT,set-special-CT,tx-rc-CT,cust-stats-CT,txrate2-CT,beacon-cb-CT,wmi-block-ack-CT,wmi-bcn-rc-CT crc32 f3d4b769
[   19.510567] ath10k_pci 0000:00:00.0: board_file api 2 bmi_id 0:1 crc32 85498734
[   22.064039] ath10k_pci 0000:00:00.0: firmware crashed! (guid dc3fa80a-9c1d-4b68-8b50-22c561c8a52d)
[   22.073570] ath10k_pci 0000:00:00.0: qca9984/qca9994 hw1.0 target 0x01000000 chip_id 0x00000000 sub 168c:cafe
[   22.083837] ath10k_pci 0000:00:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
[   22.105320] ath10k_pci 0000:00:00.0: firmware ver 10.4b-ct-9984-fW-13-795874169 api 5 features mfp,peer-flow-ctrl,txstatus-noack,wmi-10.x-CT,ratemask-CT,regdump-CT,txrate-CT,flush-all-CT,pingpong-CT,ch-regs-CT,nop-CT,set-special-CT,tx-rc-CT,cust-stats-CT,txrate2-CT,beacon-cb-CT,wmi-block-ack-CT,wmi-bcn-rc-CT crc32 f3d4b769
[   22.136831] ath10k_pci 0000:00:00.0: board_file api 2 bmi_id 0:1 crc32 85498734
[   22.144262] ath10k_pci 0000:00:00.0: htt-ver 0.0 wmi-op 6 htt-op 4 cal otp max-sta 32 raw 0 hwcrypto 1
[   22.155969] ath10k_pci 0000:00:00.0: firmware register dump:
[   22.161698] ath10k_pci 0000:00:00.0: [00]: 0x01000000 0x00000000 0x009C9E80 0x00000000
[   22.170025] ath10k_pci 0000:00:00.0: [04]: 0x009C9E80 0x00060330 0x0000000E 0xE6DE7221
[   22.178043] ath10k_pci 0000:00:00.0: [08]: 0x009C9E78 0x004069AC 0x004069B0 0x004235F0
[   22.186232] ath10k_pci 0000:00:00.0: [12]: 0x00000000 0xFFFFFFFF 0x00973D28 0x00973D33
[   22.194601] ath10k_pci 0000:00:00.0: [16]: 0x80962EF0 0x0040695C 0x00980000 0x00400000
[   22.202877] ath10k_pci 0000:00:00.0: [20]: 0x00000000 0x0040695C 0x98D81903 0x13AE3761
[   22.210904] ath10k_pci 0000:00:00.0: [24]: 0x0000000A 0xC9C1CC97 0xDEF42C59 0x5C124811
[   22.219183] ath10k_pci 0000:00:00.0: [28]: 0x000003F8 0x00000214 0x00000001 0x00000000
[   22.227016] ath10k_pci 0000:00:00.0: [32]: 0x009CA08C 0x009C9E6C 0x214311B0 0x101000A0
[   22.235207] ath10k_pci 0000:00:00.0: [36]: 0x00403A28 0x00000020 0x00000005 0x0047ED78
[   22.243658] ath10k_pci 0000:00:00.0: [40]: 0x800DDA3F 0x004069AC 0x00000004 0x00415030
[   22.251585] ath10k_pci 0000:00:00.0: [44]: 0x00000002 0x00401E88 0x00000004 0x00000000
[   22.260044] ath10k_pci 0000:00:00.0: [48]: 0x800C383A 0x004069DC 0x0002257B 0x00400000
[   22.268414] ath10k_pci 0000:00:00.0: [52]: 0x00000000 0x00000000 0x0002257B 0x00400000
[   22.276263] ath10k_pci 0000:00:00.0: [56]: 0x00405524 0x00000001 0x00000000 0x00000000
[   22.284721] ath10k_pci 0000:00:00.0: Copy Engine register dump:
[   22.290663] ath10k_pci 0000:00:00.0: [00]: 0x0004a000   3   3   4   3
[   22.297238] ath10k_pci 0000:00:00.0: [01]: 0x0004a400   6   6   5   6
[   22.303892] ath10k_pci 0000:00:00.0: [02]: 0x0004a800   0   0 127   0
[   22.310556] ath10k_pci 0000:00:00.0: [03]: 0x0004ac00   0   0   0   0
[   22.317216] ath10k_pci 0000:00:00.0: [04]: 0x0004b000   0   0   0   0
[   22.324146] ath10k_pci 0000:00:00.0: [05]: 0x0004b400   0   0   0   0
[   22.330534] ath10k_pci 0000:00:00.0: [06]: 0x0004b800   0   0   0   0
[   22.337470] ath10k_pci 0000:00:00.0: [07]: 0x0004bc00   1   1   1   1
[   22.343945] ath10k_pci 0000:00:00.0: [08]: 0x0004c000   0   0 127   0
[   22.350521] ath10k_pci 0000:00:00.0: [09]: 0x0004c400   1   1   1   1
[   22.357181] ath10k_pci 0000:00:00.0: [10]: 0x0004c800   0   0   0   0
[   22.363745] ath10k_pci 0000:00:00.0: [11]: 0x0004cc00   0   0   0   0
[   22.372515] ath10k_pci 0000:00:00.0: debug log header, dbuf: 0x96068c  dropped: 4197376
[   22.381555] ath10k_pci 0000:00:00.0: [0] next: 0x0 buf: 0x0 sz: 0 len: 0 count: 0 free: 0
[   23.014154] ath10k_pci 0000:00:00.0: failed to receive control response completion, polling..
[   24.054169] ath10k_pci 0000:00:00.0: ctl_resp never came in (-110)
[   24.060620] ath10k_pci 0000:00:00.0: failed to connect to HTC: -110
[   24.162606] ath10k_pci 0000:00:00.0: could not init core (-110)
[   24.169770] ath10k_pci 0000:00:00.0: could not probe fw (-110)
[   24.191588] Bluetooth: Core ver 2.22
[   24.195431] NET: Registered protocol family 31
[   24.200065] Bluetooth: HCI device and connection manager initialized
[   24.206638] Bluetooth: HCI socket layer initialized
[   24.211580] Bluetooth: L2CAP socket layer initialized
[   24.216985] Bluetooth: SCO socket layer initialized
[   24.224387] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   24.229850] Bluetooth: BNEP filters: protocol multicast
[   24.234111] ath10k_pci 0000:00:00.0: cannot restart a device that hasn't been started
[   24.235437] Bluetooth: BNEP socket layer initialized
[   24.250234] Bridge firewalling registered
[   24.264141] usbcore: registered new interface driver btusb
[   24.283310] Ebtables v2.0 registered
[   24.289521] Bluetooth: HCI UART driver ver 2.3
[   24.294143] Bluetooth: HCI UART protocol H4 registered
[   24.299323] Bluetooth: HCI UART protocol BCSP registered
[   24.305001] Bluetooth: HCI UART protocol ATH3K registered
[   24.313312] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[   24.319433] Bluetooth: HIDP socket layer initialized
[   24.327231] ip_tables: (C) 2000-2006 Netfilter Core Team
[   24.355057] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
[   24.364297] ctnetlink v0.93: registering with nfnetlink.
[   24.408708] Bluetooth: RFCOMM TTY layer initialized
[   24.413653] Bluetooth: RFCOMM socket layer initialized
[   24.419252] Bluetooth: RFCOMM ver 1.11
[   24.427398] usbcore: registered new interface driver ums-alauda
[   24.434986] usbcore: registered new interface driver ums-cypress
[   24.442866] usbcore: registered new interface driver ums-datafab
[   24.450474] usbcore: registered new interface driver ums-freecom
[   24.457796] usbcore: registered new interface driver ums-isd200
[   24.464656] usbcore: registered new interface driver ums-jumpshot
[   24.471423] usbcore: registered new interface driver ums-karma
[   24.478591] usbcore: registered new interface driver ums-sddr09
[   24.485645] usbcore: registered new interface driver ums-sddr55
[   24.492765] usbcore: registered new interface driver ums-usbat
[   24.529442] xt_time: kernel timezone is -0000
[   24.550399] PPP generic driver version 2.4.2
[   24.557108] NET: Registered protocol family 24
[   24.577957] kmodloader: done loading kernel modules from /etc/modules.d/*
[   25.127957] zram0: detected capacity change from 0 to 522190848
[   25.142677] Adding 509948k swap on /dev/zram0.  Priority:-2 extents:1 across:509948k SS
[   27.344824] mvneta d0030000.ethernet eth0: PHY [d0032004.mdio-mii:01] driver [Marvell 88E1510]
[   27.361367] mvneta d0030000.ethernet eth0: configuring for phy/rgmii-id link mode
[   27.370293] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   27.391860] br-family: port 1(eth0.30) entered blocking state
[   27.397595] br-family: port 1(eth0.30) entered disabled state
[   27.403866] device eth0.30 entered promiscuous mode
[   27.408953] device eth0 entered promiscuous mode
[   27.417837] IPv6: ADDRCONF(NETDEV_UP): br-family: link is not ready
[   27.465639] br-gast: port 1(eth0.50) entered blocking state
[   27.471437] br-gast: port 1(eth0.50) entered disabled state
[   27.477366] device eth0.50 entered promiscuous mode
[   27.485731] IPv6: ADDRCONF(NETDEV_UP): br-gast: link is not ready
[   27.547580] br-lan: port 1(eth0.20) entered blocking state
[   27.553356] br-lan: port 1(eth0.20) entered disabled state
[   27.573936] device eth0.20 entered promiscuous mode
[   27.580322] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[   30.615016] mvneta d0030000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   30.623273] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   30.644301] br-lan: port 1(eth0.20) entered blocking state
[   30.649829] br-lan: port 1(eth0.20) entered forwarding state
[   30.656026] br-family: port 1(eth0.30) entered blocking state
[   30.661911] br-family: port 1(eth0.30) entered forwarding state
[   30.668216] br-gast: port 1(eth0.50) entered blocking state
[   30.673742] br-gast: port 1(eth0.50) entered forwarding state
[   30.724167] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[   30.730939] IPv6: ADDRCONF(NETDEV_CHANGE): br-family: link becomes ready
[   30.738143] IPv6: ADDRCONF(NETDEV_CHANGE): br-gast: link becomes ready
A rollback to 5.3.3 brings again back my Wi-Fi…
Does anyone else discover the same problem running a WLE1216v5-20?
Thanks for report. We do have a few samples of WLE1216v5 and we will try to reproduce it.
Upgraded from 5.3.4. So far everything works just fine.
Today 2nd day in a row since with this update wfh laptop connected to guest wifi(2.4) intermittently ending up with dns resolution error. When this happens evidently still connected to the wifi (signal strength -39dBm) but no internet no ping.
Only workaround is to disconnect/reconnect to the wifi.
Seems only guest network or maybe just this laptop affected, no such issue from other subnets(wifi or wired).
Device is TO2020 and my main router since 1year, never had such problem before.
This is what I found in logs if related(there is nothing else unusual in log):
Feb 11 12:53:27 turris hostapd: guest_turris_1: STA xx:xx:xx:xx:xx:xx IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Edit: Not sure but there is a mobile(android) also connected to this guest wifi but apparently not affected.
Hello, I am not sure if the issue is related to the update, however this morning there was not a wifi network available (using mox). After restart all works well again.
I have checked the log in the evening to see if there is more info available. There are plenty of “Unknown TLDS frame type” entries. Any idea what this is ?
Thanks
Feb 12 21:15:16 turris kernel: [49200.954466] mwifiex_sdio mmc0:0001:1: Unknown TDLS frame type.
Feb 12 21:15:18 turris kernel: [49203.016026] mwifiex_sdio mmc0:0001:1: Unknown TDLS frame type.
Feb 12 21:15:20 turris kernel: [49205.068971] mwifiex_sdio mmc0:0001:1: Unknown TDLS frame type.
I just wanna say, d*** the Turris Omnia is just awesome. It saved my a** so many times (configured something wrong), rollback…
Btw, was not aware of a cronjob creating a automatic rollback (awesomely done Turris team!!).
Update to above:
Still suffering from same problem since with this update.
I was told to remove saved wifi network from that windows host and add again, but it ended up with same problem after few days.
Then I was told to do network-reset on that window host, unfortunately after 2days ended up with same problem.
I m highly suspecting it is related to this 5.3.5 release, because the problem started immediately right after with this update. That laptop connected to TO for about 1 year wo problems.
What can I check? Any help is appreciated.
This topic was automatically closed after 20 days. New replies are no longer allowed.
