I will just add my reference to this - It was fixed, and it will be included in Turris OS 5.2.1 RC2.
We would be glad to look at your issue, man. But in your comment, nothing indicates what could be wrong and how you have it configured. In this case, please, reach our support department and they will take care of you!
Bit strange, some hours after i posted this, the omnia rebooted out of itself and its fixed now.
It would be fine, in future releases, to add more info on the main tab in reForis.
Something like basic data counter (download/upload), AdBlock status, etc.
And when there will be Pakon accessible via reForis?
This worked - update installedā¦ however!..
My wireless radios seem to have swapped over, what was Radio0 is now showing as Radio1
so 0 = bg and 1 = bgn.
Problem is, my Radio0 was my N access point!
I seem to recall this happened a long time ago and I needed to swap the references to what was Radio0 and Radio1 but I canāt quite remember which config file that was in?
EDIT: I suspect it has something to do with being on a mSATA drive and I think I had to do this originallyā¦ Info: Small thing to do after adding mSata SSD
Resolved by adding in Paths to the wifi device configs - not sure where they had gone! It was all working before the 5.2 update.
Attempting to install the Pakon package in reForis
June 3, 2021 7:21 PM Updater failed: runtime: [string "requests"]:430: [string "utils"]:420: Getting URI (https://repo.turris.cz/hbs/omnia/lists/pkglists/net_monitoring.lua) failed: Couldn't resolve host 'repo.turris.cz'
and
After installing the Statistics package in reForis, manually install the missing component via Software?
Installing luci-app-statistics (git-21.132.36199-d0cf6e4-1) to root...
Downloading https://repo.turris.cz/hbs/omnia/packages/luci/luci-app-statistics_git-21.132.36199-d0cf6e4-1_all.ipk Installing collectd-mod-iwinfo (5.12.0-1) to root...
Downloading https://repo.turris.cz/hbs/omnia/packages/packages/collectd-mod-iwinfo_5.12.0-1_arm_cortex-a9_vfpv3-d16.ipk
Configuring collectd-mod-iwinfo. Configuring luci-app-statistics.
##### Errors
uci: Entry not found uci: Parse error (invalid command) at line 1, byte 0 Collected errors: * resolve_conffiles:
Existing conffile /etc/config/luci_statistics is different from the conffile in the new package.
The new conffile will be placed at /etc/config/luci_statistics-opkg.
and in syslog
Jun 3 19:06:06 turris foris-controller[20200]: WARNING:foris_controller_backends.collectd:Socket error occured '[Errno 2] No such file or directory'
Jun 3 19:06:08 turris foris-controller[20200]: WARNING:foris_controller_backends.collectd:Socket error occured '[Errno 2] No such file or directory'
Installation and required reboot of packages is in progress (more than a day): from - to
Installed version 4.14.232-1-67f70e2f39f8e8859c56d42cced0b0b3 of package kmod-ledtrig-oneshot
Installed version 4.14.232-1-67f70e2f39f8e8859c56d42cced0b0b3 of package kmod-libphy
Installed version 4.14.232-1-67f70e2f39f8e8859c56d42cced0b0b3 of package kmod-swconfig
Installed version 4.14.232-1-67f70e2f39f8e8859c56d42cced0b0b3 of package kmod-switch-mvsw61xx
Installed version 4.14.232-1-67f70e2f39f8e8859c56d42cced0b0b3 of package kmod-ikconfig
x
x
x
x
Installed version 4.14.232-1-67f70e2f39f8e8859c56d42cced0b0b3 of package kmod-nf-conntrack-netlink
Installed version 4.14.232-1-67f70e2f39f8e8859c56d42cced0b0b3 of package kmod-ipt-ipset
Installed version 4.14.232-1-67f70e2f39f8e8859c56d42cced0b0b3 of package kmod-nf-ipt6
Installed version 4.14.232-1-67f70e2f39f8e8859c56d42cced0b0b3 of package kmod-nf-reject6
Installed version 4.14.232-1-67f70e2f39f8e8859c56d42cced0b0b3 of package kmod-ip6tables
Installed version 4.14.232-1-67f70e2f39f8e8859c56d42cced0b0b3 of package kmod-ebtables
After update and before reboot, my main wifi got lost and only the guest wifi stayed on. Wired/VPN worked all the time. Not sure if it is somehow related to having an mSATA driveā¦
Some wifi-related logs from when it happened:
Summary
01:34:37 warning kernel[]: [3548760.567834] ath10k_pci 0000:02:00.0: No VIF found for vdev 1
01:34:37 warning kernel[]: [3548760.573694] ath10k_pci 0000:02:00.0: wmi-event-beacon-tx, could not find vdev for id: 1
01:34:47 err hostapd[]: Failed to set beacon parameters
01:34:52 err hostapd[11797]: Last message 'Failed to set beacon' repeated 3 times, suppressed by syslog-ng on turris
01:34:53 err hostapd[]: Failed to set beacon parameters
01:34:54 err hostapd[11797]: Last message 'Failed to set beacon' repeated 1 times, suppressed by syslog-ng on turris
01:34:54 info kernel[]: [3548776.984043] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
01:34:54 notice hostapd[]: wlan1: INTERFACE-ENABLED
01:34:54 err hostapd[]: Failed to set beacon parameters
01:34:54 notice hostapd[]: handle_probe_req: send failed
01:34:54 notice hostapd[11797]: Last message 'handle_probe_req: se' repeated 2 times, suppressed by syslog-ng on turris
01:34:54 err hostapd[]: Configuration file: /var/run/hostapd-phy1.conf
01:34:54 notice hostapd[]: wlan1: INTERFACE-DISABLED
01:34:54 err hostapd[]: Configuration file: /var/run/hostapd-phy0.conf
01:34:55 warning kernel[]: [3548778.232532] ath10k_pci 0000:02:00.0: 10.1 wmi init: vdevs: 16 peers: 127 tid: 256
01:34:55 info kernel[]: [3548778.249924] ath10k_pci 0000:02:00.0: wmi print 'P 128 V 8 T 410'
01:34:55 info kernel[]: [3548778.256207] ath10k_pci 0000:02:00.0: wmi print 'msdu-desc: 1424 sw-crypt: 0 ct-sta: 0'
01:34:55 info kernel[]: [3548778.264444] ath10k_pci 0000:02:00.0: wmi print 'alloc rem: 21000 iram: 25960'
01:34:55 warning kernel[]: [3548778.338574] ath10k_pci 0000:02:00.0: pdev param 0 not supported by firmware
01:34:55 info kernel[]: [3548778.353616] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
01:34:55 notice hostapd[]: wlan0: INTERFACE-ENABLED
01:34:55 err hostapd[]: nl80211: Could not configure driver mode
01:34:55 notice hostapd[]: nl80211: deinit ifname=wlan1 disabled_11b_rates=0
01:34:55 err hostapd[]: nl80211 driver initialization failed.
01:34:55 notice hostapd[]: wlan1: interface state UNINITIALIZED->DISABLED
01:34:55 notice hostapd[]: guest_turris_1: AP-DISABLED
01:34:55 notice hostapd[]: guest_turris_1: CTRL-EVENT-TERMINATING
01:34:55 err hostapd[]: hostapd_free_hapd_data: Interface guest_turris_1 wasn't started
01:34:55 notice hostapd[]: wlan1: AP-DISABLED
01:34:55 notice hostapd[]: wlan1: CTRL-EVENT-TERMINATING
01:34:55 err hostapd[]: hostapd_free_hapd_data: Interface wlan1 wasn't started
01:34:55 err hostapd[]: Failed to set beacon parameters
01:34:55 notice hostapd[]: wlan0: INTERFACE-DISABLED
01:34:55 err hostapd[11797]: Last message 'Failed to set beacon' repeated 1 times, suppressed by syslog-ng on turris
01:34:55 notice hostapd[]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
01:34:55 notice hostapd[]: wlan0: interface state UNINITIALIZED->DISABLED
01:34:55 notice hostapd[]: guest_turris_0: AP-DISABLED
01:34:55 notice hostapd[]: guest_turris_0: CTRL-EVENT-TERMINATING
01:34:55 err hostapd[]: hostapd_free_hapd_data: Interface guest_turris_0 wasn't started
01:34:55 notice hostapd[]: wlan0: AP-DISABLED
01:34:55 notice hostapd[]: wlan0: CTRL-EVENT-TERMINATING
01:34:55 err hostapd[]: hostapd_free_hapd_data: Interface wlan0 wasn't started
01:34:55 notice netifd[]: radio0 (9877): WARNING (wireless_add_process): executable path /usr/sbin/wpad does not match process 13541 path (/proc/13541/exe)
01:34:55 notice netifd[]: radio1 (9881): WARNING (wireless_add_process): executable path /usr/sbin/wpad does not match process 6589 path (/proc/6589/exe)
01:34:55 notice netifd[]: radio0 (9877): Device setup failed: HOSTAPD_START_FAILED
01:34:55 notice netifd[]: radio1 (9881): Device setup failed: HOSTAPD_START_FAILED
And the syslog update issue was not resolved (I had to add source net
manually even on this router).
This topic was automatically closed after 20 days. New replies are no longer allowed.
