Dear Turris community,
We released Turris 5.2.7 from the testing branch to all of you. We contributed the changes to upstream, in this case, OpenWrt and kernel as usual.
Security and bugfixes highlights in this release:
What is updated? | Feed | Why | Status * |
Kernel | base | bugfixes, etc. | ![]() |
mac80211 | base | CVE-2020-3702 |
Pending - backported ![]() |
Bind | packages | CVE-2021-25218 |
Upstreamed ![]() |
Git | packages | CVE-2021-21300 |
Upstreamed ![]() |
tor | packages | multiple CVEs |
irssi | packages | memory leaks |
Cherry-picked ![]() |
Python | packages | security release |
Upstreamed ![]() |
HAProxy | packages | CVE-2021-40346 | ![]() |
LXC | TOSp | re-add systemd workaround |
Fixed ![]() |
if there isn’t anything mentioned in status, it means that it was done by OpenWrt community and developers.
When this update will be downloaded and applied?
- If you are using automatic updates, then ASAP. We suggest updating from previous release (Turris OS 5.2.6).
This release is for Turris 1.x, Turris Omnia, Turris MOX and Turris Shield devices. - If you are not using automatic updates, then check reForis to approve the update to be safe.
I found some bug, what should I do?
- Reach our Technical support department and they will gladly help you.
If you have some technical background, take a look at this article in our documentation .
As always, we appreciate any feedback regarding this release.
