After two days in the testing branch, we released Turris OS 5.2.3 to all of you!
In this release, we prepared a few things like:
New version of Updater
This includes a more technical point of view why some messages why download was not successful.
Related fixes to install Nextcloud
Since now, you will be able to install and configure additional applications from Store.
Updated Knot Resolver and Unbound to improve scheduling priority.
Updated nano to version 5.8
The router will download and apply this update automatically if you havenât changed the default configuration. If you do, you should check the Updates tab in reForis to proceed with this update.
Installed but with error notification:
Updater failed: [string âtransactionâ]:327: [string âutilsâ]:151: Failed to stat â//srv/www/nextcloud/ocsâ: I/O error
After re-execution of the updater: âFixed Nextcloud installation in Web UI. Fixed AppStore in Nextcloudâ
But still not able to open Nexcloud: â404 Not Foundâ.
Thanks, the update itself went fine. I had some issues with DDNS after the reboot, but I am not 100% certain these were caused by the update; restarting the DDNS service (by clicking the âPIDâŚâ button in the LuCI DDNS management page resulted in working DDNS again.
Hi, many thanks for the update. For some reasons I just lost my luci All I get on main gui page is file called: download (doesnât matter if http or https).
EDIT: I will move this to a separate topic. Probably this is not a good place for asking .
EDIT2: This problem has been moved to a separate topic Luci offers only a 'download' file
This is something wrong with the device, which is mounted on /srv. There can be several reasons why it happened - the disk is full or the file system is read-only, etc. It would be best if you reached our technical support department, and they will help you with this issue.
Yes, because we manage the Nextcloud version, and it is updated only in minor versions like Turris OS 5.2 and Turris OS 5.3. Otherwise, the update will take a long time in fixup releases, which I do not favor doing that. While I was testing it, the Nextcloud update took almost ~30 minutes, but this varies a lot on the external device you use for Nextcloud.
In the future, we want to provide Turris users only install script for Nextcloud, and then they can manage it themself when they want. This will avoid situations when users updated it to the latest version, and we updated it to a newer version, which caused the downgrade (e.g., from 20 to 19), which is not good.
however the bug with the following error-message is back:
Error notifications
Updater failed:
runtime: [string "requests"]:430: [string "utils"]:422: Unable to finish URI (https://repo.turris.cz/hbs/mox/lists/base.lua): Download failed: Couldn't resolve host 'repo.turris.cz'
I will report this also in the corresponding gitlab-thread.
I must have something to do with this update as my TO 1GB is still on an older version and doesnât show this behaviour.
Edit: I had a wrong forwarding IP for DNS configured in /etc/config/network
Hi together,
just did the upgrade from 5.1.9 to 5.2.3 and it worked smoothly but i actually found out a bit later that 6 of my 18 DHCP static lease got lost after update. I had to add them again and of course restart the clients to get the new leases applied
Is that known?
