Use latest medkit + switch-branch hbt
Thanks for this release!
Issues:
- pkgupdate was stuck at ddns-scripts postinstall. I fixed it by removing luci-app-ddns and ddns-scripts temporarily (I think this is a known bug as it occured in TOS 3.X some time ago, too).
- Wrong kmod-ath10k got installed (I changed ath10k firmware to ath10k-firmware-qca988x-ct-htt), fixed by running
opkg remove kmod-ath10k && opkg install kmod-ath10k-ct
12 posts were split to a new topic: Adblock troubleshooting
@pepe Thank you for the release of Turris OS 5.0.
Iām still getting this error, even after uninstalling acme and all dependent packages. Any idea what could be going on here?
Thanks for the all the effort put into this upgrade. Iād like to ask a question before applying it, though. Thereās something in the release notes that worries me slightly:
- Removed sysupgrade from the system as it is dangerous.
I have backup scripts that heavily rely on sysupgrade
to dump the configuration of the router when I change things. I have to confess that I donāt use Foris much and that all the configuration changes to the device I perform are either via Luci or the console (uci
) so sysupgrade -b
is basically everything I need to backup the configuration to external storage. No having it is⦠a problem.
Iād like to know if itād be possible to get it back by installing it manually after the upgrade. Querying with Opkg on 4.0.5 it seems that itās shipped via base-files
so the chances that I cannot have it installed on 5.0 are quite high I imagine. Was it actually wiped from base-files
Could anybody please shred some light on this? Thanks!
This is bad. IMO if you wanted to protect users the script should have been moved away from the $PATH instead of wiping it out, perhaps? Any chance you could bring it back in 5.0.1 in a different location in the filesystem not in the $PATH?
You could use schnapps export
as an alternative, it creates a tar.gz file of your current root filesystem (or defined schnapps snapshots) that you can browse manually or even import to rollback:
schnapps import <file.tar.gz>
schnapps rollback <snapshot id shown by command above>
reboot
Thanks. Iāll use maintain-config-backup | base64 -d > $something.tar.bz2
in the meantime.
2 posts were split to a new topic: Netdata can not open file shm in proc
Yup, exactly the same thing. Wi-Fi broken, reboot fixed it. No wget on the system after rebooting so opkg is broken basically.
Collected errors:
* opkg_download: Failed to download https://repo.turris.cz/hbs/omnia/packages/core/Packages.gz, wget returned 255.
* opkg_download: Failed to download https://repo.turris.cz/hbs/omnia/packages/base/Packages.gz, wget returned 255.
* opkg_download: Failed to download https://repo.turris.cz/hbs/omnia/packages/cesnet/Packages.gz, wget returned 255.
* opkg_download: Failed to download https://repo.turris.cz/hbs/omnia/packages/luci/Packages.gz, wget returned 255.
* opkg_download: Failed to download https://repo.turris.cz/hbs/omnia/packages/node/Packages.gz, wget returned 255.
* opkg_download: Failed to download https://repo.turris.cz/hbs/omnia/packages/openwisp/Packages.gz, wget returned 255.
* opkg_download: Failed to download https://repo.turris.cz/hbs/omnia/packages/packages/Packages.gz, wget returned 255.
* opkg_download: Failed to download https://repo.turris.cz/hbs/omnia/packages/routing/Packages.gz, wget returned 255.
* opkg_download: Failed to download https://repo.turris.cz/hbs/omnia/packages/sidn/Packages.gz, wget returned 255.
* opkg_download: Failed to download https://repo.turris.cz/hbs/omnia/packages/telephony/Packages.gz, wget returned 255.
* opkg_download: Failed to download https://repo.turris.cz/hbs/omnia/packages/turrispackages/Packages.gz, wget returned 255.
root@turry:
~ # opkg install wget
Package vim-fuller version 8.0.586-2.37 has no valid architecture, ignoring.
Package vim version 8.0.586-2.18 has no valid architecture, ignoring.
Unknown package 'wget'.
Collected errors:
* opkg_install_cmd: Cannot install package wget.
root@turry:
I had to download the package by hand, scp and install it.
opkg does not require wget but leverages client-fetch instead.
opkg install gnu-wget
may work instead, see [wget] installation fails silently - clash of gnu-wget vs. wget (#599) Ā· Issues Ā· Turris / Turris OS / Turris OS packages Ā· GitLab
Thanks for the pointer! My point was though that the system was left in a bad state, IMO. I wouldnāt have expected to have a non-working opkg
to be honest
uclient-fetch
was installed on the system and opkg
was still trying to use wget
Sounds a like a leftover symlink depending on how you arrived at TOS5.x, though not sure how that might have happened or that it should have happened at all.
