I do not understand what you are asking here, twitter style? - my statement was correct.
The Information status was showing 828,107 domains in the block list but if I go to any of the sites I usually use it is not blocking anything and in the DNS report it was only showing 37 blocks out of 6000 requests so from that, to me, it appears to be working but not blocking what I have become accustomed to with Pihole.
I’ve searched the forum and there isn’t any suitable/reliable setup information for how to get this working relative to TOS5 (or one I could use from a lower revision of TOS) - if you know of one, it would be great to know.
My DNS was previously dnsmasq before I switched to pihole which I think might have been as long ago as 2017!
If I set the DNS to kresd now on adblock it shows an error, if I set it to dnsmasq or unbound I do not get an error the DNS report shows requests but still nothing blocked. If I go to known websites with ad issues I still get the ads.
What I did notice with dnsmasq is the following appears in the logs “dns backend not found, please set ‘adb_dns’ manually”
Jun 14 10:06:36 TurrisOmnia adblock-4.0.5[7327]: f_report ::: action: report, report: 1, search: +, count: 50, process: false, print: json, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: @wan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid:
Jun 14 10:06:39 TurrisOmnia adblock-4.0.5[7395]: f_report ::: action: report, report: 1, search: +, count: 50, process: true, print: json, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: @wan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid:
Jun 14 10:06:41 TurrisOmnia adblock-4.0.5[7470]: f_report ::: action: report, report: 1, search: +, count: 50, process: false, print: json, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: @wan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid:
Jun 14 10:07:05 TurrisOmnia adblock-4.0.5[7740]: f_dns ::: dns: dnsmasq, dns_dir: /tmp/dnsmasq.d, dns_file: adb_list.overall, dns_user: dnsmasq, dns_inotify: 0, dns_instance: 0, backup: 1, backup_dir: /tmp, jail_dir: /tmp
Jun 14 10:07:05 TurrisOmnia adblock-4.0.5[7740]: f_fetch ::: fetch_util: /usr/bin/curl, fetch_parm: --connect-timeout 20 --silent --show-error --location -o
Jun 14 10:07:05 TurrisOmnia adblock-4.0.5[7740]: f_bgserv ::: status: stop, bg_pid: -, dns_filereset: 0, ubus_service: /etc/adblock/adblock.monitor
Jun 14 10:07:05 TurrisOmnia adblock-4.0.5[7740]: f_uci ::: config: adblock, change: adblock.global.adb_repiface=‘br-lan’
Jun 14 10:07:05 TurrisOmnia adblock-4.0.5[7740]: f_report ::: action: reload, report: 1, search: +, count: 50, process: false, print: false, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: br-lan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid: 7809
Jun 14 10:07:06 TurrisOmnia adblock-4.0.5[7740]: adblock instance started ::: action: reload, priority: 0, pid: 7740
Jun 14 10:07:06 TurrisOmnia adblock-4.0.5[7740]: f_jsnup ::: status: running, cnt: 771553, mail: 0, mail_service: /etc/adblock/adblock.mail, mail_cnt: 0, mail_pid: -
Jun 14 10:07:06 TurrisOmnia adblock-4.0.5[7740]: f_uci ::: config: dhcp, change:
Jun 14 10:07:06 TurrisOmnia adblock-4.0.5[7740]: f_uci ::: config: firewall, change:
Jun 14 10:07:06 TurrisOmnia adblock-4.0.5[7740]: f_temp ::: tmp_base: /tmp, tmp_dir: /tmp/tmp.NpNkoc, cores: 2, sort_options: --temporary-directory=/tmp/tmp.NpNkoc --compress-program=gzip --batch-size=32 --parallel=2, pid_file: /var/run/adblock.pid
Jun 14 10:07:12 TurrisOmnia adblock-4.0.5[7740]: f_dnsup ::: lookup_util: /bin/nslookup, lookup_domain: example.com, restart_rc: 0, dns_timeout: 20, dns_cnt: 0, in_rc: 0, out_rc: 0
Jun 14 10:07:12 TurrisOmnia adblock-4.0.5[7740]: f_main ::: memory: 2067/410/1553, max_queue: 4, safe_search: 0, force_dns: 1, awk: /bin/awk
Jun 14 10:07:12 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: whitelist, mode: whitelist, cnt: 0, in_rc: 0, out_rc: 0
Jun 14 10:07:12 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: blacklist, mode: blacklist, cnt: 0, in_rc: 0, out_rc: 0
Jun 14 10:07:15 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: adaway, mode: download, cnt: 12092, in_rc: 0, out_rc: 0
Jun 14 10:07:15 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: adaway, mode: backup, cnt: 12092, in_rc: 0, out_rc: 0
Jun 14 10:07:20 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: adguard, mode: download, cnt: 36180, in_rc: 0, out_rc: 0
Jun 14 10:07:20 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: adguard, mode: backup, cnt: 36180, in_rc: 0, out_rc: 0
Jun 14 10:07:23 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: andryou, mode: download, cnt: 50461, in_rc: 0, out_rc: 0
Jun 14 10:07:23 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: anudeep, mode: download, cnt: 42518, in_rc: 0, out_rc: 0
Jun 14 10:07:23 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: andryou, mode: backup, cnt: 50461, in_rc: 0, out_rc: 0
Jun 14 10:07:23 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: anudeep, mode: backup, cnt: 42518, in_rc: 0, out_rc: 0
Jun 14 10:07:23 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: bitcoin, mode: download, cnt: 688, in_rc: 0, out_rc: 0
Jun 14 10:07:23 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: bitcoin, mode: backup, cnt: 688, in_rc: 0, out_rc: 0
Jun 14 10:07:24 TurrisOmnia adblock-4.0.5[7740]: preparation of ‘dshield’ failed, rc: 0
Jun 14 10:07:24 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: dshield, mode: restore, cnt: 0, in_rc: 0, out_rc: 4
Jun 14 10:07:24 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: disconnect, mode: download, cnt: 2735, in_rc: 0, out_rc: 0
Jun 14 10:07:24 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: disconnect, mode: backup, cnt: 2735, in_rc: 0, out_rc: 0
Jun 14 10:07:45 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: energized_porn, mode: download, cnt: 362391, in_rc: 0, out_rc: 0
Jun 14 10:07:45 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: energized_porn, mode: backup, cnt: 362391, in_rc: 0, out_rc: 0
Jun 14 10:07:46 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: malwarelist, mode: download, cnt: 1104, in_rc: 0, out_rc: 0
Jun 14 10:07:46 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: malwarelist, mode: backup, cnt: 1104, in_rc: 0, out_rc: 0
Jun 14 10:07:53 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: malwaredomains, mode: download, cnt: 26845, in_rc: 0, out_rc: 0
Jun 14 10:07:53 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: malwaredomains, mode: backup, cnt: 26845, in_rc: 0, out_rc: 0
Jun 14 10:08:02 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: notracking, mode: download, cnt: 184148, in_rc: 0, out_rc: 0
Jun 14 10:08:02 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: notracking, mode: backup, cnt: 184148, in_rc: 0, out_rc: 0
Jun 14 10:08:24 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: energized_ultimate, mode: download, cnt: 681861, in_rc: 0, out_rc: 0
Jun 14 10:08:24 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: energized_ultimate, mode: backup, cnt: 681861, in_rc: 0, out_rc: 0
Jun 14 10:08:27 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: spam404, mode: download, cnt: 7064, in_rc: 0, out_rc: 0
Jun 14 10:08:27 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: spam404, mode: backup, cnt: 7064, in_rc: 0, out_rc: 0
Jun 14 10:08:27 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: phishing_army, mode: download, cnt: 13582, in_rc: 0, out_rc: 0
Jun 14 10:08:27 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: phishing_army, mode: backup, cnt: 13582, in_rc: 0, out_rc: 0
Jun 14 10:08:30 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: openphish, mode: download, cnt: 2165, in_rc: 0, out_rc: 0
Jun 14 10:08:30 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: openphish, mode: backup, cnt: 2165, in_rc: 0, out_rc: 0
Jun 14 10:08:31 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: stevenblack, mode: download, cnt: 57449, in_rc: 0, out_rc: 0
Jun 14 10:08:31 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: stevenblack, mode: backup, cnt: 57449, in_rc: 0, out_rc: 0
Jun 14 10:08:35 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: shallalist, mode: download, cnt: 33797, in_rc: 0, out_rc: 0
Jun 14 10:08:35 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: shallalist, mode: backup, cnt: 33797, in_rc: 0, out_rc: 0
Jun 14 10:08:36 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: wally3k, mode: download, cnt: 770, in_rc: 0, out_rc: 0
Jun 14 10:08:36 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: wally3k, mode: backup, cnt: 770, in_rc: 0, out_rc: 0
Jun 14 10:08:38 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: stopforumspam, mode: download, cnt: 13474, in_rc: 0, out_rc: 0
Jun 14 10:08:38 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: stopforumspam, mode: backup, cnt: 13474, in_rc: 0, out_rc: 0
Jun 14 10:08:40 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: whocares, mode: download, cnt: 14429, in_rc: 0, out_rc: 0
Jun 14 10:08:40 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: whocares, mode: backup, cnt: 14429, in_rc: 0, out_rc: 0
Jun 14 10:08:45 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: stevenblack_porn, mode: download, cnt: 83023, in_rc: 0, out_rc: 0
Jun 14 10:08:45 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: stevenblack_porn, mode: backup, cnt: 83023, in_rc: 0, out_rc: 0
Jun 14 10:08:45 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: winspy, mode: download, cnt: 364, in_rc: 0, out_rc: 0
Jun 14 10:08:45 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: winspy, mode: backup, cnt: 364, in_rc: 0, out_rc: 0
Jun 14 10:08:46 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: yoyo, mode: download, cnt: 3376, in_rc: 0, out_rc: 0
Jun 14 10:08:46 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: yoyo, mode: backup, cnt: 3376, in_rc: 0, out_rc: 0
Jun 14 10:08:48 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: winhelp, mode: download, cnt: 10356, in_rc: 0, out_rc: 0
Jun 14 10:08:48 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: winhelp, mode: backup, cnt: 10356, in_rc: 0, out_rc: 0
Jun 14 10:08:49 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: youtube, mode: download, cnt: 24120, in_rc: 0, out_rc: 0
Jun 14 10:08:49 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: youtube, mode: backup, cnt: 24120, in_rc: 0, out_rc: 0
Jun 14 10:08:54 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: -, mode: merge, cnt: 1223431, in_rc: 4, out_rc: 0
Jun 14 10:09:11 TurrisOmnia adblock-4.0.5[7740]: f_tld ::: source: /tmp/tmp.NpNkoc/adb_list.overall, cnt: 1223431, cnt_tld: 773496
Jun 14 10:09:22 TurrisOmnia adblock-4.0.5[7740]: f_list ::: name: -, mode: final, cnt: 773496, in_rc: 4, out_rc: 0
Jun 14 10:09:30 TurrisOmnia adblock-4.0.5[7740]: f_dnsup ::: lookup_util: /bin/nslookup, lookup_domain: example.com, restart_rc: 0, dns_timeout: 20, dns_cnt: 2, in_rc: 0, out_rc: 0
Jun 14 10:09:30 TurrisOmnia adblock-4.0.5[7740]: f_jsnup ::: status: enabled, cnt: 773496, mail: 0, mail_service: /etc/adblock/adblock.mail, mail_cnt: 0, mail_pid: -
Jun 14 10:09:30 TurrisOmnia adblock-4.0.5[7740]: blocklist with overall 773496 blocked domains loaded successfully (Turris Omnia, TurrisOS 5.0.1 e752fc1ff9d1d4f50a32155dd714dcde4b070bd4)
Jun 14 10:09:30 TurrisOmnia adblock-4.0.5[7740]: f_rmtemp ::: tmp_dir: /tmp/tmp.NpNkoc, src_file: /tmp/adb_sources.json, pid_file: /var/run/adblock.pid
Jun 14 10:11:26 TurrisOmnia adblock-4.0.5[10069]: f_report ::: action: report, report: 1, search: +, count: 50, process: false, print: json, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: br-lan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid: 7809
Jun 14 10:11:30 TurrisOmnia adblock-4.0.5[10136]: f_report ::: action: report, report: 1, search: +, count: 50, process: true, print: json, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: br-lan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid: 7809
Jun 14 10:11:31 TurrisOmnia adblock-4.0.5[10237]: f_report ::: action: report, report: 1, search: +, count: 50, process: false, print: json, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: br-lan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid: 7809
Jun 14 10:12:39 TurrisOmnia adblock-4.0.5[10605]: f_dns ::: dns: dnsmasq, dns_dir: /tmp/dnsmasq.d, dns_file: adb_list.overall, dns_user: dnsmasq, dns_inotify: 0, dns_instance: 0, backup: 1, backup_dir: /tmp, jail_dir: /tmp
Jun 14 10:12:39 TurrisOmnia adblock-4.0.5[10605]: f_fetch ::: fetch_util: /usr/bin/curl, fetch_parm: --connect-timeout 20 --silent --show-error --location -o
Jun 14 10:12:39 TurrisOmnia adblock-4.0.5[10605]: f_bgserv ::: status: stop, bg_pid: -, dns_filereset: 0, ubus_service: /etc/adblock/adblock.monitor
Jun 14 10:12:39 TurrisOmnia adblock-4.0.5[10605]: f_report ::: action: reload, report: 1, search: +, count: 50, process: false, print: false, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: br-lan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid: 7809
Jun 14 10:12:39 TurrisOmnia adblock-4.0.5[10605]: adblock instance started ::: action: reload, priority: 0, pid: 10605
Jun 14 10:12:39 TurrisOmnia adblock-4.0.5[10605]: f_jsnup ::: status: running, cnt: 773496, mail: 0, mail_service: /etc/adblock/adblock.mail, mail_cnt: 0, mail_pid: -
Jun 14 10:12:39 TurrisOmnia adblock-4.0.5[10605]: f_uci ::: config: dhcp, change:
Jun 14 10:12:39 TurrisOmnia adblock-4.0.5[10605]: f_uci ::: config: firewall, change:
Jun 14 10:12:39 TurrisOmnia adblock-4.0.5[10605]: f_temp ::: tmp_base: /tmp, tmp_dir: /tmp/tmp.LOinGi, cores: 2, sort_options: --temporary-directory=/tmp/tmp.LOinGi --compress-program=gzip --batch-size=32 --parallel=2, pid_file: /var/run/adblock.pid
Jun 14 10:12:46 TurrisOmnia adblock-4.0.5[10605]: f_dnsup ::: lookup_util: /bin/nslookup, lookup_domain: example.com, restart_rc: 0, dns_timeout: 20, dns_cnt: 0, in_rc: 0, out_rc: 0
Jun 14 10:12:46 TurrisOmnia adblock-4.0.5[10605]: f_main ::: memory: 2067/408/1551, max_queue: 4, safe_search: 0, force_dns: 1, awk: /bin/awk
Jun 14 10:12:46 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: whitelist, mode: whitelist, cnt: 0, in_rc: 0, out_rc: 0
Jun 14 10:12:46 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: blacklist, mode: blacklist, cnt: 0, in_rc: 0, out_rc: 0
Jun 14 10:12:51 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: adaway, mode: download, cnt: 12092, in_rc: 0, out_rc: 0
Jun 14 10:12:51 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: adaway, mode: backup, cnt: 12092, in_rc: 0, out_rc: 0
Jun 14 10:12:54 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: anudeep, mode: download, cnt: 42518, in_rc: 0, out_rc: 0
Jun 14 10:12:54 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: anudeep, mode: backup, cnt: 42518, in_rc: 0, out_rc: 0
Jun 14 10:12:55 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: adguard, mode: download, cnt: 36180, in_rc: 0, out_rc: 0
Jun 14 10:12:55 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: adguard, mode: backup, cnt: 36180, in_rc: 0, out_rc: 0
Jun 14 10:12:56 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: andryou, mode: download, cnt: 50461, in_rc: 0, out_rc: 0
Jun 14 10:12:56 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: andryou, mode: backup, cnt: 50461, in_rc: 0, out_rc: 0
Jun 14 10:12:57 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: bitcoin, mode: download, cnt: 688, in_rc: 0, out_rc: 0
Jun 14 10:12:57 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: bitcoin, mode: backup, cnt: 688, in_rc: 0, out_rc: 0
Jun 14 10:12:57 TurrisOmnia adblock-4.0.5[10605]: preparation of ‘dshield’ failed, rc: 0
Jun 14 10:12:57 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: dshield, mode: restore, cnt: 0, in_rc: 0, out_rc: 4
Jun 14 10:12:57 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: disconnect, mode: download, cnt: 2735, in_rc: 0, out_rc: 0
Jun 14 10:12:57 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: disconnect, mode: backup, cnt: 2735, in_rc: 0, out_rc: 0
Jun 14 10:13:22 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: energized_porn, mode: download, cnt: 362391, in_rc: 0, out_rc: 0
Jun 14 10:13:22 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: energized_porn, mode: backup, cnt: 362391, in_rc: 0, out_rc: 0
Jun 14 10:13:23 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: malwarelist, mode: download, cnt: 1104, in_rc: 0, out_rc: 0
Jun 14 10:13:23 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: malwarelist, mode: backup, cnt: 1104, in_rc: 0, out_rc: 0
Jun 14 10:13:28 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: malwaredomains, mode: download, cnt: 26845, in_rc: 0, out_rc: 0
Jun 14 10:13:28 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: malwaredomains, mode: backup, cnt: 26845, in_rc: 0, out_rc: 0
Jun 14 10:13:40 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: notracking, mode: download, cnt: 184148, in_rc: 0, out_rc: 0
Jun 14 10:13:41 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: notracking, mode: backup, cnt: 184148, in_rc: 0, out_rc: 0
Jun 14 10:14:01 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: energized_ultimate, mode: download, cnt: 681861, in_rc: 0, out_rc: 0
Jun 14 10:14:01 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: energized_ultimate, mode: backup, cnt: 681861, in_rc: 0, out_rc: 0
Jun 14 10:14:02 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: spam404, mode: download, cnt: 7064, in_rc: 0, out_rc: 0
Jun 14 10:14:02 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: spam404, mode: backup, cnt: 7064, in_rc: 0, out_rc: 0
Jun 14 10:14:05 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: phishing_army, mode: download, cnt: 13582, in_rc: 0, out_rc: 0
Jun 14 10:14:05 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: phishing_army, mode: backup, cnt: 13582, in_rc: 0, out_rc: 0
Jun 14 10:14:07 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: openphish, mode: download, cnt: 2165, in_rc: 0, out_rc: 0
Jun 14 10:14:07 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: openphish, mode: backup, cnt: 2165, in_rc: 0, out_rc: 0
Jun 14 10:14:08 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: stevenblack, mode: download, cnt: 57449, in_rc: 0, out_rc: 0
Jun 14 10:14:08 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: stevenblack, mode: backup, cnt: 57449, in_rc: 0, out_rc: 0
Jun 14 10:14:12 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: shallalist, mode: download, cnt: 33797, in_rc: 0, out_rc: 0
Jun 14 10:14:12 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: shallalist, mode: backup, cnt: 33797, in_rc: 0, out_rc: 0
Jun 14 10:14:13 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: wally3k, mode: download, cnt: 770, in_rc: 0, out_rc: 0
Jun 14 10:14:13 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: wally3k, mode: backup, cnt: 770, in_rc: 0, out_rc: 0
Jun 14 10:14:17 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: stopforumspam, mode: download, cnt: 13474, in_rc: 0, out_rc: 0
Jun 14 10:14:17 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: stopforumspam, mode: backup, cnt: 13474, in_rc: 0, out_rc: 0
Jun 14 10:14:17 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: sysctl, mode: download, cnt: 20567, in_rc: 0, out_rc: 0
Jun 14 10:14:17 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: sysctl, mode: backup, cnt: 20567, in_rc: 0, out_rc: 0
Jun 14 10:14:28 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: stevenblack_porn, mode: download, cnt: 83023, in_rc: 0, out_rc: 0
Jun 14 10:14:28 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: stevenblack_porn, mode: backup, cnt: 83023, in_rc: 0, out_rc: 0
Jun 14 10:14:47 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: utcapitole, mode: download, cnt: 84844, in_rc: 0, out_rc: 0
Jun 14 10:14:48 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: utcapitole, mode: backup, cnt: 84844, in_rc: 0, out_rc: 0
Jun 14 10:16:11 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: utcapitole_porn, mode: download, cnt: 2247434, in_rc: 0, out_rc: 0
Jun 14 10:16:12 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: utcapitole_porn, mode: backup, cnt: 2247434, in_rc: 0, out_rc: 0
Jun 14 10:16:12 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: winspy, mode: download, cnt: 364, in_rc: 0, out_rc: 0
Jun 14 10:16:12 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: winspy, mode: backup, cnt: 364, in_rc: 0, out_rc: 0
Jun 14 10:16:16 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: winhelp, mode: download, cnt: 10356, in_rc: 0, out_rc: 0
Jun 14 10:16:16 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: winhelp, mode: backup, cnt: 10356, in_rc: 0, out_rc: 0
Jun 14 10:16:16 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: whocares, mode: download, cnt: 14429, in_rc: 0, out_rc: 0
Jun 14 10:16:16 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: whocares, mode: backup, cnt: 14429, in_rc: 0, out_rc: 0
Jun 14 10:16:17 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: youtube, mode: download, cnt: 24120, in_rc: 0, out_rc: 0
Jun 14 10:16:17 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: youtube, mode: backup, cnt: 24120, in_rc: 0, out_rc: 0
Jun 14 10:16:17 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: yoyo, mode: download, cnt: 3376, in_rc: 0, out_rc: 0
Jun 14 10:16:17 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: yoyo, mode: backup, cnt: 3376, in_rc: 0, out_rc: 0
Jun 14 10:16:29 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: -, mode: merge, cnt: 3233657, in_rc: 4, out_rc: 0
Jun 14 10:17:30 TurrisOmnia adblock-4.0.5[10605]: f_tld ::: source: /tmp/tmp.LOinGi/adb_list.overall, cnt: 3233657, cnt_tld: 1792177
Jun 14 10:17:56 TurrisOmnia adblock-4.0.5[10605]: f_list ::: name: -, mode: final, cnt: 1792177, in_rc: 4, out_rc: 0
Jun 14 10:18:09 TurrisOmnia adblock-4.0.5[10605]: f_dnsup ::: lookup_util: /bin/nslookup, lookup_domain: example.com, restart_rc: 0, dns_timeout: 20, dns_cnt: 6, in_rc: 0, out_rc: 0
Jun 14 10:18:09 TurrisOmnia adblock-4.0.5[10605]: f_jsnup ::: status: enabled, cnt: 1792177, mail: 0, mail_service: /etc/adblock/adblock.mail, mail_cnt: 0, mail_pid: -
Jun 14 10:18:09 TurrisOmnia adblock-4.0.5[10605]: blocklist with overall 1792177 blocked domains loaded successfully (Turris Omnia, TurrisOS 5.0.1 e752fc1ff9d1d4f50a32155dd714dcde4b070bd4)
Jun 14 10:18:09 TurrisOmnia adblock-4.0.5[10605]: f_rmtemp ::: tmp_dir: /tmp/tmp.LOinGi, src_file: /tmp/adb_sources.json, pid_file: /var/run/adblock.pid
Jun 14 10:24:39 TurrisOmnia adblock-4.0.5[13380]: f_report ::: action: report, report: 1, search: +, count: 50, process: false, print: json, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: br-lan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid: 7809
Jun 14 10:24:43 TurrisOmnia adblock-4.0.5[13451]: f_report ::: action: report, report: 1, search: +, count: 50, process: true, print: json, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: br-lan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid: 7809
Jun 14 10:24:45 TurrisOmnia adblock-4.0.5[13555]: f_report ::: action: report, report: 1, search: +, count: 50, process: false, print: json, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: br-lan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid: 7809
Jun 14 10:25:05 TurrisOmnia adblock-4.0.5[13658]: f_report ::: action: report, report: 1, search: +, count: 50, process: true, print: json, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: br-lan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid: 7809
Jun 14 10:25:07 TurrisOmnia adblock-4.0.5[13762]: f_report ::: action: report, report: 1, search: +, count: 50, process: false, print: json, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: br-lan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid: 7809
Jun 14 10:29:53 TurrisOmnia adblock-4.0.5[14009]: f_report ::: action: report, report: 1, search: +, count: 50, process: false, print: json, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: br-lan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid: 7809
Jun 14 10:31:45 TurrisOmnia adblock-4.0.5[14335]: dns backend not found, please set ‘adb_dns’ manually
Jun 14 10:31:45 TurrisOmnia adblock-4.0.5[14335]: f_rmtemp ::: tmp_dir: -, src_file: /tmp/adb_sources.json, pid_file: /var/run/adblock.pid
Jun 14 10:31:45 TurrisOmnia adblock-4.0.5[14335]: f_rmdns ::: dns: , status: true, dns_dir: , dns_file: adb_list.overall, rt_file: /tmp/adb_runtime.json, backup_dir: /tmp
Jun 14 10:31:45 TurrisOmnia adblock-4.0.5[14335]: f_bgserv ::: status: stop, bg_pid: -, dns_filereset: 0, ubus_service: /etc/adblock/adblock.monitor
Jun 14 10:31:46 TurrisOmnia adblock-4.0.5[14335]: f_jsnup ::: status: error, cnt: 0, mail: 0, mail_service: /etc/adblock/adblock.mail, mail_cnt: 0, mail_pid: -
Jun 14 10:32:14 TurrisOmnia adblock-4.0.5[14609]: f_dns ::: dns: dnsmasq, dns_dir: /tmp/dnsmasq.d, dns_file: adb_list.overall, dns_user: dnsmasq, dns_inotify: 0, dns_instance: 0, backup: 1, backup_dir: /tmp, jail_dir: /tmp
Jun 14 10:32:14 TurrisOmnia adblock-4.0.5[14609]: f_fetch ::: fetch_util: /usr/bin/curl, fetch_parm: --connect-timeout 20 --silent --show-error --location -o
Jun 14 10:32:14 TurrisOmnia adblock-4.0.5[14609]: f_bgserv ::: status: stop, bg_pid: -, dns_filereset: 0, ubus_service: /etc/adblock/adblock.monitor
Jun 14 10:32:14 TurrisOmnia adblock-4.0.5[14609]: f_report ::: action: reload, report: 1, search: +, count: 50, process: false, print: false, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: br-lan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid: 7809
Jun 14 10:32:14 TurrisOmnia adblock-4.0.5[14609]: adblock instance started ::: action: reload, priority: 0, pid: 14609
Jun 14 10:32:14 TurrisOmnia adblock-4.0.5[14609]: f_jsnup ::: status: running, cnt: 0, mail: 0, mail_service: /etc/adblock/adblock.mail, mail_cnt: 0, mail_pid: -
Jun 14 10:32:14 TurrisOmnia adblock-4.0.5[14609]: f_uci ::: config: dhcp, change:
Jun 14 10:32:14 TurrisOmnia adblock-4.0.5[14609]: f_uci ::: config: firewall, change:
Jun 14 10:32:14 TurrisOmnia adblock-4.0.5[14609]: f_temp ::: tmp_base: /tmp, tmp_dir: /tmp/tmp.BJFAoa, cores: 2, sort_options: --temporary-directory=/tmp/tmp.BJFAoa --compress-program=gzip --batch-size=32 --parallel=2, pid_file: /var/run/adblock.pid
Jun 14 10:32:21 TurrisOmnia adblock-4.0.5[14609]: f_dnsup ::: lookup_util: /bin/nslookup, lookup_domain: example.com, restart_rc: 0, dns_timeout: 20, dns_cnt: 0, in_rc: 0, out_rc: 0
Jun 14 10:32:21 TurrisOmnia adblock-4.0.5[14609]: f_main ::: memory: 2067/461/1534, max_queue: 4, safe_search: 0, force_dns: 1, awk: /bin/awk
Jun 14 10:32:21 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: whitelist, mode: whitelist, cnt: 0, in_rc: 0, out_rc: 0
Jun 14 10:32:21 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: blacklist, mode: blacklist, cnt: 0, in_rc: 0, out_rc: 0
Jun 14 10:32:26 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: adaway, mode: download, cnt: 12092, in_rc: 0, out_rc: 0
Jun 14 10:32:26 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: adaway, mode: backup, cnt: 12092, in_rc: 0, out_rc: 0
Jun 14 10:32:29 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: adguard, mode: download, cnt: 36180, in_rc: 0, out_rc: 0
Jun 14 10:32:30 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: adguard, mode: backup, cnt: 36180, in_rc: 0, out_rc: 0
Jun 14 10:32:31 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: anudeep, mode: download, cnt: 42518, in_rc: 0, out_rc: 0
Jun 14 10:32:31 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: anudeep, mode: backup, cnt: 42518, in_rc: 0, out_rc: 0
Jun 14 10:32:32 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: andryou, mode: download, cnt: 50461, in_rc: 0, out_rc: 0
Jun 14 10:32:32 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: andryou, mode: backup, cnt: 50461, in_rc: 0, out_rc: 0
Jun 14 10:32:32 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: bitcoin, mode: download, cnt: 688, in_rc: 0, out_rc: 0
Jun 14 10:32:32 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: bitcoin, mode: backup, cnt: 688, in_rc: 0, out_rc: 0
Jun 14 10:32:32 TurrisOmnia adblock-4.0.5[14609]: preparation of ‘dshield’ failed, rc: 0
Jun 14 10:32:33 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: dshield, mode: restore, cnt: 0, in_rc: 0, out_rc: 4
Jun 14 10:32:33 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: disconnect, mode: download, cnt: 2735, in_rc: 0, out_rc: 0
Jun 14 10:32:33 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: disconnect, mode: backup, cnt: 2735, in_rc: 0, out_rc: 0
Jun 14 10:32:48 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: energized_porn, mode: download, cnt: 362391, in_rc: 0, out_rc: 0
Jun 14 10:32:49 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: energized_porn, mode: backup, cnt: 362391, in_rc: 0, out_rc: 0
Jun 14 10:32:50 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: malwarelist, mode: download, cnt: 1104, in_rc: 0, out_rc: 0
Jun 14 10:32:50 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: malwarelist, mode: backup, cnt: 1104, in_rc: 0, out_rc: 0
Jun 14 10:32:56 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: malwaredomains, mode: download, cnt: 26845, in_rc: 0, out_rc: 0
Jun 14 10:32:56 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: malwaredomains, mode: backup, cnt: 26845, in_rc: 0, out_rc: 0
Jun 14 10:33:10 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: notracking, mode: download, cnt: 184148, in_rc: 0, out_rc: 0
Jun 14 10:33:10 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: notracking, mode: backup, cnt: 184148, in_rc: 0, out_rc: 0
Jun 14 10:33:28 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: energized_ultimate, mode: download, cnt: 681861, in_rc: 0, out_rc: 0
Jun 14 10:33:28 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: energized_ultimate, mode: backup, cnt: 681861, in_rc: 0, out_rc: 0
Jun 14 10:33:30 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: spam404, mode: download, cnt: 7064, in_rc: 0, out_rc: 0
Jun 14 10:33:30 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: spam404, mode: backup, cnt: 7064, in_rc: 0, out_rc: 0
Jun 14 10:33:32 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: phishing_army, mode: download, cnt: 13582, in_rc: 0, out_rc: 0
Jun 14 10:33:32 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: phishing_army, mode: backup, cnt: 13582, in_rc: 0, out_rc: 0
Jun 14 10:33:34 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: openphish, mode: download, cnt: 2165, in_rc: 0, out_rc: 0
Jun 14 10:33:34 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: openphish, mode: backup, cnt: 2165, in_rc: 0, out_rc: 0
Jun 14 10:33:35 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: stevenblack, mode: download, cnt: 57449, in_rc: 0, out_rc: 0
Jun 14 10:33:35 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: stevenblack, mode: backup, cnt: 57449, in_rc: 0, out_rc: 0
Jun 14 10:33:38 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: shallalist, mode: download, cnt: 33797, in_rc: 0, out_rc: 0
Jun 14 10:33:38 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: shallalist, mode: backup, cnt: 33797, in_rc: 0, out_rc: 0
Jun 14 10:33:39 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: wally3k, mode: download, cnt: 770, in_rc: 0, out_rc: 0
Jun 14 10:33:39 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: wally3k, mode: backup, cnt: 770, in_rc: 0, out_rc: 0
Jun 14 10:33:43 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: stopforumspam, mode: download, cnt: 13474, in_rc: 0, out_rc: 0
Jun 14 10:33:43 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: stopforumspam, mode: backup, cnt: 13474, in_rc: 0, out_rc: 0
Jun 14 10:33:43 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: sysctl, mode: download, cnt: 20567, in_rc: 0, out_rc: 0
Jun 14 10:33:43 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: sysctl, mode: backup, cnt: 20567, in_rc: 0, out_rc: 0
Jun 14 10:33:51 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: stevenblack_porn, mode: download, cnt: 83023, in_rc: 0, out_rc: 0
Jun 14 10:33:51 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: stevenblack_porn, mode: backup, cnt: 83023, in_rc: 0, out_rc: 0
Jun 14 10:34:12 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: utcapitole, mode: download, cnt: 84844, in_rc: 0, out_rc: 0
Jun 14 10:34:12 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: utcapitole, mode: backup, cnt: 84844, in_rc: 0, out_rc: 0
Jun 14 10:35:39 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: utcapitole_porn, mode: download, cnt: 2247434, in_rc: 0, out_rc: 0
Jun 14 10:35:40 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: utcapitole_porn, mode: backup, cnt: 2247434, in_rc: 0, out_rc: 0
Jun 14 10:35:41 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: winspy, mode: download, cnt: 364, in_rc: 0, out_rc: 0
Jun 14 10:35:41 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: winspy, mode: backup, cnt: 364, in_rc: 0, out_rc: 0
Jun 14 10:35:43 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: winhelp, mode: download, cnt: 10356, in_rc: 0, out_rc: 0
Jun 14 10:35:43 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: winhelp, mode: backup, cnt: 10356, in_rc: 0, out_rc: 0
Jun 14 10:35:44 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: youtube, mode: download, cnt: 24160, in_rc: 0, out_rc: 0
Jun 14 10:35:44 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: youtube, mode: backup, cnt: 24160, in_rc: 0, out_rc: 0
Jun 14 10:35:44 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: whocares, mode: download, cnt: 14429, in_rc: 0, out_rc: 0
Jun 14 10:35:44 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: whocares, mode: backup, cnt: 14429, in_rc: 0, out_rc: 0
Jun 14 10:35:45 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: yoyo, mode: download, cnt: 3376, in_rc: 0, out_rc: 0
Jun 14 10:35:45 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: yoyo, mode: backup, cnt: 3376, in_rc: 0, out_rc: 0
Jun 14 10:35:57 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: -, mode: merge, cnt: 3233697, in_rc: 4, out_rc: 0
Jun 14 10:37:00 TurrisOmnia adblock-4.0.5[14609]: f_tld ::: source: /tmp/tmp.BJFAoa/adb_list.overall, cnt: 3233697, cnt_tld: 1792217
Jun 14 10:37:25 TurrisOmnia adblock-4.0.5[14609]: f_list ::: name: -, mode: final, cnt: 1792217, in_rc: 4, out_rc: 0
Jun 14 10:37:37 TurrisOmnia adblock-4.0.5[14609]: f_dnsup ::: lookup_util: /bin/nslookup, lookup_domain: example.com, restart_rc: 0, dns_timeout: 20, dns_cnt: 5, in_rc: 0, out_rc: 0
Jun 14 10:37:37 TurrisOmnia adblock-4.0.5[14609]: f_jsnup ::: status: enabled, cnt: 1792217, mail: 0, mail_service: /etc/adblock/adblock.mail, mail_cnt: 0, mail_pid: -
Jun 14 10:37:37 TurrisOmnia adblock-4.0.5[14609]: blocklist with overall 1792217 blocked domains loaded successfully (Turris Omnia, TurrisOS 5.0.1 e752fc1ff9d1d4f50a32155dd714dcde4b070bd4)
Jun 14 10:37:37 TurrisOmnia adblock-4.0.5[14609]: f_rmtemp ::: tmp_dir: /tmp/tmp.BJFAoa, src_file: /tmp/adb_sources.json, pid_file: /var/run/adblock.pid
Jun 14 10:38:18 TurrisOmnia adblock-4.0.5[17329]: f_report ::: action: report, report: 1, search: +, count: 50, process: false, print: json, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: br-lan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid: 7809
Jun 14 10:38:22 TurrisOmnia adblock-4.0.5[17400]: f_report ::: action: report, report: 1, search: +, count: 50, process: true, print: json, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: br-lan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid: 7809
Jun 14 10:38:24 TurrisOmnia adblock-4.0.5[17504]: f_report ::: action: report, report: 1, search: +, count: 50, process: false, print: json, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: br-lan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid: 7809
Jun 14 10:47:42 TurrisOmnia adblock-4.0.5[17973]: dns backend directory ‘/var/lib/unbound’ created
Jun 14 10:47:42 TurrisOmnia adblock-4.0.5[17973]: f_dns ::: dns: unbound, dns_dir: /var/lib/unbound, dns_file: adb_list.overall, dns_user: unbound, dns_inotify: 0, dns_instance: 0, backup: 1, backup_dir: /tmp, jail_dir: /tmp
Jun 14 10:47:42 TurrisOmnia adblock-4.0.5[17973]: f_fetch ::: fetch_util: /usr/bin/curl, fetch_parm: --connect-timeout 20 --silent --show-error --location -o
Jun 14 10:47:42 TurrisOmnia adblock-4.0.5[17973]: f_bgserv ::: status: stop, bg_pid: -, dns_filereset: 0, ubus_service: /etc/adblock/adblock.monitor
Jun 14 10:47:42 TurrisOmnia adblock-4.0.5[17973]: f_report ::: action: reload, report: 1, search: +, count: 50, process: false, print: false, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: br-lan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid: 7809
Jun 14 10:47:42 TurrisOmnia adblock-4.0.5[17973]: adblock instance started ::: action: reload, priority: 0, pid: 17973
Jun 14 10:47:42 TurrisOmnia adblock-4.0.5[17973]: f_jsnup ::: status: running, cnt: 1792217, mail: 0, mail_service: /etc/adblock/adblock.mail, mail_cnt: 0, mail_pid: -
Jun 14 10:47:42 TurrisOmnia adblock-4.0.5[17973]: f_uci ::: config: firewall, change:
Jun 14 10:47:42 TurrisOmnia adblock-4.0.5[17973]: f_temp ::: tmp_base: /tmp, tmp_dir: /tmp/tmp.JfmBLG, cores: 2, sort_options: --temporary-directory=/tmp/tmp.JfmBLG --compress-program=gzip --batch-size=32 --parallel=2, pid_file: /var/run/adblock.pid
Jun 14 10:47:42 TurrisOmnia adblock-4.0.5[17973]: f_dnsup ::: lookup_util: /bin/nslookup, lookup_domain: example.com, restart_rc: 0, dns_timeout: 20, dns_cnt: 0, in_rc: 0, out_rc: 0
Jun 14 10:47:42 TurrisOmnia adblock-4.0.5[17973]: f_main ::: memory: 2067/115/1191, max_queue: 4, safe_search: 0, force_dns: 1, awk: /bin/awk
Jun 14 10:47:42 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: whitelist, mode: whitelist, cnt: 0, in_rc: 0, out_rc: 0
Jun 14 10:47:42 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: blacklist, mode: blacklist, cnt: 0, in_rc: 0, out_rc: 0
Jun 14 10:47:46 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: adaway, mode: download, cnt: 12092, in_rc: 0, out_rc: 0
Jun 14 10:47:46 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: adaway, mode: backup, cnt: 12092, in_rc: 0, out_rc: 0
Jun 14 10:47:50 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: adguard, mode: download, cnt: 36180, in_rc: 0, out_rc: 0
Jun 14 10:47:50 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: adguard, mode: backup, cnt: 36180, in_rc: 0, out_rc: 0
Jun 14 10:47:50 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: anudeep, mode: download, cnt: 42518, in_rc: 0, out_rc: 0
Jun 14 10:47:51 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: anudeep, mode: backup, cnt: 42518, in_rc: 0, out_rc: 0
Jun 14 10:47:52 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: andryou, mode: download, cnt: 50461, in_rc: 0, out_rc: 0
Jun 14 10:47:52 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: andryou, mode: backup, cnt: 50461, in_rc: 0, out_rc: 0
Jun 14 10:47:52 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: bitcoin, mode: download, cnt: 688, in_rc: 0, out_rc: 0
Jun 14 10:47:52 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: bitcoin, mode: backup, cnt: 688, in_rc: 0, out_rc: 0
Jun 14 10:47:53 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: disconnect, mode: download, cnt: 2735, in_rc: 0, out_rc: 0
Jun 14 10:47:53 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: disconnect, mode: backup, cnt: 2735, in_rc: 0, out_rc: 0
Jun 14 10:47:57 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: malwaredomains, mode: download, cnt: 26845, in_rc: 0, out_rc: 0
Jun 14 10:47:57 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: malwaredomains, mode: backup, cnt: 26845, in_rc: 0, out_rc: 0
Jun 14 10:48:09 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: energized_porn, mode: download, cnt: 362391, in_rc: 0, out_rc: 0
Jun 14 10:48:09 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: energized_porn, mode: backup, cnt: 362391, in_rc: 0, out_rc: 0
Jun 14 10:48:10 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: malwarelist, mode: download, cnt: 1104, in_rc: 0, out_rc: 0
Jun 14 10:48:10 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: malwarelist, mode: backup, cnt: 1104, in_rc: 0, out_rc: 0
Jun 14 10:48:12 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: phishing_army, mode: download, cnt: 13582, in_rc: 0, out_rc: 0
Jun 14 10:48:12 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: phishing_army, mode: backup, cnt: 13582, in_rc: 0, out_rc: 0
Jun 14 10:48:14 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: openphish, mode: download, cnt: 2165, in_rc: 0, out_rc: 0
Jun 14 10:48:14 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: openphish, mode: backup, cnt: 2165, in_rc: 0, out_rc: 0
Jun 14 10:48:26 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: notracking, mode: download, cnt: 184148, in_rc: 0, out_rc: 0
Jun 14 10:48:26 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: notracking, mode: backup, cnt: 184148, in_rc: 0, out_rc: 0
Jun 14 10:48:28 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: spam404, mode: download, cnt: 7064, in_rc: 0, out_rc: 0
Jun 14 10:48:28 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: spam404, mode: backup, cnt: 7064, in_rc: 0, out_rc: 0
Jun 14 10:48:30 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: stopforumspam, mode: download, cnt: 13474, in_rc: 0, out_rc: 0
Jun 14 10:48:30 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: stopforumspam, mode: backup, cnt: 13474, in_rc: 0, out_rc: 0
Jun 14 10:48:38 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: stevenblack, mode: download, cnt: 57449, in_rc: 0, out_rc: 0
Jun 14 10:48:38 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: stevenblack, mode: backup, cnt: 57449, in_rc: 0, out_rc: 0
Jun 14 10:48:40 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: shallalist, mode: download, cnt: 33797, in_rc: 0, out_rc: 0
Jun 14 10:48:40 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: shallalist, mode: backup, cnt: 33797, in_rc: 0, out_rc: 0
Jun 14 10:48:40 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: stevenblack_porn, mode: download, cnt: 83023, in_rc: 0, out_rc: 0
Jun 14 10:48:40 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: stevenblack_porn, mode: backup, cnt: 83023, in_rc: 0, out_rc: 0
Jun 14 10:48:41 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: wally3k, mode: download, cnt: 770, in_rc: 0, out_rc: 0
Jun 14 10:48:41 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: wally3k, mode: backup, cnt: 770, in_rc: 0, out_rc: 0
Jun 14 10:48:44 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: sysctl, mode: download, cnt: 20567, in_rc: 0, out_rc: 0
Jun 14 10:48:44 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: sysctl, mode: backup, cnt: 20567, in_rc: 0, out_rc: 0
Jun 14 10:48:44 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: whocares, mode: download, cnt: 14429, in_rc: 0, out_rc: 0
Jun 14 10:48:45 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: whocares, mode: backup, cnt: 14429, in_rc: 0, out_rc: 0
Jun 14 10:48:45 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: winhelp, mode: download, cnt: 10356, in_rc: 0, out_rc: 0
Jun 14 10:48:45 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: winhelp, mode: backup, cnt: 10356, in_rc: 0, out_rc: 0
Jun 14 10:48:52 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: utcapitole, mode: download, cnt: 84844, in_rc: 0, out_rc: 0
Jun 14 10:48:52 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: utcapitole, mode: backup, cnt: 84844, in_rc: 0, out_rc: 0
Jun 14 10:48:53 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: winspy, mode: download, cnt: 364, in_rc: 0, out_rc: 0
Jun 14 10:48:53 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: winspy, mode: backup, cnt: 364, in_rc: 0, out_rc: 0
Jun 14 10:48:53 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: yoyo, mode: download, cnt: 3376, in_rc: 0, out_rc: 0
Jun 14 10:48:53 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: yoyo, mode: backup, cnt: 3376, in_rc: 0, out_rc: 0
Jun 14 10:48:55 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: youtube, mode: download, cnt: 24160, in_rc: 0, out_rc: 0
Jun 14 10:48:55 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: youtube, mode: backup, cnt: 24160, in_rc: 0, out_rc: 0
Jun 14 10:48:58 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: -, mode: merge, cnt: 770796, in_rc: 4, out_rc: 0
Jun 14 10:49:09 TurrisOmnia adblock-4.0.5[17973]: f_tld ::: source: /tmp/tmp.JfmBLG/adb_list.overall, cnt: 770796, cnt_tld: 596565
Jun 14 10:49:18 TurrisOmnia adblock-4.0.5[17973]: f_list ::: name: -, mode: final, cnt: 596565, in_rc: 4, out_rc: 0
Jun 14 10:49:19 TurrisOmnia adblock-4.0.5[17973]: f_dnsup ::: lookup_util: /bin/nslookup, lookup_domain: example.com, restart_rc: 0, dns_timeout: 20, dns_cnt: 0, in_rc: 0, out_rc: 0
Jun 14 10:49:19 TurrisOmnia adblock-4.0.5[17973]: f_jsnup ::: status: enabled, cnt: 596565, mail: 0, mail_service: /etc/adblock/adblock.mail, mail_cnt: 0, mail_pid: -
Jun 14 10:49:19 TurrisOmnia adblock-4.0.5[17973]: blocklist with overall 596565 blocked domains loaded successfully (Turris Omnia, TurrisOS 5.0.1 e752fc1ff9d1d4f50a32155dd714dcde4b070bd4)
Jun 14 10:49:19 TurrisOmnia adblock-4.0.5[17973]: f_rmtemp ::: tmp_dir: /tmp/tmp.JfmBLG, src_file: /tmp/adb_sources.json, pid_file: /var/run/adblock.pid
Jun 14 10:53:55 TurrisOmnia adblock-4.0.5[19151]: f_report ::: action: report, report: 1, search: +, count: 50, process: false, print: json, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: br-lan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid: 7809
Jun 14 10:53:58 TurrisOmnia adblock-4.0.5[19219]: f_report ::: action: report, report: 1, search: +, count: 50, process: true, print: json, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: br-lan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid: 7809
Jun 14 10:54:00 TurrisOmnia adblock-4.0.5[19320]: f_report ::: action: report, report: 1, search: +, count: 50, process: false, print: json, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: br-lan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid: 7809
Jun 14 10:54:48 TurrisOmnia adblock-4.0.5[19396]: f_report ::: action: report, report: 1, search: +, count: 50, process: true, print: json, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: br-lan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid: 7809
Jun 14 10:54:50 TurrisOmnia adblock-4.0.5[19498]: f_report ::: action: report, report: 1, search: +, count: 50, process: false, print: json, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: br-lan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid: 7809
Jun 14 10:55:43 TurrisOmnia adblock-4.0.5[19602]: f_report ::: action: report, report: 1, search: +, count: 50, process: true, print: json, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: br-lan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid: 7809
Jun 14 10:55:45 TurrisOmnia adblock-4.0.5[19703]: f_report ::: action: report, report: 1, search: +, count: 50, process: false, print: json, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: br-lan, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid: 7809
