Turris OS 5.0.0 is released in HBT
I’ve also got error:
DIE:Failed to exec /usr/lib/opkg/info//ddns-scripts.preinst: Exec format error
It’s because all the lines (including the first one) in /usr/lib/opkg/info//ddns-scripts.preinst have tab in the beginning. And this caused /usr/lib/opkg/info/ddns-scripts.postinst to stuck later.
Package ddns-scripts comes from OpenWrt packages feed. You can open an issue in their repository or send a pull request. I’m sure that they will welcome it.
Hi @vojtech.myslivec thanks for quick response. One other thing I noticed sentinel related, I have sentinel-nikola package installed, but it seems not to be doing anything per logs below. Is this known as well?
Apr 19 18:15:01 turris crond[18365]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
Apr 19 18:15:01 turris crond[18361]: (root) CMDOUT (There is no message to send.)
Apr 19 11:15:02 turris nikola: recognized WAN interfaces: eth2, lo
Apr 19 18:15:02 turris crond[18363]: (root) CMDOUT (recognized WAN interfaces: eth2, lo)
Apr 19 11:15:32 turris nikola: Establishing connection took 0.000009 seconds
Apr 19 18:15:32 turris crond[18363]: (root) CMDOUT (Establishing connection took 0.000009 seconds)
Apr 19 11:15:32 turris nikola: Records parsed: 0
Apr 19 18:15:32 turris crond[18363]: (root) CMDOUT (Records parsed: 0)
Apr 19 11:15:32 turris nikola: Records after filtering: 0
Apr 19 18:15:32 turris crond[18363]: (root) CMDOUT (Records after filtering: 0)
Apr 19 11:15:32 turris nikola: Records filtering took 0.000785 seconds
Apr 19 18:15:32 turris crond[18363]: (root) CMDOUT (Records filtering took 0.000785 seconds)
Apr 19 11:15:32 turris nikola: Sending records took 0.001753 seconds
Apr 19 18:15:32 turris crond[18363]: (root) CMDOUT (Sending records took 0.001753 seconds)
Apr 19 11:15:32 turris nikola: turris firewall rules might not be active
Apr 19 18:15:32 turris crond[18363]: (root) CMDOUT (turris firewall rules might not be active)
Unfortunately I had to rollback to 4.0.5.
wlan0 (5Ghz) sometimes wasn’t able to get up. From dmesg:
[ 1109.959004] ath10k_pci 0000:02:00.0: pdev param 0 not supported by firmware
[ 1109.979807] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
This could be related to country settings, I tried to set CZ.
Also turris stopped to resolve dhcp clients, except of static ones.
Rollback view reForis almost work: I pressed ‘Rollback’ button and it did the job, but UI was showing spinner forever instead of saying that I need to reboot.
Thanks, I see the issue. EDIT: it already had a ticket and fix: /etc/resolver/dhcp_host_domain_ng.py broken in TurrisOS 5.0.0 (#578) · Issues · Turris / Turris OS / Turris OS packages · GitLab
can anyone help me with my Hardware bug?
I can not load the mac80211 or any else WIFI drivers?
With the 4.06 Firmware the ath10k drive could only be loadet.
With TOS5.0 nothing is loadet.
I have no WLAN.
Can anyone post me the kernellog from the Bootprocess with working WLAN, that i can see witch driver must be loadet.
Hi @tonyquan. Thanks for your report. This is long-running issue with firewall logging (which nikola reads) in TOS >= 4.0. The work is curently in progress and it should be fixed soon.
I dont know if this helps you (I am on HBL):
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.172 (beast@slave07) (gcc version 7.5.0 (OpenWrt GCC 7.5.0 5b9b833)) #0 SMP Thu Apr 9 13:28:32 2020
[    0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Turris Omnia
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 524288
[    0.000000] free_area_init_node: node 0, pgdat c0b3b300, node_mem_map eedf9000
[    0.000000]   Normal zone: 1728 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 196608 pages, LIFO batch:31
[    0.000000]   HighMem zone: 327680 pages, LIFO batch:31
[    0.000000] random: get_random_bytes called from start_kernel+0x8c/0x4c4 with crng_init=0
[    0.000000] percpu: Embedded 11 pages/cpu s15372 r8192 d21492 u45056
[    0.000000] pcpu-alloc: s15372 r8192 d21492 u45056 alloc=11*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 522560
[    0.000000] Kernel command line: earlyprintk console=ttyS0,115200 rootfstype=btrfs rootdelay=2 root=b301 rootflags=subvol=@,commit=5 rw cfg80211.freg=**
[    0.000000] Bootloader command line not present
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 2066972K/2097152K available (7168K kernel code, 239K rwdata, 1676K rodata, 1024K init, 256K bss, 30180K reserved, 0K cma-reserved, 1310720K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0800000   (8160 kB)
[    0.000000]       .init : 0xc0a00000 - 0xc0b00000   (1024 kB)
[    0.000000]       .data : 0xc0b00000 - 0xc0b3bc00   ( 239 kB)
[    0.000000]        .bss : 0xc0b3bc00 - 0xc0b7bfd8   ( 257 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] L2C-310 enabling early BRESP for Cortex-A9
[    0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[    0.000000] L2C-310 D prefetch enabled, offset 1 lines
[    0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[    0.000000] L2C-310 Coherent cache controller enabled, 16 ways, 1024 kB
[    0.000000] L2C-310 Coherent: CACHE_ID 0x410054c9, AUX_CTRL 0x56070001
[    0.000006] sched_clock: 64 bits at 800MHz, resolution 1ns, wraps every 4398046511103ns
[    0.000017] clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0xb881274fa3, max_idle_ns: 440795210636 ns
[    0.000031] Switching to timer-based delay loop, resolution 1ns
[    0.000160] Ignoring duplicate/late registration of read_current_timer delay
[    0.000167] clocksource: armada_370_xp_clocksource: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
[    0.000337] Console: colour dummy device 80x30
[    0.000354] Calibrating delay loop (skipped), value calculated using timer frequency.. 1600.00 BogoMIPS (lpj=8000000)
[    0.000362] pid_max: default: 32768 minimum: 301
[    0.000422] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000428] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000715] CPU: Testing write buffer coherency: ok
[    0.000727] CPU0: Spectre v2: using BPIALL workaround
[    0.000847] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.000977] Setting up static identity map for 0x100000 - 0x100060
[    0.001053] mvebu-soc-id: MVEBU SoC ID=0x6820, Rev=0x4
[    0.001131] mvebu-pmsu: Initializing Power Management Service Unit
[    0.001182] Hierarchical SRCU implementation.
[    0.001380] smp: Bringing up secondary CPUs ...
[    0.001515] Booting CPU 1
[    0.001671] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.001673] CPU1: Spectre v2: using BPIALL workaround
[    0.001729] smp: Brought up 1 node, 2 CPUs
[    0.001733] SMP: Total of 2 processors activated (3200.00 BogoMIPS).
[    0.001737] CPU: All CPU(s) started in SVC mode.
[    0.002265] devtmpfs: initialized
[    0.003864] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    0.003922] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.003930] futex hash table entries: 512 (order: 3, 32768 bytes)
[    0.003995] xor: measuring software checksum speed
[    0.100067]    arm4regs  :  2403.600 MB/sec
[    0.200067]    8regs     :  1942.400 MB/sec
[    0.300066]    32regs    :  2058.800 MB/sec
[    0.400067]    neon      :  1836.800 MB/sec
[    0.400071] xor: using function: arm4regs (2403.600 MB/sec)
[    0.400076] pinctrl core: initialized pinctrl subsystem
[    0.400443] NET: Registered protocol family 16
[    0.400979] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.401465] cpuidle: using governor ladder
[    0.401560] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[    0.401565] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.401685] mvebu-pmsu: CPU hotplug support is currently broken on Armada 38x: disabling
[    0.401691] mvebu-pmsu: CPU idle is currently broken on Armada 38x: disabling
[    0.570277] raid6: int32x1  gen()   171 MB/s
[    0.740166] raid6: int32x1  xor()   243 MB/s
[    0.910207] raid6: int32x2  gen()   255 MB/s
[    1.080119] raid6: int32x2  xor()   288 MB/s
[    1.250237] raid6: int32x4  gen()   304 MB/s
[    1.420165] raid6: int32x4  xor()   252 MB/s
[    1.590159] raid6: int32x8  gen()   328 MB/s
[    1.760133] raid6: int32x8  xor()   229 MB/s
[    1.930092] raid6: neonx1   gen()  1111 MB/s
[    2.100078] raid6: neonx1   xor()  1058 MB/s
[    2.270085] raid6: neonx2   gen()  1303 MB/s
[    2.440087] raid6: neonx2   xor()  1351 MB/s
[    2.610090] raid6: neonx4   gen()  1070 MB/s
[    2.780069] raid6: neonx4   xor()  1307 MB/s
[    2.950109] raid6: neonx8   gen()  1014 MB/s
[    3.120100] raid6: neonx8   xor()   947 MB/s
[    3.120104] raid6: using algorithm neonx2 gen() 1303 MB/s
[    3.120107] raid6: .... xor() 1351 MB/s, rmw enabled
[    3.120110] raid6: using neon recovery algorithm
[    3.120363] SCSI subsystem initialized
[    3.120570] libata version 3.00 loaded.
[    3.120701] usbcore: registered new interface driver usbfs
[    3.120730] usbcore: registered new interface driver hub
[    3.120755] usbcore: registered new device driver usb
[    3.121471] clocksource: Switched to clocksource arm_global_timer
[    3.125391] NET: Registered protocol family 2
[    3.125666] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    3.125704] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    3.125765] TCP: Hash tables configured (established 8192 bind 8192)
[    3.125816] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    3.125842] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    3.125935] NET: Registered protocol family 1
[    3.125950] PCI: CLS 0 bytes, default 64
[    3.126268] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[    3.127250] Crashlog allocated RAM at address 0x3f00000
[    3.127356] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    3.129319] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    3.129327] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    3.131070] bounce: pool size: 64 pages
[    3.131081] io scheduler noop registered
[    3.131085] io scheduler deadline registered (default)
[    3.131660] armada-38x-pinctrl f1018000.pinctrl: registered pinctrl driver
[    3.133084] mvebu-pcie soc:pcie: PCI host bridge to bus 0000:00
[    3.133095] pci_bus 0000:00: root bus resource [io  0x1000-0xfffff]
[    3.133100] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xe7ffffff]
[    3.133105] pci_bus 0000:00: root bus resource [bus 00-ff]
[    3.133121] pci 0000:00:01.0: [11ab:6820] type 01 class 0x060400
[    3.133211] pci 0000:00:02.0: [11ab:6820] type 01 class 0x060400
[    3.133280] pci 0000:00:03.0: [11ab:6820] type 01 class 0x060400
[    3.133352] PCI: bus0: Fast back to back transfers disabled
[    3.133358] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    3.133365] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    3.133371] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    3.133422] pci 0000:01:00.0: [168c:003c] type 00 class 0x028000
[    3.133449] pci 0000:01:00.0: reg 0x10: [mem 0xe8000000-0xe81fffff 64bit]
[    3.133476] pci 0000:01:00.0: reg 0x30: [mem 0xe8200000-0xe820ffff pref]
[    3.133537] pci 0000:01:00.0: supports D1 D2
[    3.133598] PCI: bus1: Fast back to back transfers disabled
[    3.133606] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    3.133654] pci 0000:02:00.0: [168c:0046] type 00 class 0x028000
[    3.133676] pci 0000:02:00.0: reg 0x10: [mem 0xea000000-0xea1fffff 64bit]
[    3.133743] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[    3.133799] PCI: bus2: Fast back to back transfers disabled
[    3.133805] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[    3.133855] pci 0000:03:00.0: [1b21:0612] type 00 class 0x010601
[    3.133875] pci 0000:03:00.0: reg 0x10: [io  0xfffffff8-0xffffffff]
[    3.133883] pci 0000:03:00.0: reg 0x14: [io  0xfffffffc-0xffffffff]
[    3.133890] pci 0000:03:00.0: reg 0x18: [io  0xfffffff8-0xffffffff]
[    3.133898] pci 0000:03:00.0: reg 0x1c: [io  0xfffffffc-0xffffffff]
[    3.133905] pci 0000:03:00.0: reg 0x20: [io  0xffffffe0-0xffffffff]
[    3.133912] pci 0000:03:00.0: reg 0x24: [mem 0xec000000-0xec0001ff]
[    3.133920] pci 0000:03:00.0: reg 0x30: [mem 0xec010000-0xec01ffff pref]
[    3.134019] PCI: bus3: Fast back to back transfers disabled
[    3.134025] pci_bus 0000:03: busn_res: [bus 03-ff] end is updated to 03
[    3.134047] pci 0000:00:02.0: BAR 8: assigned [mem 0xe0000000-0xe01fffff]
[    3.134052] pci 0000:00:01.0: BAR 8: assigned [mem 0xe0200000-0xe04fffff]
[    3.134057] pci 0000:00:03.0: BAR 8: assigned [mem 0xe0500000-0xe05fffff]
[    3.134062] pci 0000:00:03.0: BAR 7: assigned [io  0x10000-0x10fff]
[    3.134069] pci 0000:01:00.0: BAR 0: assigned [mem 0xe0200000-0xe03fffff 64bit]
[    3.134080] pci 0000:01:00.0: BAR 6: assigned [mem 0xe0400000-0xe040ffff pref]
[    3.134085] pci 0000:00:01.0: PCI bridge to [bus 01]
[    3.134091] pci 0000:00:01.0:   bridge window [mem 0xe0200000-0xe04fffff]
[    3.134098] pci 0000:02:00.0: BAR 0: assigned [mem 0xe0000000-0xe01fffff 64bit]
[    3.134107] pci 0000:00:02.0: PCI bridge to [bus 02]
[    3.134112] pci 0000:00:02.0:   bridge window [mem 0xe0000000-0xe01fffff]
[    3.134119] pci 0000:03:00.0: BAR 6: assigned [mem 0xe0500000-0xe050ffff pref]
[    3.134124] pci 0000:03:00.0: BAR 5: assigned [mem 0xe0510000-0xe05101ff]
[    3.134131] pci 0000:03:00.0: BAR 4: assigned [io  0x10000-0x1001f]
[    3.134137] pci 0000:03:00.0: BAR 0: assigned [io  0x10020-0x10027]
[    3.134143] pci 0000:03:00.0: BAR 2: assigned [io  0x10028-0x1002f]
[    3.134149] pci 0000:03:00.0: BAR 1: assigned [io  0x10030-0x10033]
[    3.134155] pci 0000:03:00.0: BAR 3: assigned [io  0x10034-0x10037]
[    3.134161] pci 0000:00:03.0: PCI bridge to [bus 03]
[    3.134165] pci 0000:00:03.0:   bridge window [io  0x10000-0x10fff]
[    3.134170] pci 0000:00:03.0:   bridge window [mem 0xe0500000-0xe05fffff]
[    3.134405] mv_xor f1060800.xor: Marvell shared XOR driver
[    3.191969] mv_xor f1060800.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[    3.192090] mv_xor f1060900.xor: Marvell shared XOR driver
[    3.251912] mv_xor f1060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[    3.252129] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[    3.253283] console [ttyS0] disabled
[    3.273359] f1012000.serial: ttyS0 at MMIO 0xf1012000 (irq = 22, base_baud = 15625000) is a 16550A
[    4.221904] console [ttyS0] enabled
[    4.245663] f1012100.serial: ttyS1 at MMIO 0xf1012100 (irq = 23, base_baud = 15625000) is a 16550A
[    4.256478] loop: module loaded
[    4.259938] ahci-mvebu f10a8000.sata: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[    4.269029] ahci-mvebu f10a8000.sata: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
[    4.278192] scsi host0: ahci-mvebu
[    4.281758] scsi host1: ahci-mvebu
[    4.285231] ata1: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x100 irq 44
[    4.293177] ata2: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x180 irq 44
[    4.301923] m25p80 spi0.0: s25fl164k (8192 Kbytes)
[    4.306791] 2 fixed-partitions partitions found on MTD device spi0.0
[    4.313172] Creating 2 MTD partitions on "spi0.0":
[    4.317975] 0x000000000000-0x000000100000 : "U-Boot"
[    4.323294] 0x000000100000-0x000000800000 : "Rescue system"
[    4.329335] libphy: Fixed MDIO Bus: probed
[    4.333790] libphy: orion_mdio_bus: probed
[    4.338407] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
[    4.501440] libphy: mv88e6xxx SMI: probed
[    4.509256] mvneta f1070000.ethernet eth0: Using hardware mac address d8:58:d7:00:1b:d7
[    4.518038] mvneta f1030000.ethernet eth1: Using hardware mac address d8:58:d7:00:1b:d5
[    4.526754] mvneta f1034000.ethernet eth2: Using hardware mac address d8:58:d7:00:1b:d6
[    4.534937] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.541487] ehci-pci: EHCI PCI platform driver
[    4.545968] ehci-platform: EHCI generic platform driver
[    4.551269] ehci-orion: EHCI orion driver
[    4.555388] orion-ehci f1058000.usb: EHCI Host Controller
[    4.560812] orion-ehci f1058000.usb: new USB bus registered, assigned bus number 1
[    4.568448] orion-ehci f1058000.usb: irq 40, io mem 0xf1058000
[    4.601474] orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00
[    4.607709] hub 1-0:1.0: USB hub found
[    4.611571] hub 1-0:1.0: 1 port detected
[    4.615861] xhci-hcd f10f0000.usb3: xHCI Host Controller
[    4.621193] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
[    4.628763] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
[    4.638030] xhci-hcd f10f0000.usb3: irq 46, io mem 0xf10f0000
[    4.642729] ata2: SATA link down (SStatus 0 SControl 300)
[    4.649216] ata1: SATA link down (SStatus 0 SControl 300)
[    4.654776] hub 2-0:1.0: USB hub found
[    4.658550] hub 2-0:1.0: 1 port detected
[    4.662654] xhci-hcd f10f0000.usb3: xHCI Host Controller
[    4.667984] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
[    4.675500] xhci-hcd f10f0000.usb3: Host supports USB 3.0  SuperSpeed
[    4.681989] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.690308] hub 3-0:1.0: USB hub found
[    4.694086] hub 3-0:1.0: 1 port detected
[    4.698189] xhci-hcd f10f8000.usb3: xHCI Host Controller
[    4.703529] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
[    4.711079] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
[    4.720346] xhci-hcd f10f8000.usb3: irq 47, io mem 0xf10f8000
[    4.726348] hub 4-0:1.0: USB hub found
[    4.730119] hub 4-0:1.0: 1 port detected
[    4.734156] xhci-hcd f10f8000.usb3: xHCI Host Controller
[    4.739485] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
[    4.747000] xhci-hcd f10f8000.usb3: Host supports USB 3.0  SuperSpeed
[    4.753491] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.761814] hub 5-0:1.0: USB hub found
[    4.765584] hub 5-0:1.0: 1 port detected
[    4.769719] usbcore: registered new interface driver usb-storage
[    4.776204] armada38x-rtc f10a3800.rtc: registered as rtc0
[    4.781841] i2c /dev entries driver
[    4.795858] (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[    4.808334] orion_wdt: Initial timeout 171 sec
[    4.813058] sdhci: Secure Digital Host Controller Interface driver
[    4.819252] sdhci: Copyright(c) Pierre Ossman
[    4.881472] mmc0: SDHCI controller on f10d8000.sdhci [f10d8000.sdhci] using ADMA
[    4.888978] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.895482] marvell-cesa f1090000.crypto: CESA device successfully registered
[    4.903101] NET: Registered protocol family 10
[    4.909119] Segment Routing with IPv6
[    4.912835] NET: Registered protocol family 17
[    4.917304] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    4.931550] 8021q: 802.1Q VLAN Support v1.8
[    4.935819] Registering SWP/SWPB emulation handler
[    4.941988] Btrfs loaded, crc32c=crc32c-generic
[    4.947424] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
[    5.058089] mmc0: new high speed MMC card at address 0001
[    5.063679] mmcblk0: mmc0:0001 H8G4a� 7.28 GiB
[    5.068284] mmcblk0boot0: mmc0:0001 H8G4a� partition 1 4.00 MiB
[    5.074284] mmcblk0boot1: mmc0:0001 H8G4a� partition 2 4.00 MiB
[    5.080276] mmcblk0rpmb: mmc0:0001 H8G4a� partition 3 4.00 MiB, chardev (250:0)
[    5.088650]  mmcblk0: p1
[    5.105183] libphy: mv88e6xxx SMI: probed
[    5.109257] DSA: switch 0 0 parsed
[    5.112695] DSA: tree 0 parsed
[    5.121478] usb 4-1: new high-speed USB device number 2 using xhci-hcd
[    5.434976] usb-storage 4-1:1.0: USB Mass Storage device detected
[    5.441193] scsi host2: usb-storage 4-1:1.0
[    5.816276] mv88e6085 f1072004.mdio-mii:10 lan0 (uninitialized): PHY [mv88e6xxx-1:00] driver [Marvell 88E1540]
[    5.935568] mv88e6085 f1072004.mdio-mii:10 lan1 (uninitialized): PHY [mv88e6xxx-1:01] driver [Marvell 88E1540]
[    6.057805] mv88e6085 f1072004.mdio-mii:10 lan2 (uninitialized): PHY [mv88e6xxx-1:02] driver [Marvell 88E1540]
[    6.175572] mv88e6085 f1072004.mdio-mii:10 lan3 (uninitialized): PHY [mv88e6xxx-1:03] driver [Marvell 88E1540]
[    6.295566] mv88e6085 f1072004.mdio-mii:10 lan4 (uninitialized): PHY [mv88e6xxx-1:04] driver [Marvell 88E1540]
[    6.317138] armada38x-rtc f10a3800.rtc: setting system clock to 2020-04-11 08:53:45 UTC (1586595225)
[    6.326581] Waiting 2 sec before mounting root device...
[    6.559987] scsi 2:0:0:0: Direct-Access     Corsair  Voyager VEGA     000A PQ: 0 ANSI: 6
[    8.337361] sd 2:0:0:0: [sda] 30283008 512-byte logical blocks: (15.5 GB/14.4 GiB)
[    8.345066] sd 2:0:0:0: [sda] Write Protect is off
[    8.349872] sd 2:0:0:0: [sda] Mode Sense: 23 00 00 00
[    8.349979] sd 2:0:0:0: [sda] No Caching mode page found
[    8.355313] sd 2:0:0:0: [sda] Assuming drive cache: write through
[    8.387883]  sda: sda1
[    8.391110] sd 2:0:0:0: [sda] Attached SCSI removable disk
[    8.399556] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[    8.406809] F2FS-fs (mmcblk0p1): Can't find valid F2FS filesystem in 1th superblock
[    8.414670] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[    8.421919] F2FS-fs (mmcblk0p1): Can't find valid F2FS filesystem in 2th superblock
[    8.429599] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[    8.436844] F2FS-fs (mmcblk0p1): Can't find valid F2FS filesystem in 1th superblock
[    8.444522] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[    8.451763] F2FS-fs (mmcblk0p1): Can't find valid F2FS filesystem in 2th superblock
[    8.460550] BTRFS: device fsid ce109459-155f-47fa-ab57-76b5b5e0369f devid 1 transid 6010 /dev/root
[    8.470168] BTRFS info (device mmcblk0p1): disk space caching is enabled
[    8.476905] BTRFS info (device mmcblk0p1): has skinny extents
[    8.489238] BTRFS info (device mmcblk0p1): enabling ssd optimizations
[    8.508091] random: fast init done
[    8.528633] VFS: Mounted root (btrfs filesystem) on device 0:12.
[    8.535384] devtmpfs: mounted
[    8.538917] Freeing unused kernel memory: 1024K
[    8.602518] init: Console is alive
[    8.605988] init: - watchdog -
[    9.270378] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[    9.282159] exFAT: Version 1.2.9
[    9.291734] SGI XFS with ACLs, security attributes, no debug enabled
[    9.299552] ahci 0000:03:00.0: version 3.0
[    9.299564] pci 0000:00:03.0: enabling device (0140 -> 0143)
[    9.305362] ahci 0000:03:00.0: SSS flag set, parallel bus scan disabled
[    9.312025] ahci 0000:03:00.0: AHCI 0001.0200 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[    9.320136] ahci 0000:03:00.0: flags: 64bit ncq sntf stag led clo pmp pio slum part ccc sxs
[    9.329017] scsi host3: ahci
[    9.332087] scsi host4: ahci
[    9.335038] ata3: SATA max UDMA/133 abar m512@0xe0510000 port 0xe0510100 irq 77
[    9.342384] ata4: SATA max UDMA/133 abar m512@0xe0510000 port 0xe0510180 irq 77
[    9.841475] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    9.858203] ata3.00: ATA-8: ST9750423AS, 0001SDM1, max UDMA/133
[    9.864143] ata3.00: 1465149168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[    9.890151] ata3.00: configured for UDMA/133
[    9.894600] scsi 3:0:0:0: Direct-Access     ATA      ST9750423AS      SDM1 PQ: 0 ANSI: 5
[    9.903115] sd 3:0:0:0: [sdb] 1465149168 512-byte logical blocks: (750 GB/699 GiB)
[    9.910709] sd 3:0:0:0: [sdb] 4096-byte physical blocks
[    9.915996] sd 3:0:0:0: [sdb] Write Protect is off
[    9.920799] sd 3:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    9.920838] sd 3:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    9.939620]  sdb: sdb1
[    9.942352] sd 3:0:0:0: [sdb] Attached SCSI disk
[   10.401474] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[   10.419241] ata4.00: ATA-8: ST9750423AS, 0001SDM1, max UDMA/133
[   10.425180] ata4.00: 1465149168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[   10.463951] ata4.00: configured for UDMA/133
[   10.468353] scsi 4:0:0:0: Direct-Access     ATA      ST9750423AS      SDM1 PQ: 0 ANSI: 5
[   10.476843] sd 4:0:0:0: [sdc] 1465149168 512-byte logical blocks: (750 GB/699 GiB)
[   10.484444] sd 4:0:0:0: [sdc] 4096-byte physical blocks
[   10.489716] sd 4:0:0:0: [sdc] Write Protect is off
[   10.494529] sd 4:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[   10.494566] sd 4:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   10.535235]  sdc: sdc1
[   10.537975] sd 4:0:0:0: [sdc] Attached SCSI disk
[   10.543740] usbcore: registered new interface driver uas
[   10.549138] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[   10.564099] init: - preinit -
[   10.661021] random: jshn: uninitialized urandom read (4 bytes read)
[   10.678005] random: jshn: uninitialized urandom read (4 bytes read)
[   10.712035] random: jshn: uninitialized urandom read (4 bytes read)
[   13.797553] mount_root: mounting /dev/root
[   13.866982] BTRFS info (device mmcblk0p1): disk space caching is enabled
[   13.873882] mount_root: loading kmods from internal overlay
[   13.894528] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[   13.902421] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[   14.964599] block: attempting to load /etc/config/fstab
[   14.970959] block: extroot: not configured
[   14.988945] urandom_read: 2 callbacks suppressed
[   14.988951] random: procd: uninitialized urandom read (4 bytes read)
[   16.940346] BTRFS: device label srv devid 1 transid 7977 /dev/sda1
[   16.954097] procd: - early -
[   16.957010] procd: - watchdog -
[   17.059383] random: crng init done
[   17.556309] procd: - watchdog -
[   17.559557] procd: - ubus -
[   17.612160] procd: - init -
[   17.717544] kmodloader: loading kernel modules from /etc/modules.d/*
[   17.737544] NET: Registered protocol family 38
[   17.758126] async_tx: api initialized (async)
[   17.770193] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-devel@redhat.com
[   17.782436] Key type dns_resolver registered
[   17.792675] Key type cifs.idmap registered
[   17.806374] RPC: Registered named UNIX socket transport module.
[   17.812339] RPC: Registered udp transport module.
[   17.817053] RPC: Registered tcp transport module.
[   17.821772] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   17.831143] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[   17.848060] tun: Universal TUN/TAP device driver, 1.6
[   17.861192] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[   17.879365] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   17.889350] NFS: Registering the id_resolver key type
[   17.894456] Key type id_resolver registered
[   17.898650] Key type id_legacy registered
[   17.906125] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   17.914384] Netfilter messages via NETLINK v0.30.
[   17.920357] ip_set: protocol 6
[   17.934254] cryptodev: driver 1.10 loaded.
[   17.951682] i2c i2c-0: Added multiplexed i2c bus 1
[   17.956779] i2c i2c-0: Added multiplexed i2c bus 2
[   17.961963] i2c i2c-0: Added multiplexed i2c bus 3
[   17.967131] i2c i2c-0: Added multiplexed i2c bus 4
[   17.972385] i2c i2c-0: Added multiplexed i2c bus 5
[   17.977543] i2c i2c-0: Added multiplexed i2c bus 6
[   17.982703] i2c i2c-0: Added multiplexed i2c bus 7
[   17.988000] pca953x 8-0071: 8-0071 supply vcc not found, using dummy regulator
[   18.000808] i2c i2c-0: Added multiplexed i2c bus 8
[   18.005639] pca954x 0-0070: registered 8 multiplexed busses for I2C mux pca9547
[   18.014932] Mirror/redirect action on
[   18.021546] u32 classifier
[   18.024262]     input device check on
[   18.027930]     Actions configured
[   18.033701] sch_cake: Unknown symbol nf_conntrack_find_get (err 0)
[   18.039978] sch_cake: Unknown symbol nf_ct_get_tuplepr (err 0)
[   18.073323] fuse init (API version 7.26)
[   18.080379] Bridge firewalling registered
[   18.085173] Loading modules backported from Linux version v4.19.112-0-g14cfdbd39e31
[   18.092859] Backport generated by backports.git v4.19.112-1-0-g60c3a249
[   18.102719] Ebtables v2.0 registered
[   18.107129] ip_tables: (C) 2000-2006 Netfilter Core Team
[   18.118220] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[   18.125624] ctnetlink v0.93: registering with nfnetlink.
[   18.150435] usbcore: registered new interface driver ums-alauda
[   18.156747] usbcore: registered new interface driver ums-cypress
[   18.163166] usbcore: registered new interface driver ums-datafab
[   18.169496] usbcore: registered new interface driver ums-freecom
[   18.175914] usbcore: registered new interface driver ums-isd200
[   18.182190] usbcore: registered new interface driver ums-jumpshot
[   18.188594] usbcore: registered new interface driver ums-karma
[   18.194809] usbcore: registered new interface driver ums-sddr09
[   18.201080] usbcore: registered new interface driver ums-sddr55
[   18.207394] usbcore: registered new interface driver ums-usbat
[   18.214745] usbcore: registered new interface driver usbserial
[   18.220616] usbcore: registered new interface driver usbserial_generic
[   18.227195] usbserial: USB Serial support registered for generic
[   18.243715] xt_time: kernel timezone is -0000
[   18.249296] at24 1-0054: 8192 byte 24c64 EEPROM, writable, 1 bytes/write
[   18.279312] PPP generic driver version 2.4.2
[   18.284385] NET: Registered protocol family 24
[   18.298295] ath10k 4.19 driver, optimized for CT firmware, probing pci device: 0x3c.
[   18.306327] pci 0000:00:01.0: enabling device (0140 -> 0142)
[   18.312235] ath10k_pci 0000:01:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[   18.554524] ath10k_pci 0000:01:00.0: Direct firmware load for ath10k/fwcfg-pci-0000:01:00.0.txt failed with error -2
[   18.565117] ath10k_pci 0000:01:00.0: Falling back to user helper
[   19.781449] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts:
[   20.004006] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts:
[   21.577808] firmware ath10k!fwcfg-pci-0000:01:00.0.txt: firmware_loading_store: map pages failed
[   21.586755] ath10k_pci 0000:01:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:01:00.0.bin failed with error -2
[   21.597499] ath10k_pci 0000:01:00.0: Falling back to user helper
[   21.608478] firmware ath10k!pre-cal-pci-0000:01:00.0.bin: firmware_loading_store: map pages failed
[   21.617624] ath10k_pci 0000:01:00.0: Direct firmware load for ath10k/cal-pci-0000:01:00.0.bin failed with error -2
[   21.628015] ath10k_pci 0000:01:00.0: Falling back to user helper
[   21.638537] firmware ath10k!cal-pci-0000:01:00.0.bin: firmware_loading_store: map pages failed
[   21.647330] ath10k_pci 0000:01:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/ct-firmware-5.bin failed with error -2
[   21.658344] ath10k_pci 0000:01:00.0: Falling back to user helper
[   21.668862] firmware ath10k!QCA988X!hw2.0!ct-firmware-5.bin: firmware_loading_store: map pages failed
[   21.678209] ath10k_pci 0000:01:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/ct-firmware-2.bin failed with error -2
[   21.689210] ath10k_pci 0000:01:00.0: Falling back to user helper
[   21.699709] firmware ath10k!QCA988X!hw2.0!ct-firmware-2.bin: firmware_loading_store: map pages failed
[   21.709055] ath10k_pci 0000:01:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/firmware-6.bin failed with error -2
[   21.719801] ath10k_pci 0000:01:00.0: Falling back to user helper
[   21.730261] firmware ath10k!QCA988X!hw2.0!firmware-6.bin: firmware_loading_store: map pages failed
[   21.747739] ath10k_pci 0000:01:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
[   21.756994] ath10k_pci 0000:01:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
[   21.766522] ath10k_pci 0000:01:00.0: firmware ver 10.2.4-1.0-00047 api 5 features no-p2p,raw-mode,mfp,allows-mesh-bcast crc32 35bd9258
[   21.811323] ath10k_pci 0000:01:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
[   21.821794] ath10k_pci 0000:01:00.0: Falling back to user helper
[   21.832625] firmware ath10k!QCA988X!hw2.0!board-2.bin: firmware_loading_store: map pages failed
[   21.842332] ath10k_pci 0000:01:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[   22.971001] ath10k_pci 0000:01:00.0: wmi print 'P 135 V 16 T 433'
[   22.981916] ath10k_pci 0000:01:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
[   23.102773] ath: EEPROM regdomain: 0x0
[   23.102776] ath: EEPROM indicates default country code should be used
[   23.102777] ath: doing EEPROM country->regdmn map search
[   23.102781] ath: country maps to regdmn code: 0x3a
[   23.102783] ath: Country alpha2 being used: US
[   23.102784] ath: Regpair used: 0x3a
[   23.104627] ath10k 4.19 driver, optimized for CT firmware, probing pci device: 0x46.
[   23.116174] pci 0000:00:02.0: enabling device (0140 -> 0142)
[   23.122199] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[   23.302840] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/fwcfg-pci-0000:02:00.0.txt failed with error -2
[   23.313415] ath10k_pci 0000:02:00.0: Falling back to user helper
[   23.421218] firmware ath10k!fwcfg-pci-0000:02:00.0.txt: firmware_loading_store: map pages failed
[   23.430170] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:02:00.0.bin failed with error -2
[   23.440912] ath10k_pci 0000:02:00.0: Falling back to user helper
[   23.451432] firmware ath10k!pre-cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
[   23.460564] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/cal-pci-0000:02:00.0.bin failed with error -2
[   23.470955] ath10k_pci 0000:02:00.0: Falling back to user helper
[   23.481490] firmware ath10k!cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
[   23.491123] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA9984/hw1.0/ct-firmware-5.bin failed with error -2
[   23.502123] ath10k_pci 0000:02:00.0: Falling back to user helper
[   23.512655] firmware ath10k!QCA9984!hw1.0!ct-firmware-5.bin: firmware_loading_store: map pages failed
[   23.522018] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA9984/hw1.0/ct-firmware-2.bin failed with error -2
[   23.533020] ath10k_pci 0000:02:00.0: Falling back to user helper
[   23.543754] firmware ath10k!QCA9984!hw1.0!ct-firmware-2.bin: firmware_loading_store: map pages failed
[   23.553117] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA9984/hw1.0/firmware-6.bin failed with error -2
[   23.563854] ath10k_pci 0000:02:00.0: Falling back to user helper
[   23.574489] firmware ath10k!QCA9984!hw1.0!firmware-6.bin: firmware_loading_store: map pages failed
[   23.602660] ath10k_pci 0000:02:00.0: qca9984/qca9994 hw1.0 target 0x01000000 chip_id 0x00000000 sub 168c:cafe
[   23.612620] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
[   23.624121] ath10k_pci 0000:02:00.0: firmware ver 10.4b-ct-9984-fW-012-17ba98334 api 5 features mfp,peer-flow-ctrl,txstatus-noack,wmi-10.x-CT,ratemask-CT,regdump-CT,txrate-CT,flush-all-CT,pingpong-CT,ch-regs-CT,nop-CT,set-special-CT,tx-rc-CT,cust-stats-CT,txrate2-CT,beacon-cb-CT,wmi-block-ack-CT,wmi-bcn-rc-CT crc32 877928bc
[   24.934513] ath10k_pci 0000:02:00.0: board_file api 2 bmi_id 0:31 crc32 85498734
[   27.424259] ath10k_pci 0000:02:00.0: 10.4 wmi init: vdevs: 16  peers: 48  tid: 96
[   27.431799] ath10k_pci 0000:02:00.0: msdu-desc: 2500  skid: 32
[   27.511112] ath10k_pci 0000:02:00.0: wmi print 'P 48/48 V 16 K 144 PH 176 T 186  msdu-desc: 2500  sw-crypt: 0 ct-sta: 0'
[   27.522036] ath10k_pci 0000:02:00.0: wmi print 'free: 81784 iram: 23220 sram: 14440'
[   27.772732] ath10k_pci 0000:02:00.0: htt-ver 2.2 wmi-op 6 htt-op 4 cal otp max-sta 32 raw 0 hwcrypto 1
[   27.872831] ath: EEPROM regdomain: 0x0
[   27.872834] ath: EEPROM indicates default country code should be used
[   27.872836] ath: doing EEPROM country->regdmn map search
[   27.872839] ath: country maps to regdmn code: 0x3a
[   27.872842] ath: Country alpha2 being used: US
[   27.872843] ath: Regpair used: 0x3a
[   27.883726] usbcore: registered new interface driver qcserial
[   27.889537] usbserial: USB Serial support registered for Qualcomm USB modem
[   27.901943] kmodloader: done loading kernel modules from /etc/modules.d/*
[   29.886006] IPv6: ADDRCONF(NETDEV_UP): br-guest_turris: link is not ready
[   29.896680] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[   29.907104] mvneta f1030000.ethernet eth1: configuring for fixed/rgmii link mode
[   29.915085] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[   29.920995] mvneta f1030000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
[   29.931029] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[   29.938389] mv88e6085 f1072004.mdio-mii:10 lan0: configuring for phy/gmii link mode
[   29.951199] br-lan: port 1(lan0) entered blocking state
[   29.956512] br-lan: port 1(lan0) entered disabled state
[   29.972809] device lan0 entered promiscuous mode
[   29.977449] device eth1 entered promiscuous mode
[   30.028907] mv88e6085 f1072004.mdio-mii:10 lan1: configuring for phy/gmii link mode
[   30.049119] br-lan: port 2(lan1) entered blocking state
[   30.054389] br-lan: port 2(lan1) entered disabled state
[   30.068684] device lan1 entered promiscuous mode
[   30.109120] mv88e6085 f1072004.mdio-mii:10 lan2: configuring for phy/gmii link mode
[   30.117094] br-lan: port 3(lan2) entered blocking state
[   30.122355] br-lan: port 3(lan2) entered disabled state
[   30.140400] device lan2 entered promiscuous mode
[   30.222319] mvneta f1070000.ethernet eth0: configuring for fixed/rgmii link mode
[   30.230182] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   30.236077] mvneta f1070000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   30.247203] mv88e6085 f1072004.mdio-mii:10 lan4: configuring for phy/gmii link mode
[   30.255702] br-lan: port 4(lan4) entered blocking state
[   30.260945] br-lan: port 4(lan4) entered disabled state
[   30.277051] device lan4 entered promiscuous mode
[   30.281719] device eth0 entered promiscuous mode
[   30.322412] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   30.345887] mv88e6085 f1072004.mdio-mii:10 lan3: configuring for phy/gmii link mode
[   30.354065] br-vlan: port 1(lan3) entered blocking state
[   30.359398] br-vlan: port 1(lan3) entered disabled state
[   30.373033] device lan3 entered promiscuous mode
[   30.386314] mv88e6085 f1072004.mdio-mii:10: p3: hw VLAN 1 already used by br-lan
[   30.412719] IPv6: ADDRCONF(NETDEV_UP): br-vlan: link is not ready
[   30.522925] mvneta f1034000.ethernet eth2: PHY [f1072004.mdio-mii:01] driver [Marvell 88E1510]
[   30.532225] mvneta f1034000.ethernet eth2: configuring for phy/sgmii link mode
[   30.540415] br-wan: port 1(eth2) entered blocking state
[   30.545685] br-wan: port 1(eth2) entered disabled state
[   30.556784] device eth2 entered promiscuous mode
[   30.563032] br-wan: port 1(eth2) entered blocking state
[   30.568286] br-wan: port 1(eth2) entered forwarding state
[   30.574378] BTRFS info (device sda1): disk space caching is enabled
[   30.580683] BTRFS info (device sda1): has skinny extents
[   30.932851] br-wan: port 1(eth2) entered disabled state
[   31.011567] ath: EEPROM regdomain: 0x82bf
[   31.011571] ath: EEPROM indicates we should expect a country code
[   31.011573] ath: doing EEPROM country->regdmn map search
[   31.011575] ath: country maps to regdmn code: 0x37
[   31.011577] ath: Country alpha2 being used: SK
[   31.011579] ath: Regpair used: 0x37
[   31.011581] ath: regdomain 0x82bf dynamically updated by user
[   31.011602] ath: EEPROM regdomain: 0x82bf
[   31.011604] ath: EEPROM indicates we should expect a country code
[   31.011606] ath: doing EEPROM country->regdmn map search
[   31.011608] ath: country maps to regdmn code: 0x37
[   31.011610] ath: Country alpha2 being used: SK
[   31.011611] ath: Regpair used: 0x37
[   31.011612] ath: regdomain 0x82bf dynamically updated by user
[   33.751924] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control rx/tx
[   33.915110] ath10k_pci 0000:02:00.0: 10.4 wmi init: vdevs: 16  peers: 48  tid: 96
[   33.922653] ath10k_pci 0000:02:00.0: msdu-desc: 2500  skid: 32
[   34.002067] ath10k_pci 0000:02:00.0: wmi print 'P 48/48 V 16 K 144 PH 176 T 186  msdu-desc: 2500  sw-crypt: 0 ct-sta: 0'
[   34.013067] ath10k_pci 0000:02:00.0: wmi print 'free: 81784 iram: 23220 sram: 14440'
[   34.359690] ath10k_pci 0000:02:00.0: Firmware lacks feature flag indicating a retry limit of > 2 is OK, requested limit: 4
[   34.370861] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
[   34.382531] br-wan: port 1(eth2) entered blocking state
[   34.387788] br-wan: port 1(eth2) entered forwarding state
[   34.407558] br-lan: port 5(wlan1) entered blocking state
[   34.412915] br-lan: port 5(wlan1) entered disabled state
[   34.418363] device wlan1 entered promiscuous mode
[   34.795295] ath10k_pci 0000:02:00.0: NOTE:  Firmware DBGLOG output disabled in debug_mask: 0x10000000
[   37.350167] ath10k_pci 0000:01:00.0: wmi print 'P 135 V 16 T 433'
[   37.361255] ath10k_pci 0000:01:00.0: pdev param 0 not supported by firmware
[   37.382443] ath10k_pci 0000:01:00.0: Firmware lacks feature flag indicating a retry limit of > 2 is OK, requested limit: 4
[   37.393622] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   37.404574] br-lan: port 6(wlan0) entered blocking state
[   37.409905] br-lan: port 6(wlan0) entered disabled state
[   37.415434] device wlan0 entered promiscuous mode
[   48.955104] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   48.961607] br-lan: port 6(wlan0) entered blocking state
[   48.966935] br-lan: port 6(wlan0) entered forwarding state
[   48.990982] br-guest_turris: port 1(guest_turris_0) entered blocking state
[   48.997981] br-guest_turris: port 1(guest_turris_0) entered disabled state
[   49.005029] device guest_turris_0 entered promiscuous mode
[   49.010970] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[   49.045664] IPv6: ADDRCONF(NETDEV_UP): guest_turris_0: link is not ready
[   49.052456] br-guest_turris: port 1(guest_turris_0) entered blocking state
[   49.059351] br-guest_turris: port 1(guest_turris_0) entered forwarding state
[   49.066636] IPv6: ADDRCONF(NETDEV_CHANGE): br-guest_turris: link becomes ready
[   49.292284] IPv6: ADDRCONF(NETDEV_CHANGE): guest_turris_0: link becomes ready
[   50.502957] device br-lan entered promiscuous mode
[   50.691908] device br-guest_turris entered promiscuous mode
[  100.352946] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[  100.359416] br-lan: port 5(wlan1) entered blocking state
[  100.364753] br-lan: port 5(wlan1) entered forwarding state
[  139.628988] ath10k_pci 0000:02:00.0: NIC rx-max-rate: 0 calculated-max: 0 rxnss_override: 0x80000000  nss160: 1  spatial-streams: 2
[ 2367.671297] nf_conntrack: default automatic helper assignment has been turned off for security reasons and CT-based  firewall rule not found. Use the iptables CT target to attach helpers instead.
[ 3439.733724] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 3439.742512] br-lan: port 1(lan0) entered blocking state
[ 3439.747760] br-lan: port 1(lan0) entered forwarding state
[ 6104.871356] ath10k_pci 0000:02:00.0: Invalid VHT mcs 15 peer stats
[11702.975046] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[11702.980934] br-lan: port 1(lan0) entered disabled state
[27088.116553] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[27088.125138] br-lan: port 1(lan0) entered blocking state
[27088.130385] br-lan: port 1(lan0) entered forwarding state
[27088.895000] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[27088.900889] br-lan: port 1(lan0) entered disabled state
[27090.445042] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[27090.453671] br-lan: port 1(lan0) entered blocking state
[27090.458919] br-lan: port 1(lan0) entered forwarding state
[27091.218284] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[27091.224100] br-lan: port 1(lan0) entered disabled state
[27094.413865] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[27094.422463] br-lan: port 1(lan0) entered blocking state
[27094.427709] br-lan: port 1(lan0) entered forwarding state
[27110.634422] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[27110.640236] br-lan: port 1(lan0) entered disabled state
[27112.284989] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[27112.293571] br-lan: port 1(lan0) entered blocking state
[27112.298824] br-lan: port 1(lan0) entered forwarding state
[27112.398546] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[27112.404376] br-lan: port 1(lan0) entered disabled state
[27114.195641] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[27114.204399] br-lan: port 1(lan0) entered blocking state
[27114.209649] br-lan: port 1(lan0) entered forwarding state
[27728.321771] ath10k_pci 0000:02:00.0: NIC rx-max-rate: 0 calculated-max: 0 rxnss_override: 0x80000000  nss160: 1  spatial-streams: 2
[43979.796064] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[43979.801906] br-lan: port 1(lan0) entered disabled state
[84179.352248] ath10k_pci 0000:02:00.0: NIC rx-max-rate: 0 calculated-max: 0 rxnss_override: 0x80000000  nss160: 1  spatial-streams: 2
[84583.101576] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[84583.110172] br-lan: port 1(lan0) entered blocking state
[84583.115417] br-lan: port 1(lan0) entered forwarding state
[84583.790140] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[84583.797861] br-lan: port 1(lan0) entered disabled state
[84585.459981] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[84585.468582] br-lan: port 1(lan0) entered blocking state
[84585.473827] br-lan: port 1(lan0) entered forwarding state
[84586.234929] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[84586.240859] br-lan: port 1(lan0) entered disabled state
[84590.429624] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[84590.438252] br-lan: port 1(lan0) entered blocking state
[84590.443498] br-lan: port 1(lan0) entered forwarding state
[84605.271933] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[84605.277748] br-lan: port 1(lan0) entered disabled state
[84606.821635] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[84606.830288] br-lan: port 1(lan0) entered blocking state
[84606.835543] br-lan: port 1(lan0) entered forwarding state
[84606.937444] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[84606.943287] br-lan: port 1(lan0) entered disabled state
[84608.585175] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[84608.594015] br-lan: port 1(lan0) entered blocking state
[84608.599268] br-lan: port 1(lan0) entered forwarding state
[84723.199129] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[84723.205091] br-lan: port 1(lan0) entered disabled state
[91091.410633] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[91091.419502] br-lan: port 1(lan0) entered blocking state
[91091.424748] br-lan: port 1(lan0) entered forwarding state
[100324.582594] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[100324.588496] br-lan: port 1(lan0) entered disabled state
[116182.193358] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[116182.202201] br-lan: port 1(lan0) entered blocking state
[116182.207538] br-lan: port 1(lan0) entered forwarding state
[130597.198358] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[130597.204252] br-lan: port 1(lan0) entered disabled state
[134262.275620] conntrack: generic helper won't handle protocol 47. Please consider loading the specific helper module.
[167388.742444] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[167388.751137] br-lan: port 1(lan0) entered blocking state
[167388.756485] br-lan: port 1(lan0) entered forwarding state
[167389.511532] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[167389.517498] br-lan: port 1(lan0) entered disabled state
[167391.171810] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[167391.180488] br-lan: port 1(lan0) entered blocking state
[167391.185827] br-lan: port 1(lan0) entered forwarding state
[167391.947803] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[167391.953724] br-lan: port 1(lan0) entered disabled state
[167394.595124] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[167394.603826] br-lan: port 1(lan0) entered blocking state
[167394.609171] br-lan: port 1(lan0) entered forwarding state
[167410.713443] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[167410.719411] br-lan: port 1(lan0) entered disabled state
[167414.025941] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[167414.034827] br-lan: port 1(lan0) entered blocking state
[167414.040172] br-lan: port 1(lan0) entered forwarding state
[188357.338347] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[188357.344401] br-lan: port 1(lan0) entered disabled state
[199428.959521] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[199428.968398] br-lan: port 1(lan0) entered blocking state
[199428.973734] br-lan: port 1(lan0) entered forwarding state
[201962.888206] ath10k_pci 0000:02:00.0: NIC rx-max-rate: 0 calculated-max: 0 rxnss_override: 0x80000000  nss160: 1  spatial-streams: 2
[215098.212961] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[215098.218869] br-lan: port 1(lan0) entered disabled state
[281396.542419] ath10k_pci 0000:02:00.0: NIC rx-max-rate: 0 calculated-max: 0 rxnss_override: 0x80000000  nss160: 1  spatial-streams: 2
[285242.188688] mv88e6085 f1072004.mdio-mii:10 lan3: Link is Up - 1Gbps/Full - flow control rx/tx
[285242.197419] br-vlan: port 1(lan3) entered blocking state
[285242.202844] br-vlan: port 1(lan3) entered forwarding state
[285242.218464] IPv6: ADDRCONF(NETDEV_CHANGE): br-vlan: link becomes ready
[285391.226410] mv88e6085 f1072004.mdio-mii:10 lan3: Link is Down
[285391.232312] br-vlan: port 1(lan3) entered disabled state
[285402.177838] ath10k_pci 0000:02:00.0: NIC rx-max-rate: 0 calculated-max: 0 rxnss_override: 0x80000000  nss160: 1  spatial-streams: 2
[287327.892966] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[287327.901823] br-lan: port 1(lan0) entered blocking state
[287327.907161] br-lan: port 1(lan0) entered forwarding state
[287328.584003] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[287328.589976] br-lan: port 1(lan0) entered disabled state
[287330.268315] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[287330.276986] br-lan: port 1(lan0) entered blocking state
[287330.282320] br-lan: port 1(lan0) entered forwarding state
[287331.056249] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[287331.062167] br-lan: port 1(lan0) entered disabled state
[287333.833592] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[287333.842277] br-lan: port 1(lan0) entered blocking state
[287333.847610] br-lan: port 1(lan0) entered forwarding state
[287350.051044] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[287350.056942] br-lan: port 1(lan0) entered disabled state
[287353.376014] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[287353.384864] br-lan: port 1(lan0) entered blocking state
[287353.390199] br-lan: port 1(lan0) entered forwarding state
[294941.726911] ath10k_pci 0000:02:00.0: NIC rx-max-rate: 0 calculated-max: 0 rxnss_override: 0x80000000  nss160: 1  spatial-streams: 2
[295005.749184] device lan3 left promiscuous mode
[295005.753764] br-vlan: port 1(lan3) entered disabled state
[295005.839289] IPv6: ADDRCONF(NETDEV_UP): lan3: link is not ready
[295005.915281] mv88e6085 f1072004.mdio-mii:10 lan3: configuring for phy/gmii link mode
[295005.944087] br-vlan: port 1(lan3) entered blocking state
[295005.949515] br-vlan: port 1(lan3) entered disabled state
[295005.964671] device lan3 entered promiscuous mode
[295005.977353] mv88e6085 f1072004.mdio-mii:10: p3: hw VLAN 1 already used by br-lan
[295005.991258] IPv6: ADDRCONF(NETDEV_UP): br-vlan: link is not ready
[295380.315201] mv88e6085 f1072004.mdio-mii:10 lan3: Link is Up - 100Mbps/Full - flow control rx/tx
[295380.324365] br-vlan: port 1(lan3) entered blocking state
[295380.329798] br-vlan: port 1(lan3) entered forwarding state
[295380.337523] IPv6: ADDRCONF(NETDEV_CHANGE): br-vlan: link becomes ready
[295403.981587] mv88e6085 f1072004.mdio-mii:10 lan3: Link is Down
[295403.987495] br-vlan: port 1(lan3) entered disabled state
[295407.717712] mv88e6085 f1072004.mdio-mii:10 lan3: Link is Up - 1Gbps/Full - flow control off
[295407.726249] br-vlan: port 1(lan3) entered blocking state
[295407.731669] br-vlan: port 1(lan3) entered forwarding state
[295408.942357] mv88e6085 f1072004.mdio-mii:10 lan3: Link is Down
[295408.948359] br-vlan: port 1(lan3) entered disabled state
[295413.906473] mv88e6085 f1072004.mdio-mii:10 lan3: Link is Up - 1Gbps/Full - flow control rx/tx
[295413.915185] br-vlan: port 1(lan3) entered blocking state
[295413.920622] br-vlan: port 1(lan3) entered forwarding state
[297157.381750] ath10k_pci 0000:02:00.0: NIC rx-max-rate: 0 calculated-max: 0 rxnss_override: 0x80000000  nss160: 1  spatial-streams: 2
[297170.149836] br-vlan: port 1(lan3) entered disabled state
[297170.160538] device lan3 left promiscuous mode
[297170.165065] br-vlan: port 1(lan3) entered disabled state
[297170.244568] mv88e6085 f1072004.mdio-mii:10 lan3: Link is Down
[297170.259278] IPv6: ADDRCONF(NETDEV_UP): lan3: link is not ready
[297170.382481] mv88e6085 f1072004.mdio-mii:10 lan3: configuring for phy/gmii link mode
[297170.390795] mv88e6085 f1072004.mdio-mii:10 lan3: Link is Up - 1Gbps/Full - flow control rx/tx
[297170.408209] br-vlan: port 1(lan3) entered blocking state
[297170.414240] br-vlan: port 1(lan3) entered disabled state
[297170.435357] device lan3 entered promiscuous mode
[297170.454239] mv88e6085 f1072004.mdio-mii:10: p3: hw VLAN 1 already used by br-lan
[297170.466082] br-vlan: port 1(lan3) entered blocking state
[297170.471515] br-vlan: port 1(lan3) entered forwarding state
[297878.791414] ath10k_pci 0000:02:00.0: NIC rx-max-rate: 0 calculated-max: 0 rxnss_override: 0x80000000  nss160: 1  spatial-streams: 2
[297937.893486] mv88e6085 f1072004.mdio-mii:10 lan3: Link is Down
[297937.899392] br-vlan: port 1(lan3) entered disabled state
[300788.671245] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[300788.677149] br-lan: port 1(lan0) entered disabled state
[331972.297884] ath10k_pci 0000:02:00.0: NIC rx-max-rate: 0 calculated-max: 0 rxnss_override: 0x80000000  nss160: 1  spatial-streams: 2
[352694.246570] ath10k_pci 0000:02:00.0: NIC rx-max-rate: 0 calculated-max: 0 rxnss_override: 0x80000000  nss160: 1  spatial-streams: 2
[359937.163539] ath10k_pci 0000:01:00.0: failed to wait for created wmi peer fc:f8:ae:47:d6:aa on vdev 1: -110
[359937.173315] ath10k_pci 0000:01:00.0: failed to add peer fc:f8:ae:47:d6:aa for vdev 1 when adding a new sta: -110
[373428.440458] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[373428.449124] br-lan: port 1(lan0) entered blocking state
[373428.454463] br-lan: port 1(lan0) entered forwarding state
[373429.208738] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[373429.214643] br-lan: port 1(lan0) entered disabled state
[373430.973385] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[373430.982114] br-lan: port 1(lan0) entered blocking state
[373430.987441] br-lan: port 1(lan0) entered forwarding state
[373431.750222] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[373431.756116] br-lan: port 1(lan0) entered disabled state
[373434.718345] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[373434.727018] br-lan: port 1(lan0) entered blocking state
[373434.732353] br-lan: port 1(lan0) entered forwarding state
[373450.527246] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[373450.533234] br-lan: port 1(lan0) entered disabled state
[373454.168638] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[373454.177476] br-lan: port 1(lan0) entered blocking state
[373454.182812] br-lan: port 1(lan0) entered forwarding state
[377913.806614] ath10k_pci 0000:02:00.0: NIC rx-max-rate: 0 calculated-max: 0 rxnss_override: 0x80000000  nss160: 1  spatial-streams: 2
[382577.797943] ath10k_pci 0000:01:00.0: failed to wait for created wmi peer 88:9e:33:e8:6a:8e on vdev 1: -110
[382577.807713] ath10k_pci 0000:01:00.0: failed to add peer 88:9e:33:e8:6a:8e for vdev 1 when adding a new sta: -110
[387081.488238] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[387081.494206] br-lan: port 1(lan0) entered disabled state
[420961.783025] ath10k_pci 0000:02:00.0: NIC rx-max-rate: 0 calculated-max: 0 rxnss_override: 0x80000000  nss160: 1  spatial-streams: 2
[457001.017258] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[457001.025953] br-lan: port 1(lan0) entered blocking state
[457001.031295] br-lan: port 1(lan0) entered forwarding state
[457001.894951] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[457001.901001] br-lan: port 1(lan0) entered disabled state
[457003.553788] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[457003.562493] br-lan: port 1(lan0) entered blocking state
[457003.567829] br-lan: port 1(lan0) entered forwarding state
[457004.322557] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[457004.328458] br-lan: port 1(lan0) entered disabled state
[457007.192627] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[457007.201300] br-lan: port 1(lan0) entered blocking state
[457007.206631] br-lan: port 1(lan0) entered forwarding state
[457023.555742] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[457023.561724] br-lan: port 1(lan0) entered disabled state
[457026.862461] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[457026.871390] br-lan: port 1(lan0) entered blocking state
[457026.876732] br-lan: port 1(lan0) entered forwarding state
[462982.221141] ath10k_pci 0000:02:00.0: NIC rx-max-rate: 0 calculated-max: 0 rxnss_override: 0x80000000  nss160: 1  spatial-streams: 2
[474805.313730] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[474805.319647] br-lan: port 1(lan0) entered disabled state
[507192.461408] ath10k_pci 0000:02:00.0: NIC rx-max-rate: 0 calculated-max: 0 rxnss_override: 0x80000000  nss160: 1  spatial-streams: 2
[524114.486164] ath10k_pci 0000:02:00.0: NIC rx-max-rate: 0 calculated-max: 0 rxnss_override: 0x80000000  nss160: 1  spatial-streams: 2
[535974.591683] mv88e6085 f1072004.mdio-mii:10 lan3: Link is Up - 100Mbps/Full - flow control rx/tx
[535974.600672] br-vlan: port 1(lan3) entered blocking state
[535974.606091] br-vlan: port 1(lan3) entered forwarding state
[535983.513284] mv88e6085 f1072004.mdio-mii:10 lan3: Link is Down
[535983.519287] br-vlan: port 1(lan3) entered disabled state
[535985.196908] mv88e6085 f1072004.mdio-mii:10 lan3: Link is Up - 100Mbps/Full - flow control rx/tx
[535985.205758] br-vlan: port 1(lan3) entered blocking state
[535985.211181] br-vlan: port 1(lan3) entered forwarding state
[535993.184587] mv88e6085 f1072004.mdio-mii:10 lan3: Link is Down
[535993.190488] br-vlan: port 1(lan3) entered disabled state
[535994.851470] mv88e6085 f1072004.mdio-mii:10 lan3: Link is Up - 100Mbps/Full - flow control rx/tx
[535994.860315] br-vlan: port 1(lan3) entered blocking state
[535994.865733] br-vlan: port 1(lan3) entered forwarding state
[536155.191653] ath10k_pci 0000:02:00.0: NIC rx-max-rate: 0 calculated-max: 0 rxnss_override: 0x80000000  nss160: 1  spatial-streams: 2
[536379.235091] mv88e6085 f1072004.mdio-mii:10 lan3: Link is Down
[536379.241037] br-vlan: port 1(lan3) entered disabled state
[543014.203932] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[543014.212709] br-lan: port 1(lan0) entered blocking state
[543014.218050] br-lan: port 1(lan0) entered forwarding state
[543014.976810] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[543014.982788] br-lan: port 1(lan0) entered disabled state
[543016.636738] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[543016.645459] br-lan: port 1(lan0) entered blocking state
[543016.650795] br-lan: port 1(lan0) entered forwarding state
[543017.298849] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[543017.304753] br-lan: port 1(lan0) entered disabled state
[543020.274477] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[543020.283173] br-lan: port 1(lan0) entered blocking state
[543020.288507] br-lan: port 1(lan0) entered forwarding state
[543036.557486] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[543036.563476] br-lan: port 1(lan0) entered disabled state
[543039.869495] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[543039.878405] br-lan: port 1(lan0) entered blocking state
[543039.883749] br-lan: port 1(lan0) entered forwarding state
[562837.273257] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[562837.279160] br-lan: port 1(lan0) entered disabled state
[601997.749629] ath10k_pci 0000:02:00.0: NIC rx-max-rate: 0 calculated-max: 0 rxnss_override: 0x80000000  nss160: 1  spatial-streams: 2
[602232.416930] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[602232.425612] br-lan: port 1(lan0) entered blocking state
[602232.430948] br-lan: port 1(lan0) entered forwarding state
[602233.192824] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[602233.198754] br-lan: port 1(lan0) entered disabled state
[602234.859914] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[602234.868633] br-lan: port 1(lan0) entered blocking state
[602234.873971] br-lan: port 1(lan0) entered forwarding state
[602235.522608] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[602235.528587] br-lan: port 1(lan0) entered disabled state
[602238.492398] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[602238.501205] br-lan: port 1(lan0) entered blocking state
[602238.506548] br-lan: port 1(lan0) entered forwarding state
[602254.003156] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[602254.009125] br-lan: port 1(lan0) entered disabled state
[602257.311178] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[602257.320019] br-lan: port 1(lan0) entered blocking state
[602257.325355] br-lan: port 1(lan0) entered forwarding state
[602371.043571] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[602371.049545] br-lan: port 1(lan0) entered disabled state
[602802.662208] mv88e6085 f1072004.mdio-mii:10 lan1: Link is Up - 100Mbps/Full - flow control off
[602802.670873] br-lan: port 2(lan1) entered blocking state
[602802.676213] br-lan: port 2(lan1) entered forwarding state
[602803.651555] mv88e6085 f1072004.mdio-mii:10 lan1: Link is Down
[602803.657517] br-lan: port 2(lan1) entered disabled state
[602806.547354] mv88e6085 f1072004.mdio-mii:10 lan1: Link is Up - 100Mbps/Full - flow control off
[602806.556033] br-lan: port 2(lan1) entered blocking state
[602806.561364] br-lan: port 2(lan1) entered forwarding state
[602807.691281] mv88e6085 f1072004.mdio-mii:10 lan1: Link is Down
[602807.697257] br-lan: port 2(lan1) entered disabled state
[602810.477001] mv88e6085 f1072004.mdio-mii:10 lan1: Link is Up - 100Mbps/Full - flow control off
[602810.485688] br-lan: port 2(lan1) entered blocking state
[602810.491022] br-lan: port 2(lan1) entered forwarding state
[602811.530327] mv88e6085 f1072004.mdio-mii:10 lan1: Link is Down
[602811.536268] br-lan: port 2(lan1) entered disabled state
[602817.167887] mv88e6085 f1072004.mdio-mii:10 lan1: Link is Up - 100Mbps/Full - flow control off
[602817.176727] br-lan: port 2(lan1) entered blocking state
[602817.182067] br-lan: port 2(lan1) entered forwarding state
[604031.415629] ath10k_pci 0000:02:00.0: NIC rx-max-rate: 0 calculated-max: 0 rxnss_override: 0x80000000  nss160: 1  spatial-streams: 2
[604152.138002] ath10k_pci 0000:02:00.0: NIC rx-max-rate: 0 calculated-max: 0 rxnss_override: 0x80000000  nss160: 1  spatial-streams: 2
[604153.620279] mv88e6085 f1072004.mdio-mii:10 lan1: Link is Down
[604153.626228] br-lan: port 2(lan1) entered disabled state
[610710.893292] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[610710.902138] br-lan: port 1(lan0) entered blocking state
[610710.907473] br-lan: port 1(lan0) entered forwarding state
[617477.183345] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[617477.189345] br-lan: port 1(lan0) entered disabled state
[627174.044977] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[627174.053824] br-lan: port 1(lan0) entered blocking state
[627174.059166] br-lan: port 1(lan0) entered forwarding state
[637082.684642] ath10k_pci 0000:02:00.0: NIC rx-max-rate: 0 calculated-max: 0 rxnss_override: 0x80000000  nss160: 1  spatial-streams: 2
[652872.121920] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[652872.127861] br-lan: port 1(lan0) entered disabled state
[696697.630508] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[696697.639375] br-lan: port 1(lan0) entered blocking state
[696697.644716] br-lan: port 1(lan0) entered forwarding state
[696698.297754] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[696698.303740] br-lan: port 1(lan0) entered disabled state
[696700.129446] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[696700.138157] br-lan: port 1(lan0) entered blocking state
[696700.143492] br-lan: port 1(lan0) entered forwarding state
[696700.837186] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[696700.843081] br-lan: port 1(lan0) entered disabled state
[696703.785595] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[696703.794303] br-lan: port 1(lan0) entered blocking state
[696703.799642] br-lan: port 1(lan0) entered forwarding state
[696719.721414] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[696719.727323] br-lan: port 1(lan0) entered disabled state
[696723.036100] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[696723.045047] br-lan: port 1(lan0) entered blocking state
[696723.050381] br-lan: port 1(lan0) entered forwarding state
[713929.355063] ath10k_pci 0000:02:00.0: NIC rx-max-rate: 0 calculated-max: 0 rxnss_override: 0x80000000  nss160: 1  spatial-streams: 2
[731673.010995] tpacket_rcv: packet too big, clamped from 58454 to 32638. macoff=82
[733219.904291] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[733219.910198] br-lan: port 1(lan0) entered disabled state
[763527.924242] ath10k_pci 0000:02:00.0: NIC rx-max-rate: 0 calculated-max: 0 rxnss_override: 0x80000000  nss160: 1  spatial-streams: 2
[779236.317240] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[779236.325911] br-lan: port 1(lan0) entered blocking state
[779236.331241] br-lan: port 1(lan0) entered forwarding state
[779257.031231] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[779257.037211] br-lan: port 1(lan0) entered disabled state
[779258.576104] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[779258.584877] br-lan: port 1(lan0) entered blocking state
[779258.590216] br-lan: port 1(lan0) entered forwarding state
[779258.698246] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[779258.704277] br-lan: port 1(lan0) entered disabled state
[779260.352846] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[779260.361701] br-lan: port 1(lan0) entered blocking state
[779260.367032] br-lan: port 1(lan0) entered forwarding state
[781897.007982] mv88e6085 f1072004.mdio-mii:10 lan2: Link is Up - 100Mbps/Full - flow control off
[781897.016654] br-lan: port 3(lan2) entered blocking state
[781897.021980] br-lan: port 3(lan2) entered forwarding state
[781897.781411] mv88e6085 f1072004.mdio-mii:10 lan2: Link is Down
[781897.787311] br-lan: port 3(lan2) entered disabled state
[781899.546826] mv88e6085 f1072004.mdio-mii:10 lan2: Link is Up - 100Mbps/Full - flow control off
[781899.555759] br-lan: port 3(lan2) entered blocking state
[781899.561093] br-lan: port 3(lan2) entered forwarding state
[781900.314582] mv88e6085 f1072004.mdio-mii:10 lan2: Link is Down
[781900.320567] br-lan: port 3(lan2) entered disabled state
[781903.401063] mv88e6085 f1072004.mdio-mii:10 lan2: Link is Up - 100Mbps/Full - flow control off
[781903.409788] br-lan: port 3(lan2) entered blocking state
[781903.415130] br-lan: port 3(lan2) entered forwarding state
[781919.026035] mv88e6085 f1072004.mdio-mii:10 lan2: Link is Down
[781919.031924] br-lan: port 3(lan2) entered disabled state
[781922.356418] mv88e6085 f1072004.mdio-mii:10 lan2: Link is Up - 100Mbps/Full - flow control rx/tx
[781922.365322] br-lan: port 3(lan2) entered blocking state
[781922.370657] br-lan: port 3(lan2) entered forwarding state
[782105.247055] mv88e6085 f1072004.mdio-mii:10 lan2: Link is Down
[782105.253068] br-lan: port 3(lan2) entered disabled state
[782604.590344] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[782604.596319] br-lan: port 1(lan0) entered disabled state
[782894.615652] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[782894.624501] br-lan: port 1(lan0) entered blocking state
[782894.629838] br-lan: port 1(lan0) entered forwarding state
[782979.485972] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[782979.492137] br-lan: port 1(lan0) entered disabled state
[789074.322376] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[789074.331278] br-lan: port 1(lan0) entered blocking state
[789074.336613] br-lan: port 1(lan0) entered forwarding state
[789266.173127] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[789266.179143] br-lan: port 1(lan0) entered disabled state
[789480.340507] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[789480.349377] br-lan: port 1(lan0) entered blocking state
[789480.354717] br-lan: port 1(lan0) entered forwarding state
[789562.134370] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[789562.140377] br-lan: port 1(lan0) entered disabled state
[798053.797779] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[798053.806615] br-lan: port 1(lan0) entered blocking state
[798053.811955] br-lan: port 1(lan0) entered forwarding state
[798657.818861] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[798657.824787] br-lan: port 1(lan0) entered disabled state
[798759.498139] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[798759.506976] br-lan: port 1(lan0) entered blocking state
[798759.512313] br-lan: port 1(lan0) entered forwarding state
[798848.717664] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[798848.723563] br-lan: port 1(lan0) entered disabled state
[804010.000087] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[804010.008954] br-lan: port 1(lan0) entered blocking state
[804010.014287] br-lan: port 1(lan0) entered forwarding state
[819204.640285] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[819204.646230] br-lan: port 1(lan0) entered disabled state
[819213.209635] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[819213.218540] br-lan: port 1(lan0) entered blocking state
[819213.223878] br-lan: port 1(lan0) entered forwarding state
[819296.153720] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[819296.159631] br-lan: port 1(lan0) entered disabled state
[842399.331821] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[842399.342531] br-lan: port 1(lan0) entered blocking state
[842399.347876] br-lan: port 1(lan0) entered forwarding state
[843174.162857] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[843174.168839] br-lan: port 1(lan0) entered disabled state
[846327.991508] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[846328.028434] br-lan: port 1(lan0) entered blocking state
[846328.033776] br-lan: port 1(lan0) entered forwarding state
[846388.366287] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[846388.372215] br-lan: port 1(lan0) entered disabled state
[849089.192560] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[849089.201505] br-lan: port 1(lan0) entered blocking state
[849089.206842] br-lan: port 1(lan0) entered forwarding state
[849215.917523] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[849215.923469] br-lan: port 1(lan0) entered disabled state
[849234.880031] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[849234.888703] br-lan: port 1(lan0) entered blocking state
[849234.894040] br-lan: port 1(lan0) entered forwarding state
[849255.326632] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[849255.332535] br-lan: port 1(lan0) entered disabled state
[849256.928747] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[849256.937413] br-lan: port 1(lan0) entered blocking state
[849256.942748] br-lan: port 1(lan0) entered forwarding state
[849257.034257] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[849257.040154] br-lan: port 1(lan0) entered disabled state
[849258.751727] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[849258.760589] br-lan: port 1(lan0) entered blocking state
[849258.765933] br-lan: port 1(lan0) entered forwarding state
[849838.072005] ath10k_pci 0000:02:00.0: NIC rx-max-rate: 0 calculated-max: 0 rxnss_override: 0x80000000  nss160: 1  spatial-streams: 2
[849880.048979] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[849880.054971] br-lan: port 1(lan0) entered disabled state
[850008.970479] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control off
[850008.979387] br-lan: port 1(lan0) entered blocking state
[850008.984729] br-lan: port 1(lan0) entered forwarding state
[850009.089242] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[850009.095233] br-lan: port 1(lan0) entered disabled state
[850010.965141] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[850010.974027] br-lan: port 1(lan0) entered blocking state
[850010.979368] br-lan: port 1(lan0) entered forwarding state
[850098.018385] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[850098.024279] br-lan: port 1(lan0) entered disabled state
[851488.377264] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 100Mbps/Full - flow control rx/tx
[851488.386173] br-lan: port 1(lan0) entered blocking state
[851488.391511] br-lan: port 1(lan0) entered forwarding state
[851572.193338] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[851572.199321] br-lan: port 1(lan0) entered disabled state
And? He needs only info about wifi driver and that should be the same as on HBL.
Thank you for your help.
I’d tryed to find any difference between your boot and my.
But i don’t find any difference. so I don’t now why my Wifi don’t work!
I can not load any kernelmodules for the WiFi.
root@Router:/lib/modules# modprobe ath9k
4 modules could not be probed
  • ath9k
  • ath9k_common
  • ath9k_hw
  • mac80211
Since the update to TOS5 i can not load the mac80211 modul.
Blockquote
[680735.389653] vmap allocation for size 356352 failed: use vmalloc= to increase size
[680735.397809] modprobe: vmalloc: allocation failure: 352256 bytes, mode:0x14000c0(GFP_KERNEL), nodemask=(null)
[680735.407768] modprobe cpuset=/ mems_allowed=0
[680735.412139] CPU: 0 PID: 12942 Comm: modprobe Not tainted 4.14.172 #0
[680735.418593] Hardware name: Marvell Armada 380/385 (Device Tree)
[680735.424623] [] (unwind_backtrace) from [] (show_stack+0x10/0x14)
[680735.432475] [] (show_stack) from [] (dump_stack+0x94/0xa8)
[680735.439807] [] (dump_stack) from [] (warn_alloc+0xd0/0x190)
[680735.447226] [] (warn_alloc) from [] (__vmalloc_node_range+0x22c/0x238)
[680735.455598] [] (__vmalloc_node_range) from [] (module_alloc+0x4c/0x54)
[680735.463974] [] (module_alloc) from [] (load_module+0x9e4/0x2134)
[680735.471825] [] (load_module) from [] (SyS_init_module+0x148/0x198)
[680735.479851] [] (SyS_init_module) from [] (ret_fast_syscall+0x0/0x54)
[680735.488070] Mem-Info:
[680735.490468] active_anon:27454 inactive_anon:40004 isolated_anon:0
[680735.490468] active_file:100157 inactive_file:91920 isolated_file:0
[680735.490468] unevictable:0 dirty:36 writeback:0 unstable:0
[680735.490468] slab_reclaimable:4080 slab_unreclaimable:4248
[680735.490468] mapped:7240 shmem:27177 pagetables:413 bounce:0
[680735.490468] free:238316 free_pcp:400 free_cma:0
[680735.524624] Node 0 active_anon:109816kB inactive_anon:160016kB active_file:400628kB inactive_file:367680kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:28960kB dirty:144kB writeback:0kB shmem:108708kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no
[680735.548589] Normal free:26364kB min:16384kB low:20480kB high:24576kB active_anon:0kB inactive_anon:0kB active_file:332556kB inactive_file:334040kB unevictable:0kB writepending:144kB present:786432kB managed:757276kB mlocked:0kB kernel_stack:2088kB pagetables:1652kB bounce:0kB free_pcp:740kB local_pcp:116kB free_cma:0kB
[680735.576986] lowmem_reserve: 0 10240 10240
[680735.581275] HighMem free:926900kB min:512kB low:7600kB high:14688kB active_anon:109816kB inactive_anon:160016kB active_file:68072kB inactive_file:33640kB unevictable:0kB writepending:0kB present:1310720kB managed:1310720kB mlocked:0kB kernel_stack:0kB pagetables:0kB bounce:0kB free_pcp:860kB local_pcp:212kB free_cma:0kB
[680735.609767] lowmem_reserve: 0 0 0
[680735.613366] Normal: 11434kB (UME) 1158kB (UME) 21016kB (UME) 14132kB (UME) 8564kB (UME) 35128kB (UME) 10256kB (UME) 1512kB (E) 01024kB 02048kB 04096kB = 26356kB
[680735.628816] HighMem: 601
4kB (M) 90608kB (UM) 620116kB (M) 458132kB (UM) 268264kB (M) 1209128kB (M) 435256kB (UM) 189512kB (UM) 501024kB (M) 82048kB (M) 14096kB (M) = 926900kB
[680735.645487] 219528 total pagecache pages
[680735.649507] 283 pages in swap cache
[680735.653095] Swap cache stats: add 11086, delete 10803, find 4544/5748
[680735.659636] Free swap = 3969236kB
[680735.663134] Total swap = 3973588kB
[680735.666627] 524288 pages RAM
[680735.669598] 327680 pages HighMem/MovableOnly
[680735.673967] 7289 pages reserved
[680735.682942] vmap allocation for size 454656 failed: use vmalloc= to increase size
[680735.691265] modprobe: vmalloc: allocation failure: 450560 bytes, mode:0x14000c0(GFP_KERNEL), nodemask=(null)
[680735.701360] modprobe cpuset=/ mems_allowed=0
[680735.705747] CPU: 1 PID: 12942 Comm: modprobe Not tainted 4.14.172 #0
[680735.712202] Hardware name: Marvell Armada 380/385 (Device Tree)
[680735.718231] [] (unwind_backtrace) from [] (show_stack+0x10/0x14)
[680735.726083] [] (show_stack) from [] (dump_stack+0x94/0xa8)
[680735.733413] [] (dump_stack) from [] (warn_alloc+0xd0/0x190)
[680735.740832] [] (warn_alloc) from [] (__vmalloc_node_range+0x22c/0x238)
[680735.749205] [] (__vmalloc_node_range) from [] (module_alloc+0x4c/0x54)
[680735.757582] [] (module_alloc) from [] (load_module+0x9e4/0x2134)
[680735.765432] [] (load_module) from [] (SyS_init_module+0x148/0x198)
[680735.773458] [] (SyS_init_module) from [] (ret_fast_syscall+0x0/0x54)
Hello. I’m having problem with luci after omnia hbs -> hbt upgrade.
After reboot, when trying to go to /cgi-bin/luci/admin I get:
/usr/lib/lua/luci/controller/samba4.lua:10: attempt to call global 'view' (a nil value)
stack traceback:
	/usr/lib/lua/luci/controller/samba4.lua:10: in function 'v'
	/usr/lib/lua/luci/dispatcher.lua:621: in function 'createtree'
	/usr/lib/lua/luci/dispatcher.lua:266: in function 'dispatch'
	/usr/lib/lua/luci/dispatcher.lua:127: in function </usr/lib/lua/luci/dispatcher.lua:126>
My Updater in Foris works well on Turris 1.x, Omnia and MOX too.
I have just posted my DHCPv6 issue with TOS5 (HBT) in a separate thread. It’s annoying, but workable around.
yeah, reboot solved the issue.
Pkgupdate not working anymore.
ERROR:
inconsistent: Package fix-updater-v65.0-alternatives-update requires package updater-ng that is not available.
+ echo 'Updater execution exited with error. Please see previous output to know what went wrong.'
Viktor, are you fully aware that you are writing it to the Testing (HBT) thread? Your issues belong to HBK or HBL threads. Your posts will be removed as they were flagged. This error is not in HBT neither error with the Updater tab in Foris.
It was my mistake. Can you move it please?
Can anyone help me?
It is very terrible with no WLAN…
It is worth stressing this point, because I didn’t appear to understand the ramifications.
Yesterday I had updated from 3.11.16 to 5.0.0… but then overnight my Omnia appears to have “updated” to 4.0.5 (not at all successfully). I’ve just done the medkit update to 5.0.0 again… but this time taken the additional step of switch-branch hbt.
Just wanted to note that I upgraded to TOS 5.0 (HBT) 5 days ago (from 3.x, with factory reset, HW Turris Omnia).
It took a bit of tinkering to get all my settings back (lxc needed a bit of manual config editing), but now it looks to be running a lot better than before.
The one single exception: I also cannot get ath9k to load.
The module refuses to load, I have the same “vmap allocation failed” error as described above. ath10k is running fine though.
