Make switch-branch hbk again and wait for next fixes. Updater tab is still broken but pkgupdate works.
This morning update MOX Turris 5.0.0 HBK:
##### Oznámení o chybách #####
Updater selhal:
inconsistent: Package foris-ws requires package python3-ubus that is not available.
Thanks for reporting. This happened just for Turris MOX build. There were some issues with downloading dependencies for this file and I’ve just started a new build for Turris MOX.
Another error, MOX 5.0.0 HBK:
Oznámení o chybách
Updater selhal:
inconsistent: Requested package collectd-mod-ping that is not available.
I’m working on this one. Thanks.
Ok, the package should be there since this afternoon.
After updating to 5.0.0
, when I run:
$ pkgupdate
I see:
INFO:Target Turris OS: 5.0.0
ERROR:
inconsistent: Package python3-flask requires package python3-werkzeug that is not available.
How can I fix that? I would like pkgupdate
to finish…
May I know which router are you using?
I see that both packages are present in HBS (Stable), HBT (Testing), HBK for all of our routers.
Turris 1.0 & Turris 1.1:
HBS and HBT are for now same until we release a new version in Testing branch:
https://repo.turris.cz/hbs/turris1x/packages/packages/python3-flask_1.0.3-3.7-1_powerpc_8540.ipk
https://repo.turris.cz/hbs/turris1x/packages/packages/python3-werkzeug_0.15.2-3.7-1_powerpc_8540.ipk
HBK:
https://repo.turris.cz/hbk/turris1x/packages/packages/python3-flask_1.0.3-3.7-1_powerpc_8540.ipk
https://repo.turris.cz/hbk/turris1x/packages/packages/python3-werkzeug_0.15.2-3.7-1_powerpc_8540.ipk
Turris Omnia:
Stable and Testing:
https://repo.turris.cz/hbs/omnia/packages/packages/python3-flask_1.0.3-3.7-1_arm_cortex-a9_vfpv3-d16.ipk
Turris MOX:
Stable and Testing:
https://repo.turris.cz/hbs/mox/packages/packages/python3-werkzeug_0.15.2-3.7-1_aarch64_cortex-a53.ipk
https://repo.turris.cz/hbs/mox/packages/packages/python3-flask_1.0.3-3.7-1_aarch64_cortex-a53.ipk
HBK:
https://repo.turris.cz/hbk/mox/packages/packages/python3-flask_1.0.3-3.7-1_aarch64_cortex-a53.ipk
Flask is being used by reForis and werkzeug is dependency for python3-flask, so we would notice that if those packages are missing.
I am using Turris Omnia (hbk branch). It looks like the packages were pulled in with an update that happened 2 hours ago. They did not show up with opkg find
before…
Yeah, I found that much and it was really confusing to me why it would happen that the packages were missing (opkg
correctly reported these dependencies). I did do opkg install reforis
before, so I am wondering it ended up in some half-assed state or what.
So, problem fixed. Thanks for your help.
