We released a new beta8 version of Turris OS 4.0 for Turris Omnia and Turris MOX. This release contains mostly several security fixes in kernel, subversion, clamav, mariadb also there are updated packages like Nextcloud, Unbound, Foris, sentinel-certgen, …
subversion: fix for CVE-2018-11782, CVE-2019-0203, CVE-2018-11803
kernel: fix for CVE-2019-3846, CVE-2019-3900, CVE-2019-13648, CVE-2019-10207
When you are using previous Turris OS 4.0 beta7 release and if you are not using approvals, you should be updated to this version automatically. If you do, there will be waiting for you a notification in Updater tab to approve the update.
If you would like to try this release instead of Turris OS 3.x release on Turris Omnia and start from scratch, you need to download medkit to USB flash drive, which will be formatted on EXT2/3/4. Don’t extract it and plug it to the Turris Omnia router and by using re-flash method (4 LED), it will erase all the data from the current operating system including and write there a new operating system Turris OS 4.0.
We are looking forward to receiving your feedback for this release.
There are two 2 ethernet controllers on CPU connected to switch chip. Only one of two ethernet ports between CPU and switch is in use as kernel DSA subsystem does not support multiCPU, yet. WAN / SFP and all LAN ports are working.
Turris 1.x specific
Currently not working because of kernel issues. Please do not test this release on Turris 1.x.
Since update to TOS 4.0 beta8 on my Turris Omnia I get errors for my “VPN policy based routing”:
Blockquote
Aug 9 03:28:33 turris vpn-policy-routing [5716]: Routing ‘Client’ via VPN_client [✓]
Aug 9 03:28:34 turris vpn-policy-routing [5716]: Routing ‘IP_Range’ via wan [✓]
Aug 9 03:28:34 turris vpn-policy-routing [5716]: service started on wan/185.XXX.XX.1 with errors [✗]
Aug 9 03:28:34 turris vpn-policy-routing [5716]: ERROR: Failed to set up ‘VPN_client/10.XX.XX.62 peer 10.XX.XX.61’
Aug 9 03:28:34 turris vpn-policy-routing [5716]: service monitoring interfaces: wan VPN_client [✓]
Up to beta 7 it was working without issues. Anybody also using VPN PBR with Turris Omnia and bete8?
I tried that already. All didn’t help. The tun0 interface is up and I also get the VPN IP for the client routed over the VPN, but I don’t know if the traffic is correctly only going over the VPN due to the error of VPN PBR
thanks for the update, can confirm that the dns-testing on foris is working again…still got 2 errors in the logs since i switched to beta even on a fresh reset:
1. keep 99-dhcp_host_domain_ng.py: DHCP unknown update operation
followed by a message like this for every fixed dhcp lease i set in luci:
Please, don’t confuse others with multiple issues. The second one is completely irrelevant. It is about to switch notification time in local timezone instead of UTC. Notifications all the time shows the correct time instead of some processes in the log file.
