noted some hickups with the timestamp in syslog…any ideas to fix that?
Jun 26 12:26:46 turris kernel:
Jun 26 10:26:46 turris netifd:
Jun 26 10:26:47 turris adblock-nce started :
Jun 26 12:26:47 turris kernel:
Jun 26 10:26:47 turris netifd:
Jun 26 10:26:48 turris firewall:
Jun 26 10:26:51 turris firewall:
Jun 26 10:26:54 turris ddns-scripts[1596]:
Jun 26 10:26:55 turris ddns-scripts[1596]:
Jun 26 10:27:01 turris /usr/sbin/cron[2767]:
Jun 26 10:27:07 turris kresd[1534]:
Jun 26 10:28:01 turris /usr/sbin/cron[2921]:
Jun 26 10:29:01 turris /usr/sbin/cron[3033]:
Jun 26 10:30:01 turris /usr/sbin/cron[3150]:
Jun 26 10:30:01 turris /usr/sbin/cron[3149]:
Jun 26 10:30:01 turris /usr/sbin/cron[3151]:
Jun 26 12:30:43 turris dnsmasq-dhcp[32222]:
Jun 26 10:31:01 turris /usr/sbin/cron[3293]:
But did you test that? My point is with DSA re-using the “normal” tools for switch configuration bridging an untagged interface, say LAN1 with say LAN4.4 could be one way to express untagged LAN1, but I have not tested that myself (I keep my home-network as simple as possible, which means I use VLAN tags rarely, and on my “toy” omnia I have not had use for any LAN VLAN tagging at all yet, so I really am guessing here; feel free to not take this too seriously).
What DSA does is that ports going out of switch are managed the same way in system as PHY directly connected to CPU. That means that VID and packet delivery works the same way as on any other Linux box. There is plenty of tutorial and explanation on how network works on Linux and how to configure it. You don’t have to look for DSA it self. If you know how to configure network on Linux you know how to use DSA in general.
Not sure why this now being referred to the management of the network stack in some other Linux systems when the matter at hand being DSA on TOS?
Could you be so kind to simply explain your laymen user base, that was able to get VID with untag state when managed by swconfig, of how to achieve a VID other than the default 1 with untag state now that it is DSA?
It is considered good practice to move traffic off the default VLAN where possible, in order to minimise the extent to which an unconfigured switch port would give access to the network.
This does not mean that a network which uses the default VLAN is necessarily insecure, and vacating it may not be feasible since some devices have functions that are hardwired to a VID of 1. However, if you have the opportunity to use a different VLAN then that is usually preferable.
TOS is based on Linux so Linux system management is skill you need. I don’t see why Linux management should be other matter all together in TOS management.
Please read up on Linux vlans. Those have to be enabled. You are reading snippets and concluding without really reading clearly. I am not here to teach you how networking works. I am telling you that it works the same way as if you would have plain old phy. I don’t see what that makes it unclear.
lan0 is untagged interface. There is no implicit VID on untagged interface. That simply does not make sense. The comment you posted is that if you enable 802.1q on interface and you do not specify VID then it uses 1. Yes but in that case you would see that it is VID 1. That is just implicit VID value. lan0 is not 802.1q. It is untagged base interface so not VID. Is that clear?
Nobody asked for it, simply the matter of untag state with a specific VID. I do not see what is so complicated about it?
That is whole point - VLAN is not enabled at all with the VID omitted. It is either:
enabled with tag state, or
disabled with untag state
but lacking (lost feature)
enabled with untag state
Yes it is clear, like you say it is not 802.1q. But if a user wants it to be 802.1q and appends the VID - it then automatically invokes the tag state - which not always wanted but instead the untag state is sought after?
It seems you are missing the point - maybe an example helps
VLAN enabled, VID 3 with port 2 in untag state. The transition script
*) append new_ifname “lan${port}” ;;
will disable VLAN (802.1q) when it omits the VID.
Anyway, if you do not see this being an issue then perhaps it is better to cease further discussion on the subject here in the beta thread and wait until TOS4.x hits release and see what happens to use cases like in the above sample.
I understand this, but this is more like low level functionality that I want/need. What I think is still missing in this thread is because I need it to solve this particular high level problem.
That is your perspective of how to weigh it plus also questioning of why the user wants that functionality in the first place, which I am not going to argue since VLAN enabled with untag state is quite a common deployment scenario as opposed to being termed a particular high level problem.
