Pepe
June 23, 2019, 1:46pm
1
Dear Turris users,
We are pleased to announce that we released Turris OS 4.0 - beta4! This release is for Turris Omnia and Turris MOX.
Changelog:
foris: fixed issue when English was the only language
php7: updated to 7.2.17
libxml2: updated to 2.9.9, fixed CVE-2018-14404
hostapd: fixed CVE-2019-949{4,5,6,7,8,9}, CVE-2019-11555
block-mount: fix restart of fstab service
When you are using our previous release Turris OS 4.0 beta3 , you should be updated to this version within a few hours automatically.
If you would like to give it try from Turris OS 3.x and start from scratch, you will need to download medkit and move it to the USB flash drive, insert it to the Turris Omnia and by using re-flash method (4 LEDs), it will erase all the current data which are stored on the router and it will write there system image from the USB flash drive.
We will appreciate any feedback regarding this release.
Update went without a problem. Foris is accessible.
viktor
June 24, 2019, 9:18am
4
Update from beta2 fine.
Following Managed devices instalation:
Error from 2019/06/24 11:11:28
turris-netboot-tools/postinst: udhcpc: started, v1.28.4
udhcpc: sending discover
udhcpc: no lease, failing
Downloading 'https://repo.turris.cz/hbs/netboot/mox-netboot-latest.tar.gz'
Connecting to 217.31.192.69:443
Writing to '/srv/turris-netboot/rootfs/rootfs-new.tar.gz'
/srv/turris-netboot/ 100% |*******************************| 41713k 0:00:00 ETA
Download completed (42714725 bytes)
Downloading 'https://repo.turris.cz/hbs/netboot/mox-netboot-latest.tar.gz.sha256'
Writing to '/srv/turris-netboot/rootfs/rootfs-new.tar.gz.sha256'
/srv/turris-netboot/ 100% |*******************************| 98 0:00:00 ETA
Download completed (98 bytes)
Downloading 'https://repo.turris.cz/hbs/netboot/mox-netboot-latest.tar.gz.sig'
Writing to '/srv/turris-netboot/rootfs/rootfs-new.tar.gz.sig'
/srv/turris-netboot/ 100% |*******************************| 151 0:00:00 ETA
Download completed (151 bytes)
Cannot open file '/etc/opkg/keys//XXX' for reading
Generating public/private ed25519 key pair.
Created directory '/srv/turris-netboot/.ssh'.
Your identification has been saved in /srv/turris-netboot/.ssh/reg_key.
Your public key has been saved in /srv/turris-netboot/.ssh/reg_key.pub.
The key fingerprint is:
SHA256:XXX registration_key
The key's randomart image is:
+--[ED25519 256]--+
| .++ =o. |
| .o.*=+o.. |
| oo=+=oo |
| . o.+.o+ |
| S oooo o |
| Eo.o.+ o|
| ooo.= |
| . +=o.|
| ..+==oo|
+----[SHA256]-----+
rootfs-new.tar.gz: OK
Tampered tarball
n1ete
June 24, 2019, 1:50pm
5
keep up the great work turris team!
found a small syntax bug when reloading kresd should i create an PR?
root@turris:~# /etc/init.d/kresd restart
loading file from ... /etc/resolver/dns_servers/99_google.conf
print_dns_config 99_google.conf Google 0 8.8.8.8 2001:4860:4860::8888 1 1
ret_value_dns_load=
syntax error. Last token seen: +
Garbled time
Pepe
June 24, 2019, 1:56pm
6
There’s already created one:
n1ete
June 24, 2019, 2:54pm
7
ah didnt found it…
another question:
there are a few “mox netboot data config” -related packages
…can this be used for any netboot capable devices with custom netboot images?
ty
tac2
June 24, 2019, 8:18pm
8
Updated from beta3 without issues.
Mox A D sfp
Great work turris team!
It working really good.
In the meanwhile my provider enabled I a native ipv4 and ipv6 connection at the same time. Finally I could also resolved all ipv6 issues and it is working.
Thanks Turris Team for continuously improving the device.
ftmx
June 25, 2019, 12:43am
10
What does this mean in real life? Lower throughput on not working ports?
vcunat
June 25, 2019, 6:09am
11
If you don’t know what it’s about, I don’t expect you’d notice a difference. All external ports work, and 1 Gbit/s is still there.
ftmx
June 25, 2019, 11:08am
12
Well, I actually wanted to find out. Care to share a short summary?
Also downstream VLANs can logically be assigned only to one CPU port. Switch configuration via LuCI is not available.
ftmx
June 25, 2019, 11:24am
14
But, do VLAN’s still work if configured in /etc/config/network ?
Not sure really with swconfig dev switch0 show
priducing
Failed to connect to the switch. Use the “list” command to see which switches are available.
and swconfig list
comes up empty
Nones
June 25, 2019, 11:33am
16
And what about kernel issue on Turris 1.x?
Will be solved?
If so, when?
ftmx
June 25, 2019, 11:38am
17
Well, that is a bummer. Would the Turris team share their plans to fix this before the main release? I do need the VLAN functionality on the LAN ports…
It might be mistaken but it seems that the switch management/discovery has been moved to mdio-mi
which in TOS3.x I think is not.
kernel log showing stuff like
mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
mv88e6085 f1072004.mdio-mii:10 lan0 (uninitialized): PHY [mv88e6xxx-1:00] driver [Marvell 88E1540]
mv88e6085 f1072004.mdio-mii:10 lan0: configuring for phy/gmii link mode
mv88e6085 f1072004.mdio-mii:10: p0: hw VLAN 1 already used by
OpenWRT switched switch config from swconfig to DSA which is used by Turris OS 4.0. Turris team member cynerd explained it here:
So VLANS should work but configuration changed completely…
that seems to be reflected by kernel log entries
DSA: switch 0 0 parsed
DSA: tree 0 parsed
