With new LXC version and info in this thread:
I was able to switch to 4.0 branch (but with fast rollback option - I have 4.0 on SSD and 3.11 on MMC).
Most of things works. I still need to check why timezone config in foris is not working (the same exception as usual, but it may be my configuration), and one of my RPi’s does is unavailable via WiFi.
And not all leds blinks as required:)
Ok, first problem: my Aeon Labs Z-stick (kmod-usb-serial-cp210x) does not work.
It works on 3.11.x and on current Debian.
dmesg
[ 261.311281] usb 4-1: new full-speed USB device number 6 using xhci-hcd
[ 261.461429] usb 4-1: Device not responding to setup address.
[ 261.681375] usb 4-1: Device not responding to setup address.
[ 261.901288] usb 4-1: device not accepting address 6, error -71
[ 262.051279] usb 4-1: new full-speed USB device number 7 using xhci-hcd
[ 262.201425] usb 4-1: Device not responding to setup address.
[ 262.421371] usb 4-1: Device not responding to setup address.
[ 262.641280] usb 4-1: device not accepting address 7, error -71
[ 262.647218] usb usb4-port1: attempt power cycle
[ 263.361283] usb 4-1: new full-speed USB device number 8 using xhci-hcd
[ 263.367999] usb 4-1: Device not responding to setup address.
[ 263.591365] usb 4-1: Device not responding to setup address.
[ 263.811278] usb 4-1: device not accepting address 8, error -71
[ 263.961282] usb 4-1: new full-speed USB device number 9 using xhci-hcd
[ 263.968022] usb 4-1: Device not responding to setup address.
[ 264.191397] usb 4-1: Device not responding to setup address.
[ 264.411278] usb 4-1: device not accepting address 9, error -71
[ 264.417271] usb usb4-port1: unable to enumerate USB device
Any hints how to debug this?
Another issue:
dmesg
[ 1240.091340] ------------[ cut here ]------------
[ 1240.095990] WARNING: CPU: 1 PID: 5 at net/netfilter/core.c:393 __nf_unregister_net_hook+0x6c/0x2a0
[ 1240.104990] Modules linked in: ath9k(O) ath9k_common(O) qcserial pppoe ppp_async ath9k_hw(O) ath10k_pci(O) ath10k_core(O) ath(O) usb_wwan pppox ppp_generic nf_conntrack_ipv6 mac80211(O) iptable_nat ipt_REJECT ipt_MASQUERADE ebtable_nat ebtable_filter ebtable_broute cp210x cfg80211(O) xt_time xt_tcpudp xt_tcpmss xt_statistic xt_state xt_recent xt_nat xt_multiport xt_mark xt_mac xt_limit xt_length xt_hl xt_helper xt_ecn xt_dscp xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_TCPMSS xt_REDIRECT xt_LOG xt_HL xt_FLOWOFFLOAD xt_DSCP xt_CT xt_CLASSIFY usbserial slhc sch_cake(O) nf_reject_ipv4 nf_nat_redirect nf_nat_masquerade_ipv4 nf_conntrack_ipv4 nf_nat_ipv4 nf_nat_ftp nf_nat nf_log_ipv4 nf_flow_table_hw nf_flow_table nf_defrag_ipv6 nf_defrag_ipv4 nf_conntrack_rtcache nf_conntrack_netlink
[ 1240.176183] nf_conntrack_ftp nf_conntrack iptable_mangle iptable_filter ipt_ECN ip_tables ebtables ebt_vlan ebt_stp ebt_redirect ebt_pkttype ebt_mark_m ebt_mark ebt_limit ebt_among ebt_802_3 crc_ccitt compat(O) act_skbedit act_mirred em_u32 cls_u32 cls_tcindex cls_flow cls_route cls_fw sch_tbf sch_htb sch_hfsc sch_ingress i2c_mux_pca954x i2c_mux ledtrig_oneshot ledtrig_heartbeat ledtrig_gpio xt_set ip_set_list_set ip_set_hash_netiface ip_set_hash_netport ip_set_hash_netnet ip_set_hash_net ip_set_hash_netportnet ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6t_REJECT nf_reject_ipv6 nf_log_ipv6 nf_log_common ip6table_mangle ip6table_filter ip6_tables x_tables
[ 1240.246969] ifb sit ip6_tunnel tunnel6 tunnel4 ip_tunnel veth tun snd_compress snd_pcm_oss snd_mixer_oss snd_pcm snd_timer snd_rawmidi snd_seq_device snd_hwdep snd soundcore ledtrig_transient
[ 1240.264167] CPU: 1 PID: 5 Comm: kworker/u4:0 Tainted: G W O 4.14.128 #0
[ 1240.271754] Hardware name: Marvell Armada 380/385 (Device Tree)
[ 1240.277691] Workqueue: netns cleanup_net
[ 1240.281636] [] (unwind_backtrace) from [] (show_stack+0x10/0x14)
[ 1240.289403] [] (show_stack) from [] (dump_stack+0x88/0x9c)
[ 1240.296645] [] (dump_stack) from [] (__warn+0xe4/0x100)
[ 1240.303623] [] (__warn) from [] (warn_slowpath_null+0x20/0x28)
[ 1240.311215] [] (warn_slowpath_null) from [] (__nf_unregister_net_hook+0x6c/0x2a0)
[ 1240.320459] [] (__nf_unregister_net_hook) from [] (nf_unregister_net_hooks+0x1c/0x34)
[ 1240.330049] [] (nf_unregister_net_hooks) from [] (ops_exit_list+0x38/0x60)
[ 1240.338682] [] (ops_exit_list) from [] (cleanup_net+0x188/0x294)
[ 1240.346446] [] (cleanup_net) from [] (process_one_work+0x240/0x3d4)
[ 1240.354468] [] (process_one_work) from [] (worker_thread+0x330/0x560)
[ 1240.362667] [] (worker_thread) from [] (kthread+0x148/0x154)
[ 1240.370082] [] (kthread) from [] (ret_from_fork+0x14/0x2c)
[ 1240.377339] —[ end trace b6b4fe1c8c7c479f ]—
