I see! You seem quite interesting about what we’re doing. At least in reading our release notes on Gitlab/Github. I suggest you wait a little bit till I or somebody else will write it here as not everything what you can find in our source code was included in RC, which we released today or you may be a little bit disappointed.
Changes, which was included in this release was already mentioned by me.
Dovolím si psát česky, protože Turris 1.0 a tohle asi ang. nedám.
V listopadu 2017 jsem si sám zkompiloval utilitu tree a ručně nainstaloval na router.
root@turris:~# opkg info tree
Package: tree
Version: 1.7.0-1
Depends: libc, libgcc
Status: install user installed
Architecture: mpc85xx
Installed-Time: 1514896375
V souboru /etc/updater/conf.d/opkg-auto.lua
stále vidím položku Install ("tree")
Po včerejší instalaci poslední RC verze 3.11.3 (z 6.2.2019) dostávám hlášky:
Oznámení o chybách
Updater failed:
inconsistent: Requested package tree that is not available.
Proč to najednou začlo vyskakovat, když jiné věci doinstalované ručně jsou v klidu?
(např. nmap, links, cal, coreutils-*, wsdd2)
Díky…
That’s interesting. Would you please just send Updater diagnostics to tech.support@turris.cz, so we can look, what’s could be wrong?
Looking forward to hearing from you!
Při pokusu o odeslání dat na tech.support@turris.cz
dostanu tuto nepěknou odpověď:
This is the mail system at host ahop.smtp.cz.
I’m sorry to have to inform you that your message could not be delivered to one or more recipients. It’s attached below.
For further assistance, please send mail to postmaster.
If you do so, please include this problem report. You can delete your own text from the attached returned message.
The mail system
<tech.support@turris.cz>: host mail.nic.cz[217.31.204.67] said: 550 5.7.1
Blocked by SpamAssassin (in reply to end of DATA command)
EDIT: pomohlo vše zabalit ZIPem a poslat jako jeden soubor…
Thanks, we got your email, and we’ll look at it!
Thank you for reporting it! We looked at it, and it should be fixed in the upcoming RC version.
//EDIT: It doesn’t make it to upcoming RC, but it will make to the another.
Ano, opravu jsem dostal na mail, byla aplikováva a pomohlo to. Díky.
Changelog of Turris OS 3.11.3 RC3:
New feature:
- initial support for booting Turris MOX over network together with own dedicated Foris tab.
Package updates:
- unbound: update to version 1.9.0
- nextcloud: update to version 14.0.7
- youtube-dl: update to version 2019.02.08 (not yet upstreamed to OpenWrt)
This release could be interesting for Czech users as there is added support for MallTv.
Security updates:
- dovecot: update to version 2.3.4.1
- curl: update to version 7.64.0
- prosody: update to version 0.11.2 (not yet upstreamed to OpenWrt)
Known bugs:
Unfortunately to this release doesn’t make the fix for localrepo, which was said in this thread in Czech. Will be fixed in next RC.
update from rc2 to rc3 went ok, so far no particularly error spotted, except for unbound
throwing for upstream DoT
unbound-checkconf error: no name verification functionality in ssl library
version 1.9.0 was supposed to
Fix #4206: support openssl 1.0.2 for TLS hostname verification
Appears that been a porous promise however and requires a post release patch thus
Update also went without errors. But I occasinally started seeing Foris exceptions about guide status not existing (I’m sorry I haven’t copied the exact stack traces). I assume it has to do with the new first-time setup guide? The first time I saw it was after clicking “Reboot now” in the notification tab. The second time I saw it was on Netmetr page. After reload, the same page shows without a problem.
Then I tried to install the MOX net boot support, with this result:
lcollect-majordomo/postrm: /usr/lib/opkg/info//lcollect-majordomo.postrm: line 2: /etc/init.d/lcollect: not found
I’m testing sentinel if it can be related…
Again, I was too quick. I saw some page faults with netifd and minidlna (on Omnia 1GB):
Summary
02:37:48 warning pppd[8845]: Timeout waiting for PADO packets
02:37:49 err pppd[8845]: Unable to complete PPPoE Discovery
02:37:49 info pppd[8845]: Exit.
02:37:49 notice netifd[]: Interface 'wan' is now down
02:37:49 notice netifd[]: Interface 'wan' is disabled
02:37:49 warning kernel[]: [ 762.522200] netifd: page allocation failure: order:5, mode:0x24000c0
02:37:49 warning kernel[]: [ 762.522212] CPU: 1 PID: 32074 Comm: netifd Not tainted 4.4.172-7bc33afbb1b35f5830b2b1b42c9cd8a0-0 #1
02:37:49 warning kernel[]: [ 762.522216] Hardware name: Marvell Armada 380/385 (Device Tree)
02:37:49 warning kernel[]: [ 762.522219] Backtrace:
02:37:49 warning kernel[]: [ 762.522231] [<c001c50c>] (dump_backtrace) from [<c001c74c>] (show_stack+0x18/0x1c)
02:37:49 warning kernel[]: [ 762.522234] r6:00000000 r5:60000013 r4:c076ed28 r3:00000000
02:37:49 warning kernel[]: [ 762.522248] [<c001c734>] (show_stack) from [<c02ff660>] (dump_stack+0x98/0xac)
02:37:49 warning kernel[]: [ 762.522258] [<c02ff5c8>] (dump_stack) from [<c00af744>] (warn_alloc_failed+0xec/0x120)
02:37:49 warning kernel[]: [ 762.522261] r6:00000001 r5:00000005 r4:024000c0 r3:00000000
02:37:49 warning kernel[]: [ 762.522272] [<c00af65c>] (warn_alloc_failed) from [<c00b24bc>] (__alloc_pages_nodemask+0x91c/0xa50)
02:37:49 notice netifd[]: Interface 'wan' is enabled
02:37:49 notice netifd[]: Interface 'wan' is setting up now
02:37:49 notice netifd[]: Network device 'eth1' link is down
02:37:49 notice netifd[]: Interface 'wan' has link connectivity loss
02:37:49 warning kernel[]: [ 762.522275] r3:eaf8c000 r2:00000000
02:37:49 warning kernel[]: [ 762.522279] r6:c075ed5c r5:b6db6db7 r4:00000000
02:37:49 warning kernel[]: [ 762.522288] [<c00b1ba0>] (__alloc_pages_nodemask) from [<c0020834>] (__dma_alloc_buffer+0x34/0x18c)
02:37:49 warning kernel[]: [ 762.522291] r10:00011000 r9:00000001 r8:ef33e088 r7:024000c0 r6:00000005 r5:00011000
02:37:49 warning kernel[]: [ 762.522300] r4:ffffffff
02:37:49 warning kernel[]: [ 762.522306] [<c0020800>] (__dma_alloc_buffer) from [<c0020b44>] (__dma_alloc+0x1b8/0x22c)
02:37:49 warning kernel[]: [ 762.522308] r9:00000001 r8:ef33e088 r7:024000c0 r6:ef103810 r5:00000001 r4:ffffffff
02:37:49 warning kernel[]: [ 762.522320] [<c002098c>] (__dma_alloc) from [<c0020bf0>] (arm_coherent_dma_alloc+0x38/0x40)
02:37:49 warning kernel[]: [ 762.522323] r10:00010a00 r9:ef275c80 r8:c07642f8 r7:ef103810 r6:ef33e010 r5:00000040
02:37:49 warning kernel[]: [ 762.522331] r4:00000000
02:37:49 warning kernel[]: [ 762.522340] [<c0020bb8>] (arm_coherent_dma_alloc) from [<c0422148>] (mvneta_setup_txqs+0x390/0x3d8)
02:37:49 warning kernel[]: [ 762.522343] r4:ef33e050
02:37:49 warning kernel[]: [ 762.522350] [<c0421db8>] (mvneta_setup_txqs) from [<c04246c4>] (mvneta_open+0x2ac/0x440)
02:37:49 warning kernel[]: [ 762.522353] r10:0000c018 r9:0000c018 r8:ef275c80 r7:ef103810 r6:00000000 r5:ef275800
02:37:49 warning kernel[]: [ 762.522360] r4:ef275c80
02:37:49 warning kernel[]: [ 762.522370] [<c0424418>] (mvneta_open) from [<c04ab254>] (__dev_open+0xb0/0x114)
02:37:49 warning kernel[]: [ 762.522372] r10:00000000 r9:00000000 r8:00000000 r7:00001002 r6:ef275830 r5:c06d46cc
02:37:49 warning kernel[]: [ 762.522380] r4:ef275800
02:37:49 warning kernel[]: [ 762.522387] [<c04ab1a4>] (__dev_open) from [<c04ab510>] (__dev_change_flags+0x9c/0x160)
02:37:49 warning kernel[]: [ 762.522389] r7:00001002 r6:00000001 r5:00001003 r4:ef275800
02:37:49 warning kernel[]: [ 762.522400] [<c04ab474>] (__dev_change_flags) from [<c04ab5f4>] (dev_change_flags+0x20/0x50)
02:37:49 warning kernel[]: [ 762.522402] r8:00000000 r7:c06d46cc r6:00001002 r5:00000140 r4:ef275800 r3:00008914
02:37:49 warning kernel[]: [ 762.522414] [<c04ab5d4>] (dev_change_flags) from [<c04c18f0>] (dev_ifsioc+0x20c/0x314)
02:37:49 warning kernel[]: [ 762.522417] r8:eaf8dea8 r7:c06d46cc r6:eaf8dea8 r5:ef275800 r4:00008914 r3:00008914
02:37:49 warning kernel[]: [ 762.522427] [<c04c16e4>] (dev_ifsioc) from [<c04c1e0c>] (dev_ioctl+0x3a0/0x8b0)
02:37:49 warning kernel[]: [ 762.522429] r8:eaf8dea8 r7:bea30cf0 r6:00000000 r5:c0785e80 r4:00008914
02:37:49 warning kernel[]: [ 762.522441] [<c04c1a6c>] (dev_ioctl) from [<c048ca18>] (sock_ioctl+0x250/0x2f4)
02:37:49 warning kernel[]: [ 762.522444] r10:00000000 r9:bea30cf0 r8:ea411ca0 r7:c0785e80 r6:bea30cf0 r5:fffffdfd
02:37:49 warning kernel[]: [ 762.522452] r4:00008914
02:37:49 warning kernel[]: [ 762.522460] [<c048c7c8>] (sock_ioctl) from [<c010318c>] (do_vfs_ioctl+0x4b4/0x6ec)
02:37:49 warning kernel[]: [ 762.522462] r7:00008914 r6:bea30cf0 r5:d7a76180 r4:d7a76180
02:37:49 warning kernel[]: [ 762.522472] [<c0102cd8>] (do_vfs_ioctl) from [<c0103400>] (SyS_ioctl+0x3c/0x64)
02:37:49 warning kernel[]: [ 762.522475] r10:00000000 r9:eaf8c000 r8:00000006 r7:00008914 r6:bea30cf0 r5:d7a76180
02:37:49 warning kernel[]: [ 762.522482] r4:d7a76180
02:37:49 warning kernel[]: [ 762.522489] [<c01033c4>] (SyS_ioctl) from [<c0009d00>] (ret_fast_syscall+0x0/0x48)
02:37:49 warning kernel[]: [ 762.522492] r8:c0009ec4 r7:00000036 r6:00001003 r5:00001003 r4:0003b564 r3:bea30ce8
02:37:49 warning kernel[]: [ 762.522500] Mem-Info:
02:37:49 warning kernel[]: [ 762.522510] active_anon:119946 inactive_anon:3097 isolated_anon:0
02:37:49 warning kernel[]: [ 762.522510] active_file:48835 inactive_file:53092 isolated_file:7
02:37:49 warning kernel[]: [ 762.522510] unevictable:0 dirty:1924 writeback:0 unstable:0
02:37:49 warning kernel[]: [ 762.522510] slab_reclaimable:5933 slab_unreclaimable:3658
02:37:49 warning kernel[]: [ 762.522510] mapped:14508 shmem:6025 pagetables:1239 bounce:0
02:37:49 warning kernel[]: [ 762.522510] free:5131 free_pcp:15 free_cma:0
02:37:49 warning kernel[]: [ 762.522528] Normal free:18764kB min:3504kB low:4380kB high:5256kB active_anon:329880kB inactive_anon:8980kB active_file:149076kB inactive_file:154612kB unevictable:0kB isolated(anon):0kB isolated(file):28kB present:786432kB managed:768576kB mlocked:0kB dirty:5508kB writeback:0kB mapped:38104kB shmem:16524kB slab_reclaimable:23732kB slab_unreclaimable:14632kB kernel_stack:2408kB pagetables:4956kB unstable:0kB bounce:0kB free_pcp:8kB local_pcp:8kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
02:37:49 warning kernel[]: [ 762.522531] lowmem_reserve[]: 0 2048 2048
02:37:49 warning kernel[]: [ 762.522546] HighMem free:1760kB min:256kB low:552kB high:852kB active_anon:149904kB inactive_anon:3408kB active_file:46264kB inactive_file:57756kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:262144kB managed:262144kB mlocked:0kB dirty:2188kB writeback:0kB mapped:19928kB shmem:7576kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:52kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
02:37:49 warning kernel[]: [ 762.522549] lowmem_reserve[]: 0 0 0
02:37:49 warning kernel[]: [ 762.522554] Normal: 350*4kB (UME) 1184*8kB (UME) 293*16kB (UM) 76*32kB (UM) 13*64kB (U) 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 18824kB
02:37:49 warning kernel[]: [ 762.522575] HighMem: 378*4kB (UM) 31*8kB (UM) 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 1760kB
02:37:49 warning kernel[]: [ 762.522591] 107998 total pagecache pages
02:37:49 warning kernel[]: [ 762.522595] 0 pages in swap cache
02:37:49 warning kernel[]: [ 762.522598] Swap cache stats: add 0, delete 0, find 0/0
02:37:49 warning kernel[]: [ 762.522601] Free swap = 0kB
02:37:49 warning kernel[]: [ 762.522603] Total swap = 0kB
02:37:49 warning kernel[]: [ 762.522605] 262144 pages RAM
02:37:49 warning kernel[]: [ 762.522608] 65536 pages HighMem/MovableOnly
02:37:49 warning kernel[]: [ 762.522610] 4464 pages reserved
02:37:49 err kernel[]: [ 762.522621] mvneta f1034000.ethernet eth1: mvneta_setup_txqs: can't create txq=1
02:37:49 alert kernel[]: [ 762.534242] BUG: Bad page state in process netifd pfn:01730
02:37:49 emerg kernel[]: [ 762.539946] page:ef72d2c0 count:-1 mapcount:0 mapping: (null) index:0x0
02:37:49 emerg kernel[]: [ 762.546669] flags: 0x0()
02:37:49 alert kernel[]: [ 762.549229] page dumped because: nonzero _count
02:37:49 warning kernel[]: [ 762.553768] Modules linked in: qcserial option iptable_nat ip6table_nat ath9k usb_wwan rndis_host qmi_wwan pppoe nf_nat_pptp nf_nat_ipv6 nf_nat_ipv4 nf_nat_amanda nf_conntrack_pptp nf_conntrack_ipv6 nf_conntrack_ipv4 nf_conntrack_amanda ipt_REJECT ipt_MASQUERADE ftdi_sio ebtable_nat ebtable_filter ebtable_broute cdc_ether ath9k_common armada_thermal xt_time xt_tcpudp xt_tcpmss xt_statistic xt_state xt_socket xt_recent xt_nfacct xt_nat xt_multiport xt_mark xt_mac xt_limit xt_length xt_id xt_hl xt_helper xt_ecn xt_dscp xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_TPROXY xt_TCPMSS xt_REDIRECT xt_NFQUEUE xt_LOG xt_HL xt_DSCP xt_CT xt_CLASSIFY usbserial usbnet ums_usbat ums_sddr55 ums_sddr09 ums_karma ums_jumpshot ums_isd200 ums_freecom ums_datafab ums_cypress ums_alauda ts_kmp ts_fsm ts_bm thermal_sys pptp pppox ppp_mppe ppp_async nfnetlink_queue nfnetlink_acct nf_reject_ipv4 nf_nat_tftp nf_nat_snmp_basic nf_nat_sip nf_nat_redirect nf_nat_proto_gre nf_nat_masquerade_ipv4 nf_nat_irc nf_nat_h323 nf_nat_ftp nf_log_ipv4 nf_defrag_ipv6 nf_defrag_ipv4 nf_conntrack_tftp nf_conntrack_snmp nf_conntrack_sip nf_conntrack_rtcache nf_conntrack_proto_gre nf_conntrack_netlink nf_conntrack_irc nf_conntrack_h323 nf_conntrack_ftp nf_conntrack_broadcast mvsdio iptable_raw iptable_mangle iptable_filter ipt_ECN ip_tables hwmon ebtables ebt_vlan ebt_stp ebt_redirect ebt_pkttype ebt_mark_m ebt_mark ebt_limit ebt_among ebt_802_3 crc_ccitt cdc_wdm cdc_acm ath9k_hw fuse sch_teql sch_tbf sch_sfq sch_red sch_prio sch_pie sch_netem sch_htb sch_gred sch_fq sch_dsmark sch_codel em_text em_nbyte em_meta em_cmp cls_basic act_vlan act_police act_pedit act_nat act_ipt act_gact act_csum act_bpf act_skbedit act_mirred em_u32 cls_u32 cls_tcindex cls_flow cls_route cls_fw sch_hfsc sch_ingress ath10k_pci ath10k_core ath mac80211 cfg80211 compat ledtrig_usbdev ledtrig_oneshot xt_LED ledtrig_morse ledtrig_heartbeat ledtrig_gpio cryptodev xt_set ip_set_list_set ip_set_hash_netiface ip_set_hash_netport ip_set_hash_netnet ip_set_hash_net ip_set_hash_netportnet ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set ip6t_NPT ip6t_MASQUERADE nf_nat_masquerade_ipv6 nf_nat nf_conntrack ip6t_REJECT nf_reject_ipv6 nf_log_ipv6 nf_log_common ip6table_raw ip6table_mangle ip6table_filter ip6_tables pppoatm ppp_generic slhc nfsd nfsv3 msdos ip_gre gre ifb sit ip6_tunnel tunnel6 tunnel4 ip_tunnel veth tun snd_compress snd_pcm_oss snd_mixer_oss snd_pcm snd_timer snd_rawmidi snd_seq_device snd_hwdep snd input_core soundcore rxkad vfat fat udf crc_itu_t ntfs nfs_layout_nfsv41_files nfsv4 nfs auth_rpcgss oid_registry lockd sunrpc grace minix isofs hfsplus hfs cramfs configfs cifs autofs4 kafs af_rxrpc dns_resolver dm_crypt dm_mirror dm_region_hash dm_log dm_mod br2684 atm multipath fscache raid456 async_raid6_recov async_pq async_xor async_memcpy async_tx raid10 raid1 raid0 linear md_mod xt_NFLOG x_tables nfnetlink_log nfnetlink nls_utf8 nls_koi8_r nls_cp1255 nls_iso8859_6 nls_iso8859_2 nls_iso8859_15 nls_iso8859_13 nls_iso8859_1 nls_cp932 nls_cp866 nls_cp864 nls_cp862 nls_cp852 nls_cp850 nls_cp775 nls_cp437 nls_cp1251 nls_cp1250 xts algif_skcipher algif_hash af_alg sha512_generic sha256_generic sha1_generic seqiv jitterentropy_rng drbg pcbc md5 md4 marvell_cesa hmac gf128mul fcrypt ecb des_generic ctr cmac ccm cbc authenc xhci_plat_hcd xhci_pci xhci_hcd uhci_hcd ledtrig_transient ahci_platform uas xfs libcrc32c jfs f2fs exfat mii aead crypto_null
02:37:49 warning kernel[]: [ 762.554158] CPU: 1 PID: 9020 Comm: netifd Not tainted 4.4.172-7bc33afbb1b35f5830b2b1b42c9cd8a0-0 #1
02:37:49 warning kernel[]: [ 762.554163] Hardware name: Marvell Armada 380/385 (Device Tree)
02:37:49 warning kernel[]: [ 762.554165] Backtrace:
02:37:49 warning kernel[]: [ 762.554176] [<c001c50c>] (dump_backtrace) from [<c001c74c>] (show_stack+0x18/0x1c)
02:37:49 warning kernel[]: [ 762.554180] r6:00000000 r5:60000013 r4:c076ed28 r3:00000000
02:37:49 warning kernel[]: [ 762.554193] [<c001c734>] (show_stack) from [<c02ff660>] (dump_stack+0x98/0xac)
02:37:49 warning kernel[]: [ 762.554202] [<c02ff5c8>] (dump_stack) from [<c00ae5bc>] (bad_page+0xf0/0x150)
02:37:49 warning kernel[]: [ 762.554205] r6:c075e100 r5:c07a7a98 r4:c07a7a94 r3:00000006
02:37:49 warning kernel[]: [ 762.554216] [<c00ae4cc>] (bad_page) from [<c00b16f8>] (get_page_from_freelist+0x57c/0x924)
02:37:49 warning kernel[]: [ 762.554218] r10:00000001 r9:c0762100 r8:ef72d2c0 r7:2ef83000 r6:c075ed5c r5:c065231c
02:37:49 warning kernel[]: [ 762.554227] r4:c0652330 r3:00000001
02:37:49 warning kernel[]: [ 762.554234] [<c00b117c>] (get_page_from_freelist) from [<c00b1ccc>] (__alloc_pages_nodemask+0x12c/0xa50)
02:37:49 warning kernel[]: [ 762.554236] r10:00000002 r9:c0762b80 r8:02000200 r7:00000000 r6:c075ed5c r5:b6db6db7
02:37:49 warning kernel[]: [ 762.554244] r4:00000000
02:37:49 warning kernel[]: [ 762.554250] [<c00b1ba0>] (__alloc_pages_nodemask) from [<c00b2608>] (__get_free_pages+0x18/0x34)
02:37:49 warning kernel[]: [ 762.554252] r10:eb753240 r9:c162bda0 r8:eb6b0a80 r7:d319c8c0 r6:d319ca80 r5:c162bd10
02:37:49 warning kernel[]: [ 762.554260] r4:c6e2e540
02:37:49 warning kernel[]: [ 762.554267] [<c00b25f0>] (__get_free_pages) from [<c00d629c>] (exit_mmap+0xc0/0x1f0)
02:37:49 warning kernel[]: [ 762.554274] [<c00d61dc>] (exit_mmap) from [<c0026a30>] (mmput+0x48/0xfc)
02:37:49 warning kernel[]: [ 762.554276] r6:d319ca80 r5:00000000 r4:d319c8c0
02:37:49 warning kernel[]: [ 762.554287] [<c00269e8>] (mmput) from [<c00f8454>] (flush_old_exec+0x358/0x654)
02:37:49 warning kernel[]: [ 762.554290] r5:d319c8c0 r4:d31b8900
02:37:49 warning kernel[]: [ 762.554298] [<c00f80fc>] (flush_old_exec) from [<c01408bc>] (load_elf_binary+0x29c/0x128c)
02:37:49 warning kernel[]: [ 762.554301] r10:eb753240 r9:c162bda0 r8:eb6b0a80 r7:00000001 r6:c90c6d00 r5:00000034
02:37:49 warning kernel[]: [ 762.554309] r4:c0b1aa80
02:37:49 warning kernel[]: [ 762.554315] [<c0140620>] (load_elf_binary) from [<c00f7db4>] (search_binary_handler+0xac/0x268)
02:37:49 warning kernel[]: [ 762.554318] r10:00000001 r9:c07ad7a8 r8:c076b6b4 r7:fffffff8 r6:c07ad7a8 r5:c90c6d00
02:37:49 warning kernel[]: [ 762.554325] r4:c076bbb0
02:37:49 warning kernel[]: [ 762.554331] [<c00f7d08>] (search_binary_handler) from [<c013efd0>] (load_script+0x234/0x24c)
02:37:49 warning kernel[]: [ 762.554334] r10:00000001 r9:c07ad7a8 r8:c076b6b4 r7:fffffff8 r6:c07ad7a8 r5:c90c6d00
02:37:49 warning kernel[]: [ 762.554342] r4:c90c6d00 r3:c162a000
02:37:49 warning kernel[]: [ 762.554349] [<c013ed9c>] (load_script) from [<c00f7db4>] (search_binary_handler+0xac/0x268)
02:37:49 warning kernel[]: [ 762.554351] r4:c076bb94
02:37:49 warning kernel[]: [ 762.554358] [<c00f7d08>] (search_binary_handler) from [<c00f9050>] (do_execveat_common+0x534/0x614)
02:37:49 warning kernel[]: [ 762.554361] r10:d319ca80 r9:c0cf8540 r8:c90c6d00 r7:bea30ebc r6:0000233c r5:d31b8900
02:37:49 warning kernel[]: [ 762.554369] r4:e9a09000 r3:ca2c1298
02:37:49 warning kernel[]: [ 762.554376] [<c00f8b1c>] (do_execveat_common) from [<c00f9160>] (do_execve+0x30/0x38)
02:37:49 warning kernel[]: [ 762.554379] r10:00000000 r9:c162a000 r8:c0009ec4 r7:0000000b r6:bea30c84 r5:bea30c8c
02:37:49 warning kernel[]: [ 762.554387] r4:bea30ebc
02:37:49 warning kernel[]: [ 762.554394] [<c00f9130>] (do_execve) from [<c00f9388>] (SyS_execve+0x24/0x28)
02:37:49 warning kernel[]: [ 762.554400] [<c00f9364>] (SyS_execve) from [<c0009d00>] (ret_fast_syscall+0x0/0x48)
02:37:49 warning kernel[]: [ 762.554403] r5:bea30c8c r4:00000003
02:37:49 warning kernel[]: [ 762.554407] Disabling lock debugging due to kernel taint
02:37:49 alert kernel[]: [ 762.554411] BUG: Bad page state in process netifd pfn:0172f
02:37:49 emerg kernel[]: [ 762.560103] page:ef72d29c count:-1 mapcount:0 mapping: (null) index:0x0
02:37:49 emerg kernel[]: [ 762.566819] flags: 0x0()
02:37:49 alert kernel[]: [ 762.569374] page dumped because: nonzero _count
02:37:49 warning kernel[]: [ 762.573913] Modules linked in: qcserial option iptable_nat ip6table_nat ath9k usb_wwan rndis_host qmi_wwan pppoe nf_nat_pptp nf_nat_ipv6 nf_nat_ipv4 nf_nat_amanda nf_conntrack_pptp nf_conntrack_ipv6 nf_conntrack_ipv4 nf_conntrack_amanda ipt_REJECT ipt_MASQUERADE ftdi_sio ebtable_nat ebtable_filter ebtable_broute cdc_ether ath9k_common armada_thermal xt_time xt_tcpudp xt_tcpmss xt_statistic xt_state xt_socket xt_recent xt_nfacct xt_nat xt_multiport xt_mark xt_mac xt_limit xt_length xt_id xt_hl xt_helper xt_ecn xt_dscp xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_TPROXY xt_TCPMSS xt_REDIRECT xt_NFQUEUE xt_LOG xt_HL xt_DSCP xt_CT xt_CLASSIFY usbserial usbnet ums_usbat ums_sddr55 ums_sddr09 ums_karma ums_jumpshot ums_isd200 ums_freecom ums_datafab ums_cypress ums_alauda ts_kmp ts_fsm ts_bm thermal_sys pptp pppox ppp_mppe ppp_async nfnetlink_queue nfnetlink_acct nf_reject_ipv4 nf_nat_tftp nf_nat_snmp_basic nf_nat_sip nf_nat_redirect nf_nat_proto_gre nf_nat_masquerade_ipv4 nf_nat_irc nf_nat_h323 nf_nat_ftp nf_log_ipv4 nf_defrag_ipv6 nf_defrag_ipv4 nf_conntrack_tftp nf_conntrack_snmp nf_conntrack_sip nf_conntrack_rtcache nf_conntrack_proto_gre nf_conntrack_netlink nf_conntrack_irc nf_conntrack_h323 nf_conntrack_ftp nf_conntrack_broadcast mvsdio iptable_raw iptable_mangle iptable_filter ipt_ECN ip_tables hwmon ebtables ebt_vlan ebt_stp ebt_redirect ebt_pkttype ebt_mark_m ebt_mark ebt_limit ebt_among ebt_802_3 crc_ccitt cdc_wdm cdc_acm ath9k_hw fuse sch_teql sch_tbf sch_sfq sch_red sch_prio sch_pie sch_netem sch_htb sch_gred sch_fq sch_dsmark sch_codel em_text em_nbyte em_meta em_cmp cls_basic act_vlan act_police act_pedit act_nat act_ipt act_gact act_csum act_bpf act_skbedit act_mirred em_u32 cls_u32 cls_tcindex cls_flow cls_route cls_fw sch_hfsc sch_ingress ath10k_pci ath10k_core ath mac80211 cfg80211 compat ledtrig_usbdev ledtrig_oneshot xt_LED ledtrig_morse ledtrig_heartbeat ledtrig_gpio cryptodev xt_set ip_set_list_set ip_set_hash_netiface ip_set_hash_netport ip_set_hash_netnet ip_set_hash_net ip_set_hash_netportnet ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set ip6t_NPT ip6t_MASQUERADE nf_nat_masquerade_ipv6 nf_nat nf_conntrack ip6t_REJECT nf_reject_ipv6 nf_log_ipv6 nf_log_common ip6table_raw ip6table_mangle ip6table_filter ip6_tables pppoatm ppp_generic slhc nfsd nfsv3 msdos ip_gre gre ifb sit ip6_tunnel tunnel6 tunnel4 ip_tunnel veth tun snd_compress snd_pcm_oss snd_mixer_oss snd_pcm snd_timer snd_rawmidi snd_seq_device snd_hwdep snd input_core soundcore rxkad vfat fat udf crc_itu_t ntfs nfs_layout_nfsv41_files nfsv4 nfs auth_rpcgss oid_registry lockd sunrpc grace minix isofs hfsplus hfs cramfs configfs cifs autofs4 kafs af_rxrpc dns_resolver dm_crypt dm_mirror dm_region_hash dm_log dm_mod br2684 atm multipath fscache raid456 async_raid6_recov async_pq async_xor async_memcpy async_tx raid10 raid1 raid0 linear md_mod xt_NFLOG x_tables nfnetlink_log nfnetlink nls_utf8 nls_koi8_r nls_cp1255 nls_iso8859_6 nls_iso8859_2 nls_iso8859_15 nls_iso8859_13 nls_iso8859_1 nls_cp932 nls_cp866 nls_cp864 nls_cp862 nls_cp852 nls_cp850 nls_cp775 nls_cp437 nls_cp1251 nls_cp1250 xts algif_skcipher algif_hash af_alg sha512_generic sha256_generic sha1_generic seqiv jitterentropy_rng drbg pcbc md5 md4 marvell_cesa hmac gf128mul fcrypt ecb des_generic ctr cmac ccm cbc authenc xhci_plat_hcd xhci_pci xhci_hcd uhci_hcd ledtrig_transient ahci_platform uas xfs libcrc32c jfs f2fs exfat mii aead crypto_null
02:37:49 warning kernel[]: [ 762.574274] CPU: 1 PID: 9020 Comm: netifd Tainted: G B 4.4.172-7bc33afbb1b35f5830b2b1b42c9cd8a0-0 #1
02:37:49 warning kernel[]: [ 762.574278] Hardware name: Marvell Armada 380/385 (Device Tree)
02:37:49 warning kernel[]: [ 762.574280] Backtrace:
02:37:49 warning kernel[]: [ 762.574289] [<c001c50c>] (dump_backtrace) from [<c001c74c>] (show_stack+0x18/0x1c)
02:37:49 warning kernel[]: [ 762.574292] r6:00000000 r5:60000013 r4:c076ed28 r3:00000000
02:37:49 warning kernel[]: [ 762.574303] [<c001c734>] (show_stack) from [<c02ff660>] (dump_stack+0x98/0xac)
02:37:49 warning kernel[]: [ 762.574312] [<c02ff5c8>] (dump_stack) from [<c00ae5bc>] (bad_page+0xf0/0x150)
02:37:49 warning kernel[]: [ 762.574314] r6:c075ed5c r5:c065231c r4:c07a7a94 r3:00000006
02:37:49 warning kernel[]: [ 762.574325] [<c00ae4cc>] (bad_page) from [<c00b16f8>] (get_page_from_freelist+0x57c/0x924)
02:37:49 warning kernel[]: [ 762.574328] r10:00000001 r9:c0762100 r8:ef72d29c r7:2ef83000 r6:c075ed5c r5:c065231c
02:37:49 warning kernel[]: [ 762.574336] r4:c0652330 r3:00000001
02:37:49 warning kernel[]: [ 762.574343] [<c00b117c>] (get_page_from_freelist) from [<c00b1ccc>] (__alloc_pages_nodemask+0x12c/0xa50)
02:37:49 warning kernel[]: [ 762.574346] r10:00000002 r9:c0762b80 r8:02000200 r7:00000000 r6:c075ed5c r5:b6db6db7
02:37:49 warning kernel[]: [ 762.574353] r4:00000000
02:37:49 warning kernel[]: [ 762.574359] [<c00b1ba0>] (__alloc_pages_nodemask) from [<c00b2608>] (__get_free_pages+0x18/0x34)
02:37:49 warning kernel[]: [ 762.574361] r10:eb753240 r9:c162bda0 r8:eb6b0a80 r7:d319c8c0 r6:d319ca80 r5:c162bd10
02:37:49 warning kernel[]: [ 762.574369] r4:c6e2e540
02:37:49 warning kernel[]: [ 762.574375] [<c00b25f0>] (__get_free_pages) from [<c00d629c>] (exit_mmap+0xc0/0x1f0)
02:37:49 warning kernel[]: [ 762.574381] [<c00d61dc>] (exit_mmap) from [<c0026a30>] (mmput+0x48/0xfc)
02:37:49 warning kernel[]: [ 762.574383] r6:d319ca80 r5:00000000 r4:d319c8c0
02:37:49 warning kernel[]: [ 762.574393] [<c00269e8>] (mmput) from [<c00f8454>] (flush_old_exec+0x358/0x654)
02:37:49 warning kernel[]: [ 762.574395] r5:d319c8c0 r4:d31b8900
02:37:49 warning kernel[]: [ 762.574403] [<c00f80fc>] (flush_old_exec) from [<c01408bc>] (load_elf_binary+0x29c/0x128c)
02:37:49 warning kernel[]: [ 762.574406] r10:eb753240 r9:c162bda0 r8:eb6b0a80 r7:00000001 r6:c90c6d00 r5:00000034
02:37:49 warning kernel[]: [ 762.574414] r4:c0b1aa80
02:37:49 warning kernel[]: [ 762.574420] [<c0140620>] (load_elf_binary) from [<c00f7db4>] (search_binary_handler+0xac/0x268)
02:37:49 warning kernel[]: [ 762.574422] r10:00000001 r9:c07ad7a8 r8:c076b6b4 r7:fffffff8 r6:c07ad7a8 r5:c90c6d00
02:37:49 warning kernel[]: [ 762.574430] r4:c076bbb0
02:37:49 warning kernel[]: [ 762.574436] [<c00f7d08>] (search_binary_handler) from [<c013efd0>] (load_script+0x234/0x24c)
02:37:49 warning kernel[]: [ 762.574439] r10:00000001 r9:c07ad7a8 r8:c076b6b4 r7:fffffff8 r6:c07ad7a8 r5:c90c6d00
02:37:49 warning kernel[]: [ 762.574446] r4:c90c6d00 r3:c162a000
02:37:49 warning kernel[]: [ 762.574454] [<c013ed9c>] (load_script) from [<c00f7db4>] (search_binary_handler+0xac/0x268)
02:37:49 warning kernel[]: [ 762.574456] r4:c076bb94
02:37:49 warning kernel[]: [ 762.574463] [<c00f7d08>] (search_binary_handler) from [<c00f9050>] (do_execveat_common+0x534/0x614)
02:37:49 warning kernel[]: [ 762.574465] r10:d319ca80 r9:c0cf8540 r8:c90c6d00 r7:bea30ebc r6:0000233c r5:d31b8900
02:37:49 warning kernel[]: [ 762.574473] r4:e9a09000 r3:ca2c1298
02:37:49 warning kernel[]: [ 762.574481] [<c00f8b1c>] (do_execveat_common) from [<c00f9160>] (do_execve+0x30/0x38)
02:37:49 warning kernel[]: [ 762.574483] r10:00000000 r9:c162a000 r8:c0009ec4 r7:0000000b r6:bea30c84 r5:bea30c8c
02:37:49 warning kernel[]: [ 762.574491] r4:bea30ebc
02:37:49 warning kernel[]: [ 762.574498] [<c00f9130>] (do_execve) from [<c00f9388>] (SyS_execve+0x24/0x28)
02:37:49 warning kernel[]: [ 762.574504] [<c00f9364>] (SyS_execve) from [<c0009d00>] (ret_fast_syscall+0x0/0x48)
02:37:49 warning kernel[]: [ 762.574507] r5:bea30c8c r4:00000003
02:37:49 alert kernel[]: [ 762.574513] BUG: Bad page state in process netifd pfn:0172e
02:37:49 emerg kernel[]: [ 762.580200] page:ef72d278 count:-1 mapcount:0 mapping: (null) index:0x0
02:37:49 emerg kernel[]: [ 762.586923] flags: 0x0()
02:37:49 alert kernel[]: [ 762.589526] page dumped because: nonzero _count
02:37:49 warning kernel[]: [ 762.594132] Modules linked in: qcserial option iptable_nat ip6table_nat ath9k usb_wwan rndis_host qmi_wwan pppoe nf_nat_pptp nf_nat_ipv6 nf_nat_ipv4 nf_nat_amanda nf_conntrack_pptp nf_conntrack_ipv6 nf_conntrack_ipv4 nf_conntrack_amanda ipt_REJECT ipt_MASQUERADE ftdi_sio ebtable_nat ebtable_filter ebtable_broute cdc_ether ath9k_common armada_thermal xt_time xt_tcpudp xt_tcpmss xt_statistic xt_state xt_socket xt_recent xt_nfacct xt_nat xt_multiport xt_mark xt_mac xt_limit xt_length xt_id xt_hl xt_helper xt_ecn xt_dscp xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_TPROXY xt_TCPMSS xt_REDIRECT xt_NFQUEUE xt_LOG xt_HL xt_DSCP xt_CT xt_CLASSIFY usbserial usbnet ums_usbat ums_sddr55 ums_sddr09 ums_karma ums_jumpshot ums_isd200 ums_freecom ums_datafab ums_cypress ums_alauda ts_kmp ts_fsm ts_bm thermal_sys pptp pppox ppp_mppe ppp_async nfnetlink_queue nfnetlink_acct nf_reject_ipv4 nf_nat_tftp nf_nat_snmp_basic nf_nat_sip nf_nat_redirect nf_nat_proto_gre nf_nat_masquerade_ipv4 nf_nat_irc nf_nat_h323 nf_nat_ftp nf_log_ipv4 nf_defrag_ipv6 nf_defrag_ipv4 nf_conntrack_tftp nf_conntrack_snmp nf_conntrack_sip nf_conntrack_rtcache nf_conntrack_proto_gre nf_conntrack_netlink nf_conntrack_irc nf_conntrack_h323 nf_conntrack_ftp nf_conntrack_broadcast mvsdio iptable_raw iptable_mangle iptable_filter ipt_ECN ip_tables hwmon ebtables ebt_vlan ebt_stp ebt_redirect ebt_pkttype ebt_mark_m ebt_mark ebt_limit ebt_among ebt_802_3 crc_ccitt cdc_wdm cdc_acm ath9k_hw fuse sch_teql sch_tbf sch_sfq sch_red sch_prio sch_pie sch_netem sch_htb sch_gred sch_fq sch_dsmark sch_codel em_text em_nbyte em_meta em_cmp cls_basic act_vlan act_police act_pedit act_nat act_ipt act_gact act_csum act_bpf act_skbedit act_mirred em_u32 cls_u32 cls_tcindex cls_flow cls_route cls_fw sch_hfsc sch_ingress ath10k_pci ath10k_core ath mac80211 cfg80211 compat ledtrig_usbdev ledtrig_oneshot xt_LED ledtrig_morse ledtrig_heartbeat ledtrig_gpio cryptodev xt_set ip_set_list_set ip_set_hash_netiface ip_set_hash_netport ip_set_hash_netnet ip_set_hash_net ip_set_hash_netportnet ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set ip6t_NPT ip6t_MASQUERADE nf_nat_masquerade_ipv6 nf_nat nf_conntrack ip6t_REJECT nf_reject_ipv6 nf_log_ipv6 nf_log_common ip6table_raw ip6table_mangle ip6table_filter ip6_tables pppoatm ppp_generic slhc nfsd nfsv3 msdos ip_gre gre ifb sit ip6_tunnel tunnel6 tunnel4 ip_tunnel veth tun snd_compress snd_pcm_oss snd_mixer_oss snd_pcm snd_timer snd_rawmidi snd_seq_device snd_hwdep snd input_core soundcore rxkad vfat fat udf crc_itu_t ntfs nfs_layout_nfsv41_files nfsv4 nfs auth_rpcgss oid_registry lockd sunrpc grace minix isofs hfsplus hfs cramfs configfs cifs autofs4 kafs af_rxrpc dns_resolver dm_crypt dm_mirror dm_region_hash dm_log dm_mod br2684 atm multipath fscache raid456 async_raid6_recov async_pq async_xor async_memcpy async_tx raid10 raid1 raid0 linear md_mod xt_NFLOG x_tables nfnetlink_log nfnetlink nls_utf8 nls_koi8_r nls_cp1255 nls_iso8859_6 nls_iso8859_2 nls_iso8859_15 nls_iso8859_13 nls_iso8859_1 nls_cp932 nls_cp866 nls_cp864 nls_cp862 nls_cp852 nls_cp850 nls_cp775 nls_cp437 nls_cp1251 nls_cp1250 xts algif_skcipher algif_hash af_alg sha512_generic sha256_generic sha1_generic seqiv jitterentropy_rng drbg pcbc md5 md4 marvell_cesa hmac gf128mul fcrypt ecb des_generic ctr cmac ccm cbc authenc xhci_plat_hcd xhci_pci xhci_hcd uhci_hcd ledtrig_transient ahci_platform uas xfs libcrc32c jfs f2fs exfat mii aead crypto_null
02:37:49 warning kernel[]: [ 762.594561] CPU: 1 PID: 9020 Comm: netifd Tainted: G B 4.4.172-7bc33afbb1b35f5830b2b1b42c9cd8a0-0 #1
02:37:49 warning kernel[]: [ 762.594567] Hardware name: Marvell Armada 380/385 (Device Tree)
02:37:49 warning kernel[]: [ 762.594569] Backtrace:
02:37:49 warning kernel[]: [ 762.594581] [<c001c50c>] (dump_backtrace) from [<c001c74c>] (show_stack+0x18/0x1c)
02:37:49 warning kernel[]: [ 762.594584] r6:00000000 r5:60000013 r4:c076ed28 r3:00000000
02:37:49 warning kernel[]: [ 762.594597] [<c001c734>] (show_stack) from [<c02ff660>] (dump_stack+0x98/0xac)
02:37:49 warning kernel[]: [ 762.594607] [<c02ff5c8>] (dump_stack) from [<c00ae5bc>] (bad_page+0xf0/0x150)
02:37:49 warning kernel[]: [ 762.594609] r6:c075ed5c r5:c065231c r4:c07a7a94 r3:00000006
02:37:49 warning kernel[]: [ 762.594620] [<c00ae4cc>] (bad_page) from [<c00b16f8>] (get_page_from_freelist+0x57c/0x924)
02:37:49 warning kernel[]: [ 762.594622] r10:00000001 r9:c0762100 r8:ef72d278 r7:2ef83000 r6:c075ed5c r5:c065231c
02:37:49 warning kernel[]: [ 762.594631] r4:c0652330 r3:00000001
02:37:49 warning kernel[]: [ 762.594637] [<c00b117c>] (get_page_from_freelist) from [<c00b1ccc>] (__alloc_pages_nodemask+0x12c/0xa50)
02:37:49 warning kernel[]: [ 762.594640] r10:00000002 r9:c0762b80 r8:02000200 r7:00000000 r6:c075ed5c r5:b6db6db7
02:37:49 warning kernel[]: [ 762.594648] r4:00000000
02:37:49 warning kernel[]: [ 762.594653] [<c00b1ba0>] (__alloc_pages_nodemask) from [<c00b2608>] (__get_free_pages+0x18/0x34)
02:37:49 warning kernel[]: [ 762.594656] r10:eb753240 r9:c162bda0 r8:eb6b0a80 r7:d319c8c0 r6:d319ca80 r5:c162bd10
02:37:49 warning kernel[]: [ 762.594664] r4:c6e2e540
02:37:49 warning kernel[]: [ 762.594670] [<c00b25f0>] (__get_free_pages) from [<c00d629c>] (exit_mmap+0xc0/0x1f0)
02:37:49 warning kernel[]: [ 762.594677] [<c00d61dc>] (exit_mmap) from [<c0026a30>] (mmput+0x48/0xfc)
02:37:49 warning kernel[]: [ 762.594679] r6:d319ca80 r5:00000000 r4:d319c8c0
02:37:49 warning kernel[]: [ 762.594691] [<c00269e8>] (mmput) from [<c00f8454>] (flush_old_exec+0x358/0x654)
02:37:49 warning kernel[]: [ 762.594693] r5:d319c8c0 r4:d31b8900
02:37:49 warning kernel[]: [ 762.594701] [<c00f80fc>] (flush_old_exec) from [<c01408bc>] (load_elf_binary+0x29c/0x128c)
02:37:49 warning kernel[]: [ 762.594704] r10:eb753240 r9:c162bda0 r8:eb6b0a80 r7:00000001 r6:c90c6d00 r5:00000034
02:37:49 warning kernel[]: [ 762.594712] r4:c0b1aa80
02:37:49 warning kernel[]: [ 762.594718] [<c0140620>] (load_elf_binary) from [<c00f7db4>] (search_binary_handler+0xac/0x268)
02:37:49 warning kernel[]: [ 762.594721] r10:00000001 r9:c07ad7a8 r8:c076b6b4 r7:fffffff8 r6:c07ad7a8 r5:c90c6d00
02:37:49 warning kernel[]: [ 762.594728] r4:c076bbb0
02:37:49 warning kernel[]: [ 762.594734] [<c00f7d08>] (search_binary_handler) from [<c013efd0>] (load_script+0x234/0x24c)
02:37:49 warning kernel[]: [ 762.594737] r10:00000001 r9:c07ad7a8 r8:c076b6b4 r7:fffffff8 r6:c07ad7a8 r5:c90c6d00
02:37:49 warning kernel[]: [ 762.594745] r4:c90c6d00 r3:c162a000
02:37:49 warning kernel[]: [ 762.594752] [<c013ed9c>] (load_script) from [<c00f7db4>] (search_binary_handler+0xac/0x268)
02:37:49 warning kernel[]: [ 762.594754] r4:c076bb94
02:37:49 warning kernel[]: [ 762.594761] [<c00f7d08>] (search_binary_handler) from [<c00f9050>] (do_execveat_common+0x534/0x614)
02:37:49 warning kernel[]: [ 762.594763] r10:d319ca80 r9:c0cf8540 r8:c90c6d00 r7:bea30ebc r6:0000233c r5:d31b8900
02:37:49 warning kernel[]: [ 762.594771] r4:e9a09000 r3:ca2c1298
02:37:49 warning kernel[]: [ 762.594779] [<c00f8b1c>] (do_execveat_common) from [<c00f9160>] (do_execve+0x30/0x38)
02:37:49 warning kernel[]: [ 762.594781] r10:00000000 r9:c162a000 r8:c0009ec4 r7:0000000b r6:bea30c84 r5:bea30c8c
02:37:49 warning kernel[]: [ 762.594789] r4:bea30ebc
02:37:49 warning kernel[]: [ 762.594796] [<c00f9130>] (do_execve) from [<c00f9388>] (SyS_execve+0x24/0x28)
02:37:49 warning kernel[]: [ 762.594803] [<c00f9364>] (SyS_execve) from [<c0009d00>] (ret_fast_syscall+0x0/0x48)
02:37:49 warning kernel[]: [ 762.594805] r5:bea30c8c r4:00000003
02:37:49 err ucollect[9000]: Error from socat: 2019/02/09 02:37:49 socat[9022] E connect(5, AF=2 217.31.192.101:5679, 16): Network unreachable
02:37:49 warning ucollect[9000]: Remote closed the uplink api.turris.cz:5679, reconnecting
02:37:49 warning ucollect[9000]: epoll_wait on 4 interrupted, retry
02:37:49 warning ucollect[9000]: Reconnecting too often, waiting a little while
02:37:49 alert kernel[]: [ 762.616886] BUG: Bad page state in process minidlna pfn:01705
02:37:49 emerg kernel[]: [ 762.623119] page:ef72ccb4 count:-1 mapcount:0 mapping: (null) index:0x1
02:37:49 emerg kernel[]: [ 762.629873] flags: 0x0()
02:37:49 alert kernel[]: [ 762.632824] page dumped because: nonzero _count
02:37:49 warning kernel[]: [ 762.637435] Modules linked in: qcserial option iptable_nat ip6table_nat ath9k usb_wwan rndis_host qmi_wwan pppoe nf_nat_pptp nf_nat_ipv6 nf_nat_ipv4 nf_nat_amanda nf_conntrack_pptp nf_conntrack_ipv6 nf_conntrack_ipv4 nf_conntrack_amanda ipt_REJECT ipt_MASQUERADE ftdi_sio ebtable_nat ebtable_filter ebtable_broute cdc_ether ath9k_common armada_thermal xt_time xt_tcpudp xt_tcpmss xt_statistic xt_state xt_socket xt_recent xt_nfacct xt_nat xt_multiport xt_mark xt_mac xt_limit xt_length xt_id xt_hl xt_helper xt_ecn xt_dscp xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_TPROXY xt_TCPMSS xt_REDIRECT xt_NFQUEUE xt_LOG xt_HL xt_DSCP xt_CT xt_CLASSIFY usbserial usbnet ums_usbat ums_sddr55 ums_sddr09 ums_karma ums_jumpshot ums_isd200 ums_freecom ums_datafab ums_cypress ums_alauda ts_kmp ts_fsm ts_bm thermal_sys pptp pppox ppp_mppe ppp_async nfnetlink_queue nfnetlink_acct nf_reject_ipv4 nf_nat_tftp nf_nat_snmp_basic nf_nat_sip nf_nat_redirect nf_nat_proto_gre nf_nat_masquerade_ipv4 nf_nat_irc nf_nat_h323 nf_nat_ftp nf_log_ipv4 nf_defrag_ipv6 nf_defrag_ipv4 nf_conntrack_tftp nf_conntrack_snmp nf_conntrack_sip nf_conntrack_rtcache nf_conntrack_proto_gre nf_conntrack_netlink nf_conntrack_irc nf_conntrack_h323 nf_conntrack_ftp nf_conntrack_broadcast mvsdio iptable_raw iptable_mangle iptable_filter ipt_ECN ip_tables hwmon ebtables ebt_vlan ebt_stp ebt_redirect ebt_pkttype ebt_mark_m ebt_mark ebt_limit ebt_among ebt_802_3 crc_ccitt cdc_wdm cdc_acm ath9k_hw fuse sch_teql sch_tbf sch_sfq sch_red sch_prio sch_pie sch_netem sch_htb sch_gred sch_fq sch_dsmark sch_codel em_text em_nbyte em_meta em_cmp cls_basic act_vlan act_police act_pedit act_nat act_ipt act_gact act_csum act_bpf act_skbedit act_mirred em_u32 cls_u32 cls_tcindex cls_flow cls_route cls_fw sch_hfsc sch_ingress ath10k_pci ath10k_core ath mac80211 cfg80211 compat ledtrig_usbdev ledtrig_oneshot xt_LED ledtrig_morse ledtrig_heartbeat ledtrig_gpio cryptodev xt_set ip_set_list_set ip_set_hash_netiface ip_set_hash_netport ip_set_hash_netnet ip_set_hash_net ip_set_hash_netportnet ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set ip6t_NPT ip6t_MASQUERADE nf_nat_masquerade_ipv6 nf_nat nf_conntrack ip6t_REJECT nf_reject_ipv6 nf_log_ipv6 nf_log_common ip6table_raw ip6table_mangle ip6table_filter ip6_tables pppoatm ppp_generic slhc nfsd nfsv3 msdos ip_gre gre ifb sit ip6_tunnel tunnel6 tunnel4 ip_tunnel veth tun snd_compress snd_pcm_oss snd_mixer_oss snd_pcm snd_timer snd_rawmidi snd_seq_device snd_hwdep snd input_core soundcore rxkad vfat fat udf crc_itu_t ntfs nfs_layout_nfsv41_files nfsv4 nfs auth_rpcgss oid_registry lockd sunrpc grace minix isofs hfsplus hfs cramfs configfs cifs autofs4 kafs af_rxrpc dns_resolver dm_crypt dm_mirror dm_region_hash dm_log dm_mod br2684 atm multipath fscache raid456 async_raid6_recov async_pq async_xor async_memcpy async_tx raid10 raid1 raid0 linear md_mod xt_NFLOG x_tables nfnetlink_log nfnetlink nls_utf8 nls_koi8_r nls_cp1255 nls_iso8859_6 nls_iso8859_2 nls_iso8859_15 nls_iso8859_13 nls_iso8859_1 nls_cp932 nls_cp866 nls_cp864 nls_cp862 nls_cp852 nls_cp850 nls_cp775 nls_cp437 nls_cp1251 nls_cp1250 xts algif_skcipher algif_hash af_alg sha512_generic sha256_generic sha1_generic seqiv jitterentropy_rng drbg pcbc md5 md4 marvell_cesa hmac gf128mul fcrypt ecb des_generic ctr cmac ccm cbc authenc xhci_plat_hcd xhci_pci xhci_hcd uhci_hcd ledtrig_transient ahci_platform uas xfs libcrc32c jfs f2fs exfat mii aead crypto_null
02:37:49 warning kernel[]: [ 762.637832] CPU: 0 PID: 6005 Comm: minidlna Tainted: G B 4.4.172-7bc33afbb1b35f5830b2b1b42c9cd8a0-0 #1
02:37:49 warning kernel[]: [ 762.637836] Hardware name: Marvell Armada 380/385 (Device Tree)
02:37:49 warning kernel[]: [ 762.637839] Backtrace:
02:37:49 warning kernel[]: [ 762.637850] [<c001c50c>] (dump_backtrace) from [<c001c74c>] (show_stack+0x18/0x1c)
02:37:49 warning kernel[]: [ 762.637854] r6:00000000 r5:60000013 r4:c076ed28 r3:00000000
02:37:49 warning kernel[]: [ 762.637868] [<c001c734>] (show_stack) from [<c02ff660>] (dump_stack+0x98/0xac)
02:37:49 warning kernel[]: [ 762.637877] [<c02ff5c8>] (dump_stack) from [<c00ae5bc>] (bad_page+0xf0/0x150)
02:37:49 warning kernel[]: [ 762.637880] r6:00000070 r5:c065231c r4:c07a7a94 r3:00000006
02:37:49 warning kernel[]: [ 762.637891] [<c00ae4cc>] (bad_page) from [<c00b16f8>] (get_page_from_freelist+0x57c/0x924)
02:37:49 warning kernel[]: [ 762.637893] r10:00000001 r9:c0762100 r8:ef72ccb4 r7:2ef77000 r6:00000070 r5:c065231c
02:37:49 warning kernel[]: [ 762.637902] r4:c0652330 r3:00000001
02:37:49 warning kernel[]: [ 762.637909] [<c00b117c>] (get_page_from_freelist) from [<c00b1ccc>] (__alloc_pages_nodemask+0x12c/0xa50)
02:37:49 warning kernel[]: [ 762.637912] r10:00000002 r9:c0762b80 r8:024213ca r7:00000000 r6:c075ed5c r5:b6db6db7
02:37:49 warning kernel[]: [ 762.637920] r4:00000000
02:37:49 warning kernel[]: [ 762.637927] [<c00b1ba0>] (__alloc_pages_nodemask) from [<c00b6340>] (__do_page_cache_readahead+0x108/0x25c)
02:37:49 warning kernel[]: [ 762.637930] r10:eef494c4 r9:00000014 r8:00000040 r7:00000030 r6:00000030 r5:00000044
02:37:49 warning kernel[]: [ 762.637937] r4:00000030
02:37:49 warning kernel[]: [ 762.637944] [<c00b6238>] (__do_page_cache_readahead) from [<c00b65c4>] (ondemand_readahead+0x130/0x214)
02:37:49 warning kernel[]: [ 762.637946] r10:00000001 r9:00000001 r8:c811da80 r7:eef494c4 r6:00000400 r5:00000004
02:37:49 warning kernel[]: [ 762.637954] r4:c811dae8
02:37:49 warning kernel[]: [ 762.637961] [<c00b6494>] (ondemand_readahead) from [<c00b6728>] (page_cache_async_readahead+0x80/0x84)
02:37:49 warning kernel[]: [ 762.637963] r10:eef493e0 r9:e2548000 r8:c811da80 r7:00000004 r6:c811da80 r5:eef494c4
02:37:49 warning kernel[]: [ 762.637971] r4:c811dae8
02:37:49 warning kernel[]: [ 762.637978] [<c00b66a8>] (page_cache_async_readahead) from [<c00ac0d8>] (generic_file_read_iter+0x428/0x6ac)
02:37:49 warning kernel[]: [ 762.637980] r6:eef494c4 r5:efe50efc r4:00000001
02:37:49 warning kernel[]: [ 762.637990] [<c00abcb0>] (generic_file_read_iter) from [<c00f28c8>] (do_readv_writev+0x1ac/0x298)
02:37:49 warning kernel[]: [ 762.637993] r10:00000000 r9:be8cadb0 r8:00000000 r7:e2549ebc r6:00000000 r5:c811da80
02:37:49 warning kernel[]: [ 762.638000] r4:c00abcb0
02:37:49 warning kernel[]: [ 762.638006] [<c00f271c>] (do_readv_writev) from [<c00f29f8>] (vfs_readv+0x44/0x5c)
02:37:49 warning kernel[]: [ 762.638009] r9:be8cadb0 r8:00000002 r7:c811da80 r6:c811da80 r5:00000000 r4:be8cadb0
02:37:49 warning kernel[]: [ 762.638020] [<c00f29b4>] (vfs_readv) from [<c00f31a0>] (SyS_readv+0x44/0x98)
02:37:49 warning kernel[]: [ 762.638022] r4:00003fff
02:37:49 warning kernel[]: [ 762.638029] [<c00f315c>] (SyS_readv) from [<c0009d00>] (ret_fast_syscall+0x0/0x48)
02:37:49 warning kernel[]: [ 762.638031] r9:e2548000 r8:c0009ec4 r7:00000091 r6:be8cb207 r5:00000001 r4:033a0ec0
02:37:49 alert kernel[]: [ 762.638041] BUG: Bad page state in process minidlna pfn:01706
02:37:49 emerg kernel[]: [ 762.643926] page:ef72ccd8 count:-1 mapcount:0 mapping: (null) index:0x1
02:37:49 emerg kernel[]: [ 762.650682] flags: 0x0()
02:37:49 alert kernel[]: [ 762.653244] page dumped because: nonzero _count
02:37:49 warning kernel[]: [ 762.657800] Modules linked in: qcserial option iptable_nat ip6table_nat ath9k usb_wwan rndis_host qmi_wwan pppoe nf_nat_pptp nf_nat_ipv6 nf_nat_ipv4 nf_nat_amanda nf_conntrack_pptp nf_conntrack_ipv6 nf_conntrack_ipv4 nf_conntrack_amanda ipt_REJECT ipt_MASQUERADE ftdi_sio ebtable_nat ebtable_filter ebtable_broute cdc_ether ath9k_common armada_thermal xt_time xt_tcpudp xt_tcpmss xt_statistic xt_state xt_socket xt_recent xt_nfacct xt_nat xt_multiport xt_mark xt_mac xt_limit xt_length xt_id xt_hl xt_helper xt_ecn xt_dscp xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_TPROXY xt_TCPMSS xt_REDIRECT xt_NFQUEUE xt_LOG xt_HL xt_DSCP xt_CT xt_CLASSIFY usbserial usbnet ums_usbat ums_sddr55 ums_sddr09 ums_karma ums_jumpshot ums_isd200 ums_freecom ums_datafab ums_cypress ums_alauda ts_kmp ts_fsm ts_bm thermal_sys pptp pppox ppp_mppe ppp_async nfnetlink_queue nfnetlink_acct nf_reject_ipv4 nf_nat_tftp nf_nat_snmp_basic nf_nat_sip nf_nat_redirect nf_nat_proto_gre nf_nat_masquerade_ipv4 nf_nat_irc nf_nat_h323 nf_nat_ftp nf_log_ipv4 nf_defrag_ipv6 nf_defrag_ipv4 nf_conntrack_tftp nf_conntrack_snmp nf_conntrack_sip nf_conntrack_rtcache nf_conntrack_proto_gre nf_conntrack_netlink nf_conntrack_irc nf_conntrack_h323 nf_conntrack_ftp nf_conntrack_broadcast mvsdio iptable_raw iptable_mangle iptable_filter ipt_ECN ip_tables hwmon ebtables ebt_vlan ebt_stp ebt_redirect ebt_pkttype ebt_mark_m ebt_mark ebt_limit ebt_among ebt_802_3 crc_ccitt cdc_wdm cdc_acm ath9k_hw fuse sch_teql sch_tbf sch_sfq sch_red sch_prio sch_pie sch_netem sch_htb sch_gred sch_fq sch_dsmark sch_codel em_text em_nbyte em_meta em_cmp cls_basic act_vlan act_police act_pedit act_nat act_ipt act_gact act_csum act_bpf act_skbedit act_mirred em_u32 cls_u32 cls_tcindex cls_flow cls_route cls_fw sch_hfsc sch_ingress ath10k_pci ath10k_core ath mac80211 cfg80211 compat ledtrig_usbdev ledtrig_oneshot xt_LED ledtrig_morse ledtrig_heartbeat ledtrig_gpio cryptodev xt_set ip_set_list_set ip_set_hash_netiface ip_set_hash_netport ip_set_hash_netnet ip_set_hash_net ip_set_hash_netportnet ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set ip6t_NPT ip6t_MASQUERADE nf_nat_masquerade_ipv6 nf_nat nf_conntrack ip6t_REJECT nf_reject_ipv6 nf_log_ipv6 nf_log_common ip6table_raw ip6table_mangle ip6table_filter ip6_tables pppoatm ppp_generic slhc nfsd nfsv3 msdos ip_gre gre ifb sit ip6_tunnel tunnel6 tunnel4 ip_tunnel veth tun snd_compress snd_pcm_oss snd_mixer_oss snd_pcm snd_timer snd_rawmidi snd_seq_device snd_hwdep snd input_core soundcore rxkad vfat fat udf crc_itu_t ntfs nfs_layout_nfsv41_files nfsv4 nfs auth_rpcgss oid_registry lockd sunrpc grace minix isofs hfsplus hfs cramfs configfs cifs autofs4 kafs af_rxrpc dns_resolver dm_crypt dm_mirror dm_region_hash dm_log dm_mod br2684 atm multipath fscache raid456 async_raid6_recov async_pq async_xor async_memcpy async_tx raid10 raid1 raid0 linear md_mod xt_NFLOG x_tables nfnetlink_log nfnetlink nls_utf8 nls_koi8_r nls_cp1255 nls_iso8859_6 nls_iso8859_2 nls_iso8859_15 nls_iso8859_13 nls_iso8859_1 nls_cp932 nls_cp866 nls_cp864 nls_cp862 nls_cp852 nls_cp850 nls_cp775 nls_cp437 nls_cp1251 nls_cp1250 xts algif_skcipher algif_hash af_alg sha512_generic sha256_generic sha1_generic seqiv jitterentropy_rng drbg pcbc md5 md4 marvell_cesa hmac gf128mul fcrypt ecb des_generic ctr cmac ccm cbc authenc xhci_plat_hcd xhci_pci xhci_hcd uhci_hcd ledtrig_transient ahci_platform uas xfs libcrc32c jfs f2fs exfat mii aead crypto_null
02:37:49 warning kernel[]: [ 762.658173] CPU: 0 PID: 6005 Comm: minidlna Tainted: G B 4.4.172-7bc33afbb1b35f5830b2b1b42c9cd8a0-0 #1
02:37:49 warning kernel[]: [ 762.658177] Hardware name: Marvell Armada 380/385 (Device Tree)
02:37:49 warning kernel[]: [ 762.658179] Backtrace:
02:37:49 warning kernel[]: [ 762.658188] [<c001c50c>] (dump_backtrace) from [<c001c74c>] (show_stack+0x18/0x1c)
02:37:49 warning kernel[]: [ 762.658191] r6:00000000 r5:60000013 r4:c076ed28 r3:00000000
02:37:49 warning kernel[]: [ 762.658203] [<c001c734>] (show_stack) from [<c02ff660>] (dump_stack+0x98/0xac)
02:37:49 warning kernel[]: [ 762.658211] [<c02ff5c8>] (dump_stack) from [<c00ae5bc>] (bad_page+0xf0/0x150)
02:37:49 warning kernel[]: [ 762.658214] r6:00000070 r5:c065231c r4:c07a7a94 r3:00000006
02:37:49 warning kernel[]: [ 762.658224] [<c00ae4cc>] (bad_page) from [<c00b16f8>] (get_page_from_freelist+0x57c/0x924)
02:37:49 warning kernel[]: [ 762.658226] r10:00000001 r9:c0762100 r8:ef72ccd8 r7:2ef77000 r6:00000070 r5:c065231c
02:37:49 warning kernel[]: [ 762.658234] r4:c0652330 r3:00000001
02:37:49 warning kernel[]: [ 762.658241] [<c00b117c>] (get_page_from_freelist) from [<c00b1ccc>] (__alloc_pages_nodemask+0x12c/0xa50)
02:37:49 warning kernel[]: [ 762.658244] r10:00000002 r9:c0762b80 r8:024213ca r7:00000000 r6:c075ed5c r5:b6db6db7
02:37:49 warning kernel[]: [ 762.658252] r4:00000000
02:37:49 warning kernel[]: [ 762.658258] [<c00b1ba0>] (__alloc_pages_nodemask) from [<c00b6340>] (__do_page_cache_readahead+0x108/0x25c)
02:37:49 warning kernel[]: [ 762.658261] r10:eef494c4 r9:00000014 r8:00000040 r7:00000030 r6:00000030 r5:00000044
02:37:49 warning kernel[]: [ 762.658269] r4:00000030
02:37:49 warning kernel[]: [ 762.658275] [<c00b6238>] (__do_page_cache_readahead) from [<c00b65c4>] (ondemand_readahead+0x130/0x214)
02:37:49 warning kernel[]: [ 762.658277] r10:00000001 r9:00000001 r8:c811da80 r7:eef494c4 r6:00000400 r5:00000004
02:37:49 warning kernel[]: [ 762.658285] r4:c811dae8
02:37:49 warning kernel[]: [ 762.658291] [<c00b6494>] (ondemand_readahead) from [<c00b6728>] (page_cache_async_readahead+0x80/0x84)
02:37:49 warning kernel[]: [ 762.658294] r10:eef493e0 r9:e2548000 r8:c811da80 r7:00000004 r6:c811da80 r5:eef494c4
02:37:49 warning kernel[]: [ 762.658301] r4:c811dae8
02:37:49 warning kernel[]: [ 762.658308] [<c00b66a8>] (page_cache_async_readahead) from [<c00ac0d8>] (generic_file_read_iter+0x428/0x6ac)
02:37:49 warning kernel[]: [ 762.658310] r6:eef494c4 r5:efe50efc r4:00000001
02:37:49 warning kernel[]: [ 762.658319] [<c00abcb0>] (generic_file_read_iter) from [<c00f28c8>] (do_readv_writev+0x1ac/0x298)
02:37:49 warning kernel[]: [ 762.658322] r10:00000000 r9:be8cadb0 r8:00000000 r7:e2549ebc r6:00000000 r5:c811da80
02:37:49 warning kernel[]: [ 762.658330] r4:c00abcb0
02:37:49 warning kernel[]: [ 762.658335] [<c00f271c>] (do_readv_writev) from [<c00f29f8>] (vfs_readv+0x44/0x5c)
02:37:49 warning kernel[]: [ 762.658338] r9:be8cadb0 r8:00000002 r7:c811da80 r6:c811da80 r5:00000000 r4:be8cadb0
02:37:49 warning kernel[]: [ 762.658349] [<c00f29b4>] (vfs_readv) from [<c00f31a0>] (SyS_readv+0x44/0x98)
02:37:49 warning kernel[]: [ 762.658351] r4:00003fff
02:37:49 warning kernel[]: [ 762.658358] [<c00f315c>] (SyS_readv) from [<c0009d00>] (ret_fast_syscall+0x0/0x48)
02:37:49 warning kernel[]: [ 762.658360] r9:e2548000 r8:c0009ec4 r7:00000091 r6:be8cb207 r5:00000001 r4:033a0ec0
Update to RC3 without any problem. Then I tried press Save on Data collection tab (don’t ask me why … ) and it does not work properly.
File “/usr/lib/python3.6/site-packages/foris_controller/message_router.py”, line 114, in process_message
data = module_instance.perform_action(message[“action”], message.get(“data”, {}))
File “/usr/lib/python3.6/site-packages/foris_controller/module_base.py”, line 60, in perform_action
res = action_function(data)
File “/usr/lib/python3.6/site-packages/foris_controller_modules/data_collect/init.py”, line 56, in action_set
res = self.handler.set_agreed(data[“agreed”])
File “/usr/lib/python3.6/site-packages/foris_controller/utils.py”, line 111, in inner
res = func(*args, **kwargs)
File “/usr/lib/python3.6/site-packages/foris_controller_modules/data_collect/handlers/openwrt.py”, line 69, in set_agreed
return self.uci.set_agreed(agreed)
File “/usr/lib/python3.6/site-packages/foris_controller_backends/data_collect/init.py”, line 121, in set_agreed
services.enable(“ucollect”)
File “/usr/lib/python3.6/site-packages/foris_controller_backends/services/init.py”, line 132, in enable
self._run_service_command(service_name, “enable”, fail_on_error)
File “/usr/lib/python3.6/site-packages/foris_controller_backends/services/init.py”, line 78, in _run_service_command
raise ServiceCmdFailed(service_name, cmd)
foris_controller.exceptions.ServiceCmdFailed: Calling ‘enable’ for service ‘ucollect’ failed.
So today I updated my Turris 1.x to RC3 and UPnP still doesn’t working. I checked also system, ESET and Firewall settings, but everything seems to be ok. Service is running on router, but still I see “No active translations”
Turis Omnia 2GB
root@Turris_Omnia:~# updater.sh
updater.sh is obsoleted. Please use pkgupdate directly instead.
root@Turris_Omnia:~# WARN:Branch overriden to rc
ERROR:Index turris/https://repo.turris.cz/omnia-rc/packages/turrispackages/Packages.gz is broken (missing): https://repo.turris.cz/omnia-rc/packages/turrispackages/Packages.gz: Operation timed out after 120000 milliseconds with 16082 out of 144815 bytes received
This looks like pretty much snails speed connection. Is it possible that during that time the connection was unstable or that something is throttling connection? You can test with wget and the same url from error message to see what is happening. Other less probable possibility is that your Omnia is overloaded so much that pkgupdate process is not almost executed at all.
Also respect the message you were given. Use pkgupdate
not updater.sh
Omnia overloads two processes:
10867 root pkgupdate 23% 1%
23528 root pkgupdate --batch --state-log --task-log=/usr/share/updater/updater-log --ask-approval=/usr/share/updater/need_approval 50% 1%
These backtraces could be related to your’s internet connection, which could have outage according to output, which you included. When you restart your router, it is OK?
Could you also run updater once again to see, if the Failed operation for majordomo is gone? If not, I’d suggest using Pakon instead of Majordomo, which is no longer under development.
May I know, if you’re using our new data collection system called Sentinel or the old one?
Sentinel is not installed.
