Po update kresd nasledovná chyba. Výpisy nasledujú.
Foris DNS is set:
Restart service resolver:
# /etc/init.d/resolver restart
Called /etc/init.d/kresd stop
remove dhcp script
Error! Required variable port not defined in /etc/resolver/dns_servers/99_google.conf
Called /etc/init.d/kresd start
remove dhcp script
V messages:
2019-12-19 12:06:22 err kresd[29421]: [ ta ] warning: overriding previously set trust anchors for .
2019-12-19 12:06:22 info kresd[29421]: [ta_update] refreshing TA for .
2019-12-19 12:06:22 info kresd[29421]: [ta_update] key: 20326 state: Valid
2019-12-19 12:06:22 info kresd[29421]: [ta_update] next refresh for . in 17.262222222222 hours
děkujeme za nahlášení. Opravu předávám na review ačkoliv tato chyba bude opravená až po novém roce. V tuto chvíli je možné si port doplnit v souboru /etc/resolver/dns_servers/99_google.conf, případně použít jiný DNS server.
Vo verzii TOS 3.11.12 som zmenil usb zariadenia. Upravil som správne v luci UUID.
# mount|grep sd[a-z]
/dev/sda1 on /tmp/hdd type btrfs (rw,noatime,space_cache,subvolid=5,subvol=/) < RAID1 s mPCI-SATA radičom
/dev/sdc1 on /tmp/usb type btrfs (rw,noatime,space_cache,subvolid=5,subvol=/) < USB1
/dev/sdd1 on /tmp/ext type btrfs (rw,noatime,space_cache,subvolid=5,subvol=/) < USB2
Výpis mount je v poriadku, ale keď spustím service mountd v messages vznikajú chybové záznamy:
2019-12-21 13:39:04 crit mountd[16159]: Starting OpenWrt (auto)mountd V1
2019-12-21 13:39:04 crit mountd[16159]: trying to mount /tmp/run/mountd/ as the autofs root
2019-12-21 13:39:05 crit mountd[16159]: could not find a serial number for the device sdd
2019-12-21 13:39:05 crit mountd[16159]: could not find a serial number for the device sdc
2019-12-21 13:39:06 crit mountd[16159]: could not find a serial number for the device sdd
2019-12-21 13:39:06 crit mountd[16159]: could not find a serial number for the device sdc
... a stale opakovanie riadkov s sdd a sdc!
