miska
December 17, 2018, 6:26pm
1
Dear Turris users,
we just released Turris OS 3.11.1 into RC. It contains mainly bugfixes and few updates that didn’t made it into 3.11, full release notes are bellow:
netdata: update for Omnia
subversion, unbound, git, ath10k-ct, miniupnpd, mwan3: updates
samba4, bzip2, openssl, tiff, apache, sqlite3: security updates
pakon: further improvements of archivation
majordomo: removed from the list of applications on updater page, still available for manual installation
mdadm, webapps, nextcloud: minor fixes
tvheadend: fix first time setup
As always we welcome any feedback and testing.
It solves the unbound
issues that were introduced with 3.11
Running a local NTP server instance seems not possible.
Else observed during update process
Summary
WARN:Collision with existing path. Moving /etc/init.d/unbound to /usr/share/updater/collided/etc/init.d
Output from turris-version.postinst:
/usr/lib/opkg/info//turris-version.postinst: /usr/lib/opkg/info/turris-version.postinst-pkg: line 3: lxc-config: not found
/usr/lib/opkg/info//turris-version.postinst: /usr/lib/opkg/info/turris-version.postinst-pkg: line 4: lxc-ls: not found
Output from foris-netmetr-plugin.postinst:
‘[’ -n ]
/etc/init.d/lighttpd restart
grep: /proc/22937/cmdline: No such file or directory
grep: /proc/22941/cmdline: No such file or directory
lxc container cannot be started, either from cli or LuCI perhaps due to
-ash: lxc-start: not found
Pepe
December 18, 2018, 10:50am
5
Did you have installed lxc-start package? I see, it’s compiled in RC branch and it’s working for me. Just tested it.
https://repo.turris.cz/omnia-rc/packages/packages/lxc-start_1.1.5-15_mvebu.ipk
Maybe you’re not using our prepared user list for LXC containers? It can be selected in Updater tab in Foris.
Umpf, no. Installed luci-app-lxc
and would have expected that the basic minimum dependencies for operating (start/stop/attach) a container are installed as well. However, it appears that only these were installed along:
Summary
liblxc
lxc
lxc-common
lxc-configs
lxc-create
lxc-hooks
lxc-templates
rpcd-mod-lxc
and that there is whole bunch of other related packages still available for installation:
Summary
lxc-attach
lxc-auto
lxc-autostart
lxc-cgroup
lxc-checkconfig
lxc-clone
lxc-config
lxc-console
lxc-destroy
lxc-device
lxc-execute
lxc-freeze
lxc-info
lxc-init
lxc-ls
lxc-lua
lxc-monitor
lxc-monitord
lxc-snapshot
lxc-start
lxc-stop
lxc-unfreeze
lxc-unshare
lxc-user-nic
lxc-usernsexec
lxc-wait
Another dependency for basic operations absent from luci-app-lxc
is kmod-veth
The incremental update went fine, there are those DoT/OpenSSL related but inconsequential errors when resolver
/unbound
is restarted
unbound-checkconf[25787:0] error: no name verification functionality in ssl library, ignored name for
unbound
works anyway (with opportunistic DoT).
there is something going awry with the lxc namespace however.
Having lxc.utsname = test
produces
then there is a hostname
file inside the container with alarm
in it. That is with a ArchLinux container.
With a OpenSUSE container the hostname then turned out to be linux
The hostname files should be passed the lxc.utsname =
argument to match the lxc namespace.
It works for me. Also I could still start my lxc containers.
peci1
December 18, 2018, 9:54pm
10
Everything works for me after update from 3.11 (samba4, minidlna, tor, pptp vpn server, pptp vpn client, lxc, bigclown gateway).
It only seems tor wasn’t rebuilt with the new openssl:
2018-12-18 22:32:44 warning Tor[6640]: OpenSSL version from headers does not match the version we're running with. If you get weird crashes, that might be why. (Compiled with 1000210f: OpenSSL 1.0.2p 14 Aug 2018; running with 1000211f: OpenSSL 1.0.2q 20 Nov 2018).
Started to experience network lags/outage particularly with wireguard tunnel and then with /etc/init.d/network restart
the router crashed . From a first glance at the log it seems that the firewall module caused it.
Summary
01:17 notice firewall : Reloading firewall due to ifup of guest (br-guest)
01:17 warning kernel : [51082.818229] Modules linked in: qcserial option iptable_nat ath9k usb_wwan rndis_host qmi_wwan pppoe nf_nat_pptp nf_nat_ipv4 nf_nat_amanda nf_conntrack_pptp nf_conntrack_ipv6 nf_conntrack_ipv4 nf_conntrack_amanda ipt_REJECT ipt_MASQUERADE ebtable_nat ebtable_filter ebtable_broute cdc_ether ath9k_common armada_thermal xt_time xt_tcpudp xt_tcpmss xt_statistic xt_state xt_recent xt_nat xt_multiport xt_mark xt_mac xt_limit xt_length xt_id xt_hl xt_helper xt_ecn xt_dscp xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_TCPMSS xt_REDIRECT xt_LOG xt_HL xt_DSCP xt_CT xt_CLASSIFY wireguard usbserial usbnet ums_usbat ums_sddr55 ums_sddr09 ums_karma ums_jumpshot ums_isd200 ums_freecom ums_datafab ums_cypress ums_alauda ts_kmp ts_fsm ts_bm thermal_sys pppox ppp_mppe ppp_async nf_reject_ipv4 nf_nat_tftp nf_nat_snmp_basic nf_nat_sip nf_nat_redirect nf_nat_proto_gre nf_nat_masquerade_ipv4 nf_nat_irc nf_nat_h323 nf_nat_ftp nf_nat nf_log_ipv4 nf_defrag_ipv6 nf_defrag_ipv4 nf_conntrack_tftp nf_conntrack_snmp nf_conntrack_sip nf_conntrack_rtcache nf_conntrack_proto_gre nf_conntrack_netlink nf_conntrack_irc nf_conntrack_h323 nf_conntrack_ftp nf_conntrack_broadcast mvsdio iptable_raw iptable_mangle iptable_filter ipt_ECN ip_tables hwmon ebtables ebt_vlan ebt_stp ebt_redirect ebt_pkttype ebt_mark_m ebt_mark ebt_limit ebt_among ebt_802_3 crc_ccitt cdc_wdm ath9k_hw fuse sch_cake nf_conntrack sch_teql sch_tbf sch_sfq sch_red sch_prio sch_pie sch_netem sch_htb sch_gred sch_fq sch_dsmark sch_codel em_text em_nbyte em_meta em_cmp cls_basic act_vlan act_police act_pedit act_nat act_ipt act_gact act_csum act_bpf act_skbedit act_mirred em_u32 cls_u32 cls_tcindex cls_flow cls_route cls_fw sch_hfsc sch_ingress ath10k_pci ath10k_core ath mac80211 cfg80211 compat ledtrig_usbdev ledtrig_oneshot xt_LED ledtrig_morse ledtrig_heartbeat ledtrig_gpio cryptodev xt_set ip_set_list_set ip_set_hash_netiface ip_set_hash_netport ip_set_hash_netnet ip_set_hash_net ip_set_hash_netportnet ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6t_REJECT nf_reject_ipv6 nf_log_ipv6 nf_log_common ip6table_raw ip6table_mangle ip6table_filter ip6_tables x_tables pppoatm ppp_generic slhc nfsd nfsv3 msdos ip_gre gre ifb ip6_udp_tunnel udp_tunnel sit ip6_tunnel tunnel6 tunnel4 ip_tunnel veth tun vfat fat udf crc_itu_t ntfs nfs_layout_nfsv41_files nfsv4 nfs auth_rpcgss oid_registry lockd sunrpc grace minix isofs hfsplus hfs cramfs configfs cifs autofs4 dns_resolver dm_crypt dm_mirror dm_region_hash dm_log dm_mod br2684 atm multipath fscache raid456 async_raid6_recov async_pq async_xor async_memcpy async_tx raid10 raid1 raid0 linear md_mod nls_utf8 nls_koi8_r nls_cp1255 nls_iso8859_6 nls_iso8859_2 nls_iso8859_15 nls_iso8859_13 nls_iso8859_1 nls_cp932 nls_cp866 nls_cp864 nls_cp862 nls_cp852 nls_cp850 nls_cp775 nls_cp437 nls_cp1251 nls_cp1250 xts algif_skcipher algif_hash af_alg sha512_generic sha256_generic sha1_generic seqiv jitterentropy_rng drbg pcbc md5 md4 marvell_cesa hmac gf128mul ecb des_generic ctr cmac ccm cbc authenc xhci_plat_hcd xhci_pci xhci_hcd uhci_hcd ledtrig_transient ahci_platform uas xfs libcrc32c jfs f2fs exfat mii aead crypto_null
01:17 warning kernel : [51083.108812] CPU: 0 PID: 1509 Comm: fw3 Tainted: G B D 4.4.167-4a7a81f8db0ad743e54c68e1845c60b6-1 #1
01:17 warning kernel : [51083.118836] Hardware name: Marvell Armada 380/385 (Device Tree)
01:17 warning kernel : [51083.124766] Backtrace:
01:17 warning kernel : [51083.127234] [] (dump_backtrace) from [] (show_stack+0x18/0x1c)
01:17 warning kernel : [51083.134819] r6:00000000 r5:60000013 r4:c076cd28 r3:00000000
01:17 warning kernel : [51083.140535] [] (show_stack) from [] (dump_stack+0x98/0xac)
01:17 warning kernel : [51083.147778] [] (dump_stack) from [] (bad_page+0xf0/0x150)
01:17 warning kernel : [51083.154927] r6:c075cd5c r5:c065029c r4:c07a5998 r3:00000000
01:17 warning kernel : [51083.160642] [] (bad_page) from [] (get_page_from_freelist+0x57c/0x924)
01:17 warning kernel : [51083.168923] r10:00000001 r9:c0760100 r8:ef3d84ec r7:2e674000 r6:c075cd5c r5:c065029c
01:17 warning kernel : [51083.176818] r4:c06502b0 r3:00000001
01:17 warning kernel : [51083.180422] [] (get_page_from_freelist) from [] (__alloc_pages_nodemask+0x12c/0xa50)
01:17 warning kernel : [51083.189921] r10:00000002 r9:c0760b80 r8:026084c0 r7:00000000 r6:c075cd5c r5:b6db6db7
01:17 warning kernel : [51083.197820] r4:00000000
01:17 warning kernel : [51083.200371] [] (__alloc_pages_nodemask) from [] (__pte_alloc+0x2c/0x180)
01:17 warning kernel : [51083.208826] r10:00000000 r9:00036000 r8:c840e4f0 r7:c840e4d4 r6:ccf9c000 r5:c9404fc0
01:17 warning kernel : [51083.216724] r4:d4acca20
01:17 warning kernel : [51083.219273] [] (__pte_alloc) from [] (copy_page_range+0x520/0x634)
01:17 warning kernel : [51083.227206] r6:c9404fc0 r5:c1b40720 r4:d4acca20 r3:00036000
01:17 warning kernel : [51083.232920] [] (copy_page_range) from [] (copy_process+0x1200/0x154c)
01:17 warning kernel : [51083.241113] r10:c078ad68 r9:00000000 r8:c840e4f0 r7:c840e4d4 r6:c9404fc0 r5:c1b40720
01:17 warning kernel : [51083.249012] r4:d4acca20
01:17 warning kernel : [51083.251560] [] (copy_process) from [] (_do_fork+0x78/0x338)
01:17 warning kernel : [51083.258883] r10:00000000 r9:00000000 r8:c0009ec4 r7:00000000 r6:00000000 r5:00000011
01:17 warning kernel : [51083.266781] r4:c18e7f48
01:17 warning kernel : [51083.269328] [] (_do_fork) from [] (sys_fork+0x2c/0x34)
01:17 warning kernel : [51083.276216] r9:c18e6000 r8:c0009ec4 r7:00000002 r6:b6e954d0 r5:b6e95560 r4:00000077
01:17 warning kernel : [51083.284028] [] (sys_fork) from [] (ret_fast_syscall+0x0/0x48)
01:22 notice : Added device handler type: tunnel
01:22 notice : Added device handler type: Network device
01:22 notice : Added device handler type: bridge
01:22 notice : Added device handler type: macvlan
01:22 notice : Added device handler type: 8021ad
01:22 notice : Added device handler type: 8021q
01:23 warning kernel : [51087.905516] Modules linked in: qcserial option iptable_nat ath9k usb_wwan rndis_host qmi_wwan pppoe nf_nat_pptp nf_nat_ipv4 nf_nat_amanda nf_conntrack_pptp nf_conntrack_ipv6 nf_conntrack_ipv4 nf_conntrack_amanda ipt_REJECT ipt_MASQUERADE ebtable_nat ebtable_filter ebtable_broute cdc_ether ath9k_common armada_thermal xt_time xt_tcpudp xt_tcpmss xt_statistic xt_state xt_recent xt_nat xt_multiport xt_mark xt_mac xt_limit xt_length xt_id xt_hl xt_helper xt_ecn xt_dscp xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_TCPMSS xt_REDIRECT xt_LOG xt_HL xt_DSCP xt_CT xt_CLASSIFY wireguard usbserial usbnet ums_usbat ums_sddr55 ums_sddr09 ums_karma ums_jumpshot ums_isd200 ums_freecom ums_datafab ums_cypress ums_alauda ts_kmp ts_fsm ts_bm thermal_sys pppox ppp_mppe ppp_async nf_reject_ipv4 nf_nat_tftp nf_nat_snmp_basic nf_nat_sip nf_nat_redirect nf_nat_proto_gre nf_nat_masquerade_ipv4 nf_nat_irc nf_nat_h323 nf_nat_ftp nf_nat nf_log_ipv4 nf_defrag_ipv6 nf_defrag_ipv4 nf_conntrack_tftp nf_conntrack_snmp nf_conntrack_sip nf_conntrack_rtcache nf_conntrack_proto_gre nf_conntrack_netlink nf_conntrack_irc nf_conntrack_h323 nf_conntrack_ftp nf_conntrack_broadcast mvsdio iptable_raw iptable_mangle iptable_filter ipt_ECN ip_tables hwmon ebtables ebt_vlan ebt_stp ebt_redirect ebt_pkttype ebt_mark_m ebt_mark ebt_limit ebt_among ebt_802_3 crc_ccitt cdc_wdm ath9k_hw fuse sch_cake nf_conntrack sch_teql sch_tbf sch_sfq sch_red sch_prio sch_pie sch_netem sch_htb sch_gred sch_fq sch_dsmark sch_codel em_text em_nbyte em_meta em_cmp cls_basic act_vlan act_police act_pedit act_nat act_ipt act_gact act_csum act_bpf act_skbedit act_mirred em_u32 cls_u32 cls_tcindex cls_flow cls_route cls_fw sch_hfsc sch_ingress ath10k_pci ath10k_core ath mac80211 cfg80211 compat ledtrig_usbdev ledtrig_oneshot xt_LED ledtrig_morse ledtrig_heartbeat ledtrig_gpio cryptodev xt_set ip_set_list_set ip_set_hash_netiface ip_set_hash_netport ip_set_hash_netnet ip_set_hash_net ip_set_hash_netportnet ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6t_REJECT nf_reject_ipv6 nf_log_ipv6 nf_log_common ip6table_raw ip6table_mangle ip6table_filter ip6_tables x_tables pppoatm ppp_generic slhc nfsd nfsv3 msdos ip_gre gre ifb ip6_udp_tunnel udp_tunnel sit ip6_tunnel tunnel6 tunnel4 ip_tunnel veth tun vfat fat udf crc_itu_t ntfs nfs_layout_nfsv41_files nfsv4 nfs auth_rpcgss oid_registry lockd sunrpc grace minix isofs hfsplus hfs cramfs configfs cifs autofs4 dns_resolver dm_crypt dm_mirror dm_region_hash dm_log dm_mod br2684 atm multipath fscache raid456 async_raid6_recov async_pq async_xor async_memcpy async_tx raid10 raid1 raid0 linear md_mod nls_utf8 nls_koi8_r nls_cp1255 nls_iso8859_6 nls_iso8859_2 nls_iso8859_15 nls_iso8859_13 nls_iso8859_1 nls_cp932 nls_cp866 nls_cp864 nls_cp862 nls_cp852 nls_cp850 nls_cp775 nls_cp437 nls_cp1251 nls_cp1250 xts algif_skcipher algif_hash af_alg sha512_generic sha256_generic sha1_generic seqiv jitterentropy_rng drbg pcbc md5 md4 marvell_cesa hmac gf128mul ecb des_generic ctr cmac ccm cbc authenc xhci_plat_hcd xhci_pci xhci_hcd uhci_hcd ledtrig_transient ahci_platform uas xfs libcrc32c jfs f2fs exfat mii aead crypto_null
01:23 warning kernel : [51088.196223] CPU: 0 PID: 1583 Comm: sh Tainted: G B D 4.4.167-4a7a81f8db0ad743e54c68e1845c60b6-1 #1
01:23 warning kernel : [51088.206160] Hardware name: Marvell Armada 380/385 (Device Tree)
01:23 warning kernel : [51088.212091] Backtrace:
01:23 warning kernel : [51088.214558] [] (dump_backtrace) from [] (show_stack+0x18/0x1c)
01:23 warning kernel : [51088.222143] r6:00000000 r5:60000013 r4:c076cd28 r3:00000000
01:23 warning kernel : [51088.227859] [] (show_stack) from [] (dump_stack+0x98/0xac)
01:23 warning kernel : [51088.235103] [] (dump_stack) from [] (bad_page+0xf0/0x150)
01:23 warning kernel : [51088.242251] r6:c075cd5c r5:c065029c r4:c07a5998 r3:00000000
01:23 warning kernel : [51088.247964] [] (bad_page) from [] (get_page_from_freelist+0x57c/0x924)
01:23 warning kernel : [51088.256245] r10:00000001 r9:c0760100 r8:ef009b70 r7:2e674000 r6:c075cd5c r5:c065029c
01:23 warning kernel : [51088.264140] r4:c06502b0 r3:00000001
01:23 warning kernel : [51088.267744] [] (get_page_from_freelist) from [] (__alloc_pages_nodemask+0x12c/0xa50)
01:23 warning kernel : [51088.277244] r10:00000002 r9:c0760b80 r8:026084c0 r7:00000000 r6:c075cd5c r5:b6db6db7
01:23 warning kernel : [51088.285141] r4:00000000
01:23 warning kernel : [51088.287692] [] (__alloc_pages_nodemask) from [] (__pte_alloc+0x2c/0x180)
01:23 warning kernel : [51088.296147] r10:00000000 r9:00b83000 r8:c078ad4c r7:0000001e r6:ccf14028 r5:c9405180
01:23 warning kernel : [51088.304044] r4:c2318120
01:23 warning kernel : [51088.306594] [] (__pte_alloc) from [] (copy_page_range+0x520/0x634)
01:23 warning kernel : [51088.314526] r6:c9405180 r5:c2318420 r4:c2318120 r3:00b83000
01:23 warning kernel : [51088.320240] [] (copy_page_range) from [] (copy_process+0x1200/0x154c)
01:23 warning kernel : [51088.328434] r10:c078ad68 r9:00000000 r8:c078ad4c r7:0000001e r6:c9405180 r5:c2318420
01:23 warning kernel : [51088.336332] r4:c2318120
01:23 warning kernel : [51088.338880] [] (copy_process) from [] (_do_fork+0x78/0x338)
01:23 warning kernel : [51088.346204] r10:00000000 r9:00000000 r8:c0009ec4 r7:00000000 r6:00000000 r5:00000011
01:23 warning kernel : [51088.354101] r4:c164bf48
01:23 warning kernel : [51088.356649] [] (_do_fork) from [] (sys_fork+0x2c/0x34)
01:23 warning kernel : [51088.363537] r9:c164a000 r8:c0009ec4 r7:00000002 r6:00000000 r5:bed96fbe r4:00b85870
01:23 warning kernel : [51088.371349] [] (sys_fork) from [] (ret_fast_syscall+0x0/0x48)
01:23 alert kernel : [51088.378891] BUG: Bad page state in process sh pfn:0eafb
01:23 emerg kernel : [51088.390953] flags: 0x0()
01:23 alert kernel : [51088.393630] page dumped because: nonzero _count
01:23 emerg kernel : [51088.876855] page:ef009b28 count:-1 mapcount:0 mapping: (null) index:0x0
01:23 emerg kernel : [51088.883606] flags: 0x0()
01:23 alert kernel : [51088.886158] page dumped because: nonzero _count
01:23 warning kernel : [51088.890697] Modules linked in: qcserial option iptable_nat ath9k usb_wwan rndis_host qmi_wwan pppoe nf_nat_pptp nf_nat_ipv4 nf_nat_amanda nf_conntrack_pptp nf_conntrack_ipv6 nf_conntrack_ipv4 nf_conntrack_amanda ipt_REJECT ipt_MASQUERADE ebtable_nat ebtable_filter ebtable_broute cdc_ether ath9k_common armada_thermal xt_time xt_tcpudp xt_tcpmss xt_statistic xt_state xt_recent xt_nat xt_multiport xt_mark xt_mac xt_limit xt_length xt_id xt_hl xt_helper xt_ecn xt_dscp xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_TCPMSS xt_REDIRECT xt_LOG xt_HL xt_DSCP xt_CT xt_CLASSIFY wireguard usbserial usbnet ums_usbat ums_sddr55 ums_sddr09 ums_karma ums_jumpshot ums_isd200 ums_freecom ums_datafab ums_cypress ums_alauda ts_kmp ts_fsm ts_bm thermal_sys pppox ppp_mppe ppp_async nf_reject_ipv4 nf_nat_tftp nf_nat_snmp_basic nf_nat_sip nf_nat_redirect nf_nat_proto_gre nf_nat_masquerade_ipv4 nf_nat_irc nf_nat_h323 nf_nat_ftp nf_nat nf_log_ipv4 nf_defrag_ipv6 nf_defrag_ipv4 nf_conntrack_tftp nf_conntrack_snmp nf_conntrack_sip nf_conntrack_rtcache nf_conntrack_proto_gre nf_conntrack_netlink nf_conntrack_irc nf_conntrack_h323 nf_conntrack_ftp nf_conntrack_broadcast mvsdio iptable_raw iptable_mangle iptable_filter ipt_ECN ip_tables hwmon ebtables ebt_vlan ebt_stp ebt_redirect ebt_pkttype ebt_mark_m ebt_mark ebt_limit ebt_among ebt_802_3 crc_ccitt cdc_wdm ath9k_hw fuse sch_cake nf_conntrack sch_teql sch_tbf sch_sfq sch_red sch_prio sch_pie sch_netem sch_htb sch_gred sch_fq sch_dsmark sch_codel em_text em_nbyte em_meta em_cmp cls_basic act_vlan act_police act_pedit act_nat act_ipt act_gact act_csum act_bpf act_skbedit act_mirred em_u32 cls_u32 cls_tcindex cls_flow cls_route cls_fw sch_hfsc sch_ingress ath10k_pci ath10k_core ath mac80211 cfg80211 compat ledtrig_usbdev ledtrig_oneshot xt_LED ledtrig_morse ledtrig_heartbeat ledtrig_gpio cryptodev xt_set ip_set_list_set ip_set_hash_netiface ip_set_hash_netport ip_set_hash_netnet ip_set_hash_net ip_set_hash_netportnet ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6t_REJECT nf_reject_ipv6 nf_log_ipv6 nf_log_common ip6table_raw ip6table_mangle ip6table_filter ip6_tables x_tables pppoatm ppp_generic slhc nfsd nfsv3 msdos ip_gre gre ifb ip6_udp_tunnel udp_tunnel sit ip6_tunnel tunnel6 tunnel4 ip_tunnel veth tun vfat fat udf crc_itu_t ntfs nfs_layout_nfsv41_files nfsv4 nfs auth_rpcgss oid_registry lockd sunrpc grace minix isofs hfsplus hfs cramfs configfs cifs autofs4 dns_resolver dm_crypt dm_mirror dm_region_hash dm_log dm_mod br2684 atm multipath fscache raid456 async_raid6_recov async_pq async_xor async_memcpy async_tx raid10 raid1 raid0 linear md_mod nls_utf8 nls_koi8_r nls_cp1255 nls_iso8859_6 nls_iso8859_2 nls_iso8859_15 nls_iso8859_13 nls_iso8859_1 nls_cp932 nls_cp866 nls_cp864 nls_cp862 nls_cp852 nls_cp850 nls_cp775 nls_cp437 nls_cp1251 nls_cp1250 xts algif_skcipher algif_hash af_alg sha512_generic sha256_generic sha1_generic seqiv jitterentropy_rng drbg pcbc md5 md4 marvell_cesa hmac gf128mul ecb des_generic ctr cmac ccm cbc authenc xhci_plat_hcd xhci_pci xhci_hcd uhci_hcd ledtrig_transient ahci_platform uas xfs libcrc32c jfs f2fs exfat mii aead crypto_null
01:24 emerg kernel : [51089.376047] flags: 0x0()
01:24 alert kernel : [51089.378595] page dumped because: nonzero _count
01:24 emerg kernel : [51089.861902] page:ef009ae0 count:-1 mapcount:0 mapping: (null) index:0x0
01:24 emerg kernel : [51089.868618] flags: 0x0()
01:24 alert kernel : [51089.871175] page dumped because: nonzero _count
01:25 warning kernel : [51089.875715] Modules linked in: qcserial option iptable_nat ath9k usb_wwan rndis_host qmi_wwan pppoe nf_nat_pptp nf_nat_ipv4 nf_nat_amanda nf_conntrack_pptp nf_conntrack_ipv6 nf_conntrack_ipv4 nf_conntrack_amanda ipt_REJECT ipt_MASQUERADE ebtable_nat ebtable_filter ebtable_broute cdc_ether ath9k_common armada_thermal xt_time xt_tcpudp xt_tcpmss xt_statistic xt_state xt_recent xt_nat xt_multiport xt_mark xt_mac xt_limit xt_length xt_id xt_hl xt_helper xt_ecn xt_dscp xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_TCPMSS xt_REDIRECT xt_LOG xt_HL xt_DSCP xt_CT xt_CLASSIFY wireguard usbserial usbnet ums_usbat ums_sddr55 ums_sddr09 ums_karma ums_jumpshot ums_isd200 ums_freecom ums_datafab ums_cypress ums_alauda ts_kmp ts_fsm ts_bm thermal_sys pppox ppp_mppe ppp_async nf_reject_ipv4 nf_nat_tftp nf_nat_snmp_basic nf_nat_sip nf_nat_redirect nf_nat_proto_gre nf_nat_masquerade_ipv4 nf_nat_irc nf_nat_h323 nf_nat_ftp nf_nat nf_log_ipv4 nf_defrag_ipv6 nf_defrag_ipv4 nf_conntrack_tftp nf_conntrack_snmp nf_conntrack_sip nf_conntrack_rtcache nf_conntrack_proto_gre nf_conntrack_netlink nf_conntrack_irc nf_conntrack_h323 nf_conntrack_ftp nf_conntrack_broadcast mvsdio iptable_raw iptable_mangle iptable_filter ipt_ECN ip_tables hwmon ebtables ebt_vlan ebt_stp ebt_redirect ebt_pkttype ebt_mark_m ebt_mark ebt_limit ebt_among ebt_802_3 crc_ccitt cdc_wdm ath9k_hw fuse sch_cake nf_conntrack sch_teql sch_tbf sch_sfq sch_red sch_prio sch_pie sch_netem sch_htb sch_gred sch_fq sch_dsmark sch_codel em_text em_nbyte em_meta em_cmp cls_basic act_vlan act_police act_pedit act_nat act_ipt act_gact act_csum act_bpf act_skbedit act_mirred em_u32 cls_u32 cls_tcindex cls_flow cls_route cls_fw sch_hfsc sch_ingress ath10k_pci ath10k_core ath mac80211 cfg80211 compat ledtrig_usbdev ledtrig_oneshot xt_LED ledtrig_morse ledtrig_heartbeat ledtrig_gpio cryptodev xt_set ip_set_list_set ip_set_hash_netiface ip_set_hash_netport ip_set_hash_netnet ip_set_hash_net ip_set_hash_netportnet ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6t_REJECT nf_reject_ipv6 nf_log_ipv6 nf_log_common ip6table_raw ip6table_mangle ip6table_filter ip6_tables x_tables pppoatm ppp_generic slhc nfsd nfsv3 msdos ip_gre gre ifb ip6_udp_tunnel udp_tunnel sit ip6_tunnel tunnel6 tunnel4 ip_tunnel veth tun vfat fat udf crc_itu_t ntfs nfs_layout_nfsv41_files nfsv4 nfs auth_rpcgss oid_registry lockd sunrpc grace minix isofs hfsplus hfs cramfs configfs cifs autofs4 dns_resolver dm_crypt dm_mirror dm_region_hash dm_log dm_mod br2684 atm multipath fscache raid456 async_raid6_recov async_pq async_xor async_memcpy async_tx raid10 raid1 raid0 linear md_mod nls_utf8 nls_koi8_r nls_cp1255 nls_iso8859_6 nls_iso8859_2 nls_iso8859_15 nls_iso8859_13 nls_iso8859_1 nls_cp932 nls_cp866 nls_cp864 nls_cp862 nls_cp852 nls_cp850 nls_cp775 nls_cp437 nls_cp1251 nls_cp1250 xts algif_skcipher algif_hash af_alg sha512_generic sha256_generic sha1_generic seqiv jitterentropy_rng drbg pcbc md5 md4 marvell_cesa hmac gf128mul ecb des_generic ctr cmac ccm cbc authenc xhci_plat_hcd xhci_pci xhci_hcd uhci_hcd ledtrig_transient ahci_platform uas xfs libcrc32c jfs f2fs exfat mii aead crypto_null
01:25 warning kernel : [51090.166325] CPU: 0 PID: 1583 Comm: sh Tainted: G B D 4.4.167-4a7a81f8db0ad743e54c68e1845c60b6-1 #1
01:25 warning kernel : [51090.176261] Hardware name: Marvell Armada 380/385 (Device Tree)
01:25 warning kernel : [51090.182191] Backtrace:
01:25 warning kernel : [51090.184657] [] (dump_backtrace) from [] (show_stack+0x18/0x1c)
01:25 warning kernel : [51090.192241] r6:00000000 r5:60000013 r4:c076cd28 r3:00000000
01:25 warning kernel : [51090.197955] [] (show_stack) from [] (dump_stack+0x98/0xac)
01:25 warning kernel : [51090.205197] [] (dump_stack) from [] (bad_page+0xf0/0x150)
01:25 warning kernel : [51090.212346] r6:c075cd5c r5:c065029c r4:c07a5998 r3:00000000
01:25 warning kernel : [51090.218061] [] (bad_page) from [] (get_page_from_freelist+0x57c/0x924)
01:25 warning kernel : [51090.226342] r10:00000001 r9:c0760100 r8:ef009ae0 r7:2e674000 r6:c075cd5c r5:c065029c
01:25 warning kernel : [51090.234239] r4:c06502b0 r3:00000001
01:25 warning kernel : [51090.237841] [] (get_page_from_freelist) from [] (__alloc_pages_nodemask+0x12c/0xa50)
01:25 warning kernel : [51090.247340] r10:00000002 r9:c0760b80 r8:026084c0 r7:00000000 r6:c075cd5c r5:b6db6db7
01:25 warning kernel : [51090.255236] r4:00000000
01:25 warning kernel : [51090.257786] [] (__alloc_pages_nodemask) from [] (__pte_alloc+0x2c/0x180)
01:25 warning kernel : [51090.266241] r10:00000000 r9:00b83000 r8:c078ad4c r7:0000001e r6:ccf14028 r5:c9405180
01:25 warning kernel : [51090.274140] r4:c2318120
01:25 warning kernel : [51090.276688] [] (__pte_alloc) from [] (copy_page_range+0x520/0x634)
01:25 warning kernel : [51090.284621] r6:c9405180 r5:c2318420 r4:c2318120 r3:00b83000
01:25 warning kernel : [51090.290337] [] (copy_page_range) from [] (copy_process+0x1200/0x154c)
01:25 warning kernel : [51090.298531] r10:c078ad68 r9:00000000 r8:c078ad4c r7:0000001e r6:c9405180 r5:c2318420
01:25 warning kernel : [51090.306429] r4:c2318120
01:25 warning kernel : [51090.308977] [] (copy_process) from [] (_do_fork+0x78/0x338)
01:25 warning kernel : [51090.316301] r10:00000000 r9:00000000 r8:c0009ec4 r7:00000000 r6:00000000 r5:00000011
01:25 warning kernel : [51090.324198] r4:c164bf48
01:25 warning kernel : [51090.326745] [] (_do_fork) from [] (sys_fork+0x2c/0x34)
01:25 warning kernel : [51090.333634] r9:c164a000 r8:c0009ec4 r7:00000002 r6:00000000 r5:bed96fbe r4:00b85870
01:25 warning kernel : [51090.341449] [] (sys_fork) from [] (ret_fast_syscall+0x0/0x48)
02:01 info /usr/sbin/cron[1856]: (root) CMD (nethist_stats.lua)
02:01 info /usr/sbin/cron[1857]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
03:01 info /usr/sbin/cron[2128]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
03:15 alert kernel : [51200.883072] BUG: Bad page state in process kworker/u4:1 pfn:29c30
03:15 emerg kernel : [51200.889273] page:ef3d86c0 count:-1 mapcount:0 mapping: (null) index:0x0
03:16 notice kernel : ahci_platform uas xfs libcrc32c jfs f2fs exfat mii aead crypto_null
03:16 warning kernel : [51201.193729] CPU: 1 PID: 1207 Comm: kworker/u4:1 Tainted: G B D 4.4.167-4a7a81f8db0ad743e54c68e1845c60b6-1 #1
03:16 warning kernel : [51201.204538] Hardware name: Marvell Armada 380/385 (Device Tree)
03:16 warning kernel : [51201.210475] Workqueue: btrfs-endio-write btrfs_endio_write_helper
03:16 warning kernel : [51201.216590] Backtrace:
03:16 warning kernel : [51201.219054] [] (dump_backtrace) from [] (show_stack+0x18/0x1c)
03:16 warning kernel : [51201.226639] r6:00000000 r5:60000013 r4:c076cd28 r3:00000006
03:16 warning kernel : [51201.232357] [] (show_stack) from [] (dump_stack+0x98/0xac)
03:16 warning kernel : [51201.239599] [] (dump_stack) from [] (bad_page+0xf0/0x150)
03:16 warning kernel : [51201.246749] r6:c075cd5c r5:c065029c r4:c07a5998 r3:00000000
03:16 warning kernel : [51201.252464] [] (bad_page) from [] (get_page_from_freelist+0x57c/0x924)
03:16 warning kernel : [51201.260745] r10:00000001 r9:c0760100 r8:ef3d86c0 r7:2e680000 r6:c075cd5c r5:c065029c
03:16 warning kernel : [51201.268644] r4:c06502b0 r3:00000001
03:16 warning kernel : [51201.272247] [] (get_page_from_freelist) from [] (__alloc_pages_nodemask+0x12c/0xa50)
03:16 warning kernel : [51201.281747] r10:00000002 r9:c0760b80 r8:02400840 r7:00000000 r6:c075cd5c r5:b6db6db7
03:16 warning kernel : [51201.289645] r4:00000000
03:16 warning kernel : [51201.292194] [] (__alloc_pages_nodemask) from [] (pagecache_get_page+0x78/0x1f0)
03:16 warning kernel : [51201.301258] r10:c0760ca2 r9:00026a51 r8:c075cf78 r7:00ac7c12 r6:ee592a24 r5:02400840
03:16 warning kernel : [51201.309157] r4:00000007
03:16 warning kernel : [51201.311707] [] (pagecache_get_page) from [] (alloc_extent_buffer+0xcc/0x3c8)
03:16 warning kernel : [51201.320510] r10:d1dc1bd0 r9:d1dc1bd4 r8:00026a54 r7:00026a51 r6:ee592a24 r5:00000000
03:16 warning kernel : [51201.328408] r4:ef126498
03:16 warning kernel : [51201.330960] [] (alloc_extent_buffer) from [] (btrfs_find_create_tree_block+0x14/0x18)
03:16 warning kernel : [51201.340547] r10:edf2d0e8 r9:edf2d000 r8:ee4ae958 r7:00004000 r6:edfab800 r5:00000000
03:16 warning kernel : [51201.348442] r4:00000000
03:16 warning kernel : [51201.350991] [] (btrfs_find_create_tree_block) from [] (btrfs_alloc_tree_block+0x184/0x5e0)
03:16 warning kernel : [51201.361019] [] (btrfs_alloc_tree_block) from [] (__btrfs_cow_block+0x120/0x5e4)
03:16 warning kernel : [51201.370083] r10:d1dc17e0 r9:e73f6498 r8:ee4ae958 r7:edfab800 r6:00000000 r5:00000000
03:16 warning kernel : [51201.377982] r4:00000000
03:16 warning kernel : [51201.380530] [] (__btrfs_cow_block) from [] (btrfs_cow_block+0x12c/0x1b4)
03:16 warning kernel : [51201.388985] r10:00000001 r9:d1dc17e0 r8:edfab800 r7:00000000 r6:00000000 r5:00000000
03:16 warning kernel : [51201.396882] r4:00000000
03:16 warning kernel : [51201.399431] [] (btrfs_cow_block) from [] (btrfs_search_slot+0x1f4/0x964)
03:16 warning kernel : [51201.407886] r9:edfab800 r8:00000000 r7:00000000 r6:00000002 r5:00000001 r4:d0700fa0
03:16 warning kernel : [51201.415701] [] (btrfs_search_slot) from [] (btrfs_lookup_file_extent+0x5c/0x64)
03:16 warning kernel : [51201.424766] r10:00000000 r9:00000000 r8:d0700fa0 r7:00000001 r6:0003d80a r5:00000000
03:16 warning kernel : [51201.432664] r4:00036000
03:16 warning kernel : [51201.435216] [] (btrfs_lookup_file_extent) from [] (__btrfs_drop_extents+0x144/0xfa0)
03:16 warning kernel : [51201.444715] r7:00004000 r6:00000000 r5:ffffffff r4:00036000
03:16 warning kernel : [51201.450428] [] (__btrfs_drop_extents) from [] (insert_reserved_file_extent.constprop.12+0xb4/0x38c)
03:16 warning kernel : [51201.461232] r10:ee4ae958 r9:00000000 r8:00004000 r7:00004000 r6:00000000 r5:d0700fa0
03:16 warning kernel : [51201.469131] r4:db039138
03:16 warning kernel : [51201.471680] [] (insert_reserved_file_extent.constprop.12) from [] (btrfs_finish_ordered_io+0x3f4/0x780)
03:16 warning kernel : [51201.482833] r10:00000000 r9:ee4ae958 r8:edfab800 r7:db039138 r6:c1e352d0 r5:00000000
03:16 warning kernel : [51201.490731] r4:00004000
03:16 warning kernel : [51201.493280] [] (btrfs_finish_ordered_io) from [] (finish_ordered_fn+0x14/0x18)
03:16 warning kernel : [51201.502257] r10:c0760c12 r9:00000000 r8:00000000 r7:00000000 r6:edc595c0 r5:c1e3535c
03:16 warning kernel : [51201.510154] r4:c1e35350
03:16 warning kernel : [51201.512702] [] (finish_ordered_fn) from [] (normal_work_helper+0xa0/0x1b8)
03:16 warning kernel : [51201.521333] [] (normal_work_helper) from [] (btrfs_endio_write_helper+0x14/0x18)
03:16 warning kernel : [51201.530484] r10:c0760c12 r9:00000000 r8:00000000 r7:eddbd500 r6:ee80b000 r5:c1e3535c
03:16 warning kernel : [51201.538380] r4:d16fbb80 r3:c026bd5c
03:16 warning kernel : [51201.541983] [] (btrfs_endio_write_helper) from [] (process_one_work+0x140/0x358)
03:16 warning kernel : [51201.551136] [] (process_one_work) from [] (worker_thread+0x48/0x524)
03:16 warning kernel : [51201.559242] r10:c0760c12 r9:ee80b000 r8:00000088 r7:d16fbb98 r6:ee80b014 r5:ee80b000
03:16 warning kernel : [51201.567140] r4:d16fbb80
03:16 warning kernel : [51201.569689] [] (worker_thread) from [] (kthread+0x110/0x124)
03:16 warning kernel : [51201.577099] r10:00000000 r9:00000000 r8:00000000 r7:c003ea74 r6:d16fbb80 r5:00000000
03:16 warning kernel : [51201.584999] r4:c4942040
03:16 warning kernel : [51201.587548] [] (kthread) from [] (ret_from_fork+0x14/0x24)
03:16 warning kernel : [51201.594784] r7:00000000 r6:00000000 r5:c0043e24 r4:c4942040
03:16 alert kernel : [51201.600566] BUG: Bad page state in process kworker/u4:1 pfn:08870
03:16 notice kernel : act_skbedit act_mirred em_u32 cls_u32 cls_tcindex cls_flow cls_route cls_fw sch_hfsc sch_ingress ath10k_pci ath10k_core ath mac80211 cfg80211 compat ledtrig_usbdev ledtrig_oneshot xt_LED ledtrig_morse ledtrig_heartbeat ledtrig_gpio cryptodev xt_set ip_set_list_set ip_set_hash_netiface ip_set_hash_netport ip_set_hash_netnet ip_set_hash_net ip_set_hash_netportnet ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6t_REJECT nf_reject_ipv6 nf_log_ipv6 nf_log_common ip6table_raw ip6table_mangle ip6table_filter ip6_tables x_tables pppoatm ppp_generic slhc nfsd nfsv3 msdos ip_gre gre ifb ip6_udp_tunnel udp_tunnel sit ip6_tunnel tunnel6 tunnel4 ip_tunnel<4>[51201.922021] Hardware name: Marvell Armada 380/385 (Device Tree)
03:16 warning kernel : [51201.927958] Workqueue: btrfs-endio-write btrfs_endio_write_helper
03:16 warning kernel : [51201.934074] Backtrace:
03:16 warning kernel : [51201.936538] [] (dump_backtrace) from [] (show_stack+0x18/0x1c)
03:16 warning kernel : [51201.944123] r6:00000000 r5:60000013 r4:c076cd28 r3:00000006
03:16 warning kernel : [51201.949840] [] (show_stack) from [] (dump_stack+0x98/0xac)
03:16 warning kernel : [51201.957083] [] (dump_stack) from [] (bad_page+0xf0/0x150)
03:16 warning kernel : [51201.964232] r6:c075cd5c r5:c065029c r4:c07a5998 r3:00000000
03:16 warning kernel : [51201.969946] [] (bad_page) from [] (get_page_from_freelist+0x57c/0x924)
03:16 warning kernel : [51201.978227] r10:00000001 r9:c0760100 r8:eef2bfc0 r7:2e680000 r6:c075cd5c r5:c065029c
03:16 warning kernel : [51201.986124] r4:c06502b0 r3:00000001
03:16 warning kernel : [51201.989727] [] (get_page_from_freelist) from [] (__alloc_pages_nodemask+0x12c/0xa50)
03:16 warning kernel : [51201.999226] r10:00000002 r9:c0760b80 r8:02400840 r7:00000000 r6:c075cd5c r5:b6db6db7
03:16 warning kernel : [51202.007123] r4:00000000
03:16 warning kernel : [51202.009672] [] (__alloc_pages_nodemask) from [] (pagecache_get_page+0x78/0x1f0)
03:16 warning kernel : [51202.018736] r10:c0760ca2 r9:00026a53 r8:c075cf78 r7:00ac7c32 r6:ee592a24 r5:02400840
03:16 warning kernel : [51202.026633] r4:00000007
03:16 warning kernel : [51202.029184] [] (pagecache_get_page) from [] (alloc_extent_buffer+0xcc/0x3c8)
03:16 warning kernel : [51202.037987] r10:d1dc1bd0 r9:d1dc1bdc r8:00026a54 r7:00026a53 r6:ee592a24 r5:00000000
03:16 warning kernel : [51202.045885] r4:ef2bcfe0
03:16 warning kernel : [51202.048437] [] (alloc_extent_buffer) from [] (btrfs_find_create_tree_block+0x14/0x18)
03:16 warning kernel : [51202.058023] r10:edf2d0e8 r9:edf2d000 r8:ee4ae958 r7:00004000 r6:edfab800 r5:00000000
03:16 warning kernel : [51202.065922] r4:00000000
03:16 warning kernel : [51202.068471] [] (btrfs_find_create_tree_block) from [] (btrfs_alloc_tree_block+0x184/0x5e0)
03:16 warning kernel : [51202.078498] [] (btrfs_alloc_tree_block) from [] (__btrfs_cow_block+0x120/0x5e4)
03:16 warning kernel : [51202.087562] r10:d1dc17e0 r9:e73f6498 r8:ee4ae958 r7:edfab800 r6:00000000 r5:00000000
03:16 warning kernel : [51202.095459] r4:00000000
03:16 warning kernel : [51202.098007] [] (__btrfs_cow_block) from [] (btrfs_cow_block+0x12c/0x1b4)
03:16 warning kernel : [51202.106462] r10:00000001 r9:d1dc17e0 r8:edfab800 r7:00000000 r6:00000000 r5:00000000
03:16 warning kernel : [51202.114359] r4:00000000
03:16 warning kernel : [51202.116908] [] (btrfs_cow_block) from [] (btrfs_search_slot+0x1f4/0x964)
03:16 warning kernel : [51202.125363] r9:edfab800 r8:00000000 r7:00000000 r6:00000002 r5:00000001 r4:d0700fa0
03:16 warning kernel : [51202.133179] [] (btrfs_search_slot) from [] (btrfs_lookup_file_extent+0x5c/0x64)
03:16 warning kernel : [51202.142244] r10:00000000 r9:00000000 r8:d0700fa0 r7:00000001 r6:0003d80a r5:00000000
03:16 warning kernel : [51202.150140] r4:00036000
03:16 warning kernel : [51202.152691] [] (btrfs_lookup_file_extent) from [] (__btrfs_drop_extents+0x144/0xfa0)
03:16 warning kernel : [51202.162190] r7:00004000 r6:00000000 r5:ffffffff r4:00036000
03:16 warning kernel : [51202.167906] [] (__btrfs_drop_extents) from [] (insert_reserved_file_extent.constprop.12+0xb4/0x38c)
03:16 warning kernel : [51202.178711] r10:ee4ae958 r9:00000000 r8:00004000 r7:00004000 r6:00000000 r5:d0700fa0
03:16 warning kernel : [51202.186610] r4:db039138
03:16 warning kernel : [51202.189159] [] (insert_reserved_file_extent.constprop.12) from [] (btrfs_finish_ordered_io+0x3f4/0x780)
03:16 warning kernel : [51202.200311] r10:00000000 r9:ee4ae958 r8:edfab800 r7:db039138 r6:c1e352d0 r5:00000000
03:16 warning kernel : [51202.208209] r4:00004000
03:16 warning kernel : [51202.210757] [] (btrfs_finish_ordered_io) from [] (finish_ordered_fn+0x14/0x18)
03:16 warning kernel : [51202.219734] r10:c0760c12 r9:00000000 r8:00000000 r7:00000000 r6:edc595c0 r5:c1e3535c
03:16 warning kernel : [51202.227632] r4:c1e35350
03:16 warning kernel : [51202.230180] [] (finish_ordered_fn) from [] (normal_work_helper+0xa0/0x1b8)
03:16 warning kernel : [51202.238812] [] (normal_work_helper) from [] (btrfs_endio_write_helper+0x14/0x18)
03:16 warning kernel : [51202.247962] r10:c0760c12 r9:00000000 r8:00000000 r7:eddbd500 r6:ee80b000 r5:c1e3535c
03:16 warning kernel : [51202.255860] r4:d16fbb80 r3:c026bd5c
03:16 warning kernel : [51202.259464] [] (btrfs_endio_write_helper) from [] (process_one_work+0x140/0x358)
03:16 warning kernel : [51202.268618] [] (process_one_work) from [] (worker_thread+0x48/0x524)
03:16 warning kernel : [51202.276724] r10:c0760c12 r9:ee80b000 r8:00000088 r7:d16fbb98 r6:ee80b014 r5:ee80b000
03:16 warning kernel : [51202.284623] r4:d16fbb80
03:16 warning kernel : [51202.287172] [] (worker_thread) from [] (kthread+0x110/0x124)
03:16 warning kernel : [51202.294582] r10:00000000 r9:00000000 r8:00000000 r7:c003ea74 r6:d16fbb80 r5:00000000
03:16 warning kernel : [51202.302478] r4:c4942040
03:16 warning kernel : [51202.305027] [] (kthread) from [] (ret_from_fork+0x14/0x24)
03:16 warning kernel : [51202.312264] r7:00000000 r6:00000000 r5:c0043e24 r4:c4942040
lxc container not automatically starting on router boot with the container conf
lxc.start.auto = 1
lxc.group = onboot
lxc.start.delay = 10
lxc.start.order = 100
Installed lxc components
Summary
liblxc 1.1.5-15
luci-app-lxc 20160616-1
lxc 1.1.5-15
lxc-attach 1.1.5-15
lxc-auto 1.1.5-15
lxc-autostart 1.1.5-15
lxc-cgroup 1.1.5-15
lxc-checkconfig 1.1.5-15
lxc-clone 1.1.5-15
lxc-common 1.1.5-15
lxc-config 1.1.5-15
lxc-configs 1.1.5-15
lxc-console 1.1.5-15
lxc-create 1.1.5-15
lxc-destroy 1.1.5-15
lxc-device 1.1.5-15
lxc-execute 1.1.5-15
lxc-freeze 1.1.5-15
lxc-hooks 1.1.5-15
lxc-info 1.1.5-15
lxc-init 1.1.5-15
lxc-ls 1.1.5-15
lxc-lua 1.1.5-15
lxc-monitor 1.1.5-15
lxc-monitord 1.1.5-15
lxc-snapshot 1.1.5-15
lxc-start 1.1.5-15
lxc-stop 1.1.5-15
lxc-templates 1.1.5-15
lxc-unfreeze 1.1.5-15
lxc-unshare 1.1.5-15
lxc-user-nic 1.1.5-15
lxc-usernsexec 1.1.5-15
lxc-wait 1.1.5-15
rpcd-mod-lxc 20141012
since I wanted to give sentinel a run I thought of a TOS container being a good idea except the TOS container does not provide any iface on boot and only a cli busybox, basically an empty shell. Is this by design?
In comparison unbuntu cosmic, debian stretch, archlinux and alpinelinux are all booting with with ifaces up and provision of connectivity.
peci1
December 19, 2018, 8:38am
14
My LXC container set up by https://doc.turris.cz/doc/en/howto/lxc#starting_the_container_at_boot started automatically even after the upgrade.
vcunat
December 19, 2018, 10:38am
15
I think the bugfix updates (e.g. p
→ q
in this case) are designed as ABI-compatible , so I wouldn’t expect problems from that.
I think it’s common that distros don’t rebuild all transitive reverse dependencies. For security updates it’s quite desirable, as rebuilding a whole distro takes quite some time unless you have a very powerful farm.
I see now. How about the order of starting containers (lxc.start.order =
) and the delay (lxc.start.delay =
) in between the container starts?
[ It looks like that lxc version development has ceased at OpenWRT. Wondering about bug fixes and security patches missing since LXC master LTS development is currently at v3.0.03]
Is this a growing trend now with busybox
castrating userland apps?
lxc-ls -f
ls: unrecognized option: f
BusyBox v1.29.3 () multi-call binary.
Usage: ls [-1AaCxdLHRFplinshrSXvctu] [-w WIDTH] [FILE]…
Summary
List directory contents
-1 One column output
-a Include entries which start with .
-A Like -a, but exclude . and ..
-x List by lines
-d List directory entries instead of contents
-L Follow symlinks
-H Follow symlinks on command line
-R Recurse
-p Append / to dir entries
-F Append indicator (one of */=@|) to entries
-l Long listing format
-i List inode numbers
-n List numeric UIDs and GIDs instead of names
-s List allocated blocks
-lc List ctime
-lu List atime
--full-time List full date and time
-h Human readable sizes (1K 243M 2G)
--group-directories-first
-S Sort by size
-X Sort by extension
-v Sort by version
-t Sort by mtime
-tc Sort by ctime
-tu Sort by atime
-r Reverse sort order
-w N Format N columns wide
--color[={always,never,auto}] Control coloring
Curiously those log entries are not present here. Not sure whether it would make a difference, though it should not, this setup started out vanilla from medkit 3.11
vcunat
December 19, 2018, 1:06pm
19
AFAIK that’s how busybox always was. OpenWRT defaults (and busybox) might be a bit too size-focused if you have a powerful device like Turris. You can install coreutils-ls
in this case, for example (I haven’t tried but I expect it to be full).
