we have just pushed 3.10.8. It contains kernel update where we dropped a patch that could cause a panic in some circumstances. Apart from that just few minor updates. One of them is Nextcloud, but we are still sticking to 13 branch. Nextcloud 14 will be part of 3.11 release as it needs some tuning.
Full release notes are as follows:
kernel, nextcloud, btrfs-progs, php: update
kernel: drop blkio LED trigger as it was causing some issues from time to time
pakon: more robust database maintenance
In general, we donât expect any issues, but if you encounter any regressions, let us know.
Here openvpn (turris as openvpn server) stopped passing traffic correctly to LAN after update and reboot. No idea what could cause that because according to changelog nothing related to openvpn has changed.
After the update WiFi LEDs were out and radio0 (5 GHz) was missing in Foris; in Luci it was present as enabled but didnât broadcast. After reboot WiFi LEDs are on, both radios are present and enabled in Foris and LuCi, but radio1 (2.4 GHz) isnât broadcasting (Bitrate: ? Mbit/s). Another reboot didnât improve this situation. I didnât make any changes in WiFi configuration before enabling 3.10.8 update (nor in anything else). What am I supposed to do?
Update: about one hour later I saw both radios working
I have my /var/log/messages spammed by these log records.
2018-10-16 16:45:01 info /usr/sbin/cron[6701]: (root) CMD ( /usr/bin/notifier)
2018-10-16 16:45:01 info /usr/sbin/cron[6700]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-10-16 16:45:18 warning dnsmasq-dhcp[2897]: no address range available for DHCP request via br-guest_turris
2018-10-16 16:45:24 warning dnsmasq-dhcp[2543]: Last message 'no address range ava' repeated 1 times, suppressed by syslog-ng on turris
2018-10-16 16:45:24 warning dnsmasq-dhcp[2897]: no address range available for DHCP request via br-guest_turris
2018-10-16 16:45:31 warning dnsmasq-dhcp[2543]: Last message 'no address range ava' repeated 1 times, suppressed by syslog-ng on turris
2018-10-16 16:45:47 warning dnsmasq-dhcp[2897]: no address range available for DHCP request via br-guest_turris
2018-10-16 16:45:53 warning dnsmasq-dhcp[2543]: Last message 'no address range ava' repeated 1 times, suppressed by syslog-ng on turris
2018-10-16 16:45:53 warning dnsmasq-dhcp[2897]: no address range available for DHCP request via br-guest_turris
2018-10-16 16:46:01 warning dnsmasq-dhcp[2543]: Last message 'no address range ava' repeated 1 times, suppressed by syslog-ng on turris
2018-10-16 16:46:01 info /usr/sbin/cron[6778]: (root) CMD (nethist_stats.lua)
2018-10-16 16:46:01 info /usr/sbin/cron[6777]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-10-16 16:46:17 warning dnsmasq-dhcp[2897]: no address range available for DHCP request via br-guest_turris
2018-10-16 16:46:23 warning dnsmasq-dhcp[2543]: Last message 'no address range ava' repeated 1 times, suppressed by syslog-ng on turris
2018-10-16 16:46:23 warning dnsmasq-dhcp[2897]: no address range available for DHCP request via br-guest_turris
2018-10-16 16:46:31 warning dnsmasq-dhcp[2543]: Last message 'no address range ava' repeated 1 times, suppressed by syslog-ng on turris
2018-10-16 16:46:46 warning dnsmasq-dhcp[2897]: no address range available for DHCP request via br-guest_turris
2018-10-16 16:46:52 warning dnsmasq-dhcp[2543]: Last message 'no address range ava' repeated 1 times, suppressed by syslog-ng on turris
2018-10-16 16:46:52 warning dnsmasq-dhcp[2897]: no address range available for DHCP request via br-guest_turris
2018-10-16 16:47:01 warning dnsmasq-dhcp[2543]: Last message 'no address range ava' repeated 1 times, suppressed by syslog-ng on turris
2018-10-16 16:47:01 info /usr/sbin/cron[6830]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-10-16 16:47:15 warning dnsmasq-dhcp[2897]: no address range available for DHCP request via br-guest_turris
2018-10-16 16:47:21 warning dnsmasq-dhcp[2543]: Last message 'no address range ava' repeated 1 times, suppressed by syslog-ng on turris
2018-10-16 16:47:21 warning dnsmasq-dhcp[2897]: no address range available for DHCP request via br-guest_turris
2018-10-16 16:47:31 warning dnsmasq-dhcp[2543]: Last message 'no address range ava' repeated 1 times, suppressed by syslog-ng on turris
2018-10-16 16:47:44 warning dnsmasq-dhcp[2897]: no address range available for DHCP request via br-guest_turris
2018-10-16 16:47:50 warning dnsmasq-dhcp[2543]: Last message 'no address range ava' repeated 1 times, suppressed by syslog-ng on turris
2018-10-16 16:47:50 warning dnsmasq-dhcp[2897]: no address range available for DHCP request via br-guest_turris
2018-10-16 16:47:57 warning dnsmasq-dhcp[2897]: no address range available for DHCP request via br-guest_turris
Dobry den,
MĂĄm Turris v. 1 a po poslednĂm updatu nejde Lighttpd a tudĂĹž ani Luci.
KdyĹž spustĂm Lighttpd, tak se pĹĂkaz provede. V bÄĹžĂcĂch procesech ho vidĂm, co je zajĂmavĂŠ Ĺže log je naprosto prĂĄzdnĂ˝.
Nextcloud now shows a notification that the webserver is not set to resolve /.well-known/caldav and /.well-known/carddav. According to docs it could cause problems to some clients which canât find proper sync address. Although I am not using CalDAV or CardDAV clients I would like to know a resolution. I couldnât find out how to set proper redirection in lighttpd config. Anybody experiencing the same issue?
Naprosto stejnĂ˝ problĂŠm pozoruji uĹž od verze 3.10.6. Lighttpd nebÄŞà vĹŻbec, log prĂĄzdnĂ˝. Restart lighttpd nevypisuje Şådnou chybu a v procesech nenĂ vidÄt.
I have a problem with the resolution of the repos after updating
Iâll see if a reboot again fixes it
root@turris:~# pkgupdate
WARN:Couldnât read the status file: [string âbackendâ]:1173: [string âbackendâ]:1164: Failed to lock the lock file //var/lock/opkg.lock: Resource temporarily unavailable
line not found
line not found
line not found
ERROR:
unreachable: https://repo.turris.cz/omnia/lists/base.lua: Couldnât resolve host ârepo.turris.czâ
line not found
line not found
line not found
ERROR:
line not found
line not found
line not found
ERROR:
Nextcloud is missing 2 files in this update
.user.ini and .htaaccess and complains about Code integrity check failed in a same way as dscribed here:
My assumption is that 2 hidden files were forgotten and not inclded in the update:
Technical information
The following list covers which files have failed the integrity check. Please read
the previous linked documentation to learn more about the errors and how to fix
them.
