We just released bugfix release 3.10.1 into RC. Nothing big, mostly just fixes, but still we would be grateful if it gets some more community testing. Official release notes are as follows:
foris: support 6in4 and 6 to4
foris: ability to set protocol in VPN
kernel: update and UAS driver
foris-pakon: bug and compatibility fixes
odhcp6c: fix after update
netmetr: fix synchronization code
As always, if you encounter any new issue, let us know.
TO, nas, smb and tm. Everything seems to work fine.
Wi-Fi signal seems to be stronger.
Foris:
Wan > Connection test - Nice refinement.
Region and time > Update time - Shows (shifts time to) UTC? Itās that correct? So I didnāt try to Save changes.
Wi-Fi > eye - Nice feature.
uCollect & firewall log - Seems to work again.
Storage - What are this loops in Storage? Should I worry?
EDIT:
tech.support(at)turris.cz: "Iāve managed to reproduce your issue with the Storage plugin, when I installed kernel module kmod-loop. Weāll look why this kernel module causes it and if it can be solved.
In your case, as the fastest solution, I can recommend you to uninstall this kernel module and then restart your router, of course, if you donāt use it."
Awesome, that was fast. Iāll have to review the documentation to see if I installed it, or I can turn it off. thank you
About the āStorageā functionality ā¦ can anybody confirm if once itās configured, then other services like netmeter, pagon, proxy server, samba, etcā¦ will actually use it and store their data to that?
Or do you have to go in and manually reconfigure each of those additional services to actually use the āStorageā as configured?
